Hi Guys,
I red many times this forum and i always found a good solutions for my problems, but this time I've to ask.
There's a matter that is driving me mad: I developed an application with EvmDM642 based on an example driver given with board software. To configure dsp/bios (v 5.31) I used .tcf and .cdb given with example and traslated by CCS 3.3 itself. With such dsp/bios configuration everything works perfectly.
BUT.... when I try to add a mine dsp/bios configuration, that is supposedly identical to the given with example but with new names for objects, nothing works.
I've tried to write a dsp/bios for other applications (led blinking, audio and others) and I've always get what I want, this time I can't manage and It's very difficult to undertand the error because there's no message by CCS, program runs but no results!
Execution graph says that my program runs always "Other threads", seems that program is blocked on that, no task or knl_swi are executed, is there a scheduling error?
Following .tcf files, the first (black) works (given by driver example), the second (red) not working (mine)
Could anyone understand which is the error in .tcf?
Any suggest will be appreciate!
THANK YOU!
environment["ti.bios.oldMemoryNames"] = true;
/* loading the generic platform */
var params = {};
params.clockRate = 720.000000;
params.deviceName = "DM642";
params.catalogName = "ti.catalog.c6000";
params.regs = {};
params.regs.l2Mode = "4-way cache (0k)";
utils.loadPlatform("ti.platforms.generic", params);
/* enabling DSP/BIOS components */
bios.GBL.ENABLEINST = true;
bios.MEM.NOMEMORYHEAPS = false;
bios.RTDX.ENABLERTDX = true;
bios.HST.HOSTLINKTYPE = "RTDX";
bios.TSK.ENABLETSK = true;
bios.GBL.ENABLEALLTRC = true;
bios.GBL.ENDIANMODE = "little";
bios.GBL.C641XCONFIGUREL2 = true;
bios.ISRAM.createHeap = true;
bios.ISRAM.heapSize = 0x8000;
bios.MEM.BIOSOBJSEG = prog.get("ISRAM");
bios.MEM.MALLOCSEG = prog.get("ISRAM");
bios.TSK.STACKSEG = prog.get("ISRAM");
/* applying user changes */
bios.SDRAM = bios.MEM.create("SDRAM");
bios.SDRAM.comment = "This object defines space for the DSP's off-chip memory";
bios.SDRAM.base = 0x80000000;
bios.SDRAM.len = 0x2000000;
bios.SDRAM.heapSize = 0x1000000;
bios.SDRAM.enableHeapLabel = 1;
bios.SDRAM.heapLabel = prog.extern("EXTERNALHEAP");
bios.SDRAM.space = "code/data";
bios.tskLoopback = bios.TSK.create("tskLoopback");
bios.trace = bios.LOG.create("trace");
bios.VP0CAPTURE = bios.UDEV.create("VP0CAPTURE");
bios.VP1CAPTURE = bios.UDEV.create("VP1CAPTURE");
bios.VP2DISPLAY = bios.UDEV.create("VP2DISPLAY");
bios.RTA_fromHost.bufSeg = prog.get("SDRAM");
bios.RTA_toHost.bufSeg = prog.get("SDRAM");
bios.TSK_idle.stackMemSeg = prog.get("SDRAM");
bios.LOG_system.bufSeg = prog.get("SDRAM");
bios.LOG_system.bufLen = 0x400;
bios.MEM.ARGSSEG = prog.get("SDRAM");
bios.MEM.BIOSSEG = prog.get("SDRAM");
bios.MEM.STACKSIZE = 0x1000;
bios.MEM.STACKSEG = prog.get("SDRAM");
bios.MEM.SYSINITSEG = prog.get("SDRAM");
bios.MEM.GBLINITSEG = prog.get("SDRAM");
bios.MEM.TRCDATASEG = prog.get("SDRAM");
bios.MEM.SYSDATASEG = prog.get("SDRAM");
bios.MEM.OBJSEG = prog.get("SDRAM");
bios.MEM.BIOSOBJSEG = prog.get("SDRAM");
bios.MEM.MALLOCSEG = prog.get("SDRAM");
bios.MEM.TEXTSEG = prog.get("SDRAM");
bios.MEM.SWITCHSEG = prog.get("SDRAM");
bios.MEM.BSSSEG = prog.get("SDRAM");
bios.MEM.FARSEG = prog.get("SDRAM");
bios.MEM.CINITSEG = prog.get("SDRAM");
bios.MEM.PINITSEG = prog.get("SDRAM");
bios.MEM.CONSTSEG = prog.get("SDRAM");
bios.MEM.DATASEG = prog.get("SDRAM");
bios.MEM.CIOSEG = prog.get("SDRAM");
bios.MEM.SYSMEMSEG = prog.get("SDRAM");
bios.MEM.HWISEG = prog.get("SDRAM");
bios.MEM.HWIVECSEG = prog.get("SDRAM");
bios.MEM.RTDXTEXTSEG = prog.get("SDRAM");
bios.GBL.CALLUSERINITFXN = 1;
bios.BUF.OBJMEMSEG = prog.get("SDRAM");
bios.PRD.OBJMEMSEG = prog.get("SDRAM");
bios.HST.OBJMEMSEG = prog.get("SDRAM");
bios.TSK.OBJMEMSEG = prog.get("SDRAM");
bios.TSK.STACKSEG = prog.get("SDRAM");
bios.tskLoopback.comment = "Loopback Task";
bios.tskLoopback.fxn = prog.extern("tskVideoLoopback");
bios.tskLoopback.stackMemSeg = prog.get("SDRAM");
bios.IDL.OBJMEMSEG = prog.get("SDRAM");
bios.LOG.OBJMEMSEG = prog.get("SDRAM");
bios.trace.bufSeg = prog.get("SDRAM");
bios.trace.bufLen = 0x400;
bios.PIP.OBJMEMSEG = prog.get("SDRAM");
bios.SEM.OBJMEMSEG = prog.get("SDRAM");
bios.MBX.OBJMEMSEG = prog.get("SDRAM");
bios.QUE.OBJMEMSEG = prog.get("SDRAM");
bios.LCK.OBJMEMSEG = prog.get("SDRAM");
bios.SIO.OBJMEMSEG = prog.get("SDRAM");
bios.STS.OBJMEMSEG = prog.get("SDRAM");
bios.SYS.TRACESEG = prog.get("SDRAM");
bios.GIO.ENABLEGIO = 1;
bios.VP0CAPTURE.fxnTable = prog.extern("VPORTCAP_Fxns");
bios.VP0CAPTURE.fxnTableType = "IOM_Fxns";
bios.VP0CAPTURE.params = prog.extern("EVMDM642_vCapParamsPort");
bios.VP1CAPTURE.fxnTable = prog.extern("VPORTCAP_Fxns");
bios.VP1CAPTURE.fxnTableType = "IOM_Fxns";
bios.VP1CAPTURE.deviceId = 1;
bios.VP1CAPTURE.params = prog.extern("EVMDM642_vCapParamsPort");
bios.VP2DISPLAY.fxnTable = prog.extern("VPORTDIS_Fxns");
bios.VP2DISPLAY.fxnTableType = "IOM_Fxns";
bios.VP2DISPLAY.deviceId = 0x2;
bios.VP2DISPLAY.params = prog.extern("EVMDM642_vDisParamsPort");
bios.DHL.OBJMEMSEG = prog.get("SDRAM");
bios.DIO.OBJMEMSEG = prog.get("SDRAM");
bios.GBL.USERINITFXN = prog.extern("EVMDM642_init");
bios.CLK.OBJMEMSEG = prog.get("SDRAM");
bios.RTDX.RTDXDATASEG = prog.get("SDRAM");
bios.SWI.OBJMEMSEG = prog.get("SDRAM");
bios.ISRAM.len = 0x20000;
bios.ISRAM.createHeap = 0;
// !GRAPHICAL_CONFIG_TOOL_SCRIPT_INSERT_POINT!
if (config.hasReportedError == false) {
prog.gen();
utils.loadPlatform("ti.platforms.evmDM642");
/* The following DSP/BIOS Features are enabled. */
bios.enableMemoryHeaps(prog);
bios.enableRealTimeAnalysis(prog);
bios.enableRtdx(prog);
bios.enableTskManager(prog);
bios.GBL.CLKOUT = 720.0000;
bios.MEM.instance("SDRAM").createHeap = 1;
bios.MEM.instance("SDRAM").heapSize = 0x01000000;
bios.MEM.instance("SDRAM").enableHeapLabel = 1;
bios.MEM.instance("SDRAM").heapLabel = prog.extern("EXTERNALHEAP");
bios.LOG.instance("trace").bufLen = 128;
bios.TSK.create("TSK0");
bios.TSK.instance("TSK0").order = 1;
bios.TSK.instance("TSK0").comment = "loopback";
bios.TSK.instance("TSK0").stackMemSeg = prog.get("SDRAM");
bios.TSK.instance("TSK0").fxn = prog.extern("tskVideoLoopback");
bios.UDEV.instance("VP0CAPTURE").fxnTableType = "IOM_Fxns";
bios.UDEV.instance("VP0CAPTURE").params = prog.extern("EVMDM642_vCapParamsPort");
bios.UDEV.instance("VP1CAPTURE").fxnTableType = "IOM_Fxns";
bios.UDEV.instance("VP1CAPTURE").deviceId = 1;
bios.UDEV.instance("VP1CAPTURE").params = prog.extern("EVMDM642_vCapParamsPort");
bios.UDEV.instance("VP1CAPTURE").fxnTable = prog.extern("VPORTCAP_Fxns");
bios.UDEV.instance("VP0CAPTURE").fxnTable = prog.extern("VPORTCAP_Fxns");
bios.UDEV.instance("VP2DISPLAY").fxnTable = prog.extern("VPORTDIS_Fxns");
bios.UDEV.instance("VP2DISPLAY").fxnTableType = "IOM_Fxns";
bios.UDEV.instance("VP2DISPLAY").params = prog.extern("EVMDM642_vDisParamsPort");
bios.MEM.instance("IRAM").len = 0x00020000;
bios.UDEV.instance("VP2DISPLAY").deviceId = 2;
bios.HST.instance("RTA_fromHost").bufSeg = prog.get("SDRAM");
bios.HST.instance("RTA_toHost").bufSeg = prog.get("SDRAM");
prog.gen();
