AM5728: DDR3L support
Part Number: AM5728
Good day.
Our customer uses the AM5728 and wants to get configuration about the DDR3L that they will use.
"We are planning to use the IS46TR16256BL-125KBLA2 ddr3l part from ISSI instead of the micron part due to non-availability and have noticed that both parts are pin to pin compatible. Can you kindly confirm if this device is supported with the AM5728BABCXA."
Looking forward to your input. Thank you.
Cedrick
  • The DDR controller is a generic controller that will work with a variety of memory manufactures that create JEDEC compliant memories.  I didn't see anything the the datasheet for the ISSI device that would make it non-operable with AM5728 device.
