TDA4VM: ipc_test exception occured in version 7.03 RTOS+QNX
Part Number: TDA4VM
Reference to
https://software-dl.ti.com/jacinto7/esd/processor-sdk-qnx-jacinto7/07_03_00_02/exports/docs/qnx_sdk_components_j721e.html#example-application
https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/07_03_00_07/exports/docs/pdk_jacinto_07_03_00_29/docs/userguide/jacinto/modules/ipc.html#build
Follow steps are done to run ipc_test.
1.
cd $/ ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/build
make -s -j BUILD_PROFILE=release BOARD=j721e_evm CORE=mcu1_0 ex02_bios_multicore_echo_test
make -s -j BUILD_PROFILE=release BOARD=j721e_evm CORE=mcu2_0 ex02_bios_multicore_echo_test
make -s -j BUILD_PROFILE=release BOARD=j721e_evm CORE=mcu2_1 ex02_bios_multicore_echo_test
make -s -j BUILD_PROFILE=release BOARD=j721e_evm CORE=c66xdsp_1 ex02_bios_multicore_echo_test
make -s -j BUILD_PROFILE=release BOARD=j721e_evm CORE=c66xdsp_2 ex02_bios_multicore_echo_test
make -s -j BUILD_PROFILE=release BOARD=j721e_evm CORE=c7x_1 ex02_bios_multicore_echo_test
2.
cd $/ ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/binary
cp ex02_bios_multicore_echo_test_c7x_1_release.xe71 /media/tda4/rootfs/lib/firmware/j7-c71_0-fw
cp ex02_bios_multicore_echo_test_c66xdsp_2_release.xe66 /media/tda4/rootfs/lib/firmware/j7-c66_1-fw
cp ex02_bios_multicore_echo_test_c66xdsp_1_release.xe66 /media/tda4/rootfs/lib/firmware/j7-c66_0-fw
cp ex02_bios_multicore_echo_test_mcu2_1_release.xer5f /media/tda4/rootfs/lib/firmware/j7-main-r5f0_1-fw
cp ex02_bios_multicore_echo_test_mcu2_0_release.xer5f /media/tda4/rootfs/lib/firmware/j7-main-r5f0_0-fw
3. Run EVM,  run ‘ipc_test -v’
U-Boot SPL 2020.01-g2781231a33 (Apr 10 2021 - 01:08:23 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.4(release):07.03.00.005-dirty
NOTICE:  BL31: Built : 00:15:40, Apr 10 2021
U-Boot SPL 2020.01-g2781231a33 (Apr 10 2021 - 00:17:14 +0000)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2020.01-g2781231a33 (Apr 10 2021 - 00:17:14 +0000)
SoC:   J721E SR1.0
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E7
DRAM:  4 GiB
not found for dev hbmc-mux
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from MMC... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Warning: ethernet@46000000 using MAC address from ROM
eth0: ethernet@46000000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
526 bytes read in 3 ms (170.9 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
Core 1 is already in use. No rproc commands work
Core 2 is already in use. No rproc commands work
4286448 bytes read in 91 ms (44.9 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 4286448 bytes: Success!
4286420 bytes read in 91 ms (44.9 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 4286420 bytes: Success!
5444692 bytes read in 116 ms (44.8 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 5444692 bytes: Success!
5444708 bytes read in 115 ms (45.2 MiB/s)
Load Remote Processor 7 with data@addr=0x82000000 5444708 bytes: Success!
11479872 bytes read in 37 ms (295.9 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 11479872 bytes: Success!
8176868 bytes read in 173 ms (45.1 MiB/s)
## Starting application at 0x80080000 ...
MMU: 16-bit ASID 44-bit PA TCR_EL1=b5183519
cpu0: MPIDR=80000000
cpu0: MIDR=411fd080 Cortex-A72 r1p0
cpu0: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT
cpu0: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1
cpu0: L1 Icache 48K linesz=64 set/way=256/3
cpu0: L1 Dcache 32K linesz=64 set/way=256/2
cpu0: L2 Unified 1024K linesz=64 set/way=1024/16
Display set to R5
Loading IFS...decompressing...done
cpu1: MPIDR=80000001
cpu1: MIDR=411fd080 Cortex-A72 r1p0
cpu1: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT
cpu1: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1
cpu1: L1 Icache 48K linesz=64 set/way=256/3
cpu1: L1 Dcache 32K linesz=64 set/way=256/2
cpu1: L2 Unified 1024K linesz=64 set/way=1024/16
System page at phys:0000000080011000 user:ffffff8040254000 kern:ffffff8040251000
Starting next program at vffffff8060086e10
All ClockCycles offsets within tolerance
Welcome to QNX Neutrino 7.1.0 on the TI J721E EVM Board!!
Starting random service ...
start serial driver
Starting MMC/SD memory card driver... eMMC
Starting MMC/SD memory card driver... SD
Starting XHCI driver on USB3SS0 and USB3SS1
Path=0 - am65x
 target=0 lun=0     Direct-Access(0) - SDMMC: S0J56X Rev: 1.0
Setting environment variables...
done..
Mounting the sd ..
Looking for user script to run: /ti_fs/scripts/user.sh
Running user script...
user.sh called...
Setting additional environment variables...
Starting tisci-mgr..
Starting shmemallocator..
Starting tiipc-mgr..
Mailbox_plugInterrupt: interrupt Number 489, arg 0x4C48B018
Mailbox_plugInterrupt: interrupt Number 490, arg 0x4C48B1B8
Mailbox_plugInterrupt: interrupt Number 491, arg 0x4C48B358
Mailbox_plugInterrupt: interrupt Number 492, arg 0x4C48B4F8
Mailbox_plugInterrupt: interrupt Number 493, arg 0x4C48B698
Process 57360 (tiipc-mgr) terminated SIGSEGV code=1 fltno=11 ip=000000384c43f798(/ti_fs/tibin/tiipc-mgr@lose+0x0000000000003438) mapaddr=000000000000f798. ref=0000005230448bf0
Memory fault (core dumped)
Starting tiudma-mgr..
Start screen..
screen started with dss_on_r5 configuration..
done...
J7EVM@QNX:/# ipc_test -v
IPC_echo_test (core : ) .....
responderFxn will stay active. Please use ctrl-c to exit the test when finished.
RecvTask: Failed to create endpoint
SendTask 1: Failed to create message endpoint
SendTask 2: Failed to create message endpoint
SendTask 3: Failed to create message endpoint
SendTask 4: Failed to create message endpoint
SendTask 5: Failed to create message endpoint
SendTask 6: Failed to create message endpoint
SendTask 7: Failed to create message endpoint
SendTask 8: Failed to create message endpoint
SendTask 9: Failed to create message endpoint
From log, ipc_test is not work.Then I modified $/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/drv/ipc/examples/common/src/ipc_setup.h
/* Vring start address for each device */
#ifdef SOC_AM65XX
#define VRING_BASE_ADDRESS 0xA2000000U
#elif defined (SOC_J7200)
#define VRING_BASE_ADDRESS 0xA4000000U
#elif defined (SOC_AM64X)
#define VRING_BASE_ADDRESS 0xA5000000U
#else
//#define VRING_BASE_ADDRESS 0xAA000000U
#define VRING_BASE_ADDRESS 0xB0000000U
#endif
Run EVM.
SoC:   J721E SR1.0
DRAM:  4 GiB
Flash: 0 Bytes
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Running uenvcmd ...
5444692 bytes read in 115 ms (45.2 MiB/s)
5444708 bytes read in 116 ms (44.8 MiB/s)
Display set to R5
start serial driver
Path=0 - am65x
done..
Mounting the sd ..
user.sh called...
Mailbox_plugInterrupt: interrupt Number 489, arg 0x88A71018
Mailbox_plugInterrupt: interrupt Number 490, arg 0x88A711B8
Mailbox_plugInterrupt: interrupt Number 491, arg 0x88A71358
Mailbox_plugInterrupt: interrupt Number 492, arg 0x88A714F8
Mailbox_plugInterrupt: interrupt Number 493, arg 0x88A71698
Starting TI IPC Resmgr
Start screen..
done...
IPC_echo_test (core : mpu1_0) .....
SendTask3: Sending "ping 0" from mpu1_0 to mcu2_0...
SendTask9: Sending "ping 0" from mpu1_0 to C7X_1...
SendTask4: Sending "ping 0" from mpu1_0 to mcu2_1...
SendTask7: Sending "ping 0" from mpu1_0 to C66X_1...
SendTask8: Sending "ping 0" from mpu1_0 to C66X_2...
SendTask9: RPMessage_recv failed with code -1
SendTask9: Received "ping 0" len 7 from C7X_1 endPt 13
SendTask4: RPMessage_recv failed with code -1
SendTask9: Sending "ping 1" from mpu1_0 to C7X_1...
SendTask4: Received "ping 0" len 7 from mcu2_1 endPt 13
SendTask4: Sending "ping 1" from mpu1_0 to mcu2_1...
SendTask7: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask8: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask9: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask4: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask7: RPMessage_recv failed with code -1
SendTask7: Received "ping 0" len 7 from C66X_1 endPt 13
SendTask8: RPMessage_recv failed with code -1
SendTask7: Sending "ping 1" from mpu1_0 to C66X_1...
SendTask8: Received "ping 0" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 1" len 7 from C7X_1 endPt 13
SendTask8: Sending "ping 1" from mpu1_0 to C66X_2...
SendTask4: Received "ping 1" len 7 from mcu2_1 endPt 13
SendTask9: Sending "ping 2" from mpu1_0 to C7X_1...
SendTask4: Sending "ping 2" from mpu1_0 to mcu2_1...
SendTask7: Received "ping 1" len 7 from C66X_1 endPt 13
SendTask7: Sending "ping 2" from mpu1_0 to C66X_1...
SendTask8: Received "ping 1" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 2" len 7 from C7X_1 endPt 13
Process 57360 (tiipc-mgr) terminated SIGSEGV code=1 fltno=11 ip=0000002588a22e60(/ti_fs/tibin/tiipc-mgr@lose+0x0000000000000b00) mapaddr=000000000000ce60. ref=0000002bf5bf04f0
SendTask8: Sending "ping 2" from mpu1_0 to C66X_2...
SendTask4: Received "ping 2" len 7 from mcu2_1 endPt 13
SendTask9: Sending "ping 3" from mpu1_0 to C7X_1...
SendTask3: RPMessage_recv failed with code -1
SendTask4: Sending "ping 3" from mpu1_0 to mcu2_1...
SendTask7: Received "ping 2" len 7 from C66X_1 endPt 13
SendTask1: Sending "ping 0" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 0" from mpu1_0 to mcu1_1...
SendTask3: Received "ping 0" len 7 from mcu2_0 endPt 13
SendTask6: Sending "ping 0" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 0" from mpu1_0 to mcu3_0...
SendTask7: Sending "ping 3" from mpu1_0 to C66X_1...
SendTask3: Sending "ping 1" from mpu1_0 to mcu2_0...
SendTask1: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask2: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask6: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask5: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask3: rpmsg_senderFxn: RPMessage_send  failed status -1
SendTask1: RPMessage_recv failed with code -1
SendTask2: RPMessage_recv failed with code -1
SendTask6: RPMessage_recv failed with code -1
SendTask5: RPMessage_recv failed with code -1
SendTask8: Received "ping 2" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 3" len 7 from C7X_1 endPt 13
SendTask4: Received "ping 3" len 7 from mcu2_1 endPt 13
SendTask1: Received "ping 0" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 0" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 0" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 0" len 7 from mcu3_0 endPt 13
SendTask8: Sending "ping 3" from mpu1_0 to C66X_2...
SendTask7: Received "ping 3" len 7 from C66X_1 endPt 13
SendTask9: Sending "ping 4" from mpu1_0 to C7X_1...
SendTask4: Sending "ping 4" from mpu1_0 to mcu2_1...
SendTask3: Received "ping 1" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 1" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 1" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 1" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 1" from mpu1_0 to mcu3_0...
SendTask7: Sending "ping 4" from mpu1_0 to C66X_1...
SendTask3: Sending "ping 2" from mpu1_0 to mcu2_0...
SendTask8: Received "ping 3" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 4" len 7 from C7X_1 endPt 13
SendTask4: Received "ping 4" len 7 from mcu2_1 endPt 13
SendTask1: Received "ping 1" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 1" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 1" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 1" len 7 from mcu3_0 endPt 13
SendTask8: Sending "ping 4" from mpu1_0 to C66X_2...
SendTask7: Received "ping 4" len 7 from C66X_1 endPt 13
SendTask9: Sending "ping 5" from mpu1_0 to C7X_1...
SendTask4: Sending "ping 5" from mpu1_0 to mcu2_1...
SendTask3: Received "ping 2" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 2" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 2" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 2" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 2" from mpu1_0 to mcu3_0...
SendTask7: Sending "ping 5" from mpu1_0 to C66X_1...
SendTask3: Sending "ping 3" from mpu1_0 to mcu2_0...
SendTask8: Received "ping 4" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 5" len 7 from C7X_1 endPt 13
SendTask4: Received "ping 5" len 7 from mcu2_1 endPt 13
SendTask1: Received "ping 2" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 2" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 2" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 2" len 7 from mcu3_0 endPt 13
SendTask8: Sending "ping 5" from mpu1_0 to C66X_2...
SendTask7: Received "ping 5" len 7 from C66X_1 endPt 13
SendTask9: Sending "ping 6" from mpu1_0 to C7X_1...
SendTask4: Sending "ping 6" from mpu1_0 to mcu2_1...
SendTask3: Received "ping 3" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 3" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 3" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 3" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 3" from mpu1_0 to mcu3_0...
SendTask7: Sending "ping 6" from mpu1_0 to C66X_1...
SendTask3: Sending "ping 4" from mpu1_0 to mcu2_0...
SendTask8: Received "ping 5" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 6" len 7 from C7X_1 endPt 13
SendTask4: Received "ping 6" len 7 from mcu2_1 endPt 13
SendTask1: Received "ping 3" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 3" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 3" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 3" len 7 from mcu3_0 endPt 13
SendTask8: Sending "ping 6" from mpu1_0 to C66X_2...
SendTask7: Received "ping 6" len 7 from C66X_1 endPt 13
SendTask9: Sending "ping 7" from mpu1_0 to C7X_1...
SendTask4: Sending "ping 7" from mpu1_0 to mcu2_1...
SendTask3: Received "ping 4" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 4" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 4" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 4" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 4" from mpu1_0 to mcu3_0...
SendTask7: Sending "ping 7" from mpu1_0 to C66X_1...
SendTask3: Sending "ping 5" from mpu1_0 to mcu2_0...
SendTask8: Received "ping 6" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 7" len 7 from C7X_1 endPt 13
SendTask4: Received "ping 7" len 7 from mcu2_1 endPt 13
SendTask1: Received "ping 4" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 4" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 4" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 4" len 7 from mcu3_0 endPt 13
SendTask8: Sending "ping 7" from mpu1_0 to C66X_2...
SendTask7: Received "ping 7" len 7 from C66X_1 endPt 13
SendTask9: Sending "ping 8" from mpu1_0 to C7X_1...
SendTask4: Sending "ping 8" from mpu1_0 to mcu2_1...
SendTask3: Received "ping 5" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 5" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 5" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 5" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 5" from mpu1_0 to mcu3_0...
SendTask7: Sending "ping 8" from mpu1_0 to C66X_1...
SendTask3: Sending "ping 6" from mpu1_0 to mcu2_0...
SendTask8: Received "ping 7" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 8" len 7 from C7X_1 endPt 13
SendTask4: Received "ping 8" len 7 from mcu2_1 endPt 13
SendTask1: Received "ping 5" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 5" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 5" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 5" len 7 from mcu3_0 endPt 13
SendTask8: Sending "ping 8" from mpu1_0 to C66X_2...
SendTask7: Received "ping 8" len 7 from C66X_1 endPt 13
SendTask9: Sending "ping 9" from mpu1_0 to C7X_1...
SendTask4: Sending "ping 9" from mpu1_0 to mcu2_1...
SendTask3: Received "ping 6" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 6" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 6" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 6" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 6" from mpu1_0 to mcu3_0...
SendTask7: Sending "ping 9" from mpu1_0 to C66X_1...
SendTask3: Sending "ping 7" from mpu1_0 to mcu2_0...
SendTask8: Received "ping 8" len 7 from C66X_2 endPt 13
SendTask9: Received "ping 9" len 7 from C7X_1 endPt 13
SendTask4: Received "ping 9" len 7 from mcu2_1 endPt 13
SendTask1: Received "ping 6" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 6" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 6" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 6" len 7 from mcu3_0 endPt 13
SendTask8: Sending "ping 9" from mpu1_0 to C66X_2...
SendTask7: Received "ping 9" len 7 from C66X_1 endPt 13
SendTask9: mpu1_0 <--> C7X_1, Ping- 10, pong - 10 completed
SendTask4: mpu1_0 <--> mcu2_1, Ping- 10, pong - 10 completed
SendTask3: Received "ping 7" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 7" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 7" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 7" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 7" from mpu1_0 to mcu3_0...
SendTask7: mpu1_0 <--> C66X_1, Ping- 10, pong - 10 completed
SendTask3: Sending "ping 8" from mpu1_0 to mcu2_0...
SendTask8: Received "ping 9" len 7 from C66X_2 endPt 13
SendTask1: Received "ping 7" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 7" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 7" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 7" len 7 from mcu3_0 endPt 13
SendTask8: mpu1_0 <--> C66X_2, Ping- 10, pong - 10 completed
SendTask3: Received "ping 8" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 8" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 8" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 8" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 8" from mpu1_0 to mcu3_0...
SendTask3: Sending "ping 9" from mpu1_0 to mcu2_0...
SendTask1: Received "ping 8" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 8" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 8" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 8" len 7 from mcu3_0 endPt 13
SendTask3: Received "ping 9" len 7 from mcu2_0 endPt 13
SendTask1: Sending "ping 9" from mpu1_0 to mcu1_0...
SendTask2: Sending "ping 9" from mpu1_0 to mcu1_1...
SendTask6: Sending "ping 9" from mpu1_0 to mcu3_1...
SendTask5: Sending "ping 9" from mpu1_0 to mcu3_0...
SendTask3: mpu1_0 <--> mcu2_0, Ping- 10, pong - 10 completed
SendTask1: Received "ping 9" len 7 from mcu1_0 endPt 13
SendTask2: Received "ping 9" len 7 from mcu1_1 endPt 13
SendTask6: Received "ping 9" len 7 from mcu3_1 endPt 13
SendTask5: Received "ping 9" len 7 from mcu3_0 endPt 13
SendTask1: mpu1_0 <--> mcu1_0, Ping- 10, pong - 10 completed
SendTask2: mpu1_0 <--> mcu1_1, Ping- 10, pong - 10 completed
SendTask6: mpu1_0 <--> mcu3_1, Ping- 10, pong - 10 completed
SendTask5: mpu1_0 <--> mcu3_0, Ping- 10, pong - 10 completed
Failure occur and tiipc-mgr is killed.
1 . How to solve that?
2 . Form log, IPC function beteewn MPU and (mcu3_0、mcu3_1、mcu1_0、mcu1_1) can works, but in /media/tda4/rootfs/lib/firmware, there is no relevant firmware. Why is that?
And Then I follow
TDA4VM: Ipc fail in qnx environment - Processors forum - Processors - TI E2E support forums
still fail.
SoC:   J721E SR1.0
DRAM:  4 GiB
Flash: 0 Bytes
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Running uenvcmd ...
4286416 bytes read in 92 ms (44.4 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 4286416 bytes: Success!
4286388 bytes read in 92 ms (44.4 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 4286388 bytes: Success!
4286388 bytes read in 91 ms (44.9 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 4286388 bytes: Success!
Load Remote Processor 5 with data@addr=0x82000000 4286388 bytes: Success!
11479872 bytes read in 36 ms (304.1 MiB/s)
Display set to R5
start serial driver
Path=0 - am65x
done..
Mounting the sd ..
user.sh called...
Mailbox_plugInterrupt: interrupt Number 489, arg 0x6F942018
Mailbox_plugInterrupt: interrupt Number 490, arg 0x6F9421B8
Mailbox_plugInterrupt: interrupt Number 491, arg 0x6F942358
Mailbox_plugInterrupt: interrupt Number 492, arg 0x6F9424F8
Mailbox_plugInterrupt: interrupt Number 493, arg 0x6F942698
Start screen..
done...
J7EVM@QNX:/#
J7EVM@QNX:/#
Process 57360 (tiipc-mgr) terminated SIGSEGV code=1 fltno=11 ip=0000005c6f8f3e60(/ti_fs/tibin/tiipc-mgr@lose+0x0000000000000b00) mapaddr=000000000000ce60. ref=00000063deaddcf0
  • Then I verify ipc_test  in version 7.02 (RTOS+QNX). It works.
    SoC:   J721E SR1.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    530 bytes read in 3 ms (171.9 KiB/s)
    Running uenvcmd ...
    4274368 bytes read in 90 ms (45.3 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 4274368 bytes: Success!
    4274352 bytes read in 90 ms (45.3 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 4274352 bytes: Success!
    4274348 bytes read in 91 ms (44.8 MiB/s)
    Load Remote Processor 4 with data@addr=0x82000000 4274348 bytes: Success!
    4274352 bytes read in 91 ms (44.8 MiB/s)
    Load Remote Processor 5 with data@addr=0x82000000 4274352 bytes: Success!
    5433728 bytes read in 116 ms (44.7 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 5433728 bytes: Success!
    5433740 bytes read in 114 ms (45.5 MiB/s)
    Load Remote Processor 7 with data@addr=0x82000000 5433740 bytes: Success!
    11460416 bytes read in 36 ms (303.6 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 11460416 bytes: Success!
    8176360 bytes read in 173 ms (45.1 MiB/s)
    Display set to R5
    start serial driver
    Path=0 - am65x
    done..
    user.sh called...
    Mailbox_plugInterrupt: interrupt Number 489, arg 0xF0B05EA0
    Mailbox_plugInterrupt: interrupt Number 490, arg 0xF0B06040
    Mailbox_plugInterrupt: interrupt Number 491, arg 0xF0B061E0
    Mailbox_plugInterrupt: interrupt Number 492, arg 0xF0B06380
    Mailbox_plugInterrupt: interrupt Number 493, arg 0xF0B06520
    Start screen..
    done...
    But  there is no SendTask between mpu and mcu1.  How to solve that?
    Regarding ipc_test running on  PSDK 7.3, please see instructions on below link for the default installation, with no code modifications required:
    (+) [FAQ] TDA4VM: IPC_Test on PSDK QNX 7.2 / PSDK QNX 7.3 - Processors forum - Processors - TI E2E support forums
    Regarding MPU to MCU1 communication, as the MCU1 image is already running,  the "ipc echo test" firmware images have not been loaded.   Will update this thread with recommended steps to work around this.
    kb
  • Hi KB:
        Thank you for your reply.
        From ipc_test example, known that MPU to MCU1 communication is not achieved in version 7.02 or 7.03.Also, system memory map is different from previous versions.
        From thread:
        TDA4VM: After builded MCU1_0, Run vision apps Demos for Display , IPC error occurs . - Processors forum - Processors - TI E2E support forums
        known that the Vision Apps generated firmware image for MCU1_0 with IPC enabled is not functional in version 7.03.
        1 .So how to prove out MCU1_0 and MPU IPC communication?
        2 .MPU to MCU1 ipc communication is a urgent task to be developed in our project. We try to use cddipc to achieve this requirement, but failed.
           A successful ipc communication is necessary for reference using cddipc in our project .
          I want to know if cddipc module is a avaliable way for MPU to MCU1 ipc communication?
        3. If cddipc is not work ,in TI's recommendation, how to achieve MPU to MCU1 ipc communication ?
    The issue is around the firmware image running on the MCU1.   For an IPC test to be successful, the MCU1 firmware image needs to:
    • Have IPC S/W running that is capable of responding to the particular test that is being run
    • Have a memory map that matches the rest of the system
    As per earlier response, TI will update this thread with recommended steps for a workaround.
    kb
  • Hi KB:
        Which version will realize MCU's ipc_test function?  Or which previous version that MCU's ipc_test works well?
    In referencing the FAQ for PSDK QNX 7.1:
    (+) [FAQ] PROCESSOR-SDK-DRA8X-TDA4X: How to use IPC Example Application Echo Test on PSDKQA7.0 - Processors forum - Processors - TI E2E support forums
    The logs there show mcu1_0 responding to the IPC echo test:
    "SendTask1: mpu1_0 <--> mcu1_0, Ping- 10, pong - 10 completed"
    kb
  • Hi KB:
        Follow your thread:
        I got the same result as you.
    Patch PSDK_QNX_07_03_03_patch is available at PROCESSOR-SDK-QNX-J721E_07.03.00.02 | TI.com, the patch includes a readme with instructions.
    When PSDK_QNX_07_03_03_patch is applied, and readme instructions followed, expectation is that the MCU1_0 communication for the ipc_echo test will function.
    kb
