AM5708: Timer
Part Number: AM5708
There is a 125ns periodic clock signal externally, and the customer needs to generate three interrupts synchronized with the external signal at the same time. The periods are 125us, 1ms, and 10ms. Can it be realized?
  • Yes, you can connect the external 125ns periodic clock signal to one of the device pins that has an xref_clk[n] signal in its pin mux.  Use one of the CM_CORE_AON_TIMERi registers to route one of the xref_clk[n] signals to one of the timer modules.  Then, in the timer module, you can set interrupts for when the timer reaches 1000, 8000, and 80,000.
