Part Number: AM5728
I'm working with an AM5728 custom board and have a KSZ9031RNX Ethernet Transceiver on board.
I use linux SDK "06.03.00.106"
In the log I have the following error
U-Boot SPL 2019.01-g323d51410c-dirty (Jun 24 2021 - 12:44:01 +0200)
DRA752-GP ES2.0
** Unable to read file dra7-ipu1-fw.xem4 **
Firmware loading failed
Trying to boot from MMC1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
Loading Environment from MMC... OK
U-Boot 2019.01-g323d51410c-dirty (Jun 24 2021 - 12:44:05 +0200)
CPU : DRA752-GP ES2.0
Model: TI AM5728 BeagleBoard-X15
Board: BeagleBoard X15 REV
DRAM: 2 GiB
MMC: omap_hsmmc_init_setup: timedout waiting for cc2!
mmc@480ad000 - probe failed: -110
OMAP SD/MMC: 0, OMAP SD/MMC: 1omap_hsmmc_init_setup: timedout waiting for cc2!
Warning: fastboot.board_rev: unknown board revision
Net: Could not get PHY for ethernet@48484000: addr 4
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
1494 bytes read in 1 ms (1.4 MiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
4444672 bytes read in 209 ms (20.3 MiB/s)
90623 bytes read in 6 ms (14.4 MiB/s)
Loading Device Tree to 8ffe6000, end 8ffff1fe ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.94-gbe5389fd85 (michele@michele-VirtualBox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #2 SMP PREEMPT Wed Jun 23 17:51:34 CEST 2021
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5728 BeagleBoard-X15
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[ 0.000000] OMAP4: Map 0x00000000ffd00000 to (ptrval) for dram barrier
[ 0.000000] Hit pending asynchronous external abort (FSR=0x00001211) during first unmask, this is most likely caused by a firmware/bootloader bug.
[ 0.000000] DRA752 ES2.0
[ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
[ 0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 464192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=10bec367-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1673060K/1863680K available (10240K kernel code, 334K rwdata, 2792K rodata, 2048K init, 268K bss, 34972K reserved, 155648K cma-reserved, 1283072K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 335 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 269 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000019] Switching to timer-based delay loop, resolution 162ns
[ 0.000294] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000303] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000741] Console: colour dummy device 80x30
[ 0.000784] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000799] pid_max: default: 32768 minimum: 301
[ 0.000919] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000934] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001495] CPU: Testing write buffer coherency: ok
[ 0.001532] CPU0: Spectre v2: using ICIALLU workaround
[ 0.001747] /cpus/cpu@0 missing clock-frequency property
[ 0.001767] /cpus/cpu@1 missing clock-frequency property
[ 0.001781] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.059923] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.079934] rcu: Hierarchical SRCU implementation.
[ 0.100126] EFI services will not be available.
[ 0.119994] smp: Bringing up secondary CPUs ...
[ 0.200380] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.200386] CPU1: Spectre v2: using ICIALLU workaround
[ 0.200506] smp: Brought up 1 node, 2 CPUs
[ 0.200518] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.200527] CPU: All CPU(s) started in HYP mode.
[ 0.200535] CPU: Virtualization extensions available.
[ 0.201093] devtmpfs: initialized
[ 0.217428] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.217684] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.217703] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.220331] pinctrl core: initialized pinctrl subsystem
[ 0.220853] DMI not present or invalid.
[ 0.221127] NET: Registered protocol family 16
[ 0.222261] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.223195] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.330041] wkupaon_cm:clk:0068:0: failed to disable
[ 0.429541] cpuidle: using governor ladder
[ 0.429576] cpuidle: using governor menu
[ 0.430973] ------------[ cut here ]------------
[ 0.430995] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
[ 0.431006] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER1_P3 (Read): Data Access in User mode during Functional access
[ 0.431015] Modules linked in:
[ 0.431030] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.94-gbe5389fd85 #2
[ 0.431039] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.431046] Backtrace:
[ 0.431065] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
[ 0.431078] r7:c0dfd06c r6:60000193 r5:00000000 r4:c125039c
[ 0.431094] [<c020cd54>] (show_stack) from [<c0a11664>] (dump_stack+0x9c/0xb0)
[ 0.431109] [<c0a115c8>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
[ 0.431121] r7:c0dfd06c r6:00000009 r5:00000000 r4:ee88f8ec
[ 0.431133] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
[ 0.431145] r9:ee9d29c0 r8:f0882164 r7:c0dfcf98 r6:c0dfced8 r5:c0dfd03c r4:c1204c48
[ 0.431159] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
[ 0.431168] r3:ee9d8d80 r2:c0dfd03c
[ 0.431177] r5:00000002 r4:80080003
[ 0.431194] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
[ 0.431206] r10:c1251fb8 r9:ee9d9f00 r8:00000017 r7:ee88fa18 r6:00000000 r5:ee9d9f68
[ 0.431215] r4:ee9df200
[ 0.431229] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
[ 0.431242] r10:60000013 r9:ee88e000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
[ 0.431249] r4:c1204c48
[ 0.431264] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
[ 0.431274] r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
[ 0.431288] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
[ 0.431298] r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
[ 0.431311] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
[ 0.431321] r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
[ 0.431335] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
[ 0.431349] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
[ 0.431361] r9:ee88e000 r8:fa213000 r7:ee88fae0 r6:fa212000 r5:fa21200c r4:c1205104
[ 0.431374] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
[ 0.431383] Exception stack(0xee88fae0 to 0xee88fb28)
[ 0.431394] fae0: ee9d9f68 60000013 00000004 00000005 ee9d9f00 ee9df200 00000000 00000017
[ 0.431406] fb00: ee9d9fd0 ee9d9f68 60000013 ee88fb3c ee88fb40 ee88fb30 c028b9ec c0a2bb5c
[ 0.431414] fb20: 60000013 ffffffff
[ 0.431426] r9:ee88e000 r8:ee9d9fd0 r7:ee88fb14 r6:ffffffff r5:60000013 r4:c0a2bb5c
[ 0.431442] [<c0a2bb34>] (_raw_spin_unlock_irqrestore) from [<c028b9ec>] (__setup_irq+0x3bc/0x718)
[ 0.431457] [<c028b630>] (__setup_irq) from [<c028beb8>] (request_threaded_irq+0xe0/0x154)
[ 0.431469] r10:ee9d9f14 r9:00000000 r8:00000017 r7:00000000 r6:ee9d9f00 r5:00000000
[ 0.431477] r4:ee9df200
[ 0.431492] [<c028bdd8>] (request_threaded_irq) from [<c028e7d4>] (devm_request_threaded_irq+0x70/0xc4)
[ 0.431503] r10:00000000 r9:c0566dec r8:eea12e10 r7:00000017 r6:ee9d29c0 r5:ee9d2cc0
[ 0.431512] r4:c0dfce08 r3:00000000
[ 0.431525] [<c028e764>] (devm_request_threaded_irq) from [<c0567340>] (omap_l3_probe+0x1d4/0x27c)
[ 0.431537] r10:00000002 r9:ee9d29c0 r8:eea12e10 r7:c12887ac r6:00000008 r5:ee9d29c0
[ 0.431544] r4:00000000
[ 0.431561] [<c056716c>] (omap_l3_probe) from [<c06c7e60>] (platform_drv_probe+0x50/0xa0)
[ 0.431572] r10:00000000 r9:c122425c r8:00000000 r7:00000000 r6:c122425c r5:00000000
[ 0.431580] r4:eea12e10
[ 0.431594] [<c06c7e10>] (platform_drv_probe) from [<c06c5eb0>] (really_probe+0x204/0x2c0)
[ 0.431604] r7:00000000 r6:c128d648 r5:eea12e10 r4:c128d644
[ 0.431617] [<c06c5cac>] (really_probe) from [<c06c6110>] (driver_probe_device+0x68/0x180)
[ 0.431629] r10:00000000 r9:c128d620 r8:00000001 r7:c06c6320 r6:eea12e10 r5:c122425c
[ 0.431637] r4:eea12e10 r3:00000000
[ 0.431651] [<c06c60a8>] (driver_probe_device) from [<c06c63c4>] (__device_attach_driver+0xa4/0xc8)
[ 0.431663] r9:c128d620 r8:00000001 r7:c06c6320 r6:eea12e10 r5:ee88fd04 r4:c122425c
[ 0.431676] [<c06c6320>] (__device_attach_driver) from [<c06c4068>] (bus_for_each_drv+0x88/0xcc)
[ 0.431686] r7:c06c6320 r6:ee88fd04 r5:c1204c48 r4:00000000
[ 0.431699] [<c06c3fe0>] (bus_for_each_drv) from [<c06c5c2c>] (__device_attach+0xd8/0x140)
[ 0.431709] r7:c1236ee8 r6:eea12e44 r5:c1204c48 r4:eea12e10
[ 0.431722] [<c06c5b54>] (__device_attach) from [<c06c6434>] (device_initial_probe+0x14/0x18)
[ 0.431732] r8:eea12e10 r7:c1236ee8 r6:c1237090 r5:eea12e10 r4:eea12e18
[ 0.431745] [<c06c6420>] (device_initial_probe) from [<c06c4f94>] (bus_probe_device+0x8c/0x94)
[ 0.431757] [<c06c4f08>] (bus_probe_device) from [<c06c1af8>] (device_add+0x37c/0x620)
[ 0.431767] r7:c1236ee8 r6:00000000 r5:c1204c48 r4:eea12e18
[ 0.431782] [<c06c177c>] (device_add) from [<c0859770>] (of_device_add+0x3c/0x44)
[ 0.431793] r10:00000000 r9:c1213418 r8:00000000 r7:eed7616c r6:00000000 r5:00000000
[ 0.431801] r4:eea12e00
[ 0.431815] [<c0859734>] (of_device_add) from [<c0859cf4>] (of_platform_device_create_pdata+0x98/0xc0)
[ 0.431830] [<c0859c5c>] (of_platform_device_create_pdata) from [<c0859f1c>] (of_platform_bus_create+0x1a4/0x248)
[ 0.431841] r9:c1213418 r8:c1213418 r7:00000000 r6:00000000 r5:c1204c48 r4:eed7611c
[ 0.431855] [<c0859d78>] (of_platform_bus_create) from [<c085a138>] (of_platform_populate+0x74/0xd4)
[ 0.431867] r10:00000001 r9:00000000 r8:c1213418 r7:c1053ccc r6:00000000 r5:eed7461c
[ 0.431874] r4:eed7611c
[ 0.431889] [<c085a0c4>] (of_platform_populate) from [<c100f5c8>] (pdata_quirks_init+0x78/0x88)
[ 0.431901] r10:c1060768 r9:c104b828 r8:00000000 r7:c1003ca0 r6:ffffe000 r5:c1204c48
[ 0.431908] r4:c1053ccc
[ 0.431921] [<c100f550>] (pdata_quirks_init) from [<c100f4d4>] (omap_generic_init+0x18/0x20)
[ 0.431929] r5:c1204c48 r4:c1253ac0
[ 0.431943] [<c100f4bc>] (omap_generic_init) from [<c1003cc8>] (customize_machine+0x28/0x30)
[ 0.431957] [<c1003ca0>] (customize_machine) from [<c02025b8>] (do_one_initcall+0x84/0x1b0)
[ 0.431969] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
[ 0.431980] r8:c104b848 r7:c10004f0 r6:c1253ac0 r5:c1253ac0 r4:00000004
[ 0.431995] [<c1000e24>] (kernel_init_freeable) from [<c0a25978>] (kernel_init+0x10/0x11c)
[ 0.432006] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a25968
[ 0.432014] r4:00000000
[ 0.432027] [<c0a25968>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
[ 0.432035] Exception stack(0xee88ffb0 to 0xee88fff8)
[ 0.432045] ffa0: 00000000 00000000 00000000 00000000
[ 0.432055] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.432066] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 0.432075] r5:c0a25968 r4:00000000
[ 0.432086] ---[ end trace 23a5d0ef30e1198d ]---
[ 0.441136] OMAP GPIO hardware version 0.1
[ 0.465570] No ATAGs?
[ 0.465642] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.465658] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.466494] OMAP DMA hardware revision 0.0
[ 0.478058] edma 43300000.edma: memcpy is disabled
[ 0.481463] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.488535] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.489316] evm_5v0: supplied by main_12v0
[ 0.492683] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.492859] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.493099] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.493352] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.493719] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.493899] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.494171] iommu: Adding device 58820000.ipu to group 1
[ 0.494251] iommu: Adding device 55020000.ipu to group 2
[ 0.494380] iommu: Adding device 40800000.dsp to group 0
[ 0.494607] iommu: Adding device 41000000.dsp to group 3
[ 0.495812] SCSI subsystem initialized
[ 0.496854] palmas 0-0058: Irq flag is 0x00000008
[ 0.523303] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0
[ 0.524904] SMPS12: supplied by regulator-dummy
[ 0.526562] SMPS3: supplied by regulator-dummy
[ 0.528181] SMPS45: supplied by regulator-dummy
[ 0.529969] SMPS6: supplied by regulator-dummy
[ 0.531360] SMPS7: supplied by regulator-dummy
[ 0.532728] SMPS8: supplied by regulator-dummy
[ 0.533952] SMPS9: supplied by regulator-dummy
[ 0.534393] random: fast init done
[ 0.534635] LDO1: supplied by regulator-dummy
[ 0.541168] LDO2: supplied by regulator-dummy
[ 0.551173] LDO3: supplied by regulator-dummy
[ 0.561187] LDO4: supplied by regulator-dummy
[ 0.571201] LDO5: supplied by regulator-dummy
[ 0.571878] LDO6: supplied by regulator-dummy
[ 0.572552] LDO7: supplied by regulator-dummy
[ 0.573219] LDO8: supplied by regulator-dummy
[ 0.573909] LDO9: supplied by regulator-dummy
[ 0.581233] LDOLN: supplied by regulator-dummy
[ 0.591246] LDOUSB: supplied by regulator-dummy
[ 0.603622] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.604227] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.604421] media: Linux media interface: v0.10
[ 0.604463] videodev: Linux video capture interface: v2.00
[ 0.604538] pps_core: LinuxPPS API ver. 1 registered
[ 0.604548] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.604569] PTP clock support registered
[ 0.604598] EDAC MC: Ver: 3.0.0
[ 0.605366] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.605623] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.610816] Advanced Linux Sound Architecture Driver Initialized.
[ 0.611597] clocksource: Switched to clocksource arch_sys_counter
[ 0.619912] NET: Registered protocol family 2
[ 0.620523] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.620609] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.620742] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.620871] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.620945] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.620980] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.621113] NET: Registered protocol family 1
[ 0.641551] RPC: Registered named UNIX socket transport module.
[ 0.641562] RPC: Registered udp transport module.
[ 0.641571] RPC: Registered tcp transport module.
[ 0.641580] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.642626] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.642821] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.643791] Initialise system trusted keyrings
[ 0.643922] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.648909] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.659410] NFS: Registering the id_resolver key type
[ 0.659438] Key type id_resolver registered
[ 0.659447] Key type id_legacy registered
[ 0.659489] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.661147] Key type asymmetric registered
[ 0.661158] Asymmetric key parser 'x509' registered
[ 0.661207] bounce: pool size: 64 pages
[ 0.661240] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.661251] io scheduler noop registered
[ 0.661261] io scheduler deadline registered
[ 0.661363] io scheduler cfq registered (default)
[ 0.661374] io scheduler mq-deadline registered
[ 0.661384] io scheduler kyber registered
[ 0.667098] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[ 0.670983] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
[ 0.671404] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 0.671445] dra7-pcie 51000000.pcie: IO 0x20003000..0x20012fff -> 0x00000000
[ 0.671473] dra7-pcie 51000000.pcie: MEM 0x20013000..0x2fffffff -> 0x20013000
[ 1.671810] dra7-pcie 51000000.pcie: Phy link never came up
[ 1.671949] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.671964] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.671976] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.671989] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.677742] PCI: bus0: Fast back to back transfers disabled
[ 1.683023] PCI: bus1: Fast back to back transfers enabled
[ 1.683066] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[ 1.683087] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.683413] pcieport 0000:00:00.0: Signaling PME with IRQ 171
[ 1.683542] pcieport 0000:00:00.0: AER enabled with IRQ 171
[ 1.687201] vdd_3v3: supplied by regen1
[ 1.687444] aic_dvdd_fixed: supplied by vdd_3v3
[ 1.687511] vtt_fixed: supplied by smps3
[ 1.736981] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 1.740627] console [ttyS2] disabled
[ 1.740687] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
[ 3.488484] console [ttyS2] enabled
[ 3.494125] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 3.494666] random: crng init done
[ 3.503982] omapdss_dss 58000000.dss: Linked as a consumer to regulator.22
[ 3.511004] DSS: OMAP DSS rev 6.1
[ 3.517335] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.16
[ 3.524870] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.16
[ 3.544773] brd: module loaded
[ 3.554130] loop: module loaded
[ 3.561442] libphy: Fixed MDIO Bus: probed
[ 3.569030] davinci_mdio: probe of 48485000.mdio failed with error -22
[ 3.576114] cpsw 48484000.ethernet: Detected MACID = d8:a9:8b:4c:29:48
[ 3.582772] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 3.589157] cpsw 48484000.ethernet: ALE Table size 1024
[ 3.594473] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 3.602974] i2c /dev entries driver
[ 3.609543] gpio-fan gpio_fan: GPIO fan initialized
[ 3.615135] tmp102 0-0048: error reading config register
[ 3.620571] tmp102: probe of 0-0048 failed with error -121
[ 3.629134] cpu cpu0: Linked as a consumer to regulator.6
[ 3.634666] cpu cpu0: Linked as a consumer to regulator.29
[ 3.641990] sdhci: Secure Digital Host Controller Interface driver
[ 3.648219] sdhci: Copyright(c) Pierre Ossman
[ 3.653570] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.659903] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 3.668780] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 3.673587] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.28
[ 3.680609] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.13
[ 3.687769] sdhci-omap 4809c000.mmc: Dropping the link to regulator.13
[ 3.694555] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.13
[ 3.701976] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[ 3.735525] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 3.743222] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.3
[ 3.750028] sdhci-omap 480b4000.mmc: Dropping the link to regulator.3
[ 3.756601] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.3
[ 3.763512] sdhci-omap 480b4000.mmc: no pinctrl state for ddr_3_3v mode
[ 3.796013] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 3.803754] sdhci-omap 480ad000.mmc: Linked as a consumer to regulator.3
[ 3.810718] sdhci-omap 480ad000.mmc: Dropping the link to regulator.3
[ 3.817392] sdhci-omap 480ad000.mmc: Linked as a consumer to regulator.3
[ 3.829578] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.839570] mmc0: new high speed SDHC card at address b368
[ 3.850318] mmc2: SDHCI controller on 480ad000.mmc [480ad000.mmc] using PIO
[ 3.855625] mmcblk0: mmc0:b368 CBADS 15.0 GiB
[ 3.863262] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.873411] mmcblk0: p1 p2
[ 3.874386] mmc1: new high speed MMC card at address 0001
[ 3.876926] NET: Registered protocol family 10
[ 3.887214] Segment Routing with IPv6
[ 3.890933] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.892437] mmcblk1: mmc1:0001 DG4032 14.0 GiB
[ 3.897275] NET: Registered protocol family 17
[ 3.901871] mmcblk1boot0: mmc1:0001 DG4032 partition 1 4.00 MiB
[ 3.906077] Key type dns_resolver registered
[ 3.912249] mmcblk1boot1: mmc1:0001 DG4032 partition 2 4.00 MiB
[ 3.916206] Registering SWP/SWPB emulation handler
[ 3.922166] mmcblk1rpmb: mmc1:0001 DG4032 partition 3 4.00 MiB, chardev (244:0)
[ 3.926896] omap_voltage_late_init: Voltage driver support not added
[ 3.934843] mmcblk1: p1 p2
[ 3.940620] Power Management for TI OMAP4+ devices.
[ 3.948859] Loading compiled-in X.509 certificates
[ 3.971186] dmm 4e000000.dmm: workaround for errata i878 in use
[ 3.978451] dmm 4e000000.dmm: initialized all PAT entries
[ 3.984815] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.16
[ 3.992321] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.16
[ 4.000552] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.16
[ 4.008312] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 4.016310] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 4.025029] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.030105] mmc2: new high speed MMC card at address 0001
[ 4.031686] [drm] No driver support for vblank timestamp query.
[ 4.031709] [drm] Cannot find any crtc or sizes
[ 4.047732] mmcblk2: mmc2:0001 DG4032 14.0 GiB
[ 4.052823] mmcblk2boot0: mmc2:0001 DG4032 partition 1 4.00 MiB
[ 4.058934] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[ 4.059169] mmcblk2boot1: mmc2:0001 DG4032 partition 2 4.00 MiB
[ 4.072207] mmcblk2rpmb: mmc2:0001 DG4032 partition 3 4.00 MiB, chardev (244:1)
[ 4.072419] hctosys: unable to open rtc device (rtc0)
[ 4.081521] mmcblk2: p1
[ 4.085265] ALSA device list:
[ 4.090149] No soundcards found.
[ 4.186568] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.194738] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 4.209181] devtmpfs: mounted
[ 4.213305] Freeing unused kernel memory: 2048K
[ 4.217981] Run /sbin/init as init process
[ 4.735314] systemd[1]: System time before build time, advancing clock.
[ 4.813251] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.835241] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 10 (buster)!
[ 4.872438] systemd[1]: Set hostname to <beaglebone>.
[ 5.051692] [drm] Cannot find any crtc or sizes
[ 5.118842] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 5.136001] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 5.326572] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 5.362002] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 5.377051] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.411949] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 5.452155] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
Starting Load Kernel Modules...
[ OK ] Reached target Swap.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Created slice User and Session Slice.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on Syslog Socket.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on initctl Compatibility Named Pipe.
Mounting /sys/kernel/debug...
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Paths.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Listening on udev Control Socket.
Starting udev Coldplug all Devices...
Starting Journal Service...
[ OK ] Listening on fsck to fsckd communication Socket.
Starting Remount Root and Kernel File Systems...
Mounting POSIX Message Queue File System...
[ 6.035629] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ OK ] Reached target Slices.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Journal Service.
[ OK ] Mounted /sys/kernel/debug.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Mounted POSIX Message Queue File System.
Starting Load/Save Random Seed...
Starting Create System Users...
Starting Flush Journal to Persistent Storage...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create System Users.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ 6.509011] systemd-journald[99]: Received request to flush runtime journal from PID 1
Starting Create Static Device Nodes in /dev...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
Starting Helper to synchronize boot up for ifupdown...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Helper to synchronize boot up for ifupdown.
Starting Raise network interfaces...
[ OK ] Started Entropy daemon using the HAVEGE algorithm.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ 7.798717] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver
[ OK ] Reached target System Initialization.
[ 7.827861] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver
[ OK ] Listening on D-Bus System Message Bu[ 7.844463] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
s Socket.
[ OK ] Reached target Sockets.
[ 7.882529] remoteproc remoteproc0: 58820000.ipu is available
[ 7.903172] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver
[ OK ] Reached target Basic System.
[ 7.912610] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 7.943961] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver
[[ 7.953870] remoteproc remoteproc0: powering up 58820000.ipu
OK ] Started Regular background program p[ 7.964952] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
rocessing daemon.
[ 7.977436] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[ 7.999274] remoteproc remoteproc0: request_firmware failed: -2
[ 8.008819] remoteproc remoteproc1: 55020000.ipu is available
Starting System Logging Service...
[ 8.021779] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver
[ 8.029968] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver
[ 8.038134] remoteproc remoteproc1: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
Starting LSB: Load kernel …d to enable cpufreq scaling...
[ 8.064238] remoteproc remoteproc1: powering up 55020000.ipu
[ 8.077870] remoteproc remoteproc1: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
Starting Login Service...
[ 8.101703] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 8.109839] remoteproc remoteproc2: 40800000.dsp is available
[[ 8.123742] remoteproc remoteproc1: request_firmware failed: -2
OK ] Started Daily Cleanup of Temporary Directories.
[ 8.135664] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver
[ 8.146393] remoteproc remoteproc2: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
[ OK ] Started D-Bus System Message Bus.
[ 8.221563] remoteproc remoteproc2: powering up 40800000.dsp
Starting WPA supplicant...
[ 8.234105] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver
Starting Connection service...
[ 8.274910] remoteproc remoteproc2: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
[ OK ] Reached target System Time Synchronized.
[ 8.323841] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[ OK ] Started Daily rotation of log files remoteproc remoteproc2: request_firmware failed: -2
[0m.
[ OK ] Reached target Timers.
[ 8.415039] remoteproc remoteproc3: 41000000.dsp is available
[ 8.418426] remoteproc remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[ 8.418435] remoteproc remoteproc3: powering up 41000000.dsp
[ 8.418457] remoteproc remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[ 8.418464] remoteproc remoteproc3: request_firmware failed: -2
[ 8.612171] Driver for 1-wire Dallas network protocol.
[ 8.616418] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 8.647029] rtc-ds1307: probe of 2-006f failed with error -121
[ 8.647606] omap-des 480a5000.des: will run requests pump with realtime priority
[ 8.691646] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode
[ OK ] Started System Logging Service.
[ OK ] Started Raise network interfaces.
[ 8.805519] tlv320aic3x-codec 0-0018: Linked as a consumer to regulator.3
[ 8.824459] tlv320aic3x-codec 0-0018: Linked as a consumer to regulator.4
[ OK ] Found device /dev/ttyS2.
[ 8.917486] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d
[ 8.976093] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as rtc1
[ OK ] Started Connection service.
[ OK ] Started Login Service.
[ 9.027871] w1_master_driver w1_bus_master1: Family 1 for 01.000000000000.3d is not registered.
[ OK ] Started WPA supplicant.
[ 9.098855] omap_rtc 48838000.rtc: registered as rtc2
[ 9.389790] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 9.396520] vpe 489d0000.vpe: Direct firmware load for vpdma-1b8.bin failed with error -2
[ 9.424111] vpe 489d0000.vpe: couldn't get firmware
[ 9.526832] ahci 4a140000.sata: controller can't do 64bit DMA, forcing 32bit
[ 9.556681] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 9.578483] phy phy-4a084000.phy.3: Linked as a consumer to regulator.23
[ 9.605169] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
[ 9.614304] phy phy-4a085000.phy.4: Linked as a consumer to regulator.23
[ 9.622762] net eth0: initializing cpsw version 1.15 (0)
[ 9.631034] net eth0: phy "/ocp/ethernet@48484000/mdio@48485000/ethernet-phy@1" not found on slave 0
[ 9.654902] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 9.698962] ahci 4a140000.sata: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
[ 9.714075] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 9.724378] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.782936] scsi host0: ahci
[ 9.787988] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 81
[ OK ] Started LSB: Load kernel m…ded to enable cpufreq scaling.
[ 9.831011] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 9.861109] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 9.951455] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 9.963274] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ 10.156186] ata1: SATA link down (SStatus 0 SControl 300)
[ 10.421860] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[ 10.431129] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name!
[ 10.934987] dwc3 48890000.usb: Failed to get clk 'ref': -2
[ 10.979462] remoteproc remoteproc4: 4b234000.pru is available
[ 11.012170] pru-rproc 4b234000.pru: PRU rproc node pru@4b234000 probed successfully
[ 11.038212] dwc3 488d0000.usb: Failed to get clk 'ref': -2
[ 11.054279] remoteproc remoteproc5: 4b238000.pru is available
[ 11.074529] pru-rproc 4b238000.pru: PRU rproc node pru@4b238000 probed successfully
[ 11.111361] remoteproc remoteproc6: 4b2b4000.pru is available
[ 11.126658] pru-rproc 4b2b4000.pru: PRU rproc node pru@4b2b4000 probed successfully
[ 11.142459] usbcore: registered new interface driver usbfs
[ 11.162964] usbcore: registered new interface driver hub
[ 11.172849] remoteproc remoteproc7: 4b2b8000.pru is available
[ 11.186218] usbcore: registered new device driver usb
[ 11.201790] pru-rproc 4b2b8000.pru: PRU rproc node pru@4b2b8000 probed successfully
[ 11.239655] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 11.261997] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 11.283489] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[ 11.306682] xhci-hcd xhci-hcd.1.auto: irq 182, io mem 0x48890000
[ 11.362202] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 11.370507] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.456734] usb usb1: Product: xHCI Host Controller
[ 11.472320] usb usb1: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd
[ 11.502693] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 11.511916] hub 1-0:1.0: USB hub found
[ 11.522566] hub 1-0:1.0: 1 port detected
[ 11.542015] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 11.556115] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 11.581783] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 11.601936] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 11.626362] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 11.661934] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.684661] usb usb2: Product: xHCI Host Controller
[ 11.705496] usb usb2: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd
[ 11.715308] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 11.722556] hub 2-0:1.0: USB hub found
[ 11.726352] hub 2-0:1.0: 1 port detected
[ OK ] Reached target Sound Card.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Hostname Service...
Starting LSB: set CPUFreq kernel parameters...
[ OK ] Reached target Network.
Starting Permit User Sessions...
Starting Generic Board Startup...
Starting OpenBSD Secure Shell server...
[ OK ] Started Permit User Sessions.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Getty on tty1.
[ OK ] Started Hostname Service.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started LSB: set CPUFreq kernel parameters.
[ 14.847422] using random self ethernet address
[ 14.851965] using random host ethernet address
[ 14.871855] using random self ethernet address
[ 14.876328] using random host ethernet address
[ OK ] Found device /dev/ttyGS0.
[ 14.921990] usb0: HOST MAC d8:a9:8b:4c:29:4b
[ 14.926344] usb0: MAC d8:a9:8b:4c:29:4c
[ 14.930686] usb1: HOST MAC d8:a9:8b:4c:29:4d
[ OK ] Started Serial Getty on ttyGS0.
[ 14.957770] usb1: MAC d8:a9:8b:4c:29:4e
[ OK ] Reached target Login Prompts.
[ 15.053791] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 15.084370] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
Starting dnsmasq - A light…DHCP and caching DNS server...
[ OK ] Started dnsmasq - A lightw…t DHCP and caching DNS server.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started Generic Board Startup.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
Debian GNU/Linux 10 beaglebone ttyS2
BeagleBoard.org Debian Buster Console Image 2020-04-06
Support: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
beaglebone login: root
Password:
Last login: Thu Feb 14 10:12:19 UTC 2019 on ttyS2
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@beaglebone:~#
root@beaglebone:~# ifconfig
eth0: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC> mtu 1500
ether d8:a9:8b:4c:29:48 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 88
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 80 bytes 6480 (6.3 KiB)
TX packets 80 bytes 6480 (6.3 KiB)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.7.2 netmask 255.255.255.0 broadcast 192.168.7.255
ether d8:a9:8b:4c:29:4c txqueuelen 1000 (Ethernet)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.6.2 netmask 255.255.255.0 broadcast 192.168.6.255
ether d8:a9:8b:4c:29:4e txqueuelen 1000 (Ethernet)
root@beaglebone:~# if up tth0
> [ 34.411653] aic_dvdd_fixed: disabling
^C
root@beaglebone:~# if up eth0
> ^C
root@beaglebone:~# ifup eth0
ifup: unknown interface eth0
root@beaglebone:~#
I tried to see if the interface works in u-Boot:
From what I see it looks like it communicates the interface
=> dhcp
=> dhcp
=> dhcp
=> mii dump 0 0
0. (1140) -- PHY control register --
(8000:0000) 0.15 = 0 reset
(4000:0000) 0.14 = 0 loopback
(2040:0040) 0. 6,13 = b10 speed selection = 1000 Mbps
(1000:1000) 0.12 = 1 A/N enable
(0800:0000) 0.11 = 0 power-down
(0400:0000) 0.10 = 0 isolate
(0200:0000) 0. 9 = 0 restart A/N
(0100:0100) 0. 8 = 1 duplex = full
(0080:0000) 0. 7 = 0 collision test enable
(003f:0000) 0. 5- 0 = 0 (reserved)
=> mii device
MII devices: 'ethernet@48484000'
Current device: 'ethernet@48484000'
=> mii info 0
PHY 0x00: OUI = 0x0885, Model = 0x22, Rev = 0x02, 1000baseT, FDX
=> mdio read 0
Reading from bus ethernet@48484000
PHY at address 0:
0 - 0x1140
=> mii dump 0 0
=> mdio read 0x1f
PHY at address 0:
31 - 0x349
=> mdio read 0x20
PHY at address 0:
Error
=> mdio rx ethernet@48484000 1.15
ethernet@48484000 is not a known ethernet
mdio - MDIO utility commands
Usage:
mdio list - List MDIO buses
mdio read <phydev> [<devad>.]<reg> - read PHY's register at <devad>.<reg>
mdio write <phydev> [<devad>.]<reg> <data> - write PHY's register at <devad>.<reg>
mdio rx <phydev> [<devad>.]<reg> - read PHY's extended register at <devad>.<reg>
mdio wx <phydev> [<devad>.]<reg> <data> - write PHY's extended register at <devad>.<reg>
<phydev> may be:
<busname> <addr>
<addr>
<eth name>
<addr> <devad>, and <reg> may be ranges, e.g. 1-5.4-0x1f.
DRA752-GP ES2.0
DRAM: 2 GiB
=> mii write 0x462 0xd 0x1F
Incorrect PHY address. Range should be 0-31
mii - MII utility commands
Usage:
mii device - list available devices
mii device <devname> - set current device
mii info <addr> - display MII PHY info
mii read <addr> <reg> - read MII PHY <addr> register <reg>
mii write <addr> <reg> <data> - write MII PHY <addr> register <reg>
mii modify <addr> <reg> <data> <mask> - modify MII PHY <addr> register <reg>
updating bits identified in <mask>
mii dump <addr> <reg> - pretty-print <addr> <reg> (0-5 only)
Addr and/or reg may be ranges, e.g. 2-7.
Usage:
Usage:
Usage:
=> mii write <addr> 0xd 0x1F
=> mii write <addr> 0xe 0x462
=> mii write <addr> 0xd 0x401F
=> mii read <addr> 0xd
401F
