I'm attempting to build the code made by the gencodecpkg wizard uing the EZSDK install that came with the c6a816x/am389 EVM and the build is failing:
lholeva@ubuntu:/mnt/hgfs/8168/Code/r1397/DSP/crown/preprocessing$ make all
"/home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/xdctools_3_20_05_69_eng/xdc" XDCOPTIONS= XDCARGS="CGTOOLS_C674=\"/home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/cgt6x_7_2_0\"" --xdcpath="/home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/codec-engine_3_21_00_02/packages;/home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/xdais_7_20_00_06/packages" release
making package.mak (because of package.bld) ...
gmake: Warning: File `lib/release/preprocessing.a674.mak' has modification time 9.3 s in the future
generating interfaces for package crown.preprocessing (because package/package.xdc.inc is older than package.xdc) ...
translating PREPROCESSING
cl674 preprocessing.c ...
cl674 package/package_crown.preprocessing.c ...
archiving package/lib/lib/debug/preprocessing/preprocessing.o674 package/lib/lib/debug/preprocessing/package/package_crown.preprocessing.o674 into lib/debug/preprocessing.a674 ...
--> error: 'package/lib/lib/debug/preprocessing/preprocessing.o674' not found
--> error: 'package/lib/lib/debug/preprocessing/package/package_crown.preprocessing.o674' not found
gmake: *** [lib/debug/preprocessing.a674] Error 1
gmake: *** Deleting file `lib/debug/preprocessing.a674'
make: *** [all] Error 2
I did modify the generated make file to correct the installation location of Rules.make:
# your various installation directories
XDC_INSTALL_DIR=/home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/xdctools_3_20_05_69_eng
CE_INSTALL_DIR=/home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/codec-engine_3_21_00_02
XDAIS_INSTALL_DIR=/home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/xdais_7_20_00_06
CODEGEN_INSTALL_DIR=/home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/cgt6x_7_2_0
#uncomment this for verbose builds
#XDCOPTIONS=v
# If we're a subcomponent, allow larger product settings to override our
# defaults. The variable $(RULES_MAKE) can be overridden on the 'make'
# command-line if the location below is not correct (for example, if you
# want to use a Rules.make from some other location.
RULES_MAKE := /home/lholeva/ti-ezsdk_c6a816x-evm_5_00_00_56/Rules.make
ifneq ($(wildcard $(RULES_MAKE)),)
include $(RULES_MAKE)
endif
CGTOOLS_C674=$(CODEGEN_INSTALL_DIR)
XDCARGS= CGTOOLS_C674=\"$(CGTOOLS_C674)\"
XDCPATH=$(CE_INSTALL_DIR)/packages;$(XDAIS_INSTALL_DIR)/packages
all:
"$(XDC_INSTALL_DIR)/xdc" XDCOPTIONS=$(XDCOPTIONS) XDCARGS="$(XDCARGS)" --xdcpath="$(XDCPATH)" release
clean:
"$(XDC_INSTALL_DIR)/xdc" clean
Any idea what is wrong? I'm using iUniversal.
Lee Holeva
