DaVinci PSP 03.01 GA Release (Build r37) on DM6446
Other Parts Discussed in Thread: TVP5146
Hi all,
I am a little confused by my question but I have seen the release 37 from TI which is perfect for you.
So I tried to use it on my DM6446EVM from Spectrum Digital without success about the display.
I have tried the binaries provided and tried to recompile the kernel, same result, nothing.
This release works for this platform but when I tried to use the dmai examples, I have a message error that indicates the system can open display.
Is it a problem from my bootargs or something wrong in the release ?
Thanks for your help.
GuiLig
    It looks like u have not build your kernel with proper configuration .
    Recompile your kernel with "make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi-  davinci_dm644x_defconfig"   and check.
    kirti.
    There is no davinci_dm644x_defconfig file in arch/arm/configs, only davinci_all_defconfig.
  • To be more explicit, please read the message after a test with encode from DVSDK
    ./encode -k -v test.mpeg4 -o
    Encode demo started.
    Error: Failed to get attribute window buffer
    vpfe-capture vpfe-capture: input information not found for the subdev
    Error: Failed to get display buffer
    tvp514x 1-005d: tvp5146 (Version - 0x03) found at 0xba (DaVinci I2C adapter)
    vpfe-capture vpfe-capture: width = 720, height = 480, bpp = 2
    vpfe-capture vpfe-capture: adjusted width = 720, height = 480, bpp = 2, bytesperline = 1440, sizeimage = 691200
    Reading 0x4 to ALAW...
    Reading 0x0 to CLAMP...
    Reading 0x0 to DCSUB...
    Reading 0x0 to BLKCMP...
    Reading 0x0 to FPC_ADDR...
    Reading 0x0 to FPC...
    Reading 0x0 to FMTCFG...
    Reading 0x0 to COLPTN...
    Reading 0x0 to FMT_HORZ...
    Reading 0x0 to FMT_VERT...
    Reading 0x5a0 to HSIZE_OFF...
    Reading 0x249 to SDOFST...
    Reading 0x0 to VP_OUT...
    Reading 0x32f84 to SYN_MODE...
    Reading 0x59f to HORZ_INFO...
    Reading 0x10001 to VERT_START...
    Reading 0xef to VERT_LINES...
    Error: Failed to create display device
    My bootargs are : video=davincifb:osd0=720x576,16,1620K@0,0 davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=PAL
    I checked the mode via cat /sys/class/davinci_display/ch0/mode -> PAL
  • Can you just run a  display application and try to figure out the issue?
  • It's done but nothing to display.
