YCrCb packed capture using DM642 video port driver
I need to capture BT.656 video with DM642 in YCrCb packed format (Cb-Y-Cr-Y... or something similar). The video port driver seems to only support planar capture. I was wondering if raw capture could be used to achieve what I need. I'm not sure if in raw capture mode the video port will sync to embedded BT.656 sync's.
Any comments? Advise?
Thanks.
  • Alexander,
    DM642 video port only supports planar capture. As you mentioned, the only way to capture cb-y-cr-y interleaved data is through raw capture. In that case, it will not be able to detect embedded sync though. You'd need to use AVID for capture enable.
    Xiangdong
