DRA829V: Running Standalone Diagnostic Tests through SD Card
Part Number: DRA829V
Hi TI
There's a question that Customer wants to clarify.
Could you please clarify which system firmware and bootloader images to copy to SD card ?
I'd appreciate it if you could point me to the directory with files.
  • Build diagnostic test application by following the steps described in section Building the Diagnostic Tests
  • Copy the diagnostic application image (.appimage) to SD card and rename it to ‘app’
  • Copy the system firmware and bootloader images to SD card
  • Insert the SD card into the board
  • Connect the serial port of the board to host PC
  • Open Terminal emulator program eg: Teraterm to connect to the board’s UART console
Jack
