TDA4VM: How can a VISS node support two cameras with different resolutions on TDA4VM?
Part Number: TDA4VM
   TDA4VM does not support the establishment of two VISS nodes at the same time, but our system needs to run two cameras with different resolutions(1920×1080 、1280×960), we want to adopt the mode of one VISS node (as shown in the figure above), but we have a problem:
   The resolution of the tow types of cameras is different,resulting in the different size of the rawImage output by two CAPTURE nodes.So can't generate an object array as input to VISS node.Is there another solution?
