Other Parts Discussed in Thread: SYSBIOS,
Hi team,
We are facing a trouble around NDK.
We tried to send an image each 5 seconds via FTP using NDK 3.61.01.01
[2021-09-02 16:49:57.246] 4:>csirx status [2021-09-02 16:49:57.502] [2021-09-02 16:49:57.502] (port0): ========================================================== [2021-09-02 16:49:57.582] (port0): Capture Status: Start [2021-09-02 16:49:57.614] (port0): ========================================================== [2021-09-02 16:49:57.679] (port0): Frames Received: 97372 [2021-09-02 16:49:57.710] (port0): Frames Received with errors: 0 [2021-09-02 16:49:57.759] (port0): Capture Application Completed!!! [2021-09-02 16:49:57.808] (port0): FIFO Overflow Count: 0 [2021-09-02 16:49:57.840] (port0): Spurious UDMA interrupt count: 0 [2021-09-02 16:49:57.887] (port0): Front FIFO Overflow Count: 0 [2021-09-02 16:49:57.918] (port0): CRC Error Count: 0 [2021-09-02 16:49:57.950] (port0): Un-corrected ECC Error Count: 0 [2021-09-02 16:49:57.998] (port0): Corrected ECC Error Count: 0 [2021-09-02 16:49:58.047] (port0): Data ID Error Count: 0 [2021-09-02 16:49:58.077] (port0): Invalid Access Error Count: 0 [2021-09-02 16:49:58.126] (port0): Invalid Short Packet Receive Error Count: 0 [2021-09-02 16:49:58.174] (port0): Stream0 FIFO Overflow Error Count: 0 [2021-09-02 16:49:58.222] (port0): [Channel No: 0] | Frame Queue Count: 97366 | Frame De-queue Count: 97363 | Frame Drop Count: 178 | [2021-09-02 16:49:58.334] [2021-09-02 16:49:58.334] (port1): ========================================================== [2021-09-02 16:49:58.414] (port1): Capture Status: Start [2021-09-02 16:49:58.446] (port1): ========================================================== [2021-09-02 16:49:58.510] (port1): Frames Received: 97409 [2021-09-02 16:49:58.543] (port1): Frames Received with errors: 0 [2021-09-02 16:49:58.590] (port1): Capture Application Completed!!! [2021-09-02 16:49:58.638] (port1): FIFO Overflow Count: 0 [2021-09-02 16:49:58.670] (port1): Spurious UDMA interrupt count: 0 [2021-09-02 16:49:58.718] (port1): Front FIFO Overflow Count: 0 [2021-09-02 16:49:58.766] (port1): CRC Error Count: 0 [2021-09-02 16:49:58.782] (port1): Un-corrected ECC Error Count: 0 [2021-09-02 16:49:58.830] (port1): Corrected ECC Error Count: 0 [2021-09-02 16:49:58.878] (port1): Data ID Error Count: 0 [2021-09-02 16:49:58.910] (port1): Invalid Access Error Count: 0 [2021-09-02 16:49:58.958] (port1): Invalid Short Packet Receive Error Count: 0 [2021-09-02 16:49:59.006] (port1): Stream0 FIFO Overflow Error Count: 0 [2021-09-02 16:49:59.053] (port1): [Channel No: 0] | Frame Queue Count: 97410 | Frame De-queue Count: 97400 | Frame Drop Count: 0 | [2021-09-02 16:49:59.166] 4:>rm cam0-0_latest.raw [2021-09-02 16:49:59.551] 4:>csirx save [2021-09-02 16:49:59.758] (port0): Write cam0-0_latest.raw (8518400 bytes) [2021-09-02 16:50:00.014] 4:>ftp put 192.168.1.65 user pass cam0-0_latest.raw camEVM_img367_1936x2200.raw [2021-09-02 16:50:06.349] recv(CONN) error(35) [2021-09-02 16:50:06.365] 4:>csirx status [2021-09-02 16:50:06.622] [2021-09-02 16:50:06.638] (port0): ========================================================== [2021-09-02 16:50:06.701] (port0): Capture Status: Start [2021-09-02 16:50:06.734] (port0): ========================================================== [2021-09-02 16:50:06.813] (port0): Frames Received: 97855 [2021-09-02 16:50:06.845] (port0): Frames Received with errors: 0 [2021-09-02 16:50:06.877] (port0): Capture Application Completed!!! [2021-09-02 16:50:06.925] (port0): FIFO Overflow Count: 0 [2021-09-02 16:50:06.957] (port0): Spurious UDMA interrupt count: 0 [2021-09-02 16:50:07.005] (port0): Front FIFO Overflow Count: 0 [2021-09-02 16:50:07.053] (port0): CRC Error Count: 0 [2021-09-02 16:50:07.085] (port0): Un-corrected ECC Error Count: 0 [2021-09-02 16:50:07.133] (port0): Corrected ECC Error Count: 0 [2021-09-02 16:50:07.165] (port0): Data ID Error Count: 0 [2021-09-02 16:50:07.198] (port0): Invalid Access Error Count: 0 [2021-09-02 16:50:07.245] (port0): Invalid Short Packet Receive Error Count: 0 [2021-09-02 16:50:07.294] (port0): Stream0 FIFO Overflow Error Count: 0 [2021-09-02 16:50:07.341] (port0): [Channel No: 0] | Frame Queue Count: 97848 | Frame De-queue Count: 97846 | Frame Drop Count: 178 | [2021-09-02 16:50:07.472] [2021-09-02 16:50:07.472] (port1): ========================================================== [2021-09-02 16:50:07.533] (port1): Capture Status: Start [2021-09-02 16:50:07.565] (port1): ========================================================== [2021-09-02 16:50:07.645] (port1): Frames Received: 97892 [2021-09-02 16:50:07.677] (port1): Frames Received with errors: 0 [2021-09-02 16:50:07.728] (port1): Capture Application Completed!!! [2021-09-02 16:50:07.757] (port1): FIFO Overflow Count: 0 [2021-09-02 16:50:07.805] (port1): Spurious UDMA interrupt count: 0 [2021-09-02 16:50:07.838] (port1): Front FIFO Overflow Count: 0 [2021-09-02 16:50:07.885] (port1): CRC Error Count: 0 [2021-09-02 16:50:07.918] (port1): Un-corrected ECC Error Count: 0 [2021-09-02 16:50:07.965] (port1): Corrected ECC Error Count: 0 [2021-09-02 16:50:07.998] (port1): Data ID Error Count: 0 [2021-09-02 16:50:08.029] (port1): Invalid Access Error Count: 0 [2021-09-02 16:50:08.078] (port1): Invalid Short Packet Receive Error Count: 0 [2021-09-02 16:50:08.125] (port1): Stream0 FIFO Overflow Error Count: 0 [2021-09-02 16:50:08.190] (port1): [Channel No: 0] | Frame Queue Count: 97893 | Frame De-queue Count: 97883 | Frame Drop Count: 0 | [2021-09-02 16:50:08.287] 4:>rm cam0-0_latest.raw [2021-09-02 16:50:08.669] 4:>csirx save [2021-09-02 16:50:08.877] (port0): Write cam0-0_latest.raw (8518400 bytes) [2021-09-02 16:50:09.133] 4:>ftp put 192.168.1.65 user pass cam0-0_latest.raw camEVM_img368_1936x2200.raw [2021-09-02 16:50:10.461] 220 (vsFTPd 3.0.3) [2021-09-02 16:50:10.493] [2021-09-02 16:50:10.493] USER user [2021-09-02 16:50:10.509] [2021-09-02 16:50:10.509] 331 Please specify the password. [2021-09-02 16:50:10.542] [2021-09-02 16:50:10.542] PASS pass [2021-09-02 16:50:10.557] [2021-09-02 16:50:10.573] 230 Login successful. [2021-09-02 16:50:10.605] [2021-09-02 16:50:10.605] PASV [2021-09-02 16:50:10.605] [2021-09-02 16:50:10.605] 227 Entering Passive Mode (192,168,1,65,66,80). [2021-09-02 16:50:10.669] [2021-09-02 16:50:10.669] STOR camEVM_img368_1936x2200.raw [2021-09-02 16:50:10.703] [2021-09-02 16:50:10.703] 150 Ok to send data. [2021-09-02 16:50:10.733] [2021-09-02 16:50:10.733] send size 8518400 bytes [2021-09-02 16:50:10.765] [2021-09-02 16:50:11.405] emac_poll_tx_ring2:[DEBUG] pPkt=802aac20 type=0x80344440 [2021-09-02 16:50:11.456] nimu_free_pkt:[DEBUG] pPkt=802aac20 type=0x80344440 [2021-09-02 16:50:11.519] 01897.594 PBM_free: Invalid Packet [2021-09-02 16:50:11.519] ti.sysbios.heaps.HeapMem: line 445: assertion failure: A_invalidFree: Invalid free [2021-09-02 16:50:11.519] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:11.519] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:11.534] Main handle: 0x0. [2021-09-02 16:50:11.534] Main stack base: 0x803ab3c0. [2021-09-02 16:50:11.534] Main stack size: 0x80000. [2021-09-02 16:50:11.534] X0 = 0x0000000000000018 X1 = 0x000000008030b730 [2021-09-02 16:50:11.534] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:11.551] X4 = 0x0000000000000018 X5 = 0x000000008030b730 [2021-09-02 16:50:11.551] X6 = 0x6e7164795e3fff64 X7 = 0x7f7f7f7f7f7f7f7f [2021-09-02 16:50:11.551] X8 = 0x000000008030b740 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:11.551] X10 = 0x000000008030b780 X11 = 0x000000008030b780 [2021-09-02 16:50:11.567] X12 = 0x0000000000000065 X13 = 0x00000000000000f5 [2021-09-02 16:50:11.567] X14 = 0x000000000000003c X15 = 0x000000000000001c [2021-09-02 16:50:11.567] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:11.583] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:11.583] X20 = 0x00000000800c2008 X21 = 0x0000000000000000 [2021-09-02 16:50:11.583] X22 = 0x0000000000000001 X23 = 0x00000000000001bd [2021-09-02 16:50:11.583] X24 = 0x00000000800bb910 X25 = 0x00000000800b8a2e [2021-09-02 16:50:11.600] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:11.600] X28 = 0x0000000000000000 X29 = 0x000000008030b720 [2021-09-02 16:50:11.600] X30 = 0x0000000000000000 SP = 0x000000008030b720 [2021-09-02 16:50:11.615] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:11.615] SPSR = 0x400003c4 [2021-09-02 16:50:11.615] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:11.615] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:11.631] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:11.631] Main handle: 0x0. [2021-09-02 16:50:11.631] Main stack base: 0x803ab3c0. [2021-09-02 16:50:11.631] Main stack size: 0x80000. [2021-09-02 16:50:11.631] X0 = 0x0000000000000018 X1 = 0x000000008042b030 [2021-09-02 16:50:11.647] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:11.647] X4 = 0x0000000000000018 X5 = 0x000000008042b030 [2021-09-02 16:50:11.647] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:11.647] X8 = 0x000000008042b040 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:11.661] X10 = 0x000000008042b080 X11 = 0x000000008042b080 [2021-09-02 16:50:11.661] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:11.661] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:11.661] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:11.677] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:11.677] X20 = 0x00000000800c2008 X21 = 0x0000000000000001 [2021-09-02 16:50:11.677] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:11.693] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:11.693] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:11.693] X28 = 0x0000000000000000 X29 = 0x000000008042b020 [2021-09-02 16:50:11.693] X30 = 0x0000000000000000 SP = 0x000000008042b020 [2021-09-02 16:50:11.709] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:11.709] SPSR = 0x400003c5 [2021-09-02 16:50:11.709] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:11.725] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:11.725] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:11.725] Main handle: 0x0. [2021-09-02 16:50:11.725] Main stack base: 0x803ab3c0. [2021-09-02 16:50:11.725] Main stack size: 0x80000. [2021-09-02 16:50:11.725] X0 = 0x0000000000000018 X1 = 0x000000008042ac90 [2021-09-02 16:50:11.741] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:11.741] X4 = 0x0000000000000018 X5 = 0x000000008042ac90 [2021-09-02 16:50:11.741] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:11.757] X8 = 0x000000008042aca0 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:11.757] X10 = 0x000000008042ace0 X11 = 0x000000008042ace0 [2021-09-02 16:50:11.757] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:11.757] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:11.773] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:11.773] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:11.773] X20 = 0x00000000800c2008 X21 = 0x0000000000000002 [2021-09-02 16:50:11.773] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:11.790] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:11.790] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:11.790] X28 = 0x0000000000000000 X29 = 0x000000008042ac80 [2021-09-02 16:50:11.806] X30 = 0x0000000000000000 SP = 0x000000008042ac80 [2021-09-02 16:50:11.806] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:11.806] SPSR = 0x400003c5 [2021-09-02 16:50:11.806] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:11.822] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:11.822] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:11.822] Main handle: 0x0. [2021-09-02 16:50:11.822] Main stack base: 0x803ab3c0. [2021-09-02 16:50:11.822] Main stack size: 0x80000. [2021-09-02 16:50:11.838] X0 = 0x0000000000000018 X1 = 0x000000008042a8f0 [2021-09-02 16:50:11.838] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:11.838] X4 = 0x0000000000000018 X5 = 0x000000008042a8f0 [2021-09-02 16:50:11.838] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:11.853] X8 = 0x000000008042a900 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:11.853] X10 = 0x000000008042a940 X11 = 0x000000008042a940 [2021-09-02 16:50:11.853] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:11.871] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:11.871] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:11.871] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:11.871] X20 = 0x00000000800c2008 X21 = 0x0000000000000003 [2021-09-02 16:50:11.885] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:11.885] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:11.885] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:11.885] X28 = 0x0000000000000000 X29 = 0x000000008042a8e0 [2021-09-02 16:50:11.901] X30 = 0x0000000000000000 SP = 0x000000008042a8e0 [2021-09-02 16:50:11.901] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:11.901] SPSR = 0x400003c5 [2021-09-02 16:50:11.901] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:11.917] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:11.917] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:11.917] Main handle: 0x0. [2021-09-02 16:50:11.933] Main stack base: 0x803ab3c0. [2021-09-02 16:50:11.933] Main stack size: 0x80000. [2021-09-02 16:50:11.933] X0 = 0x0000000000000018 X1 = 0x000000008042a550 [2021-09-02 16:50:11.933] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:11.933] X4 = 0x0000000000000018 X5 = 0x000000008042a550 [2021-09-02 16:50:11.949] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:11.949] X8 = 0x000000008042a560 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:11.949] X10 = 0x000000008042a5a0 X11 = 0x000000008042a5a0 [2021-09-02 16:50:11.949] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:11.965] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:11.965] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:11.965] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:11.981] X20 = 0x00000000800c2008 X21 = 0x0000000000000004 [2021-09-02 16:50:11.981] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:11.981] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:11.981] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:11.997] X28 = 0x0000000000000000 X29 = 0x000000008042a540 [2021-09-02 16:50:11.997] X30 = 0x0000000000000000 SP = 0x000000008042a540 [2021-09-02 16:50:11.997] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:11.997] SPSR = 0x400003c5 [2021-09-02 16:50:12.013] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.013] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.013] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.029] Main handle: 0x0. [2021-09-02 16:50:12.029] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.029] Main stack size: 0x80000. [2021-09-02 16:50:12.029] X0 = 0x0000000000000018 X1 = 0x000000008042a1b0 [2021-09-02 16:50:12.029] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.045] X4 = 0x0000000000000018 X5 = 0x000000008042a1b0 [2021-09-02 16:50:12.045] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.045] X8 = 0x000000008042a1c0 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.045] X10 = 0x000000008042a200 X11 = 0x000000008042a200 [2021-09-02 16:50:12.061] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.061] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.061] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.061] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.077] X20 = 0x00000000800c2008 X21 = 0x0000000000000005 [2021-09-02 16:50:12.077] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.077] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.093] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.093] X28 = 0x0000000000000000 X29 = 0x000000008042a1a0 [2021-09-02 16:50:12.093] X30 = 0x0000000000000000 SP = 0x000000008042a1a0 [2021-09-02 16:50:12.093] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.109] SPSR = 0x400003c5 [2021-09-02 16:50:12.109] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.109] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.109] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.125] Main handle: 0x0. [2021-09-02 16:50:12.125] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.125] Main stack size: 0x80000. [2021-09-02 16:50:12.125] X0 = 0x0000000000000018 X1 = 0x0000000080429e10 [2021-09-02 16:50:12.125] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.141] X4 = 0x0000000000000018 X5 = 0x0000000080429e10 [2021-09-02 16:50:12.141] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.141] X8 = 0x0000000080429e20 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.157] X10 = 0x0000000080429e60 X11 = 0x0000000080429e60 [2021-09-02 16:50:12.157] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.157] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.157] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.173] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.173] X20 = 0x00000000800c2008 X21 = 0x0000000000000006 [2021-09-02 16:50:12.173] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.173] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.189] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.189] X28 = 0x0000000000000000 X29 = 0x0000000080429e00 [2021-09-02 16:50:12.189] X30 = 0x0000000000000000 SP = 0x0000000080429e00 [2021-09-02 16:50:12.206] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.206] SPSR = 0x400003c5 [2021-09-02 16:50:12.206] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.206] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.222] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.222] Main handle: 0x0. [2021-09-02 16:50:12.222] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.222] Main stack size: 0x80000. [2021-09-02 16:50:12.222] X0 = 0x0000000000000018 X1 = 0x0000000080429a70 [2021-09-02 16:50:12.238] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.238] X4 = 0x0000000000000018 X5 = 0x0000000080429a70 [2021-09-02 16:50:12.238] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.238] X8 = 0x0000000080429a80 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.254] X10 = 0x0000000080429ac0 X11 = 0x0000000080429ac0 [2021-09-02 16:50:12.254] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.254] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.270] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.270] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.270] X20 = 0x00000000800c2008 X21 = 0x0000000000000007 [2021-09-02 16:50:12.270] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.288] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.288] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.288] X28 = 0x0000000000000000 X29 = 0x0000000080429a60 [2021-09-02 16:50:12.288] X30 = 0x0000000000000000 SP = 0x0000000080429a60 [2021-09-02 16:50:12.303] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.303] SPSR = 0x400003c5 [2021-09-02 16:50:12.303] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.317] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.317] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.317] Main handle: 0x0. [2021-09-02 16:50:12.317] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.317] Main stack size: 0x80000. [2021-09-02 16:50:12.334] X0 = 0x0000000000000018 X1 = 0x00000000804296d0 [2021-09-02 16:50:12.334] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.334] X4 = 0x0000000000000018 X5 = 0x00000000804296d0 [2021-09-02 16:50:12.334] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.349] X8 = 0x00000000804296e0 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.349] X10 = 0x0000000080429720 X11 = 0x0000000080429720 [2021-09-02 16:50:12.349] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.349] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.365] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.365] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.365] X20 = 0x00000000800c2008 X21 = 0x0000000000000008 [2021-09-02 16:50:12.381] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.381] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.381] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.381] X28 = 0x0000000000000000 X29 = 0x00000000804296c0 [2021-09-02 16:50:12.397] X30 = 0x0000000000000000 SP = 0x00000000804296c0 [2021-09-02 16:50:12.397] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.397] SPSR = 0x400003c5 [2021-09-02 16:50:12.397] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.413] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.413] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.413] Main handle: 0x0. [2021-09-02 16:50:12.413] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.428] Main stack size: 0x80000. [2021-09-02 16:50:12.428] X0 = 0x0000000000000018 X1 = 0x0000000080429330 [2021-09-02 16:50:12.428] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.428] X4 = 0x0000000000000018 X5 = 0x0000000080429330 [2021-09-02 16:50:12.445] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.445] X8 = 0x0000000080429340 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.445] X10 = 0x0000000080429380 X11 = 0x0000000080429380 [2021-09-02 16:50:12.445] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.461] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.461] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.461] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.461] X20 = 0x00000000800c2008 X21 = 0x0000000000000009 [2021-09-02 16:50:12.477] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.477] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.477] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.493] X28 = 0x0000000000000000 X29 = 0x0000000080429320 [2021-09-02 16:50:12.493] X30 = 0x0000000000000000 SP = 0x0000000080429320 [2021-09-02 16:50:12.493] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.493] SPSR = 0x400003c5 [2021-09-02 16:50:12.493] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.508] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.509] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.509] Main handle: 0x0. [2021-09-02 16:50:12.525] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.525] Main stack size: 0x80000. [2021-09-02 16:50:12.525] X0 = 0x0000000000000018 X1 = 0x0000000080428f90 [2021-09-02 16:50:12.525] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.525] X4 = 0x0000000000000018 X5 = 0x0000000080428f90 [2021-09-02 16:50:12.541] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.541] X8 = 0x0000000080428fa0 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.541] X10 = 0x0000000080428fe0 X11 = 0x0000000080428fe0 [2021-09-02 16:50:12.557] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.557] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.557] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.557] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.573] X20 = 0x00000000800c2008 X21 = 0x000000000000000a [2021-09-02 16:50:12.573] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.573] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.573] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.588] X28 = 0x0000000000000000 X29 = 0x0000000080428f80 [2021-09-02 16:50:12.588] X30 = 0x0000000000000000 SP = 0x0000000080428f80 [2021-09-02 16:50:12.588] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.605] SPSR = 0x400003c5 [2021-09-02 16:50:12.605] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.605] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.605] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.622] Main handle: 0x0. [2021-09-02 16:50:12.622] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.622] Main stack size: 0x80000. [2021-09-02 16:50:12.622] X0 = 0x0000000000000018 X1 = 0x0000000080428bf0 [2021-09-02 16:50:12.622] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.638] X4 = 0x0000000000000018 X5 = 0x0000000080428bf0 [2021-09-02 16:50:12.638] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.638] X8 = 0x0000000080428c00 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.638] X10 = 0x0000000080428c40 X11 = 0x0000000080428c40 [2021-09-02 16:50:12.653] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.653] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.653] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.671] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.671] X20 = 0x00000000800c2008 X21 = 0x000000000000000b [2021-09-02 16:50:12.671] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.671] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.685] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.685] X28 = 0x0000000000000000 X29 = 0x0000000080428be0 [2021-09-02 16:50:12.685] X30 = 0x0000000000000000 SP = 0x0000000080428be0 [2021-09-02 16:50:12.685] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.701] SPSR = 0x400003c5 [2021-09-02 16:50:12.701] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.701] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.717] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.717] Main handle: 0x0. [2021-09-02 16:50:12.717] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.717] Main stack size: 0x80000. [2021-09-02 16:50:12.717] X0 = 0x0000000000000018 X1 = 0x0000000080428850 [2021-09-02 16:50:12.717] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.733] X4 = 0x0000000000000018 X5 = 0x0000000080428850 [2021-09-02 16:50:12.733] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.733] X8 = 0x0000000080428860 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.748] X10 = 0x00000000804288a0 X11 = 0x00000000804288a0 [2021-09-02 16:50:12.748] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.748] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.748] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.765] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.765] X20 = 0x00000000800c2008 X21 = 0x000000000000000c [2021-09-02 16:50:12.765] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.781] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.781] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.781] X28 = 0x0000000000000000 X29 = 0x0000000080428840 [2021-09-02 16:50:12.781] X30 = 0x0000000000000000 SP = 0x0000000080428840 [2021-09-02 16:50:12.797] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.797] SPSR = 0x400003c5 [2021-09-02 16:50:12.797] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.797] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.813] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.813] Main handle: 0x0. [2021-09-02 16:50:12.813] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.813] Main stack size: 0x80000. [2021-09-02 16:50:12.813] X0 = 0x0000000000000018 X1 = 0x00000000804284b0 [2021-09-02 16:50:12.829] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.829] X4 = 0x0000000000000018 X5 = 0x00000000804284b0 [2021-09-02 16:50:12.829] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.829] X8 = 0x00000000804284c0 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.845] X10 = 0x0000000080428500 X11 = 0x0000000080428500 [2021-09-02 16:50:12.845] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.845] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.861] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.861] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.861] X20 = 0x00000000800c2008 X21 = 0x000000000000000d [2021-09-02 16:50:12.861] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.877] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.877] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.877] X28 = 0x0000000000000000 X29 = 0x00000000804284a0 [2021-09-02 16:50:12.893] X30 = 0x0000000000000000 SP = 0x00000000804284a0 [2021-09-02 16:50:12.893] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.893] SPSR = 0x400003c5 [2021-09-02 16:50:12.893] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:12.909] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:12.909] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:12.909] Main handle: 0x0. [2021-09-02 16:50:12.909] Main stack base: 0x803ab3c0. [2021-09-02 16:50:12.909] Main stack size: 0x80000. [2021-09-02 16:50:12.925] X0 = 0x0000000000000018 X1 = 0x0000000080428110 [2021-09-02 16:50:12.925] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:12.925] X4 = 0x0000000000000018 X5 = 0x0000000080428110 [2021-09-02 16:50:12.925] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:12.941] X8 = 0x0000000080428120 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:12.941] X10 = 0x0000000080428160 X11 = 0x0000000080428160 [2021-09-02 16:50:12.941] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:12.941] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:12.957] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:12.957] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:12.957] X20 = 0x00000000800c2008 X21 = 0x000000000000000e [2021-09-02 16:50:12.973] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:12.973] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:12.973] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:12.973] X28 = 0x0000000000000000 X29 = 0x0000000080428100 [2021-09-02 16:50:12.990] X30 = 0x0000000000000000 SP = 0x0000000080428100 [2021-09-02 16:50:12.990] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:12.990] SPSR = 0x400003c5 [2021-09-02 16:50:12.990] ti.sysbios.family.arm.gicv3.Hwi: line 1128: E_exception: A hardware exception has occurred. [2021-09-02 16:50:13.006] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.006] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.006] Main handle: 0x0. [2021-09-02 16:50:13.006] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.022] Main stack size: 0x80000. [2021-09-02 16:50:13.022] X0 = 0x0000000000000018 X1 = 0x0000000080427d70 [2021-09-02 16:50:13.022] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.022] X4 = 0x0000000000000018 X5 = 0x0000000080427d70 [2021-09-02 16:50:13.037] X6 = 0xcccccccccccccccd X7 = 0x00000000800b11c8 [2021-09-02 16:50:13.037] X8 = 0x0000000080427d80 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.037] X10 = 0x0000000080427dc0 X11 = 0x0000000080427dc0 [2021-09-02 16:50:13.037] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.056] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.056] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.056] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.056] X20 = 0x00000000800c2008 X21 = 0x000000000000000f [2021-09-02 16:50:13.071] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.071] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.071] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.089] X28 = 0x0000000000000000 X29 = 0x0000000080427d60 [2021-09-02 16:50:13.089] X30 = 0x0000000000000000 SP = 0x0000000080427d60 [2021-09-02 16:50:13.089] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.089] SPSR = 0x400003c5 [2021-09-02 16:50:13.089] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.103] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.103] Main handle: 0x0. [2021-09-02 16:50:13.103] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.103] Main stack size: 0x80000. [2021-09-02 16:50:13.103] X0 = 0x0000000000000018 X1 = 0x00000000804279d0 [2021-09-02 16:50:13.117] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.117] X4 = 0x0000000000000018 X5 = 0x00000000804279d0 [2021-09-02 16:50:13.117] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.133] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.133] X10 = 0x0000000080427ad0 X11 = 0x0000000080427ad0 [2021-09-02 16:50:13.133] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.133] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.149] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.149] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.149] X20 = 0x00000000800c2008 X21 = 0x0000000000000010 [2021-09-02 16:50:13.149] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.165] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.165] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.165] X28 = 0x0000000000000000 X29 = 0x00000000804279c0 [2021-09-02 16:50:13.181] X30 = 0x0000000000000000 SP = 0x00000000804279c0 [2021-09-02 16:50:13.181] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.181] SPSR = 0x400003c5 [2021-09-02 16:50:13.181] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.181] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.199] Main handle: 0x0. [2021-09-02 16:50:13.199] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.199] Main stack size: 0x80000. [2021-09-02 16:50:13.199] X0 = 0x0000000000000018 X1 = 0x0000000080427630 [2021-09-02 16:50:13.199] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.214] X4 = 0x0000000000000018 X5 = 0x0000000080427630 [2021-09-02 16:50:13.214] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.214] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.214] X10 = 0x0000000080427730 X11 = 0x0000000080427730 [2021-09-02 16:50:13.230] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.230] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.230] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.246] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.246] X20 = 0x00000000800c2008 X21 = 0x0000000000000011 [2021-09-02 16:50:13.246] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.246] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.261] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.261] X28 = 0x0000000000000000 X29 = 0x0000000080427620 [2021-09-02 16:50:13.261] X30 = 0x0000000000000000 SP = 0x0000000080427620 [2021-09-02 16:50:13.277] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.277] SPSR = 0x400003c5 [2021-09-02 16:50:13.277] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.277] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.277] Main handle: 0x0. [2021-09-02 16:50:13.277] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.293] Main stack size: 0x80000. [2021-09-02 16:50:13.293] X0 = 0x0000000000000018 X1 = 0x0000000080427290 [2021-09-02 16:50:13.293] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.293] X4 = 0x0000000000000018 X5 = 0x0000000080427290 [2021-09-02 16:50:13.309] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.309] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.309] X10 = 0x0000000080427390 X11 = 0x0000000080427390 [2021-09-02 16:50:13.309] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.325] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.325] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.325] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.341] X20 = 0x00000000800c2008 X21 = 0x0000000000000012 [2021-09-02 16:50:13.341] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.341] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.341] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.357] X28 = 0x0000000000000000 X29 = 0x0000000080427280 [2021-09-02 16:50:13.357] X30 = 0x0000000000000000 SP = 0x0000000080427280 [2021-09-02 16:50:13.357] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.357] SPSR = 0x400003c5 [2021-09-02 16:50:13.373] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.373] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.373] Main handle: 0x0. [2021-09-02 16:50:13.373] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.373] Main stack size: 0x80000. [2021-09-02 16:50:13.373] X0 = 0x0000000000000018 X1 = 0x0000000080426ef0 [2021-09-02 16:50:13.390] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.390] X4 = 0x0000000000000018 X5 = 0x0000000080426ef0 [2021-09-02 16:50:13.390] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.405] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.405] X10 = 0x0000000080426ff0 X11 = 0x0000000080426ff0 [2021-09-02 16:50:13.405] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.405] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.421] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.421] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.421] X20 = 0x00000000800c2008 X21 = 0x0000000000000013 [2021-09-02 16:50:13.421] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.438] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.438] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.438] X28 = 0x0000000000000000 X29 = 0x0000000080426ee0 [2021-09-02 16:50:13.453] X30 = 0x0000000000000000 SP = 0x0000000080426ee0 [2021-09-02 16:50:13.453] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.453] SPSR = 0x400003c5 [2021-09-02 16:50:13.453] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.453] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.472] Main handle: 0x0. [2021-09-02 16:50:13.472] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.472] Main stack size: 0x80000. [2021-09-02 16:50:13.472] X0 = 0x0000000000000018 X1 = 0x0000000080426b50 [2021-09-02 16:50:13.472] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.485] X4 = 0x0000000000000018 X5 = 0x0000000080426b50 [2021-09-02 16:50:13.485] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.485] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.501] X10 = 0x0000000080426c50 X11 = 0x0000000080426c50 [2021-09-02 16:50:13.501] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.501] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.501] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.517] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.517] X20 = 0x00000000800c2008 X21 = 0x0000000000000014 [2021-09-02 16:50:13.517] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.517] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.533] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.533] X28 = 0x0000000000000000 X29 = 0x0000000080426b40 [2021-09-02 16:50:13.533] X30 = 0x0000000000000000 SP = 0x0000000080426b40 [2021-09-02 16:50:13.549] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.549] SPSR = 0x400003c5 [2021-09-02 16:50:13.549] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.549] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.549] Main handle: 0x0. [2021-09-02 16:50:13.565] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.565] Main stack size: 0x80000. [2021-09-02 16:50:13.565] X0 = 0x0000000000000018 X1 = 0x00000000804267b0 [2021-09-02 16:50:13.565] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.565] X4 = 0x0000000000000018 X5 = 0x00000000804267b0 [2021-09-02 16:50:13.580] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.580] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.580] X10 = 0x00000000804268b0 X11 = 0x00000000804268b0 [2021-09-02 16:50:13.580] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.597] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.597] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.597] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.613] X20 = 0x00000000800c2008 X21 = 0x0000000000000015 [2021-09-02 16:50:13.613] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.613] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.613] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.629] X28 = 0x0000000000000000 X29 = 0x00000000804267a0 [2021-09-02 16:50:13.629] X30 = 0x0000000000000000 SP = 0x00000000804267a0 [2021-09-02 16:50:13.629] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.629] SPSR = 0x400003c5 [2021-09-02 16:50:13.645] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.645] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.645] Main handle: 0x0. [2021-09-02 16:50:13.645] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.645] Main stack size: 0x80000. [2021-09-02 16:50:13.645] X0 = 0x0000000000000018 X1 = 0x0000000080426410 [2021-09-02 16:50:13.660] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.660] X4 = 0x0000000000000018 X5 = 0x0000000080426410 [2021-09-02 16:50:13.660] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.677] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.677] X10 = 0x0000000080426510 X11 = 0x0000000080426510 [2021-09-02 16:50:13.677] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.677] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.693] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.693] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.693] X20 = 0x00000000800c2008 X21 = 0x0000000000000016 [2021-09-02 16:50:13.709] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.709] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.709] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.709] X28 = 0x0000000000000000 X29 = 0x0000000080426400 [2021-09-02 16:50:13.725] X30 = 0x0000000000000000 SP = 0x0000000080426400 [2021-09-02 16:50:13.725] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.725] SPSR = 0x400003c5 [2021-09-02 16:50:13.725] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.725] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.740] Main handle: 0x0. [2021-09-02 16:50:13.740] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.740] Main stack size: 0x80000. [2021-09-02 16:50:13.740] X0 = 0x0000000000000018 X1 = 0x0000000080426070 [2021-09-02 16:50:13.740] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.757] X4 = 0x0000000000000018 X5 = 0x0000000080426070 [2021-09-02 16:50:13.757] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.757] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.773] X10 = 0x0000000080426170 X11 = 0x0000000080426170 [2021-09-02 16:50:13.773] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.773] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.773] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.789] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.789] X20 = 0x00000000800c2008 X21 = 0x0000000000000017 [2021-09-02 16:50:13.789] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.789] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.805] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.805] X28 = 0x0000000000000000 X29 = 0x0000000080426060 [2021-09-02 16:50:13.805] X30 = 0x0000000000000000 SP = 0x0000000080426060 [2021-09-02 16:50:13.821] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.821] SPSR = 0x400003c5 [2021-09-02 16:50:13.821] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.821] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.821] Main handle: 0x0. [2021-09-02 16:50:13.837] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.837] Main stack size: 0x80000. [2021-09-02 16:50:13.837] X0 = 0x0000000000000018 X1 = 0x0000000080425cd0 [2021-09-02 16:50:13.837] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.837] X4 = 0x0000000000000018 X5 = 0x0000000080425cd0 [2021-09-02 16:50:13.854] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.854] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.854] X10 = 0x0000000080425dd0 X11 = 0x0000000080425dd0 [2021-09-02 16:50:13.854] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.869] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.869] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.869] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.888] X20 = 0x00000000800c2008 X21 = 0x0000000000000018 [2021-09-02 16:50:13.888] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.888] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.888] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.902] X28 = 0x0000000000000000 X29 = 0x0000000080425cc0 [2021-09-02 16:50:13.902] X30 = 0x0000000000000000 SP = 0x0000000080425cc0 [2021-09-02 16:50:13.902] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.902] SPSR = 0x400003c5 [2021-09-02 16:50:13.918] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:13.918] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:13.918] Main handle: 0x0. [2021-09-02 16:50:13.918] Main stack base: 0x803ab3c0. [2021-09-02 16:50:13.918] Main stack size: 0x80000. [2021-09-02 16:50:13.933] X0 = 0x0000000000000018 X1 = 0x0000000080425930 [2021-09-02 16:50:13.933] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:13.933] X4 = 0x0000000000000018 X5 = 0x0000000080425930 [2021-09-02 16:50:13.933] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:13.949] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:13.949] X10 = 0x0000000080425a30 X11 = 0x0000000080425a30 [2021-09-02 16:50:13.949] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:13.949] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:13.965] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:13.965] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:13.965] X20 = 0x00000000800c2008 X21 = 0x0000000000000019 [2021-09-02 16:50:13.981] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:13.981] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:13.981] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:13.981] X28 = 0x0000000000000000 X29 = 0x0000000080425920 [2021-09-02 16:50:13.997] X30 = 0x0000000000000000 SP = 0x0000000080425920 [2021-09-02 16:50:13.997] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:13.997] SPSR = 0x400003c5 [2021-09-02 16:50:13.997] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.014] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.014] Main handle: 0x0. [2021-09-02 16:50:14.014] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.014] Main stack size: 0x80000. [2021-09-02 16:50:14.014] X0 = 0x0000000000000018 X1 = 0x0000000080425590 [2021-09-02 16:50:14.014] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.030] X4 = 0x0000000000000018 X5 = 0x0000000080425590 [2021-09-02 16:50:14.030] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.030] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.047] X10 = 0x0000000080425690 X11 = 0x0000000080425690 [2021-09-02 16:50:14.047] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.047] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.047] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.064] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.064] X20 = 0x00000000800c2008 X21 = 0x000000000000001a [2021-09-02 16:50:14.064] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.064] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.079] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.079] X28 = 0x0000000000000000 X29 = 0x0000000080425580 [2021-09-02 16:50:14.079] X30 = 0x0000000000000000 SP = 0x0000000080425580 [2021-09-02 16:50:14.096] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.096] SPSR = 0x400003c5 [2021-09-02 16:50:14.096] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.096] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.096] Main handle: 0x0. [2021-09-02 16:50:14.109] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.109] Main stack size: 0x80000. [2021-09-02 16:50:14.109] X0 = 0x0000000000000018 X1 = 0x00000000804251f0 [2021-09-02 16:50:14.109] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.109] X4 = 0x0000000000000018 X5 = 0x00000000804251f0 [2021-09-02 16:50:14.124] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.124] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.124] X10 = 0x00000000804252f0 X11 = 0x00000000804252f0 [2021-09-02 16:50:14.141] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.141] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.141] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.141] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.157] X20 = 0x00000000800c2008 X21 = 0x000000000000001b [2021-09-02 16:50:14.157] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.157] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.157] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.173] X28 = 0x0000000000000000 X29 = 0x00000000804251e0 [2021-09-02 16:50:14.173] X30 = 0x0000000000000000 SP = 0x00000000804251e0 [2021-09-02 16:50:14.173] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.189] SPSR = 0x400003c5 [2021-09-02 16:50:14.189] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.189] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.189] Main handle: 0x0. [2021-09-02 16:50:14.189] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.189] Main stack size: 0x80000. [2021-09-02 16:50:14.205] X0 = 0x0000000000000018 X1 = 0x0000000080424e50 [2021-09-02 16:50:14.205] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.205] X4 = 0x0000000000000018 X5 = 0x0000000080424e50 [2021-09-02 16:50:14.205] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.221] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.221] X10 = 0x0000000080424f50 X11 = 0x0000000080424f50 [2021-09-02 16:50:14.221] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.221] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.238] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.238] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.238] X20 = 0x00000000800c2008 X21 = 0x000000000000001c [2021-09-02 16:50:14.253] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.253] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.253] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.253] X28 = 0x0000000000000000 X29 = 0x0000000080424e40 [2021-09-02 16:50:14.272] X30 = 0x0000000000000000 SP = 0x0000000080424e40 [2021-09-02 16:50:14.272] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.272] SPSR = 0x400003c5 [2021-09-02 16:50:14.272] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.285] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.285] Main handle: 0x0. [2021-09-02 16:50:14.285] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.285] Main stack size: 0x80000. [2021-09-02 16:50:14.285] X0 = 0x0000000000000018 X1 = 0x0000000080424ab0 [2021-09-02 16:50:14.285] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.301] X4 = 0x0000000000000018 X5 = 0x0000000080424ab0 [2021-09-02 16:50:14.301] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.301] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.317] X10 = 0x0000000080424bb0 X11 = 0x0000000080424bb0 [2021-09-02 16:50:14.317] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.317] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.317] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.332] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.332] X20 = 0x00000000800c2008 X21 = 0x000000000000001d [2021-09-02 16:50:14.332] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.349] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.349] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.349] X28 = 0x0000000000000000 X29 = 0x0000000080424aa0 [2021-09-02 16:50:14.349] X30 = 0x0000000000000000 SP = 0x0000000080424aa0 [2021-09-02 16:50:14.365] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.365] SPSR = 0x400003c5 [2021-09-02 16:50:14.365] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.365] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.365] Main handle: 0x0. [2021-09-02 16:50:14.380] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.380] Main stack size: 0x80000. [2021-09-02 16:50:14.380] X0 = 0x0000000000000018 X1 = 0x0000000080424710 [2021-09-02 16:50:14.380] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.380] X4 = 0x0000000000000018 X5 = 0x0000000080424710 [2021-09-02 16:50:14.397] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.397] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.397] X10 = 0x0000000080424810 X11 = 0x0000000080424810 [2021-09-02 16:50:14.413] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.413] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.413] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.413] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.429] X20 = 0x00000000800c2008 X21 = 0x000000000000001e [2021-09-02 16:50:14.429] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.429] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.429] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.445] X28 = 0x0000000000000000 X29 = 0x0000000080424700 [2021-09-02 16:50:14.445] X30 = 0x0000000000000000 SP = 0x0000000080424700 [2021-09-02 16:50:14.445] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.460] SPSR = 0x400003c5 [2021-09-02 16:50:14.460] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.460] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.460] Main handle: 0x0. [2021-09-02 16:50:14.460] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.460] Main stack size: 0x80000. [2021-09-02 16:50:14.477] X0 = 0x0000000000000018 X1 = 0x0000000080424370 [2021-09-02 16:50:14.477] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.477] X4 = 0x0000000000000018 X5 = 0x0000000080424370 [2021-09-02 16:50:14.477] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.493] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.493] X10 = 0x0000000080424470 X11 = 0x0000000080424470 [2021-09-02 16:50:14.493] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.509] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.509] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.509] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.509] X20 = 0x00000000800c2008 X21 = 0x000000000000001f [2021-09-02 16:50:14.525] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.525] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.525] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.525] X28 = 0x0000000000000000 X29 = 0x0000000080424360 [2021-09-02 16:50:14.540] X30 = 0x0000000000000000 SP = 0x0000000080424360 [2021-09-02 16:50:14.540] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.540] SPSR = 0x400003c5 [2021-09-02 16:50:14.540] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.557] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.557] Main handle: 0x0. [2021-09-02 16:50:14.557] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.557] Main stack size: 0x80000. [2021-09-02 16:50:14.557] X0 = 0x0000000000000018 X1 = 0x0000000080423fd0 [2021-09-02 16:50:14.573] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.573] X4 = 0x0000000000000018 X5 = 0x0000000080423fd0 [2021-09-02 16:50:14.573] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.573] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.589] X10 = 0x00000000804240d0 X11 = 0x00000000804240d0 [2021-09-02 16:50:14.589] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.589] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.589] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.605] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.605] X20 = 0x00000000800c2008 X21 = 0x0000000000000020 [2021-09-02 16:50:14.605] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.621] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.621] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.621] X28 = 0x0000000000000000 X29 = 0x0000000080423fc0 [2021-09-02 16:50:14.621] X30 = 0x0000000000000000 SP = 0x0000000080423fc0 [2021-09-02 16:50:14.637] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.637] SPSR = 0x400003c5 [2021-09-02 16:50:14.637] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.637] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.654] Main handle: 0x0. [2021-09-02 16:50:14.654] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.654] Main stack size: 0x80000. [2021-09-02 16:50:14.654] X0 = 0x0000000000000018 X1 = 0x0000000080423c30 [2021-09-02 16:50:14.654] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.654] X4 = 0x0000000000000018 X5 = 0x0000000080423c30 [2021-09-02 16:50:14.669] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.669] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.669] X10 = 0x0000000080423d30 X11 = 0x0000000080423d30 [2021-09-02 16:50:14.688] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.688] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.688] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.688] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.701] X20 = 0x00000000800c2008 X21 = 0x0000000000000021 [2021-09-02 16:50:14.701] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.701] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.717] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.717] X28 = 0x0000000000000000 X29 = 0x0000000080423c20 [2021-09-02 16:50:14.717] X30 = 0x0000000000000000 SP = 0x0000000080423c20 [2021-09-02 16:50:14.717] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.735] SPSR = 0x400003c5 [2021-09-02 16:50:14.735] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.735] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.735] Main handle: 0x0. [2021-09-02 16:50:14.735] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.735] Main stack size: 0x80000. [2021-09-02 16:50:14.751] X0 = 0x0000000000000018 X1 = 0x0000000080423890 [2021-09-02 16:50:14.751] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.751] X4 = 0x0000000000000018 X5 = 0x0000000080423890 [2021-09-02 16:50:14.751] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.767] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.767] X10 = 0x0000000080423990 X11 = 0x0000000080423990 [2021-09-02 16:50:14.767] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.784] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.784] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.784] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.784] X20 = 0x00000000800c2008 X21 = 0x0000000000000022 [2021-09-02 16:50:14.799] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.799] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.799] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.799] X28 = 0x0000000000000000 X29 = 0x0000000080423880 [2021-09-02 16:50:14.816] X30 = 0x0000000000000000 SP = 0x0000000080423880 [2021-09-02 16:50:14.816] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.816] SPSR = 0x400003c5 [2021-09-02 16:50:14.816] xdc.runtime.Error.raise: terminating execution [2021-09-02 16:50:14.831] Synchronous Exception occurred in ThreadType_Main. [2021-09-02 16:50:14.831] Main handle: 0x0. [2021-09-02 16:50:14.831] Main stack base: 0x803ab3c0. [2021-09-02 16:50:14.831] Main stack size: 0x80000. [2021-09-02 16:50:14.831] X0 = 0x0000000000000018 X1 = 0x00000000804234f0 [2021-09-02 16:50:14.848] X2 = 0x0000000000000006 X3 = 0x0000000000000001 [2021-09-02 16:50:14.848] X4 = 0x0000000000000018 X5 = 0x00000000804234f0 [2021-09-02 16:50:14.848] X6 = 0x0000000000000000 X7 = 0x0000000000000000 [2021-09-02 16:50:14.848] X8 = 0x0000000000000001 X9 = 0xffffff80ffffffc8 [2021-09-02 16:50:14.863] X10 = 0x00000000804235f0 X11 = 0x00000000804235f0 [2021-09-02 16:50:14.863] X12 = 0x00000000800c2008 X13 = 0x00000000803ab000 [2021-09-02 16:50:14.863] X14 = 0x0000000000018000 X15 = 0xfffffffffffffff8 [2021-09-02 16:50:14.863] X16 = 0x0000000000000065 X17 = 0xfffffffffffffff8 [2021-09-02 16:50:14.879] X18 = 0x0000000000018000 X19 = 0x00000000803ab000 [2021-09-02 16:50:14.879] X20 = 0x00000000800c2008 X21 = 0x0000000000000023 [2021-09-02 16:50:14.879] X22 = 0x0000000000000001 X23 = 0x0000000000000468 [2021-09-02 16:50:14.895] X24 = 0x0000000000000000 X25 = 0x0000000000000000 [2021-09-02 16:50:14.895] X26 = 0x00000000800b77a0 X27 = 0x0000000000000006 [2021-09-02 16:50:14.895] X28 = 0x0000000000000000 X29 = 0x00000000804234e0 [2021-09-02 16:50:14.895] X30 = 0x0000000000000000 SP = 0x00000000804234e0 [2021-09-02 16:50:14.911] ELR = 0x0000000080032c98 ESR = 0x02000000 [2021-09-02 16:50:14.911] SPSR = 0x400003c5
Sometimes FTP server doesn't respond due to overloading, and it causes recv(CONN) error(35).
It's expected error, but behind one is not.
It looks NDK failed to free memory, and then TI-RTOS failed to allocate heap.
Do you have any idea to avoid this?
Thanks and Best Regards,
Junpei
