TDA3MA: TDA3MA customized board Device is locked up in Hard Fault or in NMI
Part Number: TDA3MA
Other Parts Discussed in Thread: AWR2243,
The processor is in lockup when I add the link file to my project folder, I got some errors with memory allocation so I used a predefined link file to solve the issue.
I don't know what is the issue, but this linker file enter my processor to lock up, please anyone can assist?
Attached is the linker file.
Thank,
Yishai,
/* lnk.cmd -- Linker command file                                          */
/* Rev 0.0.1                                                               */
/* Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/  */
/*  Redistribution and use in source and binary forms, with or without     */
/*  modification, are permitted provided that the following conditions     */
/*  are met:                                                               */
/*    Redistributions of source code must retain the above copyright       */
/*    notice, this list of conditions and the following disclaimer.        */
/*    Redistributions in binary form must reproduce the above copyright    */
/*    notice, this list of conditions and the following disclaimer in the  */
/*    documentation and/or other materials provided with the               */
/*    distribution.                                                        */
/*    Neither the name of Texas Instruments Incorporated nor the names of  */
/*    its contributors may be used to endorse or promote products derived  */
/*    from this software without specific prior written permission.        */
/*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS    */
/*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT      */
/*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR  */
/*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT   */
/*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,  */
/*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT       */
/*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,  */
/*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY  */
/*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT    */
/*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE  */
/*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.   */
-heap  0x8000
-stack 0xC000
-l C:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/algorithms/dsplib_c66x_3_4_0_0/packages/ti/dsplib/lib/dsplib.lib
-l C:/PROCESSOR_SDK_RADAR_03_08_00_00/ti_components/algorithms/dsplib_c66x_3_4_0_0/packages/ti/dsplib/lib/dsplib_cn.lib
//-l ti/mathlib/lib/mathlib.lib
MEMORY
  L2SRAM (RWX)  : org = 0x40300000, len = 0x80000
  DSP1_L2_SRAM	: org = 0x40800000, len = 0x48000
  MSMCSRAM (RWX): org = 0x80000000, len = 0x200000
SECTIONS
  //.kernel: {
  //  dsplib*<*.o*> (.text:optimized) { SIZE(_kernel_size) }
  .text:            load >> L2SRAM
  .text:touch:      load >> L2SRAM
  GROUP (NEAR_DP)
    .neardata
    .rodata
    .bss
  } load > L2SRAM
  .init_array:	load >> L2SRAM
  .far:			load >> MSMCSRAM
  .dsp1:		load >> DSP1_L2_SRAM
  .fardata:		load >> L2SRAM
  .neardata:	load >> L2SRAM
  .rodata		load >> L2SRAM
  .data:		load >> L2SRAM
  .switch:		load >> L2SRAM
  .stack:		load >  L2SRAM
  .args:		load >  L2SRAM align = 0x4, fill = 0 {_argsize = 0x200; }
  .sysmem:		load >  L2SRAM
  .cinit:		load >  L2SRAM
  .const:		load >  L2SRAM START(const_start) SIZE(const_size)
  .pinit:		load >  L2SRAM
  .cio:			load >> L2SRAM
   xdc.meta:	load >> L2SRAM, type = COPY
