TDA4VM: Our custom TDA4VM board boot error using SDK 8.0
Part Number: TDA4VM
Our custom TDA4VM board boot error using SDK 8.0, the UART log is below:
the log is like the log of "run_app_multi_cam" program crash.
U-Boot SPL 2021.01-g53e79d0e89 (Aug 04 2021 - 23:32:00 +0000)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed 1
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.5(release):08.00.00.004-dirty
NOTICE: BL31: Built : 22:30:09, Aug 4 2021
U-Boot SPL 2021.01-dirty (Aug 30 2021 - 18:10:17 +0800)
U-Boot 2021.01-dirty (Aug 30 2021 - 18:10:17 +0800)
SoC: J721E SR2.0
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
eth0: ethernet@46000000
Hit any key to stop autoboot: 0
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
483 bytes read in 8 ms (58.6 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 7 ms (0 Bytes/s)
Already setup.
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
2514108 bytes read in 114 ms (21 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 2514108 bytes: Success!
527284 bytes read in 32 ms (15.7 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 527284 bytes: Success!
109312 bytes read in 15 ms (6.9 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 109312 bytes: Success!
Load Remote Processor 5 with data@addr=0x82000000 109312 bytes: Success!
1579120 bytes read in 72 ms (20.9 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1579120 bytes: Success!
1579120 bytes read in 73 ms (20.6 MiB/s)
Load Remote Processor 7 with data@addr=0x82000000 1579120 bytes: Success!
10399728 bytes read in 184 ms (53.9 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 10399728 bytes: Success!
19137024 bytes read in 798 ms (22.9 MiB/s)
98098 bytes read in 13 ms (7.2 MiB/s)
10737 bytes read in 9 ms (1.1 MiB/s)
Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.41-g4c2eade9f7 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Aug 4 22:47:28 UTC 2021
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x00000000fc000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Failed to reserve 512 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=6f16bc9e-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
[ 0.000000] Memory: 2319360K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 1874944K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008a00b0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000
[ 0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008384] Console: colour dummy device 80x25
[ 0.012949] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023620] pid_max: default: 32768 minimum: 301
[ 0.028369] LSM: Security Framework initializing
[ 0.033125] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.040702] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.049833] rcu: Hierarchical SRCU implementation.
[ 0.054911] Platform MSI: msi-controller@1820000 domain created
[ 0.061183] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070486] EFI services will not be available.
[ 0.075276] smp: Bringing up secondary CPUs ...
[ 0.080577] Detected PIPT I-cache on CPU1
[ 0.080604] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.080615] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000
[ 0.080652] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.080713] smp: Brought up 1 node, 2 CPUs
[ 0.110060] SMP: Total of 2 processors activated.
[ 0.114865] CPU features: detected: 32-bit EL0 Support
[ 0.120119] CPU features: detected: CRC32 instructions
[ 0.134755] CPU: All CPU(s) started at EL2
[ 0.138951] alternatives: patching kernel code
[ 0.144051] devtmpfs: initialized
[ 0.152729] KASLR disabled due to lack of seed
[ 0.157410] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.167373] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.174532] pinctrl core: initialized pinctrl subsystem
[ 0.180104] DMI not present or invalid.
[ 0.184361] NET: Registered protocol family 16
[ 0.189166] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.196526] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.204514] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.212808] thermal_sys: Registered thermal governor 'step_wise'
[ 0.212810] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.219240] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.232873] ASID allocator initialised with 65536 entries
[ 0.252665] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.259522] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.266279] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.274173] cryptd: max_cpu_qlen set to 1000
[ 0.280415] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.289254] vsys_3v3: supplied by evm_12v0
[ 0.293590] vsys_5v0: supplied by evm_12v0
[ 0.298237] iommu: Default domain type: Translated
[ 0.303443] SCSI subsystem initialized
[ 0.307550] mc: Linux media interface: v0.10
[ 0.311922] videodev: Linux video capture interface: v2.00
[ 0.317553] pps_core: LinuxPPS API ver. 1 registered
[ 0.322624] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.331961] PTP clock support registered
[ 0.335979] EDAC MC: Ver: 3.0.0
[ 0.339765] FPGA manager framework
[ 0.343280] Advanced Linux Sound Architecture Driver Initialized.
[ 0.349936] clocksource: Switched to clocksource arch_sys_counter
[ 0.356381] VFS: Disk quotas dquot_6.6.0
[ 0.360446] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.370273] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.376577] NET: Registered protocol family 2
[ 0.381218] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[ 0.389882] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.398665] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[ 0.406863] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[ 0.414685] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.421457] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.428351] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.435765] NET: Registered protocol family 1
[ 0.440514] RPC: Registered named UNIX socket transport module.
[ 0.446571] RPC: Registered udp transport module.
[ 0.451386] RPC: Registered tcp transport module.
[ 0.456190] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462775] PCI: CLS 0 bytes, default 64
[ 0.467147] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.477737] Initialise system trusted keyrings
[ 0.482386] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[ 0.490756] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.496999] NFS: Registering the id_resolver key type
[ 0.502187] Key type id_resolver registered
[ 0.506458] Key type id_legacy registered
[ 0.510577] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.517425] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.525103] 9p: Installing v9fs 9p2000 file system support
[ 0.550347] Key type asymmetric registered
[ 0.554534] Asymmetric key parser 'x509' registered
[ 0.559535] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.567094] io scheduler mq-deadline registered
[ 0.571719] io scheduler kyber registered
[ 0.576916] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.583098] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.591367] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.597636] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.605490] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.613571] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.623600] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[ 0.634658] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[ 0.642915] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.656101] brd: module loaded
[ 0.662290] loop: module loaded
[ 0.665831] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[ 0.673758] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.41-g4c2eade9f7 #1
[ 0.680958] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 0.686913] Call trace:
[ 0.689416] dump_backtrace+0x0/0x1a0
[ 0.693153] show_stack+0x18/0x68
[ 0.696538] dump_stack+0xd0/0x12c
[ 0.700009] sysfs_warn_dup+0x60/0x80
[ 0.703743] sysfs_create_dir_ns+0xe0/0xf8
[ 0.707924] kobject_add_internal+0x98/0x288
[ 0.712280] kobject_add+0x94/0x100
[ 0.715843] device_add+0xe0/0x748
[ 0.719311] platform_device_add+0x100/0x238
[ 0.723669] platform_device_register_full+0xcc/0x150
[ 0.728827] dma_buf_phys_init+0x6c/0x9c
[ 0.732828] do_one_initcall+0x54/0x1b8
[ 0.736742] kernel_init_freeable+0x1d4/0x23c
[ 0.741189] kernel_init+0x14/0x114
[ 0.744746] ret_from_fork+0x10/0x34
[ 0.748402] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
[ 0.761576] megasas: 07.714.04.00-rc1
[ 0.766482] libphy: Fixed MDIO Bus: probed
[ 0.771119] tun: Universal TUN/TAP device driver, 1.6
[ 0.776531] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.782944] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.789017] sky2: driver version 1.30
[ 0.793286] VFIO - User Level meta-driver version: 0.3
[ 0.798962] i2c /dev entries driver
[ 0.803086] sdhci: Secure Digital Host Controller Interface driver
[ 0.809402] sdhci: Copyright(c) Pierre Ossman
[ 0.814012] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.820285] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.826604] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.833715] optee: probing for conduit method.
[ 0.838271] optee: revision 3.12 (3d47a131)
[ 0.838540] optee: initialized driver
[ 0.847887] NET: Registered protocol family 17
[ 0.852510] 9pnet: Installing 9P2000 support
[ 0.856901] Key type dns_resolver registered
[ 0.861388] Loading compiled-in X.509 certificates
[ 0.870393] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.876729] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.884717] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[ 0.914610] random: fast init done
[ 0.939584] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.947305] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.953425] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.959527] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.965759] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.972586] pca953x 3-0020: using no AI
[ 0.997978] pca953x 3-0020: failed writing register
[ 1.003022] pca953x: probe of 3-0020 failed with error -121
[ 1.008899] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 1.015697] pca953x 3-0022: using AI
[ 1.019397] pca953x 3-0022: failed writing register
[ 1.024422] pca953x: probe of 3-0022 failed with error -121
[ 1.030161] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.036263] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.042401] pca953x 5-0020: supply vcc not found, using dummy regulator
[ 1.049219] pca953x 5-0020: using no AI
[ 1.073981] pca953x 5-0020: failed writing register
[ 1.079011] pca953x: probe of 5-0020 failed with error -121
[ 1.084966] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.091044] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[ 1.097021] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[ 1.103441] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.113428] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.122235] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.132084] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.150459] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 1.160341] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.167101] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.176193] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 1.186358] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.193118] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.201143] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 1.210545] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 26, base_baud = 3000000) is a 8250
[ 1.219291] printk: console [ttyS2] enabled
[ 1.227729] printk: bootconsole [ns16550a0] disabled
[ 1.238193] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 27, base_baud = 3000000) is a 8250
[ 1.247135] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 28, base_baud = 3000000) is a 8250
[ 1.297940] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.305590] libphy: 46000f00.mdio: probed
[ 1.310986] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.319291] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 1.333345] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 1.342271] mmc0: CQHCI version 5.10
[ 1.346132] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 1.357808] vdd_mmc1: supplied by vsys_3v3
[ 1.362711] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 1.369568] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 1.376397] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 1.381943] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 1.390412] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 1.397237] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 1.407080] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 1.417315] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[ 1.428031] Unable to handle kernel paging request at virtual address ffd9000822ff4d80
[ 1.435956] Mem abort info:
[ 1.438739] ESR = 0x96000004
[ 1.441781] EC = 0x25: DABT (current EL), IL = 32 bits
[ 1.447078] SET = 0, FnV = 0
[ 1.450121] EA = 0, S1PTW = 0
[ 1.453248] Data abort info:
[ 1.456117] ISV = 0, ISS = 0x00000004
[ 1.459940] CM = 0, WnR = 0
[ 1.462897] [ffd9000822ff4d80] address between user and kernel address ranges
[ 1.470015] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 1.475569] Modules linked in:
[ 1.478616] CPU: 1 PID: 25 Comm: kworker/1:1 Not tainted 5.10.41-g4c2eade9f7 #1
[ 1.485903] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 1.491729] Workqueue: events deferred_probe_work_func
[ 1.496853] pstate: a0000005 (NzCv daif -PAN -UAO -TCO BTYPE=--)
[ 1.502844] pc : __kmalloc_track_caller+0x100/0x610
[ 1.507706] lr : __kmalloc_track_caller+0x48/0x610
[ 1.512479] sp : ffff800011b4fa00
[ 1.515779] x29: ffff800011b4fa00 x28: ffff800011131000
[ 1.521075] x27: ffff000820312a00 x26: ffff000820312a00
[ 1.526371] x25: 000000000010c501 x24: ffff000820312a00
[ 1.531667] x23: ffff800011134000 x22: ffff00082001fd00
[ 1.536963] x21: 0000000000000000 x20: ffd9000822ff4d00
[ 1.542259] x19: 0000000000000dc0 x18: 0140000000000000
[ 1.547555] x17: 0000000000000000 x16: 0000000000000000
[ 1.552851] x15: ffff800011280000 x14: 0000000047050000
[ 1.558146] x13: 00000000000002c7 x12: ffff00087fff0008
[ 1.563442] x11: ffff800012a70000 x10: ffff000820370440
[ 1.568737] x9 : 0000000000000000 x8 : ffff000822f5eb00
[ 1.574033] x7 : 0000000000000000 x6 : ffff000822f5e9b0
[ 1.579329] x5 : 0003000005000000 x4 : 0000000000000000
[ 1.584625] x3 : 000000000010c501 x2 : ffffffe001e8be40
[ 1.589920] x1 : 0000000000000080 x0 : 0000000000000001
[ 1.595217] Call trace:
[ 1.597651] __kmalloc_track_caller+0x100/0x610
[ 1.602167] devres_alloc_node+0x40/0xa0
[ 1.606079] __devm_ioremap+0x40/0x118
[ 1.609813] __devm_ioremap_resource+0xa8/0x1a0
[ 1.614326] devm_ioremap_resource+0x14/0x20
[ 1.618582] cqspi_probe+0x188/0x9e8
[ 1.622143] platform_drv_probe+0x54/0xa8
[ 1.626138] really_probe+0xe4/0x3b0
[ 1.629699] driver_probe_device+0x58/0xb8
[ 1.633780] __device_attach_driver+0x84/0xc8
[ 1.638121] bus_for_each_drv+0x78/0xc8
[ 1.641941] __device_attach+0xf0/0x150
[ 1.645762] device_initial_probe+0x14/0x20
[ 1.649929] bus_probe_device+0x9c/0xa8
[ 1.653749] deferred_probe_work_func+0x88/0xc0
[ 1.658268] process_one_work+0x1a0/0x328
[ 1.662261] worker_thread+0x1f8/0x420
[ 1.665996] kthread+0x140/0x160
[ 1.669213] ret_from_fork+0x10/0x34
[ 1.672776] Code: 540024c0 b9402ac1 b9401360 11000400 (f8616a9c)
[ 1.678852] ---[ end trace 77e4f7ba96d1c3e8 ]---
[ 1.683462] Unable to handle kernel paging request at virtual address ff9b000820ff6290
[ 1.691360] Mem abort info:
[ 1.694142] ESR = 0x96000004
[ 1.697183] EC = 0x25: DABT (current EL), IL = 32 bits
[ 1.702479] SET = 0, FnV = 0
[ 1.705519] EA = 0, S1PTW = 0
[ 1.708648] Data abort info:
[ 1.711517] ISV = 0, ISS = 0x00000004
[ 1.715340] CM = 0, WnR = 0
[ 1.718297] [ff9b000820ff6290] address between user and kernel address ranges
[ 1.725413] Internal error: Oops: 96000004 [#2] PREEMPT SMP
[ 1.730967] Modules linked in:
[ 1.734009] CPU: 1 PID: 25 Comm: kworker/1:1 Tainted: G D 5.10.41-g4c2eade9f7 #1
[ 1.742681] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 1.748499] Workqueue: events deferred_probe_work_func
[ 1.753620] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
[ 1.759609] pc : load_balance+0x12c/0xce0
[ 1.763604] lr : load_balance+0xbc/0xce0
[ 1.767510] sp : ffff80001138fcf0
[ 1.770810] x29: ffff80001138fcf0 x28: ffff800011133b60
[ 1.776106] x27: 0000000000000001 x26: ffff800010fbb040
[ 1.781402] x25: 0000000000000000 x24: ffff800011133a30
[ 1.786698] x23: ffff800011133c48 x22: ffff000820043c00
[ 1.791993] x21: 0000000000000001 x20: 00000000ffffffff
[ 1.797289] x19: ff9b000820ff6280 x18: 0000000000000010
[ 1.802585] x17: 0000000000000000 x16: 0000000000000000
[ 1.807880] x15: 00000218b07a5b80 x14: 0000000000000000
[ 1.813176] x13: 000000000000018e x12: 0000000000000000
[ 1.818472] x11: 0000000000000000 x10: 00000000000000ec
[ 1.823767] x9 : ffff000820043c00 x8 : 0000000000000004
[ 1.829063] x7 : 0000000000000000 x6 : 0000000000000003
[ 1.834359] x5 : 0000000000000000 x4 : 0000000000000004
[ 1.839654] x3 : 0000000000000100 x2 : ffff00087fa81978
[ 1.844950] x1 : ffff800010fbb040 x0 : 0000000000000001
[ 1.850246] Call trace:
[ 1.852680] load_balance+0x12c/0xce0
[ 1.856327] rebalance_domains+0x290/0x390
[ 1.860408] run_rebalance_domains+0x4c/0x78
[ 1.864661] efi_header_end+0x120/0x268
[ 1.868484] irq_exit+0xc0/0xe0
[ 1.871611] __handle_domain_irq+0x68/0xc0
[ 1.875694] gic_handle_irq+0x58/0x128
[ 1.879428] el1_irq+0xcc/0x180
[ 1.882559] _raw_spin_unlock_irqrestore+0xc/0x48
[ 1.887248] die_kernel_fault+0x64/0x78
[ 1.891070] __do_kernel_fault+0x74/0x150
[ 1.895063] do_bad_area+0x5c/0x68
[ 1.898450] do_translation_fault+0x38/0x68
[ 1.902618] do_mem_abort+0x40/0xa0
[ 1.906094] el1_abort+0x48/0x70
[ 1.909308] el1_sync_handler+0xac/0xc8
[ 1.913129] el1_sync+0x88/0x140
[ 1.916343] __kmalloc_track_caller+0x100/0x610
[ 1.920857] devres_alloc_node+0x40/0xa0
[ 1.924765] __devm_ioremap+0x40/0x118
[ 1.928499] __devm_ioremap_resource+0xa8/0x1a0
[ 1.933012] devm_ioremap_resource+0x14/0x20
[ 1.937266] cqspi_probe+0x188/0x9e8
[ 1.940827] platform_drv_probe+0x54/0xa8
[ 1.944820] really_probe+0xe4/0x3b0
[ 1.948380] driver_probe_device+0x58/0xb8
[ 1.952461] __device_attach_driver+0x84/0xc8
[ 1.956802] bus_for_each_drv+0x78/0xc8
[ 1.960623] __device_attach+0xf0/0x150
[ 1.964443] device_initial_probe+0x14/0x20
[ 1.968611] bus_probe_device+0x9c/0xa8
[ 1.972431] deferred_probe_work_func+0x88/0xc0
[ 1.976946] process_one_work+0x1a0/0x328
[ 1.980941] worker_thread+0x1f8/0x420
[ 1.984676] kthread+0x140/0x160
[ 1.987890] ret_from_fork+0x10/0x34
[ 1.991452] Code: 54000240 b000855c 912d839c 12800014 (f9400a61)
[ 1.997531] ---[ end trace 77e4f7ba96d1c3e9 ]---
[ 2.002133] Kernel panic - not syncing: Oops: Fatal exception in interrupt
[ 2.008987] SMP: stopping secondary CPUs
[ 2.012899] Kernel Offset: disabled
[ 2.016374] CPU features: 0x0040022,20006008
[ 2.020628] Memory Limit: none
[ 2.023671] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Running uenvcmd ...
Already setup.
Starting kernel ...
