Part Number: AM5718
We are able to test/diagnose with TI provided diagnostic codes and GEL files.....
But for booting from SD-Card, we had to make some changes in sbl_main.c and idkAM571x_ddr.c file ( modified files attached).....
I could not understand why such changes are required (for RTOS based boot loading) as board is able to run through CCS using standard GEL file ....
Custom Board is also able to boot from evaluation board Linux/U-boot usd-card .
* Copyright (c) 2010-2015 Texas Instruments Incorporated - http://www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "board_cfg.h"
#include "board_internal.h"
#include "sbl_utils_ddr_config.h"
#include <ti/csl/csl_emif4fAux.h>
#include <ti/csl/cslr_dmm.h>
#include <ti/csl/cslr_ma_mpu_lsm.h>
#include <ti/csl/src/ip/emif4/V2/csl_emif4d5.h>
#define DDR_PHY_CTRL1_VALUE(emif_phy_read_latency, emif_phy_fast_dll_lock, \
emif_phy_dll_lock_diff, emif_phy_invert_clkout, emif_phy_dis_calib_rst, \
emif_phy_half_delay_mode, emif_phy_levelling_disabled) \
((emif_phy_read_latency << 0U) | (emif_phy_fast_dll_lock << 9U) | \
(emif_phy_dll_lock_diff << 10U) | (emif_phy_invert_clkout << 18U) | \
(emif_phy_dis_calib_rst << 19U) | (emif_phy_half_delay_mode << 21U) | \
(emif_phy_levelling_disabled))
#define MPU_DEVICE_PRM_REGS (0x4ae07d00U)
#define PRM_RSTST_REG (0x4U)
/**< IODFT TLGC */
uint32_t ioDftLogicCtrl;
/**< Read Write level ramp window*/
uint32_t readWriteLvlRampWin;
static void ddr_delay(uint32_t ix);
static void emif_ddr3_updateHwLevelOutput(CSL_emifHandle hEmif);
while (ix--) {
asm(" NOP");
int emifConfigureDdr3
CSL_emifHandle hEmif,
CSL_emifDdrConfig *ddr3Config,
Uint32 enableHwLeveling
/* Set the desired DDR3 configuration -- assumes 66.67 MHz DDR3 clock input */
Board_STATUS Board_DDR3Init()
int retVal = BOARD_SOK;
Board_IDInfo id;
Board_STATUS ret;
ret = Board_getIDInfo(&id);
if (ret != BOARD_SOK)
return ret;
/* Check if version is 1.0 or 1.1 */
/* Check if DRA chip (AM570x) */
if ((id.boardName[0] == 'D') &&
(id.boardName[1] == 'R') &&
(id.boardName[2] == 'A'))
SBLUtilsDDR3Config(0);
return ret;
CSL_emifObj emifObj1;
CSL_emifHandle hEmif1 = &emifObj1;
CSL_emifDdrConfig ddr3Config1;
CSL_ckgen_cm_core_aonRegs *hCkgenCmCoreAon =
(CSL_ckgen_cm_core_aonRegs *) CSL_MPU_CKGEN_CM_CORE_AON_REGS;
CSL_control_core_padRegs *hCtrlCorePad =
(CSL_control_core_padRegs *) CSL_MPU_CTRL_MODULE_CORE_CORE_PAD_REGISTERS_REGS;
CSL_control_core_wkupRegs *hCtrlCoreWkup =
(CSL_control_core_wkupRegs *) CSL_MPU_CTRL_MODULE_WKUP_CORE_REGISTERS_REGS;
CSL_DmmRegs *hDmmCfg =(CSL_DmmRegs *) CSL_MPU_DMM_CONF_REGS_REGS;
CSL_MampuLsmRegs *hMampuLsm = (CSL_MampuLsmRegs *) CSL_MPU_MA_MPU_LSM_REGS;
hEmif1->regs = (CSL_emifRegsOvly)CSL_MPU_EMIF1_CONF_REGS_REGS;
/* DLL override disable =0 ; enable = 1 */
hCkgenCmCoreAon->CM_DLL_CTRL_REG = 0x00000000;
* CONTROL_DDR3CH1_0 -- channel_1 CMDs
* -- 40Ohm Ron (011)
* -- SR=slowest-3 (111) on CMDs
* -- CLK SR=slow (011)
* -- No pulls (00)
hCtrlCorePad->CONTROL_DDRCACH1_0 = 0x60606080U;
* CTRL_CORE_CONTROL_DDRCH1_0
* - Impedance = 40ohm / SlewRate = fastest / No pulls
hCtrlCorePad->CONTROL_DDRCH1_0 = 0x40404040U;
* CTRL_CORE_CONTROL_DDRCH1_1
hCtrlCorePad->CONTROL_DDRCH1_1 = 0x40404040U;
* CTRL_CORE_CONTROL_DDRCH1_2
hCtrlCorePad->CONTROL_DDRCH1_2 = 0x00404000U;
* CTRL_CORE_CONTROL_DDRIO_0
* - DDRCH1_VREF_DQ0/1_INT_EN = 0, reset values for other fields
hCtrlCorePad->CONTROL_DDRIO_0 = 0x00094A40U;
* EMIF1_SDRAM_CONFIG_EXT
* -- cslice_en[2:0]=111 / Local_odt=01 / dyn_pwrdn=1 / dis_reset=0 / rd_lvl_samples=11 (128)
hCtrlCoreWkup->EMIF1_SDRAM_CONFIG_EXT = 0x0001C1A7U;
ddr3Config1.emifDdrParam.ddrPhyCtrl = hEmif1->regs->DDR_PHY_CONTROL_2;
ddr3Config1.emifDdrParam.sdramTim1 = 0xD113781C;
ddr3Config1.emifDdrParam.sdramTim2 = 0x30B37FE3;
ddr3Config1.emifDdrParam.sdramTim3 = 0x409F8AD8;
ddr3Config1.emifDdrParam.sdramCfg = 0x61862B32U;
ddr3Config1.emifDdrParam.sdramCfg2 = 0x08000000U;
ddr3Config1.emifDdrParam.sdramRefCtrl = 0x0000144AU;
ddr3Config1.emifDdrParam.zqConfig = 0x5007190BU;
ddr3Config1.emifDdrParam.sdramPwrMngtCtrl = 0x00000000U;
ioDftLogicCtrl = hEmif1->regs->IODFT_TEST_LOGIC_GLOBAL_CONTROL;
readWriteLvlRampWin = hEmif1->regs->READ_WRITE_LEVELING_RAMP_WINDOW;
ddr3Config1.emifDdrPhyParam.ctrlSlaveRatio = 0x80U;
ddr3Config1.emifDdrPhyParam.dqOffset = 0x40U;
ddr3Config1.emifDdrPhyParam.gateLevelInitMode = 0x01U;
ddr3Config1.emifDdrPhyParam.fifoWeInDelay = 0x0U;
ddr3Config1.emifDdrPhyParam.ctrlSlaveDelay = 0x0U;
ddr3Config1.emifDdrPhyParam.readDqsSlaveDelay = 0x20U;
ddr3Config1.emifDdrPhyParam.writeDqsSlaveDelay = 0x60U;
ddr3Config1.emifDdrPhyParam.writeDataSlaveDelay = 0x80U;
ddr3Config1.emifDdrPhyParam.gateLevelRatio = 0x00U;
ddr3Config1.emifDdrPhyParam.writeLevelInitRatio = 0x00;
ddr3Config1.emifDdrPhyParam.writeDqsSlaveRatio = 0x60U;
ddr3Config1.emifDdrPhyParam.fifoWeSlaveRatio = 0xBBU;
ddr3Config1.emifDdrPhyParam.useRank0Delays = 0U;
ddr3Config1.emifDdrPhyParam.gateLevelNumDq0 = 0xFU;
ddr3Config1.emifDdrPhyParam.writeLevelNumDq0 =
hEmif1->regs->EXT_PHY_CONTROL_36;
retVal = emifConfigureDdr3(hEmif1, &ddr3Config1, 1U);
// if(BOARD_SOK == retVal)
/* MA_LISA_MAP_i */
hMampuLsm->MAP_0 = 0x80600100U;
hMampuLsm->MAP_1 = 0x00000000U;
hMampuLsm->MAP_2 = 0x00000000U;
hMampuLsm->MAP_3 = 0x00000000U;
/* DMM_LISA_MAP_i */
hDmmCfg->LISA_MAP[0U] = 0x80600100U;
hDmmCfg->LISA_MAP[1U] = 0x00000000U;
hDmmCfg->LISA_MAP[2U] = 0x00000000U;
hDmmCfg->LISA_MAP[3U] = 0x00000000U;
// else
// retVal = BOARD_INIT_DDR_FAIL;
return retVal;
int retVal = 0;
Uint32 regVal = 0U;
Uint32 emifPhyLevelDisable = 0U;
Uint32 sdRamRefCtrlInit = 0x0000514CU;
/* Fields in DDR_PHY_CTRL_1 */
/* Bit[21] - calculated using DataMacro/MDLL clock ratio
* Set to 1 for 532M, so that PHY DLL runs at 266.
* Set to 0 for 400M, so that PHY DLL runs at 400M.
* Ensure PHY DLL lower limit of 266M is not violated.
uint32_t emifPhyHalfDelayMode = 1U;
uint32_t emifPhyDisCalibRst = 0U; /* Bit[19] */
uint32_t emifPhyInvertClkout = 1U; /* Bit[18] */
uint32_t emifPhyDllLockDiff = 0x10U; /* Bit[17:10] */
uint32_t emifPhyFastDllLock = 0U; /* Bit[9] */
uint32_t emifPhyReadLatency = 0xDU; /* Bit[4:0], Typically >= (CL + 4) */
if (0U != (HW_RD_REG32(MPU_DEVICE_PRM_REGS + PRM_RSTST_REG) &
(PRM_RSTST_GLOBAL_WARM_SW_RST_MASK | PRM_RSTST_EXTERNAL_WARM_RST_MASK)))
/* Phy reset is required if you are coming back from a warm reset */
regVal = hEmif->regs->IODFT_TEST_LOGIC_GLOBAL_CONTROL;
regVal |= 0x400U;
hEmif->regs->IODFT_TEST_LOGIC_GLOBAL_CONTROL = regVal;
if(1U == emifPhyInvertClkout)
regVal = EXT_PHY_CTRL_VALUE((ddr3Config->emifDdrPhyParam.ctrlSlaveRatio + 0x80U));
hEmif->regs->EXT_PHY_CONTROL_1 = regVal;
hEmif->regs->EXT_PHY_CONTROL_1_SHADOW = regVal;
/* PHY settings for DQ offset, DLL override delay, levelling etc. */
regVal = EXT_PHY_FIFO_WE_SLAVE_CTRL_DELAY(ddr3Config->emifDdrPhyParam.fifoWeInDelay,
ddr3Config->emifDdrPhyParam.ctrlSlaveDelay);
hEmif->regs->EXT_PHY_CONTROL_22 = regVal;
hEmif->regs->EXT_PHY_CONTROL_22_SHADOW = regVal;
regVal = EXT_PHY_WR_RD_DQS_SLAVE_DELAY(ddr3Config->emifDdrPhyParam.writeDqsSlaveDelay,
ddr3Config->emifDdrPhyParam.readDqsSlaveDelay);
hEmif->regs->EXT_PHY_CONTROL_23 = regVal;
hEmif->regs->EXT_PHY_CONTROL_23_SHADOW = regVal;
regVal = EXT_PHY_RANK0_DELAY_VALUE(ddr3Config->emifDdrPhyParam.dqOffset,
ddr3Config->emifDdrPhyParam.gateLevelInitMode,
ddr3Config->emifDdrPhyParam.useRank0Delays,
ddr3Config->emifDdrPhyParam.writeDataSlaveDelay);
hEmif->regs->EXT_PHY_CONTROL_24 = regVal;
hEmif->regs->EXT_PHY_CONTROL_24_SHADOW = regVal;
regVal = EXT_PHY_DQ_VALUE(ddr3Config->emifDdrPhyParam.dqOffset);
hEmif->regs->EXT_PHY_CONTROL_25 = regVal;
hEmif->regs->EXT_PHY_CONTROL_25_SHADOW = regVal;
/* Use Init values if HW leveling is enabled */
/* Gate level Init ratios */
regVal = EXT_PHY_GATE_LVL_INIT_VALUE(ddr3Config->emifDdrPhyParam.gateLevelRatio);
hEmif->regs->EXT_PHY_CONTROL_26 = regVal;
hEmif->regs->EXT_PHY_CONTROL_26_SHADOW = regVal;
hEmif->regs->EXT_PHY_CONTROL_27 = regVal;
hEmif->regs->EXT_PHY_CONTROL_27_SHADOW = regVal;
hEmif->regs->EXT_PHY_CONTROL_28 = regVal;
hEmif->regs->EXT_PHY_CONTROL_28_SHADOW = regVal;
hEmif->regs->EXT_PHY_CONTROL_29 = regVal;
hEmif->regs->EXT_PHY_CONTROL_29_SHADOW = regVal;
hEmif->regs->EXT_PHY_CONTROL_30 = regVal;
hEmif->regs->EXT_PHY_CONTROL_30_SHADOW = regVal;
/* WR DQS Init ratios */
regVal = EXT_PHY_WR_LVL_INIT_VALUE(ddr3Config->emifDdrPhyParam.writeLevelInitRatio);
hEmif->regs->EXT_PHY_CONTROL_31 = regVal;
hEmif->regs->EXT_PHY_CONTROL_31_SHADOW = regVal;
hEmif->regs->EXT_PHY_CONTROL_32 = regVal;
hEmif->regs->EXT_PHY_CONTROL_32_SHADOW = regVal;
hEmif->regs->EXT_PHY_CONTROL_33 = regVal;
hEmif->regs->EXT_PHY_CONTROL_33_SHADOW = regVal;
hEmif->regs->EXT_PHY_CONTROL_34 = regVal;
hEmif->regs->EXT_PHY_CONTROL_34_SHADOW = regVal;
hEmif->regs->EXT_PHY_CONTROL_35 = regVal;
hEmif->regs->EXT_PHY_CONTROL_35_SHADOW = regVal;
regVal = ddr3Config->emifDdrPhyParam.writeLevelNumDq0;
hEmif->regs->EXT_PHY_CONTROL_36 = regVal;
hEmif->regs->EXT_PHY_CONTROL_36_SHADOW = regVal;
regVal = hEmif->regs->SDRAM_REFRESH_CONTROL_SHADOW;
regVal = (CSL_EMIF4D5_SDRAM_REFRESH_CONTROL_INITREF_DIS_MASK |
sdRamRefCtrlInit);
regVal = hEmif->regs->SDRAM_REFRESH_CONTROL;
sdRamRefCtrlInit);
hEmif->regs->SDRAM_REFRESH_CONTROL = regVal;
/* Set up the EMIF registers */
hEmif->regs->SDRAM_TIMING_1 = ddr3Config->emifDdrParam.sdramTim1;
hEmif->regs->SDRAM_TIMING_1_SHADOW = ddr3Config->emifDdrParam.sdramTim1;
hEmif->regs->SDRAM_TIMING_2 = ddr3Config->emifDdrParam.sdramTim2;
hEmif->regs->SDRAM_TIMING_2_SHADOW = ddr3Config->emifDdrParam.sdramTim2;
hEmif->regs->SDRAM_TIMING_3 = ddr3Config->emifDdrParam.sdramTim3;
hEmif->regs->SDRAM_TIMING_3_SHADOW = ddr3Config->emifDdrParam.sdramTim3;
hEmif->regs->POWER_MANAGEMENT_CONTROL = ddr3Config->emifDdrParam.sdramPwrMngtCtrl;
hEmif->regs->POWER_MANAGEMENT_CONTROL_SHADOW = ddr3Config->emifDdrParam.sdramPwrMngtCtrl;
hEmif->regs->OCP_CONFIG = 0x0A500000U;
hEmif->regs->IODFT_TEST_LOGIC_GLOBAL_CONTROL = ioDftLogicCtrl;
hEmif->regs->SDRAM_OUTPUT_IMPEDANCE_CALIBRATION_CONFIG = ddr3Config->emifDdrParam.zqConfig;
hEmif->regs->DLL_CALIB_CTRL = 0x00050000U;
hEmif->regs->DLL_CALIB_CTRL_SHADOW = 0x00050000U;
hEmif->regs->READ_WRITE_LEVELING_RAMP_WINDOW = readWriteLvlRampWin;
hEmif->regs->READ_WRITE_LEVELING_RAMP_CONTROL = 0x80000000;
hEmif->regs->READ_WRITE_LEVELING_CONTROL = 0U;
regVal = DDR_PHY_CTRL1_VALUE(emifPhyReadLatency, emifPhyFastDllLock,
emifPhyDllLockDiff, emifPhyInvertClkout, emifPhyDisCalibRst,
emifPhyHalfDelayMode, emifPhyLevelDisable);
hEmif->regs->DDR_PHY_CONTROL_1 = regVal;
hEmif->regs->DDR_PHY_CONTROL_1_SHADOW = regVal;
/* Backup of the previous value. */
hEmif->regs->DDR_PHY_CONTROL_2 = ddr3Config->emifDdrParam.ddrPhyCtrl;
hEmif->regs->PRIORITY_TO_CLASS_OF_SERVICE_MAPPING = 0U;
hEmif->regs->CONNECTION_ID_TO_CLASS_OF_SERVICE_1_MAPPING = 0U;
hEmif->regs->CONNECTION_ID_TO_CLASS_OF_SERVICE_2_MAPPING = 0U;
hEmif->regs->READ_WRITE_EXECUTION_THRESHOLD = 0x00000305U;
hEmif->regs->COS_CONFIG = 0x00FFFFFFU;
/* SDRAM_REF_CTRL_INIT:
* For DDR3: value used initially to get 500us delay between
* RESET de-assertion to CKE assertion after power-up
hEmif->regs->SDRAM_REFRESH_CONTROL_SHADOW = 0x0000514CU;
hEmif->regs->SDRAM_REFRESH_CONTROL = 0x0000514CU;
hEmif->regs->SDRAM_CONFIG_2 = ddr3Config->emifDdrParam.sdramCfg2;
hEmif->regs->SDRAM_CONFIG = ddr3Config->emifDdrParam.sdramCfg;
ddr_delay(100000);
/* Now update with the correct refresh time */
hEmif->regs->SDRAM_REFRESH_CONTROL_SHADOW = ddr3Config->emifDdrParam.sdramRefCtrl;
hEmif->regs->SDRAM_REFRESH_CONTROL = ddr3Config->emifDdrParam.sdramRefCtrl;
/* If ECC is enabled. */
hEmif->regs->ECC_ADDRESS_RANGE_1 = 0U;
hEmif->regs->ECC_ADDRESS_RANGE_2 = 0U;
hEmif->regs->ECC_CTRL_REG = (CSL_EMIF4D5_ECC_CTRL_REG_REG_ECC_EN_MASK |
CSL_EMIF4D5_ECC_CTRL_REG_REG_ECC_ADDR_RGN_PROT_MASK);
/* Launch Full HW levelling. */
regVal = hEmif->regs->EXT_PHY_CONTROL_36;
regVal = (regVal | 0x00000100U);
regVal = hEmif->regs->EXT_PHY_CONTROL_36_SHADOW;
/* Disable SDRAM refreshes before levelling */
regVal = regVal | CSL_EMIF4D5_SDRAM_REFRESH_CONTROL_INITREF_DIS_MASK;
/* RDWR_LVL_CTRL */
CSL_EMIF4D5_READ_WRITE_LEVELING_CONTROL_RDWRLVLFULL_START_MASK;
/* Some clock cycle delay for refresh to complete. */
ddr_delay(30000U);
/* Wait for the levelling procedure to complete */
while((hEmif->regs->READ_WRITE_LEVELING_CONTROL & 0x80000000) != 0x0U);
/* Enable SDRAM refreshes after levelling */
regVal = (regVal & ~CSL_EMIF4D5_SDRAM_REFRESH_CONTROL_INITREF_DIS_MASK);
if((hEmif->regs->STATUS & 0x70) != 0U)
/* Indicates Hardware levelling timeout. */
retVal = -1;
else
emif_ddr3_updateHwLevelOutput(hEmif);
hEmif->regs->ECC_CTRL_REG = 0U;
return retVal;
/* Following function is needed for whenever CORE can go in and out of
* INACTIVE/CSWR.
Uint32 regVal = 0U;
** Updating slave ratios in PHY_STATUSx registers as per HW levelling output
/* if DISABLE_READ_GATE_LEVELING is set to 0 */
hEmif->regs->EXT_PHY_CONTROL_2 = hEmif->regs->PHY_STATUS_12;
hEmif->regs->EXT_PHY_CONTROL_2_SHADOW = hEmif->regs->PHY_STATUS_12;
hEmif->regs->EXT_PHY_CONTROL_3 = hEmif->regs->PHY_STATUS_13;
hEmif->regs->EXT_PHY_CONTROL_3_SHADOW = hEmif->regs->PHY_STATUS_13;
hEmif->regs->EXT_PHY_CONTROL_4 = hEmif->regs->PHY_STATUS_14;
hEmif->regs->EXT_PHY_CONTROL_4_SHADOW = hEmif->regs->PHY_STATUS_14;
hEmif->regs->EXT_PHY_CONTROL_5 = hEmif->regs->PHY_STATUS_15;
hEmif->regs->EXT_PHY_CONTROL_5_SHADOW = hEmif->regs->PHY_STATUS_15;
hEmif->regs->EXT_PHY_CONTROL_6 = hEmif->regs->PHY_STATUS_16;
hEmif->regs->EXT_PHY_CONTROL_6_SHADOW = hEmif->regs->PHY_STATUS_16;
/* if DISABLE_READ_LEVELING is set to 0 */
hEmif->regs->EXT_PHY_CONTROL_7 = hEmif->regs->PHY_STATUS_7;
hEmif->regs->EXT_PHY_CONTROL_7_SHADOW = hEmif->regs->PHY_STATUS_7;
hEmif->regs->EXT_PHY_CONTROL_8 = hEmif->regs->PHY_STATUS_8;
hEmif->regs->EXT_PHY_CONTROL_8_SHADOW = hEmif->regs->PHY_STATUS_8;
hEmif->regs->EXT_PHY_CONTROL_9 = hEmif->regs->PHY_STATUS_9;
hEmif->regs->EXT_PHY_CONTROL_9_SHADOW = hEmif->regs->PHY_STATUS_9;
hEmif->regs->EXT_PHY_CONTROL_10 = hEmif->regs->PHY_STATUS_10;
hEmif->regs->EXT_PHY_CONTROL_10_SHADOW = hEmif->regs->PHY_STATUS_10;
hEmif->regs->EXT_PHY_CONTROL_11 = hEmif->regs->PHY_STATUS_11;
hEmif->regs->EXT_PHY_CONTROL_11_SHADOW = hEmif->regs->PHY_STATUS_11;
/* if DISABLE_WRITE_LEVELING is set to 0 */
hEmif->regs->EXT_PHY_CONTROL_12 = hEmif->regs->PHY_STATUS_17;
hEmif->regs->EXT_PHY_CONTROL_12_SHADOW = hEmif->regs->PHY_STATUS_17;
hEmif->regs->EXT_PHY_CONTROL_13 = hEmif->regs->PHY_STATUS_18;
hEmif->regs->EXT_PHY_CONTROL_13_SHADOW = hEmif->regs->PHY_STATUS_18;
hEmif->regs->EXT_PHY_CONTROL_14 = hEmif->regs->PHY_STATUS_19;
hEmif->regs->EXT_PHY_CONTROL_14_SHADOW = hEmif->regs->PHY_STATUS_19;
hEmif->regs->EXT_PHY_CONTROL_15 = hEmif->regs->PHY_STATUS_20;
hEmif->regs->EXT_PHY_CONTROL_15_SHADOW = hEmif->regs->PHY_STATUS_20;
hEmif->regs->EXT_PHY_CONTROL_16 = hEmif->regs->PHY_STATUS_21;
hEmif->regs->EXT_PHY_CONTROL_16_SHADOW = hEmif->regs->PHY_STATUS_21;
/* EMIF_PHY_WR_DQS_SLAVE_RATIO */
hEmif->regs->EXT_PHY_CONTROL_17 = hEmif->regs->PHY_STATUS_22;
hEmif->regs->EXT_PHY_CONTROL_17_SHADOW = hEmif->regs->PHY_STATUS_22;
hEmif->regs->EXT_PHY_CONTROL_18 = hEmif->regs->PHY_STATUS_23;
hEmif->regs->EXT_PHY_CONTROL_18_SHADOW = hEmif->regs->PHY_STATUS_23;
hEmif->regs->EXT_PHY_CONTROL_19 = hEmif->regs->PHY_STATUS_24;
hEmif->regs->EXT_PHY_CONTROL_19_SHADOW = hEmif->regs->PHY_STATUS_24;
hEmif->regs->EXT_PHY_CONTROL_20 = hEmif->regs->PHY_STATUS_25;
hEmif->regs->EXT_PHY_CONTROL_20_SHADOW = hEmif->regs->PHY_STATUS_25;
hEmif->regs->EXT_PHY_CONTROL_21 = hEmif->regs->PHY_STATUS_26;
hEmif->regs->EXT_PHY_CONTROL_21_SHADOW = hEmif->regs->PHY_STATUS_26;
regVal = hEmif->regs->DDR_PHY_CONTROL_1;
regVal = (regVal | 0x0E000000U);
regVal = hEmif->regs->DDR_PHY_CONTROL_1_SHADOW;
hEmif->regs->READ_WRITE_LEVELING_RAMP_CONTROL = 0U;
* \file sbl_main.c
* \brief This file contain main function, call the Board Initialization
* functions & slave core boot-up functions in sequence.
* Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/
* are met:
* distribution.
/* TI RTOS header files */
#include <ti/csl/cslr_device.h>
#include <ti/board/board.h>
#include <ti/drv/uart/UART.h>
#include <ti/drv/uart/src/UART_osal.h>
#include <ti/drv/uart/UART_stdio.h>
#include <tistdtypes.h>
#include <ti/csl/csl_a15.h>
#include "sbl_slave_core_boot.h"
#include "sbl_avs_config.h"
#include "sbl_ver.h"
************************** Macros ************************************
************************** Internal functions ************************
************************** Global Variables **************************
sblEntryPoint_t idkAM571xEntry;
typedef void (*EntryFunPtr_t)(void);
int main()
void (*func_ptr)(void);
Board_initCfg boardCfg;
uint32_t oppMode = OPP_MODE_NOM;
#if defined(OPP_HIGH)
boardCfg = BOARD_INIT_PLL_OPP_HIGH;
oppMode = OPP_MODE_HIGH;
#elif defined(OPP_OD)
boardCfg = BOARD_INIT_PLL_OPP_OD;
oppMode = OPP_MODE_OD;
#elif defined(OPP_NOM)
boardCfg = BOARD_INIT_PLL_OPP_NOM;
#endif
boardCfg |= BOARD_INIT_UNLOCK_MMR |
BOARD_INIT_MODULE_CLOCK |
BOARD_INIT_PINMUX_CONFIG |
BOARD_INIT_DDR |
BOARD_INIT_UART_STDIO |
BOARD_INIT_WATCHDOG_DISABLE; */
// BOARD_INIT_DDR |
/* Configure AVS voltage for the selected OPP to the voltage rails. */
SBL_Configure_AVS(oppMode);
/* Board Library Init. */
int retVal = 1;
//UART_printf("Before init");
retVal = Board_init(boardCfg);
boardCfg = BOARD_INIT_DDR;
UART_printf("Retval--1 : %d\n", retVal);
// boardCfg = BOARD_INIT_DDR;
//retVal = Board_init(boardCfg);
UART_printf("Retval--2 : %d\n", retVal);
//Configure registers for UART3 (debug port)
HW_WR_REG32(0x4A0037F8, 0x00050002); //UART2_CTSN
HW_WR_REG32(0x4A0037FC, 0x00010001); //UART2_RTSN
UART_printf("Retval : %d\n", retVal);
/* enable clocks for slave core modules. */
SBL_SlaveCorePrcmEnable();
UART_printf("**** PDK SBL ****\n");
UART_printf("%s (%s - %s)\n", SBL_VERSION_STR, __DATE__, __TIME__);
UART_printf("Begin parsing user application\n");
/* Image Copy */
SBL_ImageCopy(&idkAM571xEntry);
/* Cache Write back after image copy to ensure the slave cores are brought
** out of reset correctly.
CSL_a15WbAllDataCache();
UART_printf("Jumping to user application...\n");
if (idkAM571xEntry.entryPoint_DSP1 != 0)
/* Release the DSP1 core out of reset */
SBL_DSP1_BringUp(idkAM571xEntry.entryPoint_DSP1);
if (idkAM571xEntry.entryPoint_IPU1_CPU0 != 0)
/* Release the IPU1 core out of reset and set the Entry point */
SBL_IPU1_CPU0_BringUp(idkAM571xEntry.entryPoint_IPU1_CPU0);
if (idkAM571xEntry.entryPoint_IPU1_CPU1 != 0)
SBL_IPU1_CPU1_BringUp(idkAM571xEntry.entryPoint_IPU1_CPU1);
/*Jump to MPU APP*/
if (idkAM571xEntry.entryPoint_MPU_CPU0 != 0)
func_ptr = (EntryFunPtr_t) idkAM571xEntry.entryPoint_MPU_CPU0;
CSL_a15InvAllInstrCache();
__sync_synchronize();
func_ptr();
else
while(1);
return 0;
