I'm attempting to use CCS5.02 to develop DSP code on the c6a816x EVM. From where may I find a starter .tcf file for this board? I need to define the memory segments.
Lee Holeva
Lee Holeva
Lee Holeva said:I'm attempting to use CCS5.02 to develop DSP code on the c6a816x EVM. From where may I find a starter .tcf file for this board? I need to define the memory segments.
By .tcf file, I presume you are familiar with DSP/BIOS 5.x. DSP/BIOS 5.x has been replaced by Sys/Bios 6.x which no longer uses tconf files but RTSC configuration scripts. Please have a look at BIOS_Legacy_App_note.pdf in $EZSDK/sysbios_6_31_00_06_eng directory for migratory information. You should also find examples for Sys/Bios in the same directory.
--Sid
I've used BIOS 5 with .tcf files and assumed that BIOS 6 used the same.
Lee Holeva
