Other Parts Discussed in Thread: TMS320C5505
hai i am using tms320c5505 ezdsp and i was unable to work with interrupt and while adding vector.asm i has some 84 errors help me in sort out the problem
hai i am using the adc program
when i compile the error message is [E9999]
* Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005, 2008
* Use of this software is controlled by the terms and conditions found in the
* license agreement under which this software has been supplied.
/** @file csl_sar_IntcExample.c
* @brief SAR functional layer sample source file
* Path: \(CSLPATH)\examples\sar\example3
* Revision History
* 20-Sept-2008 Created
/** @section Overview
This example file is created to test SAR working in Interrupt mode --
It registers ISR for SAR. It test the keypad voltage measurement
/* Inclusion of header files */
#include "csl_sar.h"
#include "csl_intc.h"
#include "stdio.h"
/* CSL example test failed */
#define CSL_TEST_FAILED (1)
/* CSL example test passed */
#define CSL_TEST_PASSED (0)
/* Global Structure Declaration*/
CSL_SarHandleObj SarObj; /* SAR object structure */
CSL_SarHandleObj *SarHandle; /* SAR handle */
Uint16 readBuffer; /* SAR Read Buffer */
int i = 0;
//---------Function prototypes---------//
/** Interrupt Service Routine */
interrupt void sarISR(void);
/* Reference the start of the interrupt vector table */
/* This symbol is defined in file vectors.asm */
extern void VECSTART(void);
/* To test sar in Interrupt mode */
int sar_test_Int_keypad_voltage();
int main()
int status;
status = sar_test_Int_keypad_voltage();
if(CSL_TEST_PASSED == status)
printf("sar_test_Int_keypad_voltage is passed\n");
else
printf("sar_test_Int_keypad_voltage is failed\n");
return 0;
int sar_test_Int_keypad_voltage(void)
Bool flag = 1;
int result;
/* Testing of SAR A/D Keypad Voltage Measurement */
CSL_Status status;
CSL_SarChSetup param;
int chanNo;
result = CSL_TEST_FAILED ;
printf("Testing SAR in Interrupt mode\n");
//Disable interrupt
IRQ_globalDisable();
/* Initialize Interrupt Vector table */
IRQ_setVecs((Uint32)(&VECSTART));
/* Initialize the SAR module */
status = SAR_init();
if(status != CSL_SOK)
printf("SAR Init Failed!!\n");
return (result) ;
/* Open SAR channel */
status = SAR_chanOpen(&SarObj,CSL_SAR_CHAN_3);
SarHandle = &SarObj;
printf("SAR_chanOpen Failed!!\n");
return result;
/* Initialize channel */
status = SAR_chanInit(SarHandle);
printf("SAR_chanInit Failed!!\n");
return(result);
/* Clear any pending Interrupt */
IRQ_clear(SAR_EVENT);
IRQ_test(SAR_EVENT,&flag);
/* Register the ISR */
IRQ_plug(SAR_EVENT,&sarISR);
param.OpMode = CSL_SAR_INTERRUPT;
param.MultiCh = CSL_SAR_NO_DISCHARGE;
param.RefVoltage = CSL_SAR_REF_VIN;
param.SysClkDiv = 11 ;
/* Configuration for SAR module */
status = SAR_chanSetup(SarHandle,¶m);
printf("SAR_chanConfig Failed!!\n");
return(result);
/* Set channel cycle set */
status = SAR_chanCycSet(SarHandle,CSL_SAR_CONTINUOUS_CONVERSION);
printf("SAR_chanCycSet Failed!!\n");
return(result);
/* set ADC Measurement parameters */
status = SAR_A2DMeasParamSet(SarHandle,CSL_KEYPAD_MEAS,&chanNo);
printf("SAR_A2DMeasParamSet Failed!!\n");
return(result);
printf("Channel Number selected %d\n",chanNo);
/* Enabling Interrupt */
IRQ_enable(SAR_EVENT);
IRQ_globalEnable();
/* start the conversion */
status = SAR_startConversion(SarHandle);
printf("SAR_startConversion Failed!!\n");
return(result);
/* ISR runs for 40 times */
while(TRUE)
if(i == 40)
break;
/* Stop the conversion */
status = SAR_stopConversion(SarHandle);
printf("SAR_stopConversion Failed!!\n");
return(result);
/* Close the channel */
status = SAR_chanClose(SarHandle);
printf("SAR_chanClose Failed!!\n");
return(result);
/* Deinit */
status = SAR_deInit();
printf("SAR_deInit Failed!!\n");
return(result);
result = CSL_TEST_PASSED;
return(result);
// ISR to read ADC data
SAR_readData(SarHandle, &readBuffer);
printf("SAR ADC read data %x\n",readBuffer);
i++;
/* For 40 times */
if(i == 40)
IRQ_disable(SAR_EVENT);
