Other Parts Discussed in Thread: TDA4VM
Not able to load the kernel image from the SD card.
Im using the images and rootfs from the TI released SDk.
uic68347@igl5718u:~/oti-processor-sdk-linux-j7-evm-08_00_00_08$ sudo bin/mksdboot.sh --device $SD_DEVICE --sdk .
Partitioning and formatting completed!
Copying filesystem on /dev/sdd1, /dev/sdd2
unmounting /dev/sdd1, /dev/sdd2
completed!
uic68347@igl5718u: sudo fdisk -l
Device Boot Start End Sectors Size Id Type
/dev/sdd1 * 2048 129023 126976 62M c W95 FAT32 (LBA)
/dev/sdd2 129024 116785151 116656128 55.6G 83 Linux
uic68347@igl5718u:/media/uic68347/boot$ ls
sysfw.itb tiboot3.bin tispl.bin u-boot.img uenv.txt uenv.txt.base uenv.txt.disp_sharing uenv.txt.jailhouse uenv.txt.psdkra version
uic68347@igl5718u:/media/uic68347/boot$ cd ..
uic68347@igl5718u:/media/uic68347$ cd rootfs/
uic68347@igl5718u:/media/uic68347/rootfs$ ls
bin boot dev etc home include init lib linuxrc lost+found media mnt opt proc run sbin sys tmp usr var
Bootup Log
U-Boot SPL 2021.01-00004-gc57d986ee4 (Oct 01 2021 - 09:40:50 +0530)
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E8
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.5(release):08.00.00.004-dirty
NOTICE: BL31: Built : 22:30:09, Aug 4 2021
U-Boot SPL 2021.01-00004-gc57d986ee4 (Oct 01 2021 - 09:39:42 +0530)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2021.01-00004-gc57d986ee4 (Oct 01 2021 - 09:39:42 +0530)
SoC: J721E SR2.0
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
eth0: ethernet@46000000
Hit any key to stop autoboot: 0
=> env default –a –f
=> saveenv
Saving Environment to MMC... Writing to redundant MMC(0)... OK
=> boot
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 1 ms (0 Bytes/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19137024 bytes read in 801 ms (22.8 MiB/s)
97586 bytes read in 15 ms (6.2 MiB/s)
Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.41-g4c2eade9f7 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Aug 4 22:47:28 UTC 2021
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=51444818-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[ 0.000000] Memory: 3372032K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 297984K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008800b0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[ 0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008351] Console: colour dummy device 80x25
[ 0.012912] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023582] pid_max: default: 32768 minimum: 301
[ 0.028327] LSM: Security Framework initializing
[ 0.033072] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.040639] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.049568] rcu: Hierarchical SRCU implementation.
[ 0.054619] Platform MSI: msi-controller@1820000 domain created
[ 0.060848] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070142] EFI services will not be available.
[ 0.074888] smp: Bringing up secondary CPUs ...
[ 0.080066] Detected PIPT I-cache on CPU1
[ 0.080089] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.080100] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[ 0.080134] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.080185] smp: Brought up 1 node, 2 CPUs
[ 0.109529] SMP: Total of 2 processors activated.
[ 0.114334] CPU features: detected: 32-bit EL0 Support
[ 0.119589] CPU features: detected: CRC32 instructions
[ 0.133329] CPU: All CPU(s) started at EL2
[ 0.137524] alternatives: patching kernel code
[ 0.142508] devtmpfs: initialized
[ 0.150668] KASLR disabled due to lack of seed
[ 0.155320] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.165283] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.172934] pinctrl core: initialized pinctrl subsystem
[ 0.178509] DMI not present or invalid.
[ 0.182719] NET: Registered protocol family 16
[ 0.190170] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.197469] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.205472] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.213771] thermal_sys: Registered thermal governor 'step_wise'
[ 0.213773] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.220191] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.233832] ASID allocator initialised with 65536 entries
[ 0.256094] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.262948] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.269709] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.277608] cryptd: max_cpu_qlen set to 1000
[ 0.283591] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.292418] vsys_3v3: supplied by evm_12v0
[ 0.296725] vsys_5v0: supplied by evm_12v0
[ 0.301350] iommu: Default domain type: Translated
[ 0.306529] SCSI subsystem initialized
[ 0.310651] mc: Linux media interface: v0.10
[ 0.315022] videodev: Linux video capture interface: v2.00
[ 0.320649] pps_core: LinuxPPS API ver. 1 registered
[ 0.325718] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.335055] PTP clock support registered
[ 0.339073] EDAC MC: Ver: 3.0.0
[ 0.342801] FPGA manager framework
[ 0.346310] Advanced Linux Sound Architecture Driver Initialized.
[ 0.352909] clocksource: Switched to clocksource arch_sys_counter
[ 0.359321] VFS: Disk quotas dquot_6.6.0
[ 0.363371] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.373035] NET: Registered protocol family 2
[ 0.377619] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[ 0.386208] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.394988] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[ 0.403184] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[ 0.410980] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.417733] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.424626] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.432018] NET: Registered protocol family 1
[ 0.436701] RPC: Registered named UNIX socket transport module.
[ 0.442761] RPC: Registered udp transport module.
[ 0.447566] RPC: Registered tcp transport module.
[ 0.452368] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.458952] PCI: CLS 0 bytes, default 64
[ 0.463307] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.473513] Initialise system trusted keyrings
[ 0.478133] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[ 0.486391] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.492632] NFS: Registering the id_resolver key type
[ 0.497809] Key type id_resolver registered
[ 0.502080] Key type id_legacy registered
[ 0.506198] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.513045] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.520734] 9p: Installing v9fs 9p2000 file system support
[ 0.545489] Key type asymmetric registered
[ 0.549676] Asymmetric key parser 'x509' registered
[ 0.554673] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.562232] io scheduler mq-deadline registered
[ 0.566857] io scheduler kyber registered
[ 0.572074] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.578230] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.586632] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.592896] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.600761] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.608823] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.617816] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[ 0.626652] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[ 0.634364] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.647139] brd: module loaded
[ 0.653020] loop: module loaded
[ 0.656814] megasas: 07.714.04.00-rc1
[ 0.661764] libphy: Fixed MDIO Bus: probed
[ 0.666413] tun: Universal TUN/TAP device driver, 1.6
[ 0.671833] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.678238] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.684308] sky2: driver version 1.30
[ 0.688551] VFIO - User Level meta-driver version: 0.3
[ 0.694215] i2c /dev entries driver
[ 0.698386] sdhci: Secure Digital Host Controller Interface driver
[ 0.704702] sdhci: Copyright(c) Pierre Ossman
[ 0.709320] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.715631] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.721933] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.729048] optee: probing for conduit method.
[ 0.733598] optee: revision 3.12 (3d47a131)
[ 0.733830] optee: initialized driver
[ 0.743105] NET: Registered protocol family 17
[ 0.747717] 9pnet: Installing 9P2000 support
[ 0.752102] Key type dns_resolver registered
[ 0.756560] Loading compiled-in X.509 certificates
[ 0.765786] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.772114] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.780210] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[ 0.806319] random: fast init done
[ 0.832577] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.840042] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.846109] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.852151] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.858526] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.865341] pca953x 3-0020: using no AI
[ 0.893661] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.900461] pca953x 3-0022: using AI
[ 0.904727] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[ 0.910701] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[ 0.916942] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[ 0.923451] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.929863] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.939560] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.945810] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 0.952623] pca953x 6-0020: using no AI
[ 0.977566] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.983587] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 0.989515] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 0.995707] pca953x 9-0020: supply vcc not found, using dummy regulator
[ 1.002519] pca953x 9-0020: using no AI
[ 1.029507] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 1.035901] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.045862] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.054659] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.064479] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.084110] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[ 1.091803] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.099469] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.107746] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.116021] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.126367] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 2.132785] pci_bus 0000:00: root bus resource [bus 00-0f]
[ 2.138391] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 2.148082] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 2.155130] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.161269] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.171139] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.181028] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[ 2.190990] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.200958] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[ 2.210918] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[ 2.220906] pci 0000:00:00.0: supports D1
[ 2.224999] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.230870] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[ 2.242517] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.250710] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.260670] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.270628] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.282073] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[ 2.288841] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.294139] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 2.300472] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.308142] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.316421] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.324698] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.334924] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 3.341334] pci_bus 0001:00: root bus resource [bus 00-0f]
[ 3.346940] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 3.356807] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.363851] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.370052] pci 0001:00:00.0: supports D1
[ 3.374146] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 3.381635] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.391297] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
[ 3.398066] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.403358] pcieport 0001:00:00.0: PME: Signaling with IRQ 59
[ 3.409663] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.417332] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.425608] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.433884] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.444235] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[ 4.450654] pci_bus 0002:00: root bus resource [bus 00-0f]
[ 4.456259] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[ 4.465505] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[ 4.476280] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[ 4.482481] pci 0002:00:00.0: supports D1
[ 4.486575] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[ 4.494056] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.503721] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
[ 4.510494] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 4.515752] pcieport 0002:00:00.0: PME: Signaling with IRQ 62
[ 4.522449] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 4.532331] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 4.539091] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.548002] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 4.558156] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 4.564917] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.572851] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 4.582206] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[ 4.590949] printk: console [ttyS2] enabled
[ 4.599385] printk: bootconsole [ns16550a0] disabled
[ 4.609811] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[ 4.618723] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[ 4.629006] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.639517] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 4.649674] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 4.659913] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 4.670672] scsi host0: ufshcd
[ 4.692508] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[ 4.716913] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.724555] libphy: 46000f00.mdio: probed
[ 4.728567] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[ 4.729868] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 4.740229] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[ 4.748503] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 4.759727] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.781157] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.789919] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 4.789929] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[ 4.805511] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 4.805519] mmc0: CQHCI version 5.10
[ 4.820575] vdd_mmc1: supplied by vsys_3v3
[ 4.825250] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 4.831913] pca953x 4-0020: using no AI
[ 4.852919] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 4.861817] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 4.868648] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 4.875455] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 4.882257] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 4.889038] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 4.898680] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 4.908675] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[ 4.921784] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[ 4.927017] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[ 4.934049] mtd: 47040000.spi.0: skipping zero sized partition
[ 4.939866] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 4.946464] Creating 7 MTD partitions on "47040000.spi.0":
[ 4.947099] mmc0: Command Queue Engine enabled
[ 4.951937] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 4.952457] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 4.956383] mmc0: new HS400 MMC card at address 0001
[ 4.967349] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 4.972510] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 4.976752] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 4.982451] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 4.988050] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 4.993431] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 4.999017] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 5.012066] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[ 5.018231] 0x000000800000-0x000004000000 : "ospi.rootfs"
[ 5.026326] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 5.068915] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 5.076563] libphy: 46000f00.mdio: probed
[ 5.081738] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 5.090030] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 5.103568] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 5.110468] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 5.117679] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 5.123950] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 5.134122] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 5.134452] mmc1: CQHCI version 5.10
[ 5.151530] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 5.158874] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 5.166214] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 5.173524] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 5.181626] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.197861] ALSA device list:
[ 5.200820] No soundcards found.
[ 6.199614] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 6.207865] Waiting for root device PARTUUID=51444818-02...
[ 6.248610] mmc1: error -110 whilst initialising SD card
[ 6.658274] mmc1: error -110 whilst initialising SD card
[ 7.068040] mmc1: error -110 whilst initialising SD card
[ 7.487255] mmc1: error -110 whilst initialising SD card
[ 35.912917] vdd_mmc1: disabling
