The driver only supports I frame encoding by default. I want to using P-fame, SPS+PPS+IDR frame +n P-frams, What should i do?
Looking forward to your answer, thank you very much.
Can you please tell the SDK which you are using.
If I understand the problem statement correctly, You would like to have the sequence like below (correct me if the understanding is wrong):
SPS-PPS-IDR-P-P-P-...
Have you found the solution for this query? If not, can you please give us the details asked above?
Can you please close this thread and open a new one for the decoder issue with more details, logs etc? It will be easy for tracking.
