Part Number: TDA4VM
Hi expert,
I'm using psdk 8.00. In my customer board, the i2c6 (sensor i2c) connect to the deserializer. Sometimes deserializer will not release the i2c bus because hardware problem, like the cameras are removed. Then the i2c bus cannot recover. It will keep timeout. Although the hardware problem is resolve.
If you want to reproduce this problem, You can simply short the SCL or SDA to ground. It's same with deserializer.
Regards.
