AM3358: Ti linux Kernel crash mostly during the boot time
Part Number: AM3358
Hello Team,
I have some custom boards of AM3358 and they are working fine with SDKs up-to ti-processor-sdk-linux-am335x-evm-06.03.00.106.
Now we have gone for production of these boards and we found some specific behavior of kernel crash in our production boards.
We have not seen any of these issues in our proto-type boards. The only difference between proto-type and production boards is EMMC is enabled in the production boards.
So I have removed supply to EMMC and also removed its entries from dts . Still the kernel crash mostly during the boot is being observed.
I have been attaching some logs where kernel is crashing during boot for your reference.
Most of the times I could see the following as the start of issue:
BUG: FP instruction issued in kernel mode with FP unit disabled
Kindly help me to identify the problem and resolve it at the earliest.
U-Boot SPL 2019.01 (Jul 20 2021 - 14:43:32 +0530)
Trying to boot from MMC1
U-Boot 2019.01 (Jul 20 2021 - 14:43:32 +0530)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x EVM
DRAM:  1 GiB
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net:   eth0: ethernet@4a100000
Hit any key to stop autoboot:  2  1  0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
** Unable to read file uEnv.txt **
Scanning mmc 0:1...
4297216 bytes read in 362 ms (11.3 MiB/s)
37407 bytes read in 4 ms (8.9 MiB/s)
   Loading Device Tree to 8fff3000, end 8ffff21e ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.94-gbe5389fd85 (madhu@madhu-VirtualBox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #17 PREEMPT Tue Jul 20 14:58:04 IST 2021
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x EVM
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] cma: Reserved 48 MiB at 0xbd000000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] random: get_random_bytes called from start_kernel+0xa4/0x434 with crng_init=0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=6e31ec68-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 975336K/1048576K available (9216K kernel code, 315K rwdata, 2760K rodata, 1024K init, 252K bss, 24088K reserved, 49152K cma-reserved, 212992K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 316 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 253 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000022] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000053] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000068] OMAP clocksource: timer1 at 24000000 Hz
[    0.000301] timer_probe: no matching timers found
[    0.000535] Console: colour dummy device 80x30
[    0.000571] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000581] This ensures that you still see kernel messages. Please
[    0.000590] update your kernel commandline.
[    0.000661] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[    0.118820] pid_max: default: 32768 minimum: 301
[    0.119100] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.119125] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.120185] CPU: Testing write buffer coherency: ok
[    0.120266] CPU0: Spectre v2: using BPIALL workaround
[    0.121387] Setting up static identity map for 0x80100000 - 0x80100060
[    0.121597] rcu: Hierarchical SRCU implementation.
[    0.122064] EFI services will not be available.
[    0.124050] devtmpfs: initialized
[    0.134924] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.135417] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.135452] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.140187] pinctrl core: initialized pinctrl subsystem
[    0.141135] DMI not present or invalid.
[    0.141703] NET: Registered protocol family 16
[    0.144686] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.174107] l4_wkup_cm:clk:0010:0: failed to disable
[    0.241958] cpuidle: using governor ladder
[    0.242013] cpuidle: using governor menu
[    0.249087] OMAP GPIO hardware version 0.1
[    0.264881] No ATAGs?
[    0.264897] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.285184] edma 49000000.edma: TI EDMA DMA engine driver
[    0.291581] SCSI subsystem initialized
[    0.292284] media: Linux media interface: v0.10
[    0.292348] videodev: Linux video capture interface: v2.00
[    0.292472] pps_core: LinuxPPS API ver. 1 registered
[    0.292484] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.292516] PTP clock support registered
[    0.292565] EDAC MC: Ver: 3.0.0
[    0.293987] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.294823] Advanced Linux Sound Architecture Driver Initialized.
[    0.296372] clocksource: Switched to clocksource timer1
[    0.308362] NET: Registered protocol family 2
[    0.309457] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[    0.309505] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.309618] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.309728] TCP: Hash tables configured (established 8192 bind 8192)
[    0.309893] UDP hash table entries: 512 (order: 1, 8192 bytes)
[    0.309934] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[    0.310145] NET: Registered protocol family 1
[    0.310901] RPC: Registered named UNIX socket transport module.
[    0.310923] RPC: Registered udp transport module.
[    0.310933] RPC: Registered tcp transport module.
[    0.310942] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.312178] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.313992] Initialise system trusted keyrings
[    0.314400] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.321301] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.322301] NFS: Registering the id_resolver key type
[    0.322356] Key type id_resolver registered
[    0.322368] Key type id_legacy registered
[    0.322426] ntfs: driver 2.1.32 [Flags: R/O].
[    0.325543] Key type asymmetric registered
[    0.325568] Asymmetric key parser 'x509' registered
[    0.325661] bounce: pool size: 64 pages
[    0.325746] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.325763] io scheduler noop registered
[    0.325774] io scheduler deadline registered
[    0.326099] io scheduler cfq registered (default)
[    0.326116] io scheduler mq-deadline registered
[    0.326127] io scheduler kyber registered
[    0.329041] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.334034] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.334160] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.403808] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.409379] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[    1.047730] console [ttyS0] enabled
[    1.052760] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[    1.063024] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 32, base_baud = 3000000) is a 8250
[    1.074669] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.081147] random: fast init done
[    1.084828] random: crng init done
[    1.091000] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.098023] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.104597] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.110664] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.117336] [drm] No driver support for vblank timestamp query.
[    1.127215] Console: switching to colour frame buffer device 40x30
[    1.135035] tilcdc 4830e000.lcdc: fb0: DRM emulated frame buffer device
[    1.142483] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    1.166573] brd: module loaded
[    1.178954] loop: module loaded
[    1.186703] libphy: Fixed MDIO Bus: probed
[    1.266476] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.274188] libphy: 4a101000.mdio: probed
[    1.280751] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver TI DP83867
[    1.289208] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI DP83867
[    1.298730] cpsw 4a100000.ethernet: Detected MACID = 40:2e:71:cd:50:03
[    1.305462] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.312042] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.317405] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.325713] cpsw 4a100000.ethernet: cpsw: Detected MACID = 40:2e:71:cd:50:05
[    1.334780] i2c /dev entries driver
[    1.341322] cpuidle: enable-method property 'ti,am3352' found operations
[    1.348771] sdhci: Secure Digital Host Controller Interface driver
[    1.354989] sdhci: Copyright(c) Pierre Ossman
[    1.360180]
[    1.360180]
[    1.360180]  			 hey mad inside omap_hsmmc_probe
[    1.368746] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.6
[    1.399508]
[    1.399508]
[    1.399508]  			 hey mad inside omap_hsmmc_probe
[    1.408073] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.6
[    1.439715] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.447056] ledtrig-cpu: registered to indicate activity on CPUs
[    1.463949] NET: Registered protocol family 10
[    1.470832] Segment Routing with IPv6
[    1.474763] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.481900] NET: Registered protocol family 17
[    1.487062] Key type dns_resolver registered
[    1.491766] omap_voltage_late_init: Voltage driver support not added
[    1.498330] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.507736] Loading compiled-in X.509 certificates
[    1.517704] mmc0: new high speed SDHC card at address aaaa
[    1.527951] mmc1: new high speed MMC card at address 0001
[    1.537356] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    1.545102] mmcblk1: mmc1:0001 Q2J55L 7.09 GiB
[    1.551351] mmcblk1boot0: mmc1:0001 Q2J55L partition 1 16.0 MiB
[    1.557606]  mmcblk0: p1 p2
[    1.561489] mmcblk1boot1: mmc1:0001 Q2J55L partition 2 16.0 MiB
[    1.568978] mmcblk1rpmb: mmc1:0001 Q2J55L partition 3 4.00 MiB, chardev (244:0)
[    1.578389]  mmcblk1: p1 p2
[    1.582168] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.592791] max9860 2-0010: Linked as a consumer to regulator.3
[    1.628225] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
[    1.635431] max9860 2-0010: Linked as a consumer to regulator.4
[    1.643104] asoc-simple-card sound@0: max9860-hifi <-> 4803c000.mcasp mapping ok
[    1.650647] asoc-simple-card sound@0: ASoC: no DMI vendor name!
[    1.660631] asoc-simple-card sound: pcm5102a-hifi <-> 48038000.mcasp mapping ok
[    1.668112] asoc-simple-card sound: ASoC: no source widget found for OUT
[    1.674854] asoc-simple-card sound: ASoC: Failed to add route OUT -> direct -> Headphone Jack
[    1.683458] asoc-simple-card sound: ASoC: no DMI vendor name!
[    1.691618] hctosys: unable to open rtc device (rtc0)
[    1.697624] ALSA device list:
[    1.700624]   #0: MAX9860
[    1.703255]   #1: DSP
[    1.818221] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[    1.833296] EXT4-fs (mmcblk0p2): Errors on filesystem, clearing orphan list.
[    1.833296]
[    1.841952] EXT4-fs (mmcblk0p2): recovery complete
[    1.850142] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.858413] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.876247] devtmpfs: mounted
[    1.881248] Freeing unused kernel memory: 1024K
[    1.886557] Run /sbin/init as init process
[    2.181234] systemd[1]: System time before build time, advancing clock.
[    2.231964] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.245750] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    2.269600] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    2.292085] systemd[1]: Detected architecture arm.
Welcome to Arago 2019.11!
[    2.350188] systemd[1]: Set hostname to <BEL-MVR>.
[    2.733044] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.748053] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    2.778815] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.793175] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    2.813012] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.827549] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    2.847254] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[  OK  ] Listening on Process Core Dump Socket.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Listening on Journal Socket.
         Mounting Kernel Debug File System...
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Listening on udev Control Socket.
         Starting udev Coldplug all Devices...
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Listening on initctl Compatibility Named Pipe.
         Starting Load Kernel Modules...
[  OK  ] Reached target Paths.
[  OK  ] Reached target Swap.
         Mounting Temporary Directory (/tmp)...
[    4.086623] cryptodev: loading out-of-tree module taints kernel.
[  OK  ] Listening on Network Service Netlink Socket.
         Starting Remount Root and Kernel File Systems...
[    4.143923] cryptodev: driver 1.9 loaded.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Listening on Journal Socket (/dev/log).
         Starting Journal Service...
[    4.262616] usbcore: registered new interface driver usbfs
         Mounting POSIX Message Queue File System...
[  OK  ] Created slice system-getty.slice.
[    4.341164] usbcore: registered new interface driver hub
[    4.364482] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.383013] usbcore: registered new device driver usb
         Starting Psplash Boot Screen...
[    4.462104] systemd-journald[81]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[  OK  ] Mounted Kernel Debug File System.
[    4.529856] usbcore: registered new interface driver ftdi_sio
[    4.535803] usbserial: USB Serial support registered for FTDI USB Serial Device
[    4.544030] systemd-journald[81]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Psplash Boot Screen.
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Journal Service.
[  OK  ] Started Apply Kernel Variables.
         Starting Flush Journal to Persistent Storage...
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Containers.
         Mounting /var/volatile...
         Mounting /media/ram...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[    5.753690] systemd-journald[81]: Received request to flush runtime journal from PID 1
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Load/Save Random Seed.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
         Starting Network Service...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Service.
         Starting Network Name Resolution...
         Starting Wait for Network to be Configured...
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
[    8.949962] input: matrix_keypad0 as /devices/platform/matrix_keypad0/input/input0
[    9.157055] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    9.337556] omap_rtc 44e3e000.rtc: registered as rtc0
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Started udev Coldplug all Devices.
[   10.686297] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[   10.759408] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[   10.896628] omap-aes 53500000.aes: will run requests pump with realtime priority
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight�ightness of backlight:backlight...
[   11.108421] remoteproc remoteproc0: wkup_m3 is available
[   11.141985] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.sgx on minor 1
[  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Listening on RPCbind Server Activation Socket.
[   11.967699] remoteproc remoteproc0: powering up wkup_m3
[   12.092921] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 242888
[   12.109470] net eth0: initializing cpsw version 1.12 (0)
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[   12.264986] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[  OK  ] Reached target Sockets.
[   12.322907] TI DP83867 4a101000.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[  OK  ] Reached target Basic System.
[   12.372473] PM: Cannot get wkup_m3_ipc handle
[   12.420640] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   12.551214] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
         Starting Print notice about GPLv3 packages...
[  OK  ] Started Periodic Command Scheduler.
         Starting rc.pvr.service...
[   12.958878] net eth1: initializing cpsw version 1.12 (0)
[   13.128194] TI DP83867 4a101000.mdio:01: attached PHY driver [TI DP83867] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL)
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Job spooling tools.
[   13.377564] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   13.386976] snd_soc_simple_card_utils: exports duplicate symbol asoc_simple_card_canonicalize_cpu (owned by kernel)
         Starting Lightning Fast Webserver With Light System Requirements...
[   13.607400] snd_soc_simple_card_utils: exports duplicate symbol asoc_simple_card_canonicalize_cpu (owned by kernel)
         Starting Simple Network Management Protocol (SNMP) Daemon....
[   13.874300] snd_soc_simple_card_utils: exports duplicate symbol asoc_simple_card_canonicalize_cpu (owned by kernel)
[   13.905591] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[  OK  ] Started Redis In-Memory Data Store.
         Starting Permit User Sessions...
[   14.142583] snd_soc_simple_card_utils: exports duplicate symbol asoc_simple_card_canonicalize_cpu (owned by kernel)
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started D-Bus System Message Bus.
[   15.058938] BUG: FP instruction issued in kernel mode with FP unit disabled
[   15.065991] Internal error: Oops - undefined instruction: 0 [#1] PREEMPT ARM
[   15.073075] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc pvrsrvkm(O) omap_aes_driver crypto_engine omap_sham omap_crypto ti_emif_sram pruss_soc_bus rtc_omap omap_wdt matrix_keypad matrix_keymap sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common cryptodev(O)
[   15.099511] CPU: 0 PID: 361 Comm: basename Tainted: G           O      4.19.94-gbe5389fd85 #17
[   15.108162] Hardware name: Generic AM33XX (Flattened Device Tree)
[   15.114312] PC is at load_elf_binary+0x884/0x14c8
[   15.119040] LR is at padzero+0x60/0x78
[   15.122807] pc : [<c0292958>]    lr : [<c02909dc>]    psr: a0060013
[   15.129103] sp : edf8fe68  ip : 00000003  fp : edf8ff04
[   15.134351] r10: edf8fe68  r9 : 0009d6a9  r8 : 0009d6a9
[   15.139600] r7 : 00000000  r6 : edfbfa00  r5 : c0e03048  r4 : edfc1500
[   15.146157] r3 : 00000001  r2 : 00000000  r1 : 00000957  r0 : 00000000
[   15.152719] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   15.159887] Control: 10c5387d  Table: ad178019  DAC: 00000051
[   15.165667] Process basename (pid: 361, stack limit = 0x95656f57)
[   15.171788] Stack: (0xedf8fe68 to 0xedf90000)
[   15.176173] fe60:                   00101802 00000000 00000000 edf8fe68 ffffe000 0009cf08
[   15.184395] fe80: 0008cdbc 00010000 00010000 0009d6a9 edee4140 edfc1534 00000000 0008cdbc
[   15.192617] fea0: 0009cf08 0009dca4 eddd9c00 edfc1500 edf5e840 eda1ce00 00000034 00000000
[   15.200840] fec0: c024358c c014e18c ee4eea50 00000004 00000000 bf9b4762 edfbfa00 c0e1babc
[   15.209061] fee0: edfbfa00 ffffe000 c0e1b618 c0bd8df4 00000002 fffffff8 edf8ff34 edf8ff08
[   15.217284] ff00: c023e4b4 c02920e0 00000000 c0e03048 ee8bd000 edfbfa00 00000169 00000000
[   15.225505] ff20: 00000000 00000001 edf8ff84 edf8ff38 c023ee04 c023e41c ffffe000 00000000
[   15.233725] ff40: edf543b8 edd40e40 edf54380 000d0f98 00000000 bf9b4762 0000000b 000d79b0
[   15.241947] ff60: 000d0f98 000d3f30 0000000b c0101204 edf8e000 0000000b edf8ffa4 edf8ff88
[   15.250169] ff80: c023f334 c023e958 00000000 00000000 000d3f08 000c4084 00000000 edf8ffa8
[   15.258392] ffa0: c0101000 c023f304 000d3f08 000c4084 000d3f30 000d79b0 000d0f98 000c2ae4
[   15.266614] ffc0: 000d3f08 000c4084 000d3f30 0000000b 000d79b0 000d0f98 00000000 000c4098
[   15.274835] ffe0: b6e61990 bee67064 000373a5 b6e6199c 60060010 000d3f30 00000000 00000000
[   15.283046] Backtrace:
[   15.285522] [<c02920d4>] (load_elf_binary) from [<c023e4b4>] (search_binary_handler.part.2+0xa4/0x240)
[   15.294878]  r10:fffffff8 r9:00000002 r8:c0bd8df4 r7:c0e1b618 r6:ffffe000 r5:edfbfa00
[   15.302742]  r4:c0e1babc
[   15.305294] [<c023e410>] (search_binary_handler.part.2) from [<c023ee04>] (__do_execve_file+0x4b8/0x754)
[   15.314823]  r10:00000001 r9:00000000 r8:00000000 r7:00000169 r6:edfbfa00 r5:ee8bd000
[   15.322689]  r4:c0e03048 r3:00000000
[   15.326287] [<c023e94c>] (__do_execve_file) from [<c023f334>] (sys_execve+0x3c/0x44)
[   15.334072]  r10:0000000b r9:edf8e000 r8:c0101204 r7:0000000b r6:000d3f30 r5:000d0f98
[   15.341936]  r4:000d79b0
[   15.344490] [<c023f2f8>] (sys_execve) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
[   15.352181] Exception stack(0xedf8ffa8 to 0xedf8fff0)
[   15.357261] ffa0:                   000d3f08 000c4084 000d3f30 000d79b0 000d0f98 000c2ae4
[   15.365482] ffc0: 000d3f08 000c4084 000d3f30 0000000b 000d79b0 000d0f98 00000000 000c4098
[   15.373700] ffe0: b6e61990 bee67064 000373a5 b6e6199c
[   15.378775]  r5:000c4084 r4:000d3f08
[   15.382375] Code: e3530000 0a0000ae e1d434b4 e2433002 (f3530001)
[   15.388504] ---[ end trace a2f72798f99d10b1 ]---
[   15.393360] note: basename[361] exited with preempt_count 1
         Starting Reboot and dump vmcore via kexec...
         Starting Login Service...
         Starting RPC Bind Service...
[   16.307053] gpio gpiochip3: Persistence not supported for GPIO 21
[  OK  ] Started rc.pvr.service.
[  OK  ] Started Lightning Fast Webserver With Light System Requirements.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Started RPC Bind Service.
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
[  OK  ] Found device /dev/ttyS3.
[   27.356231] Ploader does not support rtc-only!
[   27.888754] rroc remoteproc1: 4a334000.pru is available
[   27.894749] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[   28.014842] remoteproc remoteproc2: 4a338000.pru is available
[   28.045813] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
[   31.846591] vsabling
[   31.849441] lis3_reg: disabling
[   31.852599] v3v3: disabling
[   31.855406] vdig1: disabling
NOTICE: This file system contains the following GPLv3 packages:
	autoconf
	bash-dev
	bash
	bc
	binutils
	cifs-utils
	cpio
	cpp-symlinks
	cpp
	dosfstools
	elfutils
	findutils
	g++-symlinks
	g++
	gawk
	gcc-symlinks
	gcc
	gdb
	gdbserver
	gettext
	glmark2
	gstreamer1.0-libav
	gzip
	hidapi
	libbfd
	libcairo-perf-utils
	libdw1
	libelf1
	libgdbm-compat4
	libgdbm-dev
	libgdbm6
	libgettextlib
	libgettextsrc
	libgmp10
	libidn2-0
	libmavconn
	libmpc3
	libmpfr6
	libreadline-dev
	libreadline7
	libunistring2
	m4-dev
	m4
	make
	mavlink
	mavros-extras
	mavros-msgs
	mavros
	nettle
	pdm-anomaly-detection
	socketcan-interface
	swig-dev
	swig
	which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[  *** ] (4 of 5) A start job is running for�mDNS/DNS-SD Stack (34s / 1min 39s)[ ***  ] (4 of 5) A start job is running for�mDNS/DNS-SD Stack (34s / 1min 39s)[***   ] (5 of 5) A start job is running for� to be Configured (35s / no limit)[  OK  ] Found device /dev/mmcblk0p1.
         Starting Start USB gadget...
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting Save/Restore Sound Card State...
[  OK  ] Created slice system-systemd\x2dfsck.slice.
         Starting File System Check on /dev/mmcblk1p2...
[   39.696734] udc-core: couldn't find an available UDC - added [g_multi] to list of pending drivers
         Starting File System Check on /dev/mmcblk0p1...
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Serial Getty on ttyS3.
         Starting weston.service...
[   40.417640] mmc1: cache flush error -110
[   40.421654] print_req_error: I/O error, dev mmcblk1, sector 0
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started File System Check on /dev/mmcblk0p1.
[  OK  ] Started File System Check on /dev/mmcblk1p1.
[  OK  ] Started File System Check on /dev/mmcblk1p2.
         Mounting /run/media/mmcblk1p2...
         Mounting /run/media/mmcblk1p1...
         Mounting /run/media/mmcblk0p1...
[  OK  hed target Sound Card.
[   41.463634] E(mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[FAILED] Failed to start Start USB gadget.
See 'systemctl status gadget-init.service' for details.
[  OK  ] Started weston.service.
[  OK  ] Mounted /run/media/mmcblk1p2.
[  OK  nted /run/media/mmcblk1p1.
[  OK  ] Mounted /run/media/mmcblk0p1.
         Startinix GUI...
         Startinlnetd.service...
         Starting Matrix GUI...
[  OK  arted Login Service.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ted Matrix GUI.
[   42.272747] gpio gpiochip2: Persistence not supported for GPIO 1
[  OK  ] Started telnetd.service.
         Starting busybox-udhcpd.service...
         Starting thttpd.service...
[  OK  ted busybox-udhcpd.service.
[  OK  ] Started thttpd.service.
BEL-MVR login: root (automatic login)
[   45.760560] BUG: FP instruction issued in kernel mode with FP unit disabled
[   45.767609] Internal error: Oops - undefined instruction: 0 [#2] PREEMPT ARM
[   45.774693] Modules linked in: g_multi usb_f_mass_storage usb_f_rndis u_ether libcomposite udc_core pru_rproc irq_pruss_intc pruss pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc pvrsrvkm(O) omap_aes_driver crypto_engine omap_sham omap_crypto ti_emif_sram pruss_soc_bus rtc_omap omap_wdt matrix_keypad matrix_keymap sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common cryptodev(O)
[   45.809875] CPU: 0 PID: 1011 Comm: systemd Tainted: G      D    O      4.19.94-gbe5389fd85 #17
[   45.818525] Hardware name: Generic AM33XX (Flattened Device Tree)
[   45.824674] PC is at load_elf_binary+0x884/0x14c8
[   45.829401] LR is at padzero+0x60/0x78
[   45.833169] pc : [<c0292958>]    lr : [<c02909dc>]    psr: a0030013
[   45.839464] sp : ed167e68  ip : 00000000  fp : ed167f04
[   45.844712] r10: ed167e68  r9 : 000ef27c  r8 : 005bd27c
[   45.849961] r7 : 00000000  r6 : ed257100  r5 : c0e03048  r4 : ed1f8f00
[   45.856518] r3 : 00000001  r2 : 00000000  r1 : 00000d84  r0 : 00000000
[   45.863078] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   45.870246] Control: 10c5387d  Table: ad200019  DAC: 00000051
[   45.876026] Process systemd (pid: 1011, stack limit = 0x3d391909)
[   45.882147] Stack: (0xed167e68 to 0xed168000)
[   45.886531] 7e60:                   00101802 00000000 00000000 ed167e68 ffffe000 0059c2b0
[   45.894754] 7e80: 0058c0f4 004ce000 004ce000 005bd27c ed269b00 ed1f8f34 004ce000 000be0f4
[   45.902978] 7ea0: 000ce2b0 000ef324 ed2619c0 ed1f8f00 ed223600 ed9f6000 00000034 00000000
[   45.911199] 7ec0: c024358c c014e18c ee191410 00000004 00000000 b6cda846 ed257100 c0e1babc
[   45.919421] 7ee0: ed257100 ffffe000 c0e1b618 c0bd8df4 00000002 fffffff8 ed167f34 ed167f08
[   45.927642] 7f00: c023e4b4 c02920e0 00000000 c0e03048 edbb9000 ed257100 000003f3 00000000
[   45.935864] 7f20: 00000000 00000001 ed167f84 ed167f38 c023ee04 c023e41c ffffe000 00000000
[   45.944086] 7f40: edb4e038 ed21a960 edb4e000 0072a348 00000000 b6cda846 0000000b 00604b70
[   45.952308] 7f60: 0072a348 0069dcb0 0000000b c0101204 ed166000 0000000b ed167fa4 ed167f88
[   45.960530] 7f80: c023f334 c023e958 00000000 00000000 00604b70 00000000 00000000 ed167fa8
[   45.968752] 7fa0: c0101000 c023f304 00604b70 00000000 006e79d0 00604b70 0072a348 00679eb0
[   45.976973] 7fc0: 00604b70 00000000 0069dcb0 0000000b 00000001 bee3e878 00726a98 ffffffff
[   45.985194] 7fe0: 005ea920 bee3e6b4 0052a98b b6c1699c 60030010 006e79d0 00000000 00000000
[   45.993405] Backtrace:
[   45.995881] [<c02920d4>] (load_elf_binary) from [<c023e4b4>] (search_binary_handler.part.2+0xa4/0x240)
[   46.005237]  r10:fffffff8 r9:00000002 r8:c0bd8df4 r7:c0e1b618 r6:ffffe000 r5:ed257100
[   46.013103]  r4:c0e1babc
[   46.015655] [<c023e410>] (search_binary_handler.part.2) from [<c023ee04>] (__do_execve_file+0x4b8/0x754)
[   46.025185]  r10:00000001 r9:00000000 r8:00000000 r7:000003f3 r6:ed257100 r5:edbb9000
[   46.033050]  r4:c0e03048 r3:00000000
[   46.036650] [<c023e94c>] (__do_execve_file) from [<c023f334>] (sys_execve+0x3c/0x44)
[   46.044434]  r10:0000000b r9:ed166000 r8:c0101204 r7:0000000b r6:0069dcb0 r5:0072a348
[   46.052298]  r4:00604b70
[   46.054853] [<c023f2f8>] (sys_execve) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
[   46.062544] Exception stack(0xed167fa8 to 0xed167ff0)
[   46.067625] 7fa0:                   00604b70 00000000 006e79d0 00604b70 0072a348 00679eb0
[   46.075846] 7fc0: 00604b70 00000000 0069dcb0 0000000b 00000001 bee3e878 00726a98 ffffffff
[   46.084064] 7fe0: 005ea920 bee3e6b4 0052a98b b6c1699c
[   46.089138]  r5:00000000 r4:00604b70
[   46.092737] Code: e3530000 0a0000ae e1d434b4 e2433002 (f3530001)
[   46.098867] ---[ end trace a2f72798f99d10b2 ]---
[   46.103796] note: systemd[1011] exited with preempt_count 1
root@BEL-MVR:~# [   49.965665] gpio gpiochip0: Persistence not supported for GPIO 19
[   49.978866] gpio gpiochip0: Persistence not supported for GPIO 6
[   50.005256] gpio gpiochip0: Persistence not supported for GPIO 20
[   50.022769] gpio gpiochip3: Persistence not supported for GPIO 18
[   50.044963] gpio gpiochip1: Persistence not supported for GPIO 28
[   50.068525] gpio gpiochip1: Persistence not supported for GPIO 29
[   50.098280] gpio gpiochip2: Persistence not supported for GPIO 0
[   59.653883] BUG: FP instruction issued in kernel mode with FP unit disabled
[   59.660933] Internal error: Oops - undefined instruction: 0 [#3] PREEMPT ARM
[   59.668016] Modules linked in: g_multi usb_f_mass_storage usb_f_rndis u_ether libcomposite udc_core pru_rproc irq_pruss_intc pruss pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc pvrsrvkm(O) omap_aes_driver crypto_engine omap_sham omap_crypto ti_emif_sram pruss_soc_bus rtc_omap omap_wdt matrix_keypad matrix_keymap sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common cryptodev(O)
[   59.703195] CPU: 0 PID: 0 Comm: swapper Tainted: G      D    O      4.19.94-gbe5389fd85 #17
[   59.711583] Hardware name: Generic AM33XX (Flattened Device Tree)
[   59.717731] PC is at amx3_idle_enter+0xc/0x48
[   59.722114] LR is at arm_cpuidle_suspend+0x1c/0x20
[   59.726926] pc : [<c011f148>]    lr : [<c010d0b4>]    psr: 60060093
[   59.733221] sp : c0e01e98  ip : c0e01ea8  fp : c0e01ea4
[   59.738470] r10: e3a59bbc  r9 : 000000a0  r8 : eed8e000
[   59.743718] r7 : eee480a0  r6 : 0000000d  r5 : eed8e000  r4 : 00000001
[   59.750276] r3 : c011f13c  r2 : fc1edce2  r1 : 00000000  r0 : 00000001
[   59.756837] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   59.764092] Control: 10c5387d  Table: adfd0019  DAC: 00000051
[   59.769870] Process swapper (pid: 0, stack limit = 0xf1943372)
[   59.775730] Stack: (0xc0e01e98 to 0xc0e02000)
[   59.780110] 1e80:                                                       c0e01eb4 c0e01ea8
[   59.788332] 1ea0: c010d0b4 c011f148 c0e01ecc c0e01eb8 c070fc40 c010d0a4 ffffe000 eed8e000
[   59.796555] 1ec0: c0e01f0c c0e01ed0 c070d664 c070fc00 000007a0 00000000 00000001 00000000
[   59.804777] 1ee0: 0026a659 ffffe000 eed8e000 c0e030b4 eee48000 c0e3f1b8 c0e03048 c0e030c8
[   59.813000] 1f00: c0e01f1c c0e01f10 c070d930 c070d5fc c0e01f2c c0e01f20 c015494c c070d920
[   59.821222] 1f20: c0e01f74 c0e01f30 c0154cf0 c0154930 c015501c 00000001 c0bce3c8 c0e4d8a8
[   59.829444] 1f40: 00000051 fc1edce2 c0e01f6c c0e0e2e0 00000002 c0e03048 ffffffff c0e03040
[   59.837666] 1f60: c0e4eec0 c0d3da30 c0e01f84 c0e01f78 c015501c c0154b14 c0e01f9c c0e01f88
[   59.845889] 1f80: c092b084 c0155014 c0e4ef18 c0e4eec0 c0e01ff4 c0e01fa0 c0d00dbc c092afe0
[   59.854111] 1fa0: ffffffff ffffffff 00000000 c0d005dc 00000000 efffc740 00000000 c0d3da30
[   59.862334] 1fc0: fc1acfbc 00000000 00000000 c0d00330 00000051 10c03c7d 00000e05 8fff3000
[   59.870555] 1fe0: 413fc082 10c53c7d 00000000 c0e01ff8 00000000 c0d009bc 00000000 00000000
[   59.878767] Backtrace:
[   59.881239] [<c011f13c>] (amx3_idle_enter) from [<c010d0b4>] (arm_cpuidle_suspend+0x1c/0x20)
[   59.889731] [<c010d098>] (arm_cpuidle_suspend) from [<c070fc40>] (arm_enter_idle_state+0x4c/0x64)
[   59.898651] [<c070fbf4>] (arm_enter_idle_state) from [<c070d664>] (cpuidle_enter_state+0x74/0x300)
[   59.907651]  r5:eed8e000 r4:ffffe000
[   59.911248] [<c070d5f0>] (cpuidle_enter_state) from [<c070d930>] (cpuidle_enter+0x1c/0x20)
[   59.919556]  r10:c0e030c8 r9:c0e03048 r8:c0e3f1b8 r7:eee48000 r6:c0e030b4 r5:eed8e000
[   59.927420]  r4:ffffe000
[   59.929981] [<c070d914>] (cpuidle_enter) from [<c015494c>] (call_cpuidle+0x28/0x40)
[   59.937680] [<c0154924>] (call_cpuidle) from [<c0154cf0>] (do_idle+0x1e8/0x234)
[   59.945030] [<c0154b08>] (do_idle) from [<c015501c>] (cpu_startup_entry+0x14/0x18)
[   59.952641]  r10:c0d3da30 r9:c0e4eec0 r8:c0e03040 r7:ffffffff r6:c0e03048 r5:00000002
[   59.960505]  r4:c0e0e2e0
[   59.963061] [<c0155008>] (cpu_startup_entry) from [<c092b084>] (rest_init+0xb0/0xb4)
[   59.970857] [<c092afd4>] (rest_init) from [<c0d00dbc>] (start_kernel+0x40c/0x434)
[   59.978374]  r5:c0e4eec0 r4:c0e4ef18
[   59.981972] [<c0d009b0>] (start_kernel) from [<00000000>] (  (null))
[   59.988363] Code: e89da800 e1a0c00d e92dd800 e24cb004 (f30f3484)
[   59.994498] ---[ end trace a2f72798f99d10b3 ]---
[   59.999141] Kernel panic - not syncing: Attempted to kill the idle task!
[   60.005880] ---[ end Kernel panic - not syncing: Attempted to kill the idle task! ]---
[  305.360385] EXT4-fs (mmcblk0p2): error count since last fsck: 1
[  305.366391] EXT4-fs (mmcblk0p2): initial error at time 1587262234: ext4_lookup:1590: inode 262647
[  305.375321] EXT4-fs (mmcblk0p2): last error at time 1587262234: ext4_lookup:1590: inode 262647
DRAM:  1 GiB
NAND:  0 MiB
Hit any key to stop autoboot:  0
Scanning mmc 0:1...
4297216 bytes read in 363 ms (11.3 MiB/s)
37628 bytes read in 4 ms (9 MiB/s)
   Loading Device Tree to 8fff3000, end 8ffff2fb ... OK
Starting kernel ...
[    0.000020] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000049] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000064] OMAP clocksource: timer1 at 24000000 Hz
[    0.000302] timer_probe: no matching timers found
[    0.000534] Console: colour dummy device 80x30
[    0.000570] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000579] This ensures that you still see kernel messages. Please
[    0.000587] update your kernel commandline.
[    0.000655] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[    0.118824] pid_max: default: 32768 minimum: 301
[    0.119104] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.119130] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.120181] CPU: Testing write buffer coherency: ok
[    0.120259] CPU0: Spectre v2: using BPIALL workaround
[    0.121390] Setting up static identity map for 0x80100000 - 0x80100060
[    0.121595] rcu: Hierarchical SRCU implementation.
[    0.122059] EFI services will not be available.
[    0.124052] devtmpfs: initialized
[    0.134934] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.135446] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.135480] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.140243] pinctrl core: initialized pinctrl subsystem
[    0.141194] DMI not present or invalid.
[    0.141759] NET: Registered protocol family 16
[    0.144742] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.174184] l4_wkup_cm:clk:0010:0: failed to disable
[    0.242063] cpuidle: using governor ladder
[    0.242116] cpuidle: using governor menu
[    0.249129] OMAP GPIO hardware version 0.1
[    0.265106] No ATAGs?
[    0.265121] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.285448] edma 49000000.edma: TI EDMA DMA engine driver
[    0.291831] SCSI subsystem initialized
[    0.292531] media: Linux media interface: v0.10
[    0.292591] videodev: Linux video capture interface: v2.00
[    0.292710] pps_core: LinuxPPS API ver. 1 registered
[    0.292722] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.292753] PTP clock support registered
[    0.292802] EDAC MC: Ver: 3.0.0
[    0.294217] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.295038] Advanced Linux Sound Architecture Driver Initialized.
[    0.296574] clocksource: Switched to clocksource timer1
[    0.308540] NET: Registered protocol family 2
[    0.309636] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[    0.309684] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.309796] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.309906] TCP: Hash tables configured (established 8192 bind 8192)
[    0.310066] UDP hash table entries: 512 (order: 1, 8192 bytes)
[    0.310108] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[    0.310324] NET: Registered protocol family 1
[    0.311083] RPC: Registered named UNIX socket transport module.
[    0.311104] RPC: Registered udp transport module.
[    0.311113] RPC: Registered tcp transport module.
[    0.311123] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.312367] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.314160] Initialise system trusted keyrings
[    0.314567] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.321529] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.322529] NFS: Registering the id_resolver key type
[    0.322580] Key type id_resolver registered
[    0.322591] Key type id_legacy registered
[    0.322649] ntfs: driver 2.1.32 [Flags: R/O].
[    0.325750] Key type asymmetric registered
[    0.325774] Asymmetric key parser 'x509' registered
[    0.325871] bounce: pool size: 64 pages
[    0.325960] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.325977] io scheduler noop registered
[    0.325988] io scheduler deadline registered
[    0.326315] io scheduler cfq registered (default)
[    0.326331] io scheduler mq-deadline registered
[    0.326342] io scheduler kyber registered
[    0.329269] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.334270] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.334395] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.404163] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.409640] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[    1.048016] console [ttyS0] enabled
[    1.053075] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[    1.063333] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 32, base_baud = 3000000) is a 8250
[    1.075010] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.081487] random: fast init done
[    1.085170] random: crng init done
[    1.091350] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.098378] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.104989] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.111025] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.117693] [drm] No driver support for vblank timestamp query.
[    1.127561] Console: switching to colour frame buffer device 40x30
[    1.135382] tilcdc 4830e000.lcdc: fb0: DRM emulated frame buffer device
[    1.142802] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    1.167059] brd: module loaded
[    1.170170] BUG: FP instruction issued in kernel mode with FP unit disabled
[    1.177179] Internal error: Oops - undefined instruction: 0 [#1] PREEMPT ARM
[    1.184262] Modules linked in:
[    1.187346] CPU: 0 PID: 1 Comm: swapper Not tainted 4.19.94-gbe5389fd85 #17
[    1.194338] Hardware name: Generic AM33XX (Flattened Device Tree)
[    1.200479] PC is at pm_runtime_init+0x44/0xa4
[    1.204946] LR is at 0x41
[    1.207579] pc : [<c05c0058>]    lr : [<00000041>]    psr: 60000013
[    1.213872] sp : ee885dd8  ip : 00000002  fp : ee885df4
[    1.219120] r10: 00000007  r9 : c0d3d830  r8 : 00a000ed
[    1.224369] r7 : 00000000  r6 : c0e32784  r5 : c0e850f0  r4 : eec57400
[    1.230926] r3 : 00000000  r2 : 00000000  r1 : ffffffe0  r0 : ffff8b44
[    1.237486] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[    1.244654] Control: 10c5387d  Table: 80004019  DAC: 00000051
[    1.250433] Process swapper (pid: 1, stack limit = 0xccfb8cb4)
[    1.256294] Stack: (0xee885dd8 to 0xee886000)
[    1.260673] 5dc0:                                                       eec57400 c0e850f0
[    1.268895] 5de0: c0e32784 eec57400 ee885e0c ee885df8 c05ad608 c05c0020 eec57400 ee9aa340
[    1.277116] 5e00: ee885e34 ee885e10 c05aeed0 c05ad598 c0e03048 c0c51620 00000000 c0e2f898
[    1.285338] 5e20: 00000000 c0d3d830 ee885e6c ee885e38 c05aeffc c05aee80 00000000 c0c51620
[    1.293559] 5e40: ee885e78 c016d95c ee885e78 01fc0306 0000001c c0e2f8a4 c0e32784 c0e32790
[    1.301782] 5e60: ee885ea4 ee885e70 c0522900 c05aefcc 00000000 c0c51620 c0c1c718 c016e46c
[    1.310003] 5e80: ee885ea4 c0e4eec0 c0e03048 00100000 00000008 00000000 ee885ed4 ee885ea8
[    1.318225] 5ea0: c0d24d4c c0522844 00000000 ee880000 00000000 01fc0306 c0e4eec0 c0e03048
[    1.326446] 5ec0: ffffe000 c0d24cb8 ee885f4c ee885ed8 c0102640 c0d24cc4 00000000 c0bcdc64
[    1.334668] 5ee0: c0bcdc44 c0bcdc00 c0bd8af8 c0e03048 00000000 c0bcdc1c 00000006 00000006
[    1.342889] 5f00: 00000000 c0c30710 c0d004f0 c0cb07c0 ee885f34 efffc804 00000000 01fc0306
[    1.351110] 5f20: 00000000 01fc0306 c0e4eec0 c0cb07c0 c0d5092c c0e4eec0 c0e4eec0 c0d3d850
[    1.359332] 5f40: ee885f94 ee885f50 c0d00f2c c01025c8 00000006 00000006 00000000 c0d004f0
[    1.367552] 5f60: c0d004f0 000000ed ffffe000 00000000 c092b088 00000000 00000000 00000000
[    1.375773] 5f80: 00000000 00000000 ee885fac ee885f98 c092b098 c0d00df0 00000000 c092b088
[    1.383995] 5fa0: 00000000 ee885fb0 c01010e8 c092b094 00000000 00000000 00000000 00000000
[    1.392216] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.400436] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[    1.408648] Backtrace:
[    1.411133] [<c05c0014>] (pm_runtime_init) from [<c05ad608>] (device_initialize+0x7c/0xb0)
[    1.419436]  r4:eec57400
[    1.421993] [<c05ad58c>] (device_initialize) from [<c05aeed0>] (device_create_groups_vargs+0x5c/0xc4)
[    1.431255]  r5:ee9aa340 r4:eec57400
[    1.434853] [<c05aee74>] (device_create_groups_vargs) from [<c05aeffc>] (device_create_with_groups+0x3c/0x58)
[    1.444819]  r9:c0d3d830 r8:00000000 r7:c0e2f898 r6:00000000 r5:c0c51620 r4:c0e03048
[    1.452612] [<c05aefc0>] (device_create_with_groups) from [<c0522900>] (misc_register+0xc8/0x190)
[    1.461525]  r6:c0e32790 r5:c0e32784 r4:c0e2f8a4
[    1.466175] [<c0522838>] (misc_register) from [<c0d24d4c>] (loop_init+0x94/0x150)
[    1.473696]  r8:00000000 r7:00000008 r6:00100000 r5:c0e03048 r4:c0e4eec0
[    1.480440] [<c0d24cb8>] (loop_init) from [<c0102640>] (do_one_initcall+0x84/0x1b0)
[    1.488134]  r7:c0d24cb8 r6:ffffe000 r5:c0e03048 r4:c0e4eec0
[    1.493835] [<c01025bc>] (do_one_initcall) from [<c0d00f2c>] (kernel_init_freeable+0x148/0x1e4)
[    1.502578]  r8:c0d3d850 r7:c0e4eec0 r6:c0e4eec0 r5:c0d5092c r4:c0cb07c0
[    1.509321] [<c0d00de4>] (kernel_init_freeable) from [<c092b098>] (kernel_init+0x10/0x11c)
[    1.517629]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c092b088
[    1.525493]  r4:00000000
[    1.528043] [<c092b088>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    1.535646] Exception stack(0xee885fb0 to 0xee885ff8)
[    1.540724] 5fa0:                                     00000000 00000000 00000000 00000000
[    1.548945] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.557163] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.563807]  r5:c092b088 r4:00000000
[    1.567407] Code: e584c0d4 e1a02003 e5c4e0c8 e3e0101f (f284e0a8)
[    1.573554] ---[ end trace acbaed4ee50ad7d7 ]---
[    1.578316] note: swapper[1] exited with preempt_count 1
[    1.583662] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    1.583662]
[    1.592846] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    1.592846]  ]---
Trying to boot from MMC2
U-Boot 2019. 20 2021 - 14:43:32 +0530)
DRAM:  1 GiB
NAND:  0 MiB
Loading Environment from FAT... <ethaddr> not sedating first E-fuse MAC
switch to partit, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
SD/MMC found on vice 1
37628 bytes read in 5 ms (7.2 MiB/s)
Starting kernel ...
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=c13ac174-02 rw rootfstype=ext4 rootwait
[    0.000019] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000063] OMAP clocksource: timer1 at 24000000 Hz
[    0.000304] timer_probe: no matching timers found
[    0.000538] Console: colour dummy device 80x30
[    0.000572] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000583] This ensures that you still see kernel messages. Please
[    0.000591] update your kernel commandline.
[    0.000659] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[    0.118822] pid_max: default: 32768 minimum: 301
[    0.120179] CPU: Testing write buffer coherency: ok
[    0.120258] CPU0: Spectre v2: using BPIALL workaround
[    0.121380] Setting up static identity map for 0x80100000 - 0x80100060
[    0.121588] rcu: Hierarchical SRCU implementation.
[    0.122052] EFI services will not be available.
[    0.124042] devtmpfs: initialized
[    0.134944] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.135444] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.135476] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.140197] pinctrl core: initialized pinctrl subsystem
[    0.141152] DMI not present or invalid.
[    0.141714] NET: Registered protocol family 16
[    0.144685] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.174062] l4_wkup_cm:clk:0010:0: failed to disable
[    0.241946] cpuidle: using governor ladder
[    0.241995] cpuidle: using governor menu
[    0.248980] OMAP GPIO hardware version 0.1
[    0.264927] No ATAGs?
[    0.264942] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.285251] edma 49000000.edma: TI EDMA DMA engine driver
[    0.291682] SCSI subsystem initialized
[    0.292383] media: Linux media interface: v0.10
[    0.292448] videodev: Linux video capture interface: v2.00
[    0.292571] pps_core: LinuxPPS API ver. 1 registered
[    0.292583] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.292613] PTP clock support registered
[    0.292663] EDAC MC: Ver: 3.0.0
[    0.294065] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.294889] Advanced Linux Sound Architecture Driver Initialized.
[    0.296423] clocksource: Switched to clocksource timer1
[    0.308408] NET: Registered protocol family 2
[    0.309492] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[    0.309537] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.309649] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.309758] TCP: Hash tables configured (established 8192 bind 8192)
[    0.309923] UDP hash table entries: 512 (order: 1, 8192 bytes)
[    0.309966] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[    0.310189] NET: Registered protocol family 1
[    0.310936] RPC: Registered named UNIX socket transport module.
[    0.310957] RPC: Registered udp transport module.
[    0.310968] RPC: Registered tcp transport module.
[    0.310977] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.312205] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.314005] Initialise system trusted keyrings
[    0.314410] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.321366] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.322373] NFS: Registering the id_resolver key type
[    0.322423] Key type id_resolver registered
[    0.322435] Key type id_legacy registered
[    0.322493] ntfs: driver 2.1.32 [Flags: R/O].
[    0.325616] Key type asymmetric registered
[    0.325642] Asymmetric key parser 'x509' registered
[    0.325735] bounce: pool size: 64 pages
[    0.325824] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.325842] io scheduler noop registered
[    0.325854] io scheduler deadline registered
[    0.326180] io scheduler cfq registered (default)
[    0.326197] io scheduler mq-deadline registered
[    0.326209] io scheduler kyber registered
[    0.329144] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.334131] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.334253] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.404083] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.409603] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[    1.047970] console [ttyS0] enabled
[    1.053033] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[    1.063299] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 32, base_baud = 3000000) is a 8250
[    1.074980] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.081451] random: fast init done
[    1.085126] random: crng init done
[    1.091310] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.098346] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.104948] OF: graph: no port node found in /ocp/lcdc@4830e000
[    1.110985] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.117654] [drm] No driver support for vblank timestamp query.
[    1.127511] Console: switching to colour frame buffer device 40x30
[    1.135332] tilcdc 4830e000.lcdc: fb0: DRM emulated frame buffer device
[    1.142757] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    1.167011] brd: module loaded
[    1.179437] loop: module loaded
[    1.187217] libphy: Fixed MDIO Bus: probed
[    1.266523] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.274234] libphy: 4a101000.mdio: probed
[    1.280775] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver TI DP83867
[    1.289222] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI DP83867
[    1.298722] cpsw 4a100000.ethernet: Detected MACID = 40:2e:71:d1:a4:3f
[    1.305452] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.312037] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.317406] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.325718] cpsw 4a100000.ethernet: cpsw: Detected MACID = 40:2e:71:d1:a4:41
[    1.334775] i2c /dev entries driver
[    1.341343] cpuidle: enable-method property 'ti,am3352' found operations
[    1.348795] sdhci: Secure Digital Host Controller Interface driver
[    1.355015] sdhci: Copyright(c) Pierre Ossman
[    1.360213]
[    1.360213]
[    1.360213]                           hey mad inside omap_hsmmc_probe
[    1.368788] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.6
[    1.399553]
[    1.399553]
[    1.399553]                           hey mad inside omap_hsmmc_probe
[    1.408130] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.6
[    1.439642] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.446706] ledtrig-cpu: registered to indicate activity on CPUs
[    1.463497] NET: Registered protocol family 10
[    1.470064] Segment Routing with IPv6
[    1.473883] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.481123] NET: Registered protocol family 17
[    1.486028] Key type dns_resolver registered
[    1.490923] omap_voltage_late_init: Voltage driver support not added
[    1.498566] Loading compiled-in X.509 certificates
[    1.507113] mmc1: new high speed MMC card at address 0001
[    1.524334] mmcblk1: mmc1:0001 Q2J55L 7.09 GiB
[    1.529870] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.537081] mmcblk1boot0: mmc1:0001 Q2J55L partition 1 16.0 MiB
[    1.543680] mmcblk1boot1: mmc1:0001 Q2J55L partition 2 16.0 MiB
[    1.550945] max9860 2-0010: Linked as a consumer to regulator.3
[    1.557503] mmcblk1rpmb: mmc1:0001 Q2J55L partition 3 4.00 MiB, chardev (244:0)
[    1.566884]  mmcblk1: p1 p2
[    1.588334] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
[    1.595618] max9860 2-0010: Linked as a consumer to regulator.4
[    1.603331] asoc-simple-card sound@0: max9860-hifi <-> 4803c000.mcasp mapping ok
[    1.610871] asoc-simple-card sound@0: ASoC: no DMI vendor name!
[    1.620861] asoc-simple-card sound: pcm5102a-hifi <-> 48038000.mcasp mapping ok
[    1.628348] asoc-simple-card sound: ASoC: no source widget found for OUT
[    1.635088] asoc-simple-card sound: ASoC: Failed to add route OUT -> direct -> Headphone Jack
[    1.643682] asoc-simple-card sound: ASoC: no DMI vendor name!
[    1.651888] hctosys: unable to open rtc device (rtc0)
[    1.657835] ALSA device list:
[    1.660830]   #0: MAX9860
[    1.663461]   #1: DSP
[    1.688151] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.696393] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.709309] devtmpfs: mounted
[    1.714291] Freeing unused kernel memory: 1024K
[    1.719619] Run /sbin/init as init process
[    1.944174] s1]: System time before build time, advancing clock.
[    1.981969] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.001570] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    2.024010] systemd[1]: Detected architecture arm.
[    2.077735] systemd[1]: Set hostname to <BEL-MVR>.
[    2.447276] s[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.474201] s1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.490630] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.507210] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.527513] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.545589] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    2.562929] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
ted Netached target Network. Boot/Shutdown.
ted Simple Network Management Protocol (SNMP) Daemon..ments.
[   21.102410] ii-tsc as /devices/platform/ocp/44e0d000.tscadc/TI-am335x-tsc.0.auto/input/input1cutable. Please remove executable permission bits. Proceeding anyway.
[   21.185387] Ploader does not support rtc-only!NMP) Daemon.... 60 sec
[   23.977883] roc remoteproc1: 4a334000.pru is available
[   24.026734] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[   24.072304] remoteproc remoteproc2: 4a338000.pru is available
[   24.096234] pc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
***************************************************************2
NOTICE: This file system contains the following GPLv3 packages:th realtime priority
        autoconfSave Screen Backlight�ightness of backlight:backlight...
[   10.5bash-devitialized pvr 1.17.4948957 20110701 for 56000000.sgx on minor 1
[   10.8bash4] remoteproc remoteproc0: wkup_m3 is available
[   10.8bc135] rproc remoteproc0: powering up wkup_m3rectory Watch.
[   10.8binutilsot get wkup_m3_ipc handle
[   10.9cifs-utils remoteproc0: Booting fw image am335x-pm-firmware.elf, size 242888
[  OK  ]cpiorted Load/Save Screen Backlight Brightness of backlight:backlight.
[  OK  ]cpp-symlinksget System Initialization.egistered for FTDI USB Serial Device
[  OK   cpparting Remount Root and Kernel File Systems...
[  OK  tdosfstoolsy Cleanup of Temporary Directories.
[  OK  ]elfutilsng on D-Bus System Message Bus Socket..
[   11.1findutilsup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
        g++-symlinkst and dump vmcore via kexec...ts: (null)
[   11.2g++36] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   11.2gawk0] net eth0: initializing cpsw version 1.12 (0)
[  OK  ]gcc-symlinksly rotation of log files.
[  OK  ]gccached target Timers.ctory (/tmp).
[  OK  ]gdbstening on RPCbind Server Activation Socket.
[   11.4gdbserver7 4a101000.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[  OK  ]gettexting on Avahi mDNS/DNS-SD Stack Activation Socket.
[   11.6glmark2IDRCONF(NETDEV_UP): eth0: link is not ready
[   11.6gstreamer1.0-libavple_card_utils: exports duplicate symbol asoc_simple_card_canonicalize_cpu (owned by kernel)
[  OK  egzip on dropbear.socket.ration File System...
[   11.ahidapiarget Sockets.card_utils: exports duplicate symbol asoc_simple_card_canonicalize_cpu (owned by kernel)
[  OK  ]libbfded target Basic System.es.
[   12.0libcairo-perf-utilsializing cpsw version 1.12 (0)
[   12.0libdw1 ssoc_simple_card_utils: exports duplicate symbol asoc_simple_card_canonicalize_cpu (owned by kernel)
        libelf1ng Permit User Sessions...ger...
[   12.1libgdbm-compat41000.mdio:01: attached PHY driver [TI DP83867] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL)
[  OK  ]libgdbm-devb spooling tools.
ted weston.service.und Card State._utils: exports duplicate symbol asoc_simple_card_canonicalize_cpu (owned by kernel)
ted busybox-udhcpd.service.m Check on /dev/mmcblk1p1.not ready
[  OK  ] Stopped Redis In-Memory Data Store.ith Light System Requirements...
[FAILED] Failed to start Redis In-Memory Data Store.ies...
See 'systemctl status redis.service' for details.
[  OK  ]libreadline7d/Save Random Seed.
[  OK  ]libunistring2te Volatile Files and Directories.
        m4-devinrk Service...
        m4tartinork Time Synchronization...
        makerting Update UTMP about System Boot/Shutdown...
[  OK   mavlink
    [][]   []    [][]ete     [][]
    [][]   []    [][]erf     [][]
        swig
        which
        ### ###  ##  ##  ##  ##        the list above
        ##   ##   ####   ##  ##       f another package you
        ##   ##    ##    ##  ##ependent packages.  You should
[   31.654472] scoredump[838]: Configuration file /etc/systemd/coredump.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[   31.846660] vbat: disabling
[   31.849514] lis3_reg: disabling
[   31.852672] v3v3: disabling
[  OK  ] Created slice system-systemd\x2dcoredump.slice.
root@BEL-MVR:~# [   73.570166] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   73.586530] PVR_K: SGX debug (SGX_DDK_Linux_XOrg sgxddk 1.17@4948957)
[   73.593190] PVR_K:(Error): SGX Register Base Address (Linear):   0x5efa2dfe
[   73.602277] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000
[   73.610055] PVR_K: Running SGXREG Debug Scripts:p1...
[   73.614876] PVR_K: (P0)Memory Data Store.
[   73.618404] PVR_K:  I(SGXREG) 0x00000000 : 0x00222220
[   73.623502] PVR_K: .s(SGXREG) 0x00000004 : 0x00110110
[   73.629568] PVR_K: ta(SGXREG) 0x00000118 : 0x00000008.
[   73.634710] PVR_K:  t(SGXREG) 0x0000012C : 0x20000000
[   73.640713] PVR_K: l (SGXREG) 0x000004E0 : 0x001E0808
[   73.645861] PVR_K:   (SGXREG) 0x000004E4 : 0x00000A04
[   73.651893] PVR_K:   (SGXREG) 0x00000658 : 0x00000000
[   73.657611] PVR_K:   (SGXREG) 0x00000A74 : 0x09BF8200
[   73.667225] PVR_K:   (SGXREG) 0x00000C04 : 0x00000000
[   73.672297] PVR_K:   (SGXREG) 0x00000C08 : 0x00000000
[   73.678392] PVR_K:   (SGXREG) 0x00000E04 : 0x00000000
[   73.687946] PVR_K:   (SGXREG) 0x00000624 : 0x00000200
[   73.701843] PVR_K:   (SGXREG) 0x00000628 : 0x000103ED
[   73.708126] PVR_K:   (SGXREG) 0x00000630 : 0x00000007
[   73.717309] PVR_K:   (SGXREG) 0x00000734 : 0x00000000
[   73.722390] PVR_K:   (SGXREG) 0x00000AA4 : 0xAAAAAAAB
[   73.728665] PVR_K:   (SGXREG) 0x00000AA8 : 0xAAAAAAAA
[   73.733776] PVR_K:   (SGXREG) 0x00000B08 : 0x0001EB63
[   73.739935] PVR_K:   (SGXREG) 0x00000B14 : 0x0001EC87
[   73.747139] PVR_K:   (SGXREG) 0x00000B0C : 0x0001064D
[   73.752181] PVR_K:   (SGXREG) 0x00000B18 : 0x00010459
[   73.762886] PVR_K:   (SGXREG) 0x00000B10 : 0x0000E9FF
[   73.768806] PVR_K:   (SGXREG) 0x00000B1C : 0x00010000
[   73.773981] PVR_K: SGX Register Dump:
[   73.778865] PVR_K: (P0) EUR_CR_CORE_ID:          01120000
[   73.784428] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010205
[   73.796567] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   73.802118] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   73.808762] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   73.814301] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00000000
[   73.820708] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   73.826329] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   73.832807] PVR_K: (P0) EUR_CR_CLKGATECTL:       00222220
[   73.841850] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      0030683C
[   73.848128] PVR_K:  Host Ctl flags= 00000006
[   73.852515] PVR_K: SGX Host control:
[   73.856137] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   73.866616] PVR_K:   (HC-10) 0x00000001 0x00000000 0x00000014 0x00030D40
[   73.873336] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000001 0x00000000
[   73.882875] PVR_K:   (HC-30) 0x00000000 0x0000DFD6 0xEF1678A0 0x00000000
[   73.891823] PVR_K:   (HC-40) 0x00000000 0x00000000 0x000004FE 0x00000000
[   73.901835] PVR_K: SGX TA/3D control:
[   73.905570] PVR_K:   (T3C-0) 0x0F003000 0x0F003140 0x0F002000 0x00000000
[   73.913646] PVR_K:   (T3C-10) 0x00000000 0x00000000 0x00000002 0x00000000
[   73.922886] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.930459] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.946583] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.953499] PVR_K:   (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.961642] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.970972] PVR_K:   (T3C-70) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.978600] PVR_K:   (T3C-80) 0x00000000 0x00000000 0x0F09D684 0x0F000000
[   73.985505] PVR_K:   (T3C-90) 0xBC9B8000 0x0F08DB40 0x00000000 0x0F09E840
[   73.993561] PVR_K:   (T3C-A0) 0x0F00AEA0 0x0F09D684 0x0F09E840 0x00000000
[   74.000998] PVR_K:   (T3C-B0) 0x00000000 0x00000000 0x00000000 0x00000000
[   74.008511] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000044 0x00000044
[   74.015592] PVR_K:   (T3C-D0) 0x0F000000 0x8000B000 0x8004B000 0x0F004000
[   74.041891] PVR_K:   (T3C-E0) 0x0F00A420 0x0F00A740 0x0F08B000 0x0F08B000
[   74.050237] PVR_K:   (T3C-F0) 0x00000000 0x0000035C 0x0000035C 0x00000000
[   74.057914] PVR_K:   (T3C-100) 0x00000001 0x00000000 0x00000000 0x00000000
[   74.064870] PVR_K:   (T3C-110) 0x1CF1BCC8 0x00000000 0x00000000 0x00000000
[   74.076590] PVR_K:   (T3C-120) 0x0F00AEA0 0x0F08DB40 0x00000000 0x00000000
[   74.083592] PVR_K: SGX Kernel CCB WO:0xC5 RO:0xC5
[   74.096589] PVR_K: Active syncs
[   74.099840] PVR_K:   SyncInfo 13:
[   74.103234] PVR_K:           Write ops (0x0d80120c): P/C = 35/34 (0x00000023/0x00000022)
[   74.112448] PVR_K:           Read ops (0x0d801214): P/C = 0/0 (0x00000000/0x00000000)
[   74.120386] PVR_K:           Read ops 2 (0x0d80121c): P/C = 0/0 (0x00000000/0x00000000)
[   74.131209] PVR_K:   SyncInfo 2:
[   74.141878] PVR_K:           Write ops (0x0d801054): P/C = 134/134 (0x00000086/0x00000086)
[   74.155027] PVR_K:           Read ops (0x0d80105c): P/C = 69/68 (0x00000045/0x00000044)
[   74.167125] PVR_K:           Read ops 2 (0x0d801064): P/C = 0/0 (0x00000000/0x00000000)
[   74.174649] PVR_K:   SyncInfo 0:
[   74.181212] PVR_K:           Write ops (0x0d801004): P/C = 69/68 (0x00000045/0x00000044)
[   74.189658] PVR_K:           Read ops (0x0d80100c): P/C = 0/0 (0x00000000/0x00000000)
[   74.201860] PVR_K:           Read ops 2 (0x0d801014): P/C = 0/0 (0x00000000/0x00000000)
root@BEL-MVR:~#
root@BEL-MVR:~#
root@BEL-MVR:~# [  127.826858] NET: Registered protocol family 15
[  128.091156] Initializing XFRM netlink socket
[  136.032861] Unable to handle kernel paging request at virtual address af1b0760
[  136.040158] pgd = 5106fd0a
[  136.042879] [af1b0760] *pgd=00000000
[  136.046489] Internal error: Oops: 80000005 [#1] PREEMPT ARM
[  136.052090] Modules linked in: xfrm_user xfrm4_tunnel ipcomp xfrm_ipcomp esp4 ah4 af_key xfrm_algo pru_rproc irq_pruss_intc pruss ti_am335x_adc ti_am335x_tsc pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc pvrsrvkm(O) omap_aes_driver crypto_engine pruss_soc_bus omap_crypto omap_sham ti_emif_sram rtc_omap ti_am335x_tscadc omap_wdt matrix_keypad matrix_keymap sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common cryptodev(O)
[  136.091117] CPU: 0 PID: 0 Comm: swapper Tainted: G           O      4.19.94-gbe5389fd85 #17
[  136.099507] Hardware name: Generic AM33XX (Flattened Device Tree)
[  136.105637] PC is at 0xaf1b0760
[  136.108792] LR is at 0xf08602fc
[  136.111947] pc : [<af1b0760>]    lr : [<f08602fc>]    psr: 200f0093
[  136.118241] sp : c0e01e80  ip : c0c607bc  fp : c0e01e94
[  136.123490] r10: ac236018  r9 : 000000a0  r8 : eed8e200
[  136.128739] r7 : eee360a0  r6 : 0000001f  r5 : 00000009  r4 : bf1b2240
[  136.135296] r3 : 80118758  r2 : c0e01e2c  r1 : ae89c000  r0 : 00000001
[  136.141858] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[  136.149114] Control: 10c5387d  Table: adfec019  DAC: 00000051
[  136.154887] Process swapper (pid: 0, stack limit = 0x646634dd)
[  136.160746] Stack: (0xc0e01e80 to 0xc0e02000)
[  136.165134] 1e80: 00000001 eed8e200 c0e01ea4 c0e01e98 c011f174 bf1b0710 c0e01eb4 c0e01ea8
[  136.173357] 1ea0: c010d0b4 c011f148 c0e01ecc c0e01eb8 c070fc40 c010d0a4 ffffe000 eed8e200
[  136.181579] 1ec0: c0e01f0c c0e01ed0 c070d664 c070fc00 000005b9 00000000 00000001 00000000
[  136.189802] 1ee0: 0043b888 ffffe000 eed8e200 c0e030b4 eee36000 c0e3f1b8 c0e03048 c0e030c8
[  136.198024] 1f00: c0e01f1c c0e01f10 c070d930 c070d5fc c0e01f2c c0e01f20 c015494c c070d920
[  136.206247] 1f20: c0e01f74 c0e01f30 c0154cf0 c0154930 00000002 00000001 c0bce3c8 c0e4d8a8
[  136.214470] 1f40: 00e4eec0 b1dce7c9 c0e01f6c c0e0e2e0 00000002 c0e03048 ffffffff c0e03040
[  136.222693] 1f60: c0e4eec0 c0d3da30 c0e01f84 c0e01f78 c015501c c0154b14 c0e01f9c c0e01f88
[  136.230915] 1f80: c092b084 c0155014 c0e4ef18 c0e4eec0 c0e01ff4 c0e01fa0 c0d00dbc c092afe0
[  136.239138] 1fa0: ffffffff ffffffff 00000000 c0d005dc 00000000 efffc740 00000000 c0d3da30
[  136.247361] 1fc0: b1d8f497 00000000 00000000 c0d00330 00000051 10c03c7d 00000e05 8fff3000
[  136.255583] 1fe0: 413fc082 10c53c7d 00000000 c0e01ff8 00000000 c0d009bc 00000000 00000000
[  136.263795] Backtrace:
[  136.266299] [<bf1b0704>] (am33xx_do_sram_idle [pm33xx]) from [<c011f174>] (amx3_idle_enter+0x38/0x48)
[  136.275563]  r5:eed8e200 r4:00000001
[  136.279166] [<c011f13c>] (amx3_idle_enter) from [<c010d0b4>] (arm_cpuidle_suspend+0x1c/0x20)
[  136.287657] [<c010d098>] (arm_cpuidle_suspend) from [<c070fc40>] (arm_enter_idle_state+0x4c/0x64)
[  136.296579] [<c070fbf4>] (arm_enter_idle_state) from [<c070d664>] (cpuidle_enter_state+0x74/0x300)
[  136.305579]  r5:eed8e200 r4:ffffe000
[  136.309176] [<c070d5f0>] (cpuidle_enter_state) from [<c070d930>] (cpuidle_enter+0x1c/0x20)
[  136.317485]  r10:c0e030c8 r9:c0e03048 r8:c0e3f1b8 r7:eee36000 r6:c0e030b4 r5:eed8e200
[  136.325350]  r4:ffffe000
[  136.327910] [<c070d914>] (cpuidle_enter) from [<c015494c>] (call_cpuidle+0x28/0x40)
[  136.335611] [<c0154924>] (call_cpuidle) from [<c0154cf0>] (do_idle+0x1e8/0x234)
[  136.342962] [<c0154b08>] (do_idle) from [<c015501c>] (cpu_startup_entry+0x14/0x18)
[  136.350572]  r10:c0d3da30 r9:c0e4eec0 r8:c0e03040 r7:ffffffff r6:c0e03048 r5:00000002
[  136.358438]  r4:c0e0e2e0
[  136.360994] [<c0155008>] (cpu_startup_entry) from [<c092b084>] (rest_init+0xb0/0xb4)
[  136.368790] [<c092afd4>] (rest_init) from [<c0d00dbc>] (start_kernel+0x40c/0x434)
[  136.376308]  r5:c0e4eec0 r4:c0e4ef18
[  136.379904] [<c0d009b0>] (start_kernel) from [<00000000>] (  (null))
[  136.386290] Code: bad PC value
[  136.389374] ---[ end trace aaaa5e71cc954ff9 ]---
[  136.394017] Kernel panic - not syncing: Attempted to kill the idle task!
[  136.400755] ---[ end Kernel panic - not syncing: Attempted to kill the idle task! ]---
Mad_hu
    Do all your production boards have this issue or only few of them? If latter, what is the ratio?
  • Hi Bin Liu
    I could see the issue in most of the boards around 70% have these issues. In some of them ,the crash is quite frequent i.e. during boot time only full kernel crashes and you cant use the board at all.
    In some of them, the crash happens during boot ,still you will be able use the board , but within 2-5 min they too will crash fully.
    Mad_hu
  • Hi Mad_hu,
    I am not sure what causes the failure, but can you please check the hardware? Maybe first check the PMIC and ensure all the power rails are all in the spec?
  • Hello Bin Liu,
    I have checked the hardware and especially PMIC, everything is as per the spec.
    Our prototypes are also with the same IC's , same PMIC and sequence of rails followed.
    Can you identify which module is crashing with the help of above logs?
    Mad_hu
  • Hello Bin Liu,
    Any update ?
    Mad_hu
  • Hi Mad_hu,
    I won't be able to tell which module causes the crash, but since the last log shows SGX driver failure, I recommend to first disable loading SGX drivers to see if the crash still happens.
    Please rename the SGX driver /lib/modules/$(uname -r)/extra/pvrsrvkm.ko to something else, so that kernel won't load it during boot.
  • Hello Bin Liu,
    I cannot rename the above said driver as it stops pvr and my QT app wont run without pvr.
    Still I have done it and my app didn't come up and display is black so I couldnt check any thing.
    What would you like to suggest further?
    Mad_hu
  • Hi Mad_hu,
    I understand the graphics app won't run without pvr. but does your board have uart port for the linux console so that you can log in to check the kernel log to see if the crash happens or not when pvrsrvkm.ko is not loaded? We just want to rule out if the crash is related to the pvr kernel driver.
  • Hello Bin Liu
    I have renamed that driver and still found the crashes in the kernel.
    Do you suggest something or do you need logs of current crash?
    Mad_hu
  • Hello Team
    This thread has been converted to resolved after I replied to the last conversation.
    Kindly revert it back.
    Mad_hu
  • Hi Mad_hu,
    There is no way to revert the "resolved" state of the thread. We can just ignore it and continue the discussion here.
    Is my understanding correct that you have two types of boards - prototype and production boards. With the same SDK sw build, the prototype boards don't have any issue, but "about 70%" of production boards crash in Linux boot? I think we need to first understand whether this is hw or sw issue.
  • Hi Bin Liu
    Your understanding is correct.
    Mad_hu
  • Hi Mad_hu,
    Then it sound the issue is hardware/board related, or assembly related since not all production boards have the issue. I would recommend to focus on probing the board.
  • Hello Bin Liu,
    As on date we have around 50 boards fully integrated and around 45-47 are having similar issue. The only difference I found is certain boards they get this crash quite frequent. Remaining boards they crash one in a couple of hours.
    As per your suggestion I am ready to probe the boards .
    Also I have done some preliminary investigation before approaching you. I couldn't find any.
    The only thing I could sense is that the issue might be with
    1)Batch issue with either processor or DDR
    2)Assembly issue with either processor or DDR.
    As these two components are BGA , I couldn't probe them deeply.
    As far as DDR is concerned , I have done both EDMA and Data_Transfer tests available in code-composer and both of them are success.
    If my direction of investigation is wrong or am I missing something ,Kindly point it out.
    If you want me to probe something else I am ready to do it.
    Mad_hu
  • Hi Mad_hu,
    I am a sw guy and won't be able to provide further guidance on board issues. Let me route your query to our hw experts for comments on board diagnosis.
  • Hello Bin Liu,
    Kindly assure that the HW guy responds fast as my production is under halt.
    Mad_hu
  • Are you attempting to boot from the eMMC device?  If so, do you have another boot source to try, preferably the one you used on your proto board?
    On a working board, can you run memtester from the kernel prompt.  This will help determine if you have any marginality in your DDR configuration.
    Are you using the same DDR configuration (from the spreadsheet) as on the prototype board?  Is the DDR design on the prototype board the same as on the production board (including layout, stackup, trace lengths, memory used, etc.)?  If not, you will have to use the spreadsheet to generate the DDR configuration for the production board.
    James
  • Hello James,
    I have extensively used SD card as boot-device in my proto and now also I am trying with it in my production boards along with the eMMC.
    Kernel prompt means which point of time you wanted this? During u-boot or after full boot?
    There are no changes in the layout , part number etc from proto to production. I didn't change any. As I said earlier I have run DDR tests available in CCS for every board to assure my length matching is working fine
    Mad_hu
  • You should be able to run memtester after a full boot, at the kernel prompt.  Can you post a boot log failure with eMMC removed?
    James
  • Hello James,
    I have run memtester on both the boards i.e old working and new failing boards.
    Old boards are passing even for a 800MB test. Where as the new board is having bunch of failures for even a 100MB test.
    Kindly find the attached logs .
    1768.memtester_new_1.txt
    root@BEL-MVR:~# memtester 100 2
    memtester version 4.3.0 (32-bit)
    Copyright (C) 2001-2012 Charles Cazabon.
    Licensed under the GNU General Public License version 2 (only).
    pagesize is 4096
    pagesizemask is 0xfffff000
    want 100MB (104857600 bytes)
    got  100MB (104857600 bytes), trying mlock ...locked.
    Loop 1/2:
      Stuck Address       : ok
      Random Value        : ok
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Sequential Increment: ok
      Solid Bits          : ok
      Block Sequential    : ok
      Checkerboard        : ok
      Bit Spread          : ok
      Bit Flip            : ok
      Walking Ones        : ok
      Walking Zeroes      : ok
    Loop 2/2:
      Stuck Address       : ok
      Random Value        : ok
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Solid Bits          : ok
      Checkerboard        : ok
      Bit Spread          : ok
      Bit Flip            : ok
      Walking Ones        : ok
      Walking Zeroes      : ok
    Done.
    root@BEL-MVR:~#memtester 800 2
    pagesize is 4096
    want 800MB (838860800 bytes)
    got  800MB (838860800 bytes), trying mlock ...locked.
    Loop 1/2:
      Stuck Address       : ok
      Random Value        : ok
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Solid Bits          : ok
      Checkerboard        : ok
      Bit Spread          : ok
      Bit Flip            : ok
      Walking Ones        : ok
      Walking Zeroes      : ok
    Loop 2/2:
      Stuck Address       : ok
      Random Value        : ok
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Solid Bits          : ok
      Checkerboard        : ok
      Bit Spread          : ok
      Bit Flip            : ok
      Walking Ones        : ok
      Walking Zeroes      : ok
    Done.
    root@BEL-MVR:~#
    Mad_hu
  • Your logs are showing full failures in 4KB blocks, indicating some addressing issue, possibly some cross talk or corruption on the addressing signals.  Can you double check any differences in layout, including stackup, reference layers, trace spacing, etc.  Please double check all layout guidelines in the datasheet, especially those in table 5-58 concerning the CK and ADDR_CTRL routing specifications.  Do you have the ability to measure power supply noise on the IO supply with high bandwidth scope probes?
    REgards,
    James
  • Hello James,
    Stackup may have slight variation , not huge (Due to the change in the fabricator). But trace spacing and guidelines are same for the old and new boards.
    I have one more observation with respect to the DDR tests.
    I understood that we are either unable to write properly to DDR or unable to read properly from DDR. Hence we are continuously failing.
    If this is the case how are we passing the DDR Tests in CCS. So , I opened and cross checked the tests in GEL file. The test is for a small iteration of 250 times and even we are writing/reading a single value. So,even if the swap happens also we wouldn't be able to know.
    I have modified the start address , number of iterations , and values to read/write operations to 6 different values.I have observed that the test is till passing.
    It means we are comfortably able to write 6 different values to 6 different locations and also able to read those 6 different values correctly for large memory loactions.
    Now my question is why we are not able to replicate the same with the Linux and U-boot. Are we missing something or Is my understanding wrong?
    One more observation is that memtester for 100MB takes almost 25-30min where as the DDR_DATA_Transfer_Check from CCS for 100MB takes hours together to complete. How are these both different?
    One surprising thing is even it takes long time, it passes.But memtester is failing. How come a test pass when using CCS and fail using memtester?If layout is an issue how come it pass through CCS?
    Mad_hu
  • Madhu, the CCS tests are inherently slower, typically single access tests.  Memtester and u-boot operate with cache and MMU enabled, so these tests can stress the DDR interface much better.  This is probably the reason you are seeing the difference in the tests.  The linux tests will perform more switching and bursting access which can reveal more issues with signal integrity and timing margins.
    James
  • Hello James,
    I have changed the DDR speed form 400Mhz to 303Mhz and the issue seems to be resolved . Now multiple PCBS are passing the memtester and OS crash is not observed for the last 2-3 days.
    However strict endurance is not tested. i.e. continuous operation for more than 48hrs.
    What can be our next plan of action? Shall we restrict ourselves with 303 or debug and identify why 400 is not working for new set of boards?
    Mad_hu
  • Ok, at least you can continue your software development at lower speeds with the new boards.  It is up to you if you want to continue to debug, i can assist as much as possible.  There could be a number of issues that could result in the behavior you are seeing, including timing issues or board related design issues.
    First, let's start with the DDR configuration.  On a failing board at 400MHz, can you run the following DSS script using JTAG:
    https://git.ti.com/cgit/sitara-dss-files/am335x-dss-files/tree/am335x-ddr-analysis.dss
    Instructions for running this scripts are here:  https://git.ti.com/cgit/sitara-dss-files/am335x-dss-files/tree/README
    Can you also send the spreadsheet that was used and a register dump of the DDR controller and PHY  (0x4c000000-0x4c000120)
    James
