Part Number: PROCESSOR-SDK-J721E
while building the j7-evm SDK got the error.
TOOLCHAIN_BASE=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/linux-devkit/sysroots/x86_64-arago-linux/usr/ MACHINE=j7-evm bitbake -k tisdk-default-image
Followed the link:
1.2. Building the SDK with Yocto — Processor SDK Linux for J721e Documentation
Able to download and clone the git://git.ti.com/wilink8-wlan/wl18xx_fw.git and ftp.gnome.org/.../atk-2.34.1.tar.xz
uic68347@igv6350u:~/Viswa$ wget -t 2 -T 30 --passive-ftp --no-check-certificate -P /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/downloads 'ftp.gnome.org/.../atk-2.34.1.tar.xz'
--2021-10-23 12:20:30-- ftp.gnome.org/.../atk-2.34.1.tar.xz
Resolving ftp.gnome.org (ftp.gnome.org)... 8.43.85.29, 8.43.85.13, 8.43.85.14, ...
Connecting to ftp.gnome.org (ftp.gnome.org)|8.43.85.29|:443... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: download.gnome.org/.../atk-2.34.1.tar.xz [following]
--2021-10-23 12:20:31-- download.gnome.org/.../atk-2.34.1.tar.xz
Resolving download.gnome.org (download.gnome.org)... 8.43.85.14, 8.43.85.13, 8.43.85.29, ...
Connecting to download.gnome.org (download.gnome.org)|8.43.85.14|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: mirror.ossplanet.net/.../atk-2.34.1.tar.xz [following]
--2021-10-23 12:20:32-- mirror.ossplanet.net/.../atk-2.34.1.tar.xz
Resolving mirror.ossplanet.net (mirror.ossplanet.net)... 163.22.17.70, 2001:e10:6840:17::70
Connecting to mirror.ossplanet.net (mirror.ossplanet.net)|163.22.17.70|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 293140 (286K) [application/x-xz]
Saving to: ‘/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/downloads/atk-2.34.1.tar.xz.3’
atk-2.34.1.tar.xz.3 100%[================================================================================================================>] 286.27K 684KB/s in 0.4s
2021-10-23 12:20:33 (684 KB/s) - ‘/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/downloads/atk-2.34.1.tar.xz.3’ saved [293140/293140]
uic68347@igv6350u:~/Viswa$ git clone git://git.ti.com/wilink8-wlan/wl18xx_fw.git
Cloning into 'wl18xx_fw'...
remote: Counting objects: 550, done.
remote: Compressing objects: 100% (244/244), done.
remote: Total 550 (delta 319), reused 523 (delta 303)
Receiving objects: 100% (550/550), 12.13 MiB | 2.24 MiB/s, done.
Resolving deltas: 100% (319/319), done.
Log error:
e/JavaScriptCore/runtime/JSCInlines.h:40,
| from /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/qtwebkit/5.14.2+gitAUTOINC+ab1bd15209-r0.arago9/git/Source/WebCore/bridge/jsc/BridgeJSC.h:31,
| from /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/qtwebkit/5.14.2+gitAUTOINC+ab1bd15209-r0.arago9/git/Source/WebCore/html/HTMLPlugInElement.cpp:26,
| from /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/qtwebkit/5.14.2+gitAUTOINC+ab1bd15209-r0.arago9/git/Source/WebCore/html/HTMLElementsAllInOne.cpp:35:
| /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/qtwebkit/5.14.2+gitAUTOINC+ab1bd15209-r0.arago9/git/Source/JavaScriptCore/assembler/ARM64Assembler.h:402:14: note: because ‘JSC::ARM64Assembler::LinkRecord’ has user-provided ‘void JSC::ARM64Assembler::LinkRecord::operator=(const JSC::ARM64Assembler::LinkRecord&)’
| 402 | void operator=(const LinkRecord& other)
| {standard input}: Assembler messages:
| {standard input}:943762: Warning: end of file not at end of a line; newline inserted
| {standard input}:943860: Error: unknown mnemonic `_zzn7webcore15htmlbodyelemen...' -- `_zzn7webcore15htmlbodyelement31createwindoweventhandle'
| aarch64-none-linux-gnu-g++: fatal error: Killed signal terminated program cc1plus
| compilation terminated.
| ninja: build stopped: subcommand failed.
| WARNING: /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/qtwebkit/5.14.2+gitAUTOINC+ab1bd15209-r0.arago9/temp/run.do_compile.47369:1 exit 1 from 'eval ${DESTDIR:+DESTDIR=${DESTDIR} }VERBOSE=1 cmake --build '/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/qtwebkit/5.14.2+gitAUTOINC+ab1bd15209-r0.arago9/build' "$@" -- ${EXTRA_OECMAKE_BUILD}'
ERROR: Task (/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtwebkit_git.bb:do_compile) failed with exit code '1'
ERROR: nodejs-12.21.0-r0 do_compile: oe_runmake failed
ERROR: nodejs-12.21.0-r0 do_compile: Execution of '/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/temp/run.do_compile.47491' failed with exit code 1:
make -C out BUILDTYPE=Release V=0
touch 0d202111f023bc9ddfce108c7d9f167791fe9865.intermediate
touch 2ee4810bcb7cd5a83de9bfe03eeaea0c6f1ad65f.intermediate
LD_LIBRARY_PATH=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/lib.host:/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/lib.target:$LD_LIBRARY_PATH; export LD_LIBRARY_PATH; cd ../tools/v8_gypfiles; mkdir -p /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/torque-output-root/torque-generated/../../deps/v8/src/objects /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/torque-output-root/torque-generated/../../deps/v8/test/torque /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/torque-output-root/torque-generated/../../deps/v8/src/builtins /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/torque-output-root/torque-generated /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/torque-output-root/torque-generated/../../deps/v8/third_party/v8/builtins; torque ../../deps/v8/src/builtins/arguments.tq ../../deps/v8/src/builtins/array-copywithin.tq ../../deps/v8/src/builtins/array-every.tq ../../deps/v8/src/builtins/array-filter.tq ../../deps/v8/src/builtins/array-find.tq ../../deps/v8/src/builtins/array-findindex.tq ../../deps/v8/src/builtins/array-foreach.tq ../../deps/v8/src/builtins/array-join.tq ../../deps/v8/src/builtins/array-lastindexof.tq ../../deps/v8/src/builtins/array-map.tq ../../deps/v8/src/builtins/array-of.tq ../../deps/v8/src/builtins/array-reduce-right.tq ../../deps/v8/src/builtins/array-reduce.tq ../../deps/v8/src/builtins/array-reverse.tq ../../deps/v8/src/builtins/array-shift.tq ../../deps/v8/src/builtins/array-slice.tq ../../deps/v8/src/builtins/array-some.tq ../../deps/v8/src/builtins/array-splice.tq ../../deps/v8/src/builtins/array-unshift.tq ../../deps/v8/src/builtins/array.tq ../../deps/v8/src/builtins/base.tq ../../deps/v8/src/builtins/bigint.tq ../../deps/v8/src/builtins/boolean.tq ../../deps/v8/src/builtins/collections.tq ../../deps/v8/src/builtins/data-view.tq ../../deps/v8/src/builtins/extras-utils.tq ../../deps/v8/src/builtins/frames.tq ../../deps/v8/src/builtins/growable-fixed-array.tq ../../deps/v8/src/builtins/internal-coverage.tq ../../deps/v8/src/builtins/iterator.tq ../../deps/v8/src/builtins/math.tq ../../deps/v8/src/builtins/object-fromentries.tq ../../deps/v8/src/builtins/object.tq ../../deps/v8/src/builtins/proxy-constructor.tq ../../deps/v8/src/builtins/proxy-delete-property.tq ../../deps/v8/src/builtins/proxy-get-property.tq ../../deps/v8/src/builtins/proxy-get-prototype-of.tq ../../deps/v8/src/builtins/proxy-has-property.tq ../../deps/v8/src/builtins/proxy-is-extensible.tq ../../deps/v8/src/builtins/proxy-prevent-extensions.tq ../../deps/v8/src/builtins/proxy-revocable.tq ../../deps/v8/src/builtins/proxy-revoke.tq ../../deps/v8/src/builtins/proxy-set-property.tq ../../deps/v8/src/builtins/proxy-set-prototype-of.tq ../../deps/v8/src/builtins/proxy.tq ../../deps/v8/src/builtins/reflect.tq ../../deps/v8/src/builtins/regexp-match.tq ../../deps/v8/src/builtins/regexp-replace.tq ../../deps/v8/src/builtins/regexp-source.tq ../../deps/v8/src/builtins/regexp-test.tq ../../deps/v8/src/builtins/regexp.tq ../../deps/v8/src/builtins/string.tq ../../deps/v8/src/builtins/string-endswith.tq ../../deps/v8/src/builtins/string-html.tq ../../deps/v8/src/builtins/string-iterator.tq ../../deps/v8/src/builtins/string-pad.tq ../../deps/v8/src/builtins/string-repeat.tq ../../deps/v8/src/builtins/string-slice.tq ../../deps/v8/src/builtins/string-startswith.tq ../../deps/v8/src/builtins/string-substring.tq ../../deps/v8/src/builtins/torque-internal.tq ../../deps/v8/src/builtins/typed-array-createtypedarray.tq ../../deps/v8/src/builtins/typed-array-every.tq ../../deps/v8/src/builtins/typed-array-filter.tq ../../deps/v8/src/builtins/typed-array-find.tq ../../deps/v8/src/builtins/typed-array-findindex.tq ../../deps/v8/src/builtins/typed-array-foreach.tq ../../deps/v8/src/builtins/typed-array-reduce.tq ../../deps/v8/src/builtins/typed-array-reduceright.tq ../../deps/v8/src/builtins/typed-array-slice.tq ../../deps/v8/src/builtins/typed-array-some.tq ../../deps/v8/src/builtins/typed-array-subarray.tq ../../deps/v8/src/builtins/typed-array.tq ../../deps/v8/third_party/v8/builtins/array-sort.tq ../../deps/v8/test/torque/test-torque.tq ../../deps/v8/src/objects/intl-objects.tq -o "/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/torque-output-root/torque-generated" -v8-root ../../deps/v8
LD_LIBRARY_PATH=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/lib.host:/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/lib.target:$LD_LIBRARY_PATH; export LD_LIBRARY_PATH; cd ../tools/v8_gypfiles; mkdir -p /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/inspector-generated-output-root/src/inspector/protocol /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/inspector-generated-output-root/include/inspector; python ../../deps/v8/third_party/inspector_protocol/code_generator.py --jinja_dir ../../deps/v8/third_party --output_base "/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/inspector-generated-output-root/src/inspector" --config ../../deps/v8/src/inspector/inspector_protocol_config.json --inspector_protocol_dir ../../deps/v8/third_party/inspector_protocol
touch 329d521e8927858a553665567f9d76aa6cc15f60.intermediate
LD_LIBRARY_PATH=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/lib.host:/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/lib.target:$LD_LIBRARY_PATH; export LD_LIBRARY_PATH; cd ../.; mkdir -p /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/src/node/inspector/protocol; python tools/inspector_protocol/code_generator.py --jinja_dir tools/inspector_protocol --output_base "/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/node-v12.21.0/out/Release/obj/gen/src/" --config src/inspector/node_protocol_config.json
aarch64-none-linux-gnu-g++ --sysroot=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/recipe-sysroot -o Release/obj.target/v8_initializers/gen/torque-output-root/torque-generated/../../deps/v8/third_party/v8/builtins/array-sort-tq-csa.o Release/obj/gen/torque-output-root/torque-generated/../../deps/v8/third_party/v8/builtins/array-sort-tq-csa.cc '-DV8_GYP_BUILD' '-DV8_TYPED_ARRAY_MAX_SIZE_IN_HEAP=64' '-D__STDC_FORMAT_MACROS' '-DV8_TARGET_ARCH_ARM64' '-DV8_EMBEDDER_STRING="-node.45"' '-DENABLE_DISASSEMBLER' '-DV8_PROMISE_INTERNAL_FIELD_COUNT=1' '-DENABLE_MINOR_MC' '-DOBJECT_PRINT' '-DV8_INTL_SUPPORT' '-DV8_CONCURRENT_MARKING' '-DV8_ENABLE_LAZY_SOURCE_POSITIONS' '-DV8_EMBEDDED_BUILTINS' '-DV8_USE_SIPHASH' '-DDISABLE_UNTRUSTED_CODE_MITIGATIONS' '-DV8_WIN64_UNWINDING_INFO' '-DV8_ENABLE_REGEXP_INTERPRETER_THREADED_DISPATCH' -I../deps/v8 -I../deps/v8/include -I.//Release/obj/gen/torque-output-root -I.//Release/obj/gen/generate-bytecode-output-root -pthread -Wno-unused-parameter -Wno-return-type -fno-strict-aliasing -O3 -fno-omit-frame-pointer -fdata-sections -ffunction-sections -O3 -fno-rtti -fno-exceptions -std=gnu++1y -MMD -MF .//Release/.deps/Release/obj.target/v8_initializers/gen/torque-output-root/torque-generated/../../deps/v8/third_party/v8/builtins/array-sort-tq-csa.o.d.raw -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0=/usr/src/debug/nodejs/12.21.0-r0 -fdebug-prefix-map=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0=/usr/src/debug/nodejs/12.21.0-r0 -fdebug-prefix-map=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/recipe-sysroot= -fdebug-prefix-map=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/recipe-sysroot-native= -fvisibility-inlines-hidden -c
{standard input}:1273423: Warning: end of file not at end of a line; newline inserted
{standard input}: Error: open CFI at the end of file; missing .cfi_endproc directive
tools/v8_gypfiles/v8_initializers.target.mk:258: recipe for target 'Release/obj.target/v8_initializers/gen/torque-output-root/torque-generated/../../deps/v8/third_party/v8/builtins/array-sort-tq-csa.o' failed
make[1]: *** [Release/obj.target/v8_initializers/gen/torque-output-root/torque-generated/../../deps/v8/third_party/v8/builtins/array-sort-tq-csa.o] Error 1
rm 329d521e8927858a553665567f9d76aa6cc15f60.intermediate 0d202111f023bc9ddfce108c7d9f167791fe9865.intermediate 2ee4810bcb7cd5a83de9bfe03eeaea0c6f1ad65f.intermediate
Makefile:104: recipe for target 'node' failed
make: *** [node] Error 2
WARNING: /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/temp/run.do_compile.47491:1 exit 1 from 'exit 1'
ERROR: Logfile of failure stored in: /home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/temp/log.do_compile.47491
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 2 CC.host=aarch64-none-linux-gnu-gcc --sysroot=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0/recipe-sysroot CFLAGS.host= -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0=/usr/src/debug/nodejs/12.21.0-r0 -fdebug-prefix-map=/home/uic68347/ti-processor-sdk-linux-j7-evm-08_00_00_08/yocto-build/build/arago-tmp-external-arm-glibc/work/aarch64-linux/nodejs/12.21.0-r0=/usr/src/debug/nodejs/12.21.0-r0 -fdebug-prefix-map=/home/uic68347/ti-p
