I am set AM3352 boot sequence EMAC1>MMC0>XIP>NAND(SYSYBOOT[4:0]=00111b),I need AM3352 Boot from nand_flash ,but now i found ,skip Ethernet boot need about 4min,it is so long . so i want ask how to skip EMAC1(Do not change the boot sequence)
It is not possible to skip, Only option is to change boot sequence.
--Paul
Do you have an ethernet PHY connected to the ethernet boot port? If so, you may be able to keep the PHY in reset to prevent link. This may cut down on the timeout for the ROM. But ultimately, you should change the boot order.
James
