SK-TDA4VM: spl: mmc init failed with error: -110
Part Number: SK-TDA4VM
Other Parts Discussed in Thread: INA226
we are working on building a custom IPC application on Jacinto 7 evaluation board. We are using an SD card as the boot source with the altered firmware for different MCU's.
while we reboot from the terminal or power cycle we are encountered with the below-mentioned error, but when we power cycle multiple times the board boots from the sd card.
SDK - 3.7
SD card - 64GB SanDisk ultra
I use the below method to copy the new firmware to the board.
user@KOEM-Sam:~/ti_sdk_7.3v_IPC/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/pdk_jacinto_07_03_00_29/packages/ti/binary/ipc_echo_test/bin/j721e_evm$ scp ipc_echo_test_mcu3_1_release_strip.xer5f root@10.201.4.248:/lib/firmware/pdk-ipc/
U-Boot SPL 2020.01-g2781231a33 (Apr 10 2021 - 01:08:23 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE: BL31: v2.4(release):07.03.00.005-dirty
NOTICE: BL31: Built : 00:15:40, Apr 10 2021
U-Boot SPL 2020.01-g2781231a33 (Apr 10 2021 - 00:17:14 +0000)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
mmc_init: -110, time 242
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
  • new error logs while power cycling the board.
    mmc_init: -110, time 233
    mmc_init: -110, time 232
    U-Boot 2020.01-g2781231a33 (Apr 10 2021 - 00:17:14 +0000)
    SoC: J721E SR1.0
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E7
    DRAM: 4 GiB
    not found for dev hbmc-mux
    Flash: 0 Bytes
    MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from MMC... OK
    In: serial@2800000
    Out: serial@2800000
    Err: serial@2800000
    Net: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Warning: ethernet@46000000 using MAC address from ROM
    eth0: ethernet@46000000
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    0 bytes read in 1 ms (0 Bytes/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    16799752 bytes read in 350 ms (45.8 MiB/s)
    97793 bytes read in 4 ms (23.3 MiB/s)
    Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
    Starting kernel ...
    [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [ 0.000000] Linux version 5.4.106-g023faefa70 (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Sat Apr 10 00:18:09 UTC1
    [ 0.000000] Machine model: Texas Instruments K3 J721E SoC
    [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [ 0.000000] printk: bootconsole [ns16550a0] enabled
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    [ 0.000000] psci: probing for conduit method from DT.
    [ 0.000000] psci: PSCIv1.1 detected in firmware.
    [ 0.000000] psci: Using standard PSCI v0.2 function IDs
    [ 0.000000] psci: Trusted OS migration not required
    [ 0.000000] psci: SMC Calling Convention v1.0
    [ 0.000000] percpu: Embedded 2 pages/cpu s48472 r8192 d74408 u131072
    [ 0.000000] Detected PIPT I-cache on CPU0
    [ 0.000000] CPU features: detected: GIC system register CPU interface
    [ 0.000000] CPU features: detected: EL2 vector hardening
    [ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 40192
    [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backupt
    [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [ 0.000000] software IO TLB: mapped [mem 0xbbff0000-0xbfff0000] (64MB)
    [ 0.000000] Memory: 3374400K/2576384K available (9662K kernel code, 790K rwdata, 3904K rodata, 1664K init, 681K bss, 18446744073708229312K reserved, 524288K cma-reserved)
    [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
    [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [ 0.000000] Tasks RCU enabled.
    [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [ 0.000000] GICv3: 960 SPIs implemented
    [ 0.000000] GICv3: 0 Extended SPIs implemented
    [ 0.000000] GICv3: Distributor has no Range Selector support
    [ 0.000000] GICv3: 16 PPIs implemented
    [ 0.000000] GICv3: no VLPI support, no direct LPI support
    [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [ 0.000000] ITS [mem 0x01820000-0x0182ffff]
    [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [ 0.000000] ITS: using cache flushing for cmd queue
    [ 0.000000] GICv3: using LPI property table @0x00000008c00c0000
    [ 0.000000] GIC: using cache flushing for LPI property table
    [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
    [ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x42c with crng_init=0
    [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [ 0.008348] Console: colour dummy device 80x25
    [ 0.012908] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [ 0.023576] pid_max: default: 32768 minimum: 301
    [ 0.028324] LSM: Security Framework initializing
    [ 0.033068] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [ 0.040634] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [ 0.049583] ASID allocator initialised with 32768 entries
    [ 0.055160] rcu: Hierarchical SRCU implementation.
    [ 0.060179] Platform MSI: gic-its@1820000 domain created
    [ 0.065795] PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created
    [ 0.074585] smp: Bringing up secondary CPUs ...
    [ 0.079749] Detected PIPT I-cache on CPU1
    [ 0.079770] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [ 0.079779] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
    [ 0.079804] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [ 0.079851] smp: Brought up 1 node, 2 CPUs
    [ 0.109195] SMP: Total of 2 processors activated.
    [ 0.113999] CPU features: detected: 32-bit EL0 Support
    [ 0.119252] CPU features: detected: CRC32 instructions
    [ 0.130765] CPU: All CPU(s) started at EL2
    [ 0.134959] alternatives: patching kernel code
    [ 0.139980] devtmpfs: initialized
    [ 0.148066] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [ 0.158031] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [ 0.165840] pinctrl core: initialized pinctrl subsystem
    [ 0.171612] NET: Registered protocol family 16
    [ 0.179078] DMA: preallocated 256 KiB pool for atomic allocations
    [ 0.185585] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [ 0.201197] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [ 0.208052] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [ 0.214812] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [ 0.222629] cryptd: max_cpu_qlen set to 1000
    [ 0.228720] vsys_3v3: supplied by evm_12v0
    [ 0.232992] vsys_5v0: supplied by evm_12v0
    [ 0.237543] iommu: Default domain type: Translated
    [ 0.242705] SCSI subsystem initialized
    [ 0.246806] mc: Linux media interface: v0.10
    [ 0.251176] videodev: Linux video capture interface: v2.00
    [ 0.256787] pps_core: LinuxPPS API ver. 1 registered
    [ 0.261857] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.271193] PTP clock support registered
    [ 0.275204] EDAC MC: Ver: 3.0.0
    [ 0.278909] FPGA manager framework
    [ 0.282416] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.289018] clocksource: Switched to clocksource arch_sys_counter
    [ 0.295316] VFS: Disk quotas dquot_6.6.0
    [ 0.299361] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [ 0.308637] thermal_sys: Registered thermal governor 'step_wise'
    [ 0.308638] thermal_sys: Registered thermal governor 'power_allocator'
    [ 0.315029] NET: Registered protocol family 2
    [ 0.326421] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [ 0.335185] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [ 0.343376] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [ 0.351104] TCP: Hash tables configured (established 32768 bind 32768)
    [ 0.357826] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [ 0.364716] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [ 0.372107] NET: Registered protocol family 1
    [ 0.376775] RPC: Registered named UNIX socket transport module.
    [ 0.382829] RPC: Registered udp transport module.
    [ 0.387632] RPC: Registered tcp transport module.
    [ 0.392434] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.399018] PCI: CLS 0 bytes, default 64
    [ 0.403329] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [ 0.413116] Initialise system trusted keyrings
    [ 0.417724] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [ 0.426293] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.432476] NFS: Registering the id_resolver key type
    [ 0.437648] Key type id_resolver registered
    [ 0.441918] Key type id_legacy registered
    [ 0.446014] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [ 0.452934] 9p: Installing v9fs 9p2000 file system support
    [ 0.466076] Key type asymmetric registered
    [ 0.470259] Asymmetric key parser 'x509' registered
    [ 0.475254] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [ 0.482811] io scheduler mq-deadline registered
    [ 0.487436] io scheduler kyber registered
    [ 0.492643] pinctrl-single 4301c000.pinmux: 94 pins, size 376
    [ 0.498716] pinctrl-single 11c000.pinmux: 173 pins, size 692
    [ 0.506976] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [ 0.513259] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [ 0.519589] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [ 0.526008] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [ 0.533968] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [ 0.540382] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [ 0.548294] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [ 0.554706] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [ 0.562612] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [ 0.568936] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [ 0.576844] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [ 0.583165] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [ 0.592530] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [ 0.604507] brd: module loaded
    [ 0.610349] loop: module loaded
    [ 0.615077] libphy: Fixed MDIO Bus: probed
    [ 0.619464] tun: Universal TUN/TAP device driver, 1.6
    [ 0.624899] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    [ 0.632905] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [ 0.638970] sky2: driver version 1.30
    [ 0.643252] VFIO - User Level meta-driver version: 0.3
    [ 0.648843] i2c /dev entries driver
    [ 0.652934] sdhci: Secure Digital Host Controller Interface driver
    [ 0.659248] sdhci: Copyright(c) Pierre Ossman
    [ 0.663934] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 0.670193] ledtrig-cpu: registered to indicate activity on CPUs
    [ 0.676942] optee: probing for conduit method from DT.
    [ 0.682208] optee: revision 3.11 (c4def2a8)
    [ 0.682492] optee: initialized driver
    [ 0.691346] NET: Registered protocol family 17
    [ 0.695962] 9pnet: Installing 9P2000 support
    [ 0.700348] Key type dns_resolver registered
    [ 0.704856] registered taskstats version 1
    [ 0.709043] Loading compiled-in X.509 certificates
    [ 0.717765] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [ 0.724086] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [ 0.731815] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
    [ 0.750439] random: fast init done
    [ 0.773778] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [ 0.780966] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [ 0.786902] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [ 0.792837] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [ 0.798843] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
    [ 0.806254] pca953x 3-0020: using no AI
    [ 0.833531] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
    [ 0.840931] pca953x 3-0022: using AI
    [ 0.845187] GPIO line 480 (CTRL_PM_I2C_OE) hogged as output/high
    [ 0.851512] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
    [ 0.858104] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
    [ 0.864931] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [ 0.870891] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    [ 0.877499] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
    [ 0.883393] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
    [ 0.890803] pca953x 6-0020: using no AI
    [ 0.917369] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    [ 0.923199] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    [ 0.929019] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    [ 0.934913] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
    [ 0.942321] pca953x 9-0020: using no AI
    [ 0.969371] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    [ 0.975624] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [ 0.985567] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [ 0.994348] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
    [ 1.004501] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain -1 created
    [ 1.022049] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
    [ 2.031359] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [ 2.039031] j721e-pcie 2900000.pcie: IO 0x10001000..0x10010fff -> 0x10001000
    [ 2.046507] j721e-pcie 2900000.pcie: MEM 0x10011000..0x17ffffff -> 0x10011000
    [ 2.054046] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [ 2.060451] pci_bus 0000:00: root bus resource [bus 00-0f]
    [ 2.066055] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [ 2.075744] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [ 2.082784] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [ 2.088933] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [ 2.098802] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [ 2.108688] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [ 2.118646] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [ 2.128612] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [ 2.138574] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [ 2.148556] pci 0000:00:00.0: supports D1
    [ 2.152650] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [ 2.158521] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [ 2.170128] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [ 2.178310] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [ 2.188268] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [ 2.198226] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [ 2.209674] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [ 2.216441] pci 0000:00:00.0: PCI bridge to [bus 01]
    [ 2.221685] pcieport 0000:00:00.0: PME: Signaling with IRQ 46
    [ 2.227686] pcieport 0000:00:00.0: AER: enabled with IRQ 46
    [ 3.235393] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [ 3.243063] j721e-pcie 2910000.pcie: IO 0x18001000..0x18010fff -> 0x18001000
    [ 3.250539] j721e-pcie 2910000.pcie: MEM 0x18011000..0x1fffffff -> 0x18011000
    [ 3.258068] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [ 3.264473] pci_bus 0001:00: root bus resource [bus 00-0f]
    [ 3.270077] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [ 3.279944] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [ 3.286980] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [ 3.293182] pci 0001:00:00.0: supports D1
    [ 3.297275] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [ 3.304782] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [ 3.314472] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
    [ 3.321237] pci 0001:00:00.0: PCI bridge to [bus 01]
    [ 3.326466] pcieport 0001:00:00.0: PME: Signaling with IRQ 49
    [ 3.332452] pcieport 0001:00:00.0: AER: enabled with IRQ 49
    [ 4.340254] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [ 4.347925] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x00001000
    [ 4.355757] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x00011000
    [ 4.363642] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [ 4.370047] pci_bus 0002:00: root bus resource [bus 00-0f]
    [ 4.375651] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [ 4.384897] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [ 4.395677] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [ 4.401879] pci 0002:00:00.0: supports D1
    [ 4.405972] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [ 4.413470] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [ 4.423209] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
    [ 4.429976] pci 0002:00:00.0: PCI bridge to [bus 01]
    [ 4.435206] pcieport 0002:00:00.0: PME: Signaling with IRQ 52
    [ 4.441191] pcieport 0002:00:00.0: AER: enabled with IRQ 52
    [ 4.447570] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [ 4.457446] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [ 4.464205] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [ 4.472987] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [ 4.483136] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [ 4.489894] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [ 4.497720] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
    [ 4.506866] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 23, base_baud = 3000000) is a 8250
    [ 4.515606] printk: console [ttyS2] enabled
    [ 4.524042] printk: bootconsole [ns16550a0] disabled
    [ 4.534349] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 24, base_baud = 3000000) is a 8250
    [ 4.543148] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 25, base_baud = 3000000) is a 8250
    [ 4.551867] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [ 4.560576] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
    [ 4.569182] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
    [ 4.576627] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
    [ 4.586036] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [ 4.596552] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [ 4.606705] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [ 4.616944] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [ 4.627617] scsi host0: ufshcd
    [ 4.649560] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [ 4.673026] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [ 4.680666] libphy: 46000f00.mdio: probed
    [ 4.680710] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [ 4.685759] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [ 4.696327] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [ 4.704553] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [ 4.715805] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [ 4.728415] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
    [ 4.737199] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [ 4.753204] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [ 4.760716] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [ 4.769291] mmc0: CQHCI version 5.10
    [ 4.809022] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
    [ 4.817503] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [ 4.828400] vdd_mmc1: supplied by vsys_3v3
    [ 4.832802] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
    [ 4.840047] pca953x 4-0020: using no AI
    [ 4.865554] GPIO line 200 (DP0_PWR_SW_EN) hogged as output/high
    [ 4.872168] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [ 4.878957] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [ 4.885761] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [ 4.892536] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [ 4.899288] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [ 4.908460] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [ 4.918407] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
    [ 4.931319] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [ 4.936553] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [ 4.943164] Creating 8 MTD partitions on "47040000.spi.0":
    [ 4.948647] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [ 4.954619] 0x000000080000-0x000000280000 : "ospi.tispl"
    [ 4.960348] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [ 4.966160] 0x000000680000-0x0000006a0000 : "ospi.env"
    [ 4.971689] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [ 4.977846] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [ 4.983522] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
    [ 4.989517] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
    [ 4.996122] mmc0: Command Queue Engine enabled
    [ 5.000570] mmc0: new HS200 MMC card at address 0001
    [ 5.005943] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [ 5.010591] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [ 5.016623] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [ 5.022617] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
    [ 5.030888] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [ 5.077026] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [ 5.084673] libphy: 46000f00.mdio: probed
    [ 5.089729] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [ 5.097991] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [ 5.111485] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [ 5.118314] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [ 5.125523] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [ 5.131727] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [ 5.141713] mmc1: CQHCI version 5.10
    [ 6.206627] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
    [ 6.214712] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [ 6.227300] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [ 6.234696] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [ 6.242012] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [ 6.249359] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [ 6.257441] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [ 6.264453] hctosys: unable to open rtc device (rtc0)
    [ 6.277587] ALSA device list:
    [ 6.280544] No soundcards found.
    [ 6.284160] Waiting for root device PARTUUID=32d0df7d-02...
    [ 6.314833] mmc1: new ultra high speed DDR50 SDXC card at address aaaa
    [ 6.321651] mmcblk1: mmc1:aaaa SD64G 59.5 GiB
    [ 6.328727] mmcblk1: p1 p2
    [ 6.624767] EXT4-fs (mmcblk1p2): recovery complete
    [ 6.630559] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [ 6.638667] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [ 6.648805] devtmpfs: mounted
    [ 6.652043] Freeing unused kernel memory: 1664K
    [ 6.656586] Run /sbin/init as init process
    [ 6.821742] systemd[1]: System time before build time, advancing clock.
    [ 6.875548] NET: Registered protocol family 10
    [ 6.880372] Segment Routing with IPv6
    [ 6.903516] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -)
    [ 6.925226] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2020.09!
    [ 6.969581] systemd[1]: Set hostname to <j7-evm>.
    [ 7.156643] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock ��→ /run/docker.sock; please update the unit.
    [ 7.223563] random: systemd: uninitialized urandom read (16 bytes read)
    [ 7.230292] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [ 7.242617] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [ 7.252510] systemd[1]: Created slice system-getty.slice.
    [ OK ] Created slice system-getty.slice.
    [ 7.273133] random: systemd: uninitialized urandom read (16 bytes read)
    [ 7.280344] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ OK ] Created slice system-serial\x2dgetty.slice.
    [ 7.297074] random: systemd: uninitialized urandom read (16 bytes read)
    [ 7.304181] systemd[1]: Created slice User and Session Slice.
    [ OK ] Created slice User and Session Slice.
    [ 7.321179] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [ OK ] Started Dispatch Password ��…ts to Console Directory Watch.
    [ 7.345121] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ OK ] Started Forward Password R��…uests to Wall Directory Watch.
    [ 7.369119] systemd[1]: Reached target Paths.
    [ OK ] Reached target Paths.
    [ 7.385072] systemd[1]: Reached target Remote File Systems.
    [ OK ] Reached target Remote File Systems.
    [ 7.401067] systemd[1]: Reached target Slices.
    [ OK ] Reached target Slices.
    [ 7.417070] systemd[1]: Reached target Swap.
    [ OK ] Reached target Swap.
    [ 7.434484] systemd[1]: Listening on RPCbind Server Activation Socket.
    [ OK ] Listening on RPCbind Server Activation Socket.
    [ 7.453097] systemd[1]: Reached target RPC Port Mapper.
    [ OK ] Reached target RPC Port Mapper.
    [ 7.471246] systemd[1]: Listening on Process Core Dump Socket.
    [ OK ] Listening on Process Core Dump Socket.
    [ 7.489198] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [ OK ] Listening on initctl Compatibility Named Pipe.
    [ 7.524505] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [ 7.532806] systemd[1]: Listening on Journal Socket (/dev/log).
    [ OK ] Listening on Journal Socket (/dev/log).
    [ 7.549265] systemd[1]: Listening on Journal Socket.
    [ OK ] Listening on Journal Socket.
    [ 7.565322] systemd[1]: Listening on Network Service Netlink Socket.
    [ OK ] Listening on Network Service Netlink Socket.
    [ 7.585237] systemd[1]: Listening on udev Control Socket.
    [ OK ] Listening on udev Control Socket.
    [ 7.601183] systemd[1]: Listening on udev Kernel Socket.
    [ OK ] Listening on udev Kernel Socket.
    [ 7.619586] systemd[1]: Mounting Huge Pages File System...
    [ 7.643800] systemd[1]: Mounting POSIX Message Queue File System...
    [ 7.667122] systemd[1]: Mounting Kernel Debug File System...
    [ 7.695791] systemd[1]: Mounting Temporary Directory (/tmp)...
    [ 7.719393] systemd[1]: Starting Create list of static device nodes for the current kernel...
    Starting Create list of st��…odes for the current kernel...
    [ 7.747342] systemd[1]: Starting Start psplash boot splash screen...
    [ 7.773181] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    [ OK ] Started Hardware RNG Entropy Gatherer Daemon.
    [ 7.795360] systemd[1]: Starting RPC Bind...
    [ 7.813202] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [ 7.833438] systemd[1]: Starting Journal Service...
    [ 7.857563] systemd[1]: Starting Load Kernel Modules...
    [ 7.872403] cryptodev: loading out-of-tree module taints kernel.
    [ 7.884111] systemd[1]: Starting Remount Root and Kernel File Systems...
    [ 7.894460] cryptodev: driver 1.10 loaded.
    [ 7.903371] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [ 7.913075] systemd[1]: Starting udev Coldplug all Devices...
    [ 7.935472] systemd[1]: Started RPC Bind.
    [ OK ] Started RPC Bind.
    [ 7.954132] systemd[1]: Started Journal Service.
    [ OK ] Started Journal Service.
    [ OK ] Mounted Huge Pages File System.
    [ OK ] Mounted POSIX Message Queue File System.
    [ OK ] Mounted Kernel Debug File System.
    [ OK ] Mounted Temporary Directory (/tmp).
    [ OK ] Started Create list of sta��… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star��…progress communication helper.
    [ OK ] Started Load Kernel Modules.
    [ OK ] Started Remount Root and Kernel File Systems.
    Mounting Kernel Configuration File System...
    Starting Flush Journal to Persistent Storage...
    [ 8.152950] systemd-journald[172]: Received client request to flush runtime journal.
    Starting Apply Kernel Variables...
    Starting Create Static Device Nodes in /dev...
    [ OK ] Mounted Kernel Configuration File System.
    [ OK ] Started Flush Journal to Persistent Storage.
    [ OK ] Started Apply Kernel Variables.
    [ OK ] Started Create Static Device Nodes in /dev.
    [ OK ] Reached target Local File Systems (Pre).
    Mounting /media/ram...
    Mounting /var/volatile...
    Starting udev Kernel Device Manager...
    [ OK ] Mounted /media/ram.
    [ OK ] Mounted /var/volatile.
    Starting Load/Save Random Seed...
    [ OK ] Reached target Local File Systems.
    Starting Create Volatile Files and Directories...
    [ OK ] Started udev Coldplug all Devices.
    [ OK ] Started Create Volatile Files and Directories.
    Starting Network Time Synchronization...
    Starting Update UTMP about System Boot/Shutdown...
    [ OK ] Started udev Kernel Device Manager.
    [ OK ] Started Update UTMP about System Boot/Shutdown.
    [ OK ] Started Network Time Synchronization.
    [ OK ] Reached target System Initialization.
    [ OK ] Started Daily Cleanup of Temporary Directories.
    [ OK ] Reached target System Time Set.
    [ OK ] Reached target System Time Synchronized.
    [ OK ] Started Daily rotation of log files.
    [ OK ] Reached target Timers.
    [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [ OK ] Listening on D-Bus System Message Bus Socket.
    Starting Docker Socket for the API.
    [ OK ] Listening on dropbear.socket.
    Starting Reboot and dump vmcore via kexec...
    [ OK ] Listening on Docker Socket for the API.
    [ OK ] Reached target Sockets.
    [ OK ] Reached target Basic System.
    [ 8.756216] rti-wdt 2200000.watchdog: heartbeat 60 sec
    [ OK ] Started Job spooling tools.
    [ 8.806849] rti-wdt 2210000.watchdog: heartbeat 60 sec
    [ OK ] Started Periodic Command Scheduler.
    [ OK ] Started D-Bus System Message Bus.
    Starting Print notice about GPLv3 packages...
    Starting IPv6 Packet Filtering Framework...
    Starting IPv4 Packet Filtering Framework...
    [ OK ] Started irqbalance daemon.
    Starting rc.pvr.service...
    Starting Login Service...
    [ OK ] Started Reboot and dump vmcore via kexec.
    [ OK ] Started IPv6 Packet Filtering Framework.
    [ OK ] Started IPv4 Packet Filtering Framework.
    [ OK ] Reached target Network (Pre).
    Starting Network Service...
    [ 9.043968] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 9.075835] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 9.085815] PVR_K: 259: Read BVNC 22.104.208.318 from HW device registers
    [ 9.093630] PVR_K: 259: RGX Device registered with BVNC 22.104.208.318
    [ 9.104329] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
    [ OK ] Started Login Service.
    [ OK ] Started Network Service.
    Starting Wait for Network to be Configured...
    Starting Network Name Resolution...
    [ OK ] Started Network Name Resolution.
    [ OK ] Reached target Network.
    [ OK ] Reached target Host and Network Name Lookups.
    Starting Avahi mDNS/DNS-SD Stack...
    Starting Enable and configure wl18xx bluetooth stack...
    [ OK ] Started NFS status monitor for NFSv2/3 locking..
    Starting Simple Network Ma��…ent Protocol (SNMP) Daemon....
    Starting Permit User Sessions...
    [ OK ] Started Permit User Sessions.
    [ OK ] Started Getty on tty1.
    [ OK ] Started Serial Getty on ttyS2.
    [ OK ] Started Serial Getty on ttyS3.
    [ OK ] Reached target Login Prompts.
    Starting Synchronize System and HW clocks[ 9.366532] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [ OK ] Started Avahi mDNS/DNS-SD Stack.
    [ OK ] Started Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [ 9.427491] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 9.488756] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 9.502838] ov5640 9-003c: 9-003c supply DOVDD not found, using dummy regulator
    [ 9.548935] ov5640 9-003c: 9-003c supply AVDD not found, using dummy regulator
    [ 9.559883] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [ 9.583076] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 9.602758] ov5640 9-003c: 9-003c supply DVDD not found, using dummy regulator
    [ 9.663602] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 9.718262] img_enc 4200000.video-encoder: vxe_enc_probe: adding heap of type 1
    [ 9.749150] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 9.749516] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [ 9.785197] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [ 9.815123] ov5640 9-003c: ov5640_read_reg: error: reg=300a
    [ 9.833993] ov5640 9-003c: ov5640_check_chip_id: failed to read chip identifier
    [ 9.861370] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 9.887077] ov5640: probe of 9-003c failed with error -121
    [ 9.912794] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [ 9.937057] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [ 9.947388] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    [ 9.975287] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 10.009318] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    [ 10.023404] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 10.053220] remoteproc remoteproc0: 4d80800000.dsp is available
    [ 10.067161] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 10.089256] remoteproc remoteproc0: Direct firmware load for j7-c66_0-fw failed with error -2
    [ 10.101048] remoteproc remoteproc0: powering up 4d80800000.dsp
    [ 10.107440] remoteproc remoteproc0: Direct firmware load for j7-c66_0-fw failed with error -2
    [ 10.116416] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [ 10.125047] remoteproc remoteproc0: request_firmware failed: -2
    [ 10.148284] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 10.165400] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    [ 10.195324] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [ 10.229406] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    [ 10.233046] random: crng init done
    [ 10.239929] random: 7 urandom warning(s) missed due to ratelimiting
    [ 10.246970] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [ OK ] Started Load/Save Random Seed.
    [ 10.280659] remoteproc remoteproc1: 4d81800000.dsp is available
    [ 10.293127] remoteproc remoteproc1: Direct firmware load for j7-c66_1-fw failed with error -2
    [ 10.304219] remoteproc remoteproc1: powering up 4d81800000.dsp
    [ 10.313050] remoteproc remoteproc1: Direct firmware load for j7-c66_1-fw failed with error -2
    [ 10.321678] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [ 10.330219] remoteproc remoteproc1: request_firmware failed: -2
    [ 10.433163] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [ 10.461121] remoteproc remoteproc2: 64800000.dsp is available
    [ 10.494216] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [ OK ] Started Simple Network Man��…ement Protocol (SNMP) Daemon..
    [ 10.586434] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [ 10.600474] [drm] No driver support for vblank timestamp query.
    [ 10.609490] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    [ 10.645068] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    [ 10.714015] CAN device driver interface
    [ 10.729494] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    [ 10.731796] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
    [ 10.801140] remoteproc remoteproc2: Direct firmware load for j7-c71_0-fw failed with error -2
    [ 10.801147] remoteproc remoteproc2: powering up 64800000.dsp
    [ 10.801157] remoteproc remoteproc2: Direct firmware load for j7-c71_0-fw failed with error -2
    [ 10.801160] remoteproc remoteproc2: request_firmware failed: -2
    [ 10.803561] platform 41000000.r5f: configured R5F for IPC-only mode
    [ 10.803621] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [ 10.803775] remoteproc remoteproc3: 41000000.r5f is available
    [ 10.810167] remoteproc remoteproc3: powering up 41000000.r5f
    [ 10.810177] remoteproc remoteproc3: Booting fw image j7-mcu-r5f0_0-fw, size 196136
    [ 10.810312] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [ 10.810319] remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [ 10.810829] virtio_rpmsg_bus virtio0: rpmsg host is online
    [ 10.810855] remoteproc3#vdev0buffer: registered virtio0 (type 7)
    [ 10.810858] remoteproc remoteproc3: remote processor 41000000.r5f is now up
    [ 10.825890] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [ 10.826030] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [ 10.844165] Console: switching to colour frame buffer device 240x67
    [ 10.846307] platform 5c00000.r5f: configured R5F for remoteproc mode
    [ 10.867248] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [ 10.867369] remoteproc remoteproc4: 5c00000.r5f is available
    [ 10.889338] remoteproc remoteproc4: powering up 5c00000.r5f
    [ 10.889347] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 682936
    [ 10.890981] platform 5d00000.r5f: configured R5F for remoteproc mode
    [ 10.901337] platform 5c00000.r5f: booting R5F core using boot addr = 0x0
    [ 10.901400] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [ 10.901498] remoteproc remoteproc5: 5d00000.r5f is available
    [ 10.901528] remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
    [ 10.901975] virtio_rpmsg_bus virtio1: rpmsg host is online
    [ 10.901997] remoteproc4#vdev0buffer: registered virtio1 (type 7)
    [ 10.902001] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [ 10.916374] remoteproc remoteproc5: powering up 5d00000.r5f
    [ 10.916385] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 98484
    [ 10.917490] platform 5d00000.r5f: booting R5F core using boot addr = 0x0
    [ 10.922600] tidss 4a00000.dss: fb0: tidssdrmfb frame buffer device
    [ 11.140406] platform 5e00000.r5f: configured R5F for remoteproc mode
    [ 11.190599] remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [ 11.201374] virtio_rpmsg_bus virtio2: rpmsg host is online
    [ 11.209084] remoteproc5#vdev0buffer: registered virtio2 (type 7)
    [ 11.216344] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [ 11.227107] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [ 11.235910] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [ 11.252276] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [ 11.365196] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.notifyservice addr 0x1e
    [ 11.451701] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a
    [ 11.460929] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: Device info: permissions: 07FFFFFF uart_id: 2
    [ 11.477060] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: FW ver 0.1 (rev 1) 4/Apr/2021 SHA:bdb1c075
    [ 11.571369] remoteproc remoteproc6: 5e00000.r5f is available
    [ 11.678978] remoteproc remoteproc6: powering up 5e00000.r5f
    [ 11.684667] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 98484
    [ 11.706947] platform 5f00000.r5f: configured R5F for remoteproc mode
    [ 11.714290] platform 5e00000.r5f: booting R5F core using boot addr = 0x0
    [ 11.723768] remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
    [ 11.737596] virtio_rpmsg_bus virtio3: rpmsg host is online
    [ 11.746114] remoteproc6#vdev0buffer: registered virtio3 (type 7)
    [ 11.748257] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [ 11.755329] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [ 11.765149] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [ 11.814502] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [ 11.902486] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [ 11.930688] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    NOTICE: This file system contains the following GPLv3 packages:
    autoconf
    bash-dev
    bash
    bc
    binutils
    cifs-utils
    coreutils-stdbuf
    coreutils
    cpio
    cpp-symlinks
    cpp
    dosfstools
    elfutils
    g++-symlinks
    g++
    gawk
    gcc-symlinks
    gcc
    gdb
    gdbserver
    gettext
    glmark2
    gstreamer1.0-libav
    gzip
    less
    libasm1
    libbfd
    libdw1
    libelf1
    libgdbm-compat4
    libgdbm-dev
    libgdbm6
    libgettextlib
    libgettextsrc
    libgmp10
    libidn2-0
    libmpc3
    libmpfr6
    libreadline-dev
    librea[ 11.983304] remoteproc remoteproc7: 5f00000.r5f is available
    dline8
    libunistring2
    m4-dev
    m4
    make
    nettle
    parted
    tar
    which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution. This can be done using
    the opkg remove command. i.e.:
    opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
    will be notified of the dependent packages. You should
    use the --force-removal-of-dependent-packages option to
    also remove the dependent packages as well
    [ OK ] Started Print notice about GPLv3 packages.
    [ 12.153999] remoteproc remoteproc7: powering up 5f00000.r5f
    [ 12.159662] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 98612
    [ 12.173763] platform 5f00000.r5f: booting R5F core using boot addr = 0x0
    [ 12.185342] remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
    [ 12.195624] virtio_rpmsg_bus virtio4: rpmsg host is online
    [ 12.205167] remoteproc7#vdev0buffer: registered virtio4 (type 7)
    [ 12.210332] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd
    [ 12.213045] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [ 12.221006] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [ 12.855920] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [ 12.873788] j721e-audio sound@0: pcm3168a-dac <-> 2ba0000.mcasp mapping ok
    [ 12.910851] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:00000003 rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00
    [ 12.977275] j721e-audio sound@0: pcm3168a-adc <-> 2ba0000.mcasp mapping ok
    [ 13.006952] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [ OK ] Created slice system-weston.slice.
    [ OK ] Started Weston Wayland Compositor.
    [ 13.883295] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
    [ OK ] Created slice User Slice of UID 0 13.913156] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    0m.
    Starting User Runtime Directory /run/user/0...
    [ OK ] Started User Runtime Directory /run/user/0.
    [ 13.975992] remoteproc remoteproc8: b034000.pru is available
    Starting User Manager for UID 0...
    [ 14.035514] pru-rproc b034000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@34000 probed successfully
    [ OK ] Created slice system-systemd\x2dfsck.slice.
    [ OK ] Started User Manager for UID 0.
    [ OK ] Started Session c1 of user root.
    [ 14.323047] remoteproc remoteproc9: b004000.rtu is available
    [ 14.340473] pru-rproc b004000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@4000 probed successfully
    [ 14.340743] pru-rproc b00a000.txpru: IRQ vring not found
    [ 14.340747] pru-rproc b00a000.txpru: IRQ kick not found
    [ 14.340789] remoteproc remoteproc10: b00a000.txpru is available
    [ 14.340821] pru-rproc b00a000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@a000 probed successfully
    [ 14.340988] remoteproc remoteproc11: b038000.pru is available
    [ 14.348033] pru-rproc b038000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@38000 probed successfully
    [ 14.348278] remoteproc remoteproc12: b006000.rtu is available
    [ 14.348305] pru-rproc b006000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@6000 probed successfully
    [ 14.348365] pru-rproc b00c000.txpru: IRQ vring not found
    [ 14.348367] pru-rproc b00c000.txpru: IRQ kick not found
    [ 14.348392] remoteproc remoteproc13: b00c000.txpru is available
    [ 14.348417] pru-rproc b00c000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@c000 probed successfully
    [ 14.348567] remoteproc remoteproc14: b134000.pru is available
    [ 14.348590] pru-rproc b134000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@34000 probed successfully
    [ 14.348699] remoteproc remoteproc15: b104000.rtu is available
    [ 14.348722] pru-rproc b104000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@4000 probed successfully
    [ 14.348778] pru-rproc b10a000.txpru: IRQ vring not found
    [ 14.348780] pru-rproc b10a000.txpru: IRQ kick not found
    [ 14.348802] remoteproc remoteproc16: b10a000.txpru is available
    [ 14.348822] pru-rproc b10a000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@a000 probed successfully
    [ 14.352897] remoteproc remoteproc17: b138000.pru is available
    [ 14.618208] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    [ 14.636154] pru-rproc b138000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@38000 probed successfully
    [ 14.707591] remoteproc remoteproc18: b106000.rtu is available
    [ 14.728742] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    [ 14.775879] PVR_K: 984: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
    [ 14.799405] pru-rproc b106000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@6000 probed successfully
    [ 14.866048] pru-rproc b10c000.txpru: IRQ vring not found
    [ 14.909152] pru-rproc b10c000.txpru: IRQ kick not found
    [ 14.966929] remoteproc remoteproc19: b10c000.txpru is available
    [ 15.026558] pru-rproc b10c000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@c000 probed successfully
    _____ _____ _ _
    | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    | | _| .'| . | . | | __| _| . | | | -_| _| _|
    |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    |___| |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2020.09 j7-evm ttyS2
    j7-evm login: [ 15.803414] usbcore: registered new interface driver usbfs
    [ 15.865877] usbcore: registered new interface driver hub
    [ 15.904971] usbcore: registered new device driver usb
    [ 15.931195] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [ 15.943532] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [ 15.957183] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
    [ 15.973324] xhci-hcd xhci-hcd.2.auto: irq 610, io mem 0x06410000
    [ 15.985041] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [ 16.004651] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 16.013876] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [ 16.017024] usb usb1: Product: xHCI Host Controller
    [ 16.029060] usb usb1: Manufacturer: Linux 5.4.106-g023faefa70 xhci-hcd
    [ 16.037032] usb usb1: SerialNumber: xhci-hcd.2.auto
    [ 16.037654] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    [ 16.049677] hub 1-0:1.0: USB hub found
    [ 16.053811] hub 1-0:1.0: 1 port detected
    [ 16.057789] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [ 16.068398] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [ 16.077036] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [ 16.086250] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [ 16.100703] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 16.111621] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    [ 16.121050] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 16.131554] usb usb2: Product: xHCI Host Controller
    [ 16.136497] usb usb2: Manufacturer: Linux 5.4.106-g023faefa70 xhci-hcd
    [ 16.149031] usb usb2: SerialNumber: xhci-hcd.2.auto
    [ 16.157290] hub 2-0:1.0: USB hub found
    [ 16.161506] hub 2-0:1.0: 1 port detected
    [ 16.405087] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [ 16.569310] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [ 16.578668] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [ 16.593028] usb 1-1: SerialNumber: 10000859DE36
    [ 16.598059] hub 1-1:1.0: USB hub found
    [ 16.604974] hub 1-1:1.0: 4 ports detected
    [ 16.901025] usb 1-1.2: new full-speed USB device number 3 using xhci-hcd
    [ 17.016759] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
    [ 17.029019] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 17.036317] usb 1-1.2: Product: iClebo Kobuki
    [ 17.045019] usb 1-1.2: Manufacturer: Yujin Robot
    [ 17.049630] usb 1-1.2: SerialNumber: kobuki_AB0JKJ7Y
    [ 17.126390] usbcore: registered new interface driver ftdi_sio
    [ 17.132169] usbserial: USB Serial support registered for FTDI USB Serial Device
    [ 17.145086] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
    [ 17.151969] usb 1-1.2: Detected FT232RL
    [ 17.165423] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
    [ 29.916237] Initializing XFRM netlink socket
    [ 32.446525] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [ 32.462087] Bridge firewalling registered
    j7-evm login: root
    Last login: Fri Oct 1 08:08:54 UTC 2021
    root@j7-evm:~# ifconfig
    docker0 Link encap:Ethernet HWaddr 02:42:0D:11:89:EA
    inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
    UP BROADCAST MULTICAST MTU:1500 Metric:1
    RX packets:0 errors:0 dropped:0 overruns:0 frame:0
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:0
    RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
    eth0 Link encap:Ethernet HWaddr 50:51:A9:FC:1D:69
    inet addr:10.201.4.248 Bcast:10.201.4.255 Mask:255.255.255.0
    inet6 addr: fe80::5251:a9ff:fefc:1d69/64 Scope:Link
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:95 errors:0 dropped:0 overruns:0 frame:0
    TX packets:49 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:16934 (16.5 KiB) TX bytes:6238 (6.0 KiB)
    eth1 Link encap:Ethernet HWaddr 70:FF:76:1D:92:C1
    inet6 addr: fe80::72ff:76ff:fe1d:92c1/64 Scope:Link
    TX packets:33 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:0 (0.0 B) TX bytes:5990 (5.8 KiB)
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    inet6 addr: ::1/128 Scope:Host
    UP LOOPBACK RUNNING MTU:65536 Metric:1
    RX packets:82 errors:0 dropped:0 overruns:0 frame:0
    TX packets:82 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:6220 (6.0 KiB) TX bytes:6220 (6.0 KiB)
    root@j7-evm:~# reboot
    Stopping Ses[ OK ] Stopped target RPC Port Mapper.
    [ OK ] Stopped target Sound Card.
    [ OK ] Stopped target Timers.
    [ OK ] Stopped Daily rotation of log files.
    [ OK ] Stopped Daily Cleanup of Temporary Directories.
    Stopping Save/Restore Sound Card State...
    Stopping Job spooling tools...
    Stopping Avahi mDNS/DNS-SD Stack...
    Stopping Periodic Command Scheduler...
    [ OK ] Stopped DEMO.
    Stopping Docker Application Container Engine...
    Stopping SSH Per-Connectio��…Server (10.201.4.126:45046)...
    Stopping Getty on tty1...
    Stopping irqbalance daemon...
    Stopping Reboot and dump vmcore via kexec...
    Stopping NFS status monitor for NFSv2/3 locking....
    Stopping Serial Getty on ttyS2...
    Stopping Serial Getty on ttyS3...
    Stopping Simple Network Ma��…ent Protocol (SNMP) Daemon....
    Stopping strongSwan IPsec ��…Ev2 daemon using ipsec.conf...
    Stopping Load/Save Random Seed...
    Stopping thermal-zone-init.service...
    Stopping Weston Wayland Compositor...
    [ OK ] Stopped Job spooling tools.
    [ OK ] Stopped Periodic Command Scheduler.
    [ OK ] Stopped irqbalance daemon.
    [ OK ] Stopped Avahi mDNS/DNS-SD Stack.
    [ OK ] Stopped NFS status monitor for NFSv2/3 locking..
    [ OK ] Stopped Simple Network Man��…ement Protocol (SNMP) Daemon..
    [ OK ] Stopped Getty on tty1.
    [ OK ] Stopped Serial Getty on ttyS2.
    [ OK ] Stopped Serial Getty on ttyS3.
    [ OK ] Stopped Weston Wayland Compositor.
    [ OK ] Stopped strongSwan IPsec I��…IKEv2 daemon using ipsec.conf.
    [ OK ] Stopped SSH Per-Connection Server (10.201.4.126:45046).
    [ OK ] Stopped Save/Restore Sound Card State.
    [ OK ] Stopped Reboot and dump vmcore via kexec.
    [ OK ] Stopped Load/Save Random Seed.
    [ OK ] Stopped thermal-zone-init.service.
    [ OK ] Stopped Session c1 of user root.
    [ OK ] Stopped Session c2 of user root.
    [ OK ] Removed slice system-dropbear.slice.
    [ OK ] Removed slice system-getty.slice.
    [ OK ] Removed slice system-serial\x2dgetty.slice.
    [ OK ] Removed slice system-weston.slice.
    Stopping LSB: start and stop docker...
    Stopping LSB: network benchmark...
    Stopping Login Service...
    Stopping User Manager for UID 0...
    [ OK ] Stopped User Manager for UID 0.
    [ OK ] Stopped LSB: start and stop docker.
    [ OK ] Stopped LSB: network benchmark.
    [ OK ] Stopped target Host and Network Name Lookups.
    [ OK ] Stopped target System Time Synchronized.
    [ OK ] Stopped target System Time Set.
    Stopping telnetd.service...
    Stopping User Runtime Directory /run/user/0...
    [ OK ] Unmounted /run/user/0.
    [ OK ] Stopped telnetd.service.
    [ OK ] Stopped User Runtime Directory /run/user/0.
    [ OK ] Removed slice User Slice of UID 0.
    Stopping D-Bus System Message Bus...
    Stopping Permit User Sessions...
    Stopping weston.service...
    [ OK ] Stopped D-Bus System Message Bus.
    [ OK ] Stopped Login Service.
    [ OK ] Stopped Permit User Sessions.
    [ OK ] Stopped weston.service.
    [ OK ] Stopped target Remote File Systems.
    Stopping rc.pvr.service...
    [ OK ] Stopped rc.pvr.service.
    [ OK ] Stopped Docker Application Container Engine.
    [ OK ] Stopped target Network is Online.
    [ OK ] Stopped target Network.
    [ OK ] Stopped Wait for Network to be Configured.
    Stopping Network Name Resolution...
    [ OK ] Stopped Network Name Resolution.
    Stopping Network Service...
    [ OK ] Stopped Network Service.
    [ OK ] Stopped target Network (Pre).
    [ OK ] Stopped IPv6 Packet Filtering Framework.
    [ OK ] Stopped IPv4 Packet Filtering Framework.
    [ OK ] Stopped target Basic System.
    [ OK ] Stopped target Paths.
    [ OK ] Stopped Dispatch Password ��…ts to Console Directory Watch.
    [ OK ] Stopped Forward Password R��…uests to Wall Directory Watch.
    [ OK ] Stopped target Slices.
    [ OK ] Removed slice User and Session Slice.
    [ OK ] Stopped target Sockets.
    [ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [ OK ] Closed D-Bus System Message Bus Socket.
    [ OK ] Closed Docker Socket for the API.
    [ OK ] Closed dropbear.socket.
    [ OK ] Stopped target System Initialization.
    Stopping Hardware RNG Entropy Gatherer Daemon...
    [ OK ] Stopped Apply Kernel Variables.
    [ OK ] Stopped Load Kernel Modules.
    Stopping Network Time Synchronization...
    Stopping Update UTMP about System Boot/Shutdown...
    [ OK ] Stopped Hardware RNG Entropy Gatherer Daemon.
    [ OK ] Stopped Network Time Synchronization.
    [ OK ] Stopped Update UTMP about System Boot/Shutdown.
    [ OK ] Stopped Create Volatile Files and Directories.
    [ OK ] Stopped target Local File Systems.
    Unmounting /media/ram...
    Unmounting /run/media/mmcblk1p1...
    Unmounting Temporary Directory (/tmp)...
    Unmounting /var/volatile...
    [ OK ] Unmounted /media/ram.
    [ OK ] Unmounted /run/media/mmcblk1p1.
    [ OK ] Unmounted Temporary Directory (/tmp).
    [ OK ] Unmounted /var/volatile.
    [ OK ] Stopped target Swap.
    [ OK ] Reached target Unmount All Filesystems.
    [ OK ] Stopped File System Check on /dev/mmcblk1p1.
    [ OK ] Removed slice system-systemd\x2dfsck.slice.
    [ OK ] Stopped target Local File Systems (Pre).
    [ OK ] Stopped Remount Root and Kernel File Systems.
    [ OK ] Stopped Create Static Device Nodes in /dev.
    [ OK ] Reached target Shutdown.
    [ OK ] Reached target Final Step.
    [ OK ] Started Reboot.
    [ OK ] Reached target Reboot.
    [ 387.319527] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [ 387.326523] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [ 387.333402] watchdog: watchdog0: watchdog did not stop!
    [ 387.349686] systemd-shutdown[1]: Syncing filesystems and block devices.
    [ 387.400638] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [ 387.413462] systemd-journald[172]: Received SIGTERM from PID 1 (systemd-shutdow).
    [ 387.432768] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [ 387.442471] systemd-shutdown[1]: Hardware watchdog 'K3 RTI Watchdog', version 0
    [ 387.450779] systemd-shutdown[1]: Unmounting file systems.
    [ 387.457449] [1450]: Remounting '/' read-only in with options '(null)'.
    [ 387.476246] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [ 387.483518] systemd-shutdown[1]: All filesystems unmounted.
    [ 387.489142] systemd-shutdown[1]: Deactivating swaps.
    [ 387.494273] systemd-shutdown[1]: All swaps deactivated.
    [ 387.499493] systemd-shutdown[1]: Detaching loop devices.
    [ 387.506407] systemd-shutdown[1]: All loop devices detached.
    [ 387.511977] systemd-shutdown[1]: Detaching DM devices.
    [ 387.517209] systemd-shutdown[1]: All DM devices detached.
    [ 387.522607] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
    [ 387.537726] systemd-shutdown[1]: Syncing filesystems and block devices.
    [ 387.544437] systemd-shutdown[1]: Rebooting.
    [ 387.584060] pci_generic_config_write32: 80 callbacks suppressed
    [ 387.584066] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0xdc may corrupt adjacent RW1C bits
    [ 387.599740] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0xc8 may corrupt adjacent RW1C bits
    [ 387.609542] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [ 387.619259] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x9c may corrupt adjacent RW1C bits
    [ 387.629012] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [ 387.638732] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [ 387.648409] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [ 387.658065] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0xdc may corrupt adjacent RW1C bits
    [ 387.667807] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0xc8 may corrupt adjacent RW1C bits
    [ 387.677575] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [ 387.687796] reboot: Restarting system
    U-Boot SPL 2020.01-g2781231a33 (Apr 10 2021 - 01:08:23 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
    Trying to boot from MMC2
    Loading Environment from MMC... *** Warning - No MMC card found, using default environment
    Starting ATF on ARM64 core...
    NOTICE: BL31: v2.4(release):07.03.00.005-dirty
    NOTICE: BL31: Built : 00:15:40, Apr 10 2021
    U-Boot SPL 2020.01-g2781231a33 (Apr 10 2021 - 00:17:14 +0000)
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-VSC8514-ETH rev E2
    mmc_init: -110, time 238
    spl: mmc init failed with error: -110
    SPL: failed to boot from all boot devices
    ### ERROR ### Please RESET the board ###
    U-Boot 2020.01-g2781231a33 (Apr 10 2021 - 00:17:14 +0000)
    SoC: J721E SR1.0
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E7
    DRAM: 4 GiB
    not found for dev hbmc-mux
    Flash: 0 Bytes
    MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from MMC... OK
    In: serial@2800000
    Out: serial@2800000
    Err: serial@2800000
    Net: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Warning: ethernet@46000000 using MAC address from ROM
    eth0: ethernet@46000000
    Hit any key to stop autoboot: 0
    unable to read ssr
    switch to partitions #0, OK
    mmc1 is current device
    mmc_init: -110, time 223
    ** No partition table - mmc 1 **
    libfdt fdt_check_header(): FDT_ERR_BADMAGIC
    No FDT memory address configured. Please configure
    the FDT address via "fdt addr <address>" command.
    Aborting!
    Bad Linux ARM64 Image magic!
    I am not able to reproduce this issue. 7.3 should work fine. Could you migrate to 8.0 Linux SDK & check if you face the issue
    there as well.
    Also from the details give by you it is a standard TI Evaluation TDA4 EVM right? Just so as to rule out custom board issue.
    Also try to create a fresh different SD card & try.
    Keerthy
  • Hi Keerthy,
    Yes, the log is from TI Evaluation TDA4 EVM.
    It is resolved after reinstalling everything onto a new SD card.
    Thank you.
