66AK2G12: UART baremetal programming . Error #18 expected a ")"
Part Number: 66AK2G12
I'm currently working on 66AK2G12 and I'm  trying to create a Bare metal UART programming using CSL API drivers. when I'm trying to build the code I'm getting error #18 expected a ")".
Have attached the error console log and the project file for your reference.  Thanks in adavance.
  • Attaching the project file , console log and the erroe snap shot.
    uart_baremetal.rar
    code composer studio version - CCS V9.3.0
  • Hi Nandini,
    My name is Andrew, and I would be more than happy to assist you with this question.  Thank you for the files and information you have already provided.  We would like to see the entire file that is producing the error (board_utils.c from your picture), would it be possible for you to attach it?
    Andrew
  • Hi Andrew,
    Thank you for the support .Attaching the board_utils.C file (error producing file) .
     * @file   board_utils.c
     * @brief  This file includes the Keystone board level functions
     * Copyright (c) 2015, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <ti/csl/csl_bootcfg.h>
    #include <ti/csl/csl_bootcfgAux.h>
    #if defined (_TMS320C6X)
    #include <ti/csl/csl_chipAux.h>
    #endif
    #include "board_utils.h"
    * \brief  This API gets the input clock frequency.
    * \param  pll         PLL controller type.
    * \return input clock to the PLL controller.
    * \note   This API gets the input clock frequency based on the
    *         PLL controller type.\n
     *   @n@b BOARD_getExternalClk
     *   @b Description
     *   @n  This function is used to get the exteranl clock frequency.
     *   @b Arguments
     *   @verbatim
                pll             Specifies the PLL controller type.
          @endverbatim
     *   <b> Return Value </b>
     *   @n external clock frequency to the PLL controller, if 0, means failure
     *   <b> Pre Condition </b>
     *   @n  None
     *   <b> Post Condition </b>
     *   @n   None
     *   @b Affects
     *   @n None.
     *   @b Example
     *   @verbatim
            uint32_t     ext_clk;
            ext_clk = BOARD_getExternalClk(CSL_PLL_SYS);
        @endverbatim
    uint32_t BOARD_getExternalClk(CSL_PllcType pll)
        return Board_ext_clk[pll];
     *   @n@b BOARD_initPerfCounters
     *   @b Description
     *   @n  This function enables the A15 performance counters.
     *   @b Arguments
     *   @n None
     *   @n  None
     *   @n   None
     *   @b Affects
     *   @n None.
     *   @b Example
     *   @verbatim
            BOARD_initPerfCounters();
        @endverbatim
    void BOARD_initPerfCounters()
    #if defined (_TMS320C6X) || defined(__TI_ARM_V7M4__)
        // Do nothing for C6x and M4 cores
    #else
        /* PMCR
        31......24 23......16 15....11 10.....6  5 4 3 2 1 0
            IMP      IDCODE       N       Res   DP X D C P E
        [31:24] IMP: Implementer code; read-only
        [23:16] IDCODE: Identification code; read-only
        [15:11] N: Number of event counters; read-only
        [10:6] Reserved
        [5] DP: Disable cycle counter in prohibited regions; r/w
        [4] X: Export enable; r/w
        [3] D: Clock divider - PMCCNTR counts every 64 clock cycles when enabled; r/w
        [2] C: Clock counter reset; write-only
        [1] P: Event counter reset; write-only
        [0] E: Enable all counters; r/w
        __asm__ __volatile__ ("MCR p15, 0, %0, c9, c12, 0\t\n" :: "r"(0x17));
        /* PMCNTENSET - Count Enable Set Register */
        __asm__ __volatile__ ("MCR p15, 0, %0, c9, c12, 1\t\n" :: "r"(0x8000000f));
        /* PMOVSR - Overflow Flag Status Register */
        __asm__ __volatile__ ("MCR p15, 0, %0, c9, c12, 3\t\n" :: "r"(0x8000000f));
    #endif
    static uint32_t readTime32(void)
        uint32_t timeVal;
        timeVal = TSCL;
    #else
        __asm__ __volatile__ ("MRC p15, 0, %0, c9, c13, 0\t\n": "=r"(timeVal));
    #endif
        return timeVal;
     *   @n@b BOARD_delay
     *   @b Description
     *   @n  This function delays a certain period of time in micro seconds.
     *   @b Arguments
     *   @verbatim
                usecs           Specifies the time to delay in micro second.
          @endverbatim
     *   @n To prevent 32-bit counter roll over, the delay time should be less than 2^32/freq_in_mhz (usec)
     *      e.g. for 1000Mhz PLL clock, delay time should be less than ~4.2 seconds.
     *   @n None
     *   @n  None
     *   @n   None
     *   @b Affects
     *   @n None.
     *   @b Example
     *   @verbatim
            uint32_t     delay = 5;
            BOARD_delay(delay);
        @endverbatim
    void BOARD_delay(uint32_t usecs)
        uint32_t ext_clk, freq, start, delayCount;
        CSL_PllcType pllType;
        pllType = CSL_PLL_SYS;
        CSL_chipWriteTSCL(0);
    #else
    #if defined(SOC_K2E)
    #else
        pllType = CSL_PLL_ARM;
    #endif
    #endif
        start = readTime32();
        ext_clk = BOARD_getExternalClk(pllType);
        freq = CSL_BootCfgGetPllFreq(pllType, ext_clk);
        delayCount = usecs * (freq / 1000000);
        while ((readTime32() - start) < delayCount);
  • Hi Nandini,
    An explanation for the error you are encountering can be found on this e2e post.  I have quoted the pertaining answer below:
    "Unfortunately, the TI ARM compiler does not provide the same asm statement features the GCC compiler provides.  Note asm and __asm__ are equivalent."
    If you need additional support on this topic, our Code Composer Studio e2e forum would provide the most relevant information.
    Andrew
  • Hi Andrew,
    As i'm currently working on TI V18 compiler  do i have any API equivalent to asm__volatile for writing into the register sets to enable the registers that are mentioned in board_utils.c file . Do i have any other alternative way to enable the registers (PCMR,PMOVSR ) as done in board_utils.c file.
  • Hi  TI Team,
    As per the instructions given on this pdf (page number 100 ) i tried changing the __asm__ __volatile to __asm , even then then TI V18 ARM compiler is throwing error.  Can anyone help me to resolve this issue.
  • Hi Nandini,
    I'll be stepping in for this thread while Andrew is away for the next few days.
    Are you still receiving the same error when you switched the code to use "__asm"? Or is it a different error?
    Also, can you try entering a simpler assembly instruction? Just to test and see if the issue is coming from just using "__asm" in general, or if the issue is coming from entering an improper input into "__asm".
    Dillon
  • Hi Dillon ,
    Thanks for your reply. when I tried replacing __asm__ __volatile__ with __asm  I'm still getting the same error on board_utils.C file. Is there any equivalent C code or assembly language instruction  which is compatile with TI ARM V18 Compiler ?
  • Hi Nandini,
    Can you try the following command to see if it resolves the issue that you're seeing?
    asm volatile ("MCR p15, 0, %0, c9, c12, 0\t\n" :: "r"(0x17));
    Dillon
  • Hi Dillon,
    Thanks for the reply. I tried to use the above commands, But still I'm getting the same error in Board_utils.c file.
  • Hello Nandini,
    I believe we have exhausted all of our debug options here.  Could you repost your question to our Code Composer Studio e2e forum? That team will be able to provide you with the most in depth support on this topic.
    Andrew
