Part Number: AM3352
In the parent thread, I'm waiting for the latest "am335x-evm-linux-sdk-arago-src-07.03.00.005.tar.xz" .
I tried to build SDK on the normal way because it seems to take long time to get the latest "am335x-evm-linux-sdk-arago-src-07.03.00.005.tar.xz" .
But I got the build error as shown in the attached log file.
It shows that "tensorflow-lite" compilation was failed.
Could you teach me how to fix this problem ?
By the way, I don't need "tensorflow-lite".
Can I select not to build "tensorflow-lite" ?
uegaki@hqr3113:~/ex1/rmu/tisdk/build$ MACHINE=am335x-evm bitbake tisdk-base-image
WARNING: Layer meta-psdkla should set LAYERSERIES_COMPAT_meta-psdkla in its conf/layer.conf file to list the core layer names it is compatible with.
NOTE: Started PRServer with DBfile: /home/uegaki/ex1/rmu/tisdk/build/cache/prserv.sqlite3, IP: 127.0.0.1, PORT: 41895, PID: 19993
Loading cache: 100% |####################################################################################################################################################| Time: 0:00:01
Loaded 4208 entries from dependency cache.
Parsing recipes: 100% |##################################################################################################################################################| Time: 0:00:01
Parsing of 2945 .bb files complete (2944 cached, 1 parsed). 4208 targets, 595 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
/home/uegaki/ex1/rmu/tisdk/sources/meta-arago/meta-arago-distro/recipes-browser/chromium/chromium-ozone-wayland_%.bbappend
/home/uegaki/ex1/rmu/tisdk/sources/meta-psdkla/recipes-core/packagegroups/neo-ai-dlr.bbappend
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "arm-linux-gnueabi"
MACHINE = "am335x-evm"
DISTRO = "arago"
DISTRO_VERSION = "2020.09"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-arago-distro
meta-arago-extras = "HEAD:ee6ff44d90945429051c8d9573c8b60705104149"
meta-qt5 = "HEAD:b4d24d70aca75791902df5cd59a4f4a54aa4a125"
meta-virtualization = "HEAD:89abc62b47f6f20db9d00a8ec9b2c1b6b60ac3f9"
meta-networking
meta-python
meta-oe
meta-gnome
meta-filesystems = "HEAD:389757a7494221fea1d8437e9a01c6e4fb4700af"
meta-ti = "HEAD:02a53f48b9bdb242185204610610f2209bc92ca6"
meta-arm
meta-arm-toolchain = "HEAD:c4f04f3fb66f8f4365b08b553af8206372e90a63"
meta = "HEAD:707036d4ec12ef1a260adcef78627b26e32e6540"
meta-psdkla = "HEAD:41ac7fa732f1f030577885a0d06ab2976014d750"
meta-aws = "HEAD:80f6984673aca586e83a8f913ddf7ebc89f3586a"
Initialising tasks: 100% |###############################################################################################################################################| Time: 0:00:05
Sstate summary: Wanted 1164 Found 0 Missed 1164 Current 345 (0% match, 22% complete)
NOTE: Executing Tasks
WARNING: libloki-0.1.7-r0 do_fetch: Failed to fetch URL http://libloki.sourcearchive.com/downloads/0.1.7-3/libloki_0.1.7.orig.tar.gz, attempting MIRRORS if available
WARNING: opencv-4.1.0-r0 do_patch: Fuzz detected:
Applying patch CVE-2019-14491.patch
patching file modules/objdetect/src/cascadedetect.cpp
Hunk #1 succeeded at 46 with fuzz 1 (offset -1 lines).
Hunk #2 succeeded at 540 (offset -1 lines).
Hunk #3 succeeded at 552 (offset -1 lines).
Hunk #4 succeeded at 613 (offset -1 lines).
Hunk #5 succeeded at 774 (offset -1 lines).
Hunk #6 succeeded at 825 (offset -1 lines).
Hunk #7 succeeded at 1470 (offset -36 lines).
patching file modules/objdetect/src/cascadedetect.hpp
The context lines in the patches can be updated with devtool:
devtool modify opencv
devtool finish --force-patch-refresh opencv <layer_path>
Don't forget to review changes done by devtool!
WARNING: opencv-4.1.0-r0 do_patch: QA Issue: Patch log indicates that patches do not apply cleanly. [patch-fuzz]
WARNING: neo-ai-dlr-1.8.0-r0_psdkla do_patch: Fuzz detected:
Applying patch 0001-maybe-upstream-add-condition-for-googletest-build.patch
patching file CMakeLists.txt
Hunk #1 succeeded at 6 (offset 1 line).
Hunk #2 succeeded at 297 with fuzz 2 (offset -38 lines).
Applying patch 0001-upstream-add-condition-for-TIDL.patch
Hunk #1 succeeded at 122 with fuzz 2 (offset 10 lines).
Applying patch 0001-not-upstream-yocto-run-without-REST.patch
patching file python/dlr/api.py
Hunk #1 succeeded at 5 with fuzz 2 (offset -1 lines).
Hunk #2 succeeded at 53 (offset -5 lines).
devtool modify neo-ai-dlr
devtool finish --force-patch-refresh neo-ai-dlr <layer_path>
WARNING: neo-ai-dlr-1.8.0-r0_psdkla do_patch: QA Issue: Patch log indicates that patches do not apply cleanly. [patch-fuzz]
Currently 3 running tasks (1984 of 4498) 44% |########################################################### WARNING: gnutls-3.6.14-r0.arago0 do_package: QA Issue: Excluding gnutls-src from packaging as it has incompatible license(s): GPL-3.0+ [incompatible-license]
WARNING: gnutls-3.6.14-r0.arago0 do_package: QA Issue: Excluding gnutls-dbg from packaging as it has incompatible license(s): GPL-3.0+ [incompatible-license]
WARNING: gnutls-3.6.14-r0.arago0 do_package: QA Issue: Excluding gnutls-openssl from packaging as it has incompatible license(s): GPL-3.0+ [incompatible-license]
WARNING: gnutls-3.6.14-r0.arago0 do_package: QA Issue: Excluding gnutls-staticdev from packaging as it has incompatible license(s): GPL-3.0+ [incompatible-license]
WARNING: gnutls-3.6.14-r0.arago0 do_package: QA Issue: Excluding gnutls-dev from packaging as it has incompatible license(s): GPL-3.0+ [incompatible-license]
WARNING: gnutls-3.6.14-r0.arago0 do_package: QA Issue: Excluding gnutls-doc from packaging as it has incompatible license(s): GPL-3.0+ [incompatible-license]
WARNING: gnutls-3.6.14-r0.arago0 do_package: QA Issue: Excluding gnutls-bin from packaging as it has incompatible license(s): GPL-3.0+ [incompatible-license]
WARNING: psplash-0.1+gitAUTOINC+0a902f7cd8-r15.arago4 do_patch: Fuzz detected:
Applying patch psplash-18bpp.patch
patching file psplash-fb.c
Hunk #1 succeeded at 221 (offset 61 lines).
Hunk #2 succeeded at 398 with fuzz 1 (offset 89 lines).
Hunk #3 succeeded at 415 with fuzz 2 (offset 98 lines).
patching file psplash-fb.h
Hunk #1 succeeded at 27 (offset -7 lines).
devtool modify psplash
devtool finish --force-patch-refresh psplash <layer_path>
Currently 3 running tasks (2845 of 4498) 63% |##################################################################################### |
0: gdb-9.1-r0 do_compile - 31m43s (pid 18075)
ERROR: tensorflow-lite-2.4.0-psdkla do_install: 'python3 setup.py install --root=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/image --prefix=/usr --install-lib=/usr/lib/python3.8/site-packages --install-data=/usr/share' execution failed.
ERROR: tensorflow-lite-2.4.0-psdkla do_install: Execution of '/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/temp/run.do_install.24308' failed with exit code 1:
running build
running build_py
running build_ext
building 'tflite_runtime._pywrap_tensorflow_interpreter_wrapper' extension
creating /home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/git/temp.linux-x86_64-3.8
creating /home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/git/temp.linux-x86_64-3.8/interpreter_wrapper
arm-none-linux-gnueabihf-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot -Wno-unused-result -Wsign-compare -DNDEBUG -g -O3 -Wall -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/python3/3.8.2-r0=/usr/src/debug/python3/3.8.2-r0 -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/python3/3.8.2-r0=/usr/src/debug/python3/3.8.2-r0 -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot= -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot-native= -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/python3/3.8.2-r0=/usr/src/debug/python3/3.8.2-r0 -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/python3/3.8.2-r0=/usr/src/debug/python3/3.8.2-r0 -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot= -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot-native= -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla=/usr/src/debug/tensorflow-lite/2.4.0-psdkla -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla=/usr/src/debug/tensorflow-lite/2.4.0-psdkla -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot= -fdebug-prefix-map=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot-native= -fPIC -I../../../../.. -I../../../../../tensorflow/lite/tools/pip_package -I/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot-native/usr/lib/python3.8/site-packages/numpy/core/include -I../../../../../tensorflow/lite/tools/make/downloads/flatbuffers/include -I../../../../../tensorflow/lite/tools/make/downloads/absl -I/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot-native/usr/include/python3.8 -I/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot/usr/include/python3.8 -c interpreter_wrapper/interpreter_wrapper.cc -o /home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/git/temp.linux-x86_64-3.8/interpreter_wrapper/interpreter_wrapper.o --std=c++11
In file included from /home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot-native/usr/include/python3.8/Python.h:63,
from ../../../../../tensorflow/lite/python/interpreter_wrapper/interpreter_wrapper.h:28,
from interpreter_wrapper/interpreter_wrapper.cc:15:
/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/recipe-sysroot-native/usr/include/python3.8/pyport.h:726:2: error: #error "LONG_BIT definition appears wrong for platform (bad gcc/glibc config?)."
726 | #error "LONG_BIT definition appears wrong for platform (bad gcc/glibc config?)."
interpreter_wrapper/interpreter_wrapper.cc: In member function ��std::string tflite::interpreter_wrapper::InterpreterWrapper::TensorName(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:305:26: warning: comparison of integer expressions of different signedness: ��int�� and ��size_t�� {aka ��unsigned int��} [-Wsign-compare]
305 | if (!interpreter_ || i >= interpreter_->tensors_size() || i < 0) {
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::TensorType(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:43:9: warning: comparison of integer expressions of different signedness: ��int�� and ��size_t�� {aka ��unsigned int��} [-Wsign-compare]
43 | if (i >= interpreter_->tensors_size() || i < 0) { \
interpreter_wrapper/interpreter_wrapper.cc:315:3: note: in expansion of macro ��TFLITE_PY_TENSOR_BOUNDS_CHECK��
315 | TFLITE_PY_TENSOR_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::TensorSize(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:333:3: note: in expansion of macro ��TFLITE_PY_TENSOR_BOUNDS_CHECK��
333 | TFLITE_PY_TENSOR_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::TensorSizeSignature(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:348:3: note: in expansion of macro ��TFLITE_PY_TENSOR_BOUNDS_CHECK��
348 | TFLITE_PY_TENSOR_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::TensorSparsityParameters(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:368:3: note: in expansion of macro ��TFLITE_PY_TENSOR_BOUNDS_CHECK��
368 | TFLITE_PY_TENSOR_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::TensorQuantization(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:379:3: note: in expansion of macro ��TFLITE_PY_TENSOR_BOUNDS_CHECK��
379 | TFLITE_PY_TENSOR_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::TensorQuantizationParameters(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:386:3: note: in expansion of macro ��TFLITE_PY_TENSOR_BOUNDS_CHECK��
386 | TFLITE_PY_TENSOR_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::SetTensor(int, PyObject*)��:
interpreter_wrapper/interpreter_wrapper.cc:420:3: note: in expansion of macro ��TFLITE_PY_TENSOR_BOUNDS_CHECK��
420 | TFLITE_PY_TENSOR_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::NodeInputs(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:51:9: warning: comparison of integer expressions of different signedness: ��int�� and ��size_t�� {aka ��unsigned int��} [-Wsign-compare]
51 | if (i >= interpreter_->nodes_size() || i < 0) { \
interpreter_wrapper/interpreter_wrapper.cc:499:3: note: in expansion of macro ��TFLITE_PY_NODES_BOUNDS_CHECK��
499 | TFLITE_PY_NODES_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��PyObject* tflite::interpreter_wrapper::InterpreterWrapper::NodeOutputs(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:509:3: note: in expansion of macro ��TFLITE_PY_NODES_BOUNDS_CHECK��
509 | TFLITE_PY_NODES_BOUNDS_CHECK(i);
interpreter_wrapper/interpreter_wrapper.cc: In member function ��std::string tflite::interpreter_wrapper::InterpreterWrapper::NodeName(int) const��:
interpreter_wrapper/interpreter_wrapper.cc:518:26: warning: comparison of integer expressions of different signedness: ��int�� and ��size_t�� {aka ��unsigned int��} [-Wsign-compare]
518 | if (!interpreter_ || i >= interpreter_->nodes_size() || i < 0) {
interpreter_wrapper/interpreter_wrapper.cc: In function ��PyObject* tflite::interpreter_wrapper::{anonymous}::CheckGetTensorArgs(tflite::Interpreter*, int, TfLiteTensor**, int*)��:
interpreter_wrapper/interpreter_wrapper.cc:544:3: note: in expansion of macro ��TFLITE_PY_TENSOR_BOUNDS_CHECK��
544 | TFLITE_PY_TENSOR_BOUNDS_CHECK(tensor_index);
error: command 'arm-none-linux-gnueabihf-gcc' failed with exit status 1
WARNING: /home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/temp/run.do_install.24308:1 exit 1 from 'exit 1'
ERROR: Logfile of failure stored in: /home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/temp/log.do_install.24308
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['virtual:native:/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-devtools/python-numpy/python3-numpy_1.17.4.bb:do_populate_sysroot', 'virtual:native:/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot', '/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_sysroot', 'virtual:native:/home/uegaki/ex1/rmu/tisdk/sources/meta-openembedded/meta-python/recipes-devtools/python/python3-pybind11_2.4.3.bb:do_populate_sysroot', '/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-devtools/python/python3_3.8.2.bb:do_populate_sysroot', 'virtual:native:/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-extended/unzip/unzip_6.0.bb:do_populate_sysroot', '/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-core/zlib/zlib_1.2.11.bb:do_populate_sysroot', 'virtual:native:/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-devtools/python/python3_3.8.2.bb:do_populate_sysroot', '/home/uegaki/ex1/rmu/tisdk/sources/meta-arm/meta-arm-toolchain/recipes-devtools/external-arm-toolchain/external-arm-toolchain.bb:do_populate_sysroot', 'virtual:native:/home/uegaki/ex1/rmu/tisdk/sources/oe-core/meta/recipes-extended/xz/xz_5.2.4.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['python3-numpy-native', 'patch-native', 'quilt-native', 'python3-pybind11-native', 'python3', 'unzip-native', 'zlib', 'pseudo-native', 'python3-native', 'external-arm-toolchain', 'xz-native', 'python3-setuptools-native', 'autoconf-native', 'automake-native', 'attr-native', 'gnu-config-native', 'libtool-native', 'gettext-minimal-native', 'readline', 'openssl', 'bzip2', 'util-linux', 'sqlite3', 'libtirpc', 'libnsl2', 'opkg-utils', 'libffi', 'xz', 'gdbm', 'sqlite3-native', 'gdbm-native', 'openssl-native', 'util-linux-native', 'libffi-native', 'pkgconfig-native', 'bzip2-native', 'libnsl2-native', 'readline-native', 'libtirpc-native', 'zlib-native', 'texinfo-dummy-native', 'm4-native', 'ncurses', 'cryptodev-linux', 'bash-completion', 'libcap-ng', 'libpam', 'libcap-ng-native', 'ncurses-native', 'libpcre2-native', 'cracklib', 'flex']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_install
| running build
| running build_py
| running build_ext
| ERROR: 'python3 setup.py install --root=/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/image --prefix=/usr --install-lib=/usr/lib/python3.8/site-packages --install-data=/usr/share' execution failed.
| ERROR: Execution of '/home/uegaki/ex1/rmu/tisdk/build/arago-tmp-external-arm-glibc/work/armv7at2hf-neon-linux-gnueabi/tensorflow-lite/2.4.0-psdkla/temp/run.do_install.24308' failed with exit code 1:
| running build
| running build_py
| running build_ext
ERROR: Task (/home/uegaki/ex1/rmu/tisdk/sources/meta-psdkla/recipes-core/packagegroups/tensorflow-lite_2.4.0.bb:do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2890 tasks of which 2035 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 6 seconds
Summary: 1 task failed:
Summary: There were 17 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
