Part Number: TDA4VM
Other Parts Discussed in Thread: PCM3168A
HI.
SDK: ti-processor-sdk-linux-j7-evm-07_03_00_05
log:
I"ot@j7-evm:/opt/ltp# ./runltp -P j721e-idk-gw -f ddt/wdt_test -s "WDT_M_FUNC_WRI
INFO: creating /opt/ltp/results directory
INFO: Filtering testscenarios based on j721e-idk-gw capabilities
awk: cmd. line:1: warning: regexp escape sequence `\&' is not a known regexp operator
Checking for required user/group ids
'nobody' user id and group found.
'bin' user id and group found.
'daemon' user id and group found.
Users group found.
Sys group found.
Required users/groups exist.
If some fields are empty or look unusual you may have an old version.
Compare to the current minimal requirements in Documentation/Changes.
/etc/os-release
ID=arago
NAME="Arago"
VERSION="2020.09"
VERSION_ID=2020.09
PRETTY_NAME="Arago 2020.09"
uname:
Linux j7-evm 5.4.106-gc709150c2281-dirty #16 SMP PREEMPT Mon Sep 27 18:37:25 CST 2021 aarch64 aarch64 aarch64 GNU/Linux
/proc/cmdline
console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=cd57c178-02 rw rootfstype=ext4 rootwait
Gnu C gcc (GCC) 9.2.1 20191025
Clang
Gnu make 4.3
util-linux 2.35.1
mount linux 2.35.1 (libmount 2.35.1: btrfs, namespaces, assert, debug)
modutils 26
e2fsprogs 1.45.4
Linux C Library > libc.2.30
Dynamic linker (ldd) 2.30
Linux C++ Library 6..
Procps 3.3.16
iproute2 iproute2-ss200127
iputils 'V'
ethtool 5.4
Kbd 2.2.0
Sh-utils 8.31
Modules Loaded xhci_plat_hcd xhci_hcd usbcore rpmsg_char ti_am335x_adc kfifo_buf pru_rproc irq_pruss_intc icss_iep cdns3 roles udc_core usb_common crct10dif_ce snd_soc_j721e_evm ti_j721e_cpsw_virt_mac ti_k3_r5_remoteproc ti_am335x_tscadc pruss ntb_hw_epf ntb pci_endpoint_test sa2ul ti_k3_dsp_remoteproc sha512_generic authenc cdns_dphy virtio_rpmsg_bus cdns3_ti snd_soc_pcm3168a_i2c snd_soc_pcm3168a oak_pci rti_wdt sch_fq_codel rpmsg_kdrv_switch ipv6
free reports:
total used free shared buff/cache available
Mem: 1537088 200768 990336 34432 345984 1066304
Swap: 0 0 0
cpuinfo:
Architecture: aarch64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 2
On-line CPU(s) list: 0,1
Thread(s) per core: 1
Core(s) per socket: 2
Socket(s): 1
Vendor ID: ARM
Model: 0
Model name: Cortex-A72
Stepping: r1p0
BogoMIPS: 400.00
L1d cache: 64 KiB
L1i cache: 96 KiB
L2 cache: 1 MiB
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: [ 90.213006] LTP: starting WDT_M_FUNC_WRITE (source 'common.sh'; do_cmd install_modules.sh 'wdt' ; DEV_NODE=`get_devnode.sh "wdt"` || die "error getting devnode for wdt"; do_cmd wdt_tests -device $DEV_NODE -ioctl -write)
Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Spec store bypass: Vulnerable
Vulnerability Spectre v1: Mitigation; __user pointer sanitization
Vulnerability Spectre v2: Not affected
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpui
d
AppArmor disabled
SELinux mode: unknown
no big block device was specified on commandline.
Tests which require a big block device are disabled.
You can specify it with option -z
COMMAND: /opt/ltp/bin/ltp-pan -e -S -a 1051 -n 1051 -p -f /tmp/ltp-fMVd26mpLM/alltests -l /tmp/tmp.ldIEEbaepc -C /opt/ltp/output/LTP_RUN_ON-tmp.ldIEEbaepc.failed -T /opt/ltp/output/LTP_RUN_ON-tmp.ldIEEbaepc.tconf
INFO: Restricted to WDT_M_FUNC_WRI
LOG File: /tmp/tmp.ldIEEbaepc
FAILED COMMAND File: /opt/ltp/output/LTP_RUN_ON-tmp.ldIEEbaepc.failed
TCONF COMMAND File: /opt/ltp/output/LTP_RUN_ON-tmp.ldIEEbaepc.tconf
Running tests.......
<<<test_start>>>
tag=WDT_M_FUNC_WRITE stime=1629467161
cmdline="source 'common.sh'; do_cmd install_modules.sh 'wdt' ; DEV_NODE=`get_devnode.sh "wdt"` || die "error getting devnode for wdt"; do_cmd wdt_tests -device $DEV_NODE -ioctl -write"
contacts=""
analysis=exit
<<<test_output>>>
|TRACE LOG|Inside do_cmd:CMD=install_modules.sh wdt|
|TRACE LOG|Inside do_cmd:CMD=wdt_tests -device /dev/watchdog -ioctl -write|
|TEST START|wdt_tests|
|TRACE LOG|******** WDT Testcase parameters ******** |
|TRACE LOG|Device : /dev/watchdog|
|TRACE LOG|Loop Count : 1|
|TRACE LOG|I/O Operation : Write|
|TRACE LOG|Operation : Ioctl|
|TRACE LOG|Ioctl Name : WDIOC_KEEPALIVE|
|TRACE LOG|Ioctl Arg : 0 |
|TRACE LOG| ************* End of Test params ************* |
|TRACE LOG|Keeping WDT alive, sleep counter -0(sec)|
|TEST RESULT|PASS|wdt_tests|
|TEST END|wdt_tests|
|TRACE LOG|EVM will be rebooted after 60 seconds|
|TRACE LOG|59 seconds remaining before reboot|
|TRACE LOG|58 seconds remaining before reboot|
|TRACE LOG|57 seconds remaining before reboot|
|TRACE LOG|56 seconds remaining before reboot|
|TRACE LOG|55 seconds remaining before reboot|
|TRACE LOG|54 seconds remaining before reboot|
|TRACE LOG|53 seconds remaining before reboot|
|TRACE LOG|52 seconds remaining before reboot|
|TRACE LOG|51 seconds remaining before reboot|
|TRACE LOG|50 seconds remaining before reboot|
|TRACE LOG|49 seconds remaining before reboot|
|TRACE LOG|48 seconds remaining before reboot|
|TRACE LOG|47 seconds remaining before reboot|
|TRACE LOG|46 seconds remaining before reboot|
|TRACE LOG|45 seconds remaining before reboot|
|TRACE LOG|44 seconds remaining before reboot|
|TRACE LOG|43 seconds remaining before reboot|
|TRACE LOG|42 seconds remaining before reboot|
|TRACE LOG|41 seconds remaining before reboot|
|TRACE LOG|40 seconds remaining before reboot|
|TRACE LOG|39 seconds remaining before reboot|
|TRACE LOG|38 seconds remaining before reboot|
|TRACE LOG|37 seconds remaining before reboot|
|TRACE LOG|36 seconds remaining before reboot|
|TRACE LOG|35 seconds remaining before reboot|
|TRACE LOG|34 seconds remaining before reboot|
|TRACE LOG|33 seconds remaining before reboot|
|TRACE LOG|32 seconds remaining before reboot|
|TRACE LOG|31 seconds remaining before reboot|
|TRACE LOG|30 seconds remaining before reboot|
|TRACE LOG|29 seconds remaining before reboot|
|TRACE LOG|28 seconds remaining before reboot|
|TRACE LOG|27 seconds remaining before reboot|
|TRACE LOG|26 seconds remaining before reboot|
|TRACE LOG|25 seconds remaining before reboot|
[ 129.166032] Initializing XFRM netlink socket
|TRACE LOG|24 seconds remaining before reboot|
|TRACE LOG|23 seconds remaining before reboot|
|TRACE LOG|22 seconds remaining before reboot|
|TRACE LOG|21 seconds remaining before reboot|
[ 132.792012] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 132.806006] Bridge firewalling registered
|TRACE LOG|20 seconds remaining before reboot|
|TRACE LOG|19 seconds remaining before reboot|
|TRACE LOG|18 seconds remaining before reboot|
|TRACE LOG|17 seconds remaining before reboot|
|TRACE LOG|16 seconds remaining before reboot|
|TRACE LOG|15 seconds remaining before reboot|
|TRACE LOG|14 seconds remaining before reboot|
|TRACE LOG|13 seconds remaining before reboot|
|TRACE LOG|12 seconds remaining before reboot|
|TRACE LOG|11 seconds remaining before reboot|
|TRACE LOG|10 seconds remaining before reboot|
|TRACE LOG|9 seconds remaining before reboot|
|TRACE LOG|8 seconds remaining before reboot|
|TRACE LOG|7 seconds remaining before reboot|
|TRACE LOG|6 seconds remaining before reboot|
|TRACE LOG|5 seconds remaining before reboot|
|TRACE LOG|4 seconds remaining before reboot|
|TRACE LOG|3 seconds remaining before reboot|
|TRACE LOG|2 seconds remaining before reboot|
|TRACE LOG|1 seconds remaining before reboot|
|TRACE LOG|0 seconds remaining before reboot|
|TRACE LOG|-1 seconds remaining before reboot|
|TRACE LOG|-2 seconds remaining before reboot|
|TRACE LOG|-3 seconds remaining before reboot|
|TRACE LOG|-4 seconds remaining before reboot|
|TRACE LOG|-5 seconds remaining before reboot|
|TRACE LOG|-6 seconds remaining before reboot|
|TRACE LOG|-7 seconds remaining before reboot|
|TRACE LOG|-8 seconds remaining before reboot|
|TRACE LOG|-9 seconds remaining before reboot|
|TRACE LOG|-10 seconds remaining before reboot|
|TRACE LOG|-11 seconds remaining before reboot|
|TRACE LOG|-12 seconds remaining before reboot|
|TRACE LOG|-13 seconds remaining before reboot|
|TRACE LOG|-14 seconds remaining before reboot|
