TDA4VM: kernel hangs on sd boot
Part Number: TDA4VM
we are meetting an issue of custom board that kernel hangs on “Waiting for root device PARTUUID=0b959c33-02...”, and we have no idea what is wrong.  Besides, I think that timeout "Check if pads/pull-ups of bus are properly configured Timed out in wait_for_event: status=0000" is related to I2C, is that right? but currently we don't know how to configure it.
And the differences between custom board with EVM is below:
Custom board uses PMIC as tps65941212+tps65941111 instead of tps659413a+tps65941111
U-Boot SPL 2021.01-g53e79d0e89 (Aug 04 2021 - 23:32:00 +0000)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed 1
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
U-Boot SPL 2021.01-dirty (Oct 25 2021 - 11:36:18 +0800)
U-Boot 2021.01-dirty (Oct 25 2021 - 11:36:18 +0800)
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   Could not get PHY for ethernet@46000000: addr 0
am65_cpsw_nuss_slave ethernet@46000000: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
i2c_write: timed out writig last byte!
i2c_read (data phase): pads on bus probably not configured (status=0x10)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 1 ms (0 Bytes/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19137024 bytes read in 800 ms (22.8 MiB/s)
97586 bytes read in 13 ms (7.2 MiB/s)
   Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.41-g4c2eade9f7 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Aug 4 22:47:28 UTC 2021
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0b959c33-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3372032K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 297984K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008800b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008383] Console: colour dummy device 80x25
[    0.012944] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023615] pid_max: default: 32768 minimum: 301
[    0.028361] LSM: Security Framework initializing
[    0.033105] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040670] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049618] rcu: Hierarchical SRCU implementation.
[    0.054669] Platform MSI: msi-controller@1820000 domain created
[    0.060906] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070204] EFI services will not be available.
[    0.074951] smp: Bringing up secondary CPUs ...
[    0.080150] Detected PIPT I-cache on CPU1
[    0.080171] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.080181] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[    0.080213] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.080266] smp: Brought up 1 node, 2 CPUs
[    0.109611] SMP: Total of 2 processors activated.
[    0.114416] CPU features: detected: 32-bit EL0 Support
[    0.119670] CPU features: detected: CRC32 instructions
[    0.133316] CPU: All CPU(s) started at EL2
[    0.137510] alternatives: patching kernel code
[    0.142500] devtmpfs: initialized
[    0.150733] KASLR disabled due to lack of seed
[    0.155386] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.165348] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.173047] pinctrl core: initialized pinctrl subsystem
[    0.178621] DMI not present or invalid.
[    0.182843] NET: Registered protocol family 16
[    0.190431] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.197731] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.205735] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.214040] thermal_sys: Registered thermal governor 'step_wise'
[    0.214042] thermal_sys: Registered thermal governor 'power_allocator'
[    0.220451] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.234092] ASID allocator initialised with 65536 entries
[    0.256827] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.263685] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.270444] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.278271] cryptd: max_cpu_qlen set to 1000
[    0.284274] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.293092] vsys_3v3: supplied by evm_12v0
[    0.297399] vsys_5v0: supplied by evm_12v0
[    0.302010] iommu: Default domain type: Translated
[    0.307158] SCSI subsystem initialized
[    0.311279] mc: Linux media interface: v0.10
[    0.315693] videodev: Linux video capture interface: v2.00
[    0.321323] pps_core: LinuxPPS API ver. 1 registered
[    0.326393] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.335730] PTP clock support registered
[    0.339748] EDAC MC: Ver: 3.0.0
[    0.343491] FPGA manager framework
[    0.347001] Advanced Linux Sound Architecture Driver Initialized.
[    0.353591] clocksource: Switched to clocksource arch_sys_counter
[    0.360009] VFS: Disk quotas dquot_6.6.0
[    0.364054] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.373724] NET: Registered protocol family 2
[    0.378311] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.386916] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.395682] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.403877] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.411817] TCP: Hash tables configured (established 32768 bind 32768)
[    0.418566] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.425457] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.432855] NET: Registered protocol family 1
[    0.437542] RPC: Registered named UNIX socket transport module.
[    0.443603] RPC: Registered udp transport module.
[    0.448408] RPC: Registered tcp transport module.
[    0.453211] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.459794] PCI: CLS 0 bytes, default 64
[    0.464134] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.474394] Initialise system trusted keyrings
[    0.479002] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.487329] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.493535] NFS: Registering the id_resolver key type
[    0.498722] Key type id_resolver registered
[    0.502994] Key type id_legacy registered
[    0.507112] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.513962] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.521607] 9p: Installing v9fs 9p2000 file system support
[    0.546931] Key type asymmetric registered
[    0.551117] Asymmetric key parser 'x509' registered
[    0.556114] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.563673] io scheduler mq-deadline registered
[    0.568298] io scheduler kyber registered
[    0.573521] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.579670] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.588066] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.594338] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.602189] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.610237] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.619199] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.628022] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.635730] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.648410] brd: module loaded
[    0.654256] loop: module loaded
[    0.658082] megasas: 07.714.04.00-rc1
[    0.662996] libphy: Fixed MDIO Bus: probed
[    0.667644] tun: Universal TUN/TAP device driver, 1.6
[    0.673049] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.679456] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.685525] sky2: driver version 1.30
[    0.689795] VFIO - User Level meta-driver version: 0.3
[    0.695474] i2c /dev entries driver
[    0.699635] sdhci: Secure Digital Host Controller Interface driver
[    0.705955] sdhci: Copyright(c) Pierre Ossman
[    0.710576] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.716891] ledtrig-cpu: registered to indicate activity on CPUs
[    0.723197] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.730304] optee: probing for conduit method.
[    0.734863] optee: revision 3.12 (3d47a131)
[    0.735096] optee: initialized driver
[    0.744349] NET: Registered protocol family 17
[    0.748956] 9pnet: Installing 9P2000 support
[    0.753341] Key type dns_resolver registered
[    0.757784] Loading compiled-in X.509 certificates
[    0.766983] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.773310] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.781378] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[    0.807544] random: fast init done
[    0.833558] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.841001] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.847055] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.853081] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.859447] pca953x 3-0020: supply vcc not found, using dummy regulator
[    0.866262] pca953x 3-0020: using no AI
[    1.877593] omap_i2c 2000000.i2c: timeout waiting for bus ready
[    1.883646] pca953x 3-0020: failed writing register
[    1.888686] pca953x: probe of 3-0020 failed with error -16
[    1.894637] pca953x 3-0022: supply vcc not found, using dummy regulator
[    1.901439] pca953x 3-0022: using AI
[    2.909592] omap_i2c 2000000.i2c: timeout waiting for bus ready
[    2.915646] pca953x 3-0022: failed writing register
[    2.920666] pca953x: probe of 3-0022 failed with error -16
[    2.926313] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    2.932722] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[    2.942418] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[    2.948677] pca953x 6-0020: supply vcc not found, using dummy regulator
[    2.955486] pca953x 6-0020: using no AI
[    2.981636] pca953x 6-0020: failed writing register
[    2.986666] pca953x: probe of 6-0020 failed with error -121
[    2.992763] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[    2.998806] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    3.004753] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[    3.010986] pca953x 9-0020: supply vcc not found, using dummy regulator
[    3.017796] pca953x 9-0020: using no AI
[    4.029594] omap_i2c 2060000.i2c: timeout waiting for bus ready
[    4.035646] pca953x 9-0020: failed writing register
[    4.040674] pca953x: probe of 9-0020 failed with error -16
[    4.046606] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[    4.052990] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    4.062952] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    4.071750] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    4.081571] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    4.101144] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    4.108842] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    4.116509] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    4.124785] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    4.133060] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.141894] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    4.149562] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    4.157842] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    4.166119] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.174880] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    4.182543] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    4.190818] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    4.199094] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.208195] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    4.218075] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    4.224834] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    4.233833] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    4.243972] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    4.250731] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    4.258649] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    4.268006] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    4.276750] printk: console [ttyS2] enabled
[    4.285190] printk: bootconsole [ns16550a0] disabled
[    4.295606] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    4.304515] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    4.314867] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    4.325381] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    4.335539] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    4.345780] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    4.356530] scsi host0: ufshcd
[    4.401598] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    4.409243] libphy: 46000f00.mdio: probed
[    4.413664] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    4.420388] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    4.434158] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    4.442951] mmc0: CQHCI version 5.10
[    4.446585] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    4.458171] pca953x 4-0020: supply vcc not found, using dummy regulator
[    4.464830] pca953x 4-0020: using no AI
[    4.485600] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    4.571237] mmc0: Command Queue Engine enabled
[    4.575677] mmc0: new HS400 MMC card at address 0001
[    4.580846] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    4.585442] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    4.591420] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    4.597394] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
[    4.767581] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    4.773060] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    4.778098] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    4.784350] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    4.790775] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    4.797632] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    4.804230] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    4.810567] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    4.815085] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    4.823244] cdns-ufshcd 4e84000.ufs: last intr at 4664879 us, last intr status=0x404
[    4.830970] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    4.838435] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    4.847458] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    4.853449] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    4.859701] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    4.865777] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    4.871857] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    4.884017] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    4.890357] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    4.896696] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    4.903038] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    4.909375] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    4.915710] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    4.922048] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    4.928385] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    4.934737] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    4.941075] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    4.947414] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    4.952714] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    4.958011] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    4.963309] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    4.968606] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    4.973990] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    4.980154] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    4.985713] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 4665991 us
[    4.992830] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    4.998560] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    5.004376] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    5.009935] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    5.015578] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    5.477593] omap_i2c 2010000.i2c: timeout waiting for bus ready
[    5.483506] pca953x 4-0020: failed writing register
[    5.488455] pca953x: probe of 4-0020 failed with error -16
[    5.494329] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    5.501150] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    5.507961] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    5.514766] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    5.521545] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    5.530946] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    5.538447] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    5.546527] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    5.554607] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.563220] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    5.570712] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    5.578791] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    5.586870] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.595401] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    5.602890] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    5.610969] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    5.619047] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.628050] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    5.638095] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    5.651228] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    5.656461] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[    5.663492] mtd: 47040000.spi.0: skipping zero sized partition
[    5.669308] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    5.675905] Creating 7 MTD partitions on "47040000.spi.0":
[    5.681377] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    5.687339] 0x000000080000-0x000000280000 : "ospi.tispl"
[    5.693020] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    5.698756] 0x000000680000-0x0000006c0000 : "ospi.env"
[    5.704258] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    5.709930] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    5.716049] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    5.723847] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    5.730726] spi-nor: probe of spi1.0 failed with error -2
[    5.773596] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    5.781240] libphy: 46000f00.mdio: probed
[    5.785661] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    5.792385] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    5.805925] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    5.812877] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    5.820088] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    5.826360] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    5.836503] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    5.848170] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    5.855668] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    5.863748] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    5.871827] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.880388] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    5.887881] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    5.895962] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    5.904041] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.912573] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    5.920062] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    5.928155] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    5.936238] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.945977] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    5.953465] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    5.961544] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    5.969623] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.978191] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    5.985685] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    5.993769] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.001851] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.010385] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    6.017881] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    6.025961] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    6.034040] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.043440] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.050951] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    6.059052] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    6.067134] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.076572] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    6.083979] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    6.091311] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    6.098618] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    6.106657] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    6.113744] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    6.121237] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    6.129334] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.137424] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.146154] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    6.153667] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    6.161758] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    6.169845] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.186543] ALSA device list:
[    6.187496] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.189501]   No soundcards found.
[    6.200403] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    6.208761] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    6.216878] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.225526] Waiting for root device PARTUUID=0b959c33-02...
    Does your custom board have eMMC?
    I see only MMC0 traces & do not have MMC1. Have you disabled SD in the kernel DT?
    Can you share the diff patch of the kernel DT if you have modified that for your custom board.
    - Keerthy
  • Hi Keerthy,
    yes,we have 8GB eMMC on our custom board
    I didn't disable it, but I don't know why on EVM MMC0 trace matches to SD, which MMC0 trace matches to eMMC on our board
    we didn't modifiy that for our custom board, but I would like to confirm that which image is for kernel? I just want to know whether I have make it work on the board
    thanks
    On your PSDKLA installation directory please execute the following commands after modifying DT:
    cd $PSDKLA_PATH
    make linux
    Then edit the file Rules.make & point DESTDIR to /media/$USER/rootfs.
    Insert your SD card & then one more command to install the Linux Image:
    sudo make linux_install
    Keerthy
