TMDX654GPEVM: Upgrade from CCS 10.3.1 to 10.4.0 gives "Errors during memory.readData()" when running launch.js
Part Number: TMDX654GPEVM
Hi Experts,
On the Scripting Console of CCS 10.4.0, executing the launch.js of pdk_am65xx_07_03_00_54 and pdk_am65xx_08_00_00_36 gives the following error:
js:> load("C:\\ti\\pdk_am65xx_08_00_00_36\\packages\\ti\\drv\\sciclient\\tools\\ccsLoadDmsc\\am65xx\\launch.js")
Connecting to DMSC_Cortex_M3_0!
Loading DMSC Firmware...
DMSC Firmware Load Done...
DMSC Firmware run starting now...
Connecting to MCU Cortex_R5_0!
Running the board configuration initialization from R5!
Initializing DDR!
Some error in GEL execution for DDR4_CONFIG
Running DDR Memory Checks....
Error reading memory: Errors during memory.readData(): Address: 0x43000014 Error: 0x400000
(C:\ti\pdk_am65xx_08_00_00_36\packages\ti\drv\sciclient\tools\ccsLoadDmsc\am65xx\launch.js#102)
On CCS 10.3.1, both scripts run successfully. Am I missing some settings on the newly installed CCS 10.4.0?
Many thanks,
Kawai
  • Testing again with CCS 10.3.1 seems to indicate that the culprit is in pdk_am65xx_08_00_00_36's launch.js.
    The above use case is working fine on my setup. I have verified with CCS 10.4.0 and pdk_am65xx_08_00_00_36. PFA for my launch.js file and execution video.
     * Copyright (c) 2017-2020, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    //File Name: launch_am65xx.js
    //Description:
    //   Launch the DMSC firmware and board configuration from R5F.
    //Usage:
    //From CCS Scripting console
    //  1. loadJSFile "C:\\ti\\launch_am65xx.js"
    //     <Ignore the error observed on the CCS scripting console
    //     "Wrapped java.io.IOException: The handle is invalid (<location_of_script>\
    //     launch_am65xx.js#93)">
    //Note:
    //  1. Search for "edit this" to look at changes that need to be edited
    //     for your usage.
    //<!!!!!! EDIT THIS !!!!!>
    // Set this to 1 to allow loading the GEL files directly from the ccxml file.
    disableGelLoad = 1;
    if (disableGelLoad == 0)
        //Path to GEL files
        gelFilePath = "/ti/ccs910/ccs/ccs_base/emulation/boards/am65x/gel";
    // Path to the directory in which this file would be residing. CCS expects
    // absolute paths to load the binaries.
    thisJsFileDirectory = "C:/ti/pdk_am65xx_08_00_00_36/packages/ti/drv/sciclient/tools/ccsLoadDmsc/am65xx";
    // Import the DSS packages into our namespace to save on typing
    importPackage(Packages.com.ti.debug.engine.scripting)
    importPackage(Packages.com.ti.ccstudio.scripting.environment)
    importPackage(Packages.java.lang)
    importPackage(java.io);
    importPackage(java.lang);
    function updateScriptVars()
        //Open a debug session
        dsMCU1_0 = debugServer.openSession( ".*MCU_PULSAR_Cortex_R5_0" );
        dsDMSC_0 = debugServer.openSession( ".*DMSC_Cortex_M3_0" );
    function printVars()
        updateScriptVars();
    function connectTargets()
        /* Set timeout of 20 seconds */
        script.setScriptTimeout(60000);
        updateScriptVars();
        sysResetVar=dsDMSC_0.target.getResetType(1);
        sysResetVar.issueReset();
        print("Connecting to DMSC_Cortex_M3_0!");
            // Load the GEL. This can be removed if the GEL is already linked with the target ccxml
            dsDMSC_0.expression.evaluate('GEL_LoadGel("'+gelFilePath+'/AM65xEVM.gel")');
        // Connect targets
        dsDMSC_0.target.connect();
        dsMCU1_0.target.connect();
        // Read the Device ID to load the correct SYSFW
        dev_id = dsMCU1_0.memory.readWord(0, 0x43000014); // CSL_WKUP_CTRL_MMR0_CFG0_BASE + CSL_WKUP_CTRL_MMR_CFG0_JTAGID
        print("Loading DMSC Firmware...");
        // Load the DMSC firmware
        if (dev_id == 0x0BB5A02F) {
            dsDMSC_0.memory.loadRaw(0, 0x40000, thisJsFileDirectory +"/../../../soc/sysfw/binaries/ti-sci-firmware-am65x-gp.bin", 32, false);
        } else if (dev_id == 0x1BB5A02F) {
            dsDMSC_0.memory.loadRaw(0, 0x40000, thisJsFileDirectory +"/../../../soc/sysfw/binaries/ti-sci-firmware-am65x_sr2-gp.bin", 32, false);
        } else {
            print("Invalid Device ID!");
            return;
        print("DMSC Firmware Load Done...");
        // Set Stack pointer and Program Counter
        stackPointer = dsDMSC_0.memory.readWord(0, 0x40000);
        progCounter = dsDMSC_0.memory.readWord(0, 0x40004);
        dsDMSC_0.memory.writeRegister("SP", stackPointer);
        dsDMSC_0.memory.writeRegister("PC", progCounter);
        print( "DMSC Firmware run starting now...");
        // Run the DMSC firmware
        dsDMSC_0.target.runAsynch();
        print("Connecting to MCU Cortex_R5_0!");
        // Connect the MCU R5F
            dsMCU1_0.expression.evaluate('GEL_LoadGel("'+gelFilePath+'/M4_DDR39SS/M4_R5orA53_Startup.gel")');
        print("Running the board configuration initialization from R5!");
        // Load the board configuration init file.
        dsMCU1_0.memory.loadProgram(thisJsFileDirectory +"/sciclient_ccs_init_mcu1_0_release.xer5f");
        // Halt the R5F and re-run.
        dsMCU1_0.target.halt();
        dsMCU1_0.target.reset();
        dsMCU1_0.target.restart();
        // Run Synchronously for the executable to finish
        dsMCU1_0.target.run();
    function disconnectTargets()
        updateScriptVars();
        // Disconnect targets
        dsDMSC_0.target.disconnect();
        // Reset the R5F to be in clean state.
        print("Initializing DDR!");
        // Execute DDR initialization script from R5F.
        try
            dsMCU1_0.expression.evaluate("DDR4_800MHz_Initialization_for_EVM()");
            dsMCU1_0.expression.evaluate("timer0_cleanup()");
        catch(e)
            print("Some error in GEL execution for DDR4_CONFIG");
    function sampleDDRCheck ()
        print("Running DDR Memory Checks....");
        dsMCU1_0.memory.fill (0x80000000, 0, 1024, 0xA5A5A5A5);
        ar = dsMCU1_0.memory.readWord(0, 0x80000000, 1024);
        fail = 0
        for (i = 0; i < ar.length; i++) {
                x = ar[i];
                if (x != 0xA5A5A5A5)
                    fail = 1;
        if (fail == 1)
            print ("0x80000000: DDR memory sample check failed !!");
        dsMCU1_0.memory.fill (0x81000000, 0, 1024, 0x5A5A5A5A);
        ar = dsMCU1_0.memory.readWord(0, 0x81000000, 1024);
        fail = 0
                x = ar[i];
                if (x != 0x5a5a5a5a)
                    fail = 1;
        if (fail == 1)
            print ("0x81000000: DDR memory sample check failed !!");
    function doEverything()
        printVars();
        connectTargets();
        disconnectTargets();
        sampleDDRCheck ();
        print("Happy Debugging!!");
    var ds;
    var debugServer;
    var script;
    // Check to see if running from within CCSv4 Scripting Console
    var withinCCS = (ds !== undefined);
    // Create scripting environment and get debug server if running standalone
    if (!withinCCS)
        importPackage(Packages.com.ti.debug.engine.scripting);
        importPackage(Packages.com.ti.ccstudio.scripting.environment);
        importPackage(Packages.java.lang);
        // Create our scripting environment object - which is the main entry point into any script and
        // the factory for creating other Scriptable ervers and Sessions
        script = ScriptingEnvironment.instance();
        // Get the Debug Server and start a Debug Session
        debugServer = script.getServer("DebugServer.1");
    else // otherwise leverage existing scripting environment and debug server
        debugServer = ds;
        script = env;
    doEverything();
