Other Parts Discussed in Thread: TCA6424,
Hi, I want to use cpsw9g port 5 to connect with bcm89881 by RGMII.
but when the system bring up,and after i run the vision_apps_init.sh, the "GenericPhy_reset" function will be called all the time.
i'm sure the reason is that "while (hMcm->timerTaskShutDownFlag != true)" this conditions is always be true, which located at enet_mcm.c, in "EnetMcm_periodicTick" function.
but i don't kown why ???????
My SDK version: ti-processor-sdk-rtos-j721e-evm-07_03_00_07
My PDK version: pdk_jacinto_07_03_00_29
My Cpsw9g ports config as below :
RGMII3 --> BCM89881
RGMII5 --> BCM89881
RGMII6 --> BCM89881
RGMII1 --> DP83867
My test data path is TDA4 --> CPSW9G -->RGMII5 --> BCM89881 --> T1 --> T1toRJ45 siwtch --> PC;
I will provide the hardware schematic later。
When the system bringup, run the vision_apps_init.sh ,the log is below:
root@j7-evm:~# root@j7-evm:~# cd /opt/vision_apps root@j7-evm:/opt/vision_apps# source ./vision_apps_init.sh root@j7-evm:/opt/vision_apps# [MCU2_0] 3.444721 s: CIO: Init ... Done !!! [MCU2_0] 3.444790 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [MCU2_0] 3.444830 s: APP: Init ... !!! [MCU2_0] 3.444848 s: SCICLIENT: Init ... !!! [MCU2_0] 3.445037 s: SCICLIENT: DMSC FW version [21.1.1--v2021.01a (Terrific Lla] [MCU2_0] 3.445071 s: SCICLIENT: DMSC FW revision 0x15 [MCU2_0] 3.445093 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 3.445115 s: SCICLIENT: Init ... Done !!! [MCU2_0] 3.445136 s: UDMA: Init ... !!! [MCU2_0] 3.446187 s: UDMA: Init ... Done !!! [MCU2_0] 3.446238 s: MEM: Init ... !!! [MCU2_0] 3.446271 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e1000000 of size 16777216 bytes !!! [MCU2_0] 3.446324 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 131072 bytes !!! [MCU2_0] 3.446369 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d8000000 of size 16777216 bytes !!! [MCU2_0] 3.446413 s: MEM: Init ... Done !!! [MCU2_0] 3.446432 s: IPC: Init ... !!! [MCU2_0] 3.446460 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 3.446493 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 30.893546 s: IPC: HLOS is ready !!! [MCU2_0] 30.899093 s: IPC: Init ... Done !!! [MCU2_0] 30.899154 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 30.917895 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 30.918062 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 30.919871 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 30.919932 s: ETHFW: Init ... !!! [MCU2_0] 30.940989 s: CPSW_9G Test on MAIN NAVSS [MCU2_0] 30.952818 s: [LXC] phyCfg->phyAddr = 12, portNum = 0 [MCU2_0] 30.952875 s: [untouch:liuxianchao] EthFw_initLinkArgs, macPort = 0, vlanCfg portCfi is 0, portPri is 0, portVID is 400 [MCU2_0] 30.953066 s: [LXC] phyCfg->phyAddr = 0, portNum = 2 [MCU2_0] 30.953106 s: [untouch:liuxianchao] EthFw_initLinkArgs, macPort = 2, vlanCfg portCfi is 0, portPri is 2, portVID is 402 [MCU2_0] 30.953490 s: EnetPhy_bindDriver: PHY 0: OUI:2b8094 Model:03 Ver:02 <-> 'generic' : OK [MCU2_0] 30.953582 s: [LXC] phyCfg->phyAddr = 0, portNum = 4 [MCU2_0] 30.953614 s: [untouch:liuxianchao] EthFw_initLinkArgs, macPort = 4, vlanCfg portCfi is 0, portPri is 4, portVID is 404 [MCU2_0] 30.953945 s: EnetPhy_bindDriver: PHY 0: OUI:2b8094 Model:03 Ver:02 <-> 'generic' : OK [MCU2_0] 30.954029 s: [LXC] phyCfg->phyAddr = 1, portNum = 5 [MCU2_0] 30.954060 s: [untouch:liuxianchao] EthFw_initLinkArgs, macPort = 5, vlanCfg portCfi is 0, portPri is 5, portVID is 405 [MCU2_0] 30.954433 s: EnetPhy_bindDriver: PHY 1: OUI:2b8094 Model:03 Ver:02 <-> 'generic' : OK [MCU2_0] 30.954498 s: PHY 0 is alive [MCU2_0] 30.954527 s: PHY 1 is alive [MCU2_0] 30.956292 s: ETHFW: Version : 0.01.01 [MCU2_0] 30.956347 s: ETHFW: Build Date: Sep 26, 2021 [MCU2_0] 30.956397 s: ETHFW: Build Time: 18:20:43 [MCU2_0] 30.956427 s: ETHFW: Commit SHA: a9710bfb [MCU2_0] 30.956456 s: ETHFW: Init ... DONE !!! [MCU2_0] 30.956480 s: ETHFW: Remove server Init ... !!! [MCU2_0] 30.957839 s: Remote demo device (core : mcu2_0) ..... [MCU2_0] 30.957904 s: ETHFW: Remove server Init ... DONE !!! [MCU2_0] 30.963890 s: Host MAC address: 70:ff:76:1d:92:c1 [MCU2_0] 31.007376 s: FVID2: Init ... !!! [MCU2_0] 31.007474 s: FVID2: Init ... Done !!! [MCU2_0] 31.007515 s: DSS: Init ... !!! [MCU2_0] 31.007536 s: DSS: Display type is eDP !!! [MCU2_0] 31.007557 s: DSS: SoC init ... !!! [MCU2_0] 31.007577 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2 [MCU2_0] 31.007723 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.007752 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2 [MCU2_0] 31.007890 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.007915 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2 [MCU2_0] 31.008014 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.008040 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11 [MCU2_0] 31.008115 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 31.008141 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18 [MCU2_0] 31.008207 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 31.008232 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2 [MCU2_0] 31.008291 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 31.008317 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000 [MCU2_0] 31.009303 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success [MCU2_0] 31.009339 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0 [MCU2_0] 31.009460 s: SCICLIENT: Sciclient_pmModuleClkRequest success [MCU2_0] 31.009492 s: DSS: SoC init ... Done !!! [MCU2_0] 31.009513 s: DSS: Board init ... !!! [MCU2_0] 31.009532 s: DSS: Board init ... Done !!! [MCU2_0] 31.027920 s: DSS: Init ... Done !!! [MCU2_0] 31.027979 s: VHWA: VPAC Init ... !!! [MCU2_0] 31.028005 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 31.028151 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.028179 s: VHWA: LDC Init ... !!! [MCU2_0] 31.031037 s: VHWA: LDC Init ... Done !!! [MCU2_0] 31.031087 s: VHWA: MSC Init ... !!! [MCU2_0] 31.039282 s: VHWA: MSC Init ... Done !!! [MCU2_0] 31.039330 s: VHWA: NF Init ... !!! [MCU2_0] 31.040792 s: VHWA: NF Init ... Done !!! [MCU2_0] 31.040841 s: VHWA: VISS Init ... !!! [MCU2_0] 31.046551 s: VHWA: VISS Init ... Done !!! [MCU2_0] 31.046602 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 31.046639 s: VX_ZONE_INIT:Enabled [MCU2_0] 31.046661 s: VX_ZONE_ERROR:Enabled [MCU2_0] 31.046680 s: VX_ZONE_WARNING:Enabled [MCU2_0] 31.047726 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target IPU1-0 [MCU2_0] 31.048005 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_NF [MCU2_0] 31.048267 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_LDC1 [MCU2_0] 31.048570 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC1 [MCU2_0] 31.048831 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC2 [MCU2_0] 31.049121 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_VISS1 [MCU2_0] 31.049457 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE1 [MCU2_0] 31.049759 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE2 [MCU2_0] 31.050039 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY1 [MCU2_0] 31.050324 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY2 [MCU2_0] 31.050646 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CSITX [MCU2_0] 31.050930 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE3 [MCU2_0] 31.051221 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE4 [MCU2_0] 31.051560 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE5 [MCU2_0] 31.051867 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE6 [MCU2_0] 31.052147 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE7 [MCU2_0] 31.052489 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE8 [MCU2_0] 31.052539 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [MCU2_0] 31.052567 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 31.064277 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 31.064334 s: CSI2RX: Init ... !!! [MCU2_0] 31.064353 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 31.064492 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.064525 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2 [MCU2_0] 31.064620 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.064644 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2 [MCU2_0] 31.064721 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.064747 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2 [MCU2_0] 31.064802 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.064826 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2 [MCU2_0] 31.065040 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.065756 s: CSI2RX: Init ... Done !!! [MCU2_0] 31.065807 s: CSI2TX: Init ... !!! [MCU2_0] 31.065830 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 31.065898 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.065926 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2 [MCU2_0] 31.066013 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.066038 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2 [MCU2_0] 31.066111 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 31.066623 s: CSI2TX: Init ... Done !!! [MCU2_0] 31.066669 s: ISS: Init ... !!! [MCU2_0] 31.066695 s: Found sensor IMX390-UB953_D3 at location 0 [MCU2_0] 31.066767 s: LXC 0001111: IssSensor_AR0233_Init, 174, status = 255 [MCU2_0] 31.066803 s: Found sensor AR0233-UB953_MARS at location 1 [MCU2_0] 31.066831 s: Found sensor AR0820-UB953_LI at location 2 [MCU2_0] 31.066857 s: Found sensor UB9xxx_RAW12_TESTPATTERN at location 3 [MCU2_0] 31.066887 s: Found sensor UB96x_UYVY_TESTPATTERN at location 4 [MCU2_0] 31.066915 s: Found sensor GW_AR0233_UYVY at location 5 [MCU2_0] 31.066941 s: IssSensor_Init ... Done !!! [MCU2_0] 31.067011 s: vissRemoteServer_Init ... Done !!! [MCU2_0] 31.067064 s: IttRemoteServer_Init ... Done !!! [MCU2_0] 31.067090 s: UDMA Copy: Init ... !!! [MCU2_0] 31.068553 s: UDMA Copy: Init ... Done !!! [MCU2_0] 31.068606 s: APP: Init ... Done !!! [MCU2_0] 31.068629 s: APP: Run ... !!! [MCU2_0] 31.068650 s: IPC: Starting echo test ... [MCU2_0] 31.071105 s: APP: Run ... Done !!! [MCU2_0] 31.071304 s: [MCU2_0] 31.071404 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 31.071454 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 31.071501 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 31.076308 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 31.076381 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 31.077948 s: [MCU2_0] CPSW NIMU application, IP address I/F 1: 192.168.10.33 [MCU2_0] 31.078726 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 31.078906 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 31.079026 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 31.079121 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_0] 31.176978 s: [MCU2_0] 31.177043 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 31.177080 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 31.177122 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 31.181945 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 31.181996 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 31.281963 s: [MCU2_0] 31.282022 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 31.282060 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 31.282102 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 31.286927 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 31.286978 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 [MCU2_0] 31.401125 s: EthFw: TimeSync PTP enabled [MCU2_0] 33.406126 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6 [MCU2_0] 34.775420 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a32049fc,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 34.778503 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:13, Policer Entry:2 [MCU2_0] 36.454411 s: [MCU2_0] 36.454481 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 36.454523 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 36.454567 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 36.459372 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 36.459427 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 36.559974 s: [MCU2_0] 36.560035 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 36.560074 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 36.560137 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 36.564942 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 36.564995 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 36.664960 s: [MCU2_0] 36.665017 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 36.665053 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 36.665096 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 36.669932 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 36.669982 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 [MCU2_0] 41.854407 s: [MCU2_0] 41.854478 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 41.854519 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 41.854563 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 41.859391 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 41.859446 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 41.959941 s: [MCU2_0] 41.960005 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 41.960044 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 41.960086 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 41.964908 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 41.964960 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 42.064983 s: [MCU2_0] 42.065039 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 42.065079 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 42.065122 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 42.069955 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 42.070006 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 [MCU2_0] 47.254405 s: [MCU2_0] 47.254477 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 47.254520 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 47.254564 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 47.259411 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 47.259462 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 47.359961 s: [MCU2_0] 47.360022 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 47.360063 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 47.360106 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 47.364930 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 47.364983 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 47.464951 s: [MCU2_0] 47.465013 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 47.465052 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 47.465096 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 47.469918 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 47.469971 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 [MCU2_0] 52.654409 s: [MCU2_0] 52.654479 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 52.654522 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 52.654564 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 52.659384 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 52.659439 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 52.759984 s: [MCU2_0] 52.760047 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 52.760086 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 52.760153 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 52.764954 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 52.765005 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 52.864970 s: [MCU2_0] 52.865024 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 52.865062 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 52.865103 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 52.869940 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 52.869990 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 [MCU2_0] 58.054404 s: [MCU2_0] 58.054472 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 58.054511 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 58.054552 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 58.059401 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 58.059457 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 58.159947 s: [MCU2_0] 58.160008 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 58.160047 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 58.160090 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 58.164918 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 58.164967 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 58.264933 s: [MCU2_0] 58.264989 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 58.265026 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 58.265071 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 58.269903 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 58.269952 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 [MCU2_0] 63.454412 s: [MCU2_0] 63.454484 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 63.454525 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 63.454570 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 63.459373 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 63.459430 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 63.559971 s: [MCU2_0] 63.560031 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_1] 3.547293 s: CIO: Init ... Done !!! [MCU2_1] 3.547358 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [MCU2_1] 3.547399 s: APP: Init ... !!! [MCU2_1] 3.547419 s: SCICLIENT: Init ... !!! [MCU2_1] 3.547605 s: SCICLIENT: DMSC FW version [21.1.1--v2021.01a (Terrific Lla] [MCU2_1] 3.547639 s: SCICLIENT: DMSC FW revision 0x15 [MCU2_1] 3.547662 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 3.547686 s: SCICLIENT: Init ... Done !!! [MCU2_1] 3.547707 s: UDMA: Init ... !!! [MCU2_1] 3.548806 s: UDMA: Init ... Done !!! [MCU2_1] 3.548853 s: MEM: Init ... !!! [MCU2_1] 3.548889 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!! [MCU2_1] 3.548941 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3620000 of size 131072 bytes !!! [MCU2_1] 3.548991 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d9000000 of size 117440512 bytes !!! [MCU2_1] 3.549037 s: MEM: Init ... Done !!! [MCU2_1] 3.549058 s: IPC: Init ... !!! [MCU2_1] 3.549086 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 3.549123 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 30.912499 s: IPC: HLOS is ready !!! [MCU2_1] 30.917801 s: IPC: Init ... Done !!! [MCU2_1] 30.917855 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 30.917892 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 30.917920 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 30.919735 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 30.919796 s: FVID2: Init ... !!! [MCU2_1] 30.919855 s: FVID2: Init ... Done !!! [MCU2_1] 30.919884 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 30.919904 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 30.920042 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 30.920073 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 30.920518 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 30.920552 s: VHWA: DOF Init ... !!! [MCU2_1] 30.927878 s: VHWA: DOF Init ... Done !!! [MCU2_1] 30.927928 s: VHWA: SDE Init ... !!! [MCU2_1] 30.929997 s: VHWA: SDE Init ... Done !!! [MCU2_1] 30.930041 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 30.930066 s: VHWA: Codec: Init ... !!! [MCU2_1] 30.930086 s: VHWA: VDEC Init ... !!! [MCU2_1] 30.943672 s: VHWA: VDEC Init ... Done !!! [MCU2_1] 30.943725 s: VHWA: VENC Init ... !!! [MCU2_1] 30.943868 s: MM_ENC_Init: No OCM RAM pool available, fallback to DDR mode for above mp params [MCU2_1] 30.985244 s: VHWA: VENC Init ... Done !!! [MCU2_1] 30.985293 s: VHWA: Init ... Done !!! [MCU2_1] 30.985329 s: VX_ZONE_INIT:Enabled [MCU2_1] 30.985352 s: VX_ZONE_ERROR:Enabled [MCU2_1] 30.985409 s: VX_ZONE_WARNING:Enabled [MCU2_1] 30.986343 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DMPAC_SDE [MCU2_1] 30.986597 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DMPAC_DOF [MCU2_1] 30.986810 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VDEC1 [MCU2_1] 30.987020 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VDEC2 [MCU2_1] 30.987226 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VENC1 [MCU2_1] 30.987474 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VENC2 [MCU2_1] 30.987527 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [MCU2_1] 30.987556 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 30.987901 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 30.987943 s: UDMA Copy: Init ... !!! [MCU2_1] 30.989398 s: UDMA Copy: Init ... Done !!! [MCU2_1] 30.989452 s: APP: Init ... Done !!! [MCU2_1] 30.989477 s: APP: Run ... !!! [MCU2_1] 30.989497 s: IPC: Starting echo test ... [MCU2_1] 30.991617 s: APP: Run ... Done !!! [MCU2_1] 30.992721 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 30.992805 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 30.992868 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 31.078410 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 3.655613 s: CIO: Init ... Done !!! [C6x_1 ] 3.655645 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz> [C6x_1 ] 3.655658 s: APP: Init ... !!! [C6x_1 ] 3.655665 s: SCICLIENT: Init ... !!! [C6x_1 ] 3.655846 s: SCICLIENT: DMSC FW version [21.1.1--v2021.01a (Terrific Lla] [C6x_1 ] 3.655857 s: SCICLIENT: DMSC FW revision 0x15 [C6x_1 ] 3.655865 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 3.655875 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 3.655883 s: UDMA: Init ... !!! [C6x_1 ] 3.657038 s: UDMA: Init ... Done !!! [C6x_1 ] 3.657061 s: MEM: Init ... !!! [C6x_1 ] 3.657072 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e4000000 of size 16777216 bytes !!! [C6x_1 ] 3.657088 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 3.657103 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e5000000 of size 50331648 bytes !!! [C6x_1 ] 3.657118 s: MEM: Init ... Done !!! [C6x_1 ] 3.657126 s: IPC: Init ... !!! [C6x_1 ] 3.657138 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 3.657151 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 29.818252 s: IPC: HLOS is ready !!! [C6x_1 ] 29.821978 s: IPC: Init ... Done !!! [C6x_1 ] 29.822013 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 30.917892 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 30.917906 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 30.918678 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 30.918720 s: VX_ZONE_INIT:Enabled [C6x_1 ] 30.918733 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 30.918743 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 30.919649 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [C6x_1 ] 30.919670 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 30.919953 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 30.919971 s: UDMA Copy: Init ... !!! [C6x_1 ] 30.923216 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 30.923234 s: APP: Init ... Done !!! [C6x_1 ] 30.923928 s: APP: Run ... !!! [C6x_1 ] 30.923938 s: IPC: Starting echo test ... [C6x_1 ] 30.925027 s: APP: Run ... Done !!! [C6x_1 ] 30.925348 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 30.925759 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 30.992519 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 31.078269 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 3.740178 s: CIO: Init ... Done !!! [C6x_2 ] 3.740211 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz> [C6x_2 ] 3.740224 s: APP: Init ... !!! [C6x_2 ] 3.740232 s: SCICLIENT: Init ... !!! [C6x_2 ] 3.740413 s: SCICLIENT: DMSC FW version [21.1.1--v2021.01a (Terrific Lla] [C6x_2 ] 3.740425 s: SCICLIENT: DMSC FW revision 0x15 [C6x_2 ] 3.740434 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 3.740443 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 3.740452 s: UDMA: Init ... !!! [C6x_2 ] 3.741614 s: UDMA: Init ... Done !!! [C6x_2 ] 3.741637 s: MEM: Init ... !!! [C6x_2 ] 3.741648 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e8000000 of size 16777216 bytes !!! [C6x_2 ] 3.741665 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 3.741680 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e9000000 of size 50331648 bytes !!! [C6x_2 ] 3.741696 s: MEM: Init ... Done !!! [C6x_2 ] 3.741704 s: IPC: Init ... !!! [C6x_2 ] 3.741717 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 3.741730 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 29.967487 s: IPC: HLOS is ready !!! [C6x_2 ] 29.971044 s: IPC: Init ... Done !!! [C6x_2 ] 29.971074 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 30.917892 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 30.917906 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 30.918688 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 30.918726 s: VX_ZONE_INIT:Enabled [C6x_2 ] 30.918743 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 30.918752 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 30.919644 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [C6x_2 ] 30.919664 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 30.919958 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 30.919978 s: UDMA Copy: Init ... !!! [C6x_2 ] 30.923495 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 30.923513 s: APP: Init ... Done !!! [C6x_2 ] 30.924209 s: APP: Run ... !!! [C6x_2 ] 30.924231 s: IPC: Starting echo test ... [C6x_2 ] 30.925416 s: APP: Run ... Done !!! [C6x_2 ] 30.925764 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 30.925804 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 30.992545 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 31.078305 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 3.939633 s: CIO: Init ... Done !!! [C7x_1 ] 3.939655 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [C7x_1 ] 3.939671 s: APP: Init ... !!! [C7x_1 ] 3.939678 s: SCICLIENT: Init ... !!! [C7x_1 ] 3.939847 s: SCICLIENT: DMSC FW version [21.1.1--v2021.01a (Terrific Lla] [C7x_1 ] 3.939861 s: SCICLIENT: DMSC FW revision 0x15 [C7x_1 ] 3.939871 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 3.939881 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 3.939889 s: UDMA: Init ... !!! [C7x_1 ] 3.940731 s: UDMA: Init ... Done !!! [C7x_1 ] 3.940743 s: MEM: Init ... !!! [C7x_1 ] 3.940753 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ 100000000 of size 1073741824 bytes !!! [C7x_1 ] 3.940773 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 3.940791 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 491520 bytes !!! [C7x_1 ] 3.940808 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 3.940825 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ ec000000 of size 268435456 bytes !!! [C7x_1 ] 3.940843 s: MEM: Init ... Done !!! [C7x_1 ] 3.940850 s: IPC: Init ... !!! [C7x_1 ] 3.940860 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 3.940872 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 30.375878 s: IPC: HLOS is ready !!! [C7x_1 ] 30.377895 s: IPC: Init ... Done !!! [C7x_1 ] 30.377909 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 30.917893 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 30.917910 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 30.918233 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 30.918255 s: VX_ZONE_INIT:Enabled [C7x_1 ] 30.918265 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 30.918275 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 30.918520 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [C7x_1 ] 30.918534 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 30.918617 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 30.918631 s: APP: Init ... Done !!! [C7x_1 ] 30.918640 s: APP: Run ... !!! [C7x_1 ] 30.918648 s: IPC: Starting echo test ... [C7x_1 ] 30.919117 s: APP: Run ... Done !!! [C7x_1 ] 30.925359 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s] [C7x_1 ] 30.925756 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 30.992565 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 31.078327 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [MCU2_0] 95.854409 s: [MCU2_0] 95.854481 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 95.854519 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 95.854563 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 95.859387 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 95.859445 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 95.959932 s: [MCU2_0] 95.959995 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 95.960034 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 95.960076 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 95.964904 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 95.964960 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 96.064978 s: [MCU2_0] 96.065034 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 96.065074 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 96.065115 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 96.069949 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 96.069998 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 root@j7-evm:/opt/vision_apps# root@j7-evm:/opt/vision_apps# [MCU2_0] 101.254408 s: [MCU2_0] 101.254477 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 101.254517 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 101.254561 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 101.259405 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 101.259457 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 101.359954 s: [MCU2_0] 101.360012 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 101.360051 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 101.360096 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 101.364925 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 101.364981 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 101.464944 s: [MCU2_0] 101.465013 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 101.465055 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 101.465099 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 101.469912 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 101.469965 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 root@j7-evm:/opt/vision_apps# root@j7-evm:/opt/vision_apps# [MCU2_0] 106.654407 s: [MCU2_0] 106.654477 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 106.654518 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 106.654560 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 106.659381 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 106.659435 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 106.759976 s: [MCU2_0] 106.760042 s: [LXC]: GenericPhy_reset. PHY 0: reset [MCU2_0] 106.760081 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 106.760146 s: [LXC]: Bcm89881_config hPhy->addr = 0 [MCU2_0] 106.764947 s: [LXC]: hunmaster1111 finished. hPhy->addr = 0 [MCU2_0] 106.765004 s: [LXC]: hunmaster2222 finished. hPhy->addr = 0 [MCU2_0] 106.864964 s: [MCU2_0] 106.865022 s: [LXC]: GenericPhy_reset. PHY 1: reset [MCU2_0] 106.865061 s: Bcm89881_config start, master:1, speed:100, loopback:0 [MCU2_0] 106.865102 s: [LXC]: Bcm89881_config hPhy->addr = 1 [MCU2_0] 106.869932 s: [LXC]: hunmaster1111 finished. hPhy->addr = 1 [MCU2_0] 106.869983 s: [LXC]: hunmaster2222 finished. hPhy->addr = 1 root@j7-evm:/opt/vision_apps# ^C root@j7-evm:/opt/vision_apps# CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Offline | ttyUSB0
The pdk_patch 1:
commit 04193e5764b58195255051114a2d2ea6007f89b0 Author: liuxianchao <liuxianchao@untouch-tech.com> Date: Fri Sep 24 10:39:26 2021 +0800 push test code for cpsw9g rgmii5 diff --git a/packages/ti/board/src/devices/common/common.c b/packages/ti/board/src/devices/common/common.c index 600aeed..4e2ae7c 100755 --- a/packages/ti/board/src/devices/common/common.c +++ b/packages/ti/board/src/devices/common/common.c @@ -40,6 +40,17 @@ #include "common.h" +#include <ti/csl/soc.h> +#include <ti/csl/csl_types.h> +#include <ti/drv/gpio/GPIO.h> +#include <ti/drv/gpio/soc/GPIO_soc.h> +#include <ti/drv/gpio/test/led_blink/src/GPIO_board.h> + +/* + TODO: + PHY3_RST_N: low --> high +*/ + /** * \brief Delay generation function * diff --git a/packages/ti/board/src/devices/fpd/ds90ub960.c b/packages/ti/board/src/devices/fpd/ds90ub960.c index da1a5ea..ad856eb 100755 --- a/packages/ti/board/src/devices/fpd/ds90ub960.c +++ b/packages/ti/board/src/devices/fpd/ds90ub960.c @@ -674,6 +674,7 @@ Board_STATUS Board_fpdUb960ReadReg(void *handle, return ret; } +#define UNTOUCH /** * \brief Get ub960 i2c address. * @@ -694,8 +695,13 @@ void Board_fpdU960GetI2CAddr(uint8_t *chNum, //J7_TODO: Need to update to make it generic across the devices and platforms if (csiInst == BOARD_CSI_INST_0) { +#ifdef UNTOUCH + *chNum = 3U; + *i2cAddr = 0x3AU; +#else *chNum = 6U; *i2cAddr = 0x3DU; +#endif } else if (csiInst == BOARD_CSI_INST_1) { diff --git a/packages/ti/board/src/j721e_evm/J721E_pinmux_data_gesi_cpsw9g.c b/packages/ti/board/src/j721e_evm/J721E_pinmux_data_gesi_cpsw9g.c index 4745d2b..64c6b82 100755 --- a/packages/ti/board/src/j721e_evm/J721E_pinmux_data_gesi_cpsw9g.c +++ b/packages/ti/board/src/j721e_evm/J721E_pinmux_data_gesi_cpsw9g.c @@ -23,10 +23,10 @@ static pinmuxPerCfg_t gCpsw9g0PinCfg[] = { /* MyCPSW9G3 -> CLKOUT -> AA25 */ - { - PIN_PRG0_PRU1_GPO10, PIN_MODE(0) | \ - ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) - }, + // { + // PIN_PRG0_PRU1_GPO10, PIN_MODE(0) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, {PINMUX_END} }; @@ -36,14 +36,16 @@ static pinmuxModuleCfg_t gCpsw9gPinCfg[] = {PINMUX_END} }; - +/* + TODO: 配置PHY复位引脚,I2C扩展芯片P20 +*/ static pinmuxPerCfg_t gGpio0PinCfg[] = { /* MyGPIO0 -> GPIO0_96 -> T23 */ - { - PIN_RGMII5_RD0, PIN_MODE(7) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) - }, + // { + // PIN_RGMII5_RD0, PIN_MODE(7) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, /* MyGPIO0 -> GPIO0_104 -> W26 */ { PIN_RGMII6_RXC, PIN_MODE(7) | \ @@ -74,6 +76,21 @@ static pinmuxPerCfg_t gMdio0PinCfg[] = {PINMUX_END} }; +// static pinmuxPerCfg_t gMdio0PinCfg[] = +// { +// /* MyMDIO1 -> PIN_PRG1_MDIO0_MDC -> AD18 */ +// { +// PIN_PRG1_MDIO0_MDC, PIN_MODE(0) | \ +// ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) +// }, +// /* MyMDIO1 -> PIN_PRG1_MDIO0_MDIO -> AD19 */ +// { +// PIN_PRG1_MDIO0_MDIO, PIN_MODE(0) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// {PINMUX_END} +// }; + static pinmuxModuleCfg_t gMdioPinCfg[] = { {0, TRUE, gMdio0PinCfg}, @@ -276,67 +293,132 @@ static pinmuxPerCfg_t gRgmii1PinCfg[] = {PINMUX_END} }; -static pinmuxPerCfg_t gRgmii2PinCfg[] = +// static pinmuxPerCfg_t gRgmii2PinCfg[] = +// { +// /* MyRGMII2 -> RGMII2_RD0 -> AE22 */ +// { +// PIN_PRG1_PRU1_GPO0, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// /* MyRGMII2 -> RGMII2_RD1 -> AG23 */ +// { +// PIN_PRG1_PRU1_GPO1, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// /* MyRGMII2 -> RGMII2_RD2 -> AF23 */ +// { +// PIN_PRG1_PRU1_GPO2, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// /* MyRGMII2 -> RGMII2_RD3 -> AD23 */ +// { +// PIN_PRG1_PRU1_GPO3, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// /* MyRGMII2 -> RGMII2_RXC -> AE23 */ +// { +// PIN_PRG1_PRU1_GPO6, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// /* MyRGMII2 -> RGMII2_RX_CTL -> AH24 */ +// { +// PIN_PRG1_PRU1_GPO4, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// /* MyRGMII2 -> RGMII2_TD0 -> AJ25 */ +// { +// PIN_PRG1_PRU1_GPO11, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) +// }, +// /* MyRGMII2 -> RGMII2_TD1 -> AH25 */ +// { +// PIN_PRG1_PRU1_GPO12, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) +// }, +// /* MyRGMII2 -> RGMII2_TD2 -> AG25 */ +// { +// PIN_PRG1_PRU1_GPO13, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) +// }, +// /* MyRGMII2 -> RGMII2_TD3 -> AH26 */ +// { +// PIN_PRG1_PRU1_GPO14, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) +// }, +// /* MyRGMII2 -> RGMII2_TXC -> AJ26 */ +// { +// PIN_PRG1_PRU1_GPO16, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// /* MyRGMII2 -> RGMII2_TX_CTL -> AJ27 */ +// { +// PIN_PRG1_PRU1_GPO15, PIN_MODE(4) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// {PINMUX_END} +// }; + +static pinmuxPerCfg_t gRgmii5PinCfg[] = { - /* MyRGMII2 -> RGMII2_RD0 -> AE22 */ + /* MyRGMII5 -> RGMII5_RD0 */ { - PIN_PRG1_PRU1_GPO0, PIN_MODE(4) | \ + PIN_RGMII5_RD0, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII2 -> RGMII2_RD1 -> AG23 */ + /* MyRGMII5 -> RGMII5_RD1 */ { - PIN_PRG1_PRU1_GPO1, PIN_MODE(4) | \ + PIN_RGMII5_RD1, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII2 -> RGMII2_RD2 -> AF23 */ + /* MyRGMII5 -> RGMII5_RD2 */ { - PIN_PRG1_PRU1_GPO2, PIN_MODE(4) | \ + PIN_RGMII5_RD2, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII2 -> RGMII2_RD3 -> AD23 */ + /* MyRGMII5 -> RGMII5_RD3 */ { - PIN_PRG1_PRU1_GPO3, PIN_MODE(4) | \ + PIN_RGMII5_RD3, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII2 -> RGMII2_RXC -> AE23 */ + /* MyRGMII5 -> RGMII5_RXC */ { - PIN_PRG1_PRU1_GPO6, PIN_MODE(4) | \ + PIN_RGMII5_RXC, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII2 -> RGMII2_RX_CTL -> AH24 */ + /* MyRGMII5 -> RGMII5_RX_CTL */ { - PIN_PRG1_PRU1_GPO4, PIN_MODE(4) | \ + PIN_RGMII5_RX_CTL, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII2 -> RGMII2_TD0 -> AJ25 */ + /* MyRGMII5 -> RGMII5_TD0 */ { - PIN_PRG1_PRU1_GPO11, PIN_MODE(4) | \ + PIN_RGMII5_TD0, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII2 -> RGMII2_TD1 -> AH25 */ + /* MyRGMII5 -> RGMII5_TD1 */ { - PIN_PRG1_PRU1_GPO12, PIN_MODE(4) | \ + PIN_RGMII5_TD1, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII2 -> RGMII2_TD2 -> AG25 */ + /* MyRGMII5 -> RGMII5_TD2 */ { - PIN_PRG1_PRU1_GPO13, PIN_MODE(4) | \ + PIN_RGMII5_TD2, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII2 -> RGMII2_TD3 -> AH26 */ + /* MyRGMII5 -> RGMII5_TD3 */ { - PIN_PRG1_PRU1_GPO14, PIN_MODE(4) | \ + PIN_RGMII5_TD3, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII2 -> RGMII2_TXC -> AJ26 */ + /* MyRGMII5 -> RGMII5_TXC */ { - PIN_PRG1_PRU1_GPO16, PIN_MODE(4) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + PIN_RGMII5_TXC, PIN_MODE(0) | \ + ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII2 -> RGMII2_TX_CTL -> AJ27 */ + /* MyRGMII5 -> RGMII5_TX_CTL */ { - PIN_PRG1_PRU1_GPO15, PIN_MODE(4) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + PIN_RGMII5_TX_CTL, PIN_MODE(0) | \ + ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, {PINMUX_END} }; @@ -476,7 +558,8 @@ static pinmuxModuleCfg_t gRgmiiPinCfg[] = {3, TRUE, gRgmii3PinCfg}, {4, TRUE, gRgmii4PinCfg}, {1, TRUE, gRgmii1PinCfg}, - {2, TRUE, gRgmii2PinCfg}, + {5, TRUE, gRgmii5PinCfg}, + // {2, TRUE, gRgmii2PinCfg}, {PINMUX_END} }; diff --git a/packages/ti/board/src/j721e_evm/board_ethernet_config.c b/packages/ti/board/src/j721e_evm/board_ethernet_config.c index 575b2e2..35584b6 100755 --- a/packages/ti/board/src/j721e_evm/board_ethernet_config.c +++ b/packages/ti/board/src/j721e_evm/board_ethernet_config.c @@ -704,28 +704,32 @@ Board_STATUS Board_ethConfigCpsw9g(void) uint8_t portNum; /* On J721E EVM to use all 8 ports simultaneously, we use below configuration - RGMII Ports - 1,3,4,8. QSGMII ports - 2 (main),5,6,7 (sub)*/ + //RGMII Ports - 1,3,4,8. QSGMII ports - 2 (main),5,6,7 (sub) + RGMII Ports - 1,3,4,5. QSGMII ports - 2 (main),6,7,8 (sub)*/ + /* Configures the CPSW9G RGMII ports */ for(portNum=0; portNum < BOARD_CPSW9G_PORT_MAX; portNum++) { - if ( 0U == portNum || - 2U == portNum || + // if ( 0U == portNum || + if ( 2U == portNum || 3U == portNum || - 7U == portNum ) + 4U == portNum ) { status = Board_cpsw9gEthConfig(portNum, RGMII); + // status = Board_cpsw9gEthConfig(portNum, RMII); } else { - if (1U == portNum) - { - status = Board_cpsw9gEthConfig(portNum, QSGMII); - } - else - { - status = Board_cpsw9gEthConfig(portNum, QSGMII_SUB); - } + status = Board_cpsw9gEthConfig(portNum, SGMII); + // if (1U == portNum) + // { + // status = Board_cpsw9gEthConfig(portNum, QSGMII); + // } + // else + // { + // status = Board_cpsw9gEthConfig(portNum, QSGMII_SUB); + // } } if(status != BOARD_SOK) diff --git a/packages/ti/drv/enet/enet_component.mk b/packages/ti/drv/enet/enet_component.mk index 82a75e7..2e51a04 100644 --- a/packages/ti/drv/enet/enet_component.mk +++ b/packages/ti/drv/enet/enet_component.mk @@ -302,12 +302,12 @@ endif # 4 - Debug # 5 - Verbose ifeq ($(BUILD_PROFILE),debug) - ENET_CFLAGS += -DENET_CFG_TRACE_LEVEL=4 + ENET_CFLAGS += -DENET_CFG_TRACE_LEVEL=5 ENET_CFLAGS += -DENET_CFG_DEV_ERROR=1 ENET_CFLAGS += -DENETDMA_INSTRUMENTATION_ENABLED ENET_CFLAGS += -DENETCPTS_INSTRUMENTATION_ENABLED else - ENET_CFLAGS += -DENET_CFG_TRACE_LEVEL=3 + ENET_CFLAGS += -DENET_CFG_TRACE_LEVEL=5 endif ifeq ($(SOC),$(filter $(SOC), am65xx)) diff --git a/packages/ti/drv/enet/examples/utils/V1/enet_appboardutils_j721e_evm.c b/packages/ti/drv/enet/examples/utils/V1/enet_appboardutils_j721e_evm.c index 387b467..b461f63 100644 --- a/packages/ti/drv/enet/examples/utils/V1/enet_appboardutils_j721e_evm.c +++ b/packages/ti/drv/enet/examples/utils/V1/enet_appboardutils_j721e_evm.c @@ -266,11 +266,13 @@ void EnetBoard_initEthFw(void) EnetBoard_configTorrentClks(); #endif - if (Board_detectBoard(BOARD_ID_ENET)) - { - status = Board_serdesCfgQsgmii(); - EnetAppUtils_assert(status == BOARD_SOK); - } + // if (Board_detectBoard(BOARD_ID_ENET)) + // { + // status = Board_serdesCfgQsgmii(); + // EnetAppUtils_assert(status == BOARD_SOK); + // } + status = Board_serdesCfgSgmii(); + EnetAppUtils_assert(status == BOARD_SOK); #endif } @@ -351,8 +353,10 @@ uint32_t EnetBoard_getPhyAddr(Enet_Type enetType, break; case ENET_MAC_PORT_5: - /* QSGMII port */ - phyAddr = 17U; + // /* QSGMII port */ + // phyAddr = 17U; + /* RGMII port */ + phyAddr = 0U; break; case ENET_MAC_PORT_6: @@ -534,8 +538,10 @@ void EnetBoard_setPhyConfigRgmii(Enet_Type enetType, (portNum == ENET_MAC_PORT_2) || (portNum == ENET_MAC_PORT_3) || (portNum == ENET_MAC_PORT_4) || + (portNum == ENET_MAC_PORT_5) || (portNum == ENET_MAC_PORT_7) || (portNum == ENET_MAC_PORT_8)); + EnetBoard_setEnetControl(enetType, 0U/* instId */, portNum, RGMII); #elif defined (SOC_J7200) if (enetType == ENET_CPSW_2G) { @@ -555,6 +561,7 @@ void EnetBoard_setPhyConfigRgmii(Enet_Type enetType, phyCfg->phyAddr = 0U; #else phyCfg->phyAddr = EnetBoard_getPhyAddr(enetType, portNum); + printf("[LXC] phyCfg->phyAddr = %d, portNum = %d\n", phyCfg->phyAddr, portNum); #endif /* DP83867 specific configuration */ @@ -626,6 +633,7 @@ void EnetBoard_setPhyConfig(Enet_Type enetType, if ( ENET_MAC_PORT_1 == portNum || ENET_MAC_PORT_3 == portNum || ENET_MAC_PORT_4 == portNum || + ENET_MAC_PORT_5 == portNum || ENET_MAC_PORT_8 == portNum ) { EnetBoard_setPhyConfigRgmii(enetType, diff --git a/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux.c b/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux.c index 0070c2b..726c756 100644 --- a/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux.c +++ b/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux.c @@ -86,7 +86,8 @@ int32_t EnetBoard_configEthFwPinmux (void) /* Overwrite the ICSSG RGMII muc configurations with CPSW */ /* Below is CPSW9G QSGMII pinmux configuration, RGMII Ports - 1,3,4,8. QSGMII ports - 2,5,6,7 */ - Board_pinmuxUpdate(gJ721E_MainPinmuxDataGesiCpsw9gQsgmii, + // Board_pinmuxUpdate(gJ721E_MainPinmuxDataGesiCpsw9gQsgmii, + Board_pinmuxUpdate(gJ721E_MainPinmuxDataGesiCpsw9g, BOARD_SOC_DOMAIN_MAIN); #elif defined(BUILD_MCU2_0) && defined(SOC_J7200) /* Below is CPSW5G QSGMII pinmux configuration, diff --git a/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux_j721e_data.c b/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux_j721e_data.c index f4d2f90..0497db6 100644 --- a/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux_j721e_data.c +++ b/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux_j721e_data.c @@ -209,6 +209,8 @@ static pinmuxPerCfg_t gGpio2PinCfg_phyReset[] = PIN_RGMII5_RD0, PIN_MODE(7) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, + + /* TODO: 配置复位引脚 */ {PINMUX_END} }; diff --git a/packages/ti/drv/enet/examples/utils/enet_board_j7xevm.c b/packages/ti/drv/enet/examples/utils/enet_board_j7xevm.c index b186c0a..f02371b 100644 --- a/packages/ti/drv/enet/examples/utils/enet_board_j7xevm.c +++ b/packages/ti/drv/enet/examples/utils/enet_board_j7xevm.c @@ -1313,10 +1313,11 @@ void EnetBoard_getMacAddrList(uint8_t macAddr[][ENET_MAC_ADDR_LEN], * addresses in Linux builds. For RTOS build, MAC addresses will still * be read from EEPROM as such I2C contention isn't an problem. */ + // set static macaddr uint8_t macAddrBuf[][ENET_MAC_ADDR_LEN] = { - { 0x70U, 0xFFU, 0x76U, 0x1DU, 0x92U, 0xC1U }, { 0x70U, 0xFFU, 0x76U, 0x1DU, 0x92U, 0xC2U }, + { 0x70U, 0xFFU, 0x76U, 0x1DU, 0x92U, 0xC1U }, { 0x70U, 0xFFU, 0x76U, 0x1DU, 0x92U, 0xC3U }, { 0x70U, 0xFFU, 0x76U, 0x1DU, 0x92U, 0xC4U }, { 0x70U, 0xFFU, 0x76U, 0x1DU, 0x92U, 0xC5U }, diff --git a/packages/ti/drv/enet/src/mod/mdio.c b/packages/ti/drv/enet/src/mod/mdio.c index fbdcead..79f0bc9 100644 --- a/packages/ti/drv/enet/src/mod/mdio.c +++ b/packages/ti/drv/enet/src/mod/mdio.c @@ -155,7 +155,8 @@ void Mdio_initCfg(Mdio_Cfg *mdioCfg) mdioCfg->mdioBusFreqHz = MDIO_MDIOBUS_DFLT_FREQ_HZ; mdioCfg->phyStatePollFreqHz = mdioCfg->mdioBusFreqHz; mdioCfg->pollEnMask = ENET_MDIO_PHY_ADDR_MASK_ALL; - mdioCfg->c45EnMask = ENET_MDIO_PHY_ADDR_MASK_NONE; + // mdioCfg->c45EnMask = ENET_MDIO_PHY_ADDR_MASK_NONE; + mdioCfg->c45EnMask = ENET_MDIO_PHY_ADDR_MASK_ALL; mdioCfg->isMaster = true; } diff --git a/packages/ti/drv/enet/src/per/cpsw.c b/packages/ti/drv/enet/src/per/cpsw.c index 18b0872..af1c048 100644 --- a/packages/ti/drv/enet/src/per/cpsw.c +++ b/packages/ti/drv/enet/src/per/cpsw.c @@ -650,6 +650,7 @@ void Cpsw_periodicTick(EnetPer_Handle hPer) if (hPhy != NULL) { /* Run PHY tick */ + // ENETTRACE_ERR("[LXC]: Cpsw_periodicTick 222222 \n"); linkStatus = EnetPhy_tick(hPhy); /* Handle link up/down events */ diff --git a/packages/ti/drv/enet/src/per/cpsw_tpr12.c b/packages/ti/drv/enet/src/per/cpsw_tpr12.c index 3080ccf..6bb643d 100644 --- a/packages/ti/drv/enet/src/per/cpsw_tpr12.c +++ b/packages/ti/drv/enet/src/per/cpsw_tpr12.c @@ -625,6 +625,7 @@ void Cpsw_periodicTick(EnetPer_Handle hPer) if (hPhy != NULL) { /* Run PHY tick */ + // ENETTRACE_ERR("[LXC]: Cpsw_periodicTick tpr12 1111\n"); linkStatus = EnetPhy_tick(hPhy); /* Handle link up/down events */ diff --git a/packages/ti/drv/enet/src/per/icssg.c b/packages/ti/drv/enet/src/per/icssg.c index 2d1247f..4ad3d3a 100644 --- a/packages/ti/drv/enet/src/per/icssg.c +++ b/packages/ti/drv/enet/src/per/icssg.c @@ -1754,6 +1754,8 @@ void Icssg_periodicTick(EnetPer_Handle hPer) //EnetOsal_lockMutex(hIcssg->lock); /* Run PHY tick */ + ENETTRACE_ERR("[LXC]: Icssg_periodicTick 333333333 \n"); + linkStatus = EnetPhy_tick(hPhy); /* Handle link up/down events */ diff --git a/packages/ti/drv/enet/src/phy/enetphy.c b/packages/ti/drv/enet/src/phy/enetphy.c index 43a70bc..5ac6b11 100644 --- a/packages/ti/drv/enet/src/phy/enetphy.c +++ b/packages/ti/drv/enet/src/phy/enetphy.c @@ -118,8 +118,6 @@ static void EnetPhy_defaultState(EnetPhy_Handle hPhy); static void EnetPhy_findingState(EnetPhy_Handle hPhy); -static void EnetPhy_findingState(EnetPhy_Handle hPhy); - static void EnetPhy_foundState(EnetPhy_Handle hPhy); static void EnetPhy_resetWaitState(EnetPhy_Handle hPhy); @@ -363,6 +361,7 @@ void EnetPhy_close(EnetPhy_Handle hPhy) EnetPhy_releaseHandle(hPhy); } +extern void ACD_test(EnetPhy_Handle hPhy); EnetPhy_LinkStatus EnetPhy_tick(EnetPhy_Handle hPhy) { EnetPhy_State *state = &hPhy->state; @@ -370,6 +369,15 @@ EnetPhy_LinkStatus EnetPhy_tick(EnetPhy_Handle hPhy) EnetPhy_FsmState currFsmState; EnetPhy_LinkStatus status; + // static int x_count = 1; + + // printf("EnetPhy_tick test ^^^^^ i=0x%x, addr=%x, state->fsmState= %d\n", x_count, hPhy->addr, state->fsmState); + // if (x_count % 100 == 0) { + // ACD_test(hPhy); + // } + // if (x_count < 0xffffffff) + // x_count++; + /* TODO: Check if pending state transitions needs to be applied, * i.e. from EnetPhy_setPhyMode() */ @@ -514,7 +522,8 @@ bool EnetPhy_isAlive(EnetPhy_Handle hPhy) else { /* Alternatively, read BMSR - PHY is alive if transaction is successful */ - status = hMdio->readC22(phyGroup, phyAddr, PHY_BMSR, &val, hPhy->mdioArgs); + // status = hMdio->readC22(phyGroup, phyAddr, PHY_BMSR, &val, hPhy->mdioArgs); + status = hMdio->readC45(phyGroup, phyAddr, 1, PHY_BMSR, &val, hPhy->mdioArgs); ENETTRACE_ERR_IF(status != ENETPHY_SOK, "PHY %u: Failed to read reg %u: %d\n", phyAddr, PHY_BMSR, status); if (status == ENETPHY_SOK) @@ -601,6 +610,7 @@ int32_t EnetPhy_getLinkCfg(EnetPhy_Handle hPhy, return status; } +extern int g_DEVAD; int32_t EnetPhy_readReg(EnetPhy_Handle hPhy, uint32_t reg, uint16_t *val) @@ -610,12 +620,17 @@ int32_t EnetPhy_readReg(EnetPhy_Handle hPhy, uint32_t phyAddr = hPhy->addr; int32_t status; - status = hMdio->readC22(phyGroup, phyAddr, reg, val, hPhy->mdioArgs); + // printf("[LXC]: EnetPhy_readReg . phyAddr = %d\n", phyAddr); + + // status = hMdio->readC22(phyGroup, phyAddr, reg, val, hPhy->mdioArgs); + status = hMdio->readC45(phyGroup, phyAddr, g_DEVAD, reg, val, hPhy->mdioArgs); ENETTRACE_ERR_IF(status != ENETPHY_SOK, "PHY %u: Failed to read reg %u: %d\n", phyAddr, reg, status); ENETTRACE_VERBOSE_IF(status == ENETPHY_SOK, "PHY %u: reg %u val 0x%04x %s\n", phyAddr, reg, *val); + // printf("[LXC]: EnetPhy_readReg . status = %d\n", status); + return status; } @@ -628,7 +643,8 @@ int32_t EnetPhy_writeReg(EnetPhy_Handle hPhy, uint32_t phyAddr = hPhy->addr; int32_t status; - status = hMdio->writeC22(phyGroup, phyAddr, reg, val, hPhy->mdioArgs); + // status = hMdio->writeC22(phyGroup, phyAddr, reg, val, hPhy->mdioArgs); + status = hMdio->writeC45(phyGroup, phyAddr, g_DEVAD, reg, val, hPhy->mdioArgs); ENETTRACE_ERR_IF(status != ENETPHY_SOK, "PHY %u: Failed to write reg %u: %d\n", phyAddr, reg, status); ENETTRACE_VERBOSE_IF(status == ENETPHY_SOK, @@ -648,7 +664,8 @@ int32_t EnetPhy_rmwReg(EnetPhy_Handle hPhy, int32_t status; uint16_t data = 0U; - status = hMdio->readC22(phyGroup, phyAddr, reg, &data, hPhy->mdioArgs); + // status = hMdio->readC22(phyGroup, phyAddr, reg, &data, hPhy->mdioArgs); + status = hMdio->readC45(phyGroup, phyAddr, g_DEVAD, reg, &data, hPhy->mdioArgs); ENETTRACE_ERR_IF(status != ENETPHY_SOK, "PHY %u: Failed to read reg %u: %d\n", phyAddr, reg, status); ENETTRACE_VERBOSE_IF(status == ENETPHY_SOK, @@ -658,7 +675,8 @@ int32_t EnetPhy_rmwReg(EnetPhy_Handle hPhy, { data = (data & ~mask) | (val & mask); - status = hMdio->writeC22(phyGroup, phyAddr, reg, data, hPhy->mdioArgs); + // status = hMdio->writeC22(phyGroup, phyAddr, reg, data, hPhy->mdioArgs); + status = hMdio->writeC45(phyGroup, phyAddr, 1, reg, data, hPhy->mdioArgs); ENETTRACE_ERR_IF(status != ENETPHY_SOK, "PHY %u: Failed to write reg %u: %d\n", phyAddr, reg, status); ENETTRACE_VERBOSE_IF(status == ENETPHY_SOK, @@ -1074,7 +1092,7 @@ static void EnetPhy_enableState(EnetPhy_Handle hPhy) { /* Set PHY in normal mode */ ENETTRACE_DBG("PHY %u: enable\n", hPhy->addr); - EnetPhy_rmwReg(hPhy, PHY_BMCR, BMCR_ISOLATE | BMCR_PWRDOWN, 0U); + // EnetPhy_rmwReg(hPhy, PHY_BMCR, BMCR_ISOLATE | BMCR_PWRDOWN, 0U); /* PHY-specific 'extended' configuration */ if ((hPhy->hDrv->config != NULL) && @@ -1198,11 +1216,11 @@ static void EnetPhy_setupNway(EnetPhy_Handle hPhy) nway1000Advertise |= GIGCR_1000HD; } - EnetPhy_rmwReg(hPhy, PHY_ANAR, ANAR_100 | ANAR_10, nwayAdvertise); + // EnetPhy_rmwReg(hPhy, PHY_ANAR, ANAR_100 | ANAR_10, nwayAdvertise); if ((state->phyLinkCaps & ENETPHY_LINK_CAP_1000) != 0U) { - EnetPhy_rmwReg(hPhy, PHY_GIGCR, GIGCR_1000, nway1000Advertise); + ;// EnetPhy_rmwReg(hPhy, PHY_GIGCR, GIGCR_1000, nway1000Advertise); } state->needsNwayCfg = false; @@ -1210,12 +1228,12 @@ static void EnetPhy_setupNway(EnetPhy_Handle hPhy) /* Restart auto-negotiation */ ENETTRACE_DBG("PHY %u: restart autonegotiation\n", hPhy->addr); - EnetPhy_rmwReg(hPhy, PHY_BMCR, BMCR_ANEN, BMCR_ANEN); + // EnetPhy_rmwReg(hPhy, PHY_BMCR, BMCR_ANEN, BMCR_ANEN); /* TODO: is MII_ENETPHY_FD needed for auto-negotiation? */ - EnetPhy_rmwReg(hPhy, PHY_BMCR, - BMCR_ANRESTART | BMCR_FD, - BMCR_ANRESTART | BMCR_FD); + // EnetPhy_rmwReg(hPhy, PHY_BMCR, + // BMCR_ANRESTART | BMCR_FD, + // BMCR_ANRESTART | BMCR_FD); } static void EnetPhy_setupManual(EnetPhy_Handle hPhy, @@ -1292,16 +1310,27 @@ static void EnetPhy_setupManual(EnetPhy_Handle hPhy, hPhy->addr, EnetPhy_getModeString(state->speed, state->duplexity)); } +extern int g_DEVAD; static void EnetPhy_loopbackState(EnetPhy_Handle hPhy) { bool loopback = false; int32_t status; - uint16_t val; + // uint16_t val; + uint16_t val1, val2; + + g_DEVAD = 0x03; + status = EnetPhy_readReg(hPhy, 0x0000, &val1); + g_DEVAD = 0x01; + status = EnetPhy_readReg(hPhy, 0x0000, &val2); - status = EnetPhy_readReg(hPhy, PHY_BMCR, &val); + // status = EnetPhy_readReg(hPhy, PHY_BMCR, &val); if (status == ENETPHY_SOK) { - loopback = ((val & BMCR_LOOPBACK) != 0U); + // loopback = ((val & BMCR_LOOPBACK) != 0U); + if (val2 & 0x1 != 0 || val1 & 0x4000 != 0) { + EnetUtils_printf("[xujibin] %s:%d lookback true\n", __FUNCTION__, __LINE__); + loopback = true; + } } else { @@ -1325,6 +1354,7 @@ static void EnetPhy_nwayStartState(EnetPhy_Handle hPhy) /* Wait for NWAY to start */ EnetPhy_readReg(hPhy, PHY_BMCR, &mode); + mode |= BMCR_ANRESTART; if ((mode & BMCR_ANRESTART) == 0U) { @@ -1355,6 +1385,8 @@ static void EnetPhy_nwayWaitState(EnetPhy_Handle hPhy) "PHY %u: unexpected state for strapped PHY\n", hPhy->addr); EnetPhy_readReg(hPhy, PHY_BMSR, &status); + status |= BMSR_ANCOMPLETE; + status |= BMSR_LINKSTS; if (0U != (status & BMSR_ANCOMPLETE)) { nwayCaps = EnetPhy_findCommonNwayCaps(hPhy); @@ -1396,6 +1428,7 @@ static void EnetPhy_linkWaitState(EnetPhy_Handle hPhy) EnetPhy_readReg(hPhy, PHY_BMSR, &status); + status |= BMSR_LINKSTS; if ((status & BMSR_LINKSTS) != 0U) { /* Populate FSM state now as most FSM states are bypassed for strapped PHYs */ @@ -1450,59 +1483,77 @@ static void EnetPhy_linkedState(EnetPhy_Handle hPhy) static bool EnetPhy_isNwayCapable(EnetPhy_Handle hPhy) { - uint16_t val = 0U; + // uint16_t val = 0U; /* Get the PHY Status */ - EnetPhy_readReg(hPhy, PHY_BMSR, &val); + // EnetPhy_readReg(hPhy, PHY_BMSR, &val); - return ((val & BMSR_ANCAPABLE) != 0U); + // return ((val & BMSR_ANCAPABLE) != 0U); + return true; } +extern int g_speed; static uint32_t EnetPhy_getLocalCaps(EnetPhy_Handle hPhy) { uint32_t caps = 0U; - uint16_t val = 0U; - /* Get 10/100 Mbps capabilities */ - EnetPhy_readReg(hPhy, PHY_BMSR, &val); - if ((val & BMSR_100FD) != 0U) - { - caps |= ENETPHY_LINK_CAP_FD100; - } - - if ((val & BMSR_100HD) != 0U) - { - caps |= ENETPHY_LINK_CAP_HD100; - } - - if ((val & BMSR_10FD) != 0U) - { - caps |= ENETPHY_LINK_CAP_FD10; - } - - if ((val & BMSR_10HD) != 0U) - { - caps |= ENETPHY_LINK_CAP_HD10; - } - - /* Get extended (1 Gbps) capabilities if supported */ - if ((val & BMSR_GIGEXTSTS) != 0U) - { - EnetPhy_readReg(hPhy, PHY_GIGESR, &val); - - if ((val & GIGESR_1000FD) != 0U) - { - caps |= ENETPHY_LINK_CAP_FD1000; - } - - if ((val & GIGESR_1000HD) != 0U) - { - caps |= ENETPHY_LINK_CAP_HD1000; - } + /* Get 10/100/1000 Mbps capabilities */ + caps |= ENETPHY_LINK_CAP_FD100; + caps |= ENETPHY_LINK_CAP_HD100; + caps |= ENETPHY_LINK_CAP_FD10; + caps |= ENETPHY_LINK_CAP_HD10; + if (g_speed == 1000) { + caps |= ENETPHY_LINK_CAP_FD1000; + caps |= ENETPHY_LINK_CAP_HD1000; } return caps; } +// static uint32_t EnetPhy_getLocalCaps(EnetPhy_Handle hPhy) +// { +// uint32_t caps = 0U; +// // uint16_t val = 0U; + +// /* Get 10/100 Mbps capabilities */ +// EnetPhy_readReg(hPhy, PHY_BMSR, &val); +// if ((val & BMSR_100FD) != 0U) +// { +// caps |= ENETPHY_LINK_CAP_FD100; +// } + +// if ((val & BMSR_100HD) != 0U) +// { +// caps |= ENETPHY_LINK_CAP_HD100; +// } + +// if ((val & BMSR_10FD) != 0U) +// { +// caps |= ENETPHY_LINK_CAP_FD10; +// } + +// if ((val & BMSR_10HD) != 0U) +// { +// caps |= ENETPHY_LINK_CAP_HD10; +// } + +// /* Get extended (1 Gbps) capabilities if supported */ +// if ((val & BMSR_GIGEXTSTS) != 0U) +// { +// EnetPhy_readReg(hPhy, PHY_GIGESR, &val); + +// if ((val & GIGESR_1000FD) != 0U) +// { +// caps |= ENETPHY_LINK_CAP_FD1000; +// } + +// if ((val & GIGESR_1000HD) != 0U) +// { +// caps |= ENETPHY_LINK_CAP_HD1000; +// } +// } + +// return caps; +// } static uint32_t EnetPhy_findCommonCaps(EnetPhy_Handle hPhy) { @@ -1513,49 +1564,58 @@ static uint32_t EnetPhy_findCommonCaps(EnetPhy_Handle hPhy) /* Get local device capabilities */ EnetPhy_readReg(hPhy, PHY_ANAR, &val); - if ((val & ANAR_100FD) != 0U) - { - localCaps |= ENETPHY_LINK_CAP_FD100; - } + // if ((val & ANAR_100FD) != 0U) + // { + // localCaps |= ENETPHY_LINK_CAP_FD100; + // } - if ((val & ANAR_100HD) != 0U) - { - localCaps |= ENETPHY_LINK_CAP_HD100; - } + // if ((val & ANAR_100HD) != 0U) + // { + // localCaps |= ENETPHY_LINK_CAP_HD100; + // } - if ((val & ANAR_10FD) != 0U) - { - localCaps |= ENETPHY_LINK_CAP_FD10; - } + // if ((val & ANAR_10FD) != 0U) + // { + // localCaps |= ENETPHY_LINK_CAP_FD10; + // } - if ((val & ANAR_10HD) != 0U) - { - localCaps |= ENETPHY_LINK_CAP_HD10; - } + // if ((val & ANAR_10HD) != 0U) + // { + // localCaps |= ENETPHY_LINK_CAP_HD10; + // } + + localCaps |= ENETPHY_LINK_CAP_FD100; + localCaps |= ENETPHY_LINK_CAP_HD100; + localCaps |= ENETPHY_LINK_CAP_FD10; + localCaps |= ENETPHY_LINK_CAP_HD10; /* Get link partner capabilities */ val = 0U; EnetPhy_readReg(hPhy, PHY_ANLPAR, &val); - if ((val & ANLPAR_100FD) != 0U) - { - partnerCaps |= ENETPHY_LINK_CAP_FD100; - } - - if ((val & ANLPAR_100HD) != 0U) - { - partnerCaps |= ENETPHY_LINK_CAP_HD100; - } - - if ((val & ANLPAR_10FD) != 0U) - { - partnerCaps |= ENETPHY_LINK_CAP_FD10; - } - - if ((val & ANLPAR_10HD) != 0U) - { - partnerCaps |= ENETPHY_LINK_CAP_HD10; - } + // if ((val & ANLPAR_100FD) != 0U) + // { + // partnerCaps |= ENETPHY_LINK_CAP_FD100; + // } + + // if ((val & ANLPAR_100HD) != 0U) + // { + // partnerCaps |= ENETPHY_LINK_CAP_HD100; + // } + + // if ((val & ANLPAR_10FD) != 0U) + // { + // partnerCaps |= ENETPHY_LINK_CAP_FD10; + // } + + // if ((val & ANLPAR_10HD) != 0U) + // { + // partnerCaps |= ENETPHY_LINK_CAP_HD10; + // } + partnerCaps |= ENETPHY_LINK_CAP_FD100; + partnerCaps |= ENETPHY_LINK_CAP_HD100; + partnerCaps |= ENETPHY_LINK_CAP_FD10; + partnerCaps |= ENETPHY_LINK_CAP_HD10; ENETTRACE_DBG("PHY %u: local caps: %s\n", hPhy->addr, EnetPhy_getCapsString(localCaps)); @@ -1571,41 +1631,47 @@ static uint32_t EnetPhy_findCommon1000Caps(EnetPhy_Handle hPhy) { uint32_t localCaps = 0U; uint32_t partnerCaps = 0U; - uint16_t val; - - /* Get local device capabilities */ - EnetPhy_readReg(hPhy, PHY_GIGCR, &val); - - if ((val & GIGCR_1000FD) != 0U) - { + // uint16_t val; + + // /* Get local device capabilities */ + // EnetPhy_readReg(hPhy, PHY_GIGCR, &val); + + // if ((val & GIGCR_1000FD) != 0U) + // { + // localCaps |= ENETPHY_LINK_CAP_FD1000; + // } + + // if ((val & GIGCR_1000HD) != 0U) + // { + // localCaps |= ENETPHY_LINK_CAP_HD1000; + // } + + // /* Get link partner capabilities */ + // EnetPhy_readReg(hPhy, PHY_GIGSR, &val); + + // if ((val & GIGSR_1000FD) != 0U) + // { + // partnerCaps |= ENETPHY_LINK_CAP_FD1000; + // } + + // if ((val & GIGSR_1000FD) != 0U) + // { + // partnerCaps |= ENETPHY_LINK_CAP_HD1000; + // } + + // ENETTRACE_DBG("PHY %u: local caps: %s\n", + // hPhy->addr, EnetPhy_getCapsString(localCaps)); + // ENETTRACE_DBG("PHY %u: partner caps: %s\n", + // hPhy->addr, EnetPhy_getCapsString(partnerCaps)); + // ENETTRACE_DBG("PHY %u: common caps: %s\n", + // hPhy->addr, EnetPhy_getCapsString(localCaps & partnerCaps)); + + if (g_speed == 1000) { localCaps |= ENETPHY_LINK_CAP_FD1000; - } - - if ((val & GIGCR_1000HD) != 0U) - { localCaps |= ENETPHY_LINK_CAP_HD1000; - } - - /* Get link partner capabilities */ - EnetPhy_readReg(hPhy, PHY_GIGSR, &val); - - if ((val & GIGSR_1000FD) != 0U) - { partnerCaps |= ENETPHY_LINK_CAP_FD1000; - } - - if ((val & GIGSR_1000FD) != 0U) - { partnerCaps |= ENETPHY_LINK_CAP_HD1000; } - - ENETTRACE_DBG("PHY %u: local caps: %s\n", - hPhy->addr, EnetPhy_getCapsString(localCaps)); - ENETTRACE_DBG("PHY %u: partner caps: %s\n", - hPhy->addr, EnetPhy_getCapsString(partnerCaps)); - ENETTRACE_DBG("PHY %u: common caps: %s\n", - hPhy->addr, EnetPhy_getCapsString(localCaps & partnerCaps)); - return (localCaps & partnerCaps); } @@ -1640,6 +1706,7 @@ static uint32_t EnetPhy_findCommonNwayCaps(EnetPhy_Handle hPhy) return nwayCaps; } +extern int g_loopback; static bool EnetPhy_isPhyLinked(EnetPhy_Handle hPhy) { EnetPhy_MdioHandle hMdio = hPhy->hMdio; @@ -1649,6 +1716,9 @@ static bool EnetPhy_isPhyLinked(EnetPhy_Handle hPhy) uint16_t val = 0U; int32_t status; + if (g_loopback == 1) + return true; + /* Get PHY link status */ if (hMdio->isLinked != NULL) { @@ -1660,7 +1730,8 @@ static bool EnetPhy_isPhyLinked(EnetPhy_Handle hPhy) else { /* Alternatively, BMSR[2] Link Status bit can be checked */ - status = hMdio->readC22(phyGroup, phyAddr, PHY_BMSR, &val, hPhy->mdioArgs); + // status = hMdio->readC22(phyGroup, phyAddr, PHY_BMSR, &val, hPhy->mdioArgs); + status = hMdio->readC45(phyGroup, phyAddr, 1, PHY_BMSR, &val, hPhy->mdioArgs); ENETTRACE_ERR_IF(status != ENETPHY_SOK, "PHY %u: Failed to read reg %u: %d\n", phyAddr, PHY_BMSR, status); if ((status == ENETPHY_SOK) && diff --git a/packages/ti/drv/enet/src/phy/generic_phy.c b/packages/ti/drv/enet/src/phy/generic_phy.c index 21200cb..1d3534c 100644 --- a/packages/ti/drv/enet/src/phy/generic_phy.c +++ b/packages/ti/drv/enet/src/phy/generic_phy.c @@ -50,6 +50,9 @@ #include "enetphy_priv.h" #include "generic_phy.h" +#include <ti/drv/i2c/I2C.h> +#include <stdio.h> + /* ========================================================================== */ /* Macros & Typedefs */ /* ========================================================================== */ @@ -72,6 +75,8 @@ static bool GenericPhy_isPhyDevSupported(EnetPhy_Handle hPhy, static bool GenericPhy_isMacModeSupported(EnetPhy_Handle hPhy, EnetPhy_Mii mii); +static void Bcm89881_config(EnetPhy_Handle hPhy); + /* ========================================================================== */ /* Global Variables */ /* ========================================================================== */ @@ -92,6 +97,88 @@ EnetPhy_Drv gEnetPhyDrvGeneric = /* ========================================================================== */ /* Function Definitions */ /* ========================================================================== */ +#define TCA6424_CMD_AUTO_INC ((uint8_t) 0x80U) + +/* Input status register */ +#define TCA6424_REG_INPUT0 ((UInt8) 0x00U) +#define TCA6424_REG_INPUT1 ((UInt8) 0x01U) +#define TCA6424_REG_INPUT2 ((UInt8) 0x02U) + +/* Output register to change state of output BIT set to 1, output set HIGH */ +#define TCA6424_REG_OUTPUT0 ((uint8_t) 0x04U) +#define TCA6424_REG_OUTPUT1 ((uint8_t) 0x05U) +#define TCA6424_REG_OUTPUT2 ((uint8_t) 0x06U) + +/* Configuration register. BIT = '1' sets port to input, BIT = '0' sets + * port to output */ +#define TCA6424_REG_CONFIG0 ((uint8_t) 0x0CU) +#define TCA6424_REG_CONFIG1 ((uint8_t) 0x0DU) +#define TCA6424_REG_CONFIG2 ((uint8_t) 0x0EU) + +void SetupI2CTransfer(I2C_Handle handle, uint32_t slaveAddr, + uint8_t *writeData, uint32_t numWriteBytes, + uint8_t *readData, uint32_t numReadBytes) +{ + bool status; + I2C_Transaction i2cTransaction; + + printf("\n[LXC]: SetupI2CTransfer start. \n"); + I2C_transactionInit(&i2cTransaction); + i2cTransaction.slaveAddress = slaveAddr; + i2cTransaction.writeBuf = (uint8_t *)&writeData[0]; + i2cTransaction.writeCount = numWriteBytes; + i2cTransaction.readBuf = (uint8_t *)&readData[0]; + i2cTransaction.readCount = numReadBytes; + status = I2C_transfer(handle, &i2cTransaction); + if(FALSE == status) + { + printf("\n Data Transfer failed. \n"); + } + printf("\n[LXC]: SetupI2CTransfer end. \n"); +} +extern void Board_delay(uint32_t delayCycles); +void Bcm89881_init(EnetPhy_Handle hPhy) +{ + I2C_Params i2cParams; + I2C_Handle handle = NULL; + uint8_t dataToSlave[4]; + + /* + * Configuring TCA6424 IO Exp 2 with addr 0x22 + * This io expander is controlled by i2c0 + */ + /* I2C initialization */ + printf("\n[LXC]: Bcm89881_init start. \n"); + I2C_init(); + I2C_Params_init(&i2cParams); + i2cParams.transferMode = I2C_MODE_BLOCKING; + i2cParams.bitRate = I2C_400kHz; + i2cParams.transferCallbackFxn = NULL; + + handle = I2C_open(0U, &i2cParams); + +printf("\n[LXC]: Bcm89881_init ing 11111. \n"); + dataToSlave[0] = TCA6424_REG_CONFIG0 | TCA6424_CMD_AUTO_INC; + dataToSlave[1] = 0x0U; + SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 2, NULL, 0); +printf("\n[LXC]: Bcm89881_init ing 22222. \n"); + + dataToSlave[0] = TCA6424_REG_INPUT0 | TCA6424_CMD_AUTO_INC; + dataToSlave[1] = 0x0U; + dataToSlave[2] = 0x0U; + dataToSlave[3] = 0x0U; + SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 1, &dataToSlave[1], 3); +printf("\n[LXC]: Bcm89881_init ing 33333. \n"); + + /* Set P20 to 0. Delay 22, and Set to 1; + */ + Board_delay(22); + dataToSlave[0] = TCA6424_REG_OUTPUT2; + dataToSlave[1] |= 0x1; + SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 1, &dataToSlave[1], 1); + printf("\n[LXC]: Bcm89881_init Stop. \n"); + +} static bool GenericPhy_isPhyDevSupported(EnetPhy_Handle hPhy, const EnetPhy_Version *version) @@ -112,7 +199,10 @@ void GenericPhy_reset(EnetPhy_Handle hPhy) ENETTRACE_DBG("PHY %u: reset\n", hPhy->addr); /* Reset the PHY */ - EnetPhy_rmwReg(hPhy, PHY_BMCR, BMCR_RESET, BMCR_RESET); + // EnetPhy_rmwReg(hPhy, PHY_BMCR, BMCR_RESET, BMCR_RESET); + printf("\n[LXC]: GenericPhy_reset. PHY %u: reset \n", hPhy->addr); + + Bcm89881_config(hPhy); } bool GenericPhy_isResetComplete(EnetPhy_Handle hPhy) @@ -137,65 +227,72 @@ int32_t GenericPhy_readExtReg(EnetPhy_Handle hPhy, uint32_t reg, uint16_t *val) { - uint16_t devad = MMD_CR_DEVADDR; - int32_t status; + // uint16_t devad = MMD_CR_DEVADDR; + // int32_t status; - status = EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_ADDR); + // status = EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_ADDR); - if (status == ENETPHY_SOK) - { - status = EnetPhy_writeReg(hPhy, PHY_MMD_DR, reg); - } + // if (status == ENETPHY_SOK) + // { + // status = EnetPhy_writeReg(hPhy, PHY_MMD_DR, reg); + // } - if (status == ENETPHY_SOK) - { - EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_DATA_NOPOSTINC); - } + // if (status == ENETPHY_SOK) + // { + // EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_DATA_NOPOSTINC); + // } - if (status == ENETPHY_SOK) - { - status = EnetPhy_readReg(hPhy, PHY_MMD_DR, val); - } + // if (status == ENETPHY_SOK) + // { + // status = EnetPhy_readReg(hPhy, PHY_MMD_DR, val); + // } - ENETTRACE_VERBOSE_IF(status == ENETPHY_SOK, - "PHY %u: failed to read reg %u\n", hPhy->addr, reg); - ENETTRACE_ERR_IF(status != ENETPHY_SOK, - "PHY %u: read reg %u val 0x%04x\n", hPhy->addr, reg, *val); + // ENETTRACE_VERBOSE_IF(status == ENETPHY_SOK, + // "PHY %u: failed to read reg %u\n", hPhy->addr, reg); + // ENETTRACE_ERR_IF(status != ENETPHY_SOK, + // "PHY %u: read reg %u val 0x%04x\n", hPhy->addr, reg, *val); - return status; + // return status; + return ENETPHY_SOK; } int32_t GenericPhy_writeExtReg(EnetPhy_Handle hPhy, uint32_t reg, uint16_t val) { - uint16_t devad = MMD_CR_DEVADDR; - int32_t status; + // uint16_t devad = MMD_CR_DEVADDR; + // int32_t status; - ENETTRACE_VERBOSE("PHY %u: write %u val 0x%04x\n", hPhy->addr, reg, val); + // ENETTRACE_VERBOSE("PHY %u: write %u val 0x%04x\n", hPhy->addr, reg, val); - status = EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_ADDR); - if (status == ENETPHY_SOK) - { - EnetPhy_writeReg(hPhy, PHY_MMD_DR, reg); - } + // status = EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_ADDR); + // if (status == ENETPHY_SOK) + // { + // EnetPhy_writeReg(hPhy, PHY_MMD_DR, reg); + // } - if (status == ENETPHY_SOK) - { - EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_DATA_NOPOSTINC); - } + // if (status == ENETPHY_SOK) + // { + // EnetPhy_writeReg(hPhy, PHY_MMD_CR, devad | MMD_CR_DATA_NOPOSTINC); + // } - if (status == ENETPHY_SOK) - { - EnetPhy_writeReg(hPhy, PHY_MMD_DR, val); - } + // if (status == ENETPHY_SOK) + // { + // EnetPhy_writeReg(hPhy, PHY_MMD_DR, val); + // } - ENETTRACE_ERR_IF(status != ENETPHY_SOK, - "PHY %u: failed to write reg %u val 0x%04x\n", hPhy->addr, reg, val); + // ENETTRACE_ERR_IF(status != ENETPHY_SOK, + // "PHY %u: failed to write reg %u val 0x%04x\n", hPhy->addr, reg, val); - return status; + // return status; + return ENETPHY_SOK; } + +// void thoumaster(EnetPhy_Handle hPhy); +// void thouslave(EnetPhy_Handle hPhy); +// void hunmaster(EnetPhy_Handle hPhy); +// void hunslave(EnetPhy_Handle hPhy); void GenericPhy_printRegs(EnetPhy_Handle hPhy) { uint32_t i; @@ -207,3 +304,542 @@ void GenericPhy_printRegs(EnetPhy_Handle hPhy) EnetUtils_printf("PHY %u: reg 0x%02x = 0x%04x\n", hPhy->addr, i, val); } } + +/* phy config */ +int g_master = 1; +int g_speed = 100; +int g_loopback = 0; +/* end of phy config */ + +int g_DEVAD = 1; +// static void Bcm89881_config(EnetPhy_Handle hPhy) +// { +// EnetUtils_printf("Bcm89881_config start, master:%d, speed:%d, loopback:%d\n", +// g_master, g_speed, g_loopback); + +// /* master mode */ +// if (g_master) { +// if (g_speed == 1000) +// thoumaster(hPhy); +// else if (g_speed == 100) +// hunmaster(hPhy); +// return; +// } + +// /* slave mode */ +// if (g_speed == 1000) +// thouslave(hPhy); +// else if (g_speed == 100) +// hunslave(hPhy); +// } + +static void thouslave(EnetPhy_Handle hPhy) +{ + g_DEVAD = 0x01; + + EnetPhy_writeReg(hPhy, 0x0000, 0x8040); // 'reset + + uint16_t TC10_ctrl, SuperIsolate; + uint16_t TC10_disable; + uint16_t val; + uint16_t Speed = 1000; + + g_DEVAD = 0x1E; + EnetPhy_readReg(hPhy, 0x00F0, &TC10_ctrl); + g_DEVAD = 0x01; + TC10_disable = TC10_ctrl & 0x8000; // 'RXDV/PAR_EN strapped low + EnetPhy_readReg(hPhy, 0x932A, &val); + SuperIsolate = val & 0x0020; + + if (TC10_disable == 0x0000 ) { // Then ' TC10 is enabled + EnetPhy_writeReg(hPhy, 0x8F02, 0x0001); + if (Speed == 1000) { //Then 'TC10 enabled + g_DEVAD = 0x1E; + EnetPhy_writeReg(hPhy, 0x00F0, TC10_ctrl | 0x800); // 'if 1G and TC10 is enabled, through register disable TC10 + EnetPhy_writeReg(hPhy, 0x00F0, TC10_ctrl); + g_DEVAD = 0x01; + } + } else if (SuperIsolate == 0x0) { //'Super Isolate is OFF + EnetPhy_writeReg(hPhy, 0x8F02, 0x0001); + } + EnetPhy_writeReg(hPhy, 0x900B, 0x0000); + EnetPhy_writeReg(hPhy, 0x0834, 0x8001); //'1G Slave-0x8001 + EnetPhy_writeReg(hPhy, 0xa010, 0x0101);//RXC,TXC delay + Board_delay(200); // added by xjb + + if (g_loopback == 1) { + g_DEVAD = 0x03; + EnetPhy_readReg(hPhy, 0x0000, &val); + val |= 0x4000; + EnetPhy_writeReg(hPhy, 0x0000, val); + g_DEVAD = 0x01; + } + + g_DEVAD = 0x07; + EnetPhy_writeReg(hPhy, 0x0200, 0x0200); + g_DEVAD = 0x01; + + if (TC10_disable == 0x0000 || SuperIsolate == 0x0) // Then ' TC10 is enabled, superisolate is OFF + EnetPhy_writeReg(hPhy, 0x8F02, 0x0000); // 'To enable port + else + EnetPhy_writeReg(hPhy, 0x932A, 0x0002); // ' To disable superisolate + + EnetPhy_writeReg(hPhy, 0x931D, 0x3410); // 'CORE_MISC_SHD1C_0D + EnetPhy_writeReg(hPhy, 0x931E, 0x3863); // 'CORE_MISC_SHD1C_0E + EnetPhy_writeReg(hPhy, 0xA027, 0x0317); // 'TOP_MISC_LED_INTR_CTL + EnetPhy_writeReg(hPhy, 0x9319, 0x2508); // 'CORE_MISC_SHD1C_09 +} +static void thoumaster(EnetPhy_Handle hPhy) +{ + g_DEVAD = 0x01; + + EnetPhy_writeReg(hPhy, 0x0000, 0x8040); // 'reset + + uint16_t TC10_ctrl, SuperIsolate; + uint16_t TC10_disable; + uint16_t val; + uint16_t Speed = 1000; + + g_DEVAD = 0x1E; + EnetPhy_readReg(hPhy, 0x00F0, &TC10_ctrl); + g_DEVAD = 0x01; + TC10_disable = TC10_ctrl & 0x8000; // 'RXDV/PAR_EN strapped low + EnetPhy_readReg(hPhy, 0x932A, &val); + SuperIsolate = val & 0x0020; + + if (TC10_disable == 0x0000 ) { // Then ' TC10 is enabled + EnetPhy_writeReg(hPhy, 0x8F02, 0x0001); + if (Speed == 1000) { //Then 'TC10 enabled + g_DEVAD = 0x1E; //内部寄存器 + EnetPhy_writeReg(hPhy, 0x00F0, TC10_ctrl | 0x800); // 'if 1G and TC10 is enabled, through register disable TC10 + EnetPhy_writeReg(hPhy, 0x00F0, TC10_ctrl); + g_DEVAD = 0x01; + } + } else if (SuperIsolate == 0x0) { //'Super Isolate is OFF + EnetPhy_writeReg(hPhy, 0x8F02, 0x0001); + } + + EnetPhy_writeReg(hPhy, 0x900B, 0x0000); + EnetPhy_writeReg(hPhy, 0x0834, 0xC001); // '1G master + EnetPhy_writeReg(hPhy, 0xa010, 0x0101);//RXC,TXC delay + Board_delay(200); // added by xjb + + if (g_loopback == 1) { + g_DEVAD = 0x03; + EnetPhy_readReg(hPhy, 0x0000, &val); + val |= 0x4000; + EnetPhy_writeReg(hPhy, 0x0000, val); + g_DEVAD = 0x01; + } + + g_DEVAD = 0x07; + EnetPhy_writeReg(hPhy, 0x0200, 0x0200); + g_DEVAD = 0x01; + + if (TC10_disable == 0x0000 || SuperIsolate == 0x0) // Then ' TC10 is enabled, superisolate is OFF + EnetPhy_writeReg(hPhy, 0x8F02, 0x0000); // 'To enable port + else + EnetPhy_writeReg(hPhy, 0x932A, 0x0002); // ' To disable superisolate + + EnetPhy_writeReg(hPhy, 0x931D, 0x3410); // 'CORE_MISC_SHD1C_0D + EnetPhy_writeReg(hPhy, 0x931E, 0x3863); // 'CORE_MISC_SHD1C_0E + EnetPhy_writeReg(hPhy, 0xA027, 0x0317); // 'TOP_MISC_LED_INTR_CTL + EnetPhy_writeReg(hPhy, 0x9319, 0x2508); // 'CORE_MISC_SHD1C_09 +} + +static void hunslave(EnetPhy_Handle hPhy) +{ + g_DEVAD = 0x01; + + EnetPhy_writeReg(hPhy,0x8130,0x798d); + EnetPhy_writeReg(hPhy,0x8131,0x0688); + EnetPhy_writeReg(hPhy,0x8132,0xa405); + EnetPhy_writeReg(hPhy,0x8133,0x2110); + EnetPhy_writeReg(hPhy,0x8134,0xbf04); + EnetPhy_writeReg(hPhy,0x8135,0x1818); + EnetPhy_writeReg(hPhy,0x8136,0x2181); + EnetPhy_writeReg(hPhy,0x8140,0x94a9); + EnetPhy_writeReg(hPhy,0x8141,0x0688); + EnetPhy_writeReg(hPhy,0x8142,0xa405); + EnetPhy_writeReg(hPhy,0x8143,0x2110); + EnetPhy_writeReg(hPhy,0x8144,0xbf84); + EnetPhy_writeReg(hPhy,0x8145,0x1818); + EnetPhy_writeReg(hPhy,0x8146,0x0209); + + EnetPhy_writeReg(hPhy,0x81d0,0x009d); + EnetPhy_writeReg(hPhy,0x81d1,0x8000); + EnetPhy_writeReg(hPhy,0x81d2,0x0000); + EnetPhy_writeReg(hPhy,0x81d3,0x0104); + EnetPhy_writeReg(hPhy,0x81d4,0x7f04); + EnetPhy_writeReg(hPhy,0x81d5,0x1a18); + EnetPhy_writeReg(hPhy,0x81d6,0x002d); + EnetPhy_writeReg(hPhy,0x81e0,0x7eef); + EnetPhy_writeReg(hPhy,0x81e1,0x800a); + EnetPhy_writeReg(hPhy,0x81e2,0x0007); + EnetPhy_writeReg(hPhy,0x81e3,0x0014); + EnetPhy_writeReg(hPhy,0x81e4,0x0300); + EnetPhy_writeReg(hPhy,0x81e5,0x893e); + EnetPhy_writeReg(hPhy,0x81e6,0x25bf); + EnetPhy_writeReg(hPhy,0x81f0,0x007e); + EnetPhy_writeReg(hPhy,0x81f1,0x6f95); + EnetPhy_writeReg(hPhy,0x81f2,0x0000); + EnetPhy_writeReg(hPhy,0x81f3,0x0014); + EnetPhy_writeReg(hPhy,0x81f4,0x0300); + EnetPhy_writeReg(hPhy,0x81f5,0x893e); + EnetPhy_writeReg(hPhy,0x81f6,0x25bf); + + EnetPhy_writeReg(hPhy,0x8030,0xe005); + EnetPhy_writeReg(hPhy,0x8031,0xe294); + EnetPhy_writeReg(hPhy,0x8033,0xed9c); + EnetPhy_writeReg(hPhy,0x8032,0xe4a8); + + EnetPhy_writeReg(hPhy,0x0834,0x8000); //100M Slave + + EnetPhy_writeReg(hPhy,0xa010,0x0101);//RXC,TXC delay + + Board_delay(100); + + if (g_loopback == 1) { + uint16_t val = 0; + g_DEVAD = 0x03; + EnetPhy_readReg(hPhy, 0x0000, &val); + val |= 0x4000; + EnetPhy_writeReg(hPhy, 0x0000, val); + g_DEVAD = 0x01; + } + + g_DEVAD = 0x07; + EnetPhy_writeReg(hPhy, 0x0200, 0x0200); //Restart link + g_DEVAD = 0x01; + + EnetPhy_writeReg(hPhy,0x931D,0x3410); + EnetPhy_writeReg(hPhy,0x931E,0x3863); + EnetPhy_writeReg(hPhy,0xA027,0x0317); + EnetPhy_writeReg(hPhy,0x9319,0x2508); +} + +static void hunmaster(EnetPhy_Handle hPhy) +{ + g_DEVAD = 0x01; + + EnetPhy_writeReg(hPhy, 0x8130, 0x798d); + EnetPhy_writeReg(hPhy, 0x8131, 0x0688); + EnetPhy_writeReg(hPhy, 0x8132, 0xa405); + EnetPhy_writeReg(hPhy, 0x8133, 0x2110); + EnetPhy_writeReg(hPhy, 0x8134, 0xbf04); + EnetPhy_writeReg(hPhy, 0x8135, 0x1818); + EnetPhy_writeReg(hPhy, 0x8136, 0x2181); + EnetPhy_writeReg(hPhy, 0x8140, 0x94a9); + EnetPhy_writeReg(hPhy, 0x8141, 0x0688); + EnetPhy_writeReg(hPhy, 0x8142, 0xa405); + EnetPhy_writeReg(hPhy, 0x8143, 0x2110); + EnetPhy_writeReg(hPhy, 0x8144, 0xbf84); + EnetPhy_writeReg(hPhy, 0x8145, 0x1818); + EnetPhy_writeReg(hPhy, 0x8146, 0x0209); + + EnetPhy_writeReg(hPhy, 0x81d0, 0x009d); + EnetPhy_writeReg(hPhy, 0x81d1, 0x8000); + EnetPhy_writeReg(hPhy, 0x81d2, 0x0000); + EnetPhy_writeReg(hPhy, 0x81d3, 0x0104); + EnetPhy_writeReg(hPhy, 0x81d4, 0x7f04); + EnetPhy_writeReg(hPhy, 0x81d5, 0x1a18); + EnetPhy_writeReg(hPhy, 0x81d6, 0x002d); + EnetPhy_writeReg(hPhy, 0x81e0, 0x7eef); + EnetPhy_writeReg(hPhy, 0x81e1, 0x800a); + EnetPhy_writeReg(hPhy, 0x81e2, 0x0007); + EnetPhy_writeReg(hPhy, 0x81e3, 0x0014); + EnetPhy_writeReg(hPhy, 0x81e4, 0x0300); + EnetPhy_writeReg(hPhy, 0x81e5, 0x893e); + EnetPhy_writeReg(hPhy, 0x81e6, 0x25bf); + EnetPhy_writeReg(hPhy, 0x81f0, 0x007e); + EnetPhy_writeReg(hPhy, 0x81f1, 0x6f95); + EnetPhy_writeReg(hPhy, 0x81f2, 0x0000); + EnetPhy_writeReg(hPhy, 0x81f3, 0x0014); + EnetPhy_writeReg(hPhy, 0x81f4, 0x0300); + EnetPhy_writeReg(hPhy, 0x81f5, 0x893e); + EnetPhy_writeReg(hPhy, 0x81f6, 0x25bf); + + EnetPhy_writeReg(hPhy, 0x8030, 0xe005); + EnetPhy_writeReg(hPhy, 0x8031, 0xe179); + EnetPhy_writeReg(hPhy, 0x8033, 0xee7d); + EnetPhy_writeReg(hPhy, 0x8032, 0xe38c); + + EnetPhy_writeReg(hPhy, 0x0834, 0xC000); //100M Master + + EnetPhy_writeReg(hPhy, 0xa010, 0x0101); //RXC,TXC delay + + printf("[LXC]: hunmaster1111 finished. hPhy->addr = %d\n", hPhy->addr); + + if (g_loopback == 1) { + uint16_t val = 0; + g_DEVAD = 0x03; + EnetPhy_readReg(hPhy, 0x0000, &val); + val |= 0x4000; + EnetPhy_writeReg(hPhy, 0x0000, val); + g_DEVAD = 0x01; + } + + printf("[LXC]: hunmaster2222 finished. hPhy->addr = %d\n", hPhy->addr); + + Board_delay(100); + + g_DEVAD = 0x07; + EnetPhy_writeReg(hPhy, 0x0200, 0x0200); //Restart link + g_DEVAD = 0x01; + + EnetPhy_writeReg(hPhy, 0x931D, 0x3410); + EnetPhy_writeReg(hPhy, 0x931E, 0x3863); + EnetPhy_writeReg(hPhy, 0xA027, 0x0317); + EnetPhy_writeReg(hPhy, 0x9319, 0x2508); +} + +// void GenericPhy_printRegs(EnetPhy_Handle hPhy) +static void Bcm89881_config(EnetPhy_Handle hPhy) +{ + EnetUtils_printf("Bcm89881_config start, master:%d, speed:%d, loopback:%d\n", + g_master, g_speed, g_loopback); + + printf("[LXC]: Bcm89881_config hPhy->addr = %d\n", hPhy->addr); + + /* master mode */ + if (g_master) { + if (g_speed == 1000) + thoumaster(hPhy); + else if (g_speed == 100) + hunmaster(hPhy); + return; + } + + printf("[LXC]: Bcm89881_config g_speed = %d\n", g_speed); + + /* slave mode */ + if (g_speed == 1000) + thouslave(hPhy); + else if (g_speed == 100) + hunslave(hPhy); +} + +static void ACD_init(EnetPhy_Handle hPhy) +{ + // All-PHY Select + int LP = 0; // 1 for LP = Polar 0 for LP = others + int Leoni_cable_type_647 = 1; // 1 for 647 0 for 545 + uint16_t ACD_mode_reg_value; + + g_DEVAD = 0x01; + + EnetPhy_readReg(hPhy, 0xA000, &ACD_mode_reg_value); + EnetPhy_writeReg(hPhy, 0xA000, 0x4 | ACD_mode_reg_value); + EnetPhy_writeReg(hPhy, 0xA2A7, 0x0202); + EnetPhy_writeReg(hPhy, 0xA2A8, 0x7f50); + + if (LP == 1) + EnetPhy_writeReg(hPhy, 0xA2A9, 0xaC22); + else + EnetPhy_writeReg(hPhy, 0xA2A9, 0x2C22); + + if (Leoni_cable_type_647 == 1) + EnetPhy_writeReg(hPhy, 0xA2AA, 0x5252); + else + EnetPhy_writeReg(hPhy, 0xA2AA, 0xD252); + + EnetPhy_writeReg(hPhy, 0xA2Ab, 0x0); + EnetPhy_writeReg(hPhy, 0xA2Ac, 0x0094); + EnetPhy_writeReg(hPhy, 0xA2Ae, 0x1CA3); + EnetPhy_writeReg(hPhy, 0xA2Af, 0x0206); + + // --------------------------------------------------------------------------------- + // ------- page // 01// + // --------------------------------------------------------------------------------- + EnetPhy_writeReg(hPhy, 0xA2b0, 0x0010); + EnetPhy_writeReg(hPhy, 0xA2b1, 0xD0D); + EnetPhy_writeReg(hPhy, 0xA2b2, 0x0000); + EnetPhy_writeReg(hPhy, 0xA2b3, 0x7700); + EnetPhy_writeReg(hPhy, 0xA2b4, 0x0000); + EnetPhy_writeReg(hPhy, 0xA2b7, 0x0); + + // --------------------------------------------------------------------------------- + // --- Now load values + EnetPhy_writeReg(hPhy, 0xA2bf, 0x409F); + EnetPhy_writeReg(hPhy, 0xA2ad, 0x1129); + EnetPhy_writeReg(hPhy, 0xA2ad, 0x0129); + EnetPhy_writeReg(hPhy, 0xA2b0, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b1, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b2, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b3, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b4, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b7, 0x0); + EnetPhy_writeReg(hPhy, 0xA2bf, 0x0); + + // --------------------------------------------------------------------------------- + // ------- page // 10// + // --------------------------------------------------------------------------------- + EnetPhy_writeReg(hPhy, 0xA2b0, 0x3619); + EnetPhy_writeReg(hPhy, 0xA2b1, 0x343A); + EnetPhy_writeReg(hPhy, 0xA2b2, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b3, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b4, 0x8000); + EnetPhy_writeReg(hPhy, 0xA2b5, 0x000E); + EnetPhy_writeReg(hPhy, 0xA2b7, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b9, 0x0400); + EnetPhy_writeReg(hPhy, 0xA2bd, 0x0); + + // --------------------------------------------------------------------------------- + // --- Now load values + EnetPhy_writeReg(hPhy, 0xA2bf, 0xA2BF); + EnetPhy_writeReg(hPhy, 0xA2ad, 0x1129); + EnetPhy_writeReg(hPhy, 0xA2ad, 0x0129); + EnetPhy_writeReg(hPhy, 0xA2b0, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b1, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b2, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b3, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b4, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b5, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b7, 0x0); + EnetPhy_writeReg(hPhy, 0xA2b9, 0x0); + EnetPhy_writeReg(hPhy, 0xA2bd, 0x0); + EnetPhy_writeReg(hPhy, 0xA2bf, 0x0); +} + +#define ECD_INVALID 0 +#define ECD_NO_FAULT 1 +#define ECD_OPEN 2 +#define ECD_SHORT 3 +#define ECD_PIN_SHORT_OR_XT 4 +#define ECD_FORCED 5 +static void ACD_run(EnetPhy_Handle hPhy) +{ + const int N_BUSY_CYCLE_WAIT = 300; + const uint16_t ERROR_ECD_BUSY_ON_DEMAND = 0x1; + // const uint16_t ERROR_ECD_BUSY_DURING_FLUSH = 0x2; + // const uint16_t ERROR_ECD_INVALID = 0x4; + const uint16_t ERROR_ECD_NO_NEW_RESULT = 0x8; + + int k, open_threshold, fault; + uint16_t temp_A; + uint16_t EXP_C[11], faultType[3], error_flag; + float distanceCm[3]; + float length_factor, peak_amplitude; + int new_result; + int LP, m, cable_type; + char* lkup[6]; + + lkup[0] = "INVALID"; + lkup[1] = "NO_FAULT"; + lkup[2] = "OPEN"; + lkup[3] = "SHORT"; + lkup[4] = "PIN SHORT or CrossTalk"; + lkup[5] = "FORCED"; + error_flag = 0; + g_DEVAD = 0x01; + + EnetPhy_writeReg(hPhy, 0xA2A0, 0x400); + EnetPhy_writeReg(hPhy, 0xA2A0, 0x8400); + + // ----- Looping For ECD done --------------------- + new_result = 0; + + for(k = 1; k <= N_BUSY_CYCLE_WAIT; k++) { + for(m = 0; m <= 10; m++) { + EnetPhy_readReg(hPhy, 0xA2A0 + m, EXP_C + m); + } + if ((EXP_C[0] & 0x4) != 0) // There is new ECD result + new_result = 1; + if ((EXP_C[0] & 0x800) == 0) + break; + } + + if (k >= N_BUSY_CYCLE_WAIT) + error_flag = error_flag | ERROR_ECD_BUSY_ON_DEMAND; + if (new_result == 0) + error_flag = error_flag | ERROR_ECD_NO_NEW_RESULT; + + if ((EXP_C[9] & 0x8000) != 0) + LP = 1; + else + LP = 0; + + if ((EXP_C[10] & 0x8000) != 0) + cable_type = 1; + else + cable_type = 0; + + if ((EXP_C[0] & 0x400) == 0) + length_factor = 100; + else + length_factor = 1; + + // ----- Convert fault types and cable length to BRCM DVT standard format ----- + for(k = 0; k <= 0; k++) { // loop through each pair + faultType[k] = ECD_OPEN; + distanceCm[k] = 0; + } + temp_A = EXP_C[1] / 4096; + faultType[0] = EXP_C[1]; + + if (cable_type == 0) + distanceCm[0] = 0.8096 * ((float)(EXP_C[6] + EXP_C[4]) / 2) * length_factor - 1.6009; + else + distanceCm[0] = 0.807 * ((float)(EXP_C[6] + EXP_C[4]) / 2) * length_factor - 2.4191; + + peak_amplitude = (EXP_C[5] + EXP_C[3]) / 2; + open_threshold = 104; + + fault = temp_A & 0xF; + switch(fault) { + case ECD_INVALID: + faultType[0] = ECD_INVALID; + break; + case ECD_NO_FAULT: // fault = 1 + faultType[0] = ECD_NO_FAULT; + break; + case ECD_OPEN: // fault = 2 + faultType[0] = ECD_OPEN; + if (LP == 0) { + if (peak_amplitude < open_threshold) { + faultType[0] = ECD_NO_FAULT; + if (cable_type == 0) + distanceCm[0] = 0.807 * ((float)(EXP_C[6] + EXP_C[4]) / 2) * length_factor - 2.4191; + else + distanceCm[0] = 1.1987 * ((float)((EXP_C[6] + EXP_C[4]) / 2 - 2.073) * 0.6558 * length_factor - 0.2246) - 0.3482; + } + } else { // This is for Polar + if (peak_amplitude < 100) { + faultType[0] = ECD_NO_FAULT; + if (cable_type == 0) + distanceCm[0] = 0.818 * ((float)(EXP_C[6] + EXP_C[4]) / 2) * length_factor - 4.9381; + else + distanceCm[0] = 1.2043 * ((float)((EXP_C[6] + EXP_C[4]) / 2 - 5.0266) * 0.6626 * length_factor - 0.2246) - 0.3747; + } + } + break; + case ECD_SHORT: + faultType[0] = ECD_SHORT; + if (cable_type == 0) + distanceCm[0] = 0.7949 * ((float)(EXP_C[6] + EXP_C[4]) / 2) * length_factor - 1.6385; + else + distanceCm[0] = 1.2389 * (((float)(EXP_C[6] + EXP_C[4]) / 2 - 1.7506) * 0.6615 * length_factor - 0.2246) - 0.3344; + break; + case ECD_PIN_SHORT_OR_XT: + faultType[0] = ECD_PIN_SHORT_OR_XT; + break; + case ECD_FORCED: + faultType[0] = ECD_FORCED; + break; + default: + faultType[0] = ECD_INVALID; + } + + if (distanceCm[0] < 0) + distanceCm[0] = 0; + + EnetUtils_printf("Cable Diag Result: FaultType = %u(%s), Distance(cm) = %f\n", + faultType[0], lkup[faultType[0]], distanceCm[0]); +} + +void ACD_test(EnetPhy_Handle hPhy) +{ + ACD_init(hPhy); + Board_delay(100); + ACD_run(hPhy); +}
The pdk_patch 2:
diff --git a/packages/ti/board/src/j721e_evm/J721E_pinmux_data_gesi_cpsw9g.c b/packages/ti/board/src/j721e_evm/J721E_pinmux_data_gesi_cpsw9g.c index 64c6b82..48bcb9c 100755 --- a/packages/ti/board/src/j721e_evm/J721E_pinmux_data_gesi_cpsw9g.c +++ b/packages/ti/board/src/j721e_evm/J721E_pinmux_data_gesi_cpsw9g.c @@ -47,10 +47,10 @@ static pinmuxPerCfg_t gGpio0PinCfg[] = // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) // }, /* MyGPIO0 -> GPIO0_104 -> W26 */ - { - PIN_RGMII6_RXC, PIN_MODE(7) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) - }, + // { + // PIN_RGMII6_RXC, PIN_MODE(7) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, {PINMUX_END} }; @@ -63,12 +63,12 @@ static pinmuxModuleCfg_t gGpioPinCfg[] = static pinmuxPerCfg_t gMdio0PinCfg[] = { - /* MyMDIO1 -> MDIO0_MDC -> V24 */ + /* Port56_MDC -> MDIO0_MDC -> V24 */ { PIN_MDIO0_MDC, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyMDIO1 -> MDIO0_MDIO -> V26 */ + /* Port56_MDIO -> MDIO0_MDIO -> V26 */ { PIN_MDIO0_MDIO, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) @@ -76,6 +76,36 @@ static pinmuxPerCfg_t gMdio0PinCfg[] = {PINMUX_END} }; +// static pinmuxPerCfg_t gMdio1PinCfg[] = +// { +// /* Port1_MDC -> PIN_PRG1_MDIO0_MDC -> AD18 */ +// { +// PIN_PRG1_MDIO0_MDC, PIN_MODE(0) | \ +// ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) +// }, +// /* Port1_MDC -> PIN_PRG1_MDIO0_MDIO -> AD19 */ +// { +// PIN_PRG1_MDIO0_MDIO, PIN_MODE(0) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// {PINMUX_END} +// }; + +// static pinmuxPerCfg_t gMdio2PinCfg[] = +// { +// /* Port3_MDC -> PIN_PRG0_MDIO0_MDC -> AA27 */ +// { +// PIN_PRG0_MDIO0_MDC, PIN_MODE(0) | \ +// ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) +// }, +// /* Port3_MDC -> PIN_PRG0_MDIO0_MDIO -> Y26 */ +// { +// PIN_PRG0_MDIO0_MDIO, PIN_MODE(0) | \ +// ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) +// }, +// {PINMUX_END} +// }; + // static pinmuxPerCfg_t gMdio0PinCfg[] = // { // /* MyMDIO1 -> PIN_PRG1_MDIO0_MDC -> AD18 */ @@ -94,6 +124,8 @@ static pinmuxPerCfg_t gMdio0PinCfg[] = static pinmuxModuleCfg_t gMdioPinCfg[] = { {0, TRUE, gMdio0PinCfg}, + // {1, TRUE, gMdio1PinCfg}, + // {2, TRUE, gMdio2PinCfg}, {PINMUX_END} }; @@ -423,71 +455,136 @@ static pinmuxPerCfg_t gRgmii5PinCfg[] = {PINMUX_END} }; -static pinmuxPerCfg_t gRgmii7PinCfg[] = +static pinmuxPerCfg_t gRgmii6PinCfg[] = { - /* MyRGMII7 -> RGMII7_RD0 -> AC23 */ + /* MyRGMII6 -> RGMII6_RD0 */ { - PIN_PRG1_PRU0_GPO0, PIN_MODE(9) | \ + PIN_RGMII6_RD0, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII7 -> RGMII7_RD1 -> AG22 */ + /* MyRGMII6 -> RGMII6_RD1 */ { - PIN_PRG1_PRU0_GPO1, PIN_MODE(9) | \ + PIN_RGMII6_RD1, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII7 -> RGMII7_RD2 -> AF22 */ + /* MyRGMII6 -> RGMII6_RD2 */ { - PIN_PRG1_PRU0_GPO2, PIN_MODE(9) | \ + PIN_RGMII6_RD2, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII7 -> RGMII7_RD3 -> AJ23 */ + /* MyRGMII6 -> RGMII6_RD3 */ { - PIN_PRG1_PRU0_GPO3, PIN_MODE(9) | \ + PIN_RGMII6_RD3, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII7 -> RGMII7_RXC -> AD22 */ + /* MyRGMII6 -> RGMII6_RXC */ { - PIN_PRG1_PRU0_GPO6, PIN_MODE(9) | \ + PIN_RGMII6_RXC, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII7 -> RGMII7_RX_CTL -> AH23 */ + /* MyRGMII6 -> RGMII6_RX_CTL */ { - PIN_PRG1_PRU0_GPO4, PIN_MODE(9) | \ + PIN_RGMII6_RX_CTL, PIN_MODE(0) | \ ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) }, - /* MyRGMII7 -> RGMII7_TD0 -> AF24 */ + /* MyRGMII6 -> RGMII6_TD0 */ { - PIN_PRG1_PRU0_GPO11, PIN_MODE(9) | \ + PIN_RGMII6_TD0, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII7 -> RGMII7_TD1 -> AJ24 */ + /* MyRGMII6 -> RGMII6_TD1 */ { - PIN_PRG1_PRU0_GPO12, PIN_MODE(9) | \ + PIN_RGMII6_TD1, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII7 -> RGMII7_TD2 -> AG24 */ + /* MyRGMII6 -> RGMII6_TD2 */ { - PIN_PRG1_PRU0_GPO13, PIN_MODE(9) | \ + PIN_RGMII6_TD2, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII7 -> RGMII7_TD3 -> AD24 */ + /* MyRGMII6 -> RGMII6_TD3 */ { - PIN_PRG1_PRU0_GPO14, PIN_MODE(9) | \ + PIN_RGMII6_TD3, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII7 -> RGMII7_TXC -> AE24 */ + /* MyRGMII6 -> RGMII6_TXC */ { - PIN_PRG1_PRU0_GPO16, PIN_MODE(9) | \ + PIN_RGMII6_TXC, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, - /* MyRGMII7 -> RGMII7_TX_CTL -> AC24 */ + /* MyRGMII6 -> RGMII6_TX_CTL */ { - PIN_PRG1_PRU0_GPO15, PIN_MODE(9) | \ + PIN_RGMII6_TX_CTL, PIN_MODE(0) | \ ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) }, {PINMUX_END} }; +static pinmuxPerCfg_t gRgmii7PinCfg[] = +{ + // /* MyRGMII7 -> RGMII7_RD0 -> AC23 */ + // { + // PIN_PRG1_PRU0_GPO0, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRGMII7 -> RGMII7_RD1 -> AG22 */ + // { + // PIN_PRG1_PRU0_GPO1, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRGMII7 -> RGMII7_RD2 -> AF22 */ + // { + // PIN_PRG1_PRU0_GPO2, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRGMII7 -> RGMII7_RD3 -> AJ23 */ + // { + // PIN_PRG1_PRU0_GPO3, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRGMII7 -> RGMII7_RXC -> AD22 */ + // { + // PIN_PRG1_PRU0_GPO6, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRGMII7 -> RGMII7_RX_CTL -> AH23 */ + // { + // PIN_PRG1_PRU0_GPO4, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRGMII7 -> RGMII7_TD0 -> AF24 */ + // { + // PIN_PRG1_PRU0_GPO11, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, + // /* MyRGMII7 -> RGMII7_TD1 -> AJ24 */ + // { + // PIN_PRG1_PRU0_GPO12, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, + // /* MyRGMII7 -> RGMII7_TD2 -> AG24 */ + // { + // PIN_PRG1_PRU0_GPO13, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, + // /* MyRGMII7 -> RGMII7_TD3 -> AD24 */ + // { + // PIN_PRG1_PRU0_GPO14, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, + // /* MyRGMII7 -> RGMII7_TXC -> AE24 */ + // { + // PIN_PRG1_PRU0_GPO16, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, + // /* MyRGMII7 -> RGMII7_TX_CTL -> AC24 */ + // { + // PIN_PRG1_PRU0_GPO15, PIN_MODE(9) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, + {PINMUX_END} +}; + static pinmuxPerCfg_t gRgmii8PinCfg[] = { /* MyRGMII8 -> RGMII8_RD0 -> AE22 */ @@ -556,9 +653,10 @@ static pinmuxPerCfg_t gRgmii8PinCfg[] = static pinmuxModuleCfg_t gRgmiiPinCfg[] = { {3, TRUE, gRgmii3PinCfg}, - {4, TRUE, gRgmii4PinCfg}, + // {4, TRUE, gRgmii4PinCfg}, {1, TRUE, gRgmii1PinCfg}, {5, TRUE, gRgmii5PinCfg}, + {6, TRUE, gRgmii6PinCfg}, // {2, TRUE, gRgmii2PinCfg}, {PINMUX_END} }; @@ -585,51 +683,51 @@ static pinmuxModuleCfg_t gQsgmiiPinCfg[] = static pinmuxPerCfg_t gRmii8PinCfg[] = { - /* MyRMII8 -> RMII8_CRS_DV -> Y28 */ - { - PIN_RGMII6_TX_CTL, PIN_MODE(1) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) - }, - /* MyRMII8 -> RMII8_RXD0 -> W25 */ - { - PIN_RGMII6_RD0, PIN_MODE(1) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) - }, - /* MyRMII8 -> RMII8_RXD1 -> W24 */ - { - PIN_RGMII6_RD1, PIN_MODE(1) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) - }, - /* MyRMII8 -> RMII8_RX_ER -> V23 */ - { - PIN_RGMII6_RX_CTL, PIN_MODE(1) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) - }, - /* MyRMII8 -> RMII8_TXD0 -> W27 */ - { - PIN_RGMII6_TD0, PIN_MODE(1) | \ - ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) - }, - /* MyRMII8 -> RMII8_TXD1 -> V25 */ - { - PIN_RGMII6_TD1, PIN_MODE(1) | \ - ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) - }, - /* MyRMII8 -> RMII8_TX_EN -> W29 */ - { - PIN_RGMII6_TXC, PIN_MODE(1) | \ - ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) - }, + // /* MyRMII8 -> RMII8_CRS_DV -> Y28 */ + // { + // PIN_RGMII6_TX_CTL, PIN_MODE(1) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRMII8 -> RMII8_RXD0 -> W25 */ + // { + // PIN_RGMII6_RD0, PIN_MODE(1) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRMII8 -> RMII8_RXD1 -> W24 */ + // { + // PIN_RGMII6_RD1, PIN_MODE(1) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRMII8 -> RMII8_RX_ER -> V23 */ + // { + // PIN_RGMII6_RX_CTL, PIN_MODE(1) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, + // /* MyRMII8 -> RMII8_TXD0 -> W27 */ + // { + // PIN_RGMII6_TD0, PIN_MODE(1) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, + // /* MyRMII8 -> RMII8_TXD1 -> V25 */ + // { + // PIN_RGMII6_TD1, PIN_MODE(1) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, + // /* MyRMII8 -> RMII8_TX_EN -> W29 */ + // { + // PIN_RGMII6_TXC, PIN_MODE(1) | \ + // ((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE)) + // }, {PINMUX_END} }; static pinmuxPerCfg_t gRmii0PinCfg[] = { - /* MyRMII0 -> RMII_REF_CLK -> AD18 */ - { - PIN_PRG1_MDIO0_MDC, PIN_MODE(5) | \ - ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) - }, + // /* MyRMII0 -> RMII_REF_CLK -> AD18 */ + // { + // PIN_PRG1_MDIO0_MDC, PIN_MODE(5) | \ + // ((PIN_PULL_DISABLE | PIN_INPUT_ENABLE) & (~PIN_PULL_DIRECTION)) + // }, {PINMUX_END} }; @@ -643,8 +741,8 @@ static pinmuxModuleCfg_t gRmiiPinCfg[] = pinmuxBoardCfg_t gJ721E_MainPinmuxDataGesiCpsw9g[] = { - {0, gCpsw9gPinCfg}, - {1, gGpioPinCfg}, + {0, gCpsw9gPinCfg}, //配置时钟引脚?????? + {1, gGpioPinCfg}, //配置复位引脚?????? {2, gMdioPinCfg}, {3, gRgmiiPinCfg}, {4, gRmiiPinCfg}, diff --git a/packages/ti/board/src/j721e_evm/board_ethernet_config.c b/packages/ti/board/src/j721e_evm/board_ethernet_config.c index 35584b6..21c7974 100755 --- a/packages/ti/board/src/j721e_evm/board_ethernet_config.c +++ b/packages/ti/board/src/j721e_evm/board_ethernet_config.c @@ -712,9 +712,10 @@ Board_STATUS Board_ethConfigCpsw9g(void) for(portNum=0; portNum < BOARD_CPSW9G_PORT_MAX; portNum++) { // if ( 0U == portNum || - if ( 2U == portNum || + if ( 1U == portNum || 3U == portNum || - 4U == portNum ) + 5U == portNum || + 6U == portNum ) { status = Board_cpsw9gEthConfig(portNum, RGMII); // status = Board_cpsw9gEthConfig(portNum, RMII); diff --git a/packages/ti/drv/enet/examples/enet_loopback_test/enet_loopback.c b/packages/ti/drv/enet/examples/enet_loopback_test/enet_loopback.c index 4ba4f81..4d14472 100644 --- a/packages/ti/drv/enet/examples/enet_loopback_test/enet_loopback.c +++ b/packages/ti/drv/enet/examples/enet_loopback_test/enet_loopback.c @@ -516,6 +516,7 @@ static void EnetLpbk_tickTask(UArg a0, Semaphore_pend(hSem, BIOS_WAIT_FOREVER); /* PeriodicTick should be called from non-ISR context */ + printf("[LXC]: EnetLpbk_tickTask enet_loopback.c \n"); Enet_periodicTick(gEnetLpbk.hEnet); } } diff --git a/packages/ti/drv/enet/examples/utils/V1/enet_appboardutils_j721e_evm.c b/packages/ti/drv/enet/examples/utils/V1/enet_appboardutils_j721e_evm.c index b461f63..4200750 100644 --- a/packages/ti/drv/enet/examples/utils/V1/enet_appboardutils_j721e_evm.c +++ b/packages/ti/drv/enet/examples/utils/V1/enet_appboardutils_j721e_evm.c @@ -97,6 +97,8 @@ /* Function Definitions */ /* ========================================================================== */ +#undef ENETAPPUTILS_BYPASS_QSGMII + #if !defined(ENETAPPUTILS_BYPASS_I2C) && defined(BUILD_MCU2_0) static void EnetBoard_enetExpCfg(void) { @@ -360,8 +362,10 @@ uint32_t EnetBoard_getPhyAddr(Enet_Type enetType, break; case ENET_MAC_PORT_6: - /* QSGMII port */ - phyAddr = 18U; + // /* QSGMII port */ + // phyAddr = 18U; + /* RGMII port */ + phyAddr = 1U; break; case ENET_MAC_PORT_7: @@ -533,14 +537,16 @@ void EnetBoard_setPhyConfigRgmii(Enet_Type enetType, * GESI board: 0, 1, 2, 3 * SGMII board: 2, 3, 6, 7 * QSGMII board: 0, 2, 3, 7 + * untouch RGMII: 0, 2, 4, 5, port 1, 3, 5, 6 */ EnetAppUtils_assert((portNum == ENET_MAC_PORT_1) || - (portNum == ENET_MAC_PORT_2) || + // (portNum == ENET_MAC_PORT_2) || (portNum == ENET_MAC_PORT_3) || - (portNum == ENET_MAC_PORT_4) || + // (portNum == ENET_MAC_PORT_4) || (portNum == ENET_MAC_PORT_5) || - (portNum == ENET_MAC_PORT_7) || - (portNum == ENET_MAC_PORT_8)); + // (portNum == ENET_MAC_PORT_7) || + (portNum == ENET_MAC_PORT_6)); + // (portNum == ENET_MAC_PORT_8)); EnetBoard_setEnetControl(enetType, 0U/* instId */, portNum, RGMII); #elif defined (SOC_J7200) if (enetType == ENET_CPSW_2G) @@ -632,9 +638,8 @@ void EnetBoard_setPhyConfig(Enet_Type enetType, case ENET_CPSW_9G: if ( ENET_MAC_PORT_1 == portNum || ENET_MAC_PORT_3 == portNum || - ENET_MAC_PORT_4 == portNum || ENET_MAC_PORT_5 == portNum || - ENET_MAC_PORT_8 == portNum ) + ENET_MAC_PORT_6 == portNum ) { EnetBoard_setPhyConfigRgmii(enetType, portNum, diff --git a/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux.c b/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux.c index 726c756..f0606e4 100644 --- a/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux.c +++ b/packages/ti/drv/enet/examples/utils/V1/enet_board_pinmux.c @@ -85,7 +85,7 @@ int32_t EnetBoard_configEthFwPinmux (void) BOARD_SOC_DOMAIN_MAIN); /* Overwrite the ICSSG RGMII muc configurations with CPSW */ /* Below is CPSW9G QSGMII pinmux configuration, - RGMII Ports - 1,3,4,8. QSGMII ports - 2,5,6,7 */ + RGMII Ports - 1,3,5,6. QSGMII ports - 2,4,7,8 */ // Board_pinmuxUpdate(gJ721E_MainPinmuxDataGesiCpsw9gQsgmii, Board_pinmuxUpdate(gJ721E_MainPinmuxDataGesiCpsw9g, BOARD_SOC_DOMAIN_MAIN); diff --git a/packages/ti/drv/enet/examples/utils/enet_mcm.c b/packages/ti/drv/enet/examples/utils/enet_mcm.c index 1cc7911..6928921 100644 --- a/packages/ti/drv/enet/examples/utils/enet_mcm.c +++ b/packages/ti/drv/enet/examples/utils/enet_mcm.c @@ -41,6 +41,7 @@ /* ========================================================================== */ /* This is needed for memset/memcpy */ #include <string.h> +#include <stdio.h> #include <xdc/std.h> #include <xdc/runtime/Error.h> @@ -863,6 +864,7 @@ static void EnetMcm_periodicTick(UArg hTimerSem, { Semaphore_pend(timerSem, BIOS_WAIT_FOREVER); /* Enet_periodicTick should be called from only task context */ + // printf("[LXC]: EnetMcm_periodicTick enet_mcm.c \n"); Enet_periodicTick(hMcm->hEnet); } } diff --git a/packages/ti/drv/enet/src/mod/cpsw_macport.c b/packages/ti/drv/enet/src/mod/cpsw_macport.c index 189de4d..120ecf5 100644 --- a/packages/ti/drv/enet/src/mod/cpsw_macport.c +++ b/packages/ti/drv/enet/src/mod/cpsw_macport.c @@ -484,6 +484,7 @@ int32_t CpswMacPort_open(EnetMod_Handle hMod, /* Check if SoC settings (if any) matches the requested MII config */ status = CpswMacPort_checkSocCfg(enetType, instId, macPort, mii); ENETTRACE_ERR_IF(status != ENET_SOK, "MAC %u: MII mismatch with SoC settings\n", portId); + ENETTRACE_ERR_IF(status != ENET_SOK, "[LXC] MAC %u: MII mismatch with SoC settings\n", portId); /* Soft-reset the Ethernet MAC logic and SGMII port */ if (status == ENET_SOK) diff --git a/packages/ti/drv/enet/src/phy/enetphy.c b/packages/ti/drv/enet/src/phy/enetphy.c index 5ac6b11..011c135 100644 --- a/packages/ti/drv/enet/src/phy/enetphy.c +++ b/packages/ti/drv/enet/src/phy/enetphy.c @@ -175,7 +175,7 @@ static void EnetPhy_showLinkPartnerCompat(EnetPhy_Handle hPhy, /* PHY drivers */ extern EnetPhy_Drv gEnetPhyDrvGeneric; extern EnetPhy_Drv gEnetPhyDrvDp83822; -extern EnetPhy_Drv gEnetPhyDrvDp83867; +// extern EnetPhy_Drv gEnetPhyDrvDp83867; extern EnetPhy_Drv gEnetPhyDrvVsc8514; /*! \brief All the registered PHY specific drivers. */ @@ -183,7 +183,7 @@ static EnetPhyDrv_Handle gEnetPhyDrvs[] = { &gEnetPhyDrvVsc8514, /* VSC8514 */ &gEnetPhyDrvDp83822, /* DP83822 */ - &gEnetPhyDrvDp83867, /* DP83867 */ + // &gEnetPhyDrvDp83867, /* DP83867 */ &gEnetPhyDrvGeneric, /* Generic PHY - must be last */ }; diff --git a/packages/ti/drv/enet/src/phy/generic_phy.c b/packages/ti/drv/enet/src/phy/generic_phy.c index 1d3534c..1210ebc 100644 --- a/packages/ti/drv/enet/src/phy/generic_phy.c +++ b/packages/ti/drv/enet/src/phy/generic_phy.c @@ -137,48 +137,48 @@ void SetupI2CTransfer(I2C_Handle handle, uint32_t slaveAddr, printf("\n[LXC]: SetupI2CTransfer end. \n"); } extern void Board_delay(uint32_t delayCycles); -void Bcm89881_init(EnetPhy_Handle hPhy) -{ - I2C_Params i2cParams; - I2C_Handle handle = NULL; - uint8_t dataToSlave[4]; - - /* - * Configuring TCA6424 IO Exp 2 with addr 0x22 - * This io expander is controlled by i2c0 - */ - /* I2C initialization */ - printf("\n[LXC]: Bcm89881_init start. \n"); - I2C_init(); - I2C_Params_init(&i2cParams); - i2cParams.transferMode = I2C_MODE_BLOCKING; - i2cParams.bitRate = I2C_400kHz; - i2cParams.transferCallbackFxn = NULL; - - handle = I2C_open(0U, &i2cParams); - -printf("\n[LXC]: Bcm89881_init ing 11111. \n"); - dataToSlave[0] = TCA6424_REG_CONFIG0 | TCA6424_CMD_AUTO_INC; - dataToSlave[1] = 0x0U; - SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 2, NULL, 0); -printf("\n[LXC]: Bcm89881_init ing 22222. \n"); - - dataToSlave[0] = TCA6424_REG_INPUT0 | TCA6424_CMD_AUTO_INC; - dataToSlave[1] = 0x0U; - dataToSlave[2] = 0x0U; - dataToSlave[3] = 0x0U; - SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 1, &dataToSlave[1], 3); -printf("\n[LXC]: Bcm89881_init ing 33333. \n"); - - /* Set P20 to 0. Delay 22, and Set to 1; - */ - Board_delay(22); - dataToSlave[0] = TCA6424_REG_OUTPUT2; - dataToSlave[1] |= 0x1; - SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 1, &dataToSlave[1], 1); - printf("\n[LXC]: Bcm89881_init Stop. \n"); +// void Bcm89881_init(EnetPhy_Handle hPhy) +// { +// I2C_Params i2cParams; +// I2C_Handle handle = NULL; +// uint8_t dataToSlave[4]; + +// /* +// * Configuring TCA6424 IO Exp 2 with addr 0x22 +// * This io expander is controlled by i2c0 +// */ +// /* I2C initialization */ +// printf("\n[LXC]: Bcm89881_init start. \n"); +// I2C_init(); +// I2C_Params_init(&i2cParams); +// i2cParams.transferMode = I2C_MODE_BLOCKING; +// i2cParams.bitRate = I2C_400kHz; +// i2cParams.transferCallbackFxn = NULL; + +// handle = I2C_open(0U, &i2cParams); + +// printf("\n[LXC]: Bcm89881_init ing 11111. \n"); +// dataToSlave[0] = TCA6424_REG_CONFIG0 | TCA6424_CMD_AUTO_INC; +// dataToSlave[1] = 0x0U; +// SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 2, NULL, 0); +// printf("\n[LXC]: Bcm89881_init ing 22222. \n"); + +// dataToSlave[0] = TCA6424_REG_INPUT0 | TCA6424_CMD_AUTO_INC; +// dataToSlave[1] = 0x0U; +// dataToSlave[2] = 0x0U; +// dataToSlave[3] = 0x0U; +// SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 1, &dataToSlave[1], 3); +// printf("\n[LXC]: Bcm89881_init ing 33333. \n"); + +// /* Set P20 to 0. Delay 22, and Set to 1; +// */ +// Board_delay(22); +// dataToSlave[0] = TCA6424_REG_OUTPUT2; +// dataToSlave[1] |= 0x1; +// SetupI2CTransfer(handle, 0x22, &dataToSlave[0], 1, &dataToSlave[1], 1); +// printf("\n[LXC]: Bcm89881_init Stop. \n"); -} +// } static bool GenericPhy_isPhyDevSupported(EnetPhy_Handle hPhy, const EnetPhy_Version *version) @@ -601,6 +601,11 @@ static void Bcm89881_config(EnetPhy_Handle hPhy) printf("[LXC]: Bcm89881_config hPhy->addr = %d\n", hPhy->addr); + // g_DEVAD = 0x01; + // uint16_t val = 0; + // EnetPhy_readReg(hPhy, 0x0002, &val); + // printf("[LXC]: Bcm89881_config PMA_PMD_IEEE_DEVICE_ID_REG0 = 0x%x\n", val); + /* master mode */ if (g_master) { if (g_speed == 1000) diff --git a/packages/ti/drv/enet/unit_test/test_cases/enet_test_entry.c b/packages/ti/drv/enet/unit_test/test_cases/enet_test_entry.c index 0b065a5..8e62201 100644 --- a/packages/ti/drv/enet/unit_test/test_cases/enet_test_entry.c +++ b/packages/ti/drv/enet/unit_test/test_cases/enet_test_entry.c @@ -223,6 +223,7 @@ static void EnetTest_periodicTick(UArg a0, EnetTestTaskObj *taskObj = (EnetTestTaskObj *)a1; Enet_periodicTick(EnetTestCommon_getCpswHandle(taskObj)); + printf("[LXC]: EnetTest_periodicTick enet_test_entry.c \n"); } }
The ethfw patch:
commit a9710bfbceb112272a918c85cb50db9c3609b99d Author: liuxianchao <liuxianchao@untouch-tech.com> Date: Fri Sep 24 10:46:23 2021 +0800 push test code for cpsw9g rgmii5 diff --git a/apps/app_remoteswitchcfg_server/mcu_2_0/main_tirtos.c b/apps/app_remoteswitchcfg_server/mcu_2_0/main_tirtos.c index 74cc0df..c90e5ac 100644 --- a/apps/app_remoteswitchcfg_server/mcu_2_0/main_tirtos.c +++ b/apps/app_remoteswitchcfg_server/mcu_2_0/main_tirtos.c @@ -207,6 +207,14 @@ static void EthApp_startSwInterVlan(char *recvBuff, static void EthApp_startHwInterVlan(char *recvBuff, char *sendBuff); +static int32_t EthApp_addRemoteCoreStaticCfg(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId); + +static void EthApp_delRemoteCoreStaticCfg(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId); + /* ========================================================================== */ /* Extern variables */ /* ========================================================================== */ @@ -563,6 +571,10 @@ static int32_t EthApp_initEthFw(void) ethFwCfg.ports[i].portNum); } + /* Set static configuration functions */ + ethFwCfg.addStaticCfg = &EthApp_addRemoteCoreStaticCfg; + ethFwCfg.delStaticCfg = &EthApp_delRemoteCoreStaticCfg; + /* Initialize the EthFw */ gEthAppObj.hEthFw = EthFw_init(gEthAppObj.enetType, ðFwCfg); if (gEthAppObj.hEthFw == NULL) @@ -571,6 +583,8 @@ static int32_t EthApp_initEthFw(void) status = ETHAPP_ERROR; } + appLogPrintf("[untouch:liuxianchao]:EthApp_initEthFw do\n"); + /* Get and print EthFw version */ if (status == ETHAPP_OK) { @@ -587,6 +601,168 @@ static int32_t EthApp_initEthFw(void) return status; } +static int32_t EthApp_addMpu10StaticCfg(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId) +{ + const uint8_t mcastAddr[ENET_MAC_ADDR_LEN] = {0x01, 0x99, 0xc2, 0x00, 0x01, 0x0E}; + CpswAle_SetPolicerEntryInArgs polInArgs; + CpswAle_SetPolicerEntryOutArgs polOutArgs; + CpswAle_SetMcastEntryInArgs mcastInArgs; + Enet_IoctlPrms prms; + uint32_t entry; + int32_t status; + + polInArgs.policerMatch.policerMatchEnMask = 0U; + + /* Add policer entry for port 1 and dstmac */ + polInArgs.policerMatch.policerMatchEnMask = CPSW_ALE_POLICER_MATCH_PORT; + polInArgs.policerMatch.portNum = CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_2); + polInArgs.policerMatch.portIsTrunk = false; + + polInArgs.policerMatch.policerMatchEnMask |= CPSW_ALE_POLICER_MATCH_MACDST; + polInArgs.policerMatch.dstMacAddrInfo.portNum = CPSW_ALE_HOST_PORT_NUM; + polInArgs.policerMatch.dstMacAddrInfo.addr.vlanId = 0U; + EnetUtils_copyMacAddr(&polInArgs.policerMatch.dstMacAddrInfo.addr.addr[0], &mcastAddr[0]); + + polInArgs.threadIdEn = true; + polInArgs.threadId = flowId; + + polInArgs.peakRateInBitsPerSec = 0U; + polInArgs.commitRateInBitsPerSec = 0U; + + ENET_IOCTL_SET_INOUT_ARGS(&prms, &polInArgs, &polOutArgs); + + appLogPrintf("[yihang:wangkepei]:EthApp_addMpu10StaticCfg do\n"); + + status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_SET_POLICER, &prms); + if (status != ENET_SOK) + { + appLogPrintf("Failed to register PORT1 | MACDST policer: %d\n", status); + } + + /* Add policer entry for port 3 and dstmac */ + if (status == ENET_SOK) + { + polInArgs.policerMatch.portNum = CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_5); + + ENET_IOCTL_SET_INOUT_ARGS(&prms, &polInArgs, &polOutArgs); + + status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_SET_POLICER, &prms); + if (status != ENET_SOK) + { + appLogPrintf("Failed to register PORT3 | MACDST policer: %d\n", status); + } + } + + /* Add multicast entry with port mask: host port, MAC port 1 and MAC port 3 */ + if (status == ENET_SOK) + { + mcastInArgs.addr.vlanId = 0U; + EnetUtils_copyMacAddr(&mcastInArgs.addr.addr[0], &mcastAddr[0]); + + mcastInArgs.info.super = false; + mcastInArgs.info.fwdState = CPSW_ALE_FWDSTLVL_FWD; + mcastInArgs.info.portMask = (CPSW_ALE_HOST_PORT_MASK | + CPSW_ALE_MACPORT_TO_PORTMASK(ENET_MAC_PORT_2) | + CPSW_ALE_MACPORT_TO_PORTMASK(ENET_MAC_PORT_5)); + mcastInArgs.info.numIgnBits = 0U; + + ENET_IOCTL_SET_INOUT_ARGS(&prms, &mcastInArgs, &entry); + + status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_ADD_MCAST, &prms); + if (status != ENET_SOK) + { + appLogPrintf("Failed to add mcast ports: %d\n", status); + } + } + + return status; +} + +static void EthApp_delMpu10StaticCfg(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId) +{ + const uint8_t mcastAddr[ENET_MAC_ADDR_LEN] = {0x01, 0x80, 0xc2, 0x00, 0x01, 0x0E}; + CpswAle_DelPolicerEntryInArgs polInArgs; + Enet_IoctlPrms prms; + int32_t status; + + polInArgs.policerMatch.policerMatchEnMask = 0U; + + /* Delete policer entry for port 1 and dstmac */ + polInArgs.policerMatch.policerMatchEnMask = CPSW_ALE_POLICER_MATCH_PORT; + polInArgs.policerMatch.portNum = CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_2); + polInArgs.policerMatch.portIsTrunk = false; + + polInArgs.policerMatch.policerMatchEnMask |= CPSW_ALE_POLICER_MATCH_MACDST; + polInArgs.policerMatch.dstMacAddrInfo.portNum = CPSW_ALE_HOST_PORT_NUM; + polInArgs.policerMatch.dstMacAddrInfo.addr.vlanId = 0U; + EnetUtils_copyMacAddr(&polInArgs.policerMatch.dstMacAddrInfo.addr.addr[0], &mcastAddr[0]); + + polInArgs.aleEntryMask = CPSW_ALE_POLICER_MATCH_PORT; + + ENET_IOCTL_SET_IN_ARGS(&prms, &polInArgs); + + status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_DEL_POLICER, &prms); + if (status != ENET_SOK) + { + appLogPrintf("Failed to delete PORT1 | MACDST policer: %d\n", status); + } + + /* Delete policer entry for port 3 and dstmac */ + if (status == ENET_SOK) + { + polInArgs.policerMatch.portNum = CPSW_ALE_MACPORT_TO_ALEPORT(ENET_MAC_PORT_5); + + ENET_IOCTL_SET_IN_ARGS(&prms, &polInArgs); + + status = Enet_ioctl(hEnet, gEthAppObj.coreId, CPSW_ALE_IOCTL_DEL_POLICER, &prms); + if (status != ENET_SOK) + { + appLogPrintf("Failed to delete PORT3 | MACDST policer: %d\n", status); + } + } +} + +static int32_t EthApp_addRemoteCoreStaticCfg(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId) +{ + int32_t status = ENET_SOK; + + switch (coreId) + { + case IPC_MPU1_0: + appLogPrintf("Add static config for mpu1_0\n"); + status = EthApp_addMpu10StaticCfg(hEnet, coreId, flowId); + break; + + default: + break; + } + + return status; +} + +static void EthApp_delRemoteCoreStaticCfg(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId) +{ + switch (coreId) + { + case IPC_MPU1_0: + appLogPrintf("Delete static config for mpu1_0\n"); + EthApp_delMpu10StaticCfg(hEnet, coreId, flowId); + break; + + default: + break; + } +} + + static int32_t EthApp_initRemoteServices(void) { int32_t status; diff --git a/ethfw/ethfw.h b/ethfw/ethfw.h index ef4a8c9..cafab00 100644 --- a/ethfw/ethfw.h +++ b/ethfw/ethfw.h @@ -178,6 +178,35 @@ typedef struct EthFw_PortConfig_s EnetPort_VlanCfg vlanCfg; } EthFw_Port; +/*! + * \brief Add static configuration. + * + * Add static configuration that is applicable only to specific remote cores. + * + * \param hEnet Handle to Enet LLD + * \param coreId Remote core's IPC core id + * \param flowId Remote core's flow id + * + * \return 0 if no error. Negative value otherwise. + */ +typedef int32_t (*EthFw_addStaticCfg)(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId); + +/*! + * \brief Delete static configuration. + * + * Delete static configuration that is applicable only to specific remote cores. + * + * \param hEnet Handle to Enet LLD + * \param coreId Remote core's IPC core id + * \param flowId Remote core's flow id + */ +typedef void (*EthFw_delStaticCfg)(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId); + + /*! * \brief Ethernet Firmware configuration * @@ -195,6 +224,12 @@ typedef struct EthFw_Config_s /*! Number of MAC ports owned by EthFw, that is, the size of * EthFw_Config::ports array */ uint32_t numPorts; + + /* Add static configuration that is applicable only to specific remote cores */ + EthFw_addStaticCfg addStaticCfg; + + /* Delete static configuration that is applicable only to specific remote cores */ + EthFw_delStaticCfg delStaticCfg; } EthFw_Config; /*! diff --git a/ethfw/src/ethfw.c b/ethfw/src/ethfw.c index f8eeb7e..c99b637 100644 --- a/ethfw/src/ethfw.c +++ b/ethfw/src/ethfw.c @@ -182,6 +182,12 @@ typedef struct EthFw_Obj_s /* Handle to PTP stack */ TimeSyncPtp_Handle timeSyncPtp; + /* Add static configuration that is applicable only to specific remote cores */ + EthFw_addStaticCfg addStaticCfg; + + /* Delete static configuration that is applicable only to specific remote cores */ + EthFw_delStaticCfg delStaticCfg; + } EthFw_Obj; /* ========================================================================== */ @@ -268,6 +274,10 @@ void EthFw_initConfigParams(Enet_Type enetType, CpswHostPort_Cfg *hostPortCfg = &cpswCfg->hostPortCfg; EnetRm_ResCfg *resCfg = &cpswCfg->resCfg; + /* Initialize Static config function pointers */ + config->addStaticCfg = NULL; + config->delStaticCfg = NULL; + /* MAC port ownership */ config->ports = NULL; config->numPorts = 0U; @@ -306,6 +316,10 @@ EthFw_Handle EthFw_init(Enet_Type enetType, memset(&gEthFwObj, 0, sizeof(gEthFwObj)); + /* Save static config function pointers */ + gEthFwObj.addStaticCfg = config->addStaticCfg; + gEthFwObj.delStaticCfg = config->delStaticCfg; + /* Save config parameters */ gEthFwObj.cpswCfg = config->cpswCfg; gEthFwObj.numPorts = config->numPorts; @@ -419,6 +433,10 @@ int32_t EthFw_initRemoteConfig(EthFw_Handle hEthFw) cfg.notifyServiceRemoteCoreId[0] = IPC_MPU1_0; cfg.notifyServiceRemoteCoreId[1] = IPC_MCU2_1; + /* Static configuration callbacks */ + cfg.addStaticCfg = gEthFwObj.addStaticCfg; + cfg.delStaticCfg = gEthFwObj.delStaticCfg; + status = CpswProxyServer_init(&cfg); if (status != ENET_SOK) { @@ -558,6 +576,9 @@ static void EthFw_initLinkArgs(EnetPer_PortLinkCfg *linkArgs, if (gEthFwObj.ports[i].portNum == macPort) { macCfg->vlanCfg = gEthFwObj.ports[i].vlanCfg; + + appLogPrintf("[untouch:liuxianchao] EthFw_initLinkArgs, macPort = %d, vlanCfg portCfi is %d, portPri is %d, portVID is %d\r\n\n", + macPort, macCfg->vlanCfg.portCfi, macCfg->vlanCfg.portPri, macCfg->vlanCfg.portVID); } } } diff --git a/ethremotecfg/server/include/cpsw_proxy_server.h b/ethremotecfg/server/include/cpsw_proxy_server.h index c1acfa9..f4d2e41 100644 --- a/ethremotecfg/server/include/cpsw_proxy_server.h +++ b/ethremotecfg/server/include/cpsw_proxy_server.h @@ -162,6 +162,35 @@ typedef struct CpswProxyServer_RemoteCoreConfig_s char serverName[ETHREMOTECFG_SERVER_MAX_NAME_LEN]; } CpswProxyServer_RemoteCoreConfig; +/*! + * \brief Add static configuration. + * + * Add static configuration that is applicable only to specific remote cores. + * + * \param hEnet Handle to Enet LLD + * \param coreId Remote core's IPC core id + * \param flowId Remote core's flow id + * + * \return 0 if no error. Negative value otherwise. + */ +typedef int32_t (*CpswProxyServer_addStaticCfg)(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId); + +/*! + * \brief Delete static configuration. + * + * Delete static configuration that is applicable only to specific remote cores. + * + * \param hEnet Handle to Enet LLD + * \param coreId Remote core's IPC core id + * \param flowId Remote core's flow id + */ +typedef void (*CpswProxyServer_delStaticCfg)(Enet_Handle hEnet, + uint32_t coreId, + uint32_t flowId); + + /*! * \brief Cpsw Proxy Server Remote Configuration structure * @@ -199,6 +228,12 @@ typedef struct CpswProxyServer_Config_s /*! Remote Core configuration */ CpswProxyServer_RemoteCoreConfig remoteCoreCfg[ETHREMOTECFG_SERVER_MAX_INSTANCES]; + + /* Add static configuration that is applicable only to specific remote cores */ + CpswProxyServer_addStaticCfg addStaticCfg; + + /* Delete static configuration that is applicable only to specific remote cores */ + CpswProxyServer_delStaticCfg delStaticCfg; } CpswProxyServer_Config_t; /*! diff --git a/ethremotecfg/server/src/cpsw_proxy_server.c b/ethremotecfg/server/src/cpsw_proxy_server.c index 4c01eaa..295b781 100644 --- a/ethremotecfg/server/src/cpsw_proxy_server.c +++ b/ethremotecfg/server/src/cpsw_proxy_server.c @@ -184,6 +184,12 @@ typedef struct CpswProxyServer_Obj_s SemaphoreP_Handle rdevStartSem; CpswProxyServer_EthDriverObj ethDrvObj; CpswProxyServer_NotifyServiceObj notifyServiceObj; + + /* Add static configuration that is applicable only to specific remote cores */ + CpswProxyServer_addStaticCfg addStaticCfg; + + /* Delete static configuration that is applicable only to specific remote cores */ + CpswProxyServer_delStaticCfg delStaticCfg; } CpswProxyServer_Obj; /* ========================================================================== */ @@ -592,10 +598,13 @@ static int32_t CpswProxyServer_registerMacHandlerCb(uint32_t host_id, u8 *mac_address, uint32_t flow_idx) { + CpswProxyServer_Obj *hProxyServer; int32_t status; Enet_Handle hEnet = (Enet_Handle)((uintptr_t)handle); uint32_t start_flow_idx, flow_idx_offset; + hProxyServer = CpswProxyServer_getHandle(); + CpswProxyServer_validateHandle(hEnet); EnetAppUtils_absFlowIdx2FlowIdxOffset(hEnet, host_id, flow_idx, &start_flow_idx, &flow_idx_offset); appLogPrintf("Function:%s,HostId:%u,Handle:%p,CoreKey:%x, MacAddress:%x:%x:%x:%x:%x:%x, FlowIdx:%u, FlowIdxOffset:%u\n", @@ -618,6 +627,23 @@ static int32_t CpswProxyServer_registerMacHandlerCb(uint32_t host_id, appLogPrintf("EnetAppUtils_regDstMacRxFlow() failed CPSW_ALE_IOCTL_SET_POLICER: %d\n", status); status = RPMSG_KDRV_TP_ETHSWITCH_CMDSTATUS_EFAIL; } + + if (ENET_SOK == status) + { + if (hProxyServer->addStaticCfg != NULL) + { + status = hProxyServer->addStaticCfg(hEnet, host_id, flow_idx_offset); + if (ENET_SOK != status) + { + appLogPrintf("Failed to add static config for coreId=%u: %d\n", host_id, status); + } + } + } + + if (status != ENET_SOK) + { + status = RPMSG_KDRV_TP_ETHSWITCH_CMDSTATUS_EFAIL; + } else { status = RPMSG_KDRV_TP_ETHSWITCH_CMDSTATUS_OK; @@ -632,10 +658,13 @@ static int32_t CpswProxyServer_unregisterMacHandlerCb(uint32_t host_id, u8 *mac_address, uint32_t flow_idx) { + CpswProxyServer_Obj *hProxyServer; int32_t status; Enet_Handle hEnet = (Enet_Handle)((uintptr_t)handle); uint32_t start_flow_idx, flow_idx_offset; + hProxyServer = CpswProxyServer_getHandle(); + CpswProxyServer_validateHandle(hEnet); EnetAppUtils_absFlowIdx2FlowIdxOffset(hEnet, host_id, flow_idx, &start_flow_idx, &flow_idx_offset); appLogPrintf("Function:%s,HostId:%u,Handle:%p,CoreKey:%x, MacAddress:%x:%x:%x:%x:%x:%x, FlowIdx:%u, FlowIdOffset:%u\n", @@ -653,6 +682,19 @@ static int32_t CpswProxyServer_unregisterMacHandlerCb(uint32_t host_id, flow_idx_offset); status = EnetAppUtils_unregDstMacRxFlow(hEnet, core_key, host_id, start_flow_idx, flow_idx_offset, mac_address); + if (status != ENET_SOK) + { + appLogPrintf("Failed EnetAppUtils_unregDstMacRxFlow: %d\n", status); + } + + if (ENET_SOK == status) + { + if (hProxyServer->delStaticCfg != NULL) + { + hProxyServer->delStaticCfg(hEnet, host_id, flow_idx_offset); + } + } + if (status != ENET_SOK) { appLogPrintf("Failed EnetAppUtils_unregDstMacRxFlow: %d\n", status); @@ -1657,6 +1699,10 @@ int32_t CpswProxyServer_init(CpswProxyServer_Config_t *cfg) hProxyServer->initDone = true; appLogPrintf("Remote demo device (core : mcu2_0) .....\r\n"); + + hProxyServer->addStaticCfg = cfg->addStaticCfg; + hProxyServer->delStaticCfg = cfg->delStaticCfg; + return ENET_SOK; }
