PROCESSOR-SDK-J7200: About DRA821U R5F Run MCUSW Demo + A72 Boot Linux
Part Number: PROCESSOR-SDK-J7200
Hi TI,
How can I store the R5F image files, LINUX Kernel and rootfs in EMMC, and then start each cores to run the demo?
The following is the expected running demo
MCU domain R5F: lockstep mode, running MCUSW(can_app)
Main domain R5F MCU2_0: MCUSW (adc_app)
Main domain R5F MCU2_1: MCUSW (dio_app)
Main domain A72: boot Linux kernel + rootfs
There are already MCUSW app image files and an SD card that can boot Linux
How to complete the above requirements and what are the steps?
    https://e2e.ti.com/support/processors/f/791/p/886615/3330218#3330218
    Lists out the steps to get the entire file system into eMMC.
    Are you able to accomplish using SD card?
    - Keerthy
    I have used the steps listed, but I am still unable to use eMMC boot successfully.
    Following the steps described in the link, I can create an SD card for booting Linux.
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-j7200/08_00_00_05/exports/docs/j7200/linux/Overview/Processor_SDK_Linux_Formatting_SD_Card.html#partitioning-sd-card
    please help, thank you.
    The following is the error message log
    => boot
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    ** Unrecognized filesystem type **
    ## Error: "check_android" not defined
    ## Error: "emmc_android_boot" not defined
    ** Invalid partition 2 **
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    libfdt fdt_check_header(): FDT_ERR_BADMAGIC
    No FDT memory address configured. Please configure
    the FDT address via "fdt addr <address>" command.
    Aborting!
    Bad Linux ARM64 Image magic!
    Flash bootloader binaries log:
    root@j7200-evm:/# reboot
             Stopping Session c1 of user root.
    [  OK  ] Stopped target Multi-User System.
    [  OK  ] Stopped target Login Prompts.
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target Timers.
    [  OK  ] Stopped Daily rotation of log files.
    [  OK  ] Stopped Daily Cleanup of Temporary Directories.
    [  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Stopping Job spooling tools...
             Stopping Avahi mDNS/DNS-SD Stack...
             Stopping Periodic Command Scheduler...
             Stopping Docker Application Container Engine...
             Stopping Ethernet Bridge Filtering Tables...
             Stopping Getty on tty1...
             Stopping irqbalance daemon...
             Stopping Reboot and dump vmcore via kexec...
             Stopping NFS status monitor for NFSv2/3 locking....
             Stopping Telephony service...
             Stopping Serial Getty on ttyS2...
             Stopping Serial Getty on ttyS3...
             Stopping Simple Network Ma…ent Protocol (SNMP) Daemon....
             Stopping strongSwan IPsec …Ev2 daemon using ipsec.conf...
             Stopping System Logger Daemon "default" instance...
    [  OK  ] Stopped File System Check on /dev/mmcblk0p1.
    [  OK  ] Stopped File System Check on /dev/mmcblk1p1.
    [  OK  ] Removed slice system-systemd\x2dfsck.slice.
             Stopping Load/Save Random Seed...
             Stopping thermal-zone-init.service...
             Stopping Vsftpd ftp daemon...
    [  OK  ] Stopped Job spooling tools.
    [  OK  ] Stopped Periodic Command Scheduler.
    [  OK  ] Stopped irqbalance daemon.
    [  OK  ] Stopped Telephony service.
    [  OK  ] Stopped System Logger Daemon "default" instance.
    [  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
    [  OK  ] Stopped NFS status monitor for NFSv2/3 locking..
    [  OK  ] Stopped Vsftpd ftp daemon.
    [  OK  ] Stopped Getty on tty1.
    [  OK  ] Stopped Serial Getty on ttyS2.
    [  OK  ] Stopped Serial Getty on ttyS3.
    [  OK  ] Stopped strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
    [  OK  ] Stopped Ethernet Bridge Filtering Tables.
    [  OK  ] Stopped Reboot and dump vmcore via kexec.
    [  OK  ] Stopped Load/Save Random Seed.
    [  OK  ] Stopped thermal-zone-init.service.
    [  OK  ] Stopped Session c1 of user root.
    [  OK  ] Removed slice system-getty.slice.
    [  OK  ] Removed slice system-serial\x2dgetty.slice.
    [  OK  ] Removed slice system-syslog\x2dng.slice.
             Stopping LSB: start and stop docker...
             Stopping LSB: network benchmark...
             Stopping syslog.service...
             Stopping Login Service...
             Stopping User Manager for UID 0...
    [  OK  ] Stopped LSB: network benchmark.
    [  OK  ] Stopped syslog.service.
    [  OK  ] Stopped target Host and Network Name Lookups.
    [  OK  ] Stopped target System Time Synchronized.
    [  OK  ] Stopped target System Time Set.
    [  OK  ] Stopped Login Service.
    [  OK  ] Stopped User Manager for UID 0.
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Stopped LSB: start and stop docker.
    [  OK  ] Unmounted /run/user/0.
    [  OK  ] Stopped Docker Application Container Engine.
    [  OK  ] Stopped Simple Network Man…ement Protocol (SNMP) Daemon..
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [  OK  ] Removed slice User Slice of UID 0.
    [  OK  ] Stopped target Network is Online.
             Stopping D-Bus System Message Bus...
             Stopping Permit User Sessions...
             Stopping telnetd.service...
    [  OK  ] Stopped D-Bus System Message Bus.
    [  OK  ] Stopped Permit User Sessions.
    [  OK  ] Stopped telnetd.service.
    [  OK  ] Stopped target Network.
    [  OK  ] Stopped target Remote File Systems.
             Stopping Network Name Resolution...
    [  OK  ] Stopped Network Name Resolution.
             Stopping Network Service...
    [  OK  ] Stopped Network Service.
    [  OK  ] Stopped target Network (Pre).
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Paths.
    [  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
    [  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
    [  OK  ] Stopped target Slices.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Sockets.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed D-Bus System Message Bus Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Stopped target System Initialization.
             Stopping Hardware RNG Entropy Gatherer Daemon...
    [  OK  ] Stopped Apply Kernel Variables.
    [  OK  ] Stopped Load Kernel Modules.
             Stopping Network Time Synchronization...
    [  OK  ] Stopped Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Stopped Network Time Synchronization.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting /media/ram...
             Unmounting Temporary Directory (/tmp)...
             Unmounting /var/volatile...
    [  OK  ] Unmounted /media/ram.
    [  OK  ] Unmounted Temporary Directory (/tmp).
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Local File Systems (Pre).
    [  OK  ] Stopped target Swap.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Reached target Shutdown.
    [  OK  ] Reached target Final Step.
    [  OK  ] Started Reboot.
    [  OK  ] Reached target Reboot.
    [  942.983551] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [  942.990490] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [  942.997386] watchdog: watchdog0: watchdog did not stop!
    [  943.018937] systemd-shutdown[1]: Syncing filesystems and block devices.
    [  943.229014] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [  943.242834] systemd-journald[156]: Received SIGTERM from PID 1 (systemd-shutdow).
    [  943.261037] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [  943.270799] systemd-shutdown[1]: Hardware watchdog 'K3 RTI Watchdog', version 0
    [  943.279596] systemd-shutdown[1]: Unmounting file systems.
    [  943.286898] [1846]: Remounting '/' read-only in with options '(null)'.
    [  943.383421] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [  943.394759] systemd-shutdown[1]: All filesystems unmounted.
    [  943.400366] systemd-shutdown[1]: Deactivating swaps.
    [  943.405433] systemd-shutdown[1]: All swaps deactivated.
    [  943.410667] systemd-shutdown[1]: Detaching loop devices.
    [  943.418464] systemd-shutdown[1]: All loop devices detached.
    [  943.424057] systemd-shutdown[1]: Detaching DM devices.
    [  943.429390] systemd-shutdown[1]: All DM devices detached.
    [  943.434793] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
    [  943.450085] systemd-shutdown[1]: Syncing filesystems and block devices.
    [  943.456872] systemd-shutdown[1]: Rebooting.
    [  943.484293] reboot: Restarting system
    U-Boot SPL 2021.01-g53e79d0e89 (Aug 07 2021 - 08:12:48 +0000)
    Model: Texas Instruments K3 J7200 SoC
    Board: J7200X-PM2-SOM rev E6
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
    NOTICE:  BL31: Built : 07:25:50, Aug  7 2021
    U-Boot SPL 2021.01-g53e79d0e89 (Aug 07 2021 - 07:28:31 +0000)
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-GESI-EXP rev E3
    Detected: J7X-VSC8514-ETH rev E2
    am654_sdhci sdhci@4fb0000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
    U-Boot 2021.01-g53e79d0e89 (Aug 07 2021 - 07:28:31 +0000)
    SoC:   J7200 SR1.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from MMC... *** Warning - bad CRC, using default environment
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    eth0: ethernet@46000000
    Hit any key to stop autoboot:  0
    => mmc list
    sdhci@4f80000: 0 (eMMC)
    sdhci@4fb0000: 1
    => printenv partitions
    partitions=uuid_disk=${uuid_gpt_disk};name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs}
    => setenv uuid_gpt_disk f37d7f93-7067-440a-9410-e966da83550e
    => setenv uuid_gpt_rootfs 786333cc-eaff-41be-9f32-22705d8375a8
    => gpt write mmc 0 ${partitions}
    Writing GPT: success!
    => printenv mmcboot
    mmcboot=mmc dev ${mmcdev}; devnum=${mmcdev}; devtype=mmc; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadimage; then run args_mmc; if test ${boot_fit} -eq 1; then run run_fit; else run mmcloados;fi;fi;fi;
    => printenv loaduimagefat
    ## Error: "loaduimagefat" not defined
    ## Error: "loaduimage" not defined
    => printenv mmcroot
    ## Error: "mmcroot" not defined
    => printenv mmcrootfstype
    mmcrootfstype=ext4 rootwait
    => mmc dev 0 1
    switch to partitions #1, OK
    mmc0(part 1) is current device
    => fatload mmc 1 ${loadaddr} tiboot3.bin
    527381 bytes read in 11 ms (45.7 MiB/s)
    => mmc write ${loadaddr} 0x0 0x800
    MMC write: dev # 0, block # 0, count 2048 ... 2048 blocks written: OK
    => fatload mmc 1 ${loadaddr} tispl.bin
    841164 bytes read in 12 ms (66.8 MiB/s)
    => mmc write ${loadaddr} 0x800 0x1000
    MMC write: dev # 0, block # 2048, count 4096 ... 4096 blocks written: OK
    => fatload mmc 1 ${loadaddr} u-boot.img
    1092428 bytes read in 15 ms (69.5 MiB/s)
    => mmc write ${loadaddr} 0x1800 0x2000
    MMC write: dev # 0, block # 6144, count 8192 ... 8192 blocks written: OK
    => mmc partconf 0 1 1 1
    => mmc bootbus 0 2 0 0
    => setenv mmcdev 0
    => setenv bootpart 0
    => boot
    Aborting!
    => env default -f -a
    ## Resetting to default environment
    => setenv mmcdev 0
    => setenv bootpart 0:2
    => setenv dorprocboot 1
    => setenv bootcmd 'run findfdt; setenv mmcdev 0; run envboot; run check_android; if test $is_android -eq 1; then run emmc_android_boot; fi; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern'
    => setenv rproc_fw_binaries '0 /lib/firmware/j7200-main-r5f0_0-fw 1 /lib/firmware/j7200-main-r5f0_1-fw 2 j7200-mcu-r5f0_0-fw 3 j7200-mcu-r5f0_1-fw'
    => boot
    Aborting!
    Flash rootfs to eMMC log:
    root@j7200-evm:~# reboot
             Stopping Simple Network MaíKent Protocol (SNMP) Daemon....
    [  OK  ] Stopped Wait for Network to be Configured.
    [  OK  ] Stopped Simple Network ManíKement Protocol (SNMP) Daemon..
    [  OK  ] Stopped Dispatch Password íKts to Console Directory Watch.
    [  OK  ] Stopped Forward Password RíKuests to Wall Directory Watch.
             Stopping Update UTMP about System Boot/Shutdown...
    [  OK  ] Stopped Update UTMP about System Boot/Shutdown.
             Unmounting /run/media/mmcblk0p1...
             Unmounting /run/media/mmcblk0p2...
             Unmounting /run/media/mmcblk1p1...
    [  OK  ] Unmounted /run/media/mmcblk0p1.
    [  OK  ] Unmounted /run/media/mmcblk0p2.
    [  OK  ] Unmounted /run/media/mmcblk1p1.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p2.
    [   84.335888] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   84.342827] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   84.349710] watchdog: watchdog0: watchdog did not stop!
    [   84.372629] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   84.609979] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   84.622831] systemd-journald[156]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   84.633546] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   84.643280] systemd-shutdown[1]: Hardware watchdog 'K3 RTI Watchdog', version 0
    [   84.652110] systemd-shutdown[1]: Unmounting file systems.
    [   84.659720] [1085]: Remounting '/' read-only in with options '(null)'.
    [   84.721086] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [   84.728039] systemd-shutdown[1]: All filesystems unmounted.
    [   84.733630] systemd-shutdown[1]: Deactivating swaps.
    [   84.738706] systemd-shutdown[1]: All swaps deactivated.
    [   84.743943] systemd-shutdown[1]: Detaching loop devices.
    [   84.751580] systemd-shutdown[1]: All loop devices detached.
    [   84.757188] systemd-shutdown[1]: Detaching DM devices.
    [   84.762522] systemd-shutdown[1]: All DM devices detached.
    [   84.767926] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
    [   84.783598] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   84.790360] systemd-shutdown[1]: Rebooting.
    [   84.815370] reboot: Restarting system
    SoC:   J7200 SR1.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    0 bytes read in 1 ms (0 Bytes/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    19137024 bytes read in 283 ms (64.5 MiB/s)
    45267 bytes read in 6 ms (7.2 MiB/s)
       Loading Device Tree to 000000008fef1000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.41-g4c2eade9f7 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Sat Aug 7 08:06:31 UTC 2021
    [    0.000000] Machine model: Texas Instruments K3 J7200 SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
    [    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:1m(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=f55ba95a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
    [    0.000000] Memory: 3474688K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 195328K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008800b0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008293] Console: colour dummy device 80x25
    [    0.012855] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023527] pid_max: default: 32768 minimum: 301
    [    0.028275] LSM: Security Framework initializing
    [    0.033026] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040604] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.050159] rcu: Hierarchical SRCU implementation.
    [    0.055341] Platform MSI: msi-controller@1820000 domain created
    [    0.061523] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070809] EFI services will not be available.
    [    0.075646] smp: Bringing up secondary CPUs ...
    [    0.081004] Detected PIPT I-cache on CPU1
    [    0.081028] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.081041] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
    [    0.081082] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.081163] smp: Brought up 1 node, 2 CPUs
    [    0.110523] SMP: Total of 2 processors activated.
    [    0.115330] CPU features: detected: 32-bit EL0 Support
    [    0.120587] CPU features: detected: CRC32 instructions
    [    0.134161] CPU: All CPU(s) started at EL2
    [    0.138367] alternatives: patching kernel code
    [    0.143514] devtmpfs: initialized
    [    0.149728] KASLR disabled due to lack of seed
    [    0.154456] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.164432] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.172262] pinctrl core: initialized pinctrl subsystem
    [    0.177905] DMI not present or invalid.
    [    0.182205] NET: Registered protocol family 16
    [    0.190010] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.197395] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.205453] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.213824] thermal_sys: Registered thermal governor 'step_wise'
    [    0.213828] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.220204] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.233869] ASID allocator initialised with 65536 entries
    [    0.250424] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.257284] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.264044] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.273589] cryptd: max_cpu_qlen set to 1000
    [    0.281081] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR1.0 JTAGID[0x0bb6d02f] Detected
    [    0.289995] vsys_3v3: supplied by evm_12v0
    [    0.294367] vsys_5v0: supplied by evm_12v0
    [    0.299052] iommu: Default domain type: Translated
    [    0.304238] SCSI subsystem initialized
    [    0.308434] mc: Linux media interface: v0.10
    [    0.312822] videodev: Linux video capture interface: v2.00
    [    0.318464] pps_core: LinuxPPS API ver. 1 registered
    [    0.323537] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.332877] PTP clock support registered
    [    0.336896] EDAC MC: Ver: 3.0.0
    [    0.340788] FPGA manager framework
    [    0.344319] Advanced Linux Sound Architecture Driver Initialized.
    [    0.351063] clocksource: Switched to clocksource arch_sys_counter
    [    0.357542] VFS: Disk quotas dquot_6.6.0
    [    0.361622] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.371787] NET: Registered protocol family 2
    [    0.376553] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.385427] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.394243] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.402456] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.410427] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.417274] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.424181] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.431621] NET: Registered protocol family 1
    [    0.436528] RPC: Registered named UNIX socket transport module.
    [    0.442594] RPC: Registered udp transport module.
    [    0.447401] RPC: Registered tcp transport module.
    [    0.452207] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.458794] PCI: CLS 0 bytes, default 64
    [    0.463176] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.474975] Initialise system trusted keyrings
    [    0.479697] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.488241] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.494621] NFS: Registering the id_resolver key type
    [    0.499839] Key type id_resolver registered
    [    0.504117] Key type id_legacy registered
    [    0.508257] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.515108] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.522775] 9p: Installing v9fs 9p2000 file system support
    [    0.548164] Key type asymmetric registered
    [    0.552361] Asymmetric key parser 'x509' registered
    [    0.557373] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.564934] io scheduler mq-deadline registered
    [    0.569559] io scheduler kyber registered
    [    0.574764] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.580997] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.589268] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.595590] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.603475] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.617658] brd: module loaded
    [    0.625323] loop: module loaded
    [    0.629004] megasas: 07.714.04.00-rc1
    [    0.633937] libphy: Fixed MDIO Bus: probed
    [    0.638652] tun: Universal TUN/TAP device driver, 1.6
    [    0.644117] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.650533] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.656612] sky2: driver version 1.30
    [    0.660945] VFIO - User Level meta-driver version: 0.3
    [    0.666730] i2c /dev entries driver
    [    0.670845] sdhci: Secure Digital Host Controller Interface driver
    [    0.677185] sdhci: Copyright(c) Pierre Ossman
    [    0.681813] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.688100] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.694475] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.701712] optee: probing for conduit method.
    [    0.706286] optee: revision 3.12 (3d47a131)
    [    0.706611] optee: initialized driver
    [    0.716009] NET: Registered protocol family 17
    [    0.720664] 9pnet: Installing 9P2000 support
    [    0.725069] Key type dns_resolver registered
    [    0.729520] Loading compiled-in X.509 certificates
    [    0.739521] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.745913] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.753892] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
    [    0.778288] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.784581] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.790836] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.797277] pca953x 3-0021: supply vcc not found, using dummy regulator
    [    0.804132] pca953x 3-0021: using no AI
    [    0.831622] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    0.838458] pca953x 3-0020: using no AI
    [    0.843088] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    0.849914] pca953x 3-0022: using AI
    [    0.854001] random: fast init done
    [    0.857761] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.864162] pca953x 4-0020: supply vcc not found, using dummy regulator
    [    0.871073] pca953x 4-0020: using no AI
    [    0.895499] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.901714] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
    [    0.907934] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
    [    0.914117] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [    0.920303] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [    0.926465] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
    [    0.932703] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    0.942714] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    0.951538] ti-sci-intr bus@100000:bus@30000000:interrupt-controller1: Interrupt Router 213 domain created
    [    0.961563] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
    [    0.971447] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    0.979138] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    0.987418] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    0.995697] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.011681] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
    [    2.018122] pci_bus 0000:00: root bus resource [bus 00-0f]
    [    2.023733] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
    [    2.033424] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.040476] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400
    [    2.046696] pci 0000:00:00.0: supports D1
    [    2.050794] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.057500] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.066438] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [    2.073218] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.078547] pcieport 0000:00:00.0: PME: Signaling with IRQ 36
    [    2.085718] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
    [    2.095632] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    2.102397] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    2.112209] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
    [    2.122373] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    2.129134] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    2.137198] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    2.146777] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
    [    2.155538] printk: console [ttyS2] enabled
    [    2.163980] printk: bootconsole [ns16550a0] disabled
    [    2.174627] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    2.351071] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    2.358552] libphy: 46000f00.mdio: probed
    [    2.388488] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.396817] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.412202] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    2.421246] mmc0: CQHCI version 5.10
    [    2.426674] vdd_mmc1: supplied by vsys_3v3
    [    2.431472] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
    [    2.438386] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
    [    2.445522] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    2.455534] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
    [    2.461744] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    2.467677] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    2.476603] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    2.483272] Creating 7 MTD partitions on "47040000.spi.0":
    [    2.488761] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    2.495144] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    2.501344] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    2.507509] 0x000000700000-0x000000740000 : "ospi.env"
    [    2.513423] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    2.519764] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    2.525839] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.592024] mmc0: Command Queue Engine enabled
    [    2.596481] mmc0: new HS400 MMC card at address 0001
    [    2.601845] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    2.606582] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    2.612712] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    2.618778] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
    [    2.627432]  mmcblk0: p1 p2
    [    2.703078] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
    [    2.710563] libphy: 46000f00.mdio: probed
    [    2.739920] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.748249] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.761819] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.768801] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.776046] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.782452] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    2.792818] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    2.793070] mmc1: CQHCI version 5.10
    [    2.806234] ALSA device list:
    [    2.809216]   No soundcards found.
    [    2.844892] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.852663] Waiting for root device PARTUUID=f55ba95a-02...
    [    2.906248] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
    [    2.913320] mmcblk1: mmc1:59b4 USDU1 30.0 GiB
    [    2.920132]  mmcblk1: p1 p2
    [    3.040603] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.048754] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.058423] devtmpfs: mounted
    [    3.062620] Freeing unused kernel memory: 1856K
    [    3.067214] Run /sbin/init as init process
    [    3.224009] systemd[1]: System time before build time, advancing clock.
    [    3.279928] NET: Registered protocol family 10
    [    3.285017] Segment Routing with IPv6
    [    3.330758] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    3.352625] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2020.09!
    [    3.396206] systemd[1]: Set hostname to <j7200-evm>.
    [    3.636300] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock í≈ /run/docker.sock; please update the unit file accordingly.
    [    3.731389] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.738131] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.750472] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.760888] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    3.783178] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.790704] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    3.811180] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.818674] systemd[1]: Created slice system-syslog\x2dng.slice.
    [  OK  ] Created slice system-syslog\x2dng.slice.
    [    3.840077] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.863360] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password íKts to Console Directory Watch.
    [    3.887310] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password RíKuests to Wall Directory Watch.
    [    3.911268] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.927195] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.947178] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.963200] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.980949] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    4.003207] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    4.025567] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    4.047356] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.078444] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.086878] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.107516] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.123586] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.147517] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.167387] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.191326] systemd[1]: Mounting Huge Pages File System...
    [    4.211370] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.238762] systemd[1]: Mounting Kernel Debug File System...
    [    4.260014] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.279186] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of stíKodes for the current kernel...
    [    4.308491] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [    4.334683] systemd[1]: Starting RPC Bind...
    [    4.351287] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.375219] systemd[1]: Starting Journal Service...
    [    4.396358] systemd[1]: Starting Load Kernel Modules...
    [    4.419639] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems cryptodev: loading out-of-tree module taints kernel.
    [0m...
    [    4.446571] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    4.456029] systemd[1]: Starting udev Coldplug all Devices...
    [    4.471470] cryptodev: driver 1.10 loaded.
    [    4.480866] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.496853] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of staíK nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    4.663931] systemd-journald[156]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Ethernet Bridge Filtering Tables...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting System Logger Daemon "default" instance...
             Starting Login Service...
             Starting telnetd.service...
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Reached target Network (Pre).
             Starting Network Service...
    [  OK  ] Started telnetd.service.
             Starting syslog.service...
    [  OK  ] Started Telephony service.
    [    5.931450] Bluetooth: Core ver 2.22
    [    5.935129] NET: Registered protocol family 31
    [    5.947144] Bluetooth: HCI device and connection manager initialized
    [    5.953538] Bluetooth: HCI socket layer initialized
    [    5.963133] Bluetooth: L2CAP socket layer initialized
    [    5.968279] Bluetooth: SCO socket layer initialized
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Login Service.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network MaíKent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Vsftpd ftp daemon.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Enable and configure wl18xx bluetooth stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [    7.075099] random: crng init done
    [    7.078507] random: 7 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [    7.539858] ti-udma 285c0000.dma-controller: chan1: is running!
    [  OK  ] Started System Logger Daemon "default" instance.
    [    7.663658] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [  OK  ] Started syslog.service.
    [    7.809286] platform 41000000.r5f: configured R5F for IPC-only mode
    [    7.902711] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    7.971786] remoteproc remoteproc0: 41000000.r5f is available
    [    8.008230] remoteproc remoteproc0: attaching to 41000000.r5f
    [    8.107263] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    8.315116]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [    8.427788] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.441632] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.451311] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    8.507183]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [    8.520547] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
    [    8.590339] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    8.627224] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    8.663866] remoteproc remoteproc1: 5c00000.r5f is available
    [    8.693702] platform 5d00000.r5f: configured R5F for remoteproc mode
    [    8.718720] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    8.751232] remoteproc remoteproc2: 5d00000.r5f is available
    [    9.484580] remoteproc remoteproc1: powering up 5c00000.r5f
    [    9.490327] remoteproc remoteproc2: powering up 5d00000.r5f
    [    9.496066] remoteproc remoteproc1: Booting fw image j7200-main-r5f0_0-fw, size 535720
    [    9.504151] remoteproc remoteproc2: Booting fw image j7200-main-r5f0_1-fw, size 65652
    [    9.513667]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [    9.514072] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.514139]  remoteproc2#vdev0buffer: registered virtio1 (type 7)
    [    9.514145] remoteproc remoteproc2: remote processor 5d00000.r5f is now up
    [    9.515721]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [    9.516333] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.516394]  remoteproc1#vdev0buffer: registered virtio2 (type 7)
    [    9.516399] remoteproc remoteproc1: remote processor 5c00000.r5f is now up
    [    9.524680] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.524795] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    9.607925] virtio_rpmsg_bus virtio2: creating channel ti.ethfw.notifyservice addr 0x1e
    [    9.608072] virtio_rpmsg_bus virtio2: creating channel rpmsg-kdrv addr 0x1a
    [    9.609195] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: Device info: permissions: 07FFFFFF uart_id: 3
    [    9.609202] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: FW ver 0.1 (rev 1) 13/Jul/2021 SHA:4cb38131
    [    9.612791] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac loaded
    [    9.612798] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rdev_features:00000003 rdev_mtu:1522 flow_id:84 tx_psil_dst_id:4A00
    [    9.612801] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [  OK  ] Started Simple Network ManíKement Protocol (SNMP) Daemon..
    [   10.565274] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [   10.659576] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            gstreamer1.0-libav-dev
            gstreamer1.0-libav
            gzip
            less
            libasm1
            libbfd
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline8
            libunistring-dev
            libunistring2
            m4-dev
            m4
            make
            nettle-dev
            nettle
            parted
            python3-rfc3987
            python3-strict-rfc3339
            tar
            which
            zeromq
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [   12.273659] usbcore: registered new interface driver usbfs
    [   12.314876] omap_rng 40910000.rng: Random Number Generator ver. 241b34c
    [   12.443385] usbcore: registered new interface driver hub
    [   12.542827] usbcore: registered new device driver usb
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7200-evm ttyS2
    Arago 2020.09 j7200-evm ttyS2
    j7200-evm login: [   12.876367] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac started
    [   13.504087] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [  126.679431] Initializing XFRM netlink socket
    [  130.262426] process 'docker/tmp/qemu-check999872553/check' started with executable stack
    j7200-evm login: root
    root@j7200-evm:~# cd /
    root@j7200-evm:/# ls
    bin   dev  home     init  linuxrc     media        mnt  proc  sbin  tmp  var
    boot  etc  include  lib   lost+found  mksdboot.sh  opt  run   sys   usr
    root@j7200-evm:/# chmod +x mksdboot.sh
    root@j7200-evm:/# umount /dev/mmcblk0*
    umount: /dev/mmcblk0: not mounted.
    umount: /dev/mmcblk0boot0: not mounted.
    umount: /dev/mmcblk0boot1: not mounted.
    umount: /dev/mmcblk0rpmb: not mounted.
    root@j7200-evm:/# udevadm control -s
    root@j7200-evm:/# ./mksdboot.sh --device /dev/mmcblk0
    -- Main device is: /dev/mmcblk1p2
    *         THIS WILL DELETE ALL THE DATA ON /dev/mmcblk0         *
    *         WARNING! Make sure your computer does not go     *
    *                  in to idle mode while this script is    *
    *                  running. The script will complete,      *
    *                  but your SD card may be corrupted.      *
    *         Press <ENTER> to confirm....                     *
    unmounting device '/dev/mmcblk0'
    unmounting device '/dev/mmcblk0boot0'
    unmounting device '/dev/mmcblk0boot1'
    unmounting device '/dev/mmcblk0p1'
    unmounting device '/dev/mmcblk0p2'
    unmounting device '/dev/mmcblk0rpmb'
    1024+0 records in
    1024+0 records out
    1048576 bytes (1.0 MB, 1.0 MiB) copied, 0.0293412 s, 35.7 MB/s
    Welcome to fdisk (util-linux 2.35.1).
    Changes will remain in memory only, until you decide to write them.
    Be careful before using the write command.
    Device does not contain a recognized partition table.
    Created a new DOS disklabel with disk identifier 0xa9afffaf.
    Command (m for help): Partition type
       p   primary (0 primary, 0 extended, 4 free)
       e   extended (container for logical partitions)
    Select (default p): Partition number (1-4, default 1): First sector (2048-31080447, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (2048-31080447, default 31080447):
    Created a new partition 1 of type 'Linux' and of size 62 MiB.
    Partition #1 contains a vfat signature.
       p   primary (1 primary, 0 extended, [  399.179785]  mmcblk0: p1 p2
    3 free)
    Sel[  399.185873]  mmcblk0: p1 p2
    ect (default p): Partition number (2-4, default 2): First sector (129024-31080447, default 129024): Last sector, +/-sectors or +/-size{K,M,G,T,P} (129024-31080447, default 31080447):
    Created a new partition 2 of type 'Linux' and of size 14.8 GiB.
    Partition #2 contains a ext4 signature.
    Command (m for help): Partition number (1,2, default 2): Hex code (type L to list all codes):
    Changed type of partition 'Linux' to 'W95 FAT32 (LBA)'.
    The bootable flag on partition 1 is enabled now.
    Command (m for help): The partition table has been altered.
    Calling ioctl() to re-read partition table.
    Syncing disks.
    Formatting /dev/mmcblk0 ...
    mkfs.fat 4.1 (2017-01-24)
    mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
    mke2fs 1.45.4 (23-Sep-2019)
    /dev/mmcblk0p2 contains a ext4 file system labelled 'rootfs'
            last mounted on /mnt/emmc-rootfs on Sat Aug  7 07:16:15 2021
    Proceed anyway? (y,N) y
    Discarding device blocks: done
    Creating filesystem with 3868928 4k blocks and 967232 inodes
    Filesystem UUID: e4c4ee72-d715-43db-a8ff-bf1bfd803359
    Superblock backups stored on blocks:
            32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
    Allocating group tables: done
    Writing inode tables: done
    Creating journal (16384 blocks): done
    Writing superblocks and filesystem accounting information: done
    Partitioning and formatting completed!
    root@j7200-evm:/# umount /run/media/*
    root@j7200-evm:/# mount /dev/mmcblk1p2 /mnt/sd-rootfs
    root@j7200-evm:/# mount /dev/mmcblk0p2 /mnt/emmc-rootfs
    [  501.290596] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    root@j7200-evm:/# cp -r /mnt/sd-rootfs/* /mnt/emmc-rootfs
    root@j7200-evm:/# sync
    root@j7200-evm:/# umount /mnt/*
    root@j7200-evm:/#
    Can you try with:
    setenv bootpart 0:1
    - Keerthy
    After running setenv bootpart 0:1, the following error message appears, please help, thank you.
    => setenv bootpart 0:1
    => boot
    Aborting!
    LOG:
    Trying to boot from MMC1
    init_env from device 17 not supported!
    SoC:   J7200 SR1.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    Loading Environment from MMC... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    => printenv mmcboot
    => mmc list
    sdhci@4fb0000: 1
    => setenv mmcdev 0
    => boot
    Aborting!
    I suspect filesystem is not still correctly created.
    Once you get to U-Boot prompt can you try the below commands:
    mmc dev 0
    Followed by:
    ext4ls mmc 0:2
    ext4ls mmc 0:1
    One of the above should list out the filesystem folders.
    - Keerthy
    I used SD card to boot Linux and re-flash the rootfs using the steps mentioned in the link below
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-j7200/08_00_00_05/exports/docs/j7200/linux/How_to_Guides/Target/How_to _flash_emmc_device.html
    And run
    setenv bootpart 0:2
    saveenv
    Now I can boot Linux from eMMC successfully.
    thanks for your help
    Can I change the image files running on r5f cores by modifying the image files link in path: /lib/firmware/
                           j7200-mcu-r5f0_0-fw
                           j7200-mcu-r5f0_1-fw
    Reference URL:
    IPC Demo app:
    software-dl.ti.com/.../ j7200/modules/ipc.html#example-details
    I have copied can_app_mcu1_0_release.xer5f to /lib/firmware/pdk-ipc
    Run cmd:
    root@j7200-evm:/lib/firmware/pdk-ipc# ln -s /lib/firmware/pdk-ipc/can_app_mcu1_0_release.xer5f j7200-mcu-r5f0_0-fw
    After reboot, I can't see any message in MCU/UART port
    Please help, thanks!
  • This query is resolved. Request you to raise a fresh E2E query with the above data so that it will be looked at by the relevant expert.
    - Keerthy
