When i build a simple opemp project with only one main.cpp files as follow:
#include <vector> struct ABC{ float *data; } void test_fxn(const std::vector<ABC>& obj) { float * data=obj[0].data; }
an internal error will happen:
**** Build of configuration Debug for project test ****
"C:\\ti\\ccs930\\ccs\\utils\\bin\\gmake" -k -j 64 all -O
Building file: "../main.cpp"
Invoking: C6000 Compiler
"C:/ti/ccs930/ccs/tools/compiler/ti-cgt-c6000_8.3.8/bin/cl6x" -mv6600 --include_path="C:/Users/YuHaoxin/Documents/CCS_Workspace/test" --include_path="C:/ti/ccs930/ccs/tools/compiler/ti-cgt-c6000_8.3.8/include" -g --c99 --c++14 --diag_warning=225 --diag_wrap=off --display_error_number --multithread --openmp --preproc_with_compile --preproc_dependency="main.d_raw" --cmd_file="C:/Users/YuHaoxin/Documents/CCS_Workspace/cfg/Debug/configPkg/compiler.opt" "../main.cpp"
>> Compilation failure
subdir_rules.mk:9: recipe for target 'main.obj' failed
INTERNAL ERROR: C:\ti\ccs930\ccs\tools\compiler\ti-cgt-c6000_8.3.8\bin\acpia6x.exe experienced a segmentation fault
while processing function (unknown or file scope) file ../main.cpp line 9
This is caused by a defect in the TI EABI C/C++ Parser.
TI Customer Support may be able to suggest a workaround to avoid this.
Upgrading to the newest version of the compiler may fix this problem.
Contact TI in the E2E support forums at http://e2e.ti.com under
"Development Tools", "TI C/C++ Compiler". See the link titled
"Submitting an issue".
We need to see this ENTIRE error message and a complete, reproducible
test case including ALL of the command-line options.
Include the .pp file created by option --preproc_with_comment
gmake: *** [main.obj] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
The compiler options are : -mv6600 --include_path="C:/Users/YuHaoxin/Documents/CCS_Workspace/test" --include_path="C:/ti/ccs930/ccs/tools/compiler/ti-cgt-c6000_8.3.8/include" -g --c99 --c++14 --diag_warning=225 --diag_wrap=off --display_error_number --multithread --openmp
After remove "--openmp", everthing is fine.
I want to use openmp and STL at the same time, how do I solve this issue?
