TDA4VM: Event clear
Part Number: TDA4VM
for event wait api is Event_pend
for event set api is Event_post
i do not find how to clear event.....
[Question:]
does TI RTOS support clear event?
    We don't have clear apis as such, but you can look into below file for all event related apis : ti-processor-sdk-rtos-j721e-evm-07_03_00_07\bios_6_83_02_07\packages\ti\sysbios\knl\Event.c.
    Attaching the same file.
     * Copyright (c) 2013-2018, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  ======== Event.c ========
     *  Implementation of functions specified in Event.xdc.
    #include <xdc/std.h>
    #include <xdc/runtime/Log.h>
    #include <xdc/runtime/Assert.h>
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Queue.h>
    #include <ti/sysbios/hal/Hwi.h>
    #include <ti/sysbios/knl/Swi.h>
    #define ti_sysbios_knl_Task__internalaccess
    #include <ti/sysbios/knl/Task.h>
    #include <ti/sysbios/knl/Clock.h>
    #include "package/internal/Event.xdc.h"
     *  Event uses Clock and Task. Queue and Hwi are fully
     *  unconstrained. Clock uses Swi. Swi and Task APIs are safe before
     *  BIOS_start() except for the user hooks.  Clock APIs are
     *  therefore also safe. No startup checks needed in Event.
     *  ======== Event_Instance_init ========
    /* MISRA.FUNC.UNUSEDPAR.2012 */
    Void Event_Instance_init(Event_Object *event, const Event_Params *params)
        Queue_Handle pendQ;
        event->postedEvents = 0U;
        pendQ = Event_Instance_State_pendQ(event);
        Queue_construct(Queue_struct(pendQ), NULL);
     *  ======== Event_pendTimeout ========
     *  called by Clock when timeout for a event expires
    Void Event_pendTimeout(UArg arg)
        UInt hwiKey;
        Event_PendElem *elem = (Event_PendElem *)xdc_uargToPtr(arg);
        hwiKey = Hwi_disable();
         *  Verify that Event_post() hasn't already serviced this qElem.
        if (elem->pendState == Event_PendState_CLOCK_WAIT) {
            /* remove eventElem from event_Elem queue */
            Queue_remove(&(elem->tpElem.qElem));
            elem->pendState = Event_PendState_TIMEOUT;
             *  put task back into readyQ
             *  No need for Task_disable/restore sandwich since this
             *  is called within Swi (or Hwi) thread
            Task_unblockI(elem->tpElem.taskHandle, hwiKey);
        Hwi_restore(hwiKey);
     *  ======== Event_checkEvents ========
     *  Checks postedEvents for matching event conditions.
     *  Returns matchingEvents if a match and consumes matched events,
     *  else returns 0 and consumes nothing.
     *  Called with ints disabled
    UInt Event_checkEvents (Event_Object *event, UInt andMask, UInt orMask)
        UInt matchingEvents;
        matchingEvents = orMask & event->postedEvents;
        if ((andMask & event->postedEvents) == andMask) {
            matchingEvents |= andMask;
        if (matchingEvents != (UInt)0) {
            /* consume ALL the matching events */
            event->postedEvents &= ~matchingEvents;
        return (matchingEvents);
     *  ======== Event_pend ========
    UInt Event_pend(Event_Object *event, UInt andMask, UInt orMask, UInt32 timeout)
        UInt hwiKey, tskKey;
        Event_PendElem elem;
        Queue_Handle pendQ;
        Clock_Struct clockStruct;
        Assert_isTrue(((andMask | orMask) != 0U), Event_A_nullEventMasks);
        /* MISRA.ETYPE.INAPPR.OPERAND.BINOP.2012 */
        Log_write5(Event_LM_pend, (UArg)event, (UArg)event->postedEvents,
                    (UArg)andMask, (UArg)orMask, (IArg)((Int)timeout));
         * elem is filled in entirely before interrupts are disabled.
         * This significantly reduces latency at the potential cost of wasted time
         * if it turns out that there is already an event match.
        /* init Clock object if timeout is not FOREVER nor NO_WAIT */
        if ((BIOS_clockEnabled != FALSE)
                && (timeout != BIOS_WAIT_FOREVER)
                && (timeout != BIOS_NO_WAIT)) {
            Clock_initI(Clock_handle(&clockStruct), (Clock_FuncPtr)Event_pendTimeout, timeout, (UArg)&elem);
            elem.tpElem.clockHandle = Clock_handle(&clockStruct);
            elem.pendState = Event_PendState_CLOCK_WAIT;
        else {
            elem.tpElem.clockHandle = NULL;
            elem.pendState = Event_PendState_WAIT_FOREVER;
        /* fill in this task's Event_PendElem */
        elem.andMask = andMask;
        elem.orMask = orMask;
        elem.matchingEvents = 0U;
        /* get task handle */
        elem.tpElem.taskHandle = Task_self();
        /* Atomically check for a match and block if none */
        /* check if events are already available */
        matchingEvents = Event_checkEvents(event, andMask, orMask);
        if (matchingEvents != 0U) {
            return (matchingEvents);/* yes, then return with matching bits */
        if (timeout == BIOS_NO_WAIT) {
            return (0);             /* No match, no wait */
        Assert_isTrue((BIOS_getThreadType() == BIOS_ThreadType_Task),
                            Event_A_badContext);
         * Verify that THIS core hasn't already disabled the scheduler
         * so that the Task_restore() call below will indeed block
        Assert_isTrue(Task_enabled() != FALSE, Event_A_pendTaskDisabled);
        /* lock scheduler */
        tskKey = Task_disable();
        /* only one Task allowed!!! */
        Assert_isTrue(Queue_empty(pendQ) != FALSE, Event_A_eventInUse);
        /* leave a pointer for Task_delete() */
        elem.tpElem.taskHandle->pendElem = (Task_PendElem *)&(elem.tpElem);
        /* add it to Event_PendElem queue */
        Queue_enqueue(pendQ, &(elem.tpElem.qElem));
        Task_blockI(elem.tpElem.taskHandle);
        if ((BIOS_clockEnabled != FALSE) &&
                (elem.tpElem.clockHandle != (Clock_Handle)NULL)) {
            Clock_enqueueI(elem.tpElem.clockHandle);
            Clock_startI(elem.tpElem.clockHandle);
        /* unlock task scheduler and block */
        Task_restore(tskKey);       /* the calling task will switch out here */
        /* Here on unblock due to Event_post or Event_pendTimeout */
        /* remove Clock object from Clock Q */
        if ((BIOS_clockEnabled != FALSE) && (elem.tpElem.clockHandle != (Clock_Handle)NULL)) {
            Clock_removeI(elem.tpElem.clockHandle);
        elem.tpElem.taskHandle->pendElem = NULL;
        /* event match? */
        if (elem.pendState != Event_PendState_TIMEOUT) {
            return (elem.matchingEvents);
        else {
            return (0);             /* timeout */
     *  ======== Event_post ========
    Void Event_post(Event_Object *event, UInt eventId)
        UInt tskKey, hwiKey;
        Event_PendElem *elem;
        Queue_Handle pendQ;
        Assert_isTrue((eventId != 0U), Event_A_nullEventId);
        Log_write3(Event_LM_post, (UArg)event, (UArg)event->postedEvents, (UArg)eventId);
        /* atomically post this event */
        /* or in this eventId */
        event->postedEvents |= eventId;
        /* confirm that ANY tasks are pending on this event */
        if (Queue_empty(pendQ) == TRUE) {
            return;
        /* examine pendElem on pendQ */
        elem = (Event_PendElem *)Queue_head(pendQ);
        /* check for match, consume matching eventIds if so. */
        elem->matchingEvents = Event_checkEvents(event, elem->andMask, elem->orMask);
        if (elem->matchingEvents != 0U) {
            /* remove event elem from elem queue */
            /* mark the Event as having been posted */
            elem->pendState = Event_PendState_POSTED;
            /* disable Clock object */
            if ((BIOS_clockEnabled != FALSE) && (elem->tpElem.clockHandle != NULL)) {
                Clock_stop(elem->tpElem.clockHandle);
            /* put task back into readyQ */
        /* context switch may occur here */
     *  ======== Event_sync ========
     *  Must be called with interrupts disabled!
    Void Event_sync(Event_Object *event, UInt eventId, UInt count)
        if (count != FALSE) {
        else {
            event->postedEvents &= ~eventId;
     *  ======== Event_getPostedEvents ========
    UInt Event_getPostedEvents(Event_Object *event)
        return (event->postedEvents);
