I have been working on porting some code from a C6748 to the C6657. I am working with a TMDSEVM6657LS evaluation module. The new project is based on the SYS/BIOS "typical" example. From here I started adding the required c665x PDK to the project and and the required include paths and header files to get the code to build. However during linking the following errors are generated.
undefined first referenced
symbol in file
ti_sysbios_family_c66_tci66xx_CpIntc_dispatchPlug__E C:\ti\pdk_c665x_2_0_16\packages\ti\osal\lib\tirtos\c6657\c66\release\ti.osal.ae66<MuxIntcP_tirtos.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_dispatch__E C:\ti\pdk_c665x_2_0_16\packages\ti\osal\lib\tirtos\c6657\c66\release\ti.osal.ae66<MuxIntcP_tirtos.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_enableHostInt__E C:\ti\pdk_c665x_2_0_16\packages\ti\osal\lib\tirtos\c6657\c66\release\ti.osal.ae66<MuxIntcP_tirtos.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_getEventId__E C:\ti\pdk_c665x_2_0_16\packages\ti\osal\lib\tirtos\c6657\c66\release\ti.osal.ae66<MuxIntcP_tirtos.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_mapSysIntToHostInt__E C:\ti\pdk_c665x_2_0_16\packages\ti\osal\lib\tirtos\c6657\c66\release\ti.osal.ae66<MuxIntcP_tirtos.oe66>
I have been unable to locate where these symbols are defined to include them. Any help would be appreciated.
main.c
* ======== main.c ========
//***** Header Files **********************************************************
// XDC module Header Files
#include <xdc/std.h> // XDC "base types" - must be included FIRST
#include <xdc/cfg/global.h> // For all BIOS instances created statically in RTOS .cfg file
#include <xdc/runtime/Error.h> // For error handling (e.g. Error block)
#include <xdc/runtime/Log.h> // Needed for any Log_info() call
#include <xdc/runtime/System.h> // XDC System functions (e.g. System_abort(), System_printf())
#include <xdc/runtime/Timestamp.h> // Needed when using Timestamp APIs (TSCL/H), 32bit, 64bit
#include <xdc/runtime/Types.h> // XDC constants/types used in xdc.runtime pkg
// TI-RTOS Kernel Header Files
#include <ti/sysbios/BIOS.h> // BIOS module API
#include <ti/sysbios/knl/Semaphore.h> // BIOS Semaphore API
#include <ti/sysbios/knl/Task.h> // BIOS Task API
// Standard C Header Files
#include <stdint.h> // Standard integer types
#include <stddef.h> // Standard variable types and macros
#include <stdio.h> // Standard I/O for printf()
// Peripheral Driver Header Files
#include <ti/board/board.h> // Board init enables C6748 modules (e.g. GPIO Module)
#include <ti/drv/uart/uart.h> // Uart Driver Init
* ======== taskFxn ========
Void taskFxn(UArg a0, UArg a1)
System_printf("enter taskFxn()\n");
Task_sleep(10);
System_printf("exit taskFxn()\n");
System_flush(); /* force SysMin output to console */
* ======== main ========
Int main()
Task_Handle task;
Error_Block eb;
System_printf("enter main()\n");
Board_init( 0
// BOARD_INIT_PINMUX_CONFIG |
// BOARD_INIT_MODULE_CLOCK |
// BOARD_INIT_UART_STDIO
// BOARD_INIT_PINMUX_CONFIG | // Initialize PinMux registers and GPIO Module/Clock
// UART_init();
Error_init(&eb);
task = Task_create(taskFxn, NULL, &eb);
if (task == NULL) {
System_printf("Task_create() failed!\n");
BIOS_exit(0);
BIOS_start(); /* does not return */
return(0);
app.cfg
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var EventCombiner = xdc.useModule('ti.sysbios.family.c64p.EventCombiner');
var Exception = xdc.useModule('ti.sysbios.family.c64p.Exception');
var Cache = xdc.useModule('ti.sysbios.family.c66.Cache');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
var Timer = xdc.useModule('ti.sysbios.hal.Timer');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Log = xdc.useModule('xdc.runtime.Log');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var Text = xdc.useModule('xdc.runtime.Text');
var Timestamp = xdc.useModule('xdc.runtime.Timestamp');
var ti_sysbios_timers_timer64_Timer = xdc.useModule('ti.sysbios.timers.timer64.Timer');
* Uncomment this line to globally disable Asserts.
* All modules inherit the default from the 'Defaults' module. You
* can override these defaults on a per-module basis using Module.common$.
* Disabling Asserts will save code space and improve runtime performance.
Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
* Uncomment this line to keep module names from being loaded on the target.
* The module name strings are placed in the .const section. Setting this
* parameter to false will save space in the .const section. Error and
* Assert messages will contain an "unknown module" prefix instead
* of the actual module name.
Defaults.common$.namedModule = false;
* Minimize exit handler array in System. The System module includes
* an array of functions that are registered with System_atexit() to be
* called by System_exit().
//System.maxAtexitHandlers = 4;
* Uncomment this line to disable the Error print function.
* We lose error information when this is disabled since the errors are
* not printed. Disabling the raiseHook will save some code space if
* your app is not using System_printf() since the Error_print() function
* calls System_printf().
Error.raiseHook = null;
* Uncomment this line to keep Error, Assert, and Log strings from being
* loaded on the target. These strings are placed in the .const section.
* Setting this parameter to false will save space in the .const section.
* Error, Assert and Log message will print raw ids and args instead of
* a formatted message.
Text.isLoaded = false;
* Uncomment this line to disable the output of characters by SysMin
* when the program exits. SysMin writes characters to a circular buffer.
* This buffer can be viewed using the SysMin Output view in ROV.
SysMin.flushAtExit = false;
// ================ BIOS Module Setup =========================================
BIOS.taskEnabled = true; // Enable BIOS Task Scheduler
BIOS.heapSize = 0x1000; /* Specify the size of the default heap. */
BIOS.libType = BIOS.LibType_Custom; /* Build a custom SYS/BIOS library from sources. */
BIOS.assertsEnabled = true;
BIOS.logsEnabled = true;
Program.stack = 0x2000;/* System stack size (used by ISRs and Swis) */
var SysMin = xdc.useModule('xdc.runtime.SysMin');
var System = xdc.useModule('xdc.runtime.System');
SysMin.bufSize = 0x200;/* Circular buffer size for System_printf() */
System.SupportProxy = SysMin;
// ================ Create Logger for Whole System ============================
//var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
//var loggerBufParams = new LoggerBuf.Params();
//loggerBufParams.numEntries = 16;
//var logger0 = LoggerBuf.create(loggerBufParams);
//Defaults.common$.logger = logger0;
//Main.common$.diags_INFO = Diags.ALWAYS_ON;
// ================ LoggingSetup configuration ================================
// NOTE: Need to include UIA package to use
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
LoggingSetup.loadLoggerSize = 8192;
LoggingSetup.sysbiosLoggerSize = 8192;
LoggingSetup.mainLoggerSize = 8192;
LoggingSetup.loggerType = LoggingSetup.LoggerType_STOPMODE;
LoggingSetup.loadTaskLogging = true;
LoggingSetup.loadSwiLogging = true;
LoggingSetup.loadHwiLogging = false;
LoggingSetup.sysbiosSemaphoreLogging = true;
LoggingSetup.countingAndGraphingLogging = true;
// ================ Task configuration ========================================
var Task = xdc.useModule('ti.sysbios.knl.Task');
Task.checkStackFlag = false; // No runtime stack checking is performed
Task.numPriorities = 4; // Reduce the number of task priorities
// ================ Mailbox configuration =====================================
var Mailbox = xdc.useModule('ti.sysbios.knl.Mailbox');
// ================ Idle configuration ========================================
var Idle = xdc.useModule('ti.sysbios.knl.Idle');
Idle.addFunc("&myIdleFxn");
// ================ SOC and Core specific configuration ================
var devType = "c6657"
var osType = "tirtos"
// ================ Low level drivers configuration ================
// Load the OSAL package
var Osal = xdc.useModule('ti.osal.Settings');
Osal.osType = osType;
Osal.socType = devType;
// Load and use the CSL packages
var Csl = xdc.useModule('ti.csl.Settings');
Csl.deviceType = devType;
// Load the Board package and set the board name
var Board = xdc.loadPackage('ti.board');
Board.Settings.boardName = "evmC6657";
// Load the gpio package
var Gpio = xdc.loadPackage('ti.drv.gpio');
Gpio.Settings.enableProfiling = false;
Gpio.Settings.socType = devType;
// Load the uart package
var Uart = xdc.useModule('ti.drv.uart.Settings');
Uart.socType = devType;
// Load the I2C package - required by board
var I2c = xdc.loadPackage('ti.drv.i2c');
I2c.Settings.socType = devType;
// Load the SPI package
var Spi = xdc.loadPackage('ti.drv.spi');
Spi.Settings.socType = devType;
