Other Parts Discussed in Thread: CCSTUDIO
Code Composer Studio V7 will not open. The launching screen will open but get frozen there. I have tried restarting my computer several times. I recently installed and uninstalled Code Composer Studio v8 & v10 before the issue. I noticed my computer was restarted this morning when I returned to it, so maybe that has something to do with it. I would rather not have to uninstall code composer v7 and reinstall it. Here is my log file.
!ENTRY org.eclipse.equinox.event 4 0 2021-09-15 13:21:27.300
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@364863 (elementId: org.eclipse.debug.ui.BreakpointView, tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@5ab16, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@364863 (elementId: org.eclipse.debug.ui.BreakpointView, tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@5ab16, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=11, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@8684a3 (elementId: org.eclipse.debug.ui.breakpointsView.toolbar.linkWithDebugView, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=11, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@8684a3 (elementId: org.eclipse.debug.ui.breakpointsView.toolbar.linkWithDebugView, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@c3627c
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:64)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:80)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:341)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.reconcileManagerToModel(ToolBarManagerRenderer.java:925)
at org.eclipse.ui.internal.e4.compatibility.ActionBars.updateActionBars(ActionBars.java:99)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView$1.compute(CompatibilityView.java:195)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.postProcess(ToolBarManagerRenderer.java:958)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.adjustTopRight(StackRenderer.java:817)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1333)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:142)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:63)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:725)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1059)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Caused by: java.lang.NullPointerException
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.setStackVisibility(ModelServiceImpl.java:1080)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.setStackVisibility(ModelServiceImpl.java:1089)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.hideLocalPlaceholders(ModelServiceImpl.java:1069)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeChildrenHandler(PartRenderingEngine.java:317)
at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:54)
... 110 more
!ENTRY com.ti.ccstudio.app.center 4 0 2021-09-15 13:21:32.467
!MESSAGE An internal error was logged by 'com.ti.ccstudio.app.center'.
!STACK 0
org.json.JSONException: A JSONObject text must begin with '{' at 1 [character 2 line 1]
at org.json.JSONTokener.syntaxError(JSONTokener.java:433)
at org.json.JSONObject.<init>(JSONObject.java:189)
at org.json.JSONObject.<init>(JSONObject.java:316)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.processImports(CCSAppCenter.java:257)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.getAppJson_0(CCSAppCenter.java:220)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$1(CCSAppCenter.java:211)
at com.ti.ccstudio.app.center.internal.CCSAppCenter$1.run(CCSAppCenter.java:183)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!ENTRY com.ti.ccstudio.app.center 4 0 2021-09-15 13:21:32.470
!STACK 0
at com.ti.ccstudio.app.center.internal.CCSAppCenter.convertToFullpaths(CCSAppCenter.java:331)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.getAppJson_0(CCSAppCenter.java:229)
!ENTRY com.ti.ccstudio.app.center 4 0 2021-09-15 13:21:32.484
!STACK 0
at com.ti.ccstudio.app.center.internal.CCSAppCenter._replaceIusWithLatest(CCSAppCenter.java:367)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$3(CCSAppCenter.java:364)
at com.ti.ccstudio.app.center.internal.CCSAppCenter$2.run(CCSAppCenter.java:240)
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 0 2021-09-15 13:21:38.635
!MESSAGE Unexpected error loading extension: org.eclipse.equinox.p2.metadata.repository.XZedRepository
!STACK 0
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:397)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.readInto(FileReader.java:358)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:101)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:156)
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:402)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCacheFromFile(CacheManager.java:132)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.getLocalFile(XZedSimpleMetadataRepositoryFactory.java:56)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.load(XZedSimpleMetadataRepositoryFactory.java:78)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:151)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:129)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:73)
!MESSAGE Unexpected error loading extension: org.eclipse.equinox.p2.metadata.repository.simpleRepository
!STACK 0
java.lang.IllegalArgumentException: Cache manager service not available
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:65)
at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88)
!ENTRY org.eclipse.equinox.p2.updatechecker 4 0 2021-09-15 13:21:38.635
!MESSAGE Exception in update check thread
!STACK 0
java.lang.IllegalStateException: BundleContext is no longer valid
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:984)
at org.eclipse.osgi.internal.framework.BundleContextImpl.getServiceReference(BundleContextImpl.java:559)
at org.eclipse.osgi.internal.framework.BundleContextImpl.getServiceReference(BundleContextImpl.java:1011)
at org.eclipse.equinox.internal.p2.core.helpers.ServiceHelper.getService(ServiceHelper.java:27)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getSharedPreferences(AbstractRepositoryManager.java:512)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.restoreRepositories(AbstractRepositoryManager.java:1016)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getRepositoryProperty(AbstractRepositoryManager.java:564)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:686)
!SESSION 2021-09-15 13:39:07.836 -----------------------------------------------
eclipse.buildId=4.6.0.I20160606-1100
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 4 0 2021-09-15 13:39:08.739
!MESSAGE path=ccs_base/DebugServer
!MESSAGE debugServerDir=C:/ti/ccsv7/ccs_base/DebugServer
!SESSION 2021-09-16 09:10:35.660 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-09-16 09:10:36.577
!SESSION 2021-09-16 09:13:49.712 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-09-16 09:13:50.594
!SESSION 2021-09-16 09:19:38.093 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-09-16 09:19:39.057
!SESSION 2021-09-16 10:10:12.663 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-09-16 10:10:13.561
!SESSION 2021-09-16 10:13:25.909 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-09-16 10:13:26.826
!SESSION 2021-09-16 10:15:38.573 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-09-16 10:15:39.452
!SESSION 2021-09-16 10:49:20.726 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-09-16 10:49:21.643
!SESSION 2021-09-16 10:55:10.495 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2021-09-16 10:55:11.410
