Part Number: PROCESSOR-SDK-AM64X
Hi:
So I'm on this step:
I did actually re-run
$ . conf/setenv
after the two export steps for ARM cross compilers.
However ${DEF_TOOLCHAIN_PATH} is still empty.
So when I run this step the following happens.
~/tisdk/build$ . conf/setenv
~/tisdk/build$ MACHINE=arm64-evm bitbake tisdk-base-image
ERROR: Unable to start bitbake server (None)
ERROR: Server log for this session (/home/howa/tisdk/build/bitbake-cookerdaemon.log):
--- Starting bitbake server pid 11979 at 2021-08-18 08:28:20.508093 ---
ERROR: Failed to obtain external Arm toolchain version: Execution of '${DEF_TOOLCHAIN_PATH}/bin/INVALID-linux-gcc -v' failed: command not found
ERROR: Error: EXTERNAL_TOOLCHAIN path '${DEF_TOOLCHAIN_PATH}' does not exist
