Hi Ti,
I got new issue in J721EXCP01EVM Linux-RTOS SDK(ver. 08.00.00.12), process document from below link
There're no problem in Run Instructions-step 2, but matter is, after I finished step 3(make linux_fs_install_sd), board cannot boot every single time.
Monitor goes black out and it doesn't show any prints of course.
you know when I command linux_fs_install_sd, uenv.txt being changed which contains below.
psdk_setup_file=.psdk_setupcheck_psdk_setup=load mmc 1:1 ${loadaddr} ${psdk_setup_file}
# Reset to the default environment
do_psdk_setup=env default -f -a; saveenv
# If not previously configured, then configure the environment and indicate this by writing a file
uenvcmd=if run check_psdk_setup;
then echo "Already setup."; else run do_psdk_setup; mw.b ${loadaddr} 0 1;
fatwrite mmc 1:1 ${loadaddr} .psdk_setup 1;
reset; fi
dorprocboot=1
name_overlays=k3-j721e-vision-apps.dtbo
So I skipped step 3, and copied .cgf, .sh, .out files to /opt/vision_apps/ from /targetfs/opt/vision_apps,
then I got
TDA4VM: APP_LOG: ERROR: Unable to map memory @ 0xb2000000 of size 262144 bytes !!!
error message.
Board couldn't recognize "env default -a -f"
Kisik
