你好,硬件:https : //www.ti.com.cn/product/cn/AM5729?keyMatch=TMDSIDK5729&tisearch=search-everything
软件:https : //software-dl.ti.com/processor-sdk-linux/esd/AM57X/latest/index_FDS.html
I used am572x as the main station. After the migration was completed according to igh, I found that the real-time performance was very poor. I used the 4.19.94 real-time kernel provided by ti, so it should be a problem with the network card driver. I want to modify the cpsw driver to be the ethercat network card driver. After modification,I found that the sending process is ok, but there is a problem with the receiving process:I can not get receive state correctly by cpdma_ctrl_rxchs_state(cpsw->dma),the return value is always 0. I don't know how to solve it, Do you have any suggestions?/*
* Texas Instruments Ethernet Switch Driver
* Copyright (C) 2012 Texas Instruments
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation version 2.
* This program is distributed "as is" WITHOUT ANY WARRANTY of any
* kind, whether express or implied; without even the implied warranty
* of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
#include <linux/kernel.h>
#include <linux/io.h>
#include <linux/clk.h>
#include <linux/timer.h>
#include <linux/module.h>
#include <linux/platform_device.h>
#include <linux/irqreturn.h>
#include <linux/interrupt.h>
#include <linux/if_ether.h>
#include <linux/etherdevice.h>
#include <linux/netdevice.h>
#include <linux/net_tstamp.h>
#include <linux/phy.h>
#include <linux/workqueue.h>
#include <linux/delay.h>
#include <linux/pm_runtime.h>
#include <linux/gpio/consumer.h>
#include <linux/of.h>
#include <linux/of_mdio.h>
#include <linux/of_net.h>
#include <linux/of_device.h>
#include <linux/if_vlan.h>
#include <linux/kmemleak.h>
#include <linux/sys_soc.h>
#include <linux/net_switch_config.h>
#include <linux/pinctrl/consumer.h>
#include <net/pkt_cls.h>
#include "../ecdev.h"
#include "cpsw.h"
#include "cpsw_ale.h"
#include "cpts.h"
#include "davinci_cpdma.h"
#include <net/pkt_sched.h>
#define CPSW_DEBUG (NETIF_MSG_HW | NETIF_MSG_WOL | \
NETIF_MSG_DRV | NETIF_MSG_LINK | \
NETIF_MSG_IFUP | NETIF_MSG_INTR | \
NETIF_MSG_PROBE | NETIF_MSG_TIMER | \
NETIF_MSG_IFDOWN | NETIF_MSG_RX_ERR | \
NETIF_MSG_TX_ERR | NETIF_MSG_TX_DONE | \
NETIF_MSG_PKTDATA | NETIF_MSG_TX_QUEUED | \
NETIF_MSG_RX_STATUS)
#define cpsw_info(priv, type, format, ...) \
do { \
if (netif_msg_##type(priv) && net_ratelimit()) \
dev_info(priv->dev, format, ## __VA_ARGS__); \
} while (0)
#define cpsw_err(priv, type, format, ...) \
do { \
dev_err(priv->dev, format, ## __VA_ARGS__); \
} while (0)
#define cpsw_dbg(priv, type, format, ...) \
do { \
dev_dbg(priv->dev, format, ## __VA_ARGS__); \
} while (0)
#define cpsw_notice(priv, type, format, ...) \
do { \
dev_notice(priv->dev, format, ## __VA_ARGS__); \
} while (0)
#define ALE_ALL_PORTS 0x7
#define CPSW_MAJOR_VERSION(reg) (reg >> 8 & 0x7)
#define CPSW_MINOR_VERSION(reg) (reg & 0xff)
#define CPSW_RTL_VERSION(reg) ((reg >> 11) & 0x1f)
#define CPSW_VERSION_1 0x19010a
#define CPSW_VERSION_2 0x19010c
#define CPSW_VERSION_3 0x19010f
#define CPSW_VERSION_4 0x190112
#define HOST_PORT_NUM 0
#define CPSW_ALE_PORTS_NUM 3
#define SLIVER_SIZE 0x40
#define CPSW1_HOST_PORT_OFFSET 0x028
#define CPSW1_SLAVE_OFFSET 0x050
#define CPSW1_SLAVE_SIZE 0x040
#define CPSW1_CPDMA_OFFSET 0x100
#define CPSW1_STATERAM_OFFSET 0x200
#define CPSW1_HW_STATS 0x400
#define CPSW1_CPTS_OFFSET 0x500
#define CPSW1_ALE_OFFSET 0x600
#define CPSW1_SLIVER_OFFSET 0x700
#define CPSW2_HOST_PORT_OFFSET 0x108
#define CPSW2_SLAVE_OFFSET 0x200
#define CPSW2_SLAVE_SIZE 0x100
#define CPSW2_CPDMA_OFFSET 0x800
#define CPSW2_HW_STATS 0x900
#define CPSW2_STATERAM_OFFSET 0xa00
#define CPSW2_CPTS_OFFSET 0xc00
#define CPSW2_ALE_OFFSET 0xd00
#define CPSW2_SLIVER_OFFSET 0xd80
#define CPSW2_BD_OFFSET 0x2000
#define CPDMA_RXTHRESH 0x0c0
#define CPDMA_RXFREE 0x0e0
#define CPDMA_TXHDP 0x00
#define CPDMA_RXHDP 0x20
#define CPDMA_TXCP 0x40
#define CPDMA_RXCP 0x60
#define CPSW_POLL_WEIGHT 64
#define CPSW_RX_VLAN_ENCAP_HDR_SIZE 4
#define CPSW_MIN_PACKET_SIZE 60
#define CPSW_MAX_PACKET_SIZE (1500 + 14 + 4 + 4)
#define RX_PRIORITY_MAPPING 0x76543210
#define TX_PRIORITY_MAPPING 0x33221100
#define CPDMA_TX_PRIORITY_MAP 0x76543210
#define CPSW_VLAN_AWARE BIT(1)
#define CPSW_RX_VLAN_ENCAP BIT(2)
#define CPSW_ALE_VLAN_AWARE 1
#define CPSW_FIFO_NORMAL_MODE (0 << 16)
#define CPSW_FIFO_DUAL_MAC_MODE (1 << 16)
#define CPSW_FIFO_RATE_LIMIT_MODE (2 << 16)
#define CPSW_INTPACEEN (0x3f << 16)
#define CPSW_INTPRESCALE_MASK (0x7FF << 0)
#define CPSW_CMINTMAX_CNT 63
#define CPSW_CMINTMIN_CNT 2
#define CPSW_CMINTMAX_INTVL (1000 / CPSW_CMINTMIN_CNT)
#define CPSW_CMINTMIN_INTVL ((1000 / CPSW_CMINTMAX_CNT) + 1)
#define cpsw_slave_index(cpsw, priv) \
((cpsw->data.dual_emac) ? priv->emac_port : \
cpsw->data.active_slave)
#define IRQ_NUM 2
#define CPSW_MAX_QUEUES 8
#define CPSW_CPDMA_DESCS_POOL_SIZE_DEFAULT 256
#define CPSW_FIFO_QUEUE_TYPE_SHIFT 16
#define CPSW_FIFO_SHAPE_EN_SHIFT 16
#define CPSW_FIFO_RATE_EN_SHIFT 20
#define CPSW_TC_NUM 4
#define CPSW_FIFO_SHAPERS_NUM (CPSW_TC_NUM - 1)
#define CPSW_PCT_MASK 0x7f
#define CPSW_RX_VLAN_ENCAP_HDR_PRIO_SHIFT 29
#define CPSW_RX_VLAN_ENCAP_HDR_PRIO_MSK GENMASK(2, 0)
#define CPSW_RX_VLAN_ENCAP_HDR_VID_SHIFT 16
#define CPSW_RX_VLAN_ENCAP_HDR_PKT_TYPE_SHIFT 8
#define CPSW_RX_VLAN_ENCAP_HDR_PKT_TYPE_MSK GENMASK(1, 0)
enum {
CPSW_RX_VLAN_ENCAP_HDR_PKT_VLAN_TAG = 0,
CPSW_RX_VLAN_ENCAP_HDR_PKT_RESERV,
CPSW_RX_VLAN_ENCAP_HDR_PKT_PRIO_TAG,
CPSW_RX_VLAN_ENCAP_HDR_PKT_UNTAG,
static int debug_level;
module_param(debug_level, int, 0);
MODULE_PARM_DESC(debug_level, "cpsw debug level (NETIF_MSG bits)");
static int ale_ageout = 10;
module_param(ale_ageout, int, 0);
MODULE_PARM_DESC(ale_ageout, "cpsw ale ageout interval (seconds)");
static int rx_packet_max = CPSW_MAX_PACKET_SIZE;
module_param(rx_packet_max, int, 0);
MODULE_PARM_DESC(rx_packet_max, "maximum receive packet size (bytes)");
static int tx_packet_min = CPSW_MIN_PACKET_SIZE;
module_param(tx_packet_min, int, 0444);
MODULE_PARM_DESC(tx_packet_min, "minimum tx packet size (bytes)");
static int descs_pool_size = CPSW_CPDMA_DESCS_POOL_SIZE_DEFAULT;
module_param(descs_pool_size, int, 0444);
MODULE_PARM_DESC(descs_pool_size, "Number of CPDMA CPPI descriptors in pool");
struct cpsw_wr_regs {
u32 id_ver;
u32 soft_reset;
u32 control;
u32 int_control;
u32 rx_thresh_en;
u32 rx_en;
u32 tx_en;
u32 misc_en;
u32 mem_allign1[8];
u32 rx_thresh_stat;
u32 rx_stat;
u32 tx_stat;
u32 misc_stat;
u32 mem_allign2[8];
u32 rx_imax;
u32 tx_imax;
struct cpsw_ss_regs {
u32 id_ver;
u32 control;
u32 soft_reset;
u32 stat_port_en;
u32 ptype;
u32 soft_idle;
u32 thru_rate;
u32 gap_thresh;
u32 tx_start_wds;
u32 flow_control;
u32 vlan_ltype;
u32 ts_ltype;
u32 dlr_ltype;
/* CPSW_PORT_V1 */
#define CPSW1_MAX_BLKS 0x00 /* Maximum FIFO Blocks */
#define CPSW1_BLK_CNT 0x04 /* FIFO Block Usage Count (Read Only) */
#define CPSW1_TX_IN_CTL 0x08 /* Transmit FIFO Control */
#define CPSW1_PORT_VLAN 0x0c /* VLAN Register */
#define CPSW1_TX_PRI_MAP 0x10 /* Tx Header Priority to Switch Pri Mapping */
#define CPSW1_TS_CTL 0x14 /* Time Sync Control */
#define CPSW1_TS_SEQ_LTYPE 0x18 /* Time Sync Sequence ID Offset and Msg Type */
#define CPSW1_TS_VLAN 0x1c /* Time Sync VLAN1 and VLAN2 */
/* CPSW_PORT_V2 */
#define CPSW2_CONTROL 0x00 /* Control Register */
#define CPSW2_MAX_BLKS 0x08 /* Maximum FIFO Blocks */
#define CPSW2_BLK_CNT 0x0c /* FIFO Block Usage Count (Read Only) */
#define CPSW2_TX_IN_CTL 0x10 /* Transmit FIFO Control */
#define CPSW2_PORT_VLAN 0x14 /* VLAN Register */
#define CPSW2_TX_PRI_MAP 0x18 /* Tx Header Priority to Switch Pri Mapping */
#define CPSW2_TS_SEQ_MTYPE 0x1c /* Time Sync Sequence ID Offset and Msg Type */
/* CPSW_PORT_V1 and V2 */
#define SA_LO 0x20 /* CPGMAC_SL Source Address Low */
#define SA_HI 0x24 /* CPGMAC_SL Source Address High */
#define SEND_PERCENT 0x28 /* Transmit Queue Send Percentages */
/* CPSW_PORT_V2 only */
#define RX_DSCP_PRI_MAP0 0x30 /* Rx DSCP Priority to Rx Packet Mapping */
#define RX_DSCP_PRI_MAP1 0x34 /* Rx DSCP Priority to Rx Packet Mapping */
#define RX_DSCP_PRI_MAP2 0x38 /* Rx DSCP Priority to Rx Packet Mapping */
#define RX_DSCP_PRI_MAP3 0x3c /* Rx DSCP Priority to Rx Packet Mapping */
#define RX_DSCP_PRI_MAP4 0x40 /* Rx DSCP Priority to Rx Packet Mapping */
#define RX_DSCP_PRI_MAP5 0x44 /* Rx DSCP Priority to Rx Packet Mapping */
#define RX_DSCP_PRI_MAP6 0x48 /* Rx DSCP Priority to Rx Packet Mapping */
#define RX_DSCP_PRI_MAP7 0x4c /* Rx DSCP Priority to Rx Packet Mapping */
/* Bit definitions for the CPSW2_CONTROL register */
#define PASS_PRI_TAGGED BIT(24) /* Pass Priority Tagged */
#define VLAN_LTYPE2_EN BIT(21) /* VLAN LTYPE 2 enable */
#define VLAN_LTYPE1_EN BIT(20) /* VLAN LTYPE 1 enable */
#define DSCP_PRI_EN BIT(16) /* DSCP Priority Enable */
#define TS_107 BIT(15) /* Tyme Sync Dest IP Address 107 */
#define TS_320 BIT(14) /* Time Sync Dest Port 320 enable */
#define TS_319 BIT(13) /* Time Sync Dest Port 319 enable */
#define TS_132 BIT(12) /* Time Sync Dest IP Addr 132 enable */
#define TS_131 BIT(11) /* Time Sync Dest IP Addr 131 enable */
#define TS_130 BIT(10) /* Time Sync Dest IP Addr 130 enable */
#define TS_129 BIT(9) /* Time Sync Dest IP Addr 129 enable */
#define TS_TTL_NONZERO BIT(8) /* Time Sync Time To Live Non-zero enable */
#define TS_ANNEX_F_EN BIT(6) /* Time Sync Annex F enable */
#define TS_ANNEX_D_EN BIT(4) /* Time Sync Annex D enable */
#define TS_LTYPE2_EN BIT(3) /* Time Sync LTYPE 2 enable */
#define TS_LTYPE1_EN BIT(2) /* Time Sync LTYPE 1 enable */
#define TS_TX_EN BIT(1) /* Time Sync Transmit Enable */
#define TS_RX_EN BIT(0) /* Time Sync Receive Enable */
#define CTRL_V2_TS_BITS \
(TS_320 | TS_319 | TS_132 | TS_131 | TS_130 | TS_129 |\
TS_TTL_NONZERO | TS_ANNEX_D_EN | TS_LTYPE1_EN | VLAN_LTYPE1_EN)
#define CTRL_V2_ALL_TS_MASK (CTRL_V2_TS_BITS | TS_TX_EN | TS_RX_EN)
#define CTRL_V2_TX_TS_BITS (CTRL_V2_TS_BITS | TS_TX_EN)
#define CTRL_V2_RX_TS_BITS (CTRL_V2_TS_BITS | TS_RX_EN)
#define CTRL_V3_TS_BITS \
(TS_107 | TS_320 | TS_319 | TS_132 | TS_131 | TS_130 | TS_129 |\
TS_TTL_NONZERO | TS_ANNEX_F_EN | TS_ANNEX_D_EN |\
#define CTRL_V3_ALL_TS_MASK (CTRL_V3_TS_BITS | TS_TX_EN | TS_RX_EN)
#define CTRL_V3_TX_TS_BITS (CTRL_V3_TS_BITS | TS_TX_EN)
#define CTRL_V3_RX_TS_BITS (CTRL_V3_TS_BITS | TS_RX_EN)
/* Bit definitions for the CPSW2_TS_SEQ_MTYPE register */
#define TS_SEQ_ID_OFFSET_SHIFT (16) /* Time Sync Sequence ID Offset */
#define TS_SEQ_ID_OFFSET_MASK (0x3f)
#define TS_MSG_TYPE_EN_SHIFT (0) /* Time Sync Message Type Enable */
#define TS_MSG_TYPE_EN_MASK (0xffff)
/* The PTP event messages - Sync, Delay_Req, Pdelay_Req, and Pdelay_Resp. */
#define EVENT_MSG_BITS ((1<<0) | (1<<1) | (1<<2) | (1<<3))
/* Bit definitions for the CPSW1_TS_CTL register */
#define CPSW_V1_TS_RX_EN BIT(0)
#define CPSW_V1_TS_TX_EN BIT(4)
#define CPSW_V1_MSG_TYPE_OFS 16
/* Bit definitions for the CPSW1_TS_SEQ_LTYPE register */
#define CPSW_V1_SEQ_ID_OFS_SHIFT 16
#define CPSW_MAX_BLKS_TX 15
#define CPSW_MAX_BLKS_TX_SHIFT 4
#define CPSW_MAX_BLKS_RX 5
struct cpsw_host_regs {
u32 max_blks;
u32 blk_cnt;
u32 tx_in_ctl;
u32 port_vlan;
u32 tx_pri_map;
u32 cpdma_tx_pri_map;
u32 cpdma_rx_chan_map;
struct cpsw_sliver_regs {
u32 id_ver;
u32 mac_control;
u32 mac_status;
u32 soft_reset;
u32 rx_maxlen;
u32 __reserved_0;
u32 rx_pause;
u32 tx_pause;
u32 __reserved_1;
u32 rx_pri_map;
struct cpsw_hw_stats {
u32 rxgoodframes;
u32 rxbroadcastframes;
u32 rxmulticastframes;
u32 rxpauseframes;
u32 rxcrcerrors;
u32 rxaligncodeerrors;
u32 rxoversizedframes;
u32 rxjabberframes;
u32 rxundersizedframes;
u32 rxfragments;
u32 __pad_0[2];
u32 rxoctets;
u32 txgoodframes;
u32 txbroadcastframes;
u32 txmulticastframes;
u32 txpauseframes;
u32 txdeferredframes;
u32 txcollisionframes;
u32 txsinglecollframes;
u32 txmultcollframes;
u32 txexcessivecollisions;
u32 txlatecollisions;
u32 txunderrun;
u32 txcarriersenseerrors;
u32 txoctets;
u32 octetframes64;
u32 octetframes65t127;
u32 octetframes128t255;
u32 octetframes256t511;
u32 octetframes512t1023;
u32 octetframes1024tup;
u32 netoctets;
u32 rxsofoverruns;
u32 rxmofoverruns;
u32 rxdmaoverruns;
struct cpsw_slave_data {
struct device_node *phy_node;
char phy_id[MII_BUS_ID_SIZE];
int phy_if;
u8 mac_addr[ETH_ALEN];
u16 dual_emac_res_vlan; /* Reserved VLAN for DualEMAC */
struct cpsw_platform_data {
struct cpsw_slave_data *slave_data;
u32 ss_reg_ofs; /* Subsystem control register offset */
u32 channels; /* number of cpdma channels (symmetric) */
u32 slaves; /* number of slave cpgmac ports */
u32 active_slave; /* time stamping, ethtool and SIOCGMIIPHY slave */
u32 ale_entries; /* ale table size */
u32 bd_ram_size; /*buffer descriptor ram size */
u32 mac_control; /* Mac control register */
u16 default_vlan; /* Def VLAN for ALE lookup in VLAN aware mode*/
bool dual_emac; /* Enable Dual EMAC mode */
struct cpsw_slave {
void __iomem *regs;
struct cpsw_sliver_regs __iomem *sliver;
int slave_num;
u32 mac_control;
struct cpsw_slave_data *data;
struct phy_device *phy;
struct net_device *ndev;
u32 port_vlan;
static inline u32 slave_read(struct cpsw_slave *slave, u32 offset)
return readl_relaxed(slave->regs + offset);
static inline void slave_write(struct cpsw_slave *slave, u32 val, u32 offset)
writel_relaxed(val, slave->regs + offset);
struct cpsw_vector {
struct cpdma_chan *ch;
int budget;
struct cpsw_common {
struct device *dev;
struct cpsw_platform_data data;
struct napi_struct napi_rx;
struct napi_struct napi_tx;
struct cpsw_ss_regs __iomem *regs;
struct cpsw_wr_regs __iomem *wr_regs;
u8 __iomem *hw_stats;
struct cpsw_host_regs __iomem *host_port_regs;
u32 version;
u32 coal_intvl;
u32 bus_freq_mhz;
int rx_packet_max;
struct cpsw_slave *slaves;
struct cpdma_ctlr *dma;
struct cpsw_vector txv[CPSW_MAX_QUEUES];
struct cpsw_vector rxv[CPSW_MAX_QUEUES];
struct cpsw_ale *ale;
bool quirk_irq;
bool rx_irq_disabled;
bool tx_irq_disabled;
u32 irqs_table[IRQ_NUM];
struct cpts *cpts;
int rx_ch_num, tx_ch_num;
int speed;
int usage_count;
ec_device_t *ecdev;
struct cpsw_priv {
struct device *dev;
u32 msg_enable;
bool rx_pause;
bool tx_pause;
bool mqprio_hw;
int fifo_bw[CPSW_TC_NUM];
int shp_cfg_speed;
int tx_ts_enabled;
int rx_ts_enabled;
u32 emac_port;
struct cpsw_common *cpsw;
u8 port_state[3];
struct cpsw_stats {
char stat_string[ETH_GSTRING_LEN];
int type;
int sizeof_stat;
int stat_offset;
enum {
CPSW_STATS,
CPDMA_RX_STATS,
CPDMA_TX_STATS,
#define CPSW_STAT(m) CPSW_STATS, \
FIELD_SIZEOF(struct cpsw_hw_stats, m), \
offsetof(struct cpsw_hw_stats, m)
#define CPDMA_RX_STAT(m) CPDMA_RX_STATS, \
FIELD_SIZEOF(struct cpdma_chan_stats, m), \
offsetof(struct cpdma_chan_stats, m)
#define CPDMA_TX_STAT(m) CPDMA_TX_STATS, \
static const struct cpsw_stats cpsw_gstrings_stats[] = {
{ "Good Rx Frames", CPSW_STAT(rxgoodframes) },
{ "Broadcast Rx Frames", CPSW_STAT(rxbroadcastframes) },
{ "Multicast Rx Frames", CPSW_STAT(rxmulticastframes) },
{ "Pause Rx Frames", CPSW_STAT(rxpauseframes) },
{ "Rx CRC Errors", CPSW_STAT(rxcrcerrors) },
{ "Rx Align/Code Errors", CPSW_STAT(rxaligncodeerrors) },
{ "Oversize Rx Frames", CPSW_STAT(rxoversizedframes) },
{ "Rx Jabbers", CPSW_STAT(rxjabberframes) },
{ "Undersize (Short) Rx Frames", CPSW_STAT(rxundersizedframes) },
{ "Rx Fragments", CPSW_STAT(rxfragments) },
{ "Rx Octets", CPSW_STAT(rxoctets) },
{ "Good Tx Frames", CPSW_STAT(txgoodframes) },
{ "Broadcast Tx Frames", CPSW_STAT(txbroadcastframes) },
{ "Multicast Tx Frames", CPSW_STAT(txmulticastframes) },
{ "Pause Tx Frames", CPSW_STAT(txpauseframes) },
{ "Deferred Tx Frames", CPSW_STAT(txdeferredframes) },
{ "Collisions", CPSW_STAT(txcollisionframes) },
{ "Single Collision Tx Frames", CPSW_STAT(txsinglecollframes) },
{ "Multiple Collision Tx Frames", CPSW_STAT(txmultcollframes) },
{ "Excessive Collisions", CPSW_STAT(txexcessivecollisions) },
{ "Late Collisions", CPSW_STAT(txlatecollisions) },
{ "Tx Underrun", CPSW_STAT(txunderrun) },
{ "Carrier Sense Errors", CPSW_STAT(txcarriersenseerrors) },
{ "Tx Octets", CPSW_STAT(txoctets) },
{ "Rx + Tx 64 Octet Frames", CPSW_STAT(octetframes64) },
{ "Rx + Tx 65-127 Octet Frames", CPSW_STAT(octetframes65t127) },
{ "Rx + Tx 128-255 Octet Frames", CPSW_STAT(octetframes128t255) },
{ "Rx + Tx 256-511 Octet Frames", CPSW_STAT(octetframes256t511) },
{ "Rx + Tx 512-1023 Octet Frames", CPSW_STAT(octetframes512t1023) },
{ "Rx + Tx 1024-Up Octet Frames", CPSW_STAT(octetframes1024tup) },
{ "Net Octets", CPSW_STAT(netoctets) },
{ "Rx Start of Frame Overruns", CPSW_STAT(rxsofoverruns) },
{ "Rx Middle of Frame Overruns", CPSW_STAT(rxmofoverruns) },
{ "Rx DMA Overruns", CPSW_STAT(rxdmaoverruns) },
static const struct cpsw_stats cpsw_gstrings_ch_stats[] = {
{ "head_enqueue", CPDMA_RX_STAT(head_enqueue) },
{ "tail_enqueue", CPDMA_RX_STAT(tail_enqueue) },
{ "pad_enqueue", CPDMA_RX_STAT(pad_enqueue) },
{ "misqueued", CPDMA_RX_STAT(misqueued) },
{ "desc_alloc_fail", CPDMA_RX_STAT(desc_alloc_fail) },
{ "pad_alloc_fail", CPDMA_RX_STAT(pad_alloc_fail) },
{ "runt_receive_buf", CPDMA_RX_STAT(runt_receive_buff) },
{ "runt_transmit_buf", CPDMA_RX_STAT(runt_transmit_buff) },
{ "empty_dequeue", CPDMA_RX_STAT(empty_dequeue) },
{ "busy_dequeue", CPDMA_RX_STAT(busy_dequeue) },
{ "good_dequeue", CPDMA_RX_STAT(good_dequeue) },
{ "requeue", CPDMA_RX_STAT(requeue) },
{ "teardown_dequeue", CPDMA_RX_STAT(teardown_dequeue) },
#define CPSW_STATS_COMMON_LEN ARRAY_SIZE(cpsw_gstrings_stats)
#define CPSW_STATS_CH_LEN ARRAY_SIZE(cpsw_gstrings_ch_stats)
#define ndev_to_cpsw(ndev) (((struct cpsw_priv *)netdev_priv(ndev))->cpsw)
#define napi_to_cpsw(napi) container_of(napi, struct cpsw_common, napi)
#define for_each_slave(priv, func, arg...) \
do { \
struct cpsw_slave *slave; \
struct cpsw_common *cpsw = (priv)->cpsw; \
int n; \
if (cpsw->data.dual_emac) \
(func)((cpsw)->slaves + priv->emac_port, ##arg);\
else \
for (n = cpsw->data.slaves, \
slave = cpsw->slaves; \
n; n--) \
(func)(slave++, ##arg); \
} while (0)
static inline int cpsw_get_slave_port(u32 slave_num)
return slave_num + 1;
static void cpsw_add_mcast(struct cpsw_priv *priv, const u8 *addr)
struct cpsw_common *cpsw = priv->cpsw;
if (cpsw->data.dual_emac) {
struct cpsw_slave *slave = cpsw->slaves + priv->emac_port;
cpsw_ale_add_mcast(cpsw->ale, addr, ALE_PORT_HOST,
ALE_VLAN, slave->port_vlan, 0);
return;
cpsw_ale_add_mcast(cpsw->ale, addr, ALE_ALL_PORTS, 0, 0, 0);
static void cpsw_set_promiscious(struct net_device *ndev, bool enable)
struct cpsw_common *cpsw = ndev_to_cpsw(ndev);
struct cpsw_ale *ale = cpsw->ale;
int i;
bool flag = false;
/* Enabling promiscuous mode for one interface will be
* common for both the interface as the interface shares
* the same hardware resource.
for (i = 0; i < cpsw->data.slaves; i++)
if (cpsw->slaves[i].ndev->flags & IFF_PROMISC)
flag = true;
if (!enable && flag) {
enable = true;
dev_err(&ndev->dev, "promiscuity not disabled as the other interface is still in promiscuity mode\n");
if (enable) {
/* Enable Bypass */
cpsw_ale_control_set(ale, 0, ALE_BYPASS, 1);
dev_dbg(&ndev->dev, "promiscuity enabled\n");
} else {
/* Disable Bypass */
cpsw_ale_control_set(ale, 0, ALE_BYPASS, 0);
dev_dbg(&ndev->dev, "promiscuity disabled\n");
} else {
if (enable) {
unsigned long timeout = jiffies + HZ;
/* Disable Learn for all ports (host is port 0 and slaves are port 1 and up */
for (i = 0; i <= cpsw->data.slaves; i++) {
cpsw_ale_control_set(ale, i,
ALE_PORT_NOLEARN, 1);
ALE_PORT_NO_SA_UPDATE, 1);
/* Clear All Untouched entries */
cpsw_ale_control_set(ale, 0, ALE_AGEOUT, 1);
do {
cpu_relax();
if (cpsw_ale_control_get(ale, 0, ALE_AGEOUT))
break;
} while (time_after(timeout, jiffies));
/* Clear all mcast from ALE */
cpsw_ale_flush_multicast(ale, ALE_ALL_PORTS, -1);
__dev_mc_unsync(ndev, NULL);
/* Flood All Unicast Packets to Host port */
cpsw_ale_control_set(ale, 0, ALE_P0_UNI_FLOOD, 1);
} else {
/* Don't Flood All Unicast Packets to Host port */
cpsw_ale_control_set(ale, 0, ALE_P0_UNI_FLOOD, 0);
/* Enable Learn for all ports (host is port 0 and slaves are port 1 and up */
ALE_PORT_NOLEARN, 0);
ALE_PORT_NO_SA_UPDATE, 0);
static int cpsw_add_mc_addr(struct net_device *ndev, const u8 *addr)
struct cpsw_priv *priv = netdev_priv(ndev);
cpsw_add_mcast(priv, addr);
return 0;
static int cpsw_del_mc_addr(struct net_device *ndev, const u8 *addr)
int vid, flags;
vid = cpsw->slaves[priv->emac_port].port_vlan;
flags = ALE_VLAN;
} else {
vid = 0;
flags = 0;
cpsw_ale_del_mcast(cpsw->ale, addr, 0, flags, vid);
return 0;
static void cpsw_ndo_set_rx_mode(struct net_device *ndev)
if (ndev->flags & IFF_PROMISC) {
/* Enable promiscuous mode */
cpsw_set_promiscious(ndev, true);
cpsw_ale_set_allmulti(cpsw->ale, IFF_ALLMULTI);
return;
} else {
/* Disable promiscuous mode */
cpsw_set_promiscious(ndev, false);
/* Restore allmulti on vlans if necessary */
cpsw_ale_set_allmulti(cpsw->ale, ndev->flags & IFF_ALLMULTI);
__dev_mc_sync(ndev, cpsw_add_mc_addr, cpsw_del_mc_addr);
static void cpsw_intr_enable(struct cpsw_common *cpsw)
writel_relaxed(0xFF, &cpsw->wr_regs->tx_en);
writel_relaxed(0xFF, &cpsw->wr_regs->rx_en);
cpdma_ctlr_int_ctrl(cpsw->dma, true);
return;
static void cpsw_intr_disable(struct cpsw_common *cpsw)
writel_relaxed(0, &cpsw->wr_regs->tx_en);
writel_relaxed(0, &cpsw->wr_regs->rx_en);
cpdma_ctlr_int_ctrl(cpsw->dma, false);
return;
static void cpsw_tx_handler(void *token, int len, int status)
printk("========== cpsw_tx_handler \n");
struct netdev_queue *txq;
struct sk_buff *skb = token;
struct net_device *ndev = skb->dev;
/* Check whether the queue is stopped due to stalled tx dma, if the
* queue is stopped then start the queue as we have free desc for tx
txq = netdev_get_tx_queue(ndev, skb_get_queue_mapping(skb));
if (!cpsw->ecdev && unlikely(netif_tx_queue_stopped(txq)))
netif_tx_wake_queue(txq);
cpts_tx_timestamp(cpsw->cpts, skb);
ndev->stats.tx_packets++;
ndev->stats.tx_bytes += len;
if (!cpsw->ecdev){
dev_kfree_skb_any(skb);
static void cpsw_rx_vlan_encap(struct sk_buff *skb)
struct cpsw_priv *priv = netdev_priv(skb->dev);
u32 rx_vlan_encap_hdr = *((u32 *)skb->data);
u16 vtag, vid, prio, pkt_type;
/* Remove VLAN header encapsulation word */
skb_pull(skb, CPSW_RX_VLAN_ENCAP_HDR_SIZE);
pkt_type = (rx_vlan_encap_hdr >>
CPSW_RX_VLAN_ENCAP_HDR_PKT_TYPE_SHIFT) &
CPSW_RX_VLAN_ENCAP_HDR_PKT_TYPE_MSK;
/* Ignore unknown & Priority-tagged packets*/
if (pkt_type == CPSW_RX_VLAN_ENCAP_HDR_PKT_RESERV ||
pkt_type == CPSW_RX_VLAN_ENCAP_HDR_PKT_PRIO_TAG)
return;
vid = (rx_vlan_encap_hdr >>
CPSW_RX_VLAN_ENCAP_HDR_VID_SHIFT) &
VLAN_VID_MASK;
/* Ignore vid 0 and pass packet as is */
if (!vid)
return;
/* Ignore default vlans in dual mac mode */
if (cpsw->data.dual_emac &&
vid == cpsw->slaves[priv->emac_port].port_vlan)
return;
prio = (rx_vlan_encap_hdr >>
CPSW_RX_VLAN_ENCAP_HDR_PRIO_SHIFT) &
CPSW_RX_VLAN_ENCAP_HDR_PRIO_MSK;
vtag = (prio << VLAN_PRIO_SHIFT) | vid;
__vlan_hwaccel_put_tag(skb, htons(ETH_P_8021Q), vtag);
/* strip vlan tag for VLAN-tagged packet */
if (pkt_type == CPSW_RX_VLAN_ENCAP_HDR_PKT_VLAN_TAG) {
memmove(skb->data + VLAN_HLEN, skb->data, 2 * ETH_ALEN);
skb_pull(skb, VLAN_HLEN);
static void cpsw_rx_handler(void *token, int len, int status)
printk("========== cpsw_rx_handler \n");
struct sk_buff *new_skb;
int ret = 0, port;
struct cpsw_priv *priv;
int i;
port = CPDMA_RX_SOURCE_PORT(status);
if (port) {
ndev = cpsw->slaves[--port].ndev;
skb->dev = ndev;
if (unlikely(status < 0) || unlikely(!netif_running(ndev))) {
/* In dual emac mode check for all interfaces */
if (cpsw->data.dual_emac && cpsw->usage_count &&
(status >= 0)) {
/* The packet received is for the interface which
* is already down and the other interface is up
* and running, instead of freeing which results
* in reducing of the number of rx descriptor in
* DMA engine, requeue skb back to cpdma.
new_skb = skb;
goto requeue;
/* the interface is going down, skbs are purged */
if (!cpsw->ecdev){
return;
new_skb = netdev_alloc_skb_ip_align(ndev, cpsw->rx_packet_max);
if (new_skb) {
skb_copy_queue_mapping(new_skb, skb);
skb_put(skb, len);
if (status & CPDMA_RX_VLAN_ENCAP)
cpsw_rx_vlan_encap(skb);
if (priv->rx_ts_enabled)
cpts_rx_timestamp(cpsw->cpts, skb);
skb->protocol = eth_type_trans(skb, ndev);
netif_receive_skb(skb);
ndev->stats.rx_bytes += len;
ndev->stats.rx_packets++;
kmemleak_not_leak(new_skb);
} else {
ndev->stats.rx_dropped++;
new_skb = skb;
requeue:
if (!cpsw->ecdev && netif_dormant(ndev)) {
dev_kfree_skb_any(new_skb);
return;
ch = cpsw->rxv[skb_get_queue_mapping(new_skb)].ch;
ret = cpdma_chan_submit(ch, new_skb, new_skb->data,
skb_tailroom(new_skb), 0);
if (!cpsw->ecdev && WARN_ON(ret < 0))
static void cpsw_split_res(struct net_device *ndev)
u32 consumed_rate = 0, bigest_rate = 0;
struct cpsw_vector *txv = cpsw->txv;
int i, ch_weight, rlim_ch_num = 0;
int budget, bigest_rate_ch = 0;
u32 ch_rate, max_rate;
int ch_budget = 0;
for (i = 0; i < cpsw->tx_ch_num; i++) {
ch_rate = cpdma_chan_get_rate(txv[i].ch);
if (!ch_rate)
continue;
rlim_ch_num++;
consumed_rate += ch_rate;
if (cpsw->tx_ch_num == rlim_ch_num) {
max_rate = consumed_rate;
} else if (!rlim_ch_num) {
ch_budget = CPSW_POLL_WEIGHT / cpsw->tx_ch_num;
bigest_rate = 0;
} else {
max_rate = cpsw->speed * 1000;
/* if max_rate is less then expected due to reduced link speed,
* split proportionally according next potential max speed
if (max_rate < consumed_rate)
max_rate *= 10;
max_rate *= 10;
ch_budget = (consumed_rate * CPSW_POLL_WEIGHT) / max_rate;
ch_budget = (CPSW_POLL_WEIGHT - ch_budget) /
(cpsw->tx_ch_num - rlim_ch_num);
bigest_rate = (max_rate - consumed_rate) /
/* split tx weight/budget */
budget = CPSW_POLL_WEIGHT;
if (ch_rate) {
txv[i].budget = (ch_rate * CPSW_POLL_WEIGHT) / max_rate;
if (!txv[i].budget)
txv[i].budget++;
if (ch_rate > bigest_rate) {
bigest_rate_ch = i;
bigest_rate = ch_rate;
ch_weight = (ch_rate * 100) / max_rate;
if (!ch_weight)
ch_weight++;
cpdma_chan_set_weight(cpsw->txv[i].ch, ch_weight);
} else {
txv[i].budget = ch_budget;
if (!bigest_rate_ch)
bigest_rate_ch = i;
cpdma_chan_set_weight(cpsw->txv[i].ch, 0);
budget -= txv[i].budget;
if (budget)
txv[bigest_rate_ch].budget += budget;
/* split rx budget */
ch_budget = budget / cpsw->rx_ch_num;
for (i = 0; i < cpsw->rx_ch_num; i++) {
cpsw->rxv[i].budget = ch_budget;
budget -= ch_budget;
if (budget)
cpsw->rxv[0].budget += budget;
static int cpsw_tx_mq_poll(struct napi_struct *napi_tx, int budget)
printk("========== cpsw_tx_mq_poll \n");
u32 ch_map;
int num_tx, cur_budget, ch;
struct cpsw_common *cpsw = napi_to_cpsw(napi_tx);
struct cpsw_vector *txv;
/* process every unprocessed channel */
ch_map = cpdma_ctrl_txchs_state(cpsw->dma);
for (ch = 0, num_tx = 0; ch_map & 0xff; ch_map <<= 1, ch++) {
if (!(ch_map & 0x80))
continue;
txv = &cpsw->txv[ch];
if (unlikely(txv->budget > budget - num_tx))
cur_budget = budget - num_tx;
else
cur_budget = txv->budget;
num_tx += cpdma_chan_process(txv->ch, cur_budget);
if (num_tx >= budget)
break;
if (num_tx < budget) {
napi_complete(napi_tx);
writel(0xff, &cpsw->wr_regs->tx_en);
return num_tx;
static irqreturn_t cpsw_tx_interrupt(int irq, void *dev_id)
struct cpsw_common *cpsw = dev_id;
writel(0, &cpsw->wr_regs->tx_en);
cpdma_ctlr_eoi(cpsw->dma, CPDMA_EOI_TX);
if (cpsw->quirk_irq) {
disable_irq_nosync(cpsw->irqs_table[1]);
cpsw->tx_irq_disabled = true;
napi_schedule(&cpsw->napi_tx);
return IRQ_HANDLED;
static int cpsw_tx_poll(struct napi_struct *napi_tx, int budget)
int num_tx;
num_tx = cpdma_chan_process(cpsw->txv[0].ch, budget);
if (cpsw->tx_irq_disabled) {
cpsw->tx_irq_disabled = false;
enable_irq(cpsw->irqs_table[1]);
return num_tx;
static int cpsw_rx_mq_poll(struct napi_struct *napi_rx, int budget)
printk("========== cpsw_rx_mq_poll \n");
u32 ch_map;
int num_rx, cur_budget, ch;
struct cpsw_common *cpsw = napi_to_cpsw(napi_rx);
struct cpsw_vector *rxv;
ch_map = cpdma_ctrl_rxchs_state(cpsw->dma);
for (ch = 0, num_rx = 0; ch_map; ch_map >>= 1, ch++) {
if (!(ch_map & 0x01))
continue;
rxv = &cpsw->rxv[ch];
if (unlikely(rxv->budget > budget - num_rx))
cur_budget = budget - num_rx;
else
cur_budget = rxv->budget;
num_rx += cpdma_chan_process(rxv->ch, cur_budget);
if (num_rx >= budget)
break;
if (num_rx < budget) {
napi_complete_done(napi_rx, num_rx);
writel(0xff, &cpsw->wr_regs->rx_en);
return num_rx;
static irqreturn_t cpsw_rx_interrupt(int irq, void *dev_id)
writel(0, &cpsw->wr_regs->rx_en);
cpdma_ctlr_eoi(cpsw->dma, CPDMA_EOI_RX);
disable_irq_nosync(cpsw->irqs_table[0]);
cpsw->rx_irq_disabled = true;
napi_schedule(&cpsw->napi_rx);
return IRQ_HANDLED;
static int cpsw_rx_poll(struct napi_struct *napi_rx, int budget)
int num_rx;
num_rx = cpdma_chan_process(cpsw->rxv[0].ch, budget);
if (!cpsw->ecdev && cpsw->rx_irq_disabled) {
cpsw->rx_irq_disabled = false;
enable_irq(cpsw->irqs_table[0]);
return num_rx;
static inline void soft_reset(const char *module, void __iomem *reg)
writel_relaxed(1, reg);
do {
cpu_relax();
} while ((readl_relaxed(reg) & 1) && time_after(timeout, jiffies));
WARN(readl_relaxed(reg) & 1, "failed to soft-reset %s\n", module);
static void cpsw_set_slave_mac(struct cpsw_slave *slave,
struct cpsw_priv *priv)
slave_write(slave, mac_hi(priv->mac_addr), SA_HI);
slave_write(slave, mac_lo(priv->mac_addr), SA_LO);
static bool cpsw_shp_is_off(struct cpsw_priv *priv)
u32 shift, mask, val;
val = readl_relaxed(&cpsw->regs->ptype);
slave = &cpsw->slaves[cpsw_slave_index(cpsw, priv)];
shift = CPSW_FIFO_SHAPE_EN_SHIFT + 3 * slave->slave_num;
mask = 7 << shift;
val = val & mask;
return !val;
static void cpsw_fifo_shp_on(struct cpsw_priv *priv, int fifo, int on)
mask = (1 << --fifo) << shift;
val = on ? val | mask : val & ~mask;
writel_relaxed(val, &cpsw->regs->ptype);
static void _cpsw_adjust_link(struct cpsw_slave *slave,
struct cpsw_priv *priv, bool *link)
struct phy_device *phy = slave->phy;
u32 mac_control = 0;
u32 slave_port;
if (!phy)
return;
slave_port = cpsw_get_slave_port(slave->slave_num);
if (phy->link) {
mac_control = cpsw->data.mac_control;
/* enable forwarding */
cpsw_ale_control_set(cpsw->ale, slave_port,
ALE_PORT_STATE,
priv->port_state[slave_port]);
if (phy->speed == 1000)
mac_control |= BIT(7); /* GIGABITEN */
if (phy->duplex)
mac_control |= BIT(0); /* FULLDUPLEXEN */
/* set speed_in input in case RMII mode is used in 100Mbps */
if (phy->speed == 100)
mac_control |= BIT(15);
/* in band mode only works in 10Mbps RGMII mode */
else if ((phy->speed == 10) && phy_interface_is_rgmii(phy))
mac_control |= BIT(18); /* In Band mode */
if (priv->rx_pause)
mac_control |= BIT(3);
if (priv->tx_pause)
mac_control |= BIT(4);
*link = true;
if (priv->shp_cfg_speed &&
priv->shp_cfg_speed != slave->phy->speed &&
!cpsw_shp_is_off(priv))
dev_warn(priv->dev,
"Speed was changed, CBS shaper speeds are changed!");
} else {
mac_control = 0;
/* disable forwarding */
ALE_PORT_STATE, ALE_PORT_STATE_DISABLE);
if (mac_control != slave->mac_control) {
phy_print_status(phy);
writel_relaxed(mac_control, &slave->sliver->mac_control);
slave->mac_control = mac_control;
static int cpsw_get_common_speed(struct cpsw_common *cpsw)
int i, speed;
for (i = 0, speed = 0; i < cpsw->data.slaves; i++)
if (cpsw->slaves[i].phy && cpsw->slaves[i].phy->link)
speed += cpsw->slaves[i].phy->speed;
return speed;
static int cpsw_need_resplit(struct cpsw_common *cpsw)
int i, rlim_ch_num;
int speed, ch_rate;
/* re-split resources only in case speed was changed */
speed = cpsw_get_common_speed(cpsw);
if (speed == cpsw->speed || !speed)
return 0;
cpsw->speed = speed;
for (i = 0, rlim_ch_num = 0; i < cpsw->tx_ch_num; i++) {
ch_rate = cpdma_chan_get_rate(cpsw->txv[i].ch);
if (!ch_rate)
break;
rlim_ch_num++;
/* cases not dependent on speed */
if (!rlim_ch_num || rlim_ch_num == cpsw->tx_ch_num)
return 0;
return 1;
static void cpsw_adjust_link(struct net_device *ndev)
bool link = false;
for_each_slave(priv, _cpsw_adjust_link, priv, &link);
if (cpsw->ecdev) {
ecdev_set_link(cpsw->ecdev, link?1:0);
return;
if (link) {
if (cpsw_need_resplit(cpsw))
cpsw_split_res(ndev);
netif_carrier_on(ndev);
if (netif_running(ndev))
netif_tx_wake_all_queues(ndev);
} else {
netif_carrier_off(ndev);
netif_tx_stop_all_queues(ndev);
static int cpsw_get_coalesce(struct net_device *ndev,
struct ethtool_coalesce *coal)
coal->rx_coalesce_usecs = cpsw->coal_intvl;
return 0;
static int cpsw_set_coalesce(struct net_device *ndev,
u32 int_ctrl;
u32 num_interrupts = 0;
u32 prescale = 0;
u32 addnl_dvdr = 1;
u32 coal_intvl = 0;
coal_intvl = coal->rx_coalesce_usecs;
int_ctrl = readl(&cpsw->wr_regs->int_control);
prescale = cpsw->bus_freq_mhz * 4;
if (!coal->rx_coalesce_usecs) {
int_ctrl &= ~(CPSW_INTPRESCALE_MASK | CPSW_INTPACEEN);
goto update_return;
if (coal_intvl < CPSW_CMINTMIN_INTVL)
coal_intvl = CPSW_CMINTMIN_INTVL;
if (coal_intvl > CPSW_CMINTMAX_INTVL) {
/* Interrupt pacer works with 4us Pulse, we can
* throttle further by dilating the 4us pulse.
addnl_dvdr = CPSW_INTPRESCALE_MASK / prescale;
if (addnl_dvdr > 1) {
prescale *= addnl_dvdr;
if (coal_intvl > (CPSW_CMINTMAX_INTVL * addnl_dvdr))
coal_intvl = (CPSW_CMINTMAX_INTVL
* addnl_dvdr);
} else {
addnl_dvdr = 1;
coal_intvl = CPSW_CMINTMAX_INTVL;
num_interrupts = (1000 * addnl_dvdr) / coal_intvl;
writel(num_interrupts, &cpsw->wr_regs->rx_imax);
writel(num_interrupts, &cpsw->wr_regs->tx_imax);
int_ctrl |= CPSW_INTPACEEN;
int_ctrl &= (~CPSW_INTPRESCALE_MASK);
int_ctrl |= (prescale & CPSW_INTPRESCALE_MASK);
update_return:
writel(int_ctrl, &cpsw->wr_regs->int_control);
cpsw_notice(priv, timer, "Set coalesce to %d usecs.\n", coal_intvl);
cpsw->coal_intvl = coal_intvl;
return 0;
static int cpsw_get_sset_count(struct net_device *ndev, int sset)
switch (sset) {
case ETH_SS_STATS:
return (CPSW_STATS_COMMON_LEN +
(cpsw->rx_ch_num + cpsw->tx_ch_num) *
CPSW_STATS_CH_LEN);
default:
return -EOPNOTSUPP;
static void cpsw_add_ch_strings(u8 **p, int ch_num, int rx_dir)
int ch_stats_len;
int line;
int i;
ch_stats_len = CPSW_STATS_CH_LEN * ch_num;
for (i = 0; i < ch_stats_len; i++) {
line = i % CPSW_STATS_CH_LEN;
snprintf(*p, ETH_GSTRING_LEN,
"%s DMA chan %ld: %s", rx_dir ? "Rx" : "Tx",
(long)(i / CPSW_STATS_CH_LEN),
cpsw_gstrings_ch_stats[line].stat_string);
*p += ETH_GSTRING_LEN;
static void cpsw_get_strings(struct net_device *ndev, u32 stringset, u8 *data)
u8 *p = data;
int i;
switch (stringset) {
case ETH_SS_STATS:
for (i = 0; i < CPSW_STATS_COMMON_LEN; i++) {
memcpy(p, cpsw_gstrings_stats[i].stat_string,
ETH_GSTRING_LEN);
cpsw_add_ch_strings(&p, cpsw->rx_ch_num, 1);
cpsw_add_ch_strings(&p, cpsw->tx_ch_num, 0);
break;
static void cpsw_get_ethtool_stats(struct net_device *ndev,
struct ethtool_stats *stats, u64 *data)
u8 *p;
struct cpdma_chan_stats ch_stats;
int i, l, ch;
/* Collect Davinci CPDMA stats for Rx and Tx Channel */
for (l = 0; l < CPSW_STATS_COMMON_LEN; l++)
data[l] = readl(cpsw->hw_stats +
cpsw_gstrings_stats[l].stat_offset);
for (ch = 0; ch < cpsw->rx_ch_num; ch++) {
cpdma_chan_get_stats(cpsw->rxv[ch].ch, &ch_stats);
for (i = 0; i < CPSW_STATS_CH_LEN; i++, l++) {
p = (u8 *)&ch_stats +
cpsw_gstrings_ch_stats[i].stat_offset;
data[l] = *(u32 *)p;
for (ch = 0; ch < cpsw->tx_ch_num; ch++) {
cpdma_chan_get_stats(cpsw->txv[ch].ch, &ch_stats);
static inline int cpsw_tx_packet_submit(struct cpsw_priv *priv,
struct sk_buff *skb,
struct cpdma_chan *txch)
skb_tx_timestamp(skb);
return cpdma_chan_submit(txch, skb, skb->data, skb->len,
priv->emac_port + cpsw->data.dual_emac);
static inline void cpsw_add_dual_emac_def_ale_entries(
struct cpsw_priv *priv, struct cpsw_slave *slave,
u32 slave_port)
u32 port_mask = 1 << slave_port | ALE_PORT_HOST;
if (cpsw->version == CPSW_VERSION_1)
slave_write(slave, slave->port_vlan, CPSW1_PORT_VLAN);
else
slave_write(slave, slave->port_vlan, CPSW2_PORT_VLAN);
cpsw_ale_add_vlan(cpsw->ale, slave->port_vlan, port_mask,
port_mask, port_mask, 0);
cpsw_ale_add_mcast(cpsw->ale, priv->ndev->broadcast,
ALE_PORT_HOST, ALE_VLAN, slave->port_vlan, 0);
cpsw_ale_add_ucast(cpsw->ale, priv->mac_addr,
HOST_PORT_NUM, ALE_VLAN |
ALE_SECURE, slave->port_vlan);
ALE_PORT_DROP_UNKNOWN_VLAN, 1);
static void soft_reset_slave(struct cpsw_slave *slave)
char name[32];
snprintf(name, sizeof(name), "slave-%d", slave->slave_num);
soft_reset(name, &slave->sliver->soft_reset);
static void cpsw_slave_open(struct cpsw_slave *slave, struct cpsw_priv *priv)
u32 slave_port;
soft_reset_slave(slave);
/* setup priority mapping */
writel_relaxed(RX_PRIORITY_MAPPING, &slave->sliver->rx_pri_map);
switch (cpsw->version) {
case CPSW_VERSION_1:
slave_write(slave, TX_PRIORITY_MAPPING, CPSW1_TX_PRI_MAP);
/* Increase RX FIFO size to 5 for supporting fullduplex
* flow control mode
slave_write(slave,
(CPSW_MAX_BLKS_TX << CPSW_MAX_BLKS_TX_SHIFT) |
CPSW_MAX_BLKS_RX, CPSW1_MAX_BLKS);
break;
case CPSW_VERSION_2:
case CPSW_VERSION_3:
case CPSW_VERSION_4:
slave_write(slave, TX_PRIORITY_MAPPING, CPSW2_TX_PRI_MAP);
* flow control mode
slave_write(slave,
CPSW_MAX_BLKS_RX, CPSW2_MAX_BLKS);
break;
/* setup max packet size, and mac address */
writel_relaxed(cpsw->rx_packet_max, &slave->sliver->rx_maxlen);
cpsw_set_slave_mac(slave, priv);
slave->mac_control = 0; /* no link yet */
priv->port_state[slave_port] = ALE_PORT_STATE_FORWARD;
cpsw_add_dual_emac_def_ale_entries(priv, slave, slave_port);
else
1 << slave_port, 0, 0, ALE_MCAST_FWD_2);
if (slave->data->phy_node) {
phy = of_phy_connect(priv->ndev, slave->data->phy_node,
&cpsw_adjust_link, 0, slave->data->phy_if);
if (!phy) {
dev_err(priv->dev, "phy \"%pOF\" not found on slave %d\n",
slave->slave_num);
return;
} else {
phy = phy_connect(priv->ndev, slave->data->phy_id,
&cpsw_adjust_link, slave->data->phy_if);
if (IS_ERR(phy)) {
dev_err(priv->dev,
"phy \"%s\" not found on slave %d, err %ld\n",
slave->data->phy_id, slave->slave_num,
PTR_ERR(phy));
return;
slave->phy = phy;
phy_attached_info(slave->phy);
phy_start(slave->phy);
/* Configure GMII_SEL register */
cpsw_phy_sel(cpsw->dev, slave->phy->interface, slave->slave_num);
static inline void cpsw_add_default_vlan(struct cpsw_priv *priv)
const int vlan = cpsw->data.default_vlan;
u32 reg;
int i;
int unreg_mcast_mask;
reg = (cpsw->version == CPSW_VERSION_1) ? CPSW1_PORT_VLAN :
CPSW2_PORT_VLAN;
writel(vlan, &cpsw->host_port_regs->port_vlan);
slave_write(cpsw->slaves + i, vlan, reg);
if (priv->ndev->flags & IFF_ALLMULTI)
unreg_mcast_mask = ALE_ALL_PORTS;
else
unreg_mcast_mask = ALE_PORT_1 | ALE_PORT_2;
cpsw_ale_add_vlan(cpsw->ale, vlan, ALE_ALL_PORTS,
ALE_ALL_PORTS, ALE_ALL_PORTS,
unreg_mcast_mask);
static void cpsw_init_host_port(struct cpsw_priv *priv)
u32 fifo_mode;
u32 control_reg;
/* soft reset the controller and initialize ale */
soft_reset("cpsw", &cpsw->regs->soft_reset);
cpsw_ale_start(cpsw->ale);
/* switch to vlan unaware mode */
cpsw_ale_control_set(cpsw->ale, HOST_PORT_NUM, ALE_VLAN_AWARE,
CPSW_ALE_VLAN_AWARE);
control_reg = readl(&cpsw->regs->control);
control_reg |= CPSW_VLAN_AWARE | CPSW_RX_VLAN_ENCAP;
writel(control_reg, &cpsw->regs->control);
fifo_mode = (cpsw->data.dual_emac) ? CPSW_FIFO_DUAL_MAC_MODE :
CPSW_FIFO_NORMAL_MODE;
writel(fifo_mode, &cpsw->host_port_regs->tx_in_ctl);
/* setup host port priority mapping */
writel_relaxed(CPDMA_TX_PRIORITY_MAP,
&cpsw->host_port_regs->cpdma_tx_pri_map);
writel_relaxed(0, &cpsw->host_port_regs->cpdma_rx_chan_map);
ALE_PORT_STATE, ALE_PORT_STATE_FORWARD);
if (!cpsw->data.dual_emac) {
cpsw_ale_add_ucast(cpsw->ale, priv->mac_addr, HOST_PORT_NUM,
0, 0);
ALE_PORT_HOST, 0, 0, ALE_MCAST_FWD_2);
static int cpsw_fill_rx_channels(struct cpsw_priv *priv)
struct sk_buff *skb;
int ch_buf_num;
int ch, i, ret;
ch_buf_num = cpdma_chan_get_rx_buf_num(cpsw->rxv[ch].ch);
for (i = 0; i < ch_buf_num; i++) {
skb = __netdev_alloc_skb_ip_align(priv->ndev,
GFP_KERNEL);
if (!skb) {
cpsw_err(priv, ifup, "cannot allocate skb\n");
return -ENOMEM;
skb_set_queue_mapping(skb, ch);
ret = cpdma_chan_submit(cpsw->rxv[ch].ch, skb,
skb->data, skb_tailroom(skb),
0);
if (ret < 0) {
"cannot submit skb to channel %d rx, error %d\n",
ch, ret);
kfree_skb(skb);
return ret;
kmemleak_not_leak(skb);
cpsw_info(priv, ifup, "ch %d rx, submitted %d descriptors\n",
ch, ch_buf_num);
return 0;
static void cpsw_slave_stop(struct cpsw_slave *slave, struct cpsw_common *cpsw)
u32 slave_port;
if (!slave->phy)
return;
phy_stop(slave->phy);
phy_disconnect(slave->phy);
slave->phy = NULL;
static int cpsw_tc_to_fifo(int tc, int num_tc)
if (tc == num_tc - 1)
return 0;
return CPSW_FIFO_SHAPERS_NUM - tc;
static int cpsw_set_fifo_bw(struct cpsw_priv *priv, int fifo, int bw)
u32 val = 0, send_pct, shift;
int pct = 0, i;
if (bw > priv->shp_cfg_speed * 1000)
goto err;
/* shaping has to stay enabled for highest fifos linearly
* and fifo bw no more then interface can allow
send_pct = slave_read(slave, SEND_PERCENT);
for (i = CPSW_FIFO_SHAPERS_NUM; i > 0; i--) {
if (!bw) {
if (i >= fifo || !priv->fifo_bw[i])
continue;
dev_warn(priv->dev, "Prev FIFO%d is shaped", i);
continue;
if (!priv->fifo_bw[i] && i > fifo) {
dev_err(priv->dev, "Upper FIFO%d is not shaped", i);
return -EINVAL;
shift = (i - 1) * 8;
if (i == fifo) {
send_pct &= ~(CPSW_PCT_MASK << shift);
val = DIV_ROUND_UP(bw, priv->shp_cfg_speed * 10);
if (!val)
val = 1;
send_pct |= val << shift;
pct += val;
continue;
if (priv->fifo_bw[i])
pct += (send_pct >> shift) & CPSW_PCT_MASK;
if (pct >= 100)
goto err;
slave_write(slave, send_pct, SEND_PERCENT);
priv->fifo_bw[fifo] = bw;
dev_warn(priv->dev, "set FIFO%d bw = %d\n", fifo,
DIV_ROUND_CLOSEST(val * priv->shp_cfg_speed, 100));
return 0;
err:
dev_err(priv->dev, "Bandwidth doesn't fit in tc configuration");
return -EINVAL;
static int cpsw_set_fifo_rlimit(struct cpsw_priv *priv, int fifo, int bw)
u32 tx_in_ctl_rg, val;
int ret;
ret = cpsw_set_fifo_bw(priv, fifo, bw);
if (ret)
return ret;
tx_in_ctl_rg = cpsw->version == CPSW_VERSION_1 ?
CPSW1_TX_IN_CTL : CPSW2_TX_IN_CTL;
if (!bw)
cpsw_fifo_shp_on(priv, fifo, bw);
val = slave_read(slave, tx_in_ctl_rg);
if (cpsw_shp_is_off(priv)) {
/* disable FIFOs rate limited queues */
val &= ~(0xf << CPSW_FIFO_RATE_EN_SHIFT);
/* set type of FIFO queues to normal priority mode */
val &= ~(3 << CPSW_FIFO_QUEUE_TYPE_SHIFT);
/* set type of FIFO queues to be rate limited */
if (bw)
val |= 2 << CPSW_FIFO_QUEUE_TYPE_SHIFT;
else
priv->shp_cfg_speed = 0;
/* toggle a FIFO rate limited queue */
if (bw)
val |= BIT(fifo + CPSW_FIFO_RATE_EN_SHIFT);
else
val &= ~BIT(fifo + CPSW_FIFO_RATE_EN_SHIFT);
slave_write(slave, val, tx_in_ctl_rg);
/* FIFO transmit shape enable */
return 0;
/* Defaults:
* class A - prio 3
* class B - prio 2
* shaping for class A should be set first
static int cpsw_set_cbs(struct net_device *ndev,
struct tc_cbs_qopt_offload *qopt)
int prev_speed = 0;
int tc, ret, fifo;
u32 bw = 0;
tc = netdev_txq_to_tc(priv->ndev, qopt->queue);
/* enable channels in backward order, as highest FIFOs must be rate
* limited first and for compliance with CPDMA rate limited channels
* that also used in bacward order. FIFO0 cannot be rate limited.
fifo = cpsw_tc_to_fifo(tc, ndev->num_tc);
if (!fifo) {
dev_err(priv->dev, "Last tc%d can't be rate limited", tc);
return -EINVAL;
/* do nothing, it's disabled anyway */
if (!qopt->enable && !priv->fifo_bw[fifo])
return 0;
/* shapers can be set if link speed is known */
if (slave->phy && slave->phy->link) {
priv->shp_cfg_speed != slave->phy->speed)
prev_speed = priv->shp_cfg_speed;
priv->shp_cfg_speed = slave->phy->speed;
if (!priv->shp_cfg_speed) {
dev_err(priv->dev, "Link speed is not known");
return -1;
ret = pm_runtime_get_sync(cpsw->dev);
if (ret < 0) {
pm_runtime_put_noidle(cpsw->dev);
return ret;
bw = qopt->enable ? qopt->idleslope : 0;
ret = cpsw_set_fifo_rlimit(priv, fifo, bw);
if (ret) {
priv->shp_cfg_speed = prev_speed;
prev_speed = 0;
if (bw && prev_speed)
dev_warn(priv->dev,
pm_runtime_put_sync(cpsw->dev);
return ret;
static void cpsw_cbs_resume(struct cpsw_slave *slave, struct cpsw_priv *priv)
int fifo, bw;
for (fifo = CPSW_FIFO_SHAPERS_NUM; fifo > 0; fifo--) {
bw = priv->fifo_bw[fifo];
if (!bw)
continue;
static void cpsw_mqprio_resume(struct cpsw_slave *slave, struct cpsw_priv *priv)
u32 tx_prio_map = 0;
int i, tc, fifo;
u32 tx_prio_rg;
if (!priv->mqprio_hw)
return;
for (i = 0; i < 8; i++) {
tc = netdev_get_prio_tc_map(priv->ndev, i);
fifo = CPSW_FIFO_SHAPERS_NUM - tc;
tx_prio_map |= fifo << (4 * i);
tx_prio_rg = cpsw->version == CPSW_VERSION_1 ?
CPSW1_TX_PRI_MAP : CPSW2_TX_PRI_MAP;
slave_write(slave, tx_prio_map, tx_prio_rg);
/* restore resources after port reset */
static void cpsw_restore(struct cpsw_priv *priv)
/* restore MQPRIO offload */
for_each_slave(priv, cpsw_mqprio_resume, priv);
/* restore CBS offload */
for_each_slave(priv, cpsw_cbs_resume, priv);
static int cpsw_ndo_open(struct net_device *ndev)
int ret;
u32 reg;
if (ret < 0) {
return ret;
if (!cpsw->ecdev) {
/* Notify the stack of the actual queue counts. */
ret = netif_set_real_num_tx_queues(ndev, cpsw->tx_ch_num);
if (ret) {
dev_err(priv->dev, "cannot set real number of tx queues\n");
goto err_cleanup;
ret = netif_set_real_num_rx_queues(ndev, cpsw->rx_ch_num);
if (ret) {
dev_err(priv->dev, "cannot set real number of rx queues\n");
goto err_cleanup;
reg = cpsw->version;
dev_info(priv->dev, "initializing cpsw version %d.%d (%d)\n",
CPSW_MAJOR_VERSION(reg), CPSW_MINOR_VERSION(reg),
CPSW_RTL_VERSION(reg));
/* Initialize host and slave ports */
if (!cpsw->usage_count)
cpsw_init_host_port(priv);
for_each_slave(priv, cpsw_slave_open, priv);
/* Add default VLAN */
cpsw_add_default_vlan(priv);
else
cpsw_ale_add_vlan(cpsw->ale, cpsw->data.default_vlan,
ALE_ALL_PORTS, ALE_ALL_PORTS, 0, 0);
/* initialize shared resources for every ndev */
if (!cpsw->usage_count) {
/* disable priority elevation */
writel_relaxed(0, &cpsw->regs->ptype);
/* enable statistics collection only on all ports */
writel_relaxed(0x7, &cpsw->regs->stat_port_en);
/* Enable internal fifo flow control */
writel(0x7, &cpsw->regs->flow_control);
if (!cpsw->ecdev) {
napi_enable(&cpsw->napi_rx);
napi_enable(&cpsw->napi_tx);
if (!cpsw->ecdev && cpsw->tx_irq_disabled) {
ret = cpsw_fill_rx_channels(priv);
if (ret < 0)
goto err_cleanup;
if (cpts_register(cpsw->cpts))
dev_err(priv->dev, "error registering cpts device\n");
cpsw_restore(priv);
/* Enable Interrupt pacing if configured */
if (cpsw->coal_intvl != 0) {
struct ethtool_coalesce coal;
coal.rx_coalesce_usecs = cpsw->coal_intvl;
cpsw_set_coalesce(ndev, &coal);
cpdma_ctlr_start(cpsw->dma);
cpsw_intr_enable(cpsw);
cpsw->usage_count++;
return 0;
err_cleanup:
cpdma_ctlr_stop(cpsw->dma);
for_each_slave(priv, cpsw_slave_stop, cpsw);
if (!cpsw->ecdev)
netif_carrier_off(priv->ndev);
return ret;
static int cpsw_ndo_stop(struct net_device *ndev)
cpsw_info(priv, ifdown, "shutting down cpsw device\n");
__dev_mc_unsync(priv->ndev, cpsw_del_mc_addr);
if (!cpsw->ecdev) {
netif_tx_stop_all_queues(priv->ndev);
if (cpsw->usage_count <= 1) {
napi_disable(&cpsw->napi_rx);
napi_disable(&cpsw->napi_tx);
cpts_unregister(cpsw->cpts);
cpsw_intr_disable(cpsw);
cpsw_ale_stop(cpsw->ale);
cpsw->usage_count--;
return 0;
static netdev_tx_t cpsw_ndo_start_xmit(struct sk_buff *skb,
struct cpts *cpts = cpsw->cpts;
struct cpdma_chan *txch;
int ret, q_idx;
if (skb_padto(skb, tx_packet_min)) {
cpsw_err(priv, tx_err, "packet pad failed\n");
ndev->stats.tx_dropped++;
return NET_XMIT_DROP;
if (skb_shinfo(skb)->tx_flags & SKBTX_HW_TSTAMP &&
priv->tx_ts_enabled && cpts_can_timestamp(cpts, skb))
skb_shinfo(skb)->tx_flags |= SKBTX_IN_PROGRESS;
q_idx = skb_get_queue_mapping(skb);
if (q_idx >= cpsw->tx_ch_num)
q_idx = q_idx % cpsw->tx_ch_num;
txch = cpsw->txv[q_idx].ch;
txq = netdev_get_tx_queue(ndev, q_idx);
ret = cpsw_tx_packet_submit(priv, skb, txch);
if (unlikely(ret != 0)) {
cpsw_err(priv, tx_err, "desc submit failed\n");
goto fail;
/* If there is no more tx desc left free then we need to
* tell the kernel to stop sending us tx frames.
if (unlikely(!cpdma_check_free_tx_desc(txch))) {
if (!cpsw->ecdev)
netif_tx_stop_queue(txq);
/* Barrier, so that stop_queue visible to other cpus */
smp_mb__after_atomic();
if (!cpsw->ecdev && cpdma_check_free_tx_desc(txch))
return NETDEV_TX_OK;
fail:
if (!cpsw->ecdev) {
return NETDEV_TX_BUSY;
#if IS_ENABLED(CONFIG_TI_CPTS)
static void cpsw_hwtstamp_v1(struct cpsw_priv *priv)
struct cpsw_slave *slave = &cpsw->slaves[cpsw->data.active_slave];
u32 ts_en, seq_id;
if (!priv->tx_ts_enabled && !priv->rx_ts_enabled) {
slave_write(slave, 0, CPSW1_TS_CTL);
return;
seq_id = (30 << CPSW_V1_SEQ_ID_OFS_SHIFT) | ETH_P_1588;
ts_en = EVENT_MSG_BITS << CPSW_V1_MSG_TYPE_OFS;
if (priv->tx_ts_enabled)
ts_en |= CPSW_V1_TS_TX_EN;
ts_en |= CPSW_V1_TS_RX_EN;
slave_write(slave, ts_en, CPSW1_TS_CTL);
slave_write(slave, seq_id, CPSW1_TS_SEQ_LTYPE);
static void cpsw_hwtstamp_v2(struct cpsw_priv *priv)
u32 ctrl, mtype;
ctrl = slave_read(slave, CPSW2_CONTROL);
ctrl &= ~CTRL_V2_ALL_TS_MASK;
ctrl |= CTRL_V2_TX_TS_BITS;
ctrl |= CTRL_V2_RX_TS_BITS;
break;
default:
ctrl &= ~CTRL_V3_ALL_TS_MASK;
ctrl |= CTRL_V3_TX_TS_BITS;
ctrl |= CTRL_V3_RX_TS_BITS;
break;
mtype = (30 << TS_SEQ_ID_OFFSET_SHIFT) | EVENT_MSG_BITS;
slave_write(slave, mtype, CPSW2_TS_SEQ_MTYPE);
slave_write(slave, ctrl, CPSW2_CONTROL);
writel_relaxed(ETH_P_1588, &cpsw->regs->ts_ltype);
writel_relaxed(ETH_P_8021Q, &cpsw->regs->vlan_ltype);
static int cpsw_hwtstamp_set(struct net_device *dev, struct ifreq *ifr)
struct cpsw_priv *priv = netdev_priv(dev);
struct hwtstamp_config cfg;
if (cpsw->version != CPSW_VERSION_1 &&
cpsw->version != CPSW_VERSION_2 &&
cpsw->version != CPSW_VERSION_3)
return -EOPNOTSUPP;
if (copy_from_user(&cfg, ifr->ifr_data, sizeof(cfg)))
return -EFAULT;
/* reserved for future extensions */
if (cfg.flags)
return -EINVAL;
if (cfg.tx_type != HWTSTAMP_TX_OFF && cfg.tx_type != HWTSTAMP_TX_ON)
return -ERANGE;
switch (cfg.rx_filter) {
case HWTSTAMP_FILTER_NONE:
priv->rx_ts_enabled = 0;
break;
case HWTSTAMP_FILTER_ALL:
case HWTSTAMP_FILTER_NTP_ALL:
return -ERANGE;
case HWTSTAMP_FILTER_PTP_V1_L4_EVENT:
case HWTSTAMP_FILTER_PTP_V1_L4_SYNC:
case HWTSTAMP_FILTER_PTP_V1_L4_DELAY_REQ:
priv->rx_ts_enabled = HWTSTAMP_FILTER_PTP_V1_L4_EVENT;
cfg.rx_filter = HWTSTAMP_FILTER_PTP_V1_L4_EVENT;
break;
case HWTSTAMP_FILTER_PTP_V2_L4_EVENT:
case HWTSTAMP_FILTER_PTP_V2_L4_SYNC:
case HWTSTAMP_FILTER_PTP_V2_L4_DELAY_REQ:
case HWTSTAMP_FILTER_PTP_V2_L2_EVENT:
case HWTSTAMP_FILTER_PTP_V2_L2_SYNC:
case HWTSTAMP_FILTER_PTP_V2_L2_DELAY_REQ:
case HWTSTAMP_FILTER_PTP_V2_EVENT:
case HWTSTAMP_FILTER_PTP_V2_SYNC:
case HWTSTAMP_FILTER_PTP_V2_DELAY_REQ:
priv->rx_ts_enabled = HWTSTAMP_FILTER_PTP_V2_EVENT;
cfg.rx_filter = HWTSTAMP_FILTER_PTP_V2_EVENT;
break;
default:
return -ERANGE;
priv->tx_ts_enabled = cfg.tx_type == HWTSTAMP_TX_ON;
cpsw_hwtstamp_v1(priv);
break;
cpsw_hwtstamp_v2(priv);
break;
default:
WARN_ON(1);
return copy_to_user(ifr->ifr_data, &cfg, sizeof(cfg)) ? -EFAULT : 0;
static int cpsw_hwtstamp_get(struct net_device *dev, struct ifreq *ifr)
struct cpsw_common *cpsw = ndev_to_cpsw(dev);
return -EOPNOTSUPP;
cfg.flags = 0;
cfg.tx_type = priv->tx_ts_enabled ? HWTSTAMP_TX_ON : HWTSTAMP_TX_OFF;
cfg.rx_filter = priv->rx_ts_enabled;
#else
return -EOPNOTSUPP;
return -EOPNOTSUPP;
#endif /*CONFIG_TI_CPTS*/
static int cpsw_set_port_state(struct cpsw_priv *priv, int port,
int port_state)
switch (port_state) {
case PORT_STATE_DISABLED:
priv->port_state[port] = ALE_PORT_STATE_DISABLE;
break;
case PORT_STATE_BLOCKED:
priv->port_state[port] = ALE_PORT_STATE_BLOCK;
break;
case PORT_STATE_LEARN:
priv->port_state[port] = ALE_PORT_STATE_LEARN;
break;
case PORT_STATE_FORWARD:
priv->port_state[port] = ALE_PORT_STATE_FORWARD;
break;
default:
dev_err(priv->dev, "Switch config: Invalid port state\n");
return -EINVAL;
return cpsw_ale_control_set(priv->cpsw->ale, port, ALE_PORT_STATE,
priv->port_state[port]);
static int cpsw_switch_config_ioctl(struct net_device *ndev,
struct ifreq *ifrq, int cmd)
struct net_switch_config config;
int ret = -EINVAL;
dev_err(priv->dev, "CPSW not in switch mode\n");
return -ENOTSUPP;
/* Only SIOCSWITCHCONFIG is used as cmd argument and hence, there is no
* switch statement required.
* Function calls are based on switch_config.cmd
if (copy_from_user(&config, (ifrq->ifr_data), sizeof(config)))
return -EFAULT;
if (config.vid > 4095) {
dev_err(priv->dev, "Invalid VLAN id Arguments for cmd %d\n",
config.cmd);
return ret;
switch (config.cmd) {
case CONFIG_SWITCH_ADD_MULTICAST:
if ((config.port > 0) && (config.port <= 7) &&
is_multicast_ether_addr(config.addr)) {
ret = cpsw_ale_add_mcast(cpsw->ale, config.addr,
config.port, ALE_VLAN,
config.vid, 0);
} else {
dev_err(priv->dev, "Invalid Arguments for cmd %d\n",
config.cmd);
break;
case CONFIG_SWITCH_DEL_MULTICAST:
if (is_multicast_ether_addr(config.addr)) {
ret = cpsw_ale_del_mcast(cpsw->ale, config.addr,
0, ALE_VLAN, config.vid);
} else {
config.cmd);
break;
case CONFIG_SWITCH_ADD_VLAN:
if ((config.port > 0) && (config.port <= 7)) {
ret = cpsw_ale_add_vlan(cpsw->ale, config.vid,
config.port,
config.untag_port,
config.reg_multi,
config.unreg_multi);
} else {
config.cmd);
break;
case CONFIG_SWITCH_DEL_VLAN:
ret = cpsw_ale_del_vlan(cpsw->ale, config.vid, 0);
break;
case CONFIG_SWITCH_SET_PORT_CONFIG:
struct phy_device *phy = NULL;
struct ethtool_link_ksettings cmd;
if ((config.port == 1) || (config.port == 2))
phy = cpsw->slaves[config.port - 1].phy;
if (!phy) {
dev_err(priv->dev, "Phy not Found\n");
break;
convert_legacy_settings_to_link_ksettings(&cmd, &config.ecmd);
cmd.base.phy_address = phy->mdio.addr;
ret = phy_ethtool_ksettings_set(phy, &cmd);
break;
case CONFIG_SWITCH_GET_PORT_CONFIG:
if (!phy) {
break;
phy_ethtool_ksettings_get(phy, &cmd);
convert_link_ksettings_to_legacy_settings(&config.ecmd, &cmd);
ret = copy_to_user(ifrq->ifr_data, &config, sizeof(config));
break;
case CONFIG_SWITCH_ADD_UNKNOWN_VLAN_INFO:
if ((config.unknown_vlan_member <= 7) &&
(config.unknown_vlan_untag <= 7) &&
(config.unknown_vlan_unreg_multi <= 7) &&
(config.unknown_vlan_reg_multi <= 7)) {
cpsw_ale_control_set(cpsw->ale, 0,
ALE_PORT_UNTAGGED_EGRESS,
config.unknown_vlan_untag);
ALE_PORT_UNKNOWN_REG_MCAST_FLOOD,
config.unknown_vlan_reg_multi);
ALE_PORT_UNKNOWN_MCAST_FLOOD,
config.unknown_vlan_unreg_multi);
ALE_PORT_UNKNOWN_VLAN_MEMBER,
config.unknown_vlan_member);
ret = 0;
} else {
dev_err(priv->dev, "Invalid Unknown VLAN Arguments\n");
break;
case CONFIG_SWITCH_GET_PORT_STATE:
if (config.port == 1 || config.port == 2) {
config.port_state = priv->port_state[config.port];
sizeof(config));
} else {
dev_err(priv->dev, "Invalid Port number\n");
break;
case CONFIG_SWITCH_SET_PORT_STATE:
ret = cpsw_set_port_state(priv, config.port,
config.port_state);
} else {
break;
case CONFIG_SWITCH_GET_PORT_VLAN_CONFIG:
u32 __iomem *port_vlan_reg;
u32 port_vlan;
switch (config.port) {
case 0:
port_vlan_reg = &cpsw->host_port_regs->port_vlan;
port_vlan = readl(port_vlan_reg);
ret = 0;
break;
case 1:
case 2:
int slave = config.port - 1;
int reg = CPSW2_PORT_VLAN;
reg = CPSW1_PORT_VLAN;
port_vlan = slave_read(cpsw->slaves + slave, reg);
ret = 0;
break;
default:
break;
if (!ret) {
config.vid = port_vlan & 0xfff;
config.vlan_cfi = port_vlan & BIT(12) ? true : false;
config.prio = (port_vlan >> 13) & 0x7;
sizeof(config));
break;
case CONFIG_SWITCH_SET_PORT_VLAN_CONFIG:
void __iomem *port_vlan_reg;
u32 port_vlan;
port_vlan = config.vid;
port_vlan |= config.vlan_cfi ? BIT(12) : 0;
port_vlan |= (config.prio & 0x7) << 13;
case 0:
writel(port_vlan, port_vlan_reg);
ret = 0;
break;
case 1:
case 2:
slave_write(cpsw->slaves + slave, port_vlan, reg);
ret = 0;
break;
default:
break;
break;
case CONFIG_SWITCH_RATELIMIT:
if (config.port > 2) {
break;
ret = cpsw_ale_set_ratelimit(cpsw->ale,
cpsw->bus_freq_mhz * 1000000,
config.port,
config.bcast_rate_limit,
config.mcast_rate_limit,
!!config.direction);
if (ret)
dev_err(priv->dev, "CPSW_ALE set ratelimit failed");
break;
default:
ret = -EOPNOTSUPP;
return ret;
static int cpsw_ndo_ioctl(struct net_device *dev, struct ifreq *req, int cmd)
int slave_no = cpsw_slave_index(cpsw, priv);
if (!netif_running(dev))
return -EINVAL;
switch (cmd) {
case SIOCSHWTSTAMP:
return cpsw_hwtstamp_set(dev, req);
case SIOCGHWTSTAMP:
return cpsw_hwtstamp_get(dev, req);
case SIOCSWITCHCONFIG:
return cpsw_switch_config_ioctl(dev, req, cmd);
if (!cpsw->slaves[slave_no].phy)
return -EOPNOTSUPP;
return phy_mii_ioctl(cpsw->slaves[slave_no].phy, req, cmd);
static void cpsw_ndo_tx_timeout(struct net_device *ndev)
int ch;
cpsw_err(priv, tx_err, "transmit timeout, restarting dma\n");
ndev->stats.tx_errors++;
cpdma_chan_stop(cpsw->txv[ch].ch);
cpdma_chan_start(cpsw->txv[ch].ch);
if (!cpsw->ecdev){
netif_trans_update(ndev);
static int cpsw_ndo_set_mac_address(struct net_device *ndev, void *p)
struct sockaddr *addr = (struct sockaddr *)p;
int flags = 0;
u16 vid = 0;
int ret;
if (!is_valid_ether_addr(addr->sa_data))
return -EADDRNOTAVAIL;
if (ret < 0) {
return ret;
flags = ALE_VLAN;
cpsw_ale_del_ucast(cpsw->ale, priv->mac_addr, HOST_PORT_NUM,
flags, vid);
cpsw_ale_add_ucast(cpsw->ale, addr->sa_data, HOST_PORT_NUM,
flags, vid);
memcpy(priv->mac_addr, addr->sa_data, ETH_ALEN);
memcpy(ndev->dev_addr, priv->mac_addr, ETH_ALEN);
for_each_slave(priv, cpsw_set_slave_mac, priv);
pm_runtime_put(cpsw->dev);
return 0;
#ifdef CONFIG_NET_POLL_CONTROLLER
static void cpsw_ndo_poll_controller(struct net_device *ndev)
printk("================== cpsw_ndo_poll_controller\n");
cpsw_rx_interrupt(cpsw->irqs_table[0], cpsw);
cpsw_tx_interrupt(cpsw->irqs_table[1], cpsw);
#endif
static inline int cpsw_add_vlan_ale_entry(struct cpsw_priv *priv,
unsigned short vid)
int ret;
int unreg_mcast_mask = 0;
int mcast_mask;
u32 port_mask;
port_mask = (1 << (priv->emac_port + 1)) | ALE_PORT_HOST;
mcast_mask = ALE_PORT_HOST;
unreg_mcast_mask = mcast_mask;
} else {
port_mask = ALE_ALL_PORTS;
mcast_mask = port_mask;
else
ret = cpsw_ale_add_vlan(cpsw->ale, vid, port_mask, 0, port_mask,
unreg_mcast_mask);
if (ret != 0)
return ret;
ret = cpsw_ale_add_ucast(cpsw->ale, priv->mac_addr,
HOST_PORT_NUM, ALE_VLAN, vid);
if (ret != 0)
goto clean_vid;
ret = cpsw_ale_add_mcast(cpsw->ale, priv->ndev->broadcast,
mcast_mask, ALE_VLAN, vid, 0);
if (ret != 0)
goto clean_vlan_ucast;
return 0;
clean_vlan_ucast:
clean_vid:
cpsw_ale_del_vlan(cpsw->ale, vid, 0);
return ret;
static int cpsw_ndo_vlan_rx_add_vid(struct net_device *ndev,
__be16 proto, u16 vid)
int ret;
if (vid == cpsw->data.default_vlan)
return 0;
if (ret < 0) {
return ret;
/* In dual EMAC, reserved VLAN id should not be used for
* creating VLAN interfaces as this can break the dual
* EMAC port separation
int i;
for (i = 0; i < cpsw->data.slaves; i++) {
if (vid == cpsw->slaves[i].port_vlan) {
ret = -EINVAL;
goto err;
dev_info(priv->dev, "Adding vlanid %d to vlan filter\n", vid);
ret = cpsw_add_vlan_ale_entry(priv, vid);
err:
return ret;
static int cpsw_ndo_vlan_rx_kill_vid(struct net_device *ndev,
int ret;
return 0;
if (ret < 0) {
return ret;
int i;
goto err;
dev_info(priv->dev, "removing vlanid %d from vlan filter\n", vid);
ret = cpsw_ale_del_vlan(cpsw->ale, vid, 0);
ret |= cpsw_ale_del_ucast(cpsw->ale, priv->mac_addr,
ret |= cpsw_ale_del_mcast(cpsw->ale, priv->ndev->broadcast,
0, ALE_VLAN, vid);
err:
return ret;
static int cpsw_ndo_set_tx_maxrate(struct net_device *ndev, int queue, u32 rate)
u32 min_rate;
u32 ch_rate;
int i, ret;
ch_rate = netdev_get_tx_queue(ndev, queue)->tx_maxrate;
if (ch_rate == rate)
return 0;
ch_rate = rate * 1000;
min_rate = cpdma_chan_get_min_rate(cpsw->dma);
if ((ch_rate < min_rate && ch_rate)) {
dev_err(priv->dev, "The channel rate cannot be less than %dMbps",
min_rate);
return -EINVAL;
if (rate > cpsw->speed) {
dev_err(priv->dev, "The channel rate cannot be more than 2Gbps");
return -EINVAL;
if (ret < 0) {
return ret;
ret = cpdma_chan_set_rate(cpsw->txv[queue].ch, ch_rate);
if (ret)
return ret;
/* update rates for slaves tx queues */
slave = &cpsw->slaves[i];
if (!slave->ndev)
continue;
netdev_get_tx_queue(slave->ndev, queue)->tx_maxrate = rate;
return ret;
static int cpsw_set_mqprio(struct net_device *ndev, void *type_data)
struct tc_mqprio_qopt_offload *mqprio = type_data;
int fifo, num_tc, count, offset;
int i, tc, ret;
num_tc = mqprio->qopt.num_tc;
if (num_tc > CPSW_TC_NUM)
return -EINVAL;
if (mqprio->mode != TC_MQPRIO_MODE_DCB)
return -EINVAL;
if (ret < 0) {
return ret;
if (num_tc) {
tc = mqprio->qopt.prio_tc_map[i];
fifo = cpsw_tc_to_fifo(tc, num_tc);
netdev_set_num_tc(ndev, num_tc);
for (i = 0; i < num_tc; i++) {
count = mqprio->qopt.count[i];
offset = mqprio->qopt.offset[i];
netdev_set_tc_queue(ndev, i, count, offset);
if (!mqprio->qopt.hw) {
/* restore default configuration */
netdev_reset_tc(ndev);
tx_prio_map = TX_PRIORITY_MAPPING;
priv->mqprio_hw = mqprio->qopt.hw;
offset = cpsw->version == CPSW_VERSION_1 ?
slave_write(slave, tx_prio_map, offset);
return 0;
static int cpsw_ndo_setup_tc(struct net_device *ndev, enum tc_setup_type type,
void *type_data)
switch (type) {
case TC_SETUP_QDISC_CBS:
return cpsw_set_cbs(ndev, type_data);
case TC_SETUP_QDISC_MQPRIO:
return cpsw_set_mqprio(ndev, type_data);
default:
return -EOPNOTSUPP;
static const struct net_device_ops cpsw_netdev_ops = {
.ndo_open = cpsw_ndo_open,
.ndo_stop = cpsw_ndo_stop,
.ndo_start_xmit = cpsw_ndo_start_xmit,
.ndo_set_mac_address = cpsw_ndo_set_mac_address,
.ndo_do_ioctl = cpsw_ndo_ioctl,
.ndo_validate_addr = eth_validate_addr,
.ndo_tx_timeout = cpsw_ndo_tx_timeout,
.ndo_set_rx_mode = cpsw_ndo_set_rx_mode,
.ndo_set_tx_maxrate = cpsw_ndo_set_tx_maxrate,
.ndo_poll_controller = cpsw_ndo_poll_controller,
#endif
.ndo_vlan_rx_add_vid = cpsw_ndo_vlan_rx_add_vid,
.ndo_vlan_rx_kill_vid = cpsw_ndo_vlan_rx_kill_vid,
.ndo_setup_tc = cpsw_ndo_setup_tc,
static int cpsw_get_regs_len(struct net_device *ndev)
return cpsw->data.ale_entries * ALE_ENTRY_WORDS * sizeof(u32);
static void cpsw_get_regs(struct net_device *ndev,
struct ethtool_regs *regs, void *p)
u32 *reg = p;
/* update CPSW IP version */
regs->version = cpsw->version;
cpsw_ale_dump(cpsw->ale, reg);
static void cpsw_get_drvinfo(struct net_device *ndev,
struct ethtool_drvinfo *info)
struct platform_device *pdev = to_platform_device(cpsw->dev);
strlcpy(info->driver, "cpsw", sizeof(info->driver));
strlcpy(info->version, "1.0", sizeof(info->version));
strlcpy(info->bus_info, pdev->name, sizeof(info->bus_info));
static u32 cpsw_get_msglevel(struct net_device *ndev)
return priv->msg_enable;
static void cpsw_set_msglevel(struct net_device *ndev, u32 value)
priv->msg_enable = value;
static int cpsw_get_ts_info(struct net_device *ndev,
struct ethtool_ts_info *info)
info->so_timestamping =
SOF_TIMESTAMPING_TX_HARDWARE |
SOF_TIMESTAMPING_TX_SOFTWARE |
SOF_TIMESTAMPING_RX_HARDWARE |
SOF_TIMESTAMPING_RX_SOFTWARE |
SOF_TIMESTAMPING_SOFTWARE |
SOF_TIMESTAMPING_RAW_HARDWARE;
info->phc_index = cpsw->cpts->phc_index;
info->tx_types =
(1 << HWTSTAMP_TX_OFF) |
(1 << HWTSTAMP_TX_ON);
info->rx_filters =
(1 << HWTSTAMP_FILTER_NONE) |
(1 << HWTSTAMP_FILTER_PTP_V1_L4_EVENT) |
(1 << HWTSTAMP_FILTER_PTP_V2_EVENT);
return 0;
#else
SOF_TIMESTAMPING_SOFTWARE;
info->phc_index = -1;
info->tx_types = 0;
info->rx_filters = 0;
return 0;
#endif
static int cpsw_get_link_ksettings(struct net_device *ndev,
struct ethtool_link_ksettings *ecmd)
return -EOPNOTSUPP;
phy_ethtool_ksettings_get(cpsw->slaves[slave_no].phy, ecmd);
return 0;
static int cpsw_set_link_ksettings(struct net_device *ndev,
const struct ethtool_link_ksettings *ecmd)
if (cpsw->slaves[slave_no].phy)
return phy_ethtool_ksettings_set(cpsw->slaves[slave_no].phy,
ecmd);
else
return -EOPNOTSUPP;
static void cpsw_get_wol(struct net_device *ndev, struct ethtool_wolinfo *wol)
wol->supported = 0;
wol->wolopts = 0;
phy_ethtool_get_wol(cpsw->slaves[slave_no].phy, wol);
static int cpsw_set_wol(struct net_device *ndev, struct ethtool_wolinfo *wol)
return phy_ethtool_set_wol(cpsw->slaves[slave_no].phy, wol);
else
return -EOPNOTSUPP;
static void cpsw_get_pauseparam(struct net_device *ndev,
struct ethtool_pauseparam *pause)
pause->autoneg = AUTONEG_DISABLE;
pause->rx_pause = priv->rx_pause ? true : false;
pause->tx_pause = priv->tx_pause ? true : false;
static int cpsw_set_pauseparam(struct net_device *ndev,
bool link;
priv->rx_pause = pause->rx_pause ? true : false;
priv->tx_pause = pause->tx_pause ? true : false;
return 0;
static int cpsw_ethtool_op_begin(struct net_device *ndev)
int ret;
if (ret < 0) {
cpsw_err(priv, drv, "ethtool begin failed %d\n", ret);
return ret;
static void cpsw_ethtool_op_complete(struct net_device *ndev)
int ret;
ret = pm_runtime_put(priv->cpsw->dev);
if (ret < 0)
cpsw_err(priv, drv, "ethtool complete failed %d\n", ret);
static void cpsw_get_channels(struct net_device *ndev,
struct ethtool_channels *ch)
ch->max_rx = cpsw->quirk_irq ? 1 : CPSW_MAX_QUEUES;
ch->max_tx = cpsw->quirk_irq ? 1 : CPSW_MAX_QUEUES;
ch->max_combined = 0;
ch->max_other = 0;
ch->other_count = 0;
ch->rx_count = cpsw->rx_ch_num;
ch->tx_count = cpsw->tx_ch_num;
ch->combined_count = 0;
static int cpsw_check_ch_settings(struct cpsw_common *cpsw,
dev_err(cpsw->dev, "Maximum one tx/rx queue is allowed");
return -EOPNOTSUPP;
if (ch->combined_count)
return -EINVAL;
/* verify we have at least one channel in each direction */
if (!ch->rx_count || !ch->tx_count)
return -EINVAL;
if (ch->rx_count > cpsw->data.channels ||
ch->tx_count > cpsw->data.channels)
return -EINVAL;
return 0;
static int cpsw_update_channels_res(struct cpsw_priv *priv, int ch_num, int rx)
void (*handler)(void *, int, int);
struct netdev_queue *queue;
struct cpsw_vector *vec;
int ret, *ch, vch;
if (rx) {
ch = &cpsw->rx_ch_num;
vec = cpsw->rxv;
handler = cpsw_rx_handler;
} else {
ch = &cpsw->tx_ch_num;
vec = cpsw->txv;
handler = cpsw_tx_handler;
while (*ch < ch_num) {
vch = rx ? *ch : 7 - *ch;
vec[*ch].ch = cpdma_chan_create(cpsw->dma, vch, handler, rx);
queue = netdev_get_tx_queue(priv->ndev, *ch);
queue->tx_maxrate = 0;
if (IS_ERR(vec[*ch].ch))
return PTR_ERR(vec[*ch].ch);
if (!vec[*ch].ch)
return -EINVAL;
cpsw_info(priv, ifup, "created new %d %s channel\n", *ch,
(rx ? "rx" : "tx"));
(*ch)++;
while (*ch > ch_num) {
(*ch)--;
ret = cpdma_chan_destroy(vec[*ch].ch);
if (ret)
return ret;
cpsw_info(priv, ifup, "destroyed %d %s channel\n", *ch,
return 0;
static int cpsw_update_channels(struct cpsw_priv *priv,
int ret;
ret = cpsw_update_channels_res(priv, ch->rx_count, 1);
if (ret)
return ret;
ret = cpsw_update_channels_res(priv, ch->tx_count, 0);
if (ret)
return ret;
return 0;
static void cpsw_suspend_data_pass(struct net_device *ndev)
int i;
if (!cpsw->ecdev){
/* Disable NAPI scheduling */
/* Stop all transmit queues for every network device.
* Disable re-using rx descriptors with dormant_on.
for (i = cpsw->data.slaves, slave = cpsw->slaves; i; i--, slave++) {
if (!(slave->ndev && netif_running(slave->ndev)))
continue;
netif_tx_stop_all_queues(slave->ndev);
netif_dormant_on(slave->ndev);
/* Handle rest of tx packets and stop cpdma channels */
static int cpsw_resume_data_pass(struct net_device *ndev)
int i, ret;
/* Allow rx packets handling */
if (!cpsw->ecdev && slave->ndev && netif_running(slave->ndev))
netif_dormant_off(slave->ndev);
/* After this receive is started */
if (!cpsw->ecdev && cpsw->usage_count) {
if (ret)
return ret;
/* Resume transmit for every affected interface */
netif_tx_start_all_queues(slave->ndev);
return 0;
static int cpsw_set_channels(struct net_device *ndev,
struct ethtool_channels *chs)
int i, ret;
ret = cpsw_check_ch_settings(cpsw, chs);
if (ret < 0)
return ret;
cpsw_suspend_data_pass(ndev);
ret = cpsw_update_channels(priv, chs);
if (ret)
goto err;
if (!cpsw->ecdev){
continue;
/* Inform stack about new count of queues */
ret = netif_set_real_num_tx_queues(slave->ndev,
cpsw->tx_ch_num);
if (ret) {
goto err;
ret = netif_set_real_num_rx_queues(slave->ndev,
cpsw->rx_ch_num);
if (ret) {
goto err;
if (cpsw->usage_count)
ret = cpsw_resume_data_pass(ndev);
if (!ret)
return 0;
err:
dev_err(priv->dev, "cannot update channels number, closing device\n");
dev_close(ndev);
return ret;
static int cpsw_get_eee(struct net_device *ndev, struct ethtool_eee *edata)
return phy_ethtool_get_eee(cpsw->slaves[slave_no].phy, edata);
else
return -EOPNOTSUPP;
static int cpsw_set_eee(struct net_device *ndev, struct ethtool_eee *edata)
return phy_ethtool_set_eee(cpsw->slaves[slave_no].phy, edata);
else
return -EOPNOTSUPP;
static int cpsw_nway_reset(struct net_device *ndev)
return genphy_restart_aneg(cpsw->slaves[slave_no].phy);
else
return -EOPNOTSUPP;
static void cpsw_get_ringparam(struct net_device *ndev,
struct ethtool_ringparam *ering)
/* not supported */
ering->tx_max_pending = descs_pool_size - CPSW_MAX_QUEUES;
ering->tx_pending = cpdma_get_num_tx_descs(cpsw->dma);
ering->rx_max_pending = descs_pool_size - CPSW_MAX_QUEUES;
ering->rx_pending = cpdma_get_num_rx_descs(cpsw->dma);
static int cpsw_set_ringparam(struct net_device *ndev,
int ret;
/* ignore ering->tx_pending - only rx_pending adjustment is supported */
if (ering->rx_mini_pending || ering->rx_jumbo_pending ||
ering->rx_pending < CPSW_MAX_QUEUES ||
ering->rx_pending > (descs_pool_size - CPSW_MAX_QUEUES))
return -EINVAL;
if (ering->rx_pending == cpdma_get_num_rx_descs(cpsw->dma))
return 0;
cpdma_set_num_rx_descs(cpsw->dma, ering->rx_pending);
cpdma_chan_split_pool(cpsw->dma);
if (!ret)
return 0;
dev_err(&ndev->dev, "cannot set ring params, closing device\n");
dev_close(ndev);
return ret;
static const struct ethtool_ops cpsw_ethtool_ops = {
.get_drvinfo = cpsw_get_drvinfo,
.get_msglevel = cpsw_get_msglevel,
.set_msglevel = cpsw_set_msglevel,
.get_link = ethtool_op_get_link,
.get_ts_info = cpsw_get_ts_info,
.get_coalesce = cpsw_get_coalesce,
.set_coalesce = cpsw_set_coalesce,
.get_sset_count = cpsw_get_sset_count,
.get_strings = cpsw_get_strings,
.get_ethtool_stats = cpsw_get_ethtool_stats,
.get_pauseparam = cpsw_get_pauseparam,
.set_pauseparam = cpsw_set_pauseparam,
.get_wol = cpsw_get_wol,
.set_wol = cpsw_set_wol,
.get_regs_len = cpsw_get_regs_len,
.get_regs = cpsw_get_regs,
.begin = cpsw_ethtool_op_begin,
.complete = cpsw_ethtool_op_complete,
.get_channels = cpsw_get_channels,
.set_channels = cpsw_set_channels,
.get_link_ksettings = cpsw_get_link_ksettings,
.set_link_ksettings = cpsw_set_link_ksettings,
.get_eee = cpsw_get_eee,
.set_eee = cpsw_set_eee,
.nway_reset = cpsw_nway_reset,
.get_ringparam = cpsw_get_ringparam,
.set_ringparam = cpsw_set_ringparam,
static void cpsw_slave_init(struct cpsw_slave *slave, struct cpsw_common *cpsw,
u32 slave_reg_ofs, u32 sliver_reg_ofs)
void __iomem *regs = cpsw->regs;
int slave_num = slave->slave_num;
struct cpsw_slave_data *data = cpsw->data.slave_data + slave_num;
slave->data = data;
slave->regs = regs + slave_reg_ofs;
slave->sliver = regs + sliver_reg_ofs;
slave->port_vlan = data->dual_emac_res_vlan;
static int cpsw_probe_dt(struct cpsw_platform_data *data,
struct platform_device *pdev)
struct device_node *node = pdev->dev.of_node;
struct device_node *slave_node;
int i = 0, ret;
u32 prop;
if (!node)
return -EINVAL;
if (of_property_read_u32(node, "slaves", &prop)) {
dev_err(&pdev->dev, "Missing slaves property in the DT.\n");
return -EINVAL;
data->slaves = prop;
if (of_property_read_u32(node, "active_slave", &prop)) {
dev_err(&pdev->dev, "Missing active_slave property in the DT.\n");
return -EINVAL;
data->active_slave = prop;
data->slave_data = devm_kcalloc(&pdev->dev,
data->slaves,
sizeof(struct cpsw_slave_data),
GFP_KERNEL);
if (!data->slave_data)
return -ENOMEM;
if (of_property_read_u32(node, "cpdma_channels", &prop)) {
dev_err(&pdev->dev, "Missing cpdma_channels property in the DT.\n");
return -EINVAL;
data->channels = prop;
if (of_property_read_u32(node, "ale_entries", &prop)) {
dev_err(&pdev->dev, "Missing ale_entries property in the DT.\n");
return -EINVAL;
data->ale_entries = prop;
if (of_property_read_u32(node, "bd_ram_size", &prop)) {
dev_err(&pdev->dev, "Missing bd_ram_size property in the DT.\n");
return -EINVAL;
data->bd_ram_size = prop;
if (of_property_read_u32(node, "mac_control", &prop)) {
dev_err(&pdev->dev, "Missing mac_control property in the DT.\n");
return -EINVAL;
data->mac_control = prop;
if (of_property_read_bool(node, "dual_emac"))
data->dual_emac = 1;
* Populate all the child nodes here...
ret = of_platform_populate(node, NULL, NULL, &pdev->dev);
/* We do not want to force this, as in some cases may not have child */
if (ret)
dev_warn(&pdev->dev, "Doesn't have any child node\n");
for_each_available_child_of_node(node, slave_node) {
struct cpsw_slave_data *slave_data = data->slave_data + i;
const void *mac_addr = NULL;
int lenp;
const __be32 *parp;
/* This is no slave child node, continue */
if (strcmp(slave_node->name, "slave"))
continue;
slave_data->phy_node = of_parse_phandle(slave_node,
"phy-handle", 0);
parp = of_get_property(slave_node, "phy_id", &lenp);
if (slave_data->phy_node) {
dev_dbg(&pdev->dev,
"slave[%d] using phy-handle=\"%pOF\"\n",
i, slave_data->phy_node);
} else if (of_phy_is_fixed_link(slave_node)) {
/* In the case of a fixed PHY, the DT node associated
* to the PHY is the Ethernet MAC DT node.
ret = of_phy_register_fixed_link(slave_node);
if (ret) {
if (ret != -EPROBE_DEFER)
dev_err(&pdev->dev, "failed to register fixed-link phy: %d\n", ret);
return ret;
slave_data->phy_node = of_node_get(slave_node);
} else if (parp) {
u32 phyid;
struct device_node *mdio_node;
struct platform_device *mdio;
if (lenp != (sizeof(__be32) * 2)) {
dev_err(&pdev->dev, "Invalid slave[%d] phy_id property\n", i);
goto no_phy_slave;
mdio_node = of_find_node_by_phandle(be32_to_cpup(parp));
phyid = be32_to_cpup(parp+1);
mdio = of_find_device_by_node(mdio_node);
of_node_put(mdio_node);
if (!mdio) {
dev_err(&pdev->dev, "Missing mdio platform device\n");
return -EINVAL;
snprintf(slave_data->phy_id, sizeof(slave_data->phy_id),
PHY_ID_FMT, mdio->name, phyid);
put_device(&mdio->dev);
} else {
dev_err(&pdev->dev,
"No slave[%d] phy_id, phy-handle, or fixed-link property\n",
i);
goto no_phy_slave;
slave_data->phy_if = of_get_phy_mode(slave_node);
if (slave_data->phy_if < 0) {
dev_err(&pdev->dev, "Missing or malformed slave[%d] phy-mode property\n",
i);
return slave_data->phy_if;
no_phy_slave:
mac_addr = of_get_mac_address(slave_node);
if (mac_addr) {
memcpy(slave_data->mac_addr, mac_addr, ETH_ALEN);
} else {
ret = ti_cm_get_macid(&pdev->dev, i,
slave_data->mac_addr);
if (ret)
return ret;
if (data->dual_emac) {
if (of_property_read_u32(slave_node, "dual_emac_res_vlan",
&prop)) {
dev_err(&pdev->dev, "Missing dual_emac_res_vlan in DT.\n");
slave_data->dual_emac_res_vlan = i+1;
dev_err(&pdev->dev, "Using %d as Reserved VLAN for %d slave\n",
slave_data->dual_emac_res_vlan, i);
} else {
slave_data->dual_emac_res_vlan = prop;
i++;
if (i == data->slaves)
break;
return 0;
static void cpsw_remove_dt(struct platform_device *pdev)
struct net_device *ndev = platform_get_drvdata(pdev);
struct cpsw_platform_data *data = &cpsw->data;
int i = 0;
struct cpsw_slave_data *slave_data = &data->slave_data[i];
continue;
of_phy_deregister_fixed_link(slave_node);
of_node_put(slave_data->phy_node);
i++;
break;
of_platform_depopulate(&pdev->dev);
static int cpsw_probe_dual_emac(struct cpsw_priv *priv)
struct net_device *ndev;
struct cpsw_priv *priv_sl2;
int ret = 0;
ndev = alloc_etherdev_mq(sizeof(struct cpsw_priv), CPSW_MAX_QUEUES);
if (!ndev) {
dev_err(cpsw->dev, "cpsw: error allocating net_device\n");
return -ENOMEM;
priv_sl2 = netdev_priv(ndev);
priv_sl2->cpsw = cpsw;
priv_sl2->ndev = ndev;
priv_sl2->dev = &ndev->dev;
priv_sl2->msg_enable = netif_msg_init(debug_level, CPSW_DEBUG);
if (is_valid_ether_addr(data->slave_data[1].mac_addr)) {
memcpy(priv_sl2->mac_addr, data->slave_data[1].mac_addr,
ETH_ALEN);
dev_info(cpsw->dev, "cpsw: Detected MACID = %pM\n",
priv_sl2->mac_addr);
} else {
eth_random_addr(priv_sl2->mac_addr);
dev_info(cpsw->dev, "cpsw: Random MACID = %pM\n",
memcpy(ndev->dev_addr, priv_sl2->mac_addr, ETH_ALEN);
priv_sl2->emac_port = 1;
cpsw->slaves[1].ndev = ndev;
ndev->features |= NETIF_F_HW_VLAN_CTAG_FILTER | NETIF_F_HW_VLAN_CTAG_RX;
ndev->netdev_ops = &cpsw_netdev_ops;
ndev->ethtool_ops = &cpsw_ethtool_ops;
/* register the network device */
SET_NETDEV_DEV(ndev, cpsw->dev);
ret = register_netdev(ndev);
if (ret) {
dev_err(cpsw->dev, "cpsw: error registering net device\n");
free_netdev(ndev);
ret = -ENODEV;
return ret;
void cpsw_ec_poll(struct net_device *ndev)
int budget = CPSW_POLL_WEIGHT;
cpsw_rx_mq_poll(&cpsw->napi_rx, budget);
cpsw_tx_mq_poll(&cpsw->napi_tx, budget);
static const struct of_device_id cpsw_of_mtable[] = {
{ .compatible = "ti,cpsw"},
{ .compatible = "ti,am335x-cpsw"},
{ .compatible = "ti,am4372-cpsw"},
{ .compatible = "ti,dra7-cpsw"},
{ /* sentinel */ },
MODULE_DEVICE_TABLE(of, cpsw_of_mtable);
static const struct soc_device_attribute cpsw_soc_devices[] = {
{ .family = "AM33xx", .revision = "ES1.0"},
{ /* sentinel */ }
static int cpsw_probe(struct platform_device *pdev)
struct clk *clk;
struct cpsw_platform_data *data;
struct cpdma_params dma_params;
struct cpsw_ale_params ale_params;
void __iomem *ss_regs;
void __iomem *cpts_regs;
struct resource *res, *ss_res;
struct gpio_descs *mode;
u32 slave_offset, sliver_offset, slave_size;
const struct soc_device_attribute *soc;
struct cpsw_common *cpsw;
int ret = 0, i, ch;
int irq;
cpsw = devm_kzalloc(&pdev->dev, sizeof(struct cpsw_common), GFP_KERNEL);
if (!cpsw)
return -ENOMEM;
cpsw->dev = &pdev->dev;
if (!ndev) {
dev_err(&pdev->dev, "error allocating net_device\n");
return -ENOMEM;
platform_set_drvdata(pdev, ndev);
priv->cpsw = cpsw;
priv->ndev = ndev;
priv->dev = &ndev->dev;
priv->msg_enable = netif_msg_init(debug_level, CPSW_DEBUG);
cpsw->rx_packet_max = max(rx_packet_max, 128);
dev_info(priv->dev, "initializing priv dev\n");
mode = devm_gpiod_get_array_optional(&pdev->dev, "mode", GPIOD_OUT_LOW);
if (IS_ERR(mode)) {
ret = PTR_ERR(mode);
dev_err(&pdev->dev, "gpio request failed, ret %d\n", ret);
goto clean_ndev_ret;
* This may be required here for child devices.
pm_runtime_enable(&pdev->dev);
/* Select default pin state */
pinctrl_pm_select_default_state(&pdev->dev);
/* Need to enable clocks with runtime PM api to access module
* registers
ret = pm_runtime_get_sync(&pdev->dev);
if (ret < 0) {
pm_runtime_put_noidle(&pdev->dev);
goto clean_runtime_disable_ret;
ret = cpsw_probe_dt(&cpsw->data, pdev);
if (ret)
goto clean_dt_ret;
data = &cpsw->data;
cpsw->rx_ch_num = 1;
cpsw->tx_ch_num = 1;
if (is_valid_ether_addr(data->slave_data[0].mac_addr)) {
memcpy(priv->mac_addr, data->slave_data[0].mac_addr, ETH_ALEN);
dev_info(&pdev->dev, "Detected MACID = %pM\n", priv->mac_addr);
} else {
eth_random_addr(priv->mac_addr);
dev_info(&pdev->dev, "Random MACID = %pM\n", priv->mac_addr);
cpsw->slaves = devm_kcalloc(&pdev->dev,
data->slaves, sizeof(struct cpsw_slave),
GFP_KERNEL);
if (!cpsw->slaves) {
ret = -ENOMEM;
goto clean_dt_ret;
for (i = 0; i < data->slaves; i++)
cpsw->slaves[i].slave_num = i;
cpsw->slaves[0].ndev = ndev;
priv->emac_port = 0;
clk = devm_clk_get(&pdev->dev, "fck");
if (IS_ERR(clk)) {
dev_err(priv->dev, "fck is not found\n");
ret = -ENODEV;
goto clean_dt_ret;
cpsw->bus_freq_mhz = clk_get_rate(clk) / 1000000;
ss_res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
ss_regs = devm_ioremap_resource(&pdev->dev, ss_res);
if (IS_ERR(ss_regs)) {
ret = PTR_ERR(ss_regs);
goto clean_dt_ret;
cpsw->regs = ss_regs;
cpsw->version = readl(&cpsw->regs->id_ver);
res = platform_get_resource(pdev, IORESOURCE_MEM, 1);
cpsw->wr_regs = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(cpsw->wr_regs)) {
ret = PTR_ERR(cpsw->wr_regs);
goto clean_dt_ret;
memset(&dma_params, 0, sizeof(dma_params));
memset(&ale_params, 0, sizeof(ale_params));
cpsw->host_port_regs = ss_regs + CPSW1_HOST_PORT_OFFSET;
cpts_regs = ss_regs + CPSW1_CPTS_OFFSET;
cpsw->hw_stats = ss_regs + CPSW1_HW_STATS;
dma_params.dmaregs = ss_regs + CPSW1_CPDMA_OFFSET;
dma_params.txhdp = ss_regs + CPSW1_STATERAM_OFFSET;
ale_params.ale_regs = ss_regs + CPSW1_ALE_OFFSET;
slave_offset = CPSW1_SLAVE_OFFSET;
slave_size = CPSW1_SLAVE_SIZE;
sliver_offset = CPSW1_SLIVER_OFFSET;
dma_params.desc_mem_phys = 0;
break;
cpsw->host_port_regs = ss_regs + CPSW2_HOST_PORT_OFFSET;
cpts_regs = ss_regs + CPSW2_CPTS_OFFSET;
cpsw->hw_stats = ss_regs + CPSW2_HW_STATS;
dma_params.dmaregs = ss_regs + CPSW2_CPDMA_OFFSET;
dma_params.txhdp = ss_regs + CPSW2_STATERAM_OFFSET;
ale_params.ale_regs = ss_regs + CPSW2_ALE_OFFSET;
slave_offset = CPSW2_SLAVE_OFFSET;
slave_size = CPSW2_SLAVE_SIZE;
sliver_offset = CPSW2_SLIVER_OFFSET;
(u32 __force) ss_res->start + CPSW2_BD_OFFSET;
break;
default:
dev_err(priv->dev, "unknown version 0x%08x\n", cpsw->version);
ret = -ENODEV;
goto clean_dt_ret;
struct cpsw_slave *slave = &cpsw->slaves[i];
cpsw_slave_init(slave, cpsw, slave_offset, sliver_offset);
slave_offset += slave_size;
sliver_offset += SLIVER_SIZE;
dma_params.dev = &pdev->dev;
dma_params.rxthresh = dma_params.dmaregs + CPDMA_RXTHRESH;
dma_params.rxfree = dma_params.dmaregs + CPDMA_RXFREE;
dma_params.rxhdp = dma_params.txhdp + CPDMA_RXHDP;
dma_params.txcp = dma_params.txhdp + CPDMA_TXCP;
dma_params.rxcp = dma_params.txhdp + CPDMA_RXCP;
dma_params.num_chan = data->channels;
dma_params.has_soft_reset = true;
dma_params.min_packet_size = tx_packet_min;
dma_params.desc_mem_size = data->bd_ram_size;
dma_params.desc_align = 16;
dma_params.has_ext_regs = true;
dma_params.desc_hw_addr = dma_params.desc_mem_phys;
dma_params.bus_freq_mhz = cpsw->bus_freq_mhz;
dma_params.descs_pool_size = descs_pool_size;
cpsw->dma = cpdma_ctlr_create(&dma_params);
if (!cpsw->dma) {
dev_err(priv->dev, "error initializing dma\n");
ret = -ENOMEM;
goto clean_dt_ret;
soc = soc_device_match(cpsw_soc_devices);
if (soc)
cpsw->quirk_irq = 1;
ch = cpsw->quirk_irq ? 0 : 7;
cpsw->txv[0].ch = cpdma_chan_create(cpsw->dma, ch, cpsw_tx_handler, 0);
if (IS_ERR(cpsw->txv[0].ch)) {
dev_err(priv->dev, "error initializing tx dma channel\n");
ret = PTR_ERR(cpsw->txv[0].ch);
goto clean_dma_ret;
cpsw->rxv[0].ch = cpdma_chan_create(cpsw->dma, 0, cpsw_rx_handler, 1);
if (IS_ERR(cpsw->rxv[0].ch)) {
dev_err(priv->dev, "error initializing rx dma channel\n");
ret = PTR_ERR(cpsw->rxv[0].ch);
goto clean_dma_ret;
ale_params.dev = &pdev->dev;
ale_params.ale_ageout = ale_ageout;
ale_params.ale_entries = data->ale_entries;
ale_params.ale_ports = CPSW_ALE_PORTS_NUM;
cpsw->ale = cpsw_ale_create(&ale_params);
if (!cpsw->ale) {
dev_err(priv->dev, "error initializing ale engine\n");
ret = -ENODEV;
goto clean_dma_ret;
cpsw->cpts = cpts_create(cpsw->dev, cpts_regs, cpsw->dev->of_node);
if (IS_ERR(cpsw->cpts)) {
ret = PTR_ERR(cpsw->cpts);
goto clean_dma_ret;
ndev->irq = platform_get_irq(pdev, 1);
if (ndev->irq < 0) {
dev_err(priv->dev, "error getting irq resource\n");
ret = ndev->irq;
goto clean_dma_ret;
netif_napi_add(ndev, &cpsw->napi_rx,
cpsw->quirk_irq ? cpsw_rx_poll : cpsw_rx_mq_poll,
CPSW_POLL_WEIGHT);
netif_tx_napi_add(ndev, &cpsw->napi_tx,
cpsw->quirk_irq ? cpsw_tx_poll : cpsw_tx_mq_poll,
CPSW_POLL_WEIGHT);
SET_NETDEV_DEV(ndev, &pdev->dev);
// offer device to EtherCAT master module
cpsw->ecdev = ecdev_offer(ndev, cpsw_ec_poll, THIS_MODULE);
cpsw_notice(priv, probe, "initialized cpsw ethercat device");
if (!cpsw->ecdev){
if (ret) {
dev_err(priv->dev, "error registering net device\n");
ret = -ENODEV;
goto clean_dma_ret;
cpsw_notice(priv, probe, "initialized device (regs %pa, irq %d)\n",
&ss_res->start, ndev->irq);
if (cpsw->data.dual_emac) {
ret = cpsw_probe_dual_emac(priv);
if (ret) {
cpsw_err(priv, probe, "error probe slave 2 emac interface\n");
goto clean_unregister_netdev_ret;
/* Grab RX and TX IRQs. Note that we also have RX_THRESHOLD and
* MISC IRQs which are always kept disabled with this driver so
* we will not request them.
* If anyone wants to implement support for those, make sure to
* first request and append them to irqs_table array.
if (!cpsw->ecdev) {
/* RX IRQ */
if (irq < 0) {
ret = irq;
goto clean_dma_ret;
cpsw->irqs_table[0] = irq;
ret = devm_request_irq(&pdev->dev, irq, cpsw_rx_interrupt,
0, dev_name(&pdev->dev), cpsw);
if (ret < 0) {
dev_err(priv->dev, "error attaching irq (%d)\n", ret);
goto clean_dma_ret;
/* TX IRQ */
irq = platform_get_irq(pdev, 2);
if (irq < 0) {
ret = irq;
goto clean_dma_ret;
cpsw->irqs_table[1] = irq;
ret = devm_request_irq(&pdev->dev, irq, cpsw_tx_interrupt,
if (ret < 0) {
goto clean_dma_ret;
"initialized device (regs %pa, irq %d, pool size %d)\n",
&ss_res->start, ndev->irq, dma_params.descs_pool_size);
pm_runtime_put(&pdev->dev);
if (cpsw->ecdev){
ret = ecdev_open(cpsw->ecdev);
if (ret) {
ecdev_withdraw(cpsw->ecdev);
goto clean_dma_ret;
return 0;
clean_unregister_netdev_ret:
unregister_netdev(ndev);
clean_dma_ret:
cpdma_ctlr_destroy(cpsw->dma);
clean_dt_ret:
cpsw_remove_dt(pdev);
pm_runtime_put_sync(&pdev->dev);
clean_runtime_disable_ret:
pm_runtime_disable(&pdev->dev);
clean_ndev_ret:
free_netdev(priv->ndev);
return ret;
static int cpsw_remove(struct platform_device *pdev)
struct cpsw_common *cpsw = ndev_to_cpsw(ndev);
int ret;
if (ret < 0) {
return ret;
if (cpsw->ecdev) {
ecdev_close(cpsw->ecdev);
} else {
unregister_netdev(cpsw->slaves[1].ndev);
cpts_release(cpsw->cpts);
free_netdev(cpsw->slaves[1].ndev);
free_netdev(ndev);
return 0;
#ifdef CONFIG_PM_SLEEP
static int cpsw_suspend(struct device *dev)
struct net_device *ndev = dev_get_drvdata(dev);
if (cpsw->ecdev)
return -EBUSY;
int i;
if (netif_running(cpsw->slaves[i].ndev))
cpsw_ndo_stop(cpsw->slaves[i].ndev);
} else {
cpsw_ndo_stop(ndev);
/* Select sleep pin state */
pinctrl_pm_select_sleep_state(dev);
return 0;
static int cpsw_resume(struct device *dev)
pinctrl_pm_select_default_state(dev);
/* shut up ASSERT_RTNL() warning in netif_set_real_num_tx/rx_queues */
rtnl_lock();
int i;
cpsw_ndo_open(cpsw->slaves[i].ndev);
} else {
cpsw_ndo_open(ndev);
rtnl_unlock();
return 0;
#endif
static SIMPLE_DEV_PM_OPS(cpsw_pm_ops, cpsw_suspend, cpsw_resume);
static struct platform_driver cpsw_driver = {
.driver = {
.name = "cpsw",
.pm = &cpsw_pm_ops,
.of_match_table = cpsw_of_mtable,
.probe = cpsw_probe,
.remove = cpsw_remove,
module_platform_driver(cpsw_driver);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Cyril Chemparathy <cyril@ti.com>");
MODULE_AUTHOR("Mugunthan V N <mugunthanvnm@ti.com>");
MODULE_DESCRIPTION("TI CPSW Ethernet driver");
