Re: DSP/BIOS configuration issue on EVMC6748
I thought perhaps the .map file is also useful to disclose here:
               TMS320C6x Linker PC v7.2.2
>> Linked Tue Apr 12 11:47:41 2011
OUTPUT FILE NAME:   <IPTFirmwareCCS.out>
ENTRY POINT SYMBOL: "_c_int00"  address: c4034620
MEMORY CONFIGURATION
         name            origin    length      used     unused   attr    fill
  IRAM                  11800000   00020000  000000bc  0001ff44  RWIX
  CACHE_L2              11820000   00020000  00000000  00020000  RWIX
  CACHE_L1P             11e00000   00008000  00000000  00008000  RWIX
  CACHE_L1D             11f00000   00008000  00000000  00008000  RWIX
  L3_CBA_RAM            80000000   00020000  00000000  00020000  RWIX
  DDR                   c0000000   08000000  040364a8  03fc9b58  RWIX
SECTION ALLOCATION MAP
 output                                  attributes/
section   page    origin      length       input sections
.vers      0    00000000    00000044     COPY SECTION
                  00000000    00000044     IPT_Firmwarecfg.obj (.vers)
.log       0    11800000    00000030
                  11800000    00000030     IPT_Firmwarecfg.obj (.log)
.sts       0    11800030    00000030
                  11800030    00000030     IPT_Firmwarecfg.obj (.sts)
.swi       0    11800060    0000002c     UNINITIALIZED
                  11800060    0000002c     IPT_Firmwarecfg.obj (.swi)
.idl       0    1180008c    00000014     UNINITIALIZED
                  1180008c    00000014     IPT_Firmwarecfg.obj (.idl)
.idlcal    0    118000a0    00000014     UNINITIALIZED
                  118000a0    00000014     IPT_Firmwarecfg.obj (.idlcal)
.clk       0    118000b4    00000008     UNINITIALIZED
                  118000b4    00000008     IPT_Firmwarecfg.obj (.clk)
.prd       0    c0000000    00000000     UNINITIALIZED
.data      0    c0000000    00000000     UNINITIALIZED
.DDR$heap
*          0    c0000000    04000000     UNINITIALIZED
                  c0000000    04000000     --HOLE--
.text      0    c4000000    00020fe0
                  c4000000    00001060     main.obj (.text)
                  c4001060    00000780     rts6740_eh.lib : iostream.obj (.text:_overflow__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_Z2Z8int_type_Q2_Z2Z8int_type)
                  c40017e0    00000780                    : iostream.obj (.text:_uflow__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_Q2_Z2Z8int_type)
                  c4001f60    00000760                    : wiostrea.obj (.text:_uflow__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_Q2_Z2Z8int_type)
                  c40026c0    00000740                    : wiostrea.obj (.text:_overflow__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_Z2Z8int_type_Q2_Z2Z8int_type)
                  c4002e00    000006e0                    : wiostrea.obj (.text:___ct__Q2_3std6_WinitFv)
                  c40034e0    000006e0                    : iostream.obj (.text:___ct__Q3_3std8ios_base4InitFv)
                  c4003bc0    00000680                    : divd.obj (.text:__divd)
                  c4004240    00000660                    : throw_edg.obj (.text:___throw)
                  c40048a0    00000620                    : iostream.obj (.text:__Endwrite__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_b)
                  c4004ec0    00000620                    : wiostrea.obj (.text:__Endwrite__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_b)
                  c40054e0    00000580                    : _printfi.obj (.text:__getarg_diouxp)
                  c4005a60    00000560                    : ios.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFPCZ1Z)
                  c4005fc0    00000560                    : wlocale.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFPCZ1Z)
                  c4006520    00000520                    : wlocale.obj (.text:___ct__Q2_3std78basic_string__tm__58_wQ2_3std20char_traits__tm__2_wQ2_3std18allocator__tm__2_wFPCZ1Z)
                  c4006a40    000004c0                    : locale0.obj (.text:___ct__Q2_3std8_LocinfoFPCc)
                  c4006f00    000004a0                    : xlocale.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFPCZ1Z)
                  c40073a0    00000480                    : _printfi.obj (.text:__setfield)
                  c4007820    00000460                    : fwrite.obj (.text:_fwrite)
                  c4007c80    00000440                    : _printfi.obj (.text:__printfi)
                  c40080c0    00000380                    : wlocale.obj (.text:__Copy__Q2_3std78basic_string__tm__58_wQ2_3std20char_traits__tm__2_wQ2_3std18allocator__tm__2_wFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_v)
                  c4008440    00000360                    : ios.obj (.text:__Copy__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_v)
                  c40087a0    00000360                    : iostream.obj (.text:__Copy__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_v)
                  c4008b00    00000360                    : locale0.obj (.text:__Copy__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_v)
                  c4008e60    00000360                    : string.obj (.text:__Copy__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_v)
                  c40091c0    00000360                    : wiostrea.obj (.text:__Copy__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_v)
                  c4009520    00000360                    : wlocale.obj (.text:__Copy__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_v)
                  c4009880    00000360                    : xlocale.obj (.text:__Copy__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_v)
                  c4009be0    00000360                    : locale0.obj (.text:__Init__Q2_3std6localeSFv)
                  c4009f40    00000300                    : ios.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFRCQ2_3std30basic_string__tm__10_Z1ZZ2ZZ3Z)
                  c400a240    00000300                    : fputs.obj (.text:_fputs)
                  c400a540    000002e0                    : locale0.obj (.text:___CPR230__assign__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFRCQ2_3std30basic_string__tm__10_Z1ZZ2ZZ3ZQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT2_RQ2_3stdJ105J)
                  c400a820    000002e0                    : string.obj (.text:___CPR230__assign__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFRCQ2_3std30basic_string__tm__10_Z1ZZ2ZZ3ZQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT2_RQ2_3stdJ105J)
                  c400ab00    000002e0                    : wiostrea.obj (.text:___dt__Q2_3std6_WinitFv)
                  c400ade0    000002e0                    : iostream.obj (.text:___dt__Q3_3std8ios_base4InitFv)
                  c400b0c0    000002e0                    : _printfi.obj (.text:__pproc_fwp)
                  c400b3a0    000002e0                    : ios.obj (.text:_clear__Q2_3std8ios_baseFQ3_3std14_Iosb__tm__2_i8_Iostateb)
                  c400b680    000002c0                    : throw_edg.obj (.text:___CPR138__check_exception_type_specifications__FP31an_exception_type_specificationPC16a_type_info_implUcPUcPciPPvPPJ39J)
                  c400b940    000002c0                    : locale0.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFPCZ1Z)
                  c400bc00    000002c0                    : string.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFPCZ1Z)
                  c400bec0    000002c0                    : _printfi.obj (.text:__pproc_fge)
                  c400c180    000002a0                    : _printfi.obj (.text:_ecvt)
                  c400c420    000002a0                    : _printfi.obj (.text:_fcvt)
                  c400c6c0    00000280                    : iostream.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeZ1Z)
                  c400c940    00000280                    : wiostrea.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeZ1Z)
                  c400cbc0    00000280                    : rtti.obj (.text:___derived_to_base_conversion)
                  c400ce40    00000260                    : imath64.obj (.text:__divull)
                  c400d0a0    00000260                    : _printfi.obj (.text:__pconv_e)
                  c400d300    00000220                    : iostream.obj (.text:___ct__Q2_3std52basic_istream__tm__31_cQ2_3std20char_traits__tm__2_cFPQ2_3std29basic_streambuf__tm__7_Z1ZZ2ZbT2)
                  c400d520    00000220                    : wiostrea.obj (.text:___ct__Q2_3std52basic_istream__tm__31_wQ2_3std20char_traits__tm__2_wFPQ2_3std29basic_streambuf__tm__7_Z1ZZ2ZbT2)
                  c400d740    00000220                    : _printfi.obj (.text:__pproc_diouxp)
                  c400d960    00000220                    : _printfi.obj (.text:__pproc_str)
                  c400db80    00000220                    : throw_edg.obj (.text:_cleanup__FP19__an_eh_stack_entryUsT2)
                  c400dda0    00000200                    : iostream.obj (.text:___ct__Q2_3std52basic_ostream__tm__31_cQ2_3std20char_traits__tm__2_cFPQ2_3std29basic_streambuf__tm__7_Z1ZZ2Zb)
                  c400dfa0    00000200                    : wiostrea.obj (.text:___ct__Q2_3std52basic_ostream__tm__31_wQ2_3std20char_traits__tm__2_wFPQ2_3std29basic_streambuf__tm__7_Z1ZZ2Zb)
                  c400e1a0    00000200                    : iostream.obj (.text:___dt__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFv)
                  c400e3a0    00000200                    : wiostrea.obj (.text:___dt__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFv)
                  c400e5a0    00000200                    : locale0.obj (.text:___dt__Q2_3std8_LocinfoFv)
                  c400e7a0    00000200                    : locale0.obj (.text:___dt__Q3_3std6locale7_LocimpFv)
                  c400e9a0    00000200                    : _printfi.obj (.text:__pconv_g)
                  c400eba0    000001e0                    : eh_util.obj (.text:___call_unexpected)
                  c400ed80    000001e0                    : iostream.obj (.text:___ct__Q2_3std17ctype__tm__2_c__SFPCsbUi)
                  c400ef60    000001e0                    : iostream.obj (.text:___ct__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFPQ2_3std4FILE)
                  c400f140    000001c0                    : iostream.obj (.text:___CPR167__seekoff__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_Z2Z8off_typeQ3_3std14_Iosb__tm__2_i8_SeekdirQ3_3stdJ93J9_Openmode_Q2_Z2Z8pos_type)
                  c400f300    000001c0                    : wiostrea.obj (.text:___CPR167__seekoff__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_Z2Z8off_typeQ3_3std14_Iosb__tm__2_i8_SeekdirQ3_3stdJ93J9_Openmode_Q2_Z2Z8pos_type)
                  c400f4c0    000001c0                    : _printfi.obj (.text:__mcpy)
                  c400f680    000001a0                    : xlocinfo.obj (.text:__Getctyptab)
                  c400f820    000001a0                    : wiostrea.obj (.text:___ct__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFPQ2_3std4FILE)
                  c400f9c0    000001a0                    : imath40.obj (.text:__divul)
                  c400fb60    000001a0                    : wiostrea.obj (.text:_do_in__Q2_3std21codecvt__tm__4_wci__SCFRiPCcT2RPCcPwT5RPw)
                  c400fd00    000001a0                    : setvbuf.obj (.text:_setvbuf)
                  c400fea0    00000180                    : trgdrv.obj (.text:_HOSTrename)
                  c4010020    00000180                    : iostream.obj (.text:___ct__Q2_3std52basic_istream__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_3std14_Uninitialized)
                  c40101a0    00000180                    : wiostrea.obj (.text:___ct__Q2_3std52basic_istream__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_3std14_Uninitialized)
                  c4010320    00000180                    : iostream.obj (.text:___ct__Q2_3std52basic_ostream__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_3std14_Uninitialized)
                  c40104a0    00000180                    : wiostrea.obj (.text:___ct__Q2_3std52basic_ostream__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_3std14_Uninitialized)
                  c4010620    00000180                    : iostream.obj (.text:___ct__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFv)
                  c40107a0    00000180                    : wiostrea.obj (.text:___ct__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFv)
                  c4010920    00000180                    : throw_edg.obj (.text:___free_thrown_object)
                  c4010aa0    00000180                    : frcmpyd_div.obj (.text:__frcmpyd_div)
                  c4010c20    00000180                    : wiostrea.obj (.text:_do_out__Q2_3std21codecvt__tm__4_wci__SCFRiPCwT2RPCwPcT5RPc)
                  c4010da0    00000180                    : throw_edg.obj (.text:_eh_alloc_on_stack__FUi)
                  c4010f20    00000180                    : throw_edg.obj (.text:_push_throw_stack__FPC16a_type_info_implPFPvi_vUcPUcPciPvT6P19a_throw_stack_entry)
                  c40110a0    00000180                    : iostream.obj (.text:_seekpos__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_Z2Z8pos_typeQ3_3std14_Iosb__tm__2_i9_Openmode_Q2_Z2Z8pos_type)
                  c4011220    00000180                    : wiostrea.obj (.text:_seekpos__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_Z2Z8pos_typeQ3_3std14_Iosb__tm__2_i9_Openmode_Q2_Z2Z8pos_type)
                  c40113a0    00000160                    : wiostrea.obj (.text:___ct__Q2_3std17ctype__tm__2_w__SFUi)
                  c4011500    00000160                    : vec_newdel.obj (.text:_array_delete_general__FPviUiT3PFPvi_vT2PFPv_vN22)
                  c4011660    00000160                    : iostream.obj (.text:_pbackfail__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_Z2Z8int_type_Q2_Z2Z8int_type)
                  c40117c0    00000160                    : wiostrea.obj (.text:_pbackfail__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_Z2Z8int_type_Q2_Z2Z8int_type)
                  c4011920    00000140                    : locale0.obj (.text:__Fac_tidy)
                  c4011a60    00000140                    : iostream.obj (.text:___ct__Q2_3std18codecvt__tm__4_cciFUi)
                  c4011ba0    00000140                    : wiostrea.obj (.text:___ct__Q2_3std21codecvt__tm__4_wci__SFUi)
                  c4011ce0    00000140                    : locale0.obj (.text:___ct__Q3_3std6locale7_LocimpFb)
                  c4011e20    00000140                    : string.obj (.text:___dt__Q2_3std11logic_errorFv)
                  c4011f60    00000140                    : ios.obj (.text:___dt__Q2_3std13runtime_errorFv)
                  c40120a0    00000140                    : iostream.obj (.text:___dt__Q2_3std17ctype__tm__2_c__SFv)
                  c40121e0    00000140                    : wiostrea.obj (.text:___sti___12_wiostrea_cpp_74e2bd13)
                  c4012320    00000140                    : _bufread.obj (.text:__buff_read)
                  c4012460    00000140                    : _printfi.obj (.text:__pproc_fflags)
                  c40125a0    00000140                    : fputc.obj (.text:_fputc)
                  c40126e0    00000140                    : lowlev.obj (.text:_getdevice)
                  c4012820    00000140                    : iostream.obj (.text:_setbuf__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFPZ1Zi_PQ2_3std29basic_streambuf__tm__7_Z1ZZ2Z)
                  c4012960    00000140                    : iostream.obj (.text:_use_facet__tm__24_Q2_3std14ctype__tm__2_c__3stdFRCQ2_3std6locale_RCZ1Z)
                  c4012aa0    00000120                    : ios.obj (.text:__Addstd__Q2_3std8ios_baseFv)
                  c4012bc0    00000120                    : string.obj (.text:__Xlen__Q2_3std12_String_baseCFv)
                  c4012ce0    00000120                    : string.obj (.text:__Xran__Q2_3std12_String_baseCFv)
                  c4012e00    00000120                    : throw_edg.obj (.text:___can_throw_type)
                  c4012f20    00000120                    : iostream.obj (.text:___ct__Q2_3std10ctype_baseFUi)
                  c4013040    00000120                    : wiostrea.obj (.text:___ct__Q2_3std10ctype_baseFUi)
                  c4013160    00000120                    : string.obj (.text:___ct__Q2_3std11logic_errorFRCQ2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_c)
                  c4013280    00000120                    : iostream.obj (.text:___ct__Q2_3std12codecvt_baseFUi)
                  c40133a0    00000120                    : wiostrea.obj (.text:___ct__Q2_3std12codecvt_baseFUi)
                  c40134c0    00000120                    : string.obj (.text:___ct__Q2_3std12length_errorFRCQ2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_c)
                  c40135e0    00000120                    : string.obj (.text:___ct__Q2_3std12out_of_rangeFRCQ2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_c)
                  c4013700    00000120                    : eh_util.obj (.text:___ct__Q2_3std13bad_exceptionFPCc)
                  c4013820    00000120                    : ios.obj (.text:___ct__Q2_3std13runtime_errorFRCQ2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_c)
                  c4013940    00000120                    : iostream.obj (.text:___ct__Q2_3std6localeFRCQ2_3std6locale)
                  c4013a60    00000120                    : wiostrea.obj (.text:___ct__Q2_3std6localeFRCQ2_3std6locale)
                  c4013b80    00000120                    : locale0.obj (.text:___ct__Q2_3std6localeFv)
                  c4013ca0    00000120                    : string.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFRCQ2_3std30basic_string__tm__10_Z1ZZ2ZZ3Z)
                  c4013dc0    00000120                    : newhandler.obj (.text:___ct__Q2_3std9bad_allocFPCc)
                  c4013ee0    00000120                    : ios.obj (.text:___ct__Q3_3std8ios_base7failureFRCQ2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_c)
                  c4014000    00000120                    : xlocale.obj (.text:___dt__Q2_3std16_Mpunct__tm__2_cFv)
                  c4014120    00000120                    : wlocale.obj (.text:___dt__Q2_3std16_Mpunct__tm__2_wFv)
                  c4014240    00000120                    : wiostrea.obj (.text:___dt__Q2_3std17ctype__tm__2_w__SFv)
                  c4014360    00000120                    : iostream.obj (.text:___sti___12_iostream_cpp_3a72482d)
                  c4014480    00000120                    : wiostrea.obj (.text:_do_is__Q2_3std17ctype__tm__2_w__SCFPCwT1Ps)
                  c40145a0    00000120                    : wiostrea.obj (.text:_do_narrow__Q2_3std17ctype__tm__2_w__SCFPCwT1cPc)
                  c40146c0    00000120                    : fclose.obj (.text:_fclose)
                  c40147e0    00000120                    : fgetc.obj (.text:_fgetc)
                  c4014900    00000120                    : iostream.obj (.text:_imbue__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFRCQ2_3std6locale_v)
                  c4014a20    00000120                    : wiostrea.obj (.text:_imbue__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFRCQ2_3std6locale_v)
                  c4014b40    00000120                    : wiostrea.obj (.text:_setbuf__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFPZ1Zi_PQ2_3std29basic_streambuf__tm__7_Z1ZZ2Z)
                  c4014c60    00000120                    : wiostrea.obj (.text:_use_facet__tm__24_Q2_3std14ctype__tm__2_w__3stdFRCQ2_3std6locale_RCZ1Z)
                  c4014d80    00000120                    : iostream.obj (.text:_use_facet__tm__28_Q2_3std18codecvt__tm__4_cci__3stdFRCQ2_3std6locale_RCZ1Z)
                  c4014ea0    00000120                    : wiostrea.obj (.text:_use_facet__tm__28_Q2_3std18codecvt__tm__4_wci__3stdFRCQ2_3std6locale_RCZ1Z)
                  c4014fc0    00000120                    : wiostrea.obj (.text:_xsgetn__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFPZ1Zi_i)
                  c40150e0    00000100                    : trgdrv.obj (.text:_HOSTlseek)
                  c40151e0    00000100                    : vec_newdel.obj (.text:___cleanup_vec_new_or_delete)
                  c40152e0    00000100                    : iostream.obj (.text:___ct__Q2_3std13fpos__tm__2_iFZ1Zi)
                  c40153e0    00000100                    : wiostrea.obj (.text:___ct__Q2_3std13fpos__tm__2_iFZ1Zi)
                  c40154e0    00000100                    : iostream.obj (.text:___ct__Q2_3std13fpos__tm__2_iFl)
                  c40155e0    00000100                    : wiostrea.obj (.text:___ct__Q2_3std13fpos__tm__2_iFl)
                  c40156e0    00000100                    : ios.obj (.text:___ct__Q2_3std48_String_val__tm__29_cQ2_3std18allocator__tm__2_cFQ3_Z2Z17rebind__tm__4_Z1Z5other)
                  c40157e0    00000100                    : iostream.obj (.text:___ct__Q2_3std48_String_val__tm__29_cQ2_3std18allocator__tm__2_cFQ3_Z2Z17rebind__tm__4_Z1Z5other)
                  c40158e0    00000100                    : locale0.obj (.text:___ct__Q2_3std48_String_val__tm__29_cQ2_3std18allocator__tm__2_cFQ3_Z2Z17rebind__tm__4_Z1Z5other)
                  c40159e0    00000100                    : string.obj (.text:___ct__Q2_3std48_String_val__tm__29_cQ2_3std18allocator__tm__2_cFQ3_Z2Z17rebind__tm__4_Z1Z5other)
                  c4015ae0    00000100                    : wiostrea.obj (.text:___ct__Q2_3std48_String_val__tm__29_cQ2_3std18allocator__tm__2_cFQ3_Z2Z17rebind__tm__4_Z1Z5other)
                  c4015be0    00000100                    : wlocale.obj (.text:___ct__Q2_3std48_String_val__tm__29_cQ2_3std18allocator__tm__2_cFQ3_Z2Z17rebind__tm__4_Z1Z5other)
                  c4015ce0    00000100                    : xlocale.obj (.text:___ct__Q2_3std48_String_val__tm__29_cQ2_3std18allocator__tm__2_cFQ3_Z2Z17rebind__tm__4_Z1Z5other)
                  c4015de0    00000100                    : wlocale.obj (.text:___ct__Q2_3std48_String_val__tm__29_wQ2_3std18allocator__tm__2_wFQ3_Z2Z17rebind__tm__4_Z1Z5other)
                  c4015ee0    00000100                    : iostream.obj (.text:___ct__Q2_3std48basic_ios__tm__31_cQ2_3std20char_traits__tm__2_cFv)
                  c4015fe0    00000100                    : wiostrea.obj (.text:___ct__Q2_3std48basic_ios__tm__31_wQ2_3std20char_traits__tm__2_wFv)
                  c40160e0    00000100                    : iostream.obj (.text:___ct__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_3std14_Uninitialized)
                  c40161e0    00000100                    : wiostrea.obj (.text:___ct__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_3std14_Uninitialized)
                  c40162e0    00000100                    : iostream.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c40163e0    00000100                    : locale0.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c40164e0    00000100                    : wiostrea.obj (.text:___ct__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c40165e0    00000100                    : iostream.obj (.text:___ct__Q2_3std82_String_iterator__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ2_Z3Z7pointer)
                  c40166e0    00000100                    : wiostrea.obj (.text:___ct__Q2_3std82_String_iterator__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ2_Z3Z7pointer)
                  c40167e0    00000100                    : eh_util.obj (.text:___ct__Q2_3std9exceptionFPCc)
                  c40168e0    00000100                    : ios.obj (.text:___ct__Q2_3std9exceptionFPCc)
                  c40169e0    00000100                    : newhandler.obj (.text:___ct__Q2_3std9exceptionFPCc)
                  c4016ae0    00000100                    : string.obj (.text:___ct__Q2_3std9exceptionFPCc)
                  c4016be0    00000100                    : iostream.obj (.text:___ct__Q3_3std6locale5facetFUi)
                  c4016ce0    00000100                    : locale0.obj (.text:___ct__Q3_3std6locale5facetFUi)
                  c4016de0    00000100                    : wiostrea.obj (.text:___ct__Q3_3std6locale5facetFUi)
                  c4016ee0    00000100                    : iostream.obj (.text:___dt__Q2_3std52basic_istream__tm__31_cQ2_3std20char_traits__tm__2_cFv)
                  c4016fe0    00000100                    : wiostrea.obj (.text:___dt__Q2_3std52basic_istream__tm__31_wQ2_3std20char_traits__tm__2_wFv)
                  c40170e0    00000100                    : iostream.obj (.text:___dt__Q2_3std52basic_ostream__tm__31_cQ2_3std20char_traits__tm__2_cFv)
                  c40171e0    00000100                    : wiostrea.obj (.text:___dt__Q2_3std52basic_ostream__tm__31_wQ2_3std20char_traits__tm__2_wFv)
                  c40172e0    00000100                    : throw_edg.obj (.text:___rethrow)
                  c40173e0    00000100                    : _printfi.obj (.text:__ltostr)
                  c40174e0    00000100                    : _io_perm.obj (.text:__wrt_ok)
                  c40175e0    00000100                    : sinit.obj (.text:_call_dtors)
                  c40176e0    00000100                    : wiostrea.obj (.text:_do_length__Q2_3std21codecvt__tm__4_wci__SCFRCiPCcT2Ui)
                  c40177e0    00000100                    : fflush.obj (.text:_fflush)
                  c40178e0    00000100                    : ungetc.obj (.text:_ungetc)
                  c40179e0    00000100                    : iostream.obj (.text:_widen__Q2_3std48basic_ios__tm__31_cQ2_3std20char_traits__tm__2_cCFc_Z1Z)
                  c4017ae0    00000100                    : iostream.obj (.text:_xsgetn__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFPZ1Zi_i)
                  c4017be0    00000100                    : iostream.obj (.text:_xsputn__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFPCZ1Zi_i)
                  c4017ce0    00000100                    : wiostrea.obj (.text:_xsputn__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFPCZ1Zi_i)
                  c4017de0    000000e0                    : trgdrv.obj (.text:_HOSTopen)
                  c4017ec0    000000e0                    : iostream.obj (.text:___ct__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_3std14_Uninitialized)
                  c4017fa0    000000e0                    : wiostrea.obj (.text:___ct__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_3std14_Uninitialized)
                  c4018080    000000e0                    : locale0.obj (.text:___ct__Q2_3std6localeFPQ3_3std6locale7_Locimp)
                  c4018160    000000e0                    : iostream.obj (.text:___ct__Q2_3std88_String_const_iterator__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ2_Z3Z13const_pointer)
                  c4018240    000000e0                    : wiostrea.obj (.text:___ct__Q2_3std88_String_const_iterator__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ2_Z3Z13const_pointer)
                  c4018320    000000e0                    : iostream.obj (.text:___ct__Q2_3std8ios_baseFv)
                  c4018400    000000e0                    : wiostrea.obj (.text:___ct__Q2_3std8ios_baseFv)
                  c40184e0    000000e0                    : locale0.obj (.text:___ct__Q2_3std9_Fac_nodeFPQ2_3std9_Fac_nodePQ3_3std6locale5facet)
                  c40185c0    000000e0                    : iostream.obj (.text:___ct__Q3_3std6locale2idFUi)
                  c40186a0    000000e0                    : locale.obj (.text:___ct__Q3_3std6locale2idFUi)
                  c4018780    000000e0                    : locale0.obj (.text:___ct__Q3_3std6locale2idFUi)
                  c4018860    000000e0                    : wlocale.obj (.text:___ct__Q3_3std6locale2idFUi)
                  c4018940    000000e0                    : xlocale.obj (.text:___ct__Q3_3std6locale2idFUi)
                  c4018a20    000000e0                    : string.obj (.text:___dt__Q2_3std12length_errorFv)
                  c4018b00    000000e0                    : string.obj (.text:___dt__Q2_3std12out_of_rangeFv)
                  c4018be0    000000e0                    : iostream.obj (.text:___dt__Q2_3std18codecvt__tm__4_cciFv)
                  c4018cc0    000000e0                    : wiostrea.obj (.text:___dt__Q2_3std21codecvt__tm__4_wci__SFv)
                  c4018da0    000000e0                    : iostream.obj (.text:___dt__Q2_3std48basic_ios__tm__31_cQ2_3std20char_traits__tm__2_cFv)
                  c4018e80    000000e0                    : wiostrea.obj (.text:___dt__Q2_3std48basic_ios__tm__31_wQ2_3std20char_traits__tm__2_wFv)
                  c4018f60    000000e0                    : ios.obj (.text:___dt__Q2_3std6localeFv)
                  c4019040    000000e0                    : iostream.obj (.text:___dt__Q2_3std6localeFv)
                  c4019120    000000e0                    : locale.obj (.text:___dt__Q2_3std6localeFv)
                  c4019200    000000e0                    : locale0.obj (.text:___dt__Q2_3std6localeFv)
                  c40192e0    000000e0                    : wiostrea.obj (.text:___dt__Q2_3std6localeFv)
                  c40193c0    000000e0                    : wlocale.obj (.text:___dt__Q2_3std6localeFv)
                  c40194a0    000000e0                    : xlocale.obj (.text:___dt__Q2_3std6localeFv)
                  c4019580    000000e0                    : ios.obj (.text:___dt__Q3_3std8ios_base7failureFv)
                  c4019660    000000e0                    : iostream.obj (.text:___opUi__Q3_3std6locale2idFv)
                  c4019740    000000e0                    : wiostrea.obj (.text:___opUi__Q3_3std6locale2idFv)
                  c4019820    000000e0                    : wlocale.obj (.text:___sti___11_wlocale_cpp_961df3c4)
                  c4019900    000000e0                    : throw_edg.obj (.text:_alloc_in_mem_block__FUiPP16a_mem_allocation)
                  c40199e0    000000e0                    : throw_edg.obj (.text:_alloc_new_mem_block__FUi)
                  c4019ac0    000000e0                    : atoi.obj (.text:_atoi)
                  c4019ba0    000000e0                    : lowlev.obj (.text:_close)
                  c4019c80    000000e0                    : xlocale.obj (.text:_erase__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFQ4_3std25_String_val__tm__7_Z1ZZ3Z5_Alty9size_typeT1_RQ2_3std30basic_string__tm__10_Z1ZZ2ZZ3Z)
                  c4019d60    000000e0                    : memset.obj (.text:_memset)
                  c4019e40    000000e0                    : wiostrea.obj (.text:_widen__Q2_3std48basic_ios__tm__31_wQ2_3std20char_traits__tm__2_wCFc_Z1Z)
                  c4019f20    000000c0                    : trgdrv.obj (.text:_HOSTread)
                  c4019fe0    000000c0                    : trgdrv.obj (.text:_HOSTunlink)
                  c401a0a0    000000c0                    : trgdrv.obj (.text:_HOSTwrite)
                  c401a160    000000c0                    : ios.obj (.text:__Decref__Q3_3std6locale5facetFv)
                  c401a220    000000c0                    : iostream.obj (.text:__Decref__Q3_3std6locale5facetFv)
                  c401a2e0    000000c0                    : locale.obj (.text:__Decref__Q3_3std6locale5facetFv)
                  c401a3a0    000000c0                    : locale0.obj (.text:__Decref__Q3_3std6locale5facetFv)
                  c401a460    000000c0                    : wiostrea.obj (.text:__Decref__Q3_3std6locale5facetFv)
                  c401a520    000000c0                    : wlocale.obj (.text:__Decref__Q3_3std6locale5facetFv)
                  c401a5e0    000000c0                    : xlocale.obj (.text:__Decref__Q3_3std6locale5facetFv)
                  c401a6a0    000000c0                    : iostream.obj (.text:__Incref__Q3_3std6locale5facetFv)
                  c401a760    000000c0                    : locale0.obj (.text:__Incref__Q3_3std6locale5facetFv)
                  c401a820    000000c0                    : wiostrea.obj (.text:__Incref__Q3_3std6locale5facetFv)
                  c401a8e0    000000c0                    : ios.obj (.text:___ct__Q2_3std18allocator__tm__2_cFRCQ2_3std20allocator__tm__4_Z1Z)
                  c401a9a0    000000c0                    : iostream.obj (.text:___ct__Q2_3std18allocator__tm__2_cFRCQ2_3std20allocator__tm__4_Z1Z)
                  c401aa60    000000c0                    : locale0.obj (.text:___ct__Q2_3std18allocator__tm__2_cFRCQ2_3std20allocator__tm__4_Z1Z)
                  c401ab20    000000c0                    : string.obj (.text:___ct__Q2_3std18allocator__tm__2_cFRCQ2_3std20allocator__tm__4_Z1Z)
                  c401abe0    000000c0                    : wiostrea.obj (.text:___ct__Q2_3std18allocator__tm__2_cFRCQ2_3std20allocator__tm__4_Z1Z)
                  c401aca0    000000c0                    : wlocale.obj (.text:___ct__Q2_3std18allocator__tm__2_cFRCQ2_3std20allocator__tm__4_Z1Z)
                  c401ad60    000000c0                    : xlocale.obj (.text:___ct__Q2_3std18allocator__tm__2_cFRCQ2_3std20allocator__tm__4_Z1Z)
                  c401ae20    000000c0                    : ios.obj (.text:___ct__Q2_3std18allocator__tm__2_cFv)
                  c401aee0    000000c0                    : iostream.obj (.text:___ct__Q2_3std18allocator__tm__2_cFv)
                  c401afa0    000000c0                    : locale0.obj (.text:___ct__Q2_3std18allocator__tm__2_cFv)
                  c401b060    000000c0                    : string.obj (.text:___ct__Q2_3std18allocator__tm__2_cFv)
                  c401b120    000000c0                    : wiostrea.obj (.text:___ct__Q2_3std18allocator__tm__2_cFv)
                  c401b1e0    000000c0                    : wlocale.obj (.text:___ct__Q2_3std18allocator__tm__2_cFv)
                  c401b2a0    000000c0                    : xlocale.obj (.text:___ct__Q2_3std18allocator__tm__2_cFv)
                  c401b360    000000c0                    : wlocale.obj (.text:___ct__Q2_3std18allocator__tm__2_wFRCQ2_3std20allocator__tm__4_Z1Z)
                  c401b420    000000c0                    : wlocale.obj (.text:___ct__Q2_3std18allocator__tm__2_wFv)
                  c401b4e0    000000c0                    : eh_util.obj (.text:___dt__Q2_3std13bad_exceptionFv)
                  c401b5a0    000000c0                    : ios.obj (.text:___dt__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c401b660    000000c0                    : iostream.obj (.text:___dt__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c401b720    000000c0                    : locale.obj (.text:___dt__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c401b7e0    000000c0                    : locale0.obj (.text:___dt__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c401b8a0    000000c0                    : string.obj (.text:___dt__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c401b960    000000c0                    : wiostrea.obj (.text:___dt__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c401ba20    000000c0                    : wlocale.obj (.text:___dt__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c401bae0    000000c0                    : xlocale.obj (.text:___dt__Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_cFv)
                  c401bba0    000000c0                    : wlocale.obj (.text:___dt__Q2_3std78basic_string__tm__58_wQ2_3std20char_traits__tm__2_wQ2_3std18allocator__tm__2_wFv)
                  c401bc60    000000c0                    : ios.obj (.text:___dt__Q2_3std8ios_baseFv)
                  c401bd20    000000c0                    : new_.obj (.text:___nw__FUi)
                  c401bde0    000000c0                    : throw_edg.obj (.text:___type_of_thrown_object)
                  c401bea0    000000c0                    : fopen.obj (.text:__cleanup)
                  c401bf60    000000c0                    : _printfi.obj (.text:__div)
                  c401c020    000000c0                    : divu.obj (.text:__divu)
                  c401c0e0    000000c0                    : fflush.obj (.text:__doflush)
                  c401c1a0    000000c0                    : atexit.obj (.text:_atexit)
                  c401c260    000000c0                    : throw_edg.obj (.text:_check_pointer_levels_and_qualifiers__FP31an_exception_type_specificationPUc)
                  c401c320    000000c0                    : throw_edg.obj (.text:_destroy_thrown_object__FP19a_throw_stack_entry)
                  c401c3e0    000000c0                    : wiostrea.obj (.text:_do_tolower__Q2_3std17ctype__tm__2_w__SCFPwPCw)
                  c401c4a0    000000c0                    : wiostrea.obj (.text:_do_toupper__Q2_3std17ctype__tm__2_w__SCFPwPCw)
                  c401c560    000000c0                    : wiostrea.obj (.text:_do_unshift__Q2_3std21codecvt__tm__4_wci__SCFRiPcT2RPc)
                  c401c620    000000c0                    : fseek.obj (.text:_fseek)
                  c401c6e0    000000c0                    : ftell.obj (.text:_ftell)
                  c401c7a0    000000c0                    : lowlev.obj (.text:_lseek)
                  c401c860    000000c0                    : ltoa.obj (.text:_ltoa)
                  c401c920    000000c0                    : lowlev.obj (.text:_read)
                  c401c9e0    000000c0                    : locale0.obj (.text:_tidy_global__3stdFKv)
                  c401caa0    000000c0                    : iostream.obj (.text:_underflow__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_Q2_Z2Z8int_type)
                  c401cb60    000000c0                    : wiostrea.obj (.text:_underflow__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_Q2_Z2Z8int_type)
                  c401cc20    000000c0                    : wchar.obj (.text:_wmemmove)
                  c401cce0    000000c0                    : lowlev.obj (.text:_write)
                  c401cda0    000000c0     bios.a674 : tsk_stup.o674 (.text)
                  c401ce60    000000a0     rts6740_eh.lib : trgdrv.obj (.text:_HOSTclose)
                  c401cf00    000000a0                    : locale0.obj (.text:__Setgloballocale)
                  c401cfa0    000000a0                    : ios.obj (.text:__Tidy__Q2_3std8ios_baseFv)
                  c401d040    000000a0                    : locale0.obj (.text:___ct__Q2_3std6localeFQ2_3std14_Uninitialized)
                  c401d0e0    000000a0                    : ios.obj (.text:___ct__Q2_3std7_LockitFi)
                  c401d180    000000a0                    : iostream.obj (.text:___ct__Q2_3std7_LockitFi)
                  c401d220    000000a0                    : locale.obj (.text:___ct__Q2_3std7_LockitFi)
                  c401d2c0    000000a0                    : locale0.obj (.text:___ct__Q2_3std7_LockitFi)
                  c401d360    000000a0                    : wiostrea.obj (.text:___ct__Q2_3std7_LockitFi)
                  c401d400    000000a0                    : wlocale.obj (.text:___ct__Q2_3std7_LockitFi)
                  c401d4a0    000000a0                    : xlocale.obj (.text:___ct__Q2_3std7_LockitFi)
                  c401d540    000000a0                    : iostream.obj (.text:___dt__Q2_3std10ctype_baseFv)
                  c401d5e0    000000a0                    : locale.obj (.text:___dt__Q2_3std10ctype_baseFv)
                  c401d680    000000a0                    : wiostrea.obj (.text:___dt__Q2_3std10ctype_baseFv)
                  c401d720    000000a0                    : wlocale.obj (.text:___dt__Q2_3std10ctype_baseFv)
                  c401d7c0    000000a0                    : xlocale.obj (.text:___dt__Q2_3std10ctype_baseFv)
                  c401d860    000000a0                    : wlocale.obj (.text:___dt__Q2_3std10money_baseFv)
                  c401d900    000000a0                    : xlocale.obj (.text:___dt__Q2_3std10money_baseFv)
                  c401d9a0    000000a0                    : iostream.obj (.text:___dt__Q2_3std12codecvt_baseFv)
                  c401da40    000000a0                    : locale.obj (.text:___dt__Q2_3std12codecvt_baseFv)
                  c401dae0    000000a0                    : wiostrea.obj (.text:___dt__Q2_3std12codecvt_baseFv)
                  c401db80    000000a0                    : wlocale.obj (.text:___dt__Q2_3std12codecvt_baseFv)
                  c401dc20    000000a0                    : wlocale.obj (.text:___dt__Q2_3std13messages_baseFv)
                  c401dcc0    000000a0                    : xlocale.obj (.text:___dt__Q2_3std13messages_baseFv)
                  c401dd60    000000a0                    : locale.obj (.text:___dt__Q2_3std9bad_allocFv)
                  c401de00    000000a0                    : newhandler.obj (.text:___dt__Q2_3std9bad_allocFv)
                  c401dea0    000000a0                    : wlocale.obj (.text:___dt__Q2_3std9time_baseFv)
                  c401df40    000000a0                    : xlocale.obj (.text:___dt__Q2_3std9time_baseFv)
                  c401dfe0    000000a0                    : xlocale.obj (.text:___sti___11_xlocale_cpp_e9f82b60)
                  c401e080    000000a0                    : imath40.obj (.text:__divli)
                  c401e120    000000a0                    : _printfi.obj (.text:__ecpy)
                  c401e1c0    000000a0                    : _printfi.obj (.text:__fcpy)
                  c401e260    000000a0                    : fixdli.obj (.text:__fixdli)
                  c401e300    000000a0                    : _printfi.obj (.text:__pconv_f)
                  c401e3a0    000000a0                    : _io_perm.obj (.text:__rd_ok)
                  c401e440    000000a0                    : wiostrea.obj (.text:_do_widen__Q2_3std17ctype__tm__2_w__SCFPCcT1Pw)
                  c401e4e0    000000a0                    : lowlev.obj (.text:_finddevice)
                  c401e580    000000a0                    : throw_edg.obj (.text:_free_in_mem_block__FPv)
                  c401e620    000000a0                    : memcpy64.obj (.text:_memcpy)
                  c401e6c0    00000080                    : ios.obj (.text:__Callfns__Q2_3std8ios_baseFQ3_3std8ios_base5event)
                  c401e740    00000080                    : locale0.obj (.text:__Getfacet__Q2_3std6localeCFUi)
                  c401e7c0    00000080                    : locale0.obj (.text:__Register__Q3_3std6locale5facetFv)
                  c401e840    00000080                    : delete.obj (.text:___dl__FPv)
                  c401e8c0    00000080                    : fltlid.obj (.text:__fltlid)
                  c401e940    00000080                    : llshift.obj (.text:__llshl)
                  c401e9c0    00000080                    : wiostrea.obj (.text:_do_scan_is__Q2_3std17ctype__tm__2_w__SCFsPCwT2)
                  c401ea40    00000080                    : wiostrea.obj (.text:_do_scan_not__Q2_3std17ctype__tm__2_w__SCFsPCwT2)
                  c401eac0    00000080                    : wiostrea.obj (.text:_do_tolower__Q2_3std17ctype__tm__2_w__SCFw)
                  c401eb40    00000080                    : wiostrea.obj (.text:_do_toupper__Q2_3std17ctype__tm__2_w__SCFw)
                  c401ebc0    00000080                    : throw_edg.obj (.text:_eh_free_on_stack__FPv)
                  c401ec40    00000080                    : fprintf.obj (.text:_fprintf)
                  c401ecc0    00000080                    : trgmsg.obj (.text:_readmsg)
                  c401ed40    00000080                    : iostream.obj (.text:_sync__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_i)
                  c401edc0    00000080                    : wiostrea.obj (.text:_sync__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_i)
                  c401ee40    00000080                    : iostream.obj (.text:_uflow__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_Q2_Z2Z8int_type)
                  c401eec0    00000080                    : wiostrea.obj (.text:_uflow__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_Q2_Z2Z8int_type)
                  c401ef40    00000080                    : wchar.obj (.text:_ungetwc)
                  c401efc0    00000080                    : lowlev.obj (.text:_unlink)
                  c401f040    00000080                    : wchar.obj (.text:_wmemcpy)
                  c401f0c0    00000060                    : locale0.obj (.text:__Deletegloballocale)
                  c401f120    00000060                    : ios.obj (.text:__Init__Q2_3std8ios_baseFv)
                  c401f180    00000060                    : iostream.obj (.text:___CPR169__seekoff__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_Z2Z8off_typeQ3_3std14_Iosb__tm__2_i8_SeekdirQ3_3stdJ95J9_Openmode_Q2_Z2Z8pos_type)
                  c401f1e0    00000060                    : wiostrea.obj (.text:___CPR169__seekoff__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_Z2Z8off_typeQ3_3std14_Iosb__tm__2_i8_SeekdirQ3_3stdJ95J9_Openmode_Q2_Z2Z8pos_type)
                  c401f240    00000060                    : eh_util.obj (.text:___call_terminate)
                  c401f2a0    00000060                    : array_del.obj (.text:___dla__FPv)
                  c401f300    00000060                    : iostream.obj (.text:___dt__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFv)
                  c401f360    00000060                    : wiostrea.obj (.text:___dt__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFv)
                  c401f3c0    00000060                    : throw_edg.obj (.text:___exception_caught)
                  c401f420    00000060                    : locale.obj (.text:___sti___10_locale_cpp_8e0a6042)
                  c401f480    00000060                    : locale0.obj (.text:___sti___11_locale0_cpp_36e19383)
                  c401f4e0    00000060                    : throw_edg.obj (.text:___throw_setup_dtor)
                  c401f540    00000060                    : imath64.obj (.text:__subcull)
                  c401f5a0    00000060                    : iostream.obj (.text:_do_tolower__Q2_3std17ctype__tm__2_c__SCFPcPCc)
                  c401f600    00000060                    : iostream.obj (.text:_do_toupper__Q2_3std17ctype__tm__2_c__SCFPcPCc)
                  c401f660    00000060                    : setjmp.obj (.text:_longjmp)
                  c401f6c0    00000060                    : memccpy.obj (.text:_memccpy)
                  c401f720    00000060                    : memmov.obj (.text:_memmove)
                  c401f780    00000060                    : iostream.obj (.text:_seekpos__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_Z2Z8pos_typeQ3_3std14_Iosb__tm__2_i9_Openmode_Q2_Z2Z8pos_type)
                  c401f7e0    00000060                    : wiostrea.obj (.text:_seekpos__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_Z2Z8pos_typeQ3_3std14_Iosb__tm__2_i9_Openmode_Q2_Z2Z8pos_type)
                  c401f840    00000060                    : setlocale.obj (.text:_setlocale)
                  c401f8a0    00000060                    : trgmsg.obj (.text:_writemsg)
                  c401f900    00000040                    : sinit.obj (.text:___add_dtor)
                  c401f940    00000040                    : vec_newdel.obj (.text:___adelete)
                  c401f980    00000040                    : newhandler.obj (.text:___default_new_handler__Fv)
                  c401f9c0    00000040                    : ios.obj (.text:___dt__Q2_3std7_LockitFv)
                  c401fa00    00000040                    : iostream.obj (.text:___dt__Q2_3std7_LockitFv)
                  c401fa40    00000040                    : locale.obj (.text:___dt__Q2_3std7_LockitFv)
                  c401fa80    00000040                    : locale0.obj (.text:___dt__Q2_3std7_LockitFv)
                  c401fac0    00000040                    : wiostrea.obj (.text:___dt__Q2_3std7_LockitFv)
                  c401fb00    00000040                    : wlocale.obj (.text:___dt__Q2_3std7_LockitFv)
                  c401fb40    00000040                    : xlocale.obj (.text:___dt__Q2_3std7_LockitFv)
                  c401fb80    00000040                    : eh_util.obj (.text:___dt__Q2_3std9exceptionFv)
                  c401fbc0    00000040                    : ios.obj (.text:___dt__Q2_3std9exceptionFv)
                  c401fc00    00000040                    : locale.obj (.text:___dt__Q2_3std9exceptionFv)
                  c401fc40    00000040                    : newhandler.obj (.text:___dt__Q2_3std9exceptionFv)
                  c401fc80    00000040                    : string.obj (.text:___dt__Q2_3std9exceptionFv)
                  c401fcc0    00000040                    : typeinfo_.obj (.text:___dt__Q2_3std9exceptionFv)
                  c401fd00    00000040                    : typeinfo_.obj (.text:___dt__Q2_3std9type_infoFv)
                  c401fd40    00000040                    : iostream.obj (.text:___dt__Q3_3std6locale5facetFv)
                  c401fd80    00000040                    : locale.obj (.text:___dt__Q3_3std6locale5facetFv)
                  c401fdc0    00000040                    : locale0.obj (.text:___dt__Q3_3std6locale5facetFv)
                  c401fe00    00000040                    : wiostrea.obj (.text:___dt__Q3_3std6locale5facetFv)
                  c401fe40    00000040                    : wlocale.obj (.text:___dt__Q3_3std6locale5facetFv)
                  c401fe80    00000040                    : xlocale.obj (.text:___dt__Q3_3std6locale5facetFv)
                  c401fec0    00000040                    : isinf.obj (.text:___isinf)
                  c401ff00    00000040                    : _printfi.obj (.text:___isnan)
                  c401ff40    00000040                    : divd.obj (.text:___isnan)
                  c401ff80    00000040                    : throw_edg.obj (.text:___suppress_optim_on_vars_in_try)
                  c401ffc0    00000040                    : llshift.obj (.text:__llshru)
                  c4020000    00000040                    : imath40.obj (.text:__remli)
                  c4020040    00000040                    : vec_newdel.obj (.text:_add_vec_new_or_delete_eh_stack_entry__FP19__an_eh_stack_entryP22an_array_alloc_eh_infoi)
                  c4020080    00000040                    : wiostrea.obj (.text:_do_is__Q2_3std17ctype__tm__2_w__SCFsw)
                  c40200c0    00000040                    : iostream.obj (.text:_do_narrow__Q2_3std17ctype__tm__2_c__SCFPCcT1cPc)
                  c4020100    00000040                    : wiostrea.obj (.text:_do_narrow__Q2_3std17ctype__tm__2_w__SCFwc)
                  c4020140    00000040                    : iostream.obj (.text:_do_tolower__Q2_3std17ctype__tm__2_c__SCFc)
                  c4020180    00000040                    : iostream.obj (.text:_do_toupper__Q2_3std17ctype__tm__2_c__SCFc)
                  c40201c0    00000040                    : iostream.obj (.text:_do_widen__Q2_3std17ctype__tm__2_c__SCFPCcT1Pc)
                  c4020200    00000040                    : wiostrea.obj (.text:_do_widen__Q2_3std17ctype__tm__2_w__SCFc)
                  c4020240    00000040                    : fgetpos.obj (.text:_fgetpos)
                  c4020280    00000040                    : vec_newdel.obj (.text:_free_array__FPvUiT2PFPv_vi)
                  c40202c0    00000040                    : wchar.obj (.text:_mbrtowc)
                  c4020300    00000040                    : multibyte.obj (.text:_mbtowc)
                  c4020340    00000040                    : setjmp.obj (.text:_setjmp)
                  c4020380    00000040                    : strcmp.obj (.text:_strcmp)
                  c40203c0    00000040                    : strlen.obj (.text:_strlen)
                  c4020400    00000040                    : eh_util.obj (.text:_terminate__3stdFv)
                  c4020440    00000040                    : wchar.obj (.text:_wcrtomb)
                  c4020480    00000040                    : wchar.obj (.text:_wcslen)
                  c40204c0    00000040                    : string.obj (.text:_what__Q2_3std11logic_errorCFv)
                  c4020500    00000040                    : ios.obj (.text:_what__Q2_3std13runtime_errorCFv)
                  c4020540    00000020                    : xatexit.obj (.text:__Atexit)
                  c4020560    00000020                    : locale0.obj (.text:__Getgloballocale)
                  c4020580    00000020                    : iostream.obj (.text:__Lock__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_v)
                  c40205a0    00000020                    : wiostrea.obj (.text:__Lock__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_v)
                  c40205c0    00000020                    : iostream.obj (.text:__Unlock__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_v)
                  c40205e0    00000020                    : wiostrea.obj (.text:__Unlock__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_v)
                  c4020600    00000020                    : error.obj (.text:___abort_execution)
                  c4020620    00000020                    : eh_util.obj (.text:___default_terminate)
                  c4020640    00000020                    : placedel.obj (.text:___dl__FPvT1)
                  c4020660    00000020                    : throw_edg.obj (.text:___internal_rethrow)
                  c4020680    00000020                    : placenew.obj (.text:___nw__FUiPv)
                  c40206a0    00000020                    : negll.obj (.text:__negll)
                  c40206c0    00000020                    : _lock.obj (.text:__nop)
                  c40206e0    00000020                    : fprintf.obj (.text:__outc)
                  c4020700    00000020                    : fprintf.obj (.text:__outs)
                  c4020720    00000020                    : _lock.obj (.text:__register_lock)
                  c4020740    00000020                    : _lock.obj (.text:__register_unlock)
                  c4020760    00000020                    : exit.obj (.text:_abort)
                  c4020780    00000020                    : iostream.obj (.text:_do_always_noconv__Q2_3std12codecvt_baseCFv)
                  c40207a0    00000020                    : wiostrea.obj (.text:_do_always_noconv__Q2_3std12codecvt_baseCFv)
                  c40207c0    00000020                    : wiostrea.obj (.text:_do_always_noconv__Q2_3std21codecvt__tm__4_wci__SCFv)
                  c40207e0    00000020                    : xlocale.obj (.text:_do_curr_symbol__Q2_3std16_Mpunct__tm__2_cCFv_Q2_3std84basic_string__tm__64_Z1ZQ2_3std22char_traits__tm__4_Z1ZQ2_3std20allocator__tm__4_Z1Z)
                  c4020800    00000020                    : wlocale.obj (.text:_do_curr_symbol__Q2_3std16_Mpunct__tm__2_wCFv_Q2_3std84basic_string__tm__64_Z1ZQ2_3std22char_traits__tm__4_Z1ZQ2_3std20allocator__tm__4_Z1Z)
                  c4020820    00000020                    : xlocale.obj (.text:_do_decimal_point__Q2_3std16_Mpunct__tm__2_cCFv_Z1Z)
                  c4020840    00000020                    : wlocale.obj (.text:_do_decimal_point__Q2_3std16_Mpunct__tm__2_wCFv_Z1Z)
                  c4020860    00000020                    : iostream.obj (.text:_do_encoding__Q2_3std12codecvt_baseCFv)
                  c4020880    00000020                    : wiostrea.obj (.text:_do_encoding__Q2_3std12codecvt_baseCFv)
                  c40208a0    00000020                    : wiostrea.obj (.text:_do_encoding__Q2_3std21codecvt__tm__4_wci__SCFv)
                  c40208c0    00000020                    : xlocale.obj (.text:_do_frac_digits__Q2_3std16_Mpunct__tm__2_cCFv_i)
                  c40208e0    00000020                    : wlocale.obj (.text:_do_frac_digits__Q2_3std16_Mpunct__tm__2_wCFv_i)
                  c4020900    00000020                    : xlocale.obj (.text:_do_grouping__Q2_3std16_Mpunct__tm__2_cCFv_Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_c)
                  c4020920    00000020                    : wlocale.obj (.text:_do_grouping__Q2_3std16_Mpunct__tm__2_wCFv_Q2_3std78basic_string__tm__58_cQ2_3std20char_traits__tm__2_cQ2_3std18allocator__tm__2_c)
                  c4020940    00000020                    : iostream.obj (.text:_do_in__Q2_3std18codecvt__tm__4_cciCFRZ3ZPCZ2ZT2RPCZ2ZPZ1ZT5RPZ1Z_i)
                  c4020960    00000020                    : iostream.obj (.text:_do_length__Q2_3std18codecvt__tm__4_cciCFRCZ3ZPCZ2ZT2Ui_i)
                  c4020980    00000020                    : iostream.obj (.text:_do_max_length__Q2_3std12codecvt_baseCFv)
                  c40209a0    00000020                    : wiostrea.obj (.text:_do_max_length__Q2_3std12codecvt_baseCFv)
                  c40209c0    00000020                    : wiostrea.obj (.text:_do_max_length__Q2_3std21codecvt__tm__4_wci__SCFv)
                  c40209e0    00000020                    : iostream.obj (.text:_do_narrow__Q2_3std17ctype__tm__2_c__SCFcT1)
                  c4020a00    00000020                    : xlocale.obj (.text:_do_neg_format__Q2_3std16_Mpunct__tm__2_cCFv_Q3_3std10money_base7pattern)
                  c4020a20    00000020                    : wlocale.obj (.text:_do_neg_format__Q2_3std16_Mpunct__tm__2_wCFv_Q3_3std10money_base7pattern)
                  c4020a40    00000020                    : xlocale.obj (.text:_do_negative_sign__Q2_3std16_Mpunct__tm__2_cCFv_Q2_3std84basic_string__tm__64_Z1ZQ2_3std22char_traits__tm__4_Z1ZQ2_3std20allocator__tm__4_Z1Z)
                  c4020a60    00000020                    : wlocale.obj (.text:_do_negative_sign__Q2_3std16_Mpunct__tm__2_wCFv_Q2_3std84basic_string__tm__64_Z1ZQ2_3std22char_traits__tm__4_Z1ZQ2_3std20allocator__tm__4_Z1Z)
                  c4020a80    00000020                    : iostream.obj (.text:_do_out__Q2_3std18codecvt__tm__4_cciCFRZ3ZPCZ1ZT2RPCZ1ZPZ2ZT5RPZ2Z_i)
                  c4020aa0    00000020                    : xlocale.obj (.text:_do_pos_format__Q2_3std16_Mpunct__tm__2_cCFv_Q3_3std10money_base7pattern)
                  c4020ac0    00000020                    : wlocale.obj (.text:_do_pos_format__Q2_3std16_Mpunct__tm__2_wCFv_Q3_3std10money_base7pattern)
                  c4020ae0    00000020                    : xlocale.obj (.text:_do_positive_sign__Q2_3std16_Mpunct__tm__2_cCFv_Q2_3std84basic_string__tm__64_Z1ZQ2_3std22char_traits__tm__4_Z1ZQ2_3std20allocator__tm__4_Z1Z)
                  c4020b00    00000020                    : wlocale.obj (.text:_do_positive_sign__Q2_3std16_Mpunct__tm__2_wCFv_Q2_3std84basic_string__tm__64_Z1ZQ2_3std22char_traits__tm__4_Z1ZQ2_3std20allocator__tm__4_Z1Z)
                  c4020b20    00000020                    : xlocale.obj (.text:_do_thousands_sep__Q2_3std16_Mpunct__tm__2_cCFv_Z1Z)
                  c4020b40    00000020                    : wlocale.obj (.text:_do_thousands_sep__Q2_3std16_Mpunct__tm__2_wCFv_Z1Z)
                  c4020b60    00000020                    : iostream.obj (.text:_do_unshift__Q2_3std18codecvt__tm__4_cciCFRZ3ZPZ2ZT2RPZ2Z_i)
                  c4020b80    00000020                    : iostream.obj (.text:_do_widen__Q2_3std17ctype__tm__2_c__SCFc)
                  c4020ba0    00000020                    : wchar.obj (.text:_fgetwc)
                  c4020bc0    00000020                    : wchar.obj (.text:_fputwc)
                  c4020be0    00000020                    : fsetpos.obj (.text:_fsetpos)
                  c4020c00    00000020                    : iostream.obj (.text:_imbue__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFRCQ2_3std6locale_v)
                  c4020c20    00000020                    : wiostrea.obj (.text:_imbue__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFRCQ2_3std6locale_v)
                  c4020c40    00000020                    : wiostrea.obj (.text:_is__Q2_3std17ctype__tm__2_w__SCFsw)
                  c4020c60    00000020                    : wiostrea.obj (.text:_narrow__Q2_3std17ctype__tm__2_w__SCFwc)
                  c4020c80    00000020                    : iostream.obj (.text:_overflow__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_Z2Z8int_type_Q2_Z2Z8int_type)
                  c4020ca0    00000020                    : wiostrea.obj (.text:_overflow__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_Z2Z8int_type_Q2_Z2Z8int_type)
                  c4020cc0    00000020                    : iostream.obj (.text:_pbackfail__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFQ2_Z2Z8int_type_Q2_Z2Z8int_type)
                  c4020ce0    00000020                    : wiostrea.obj (.text:_pbackfail__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFQ2_Z2Z8int_type_Q2_Z2Z8int_type)
                  c4020d00    00000020                    : remove.obj (.text:_remove)
                  c4020d20    00000020                    : iostream.obj (.text:_setbuf__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFPZ1Zi_PQ2_3std29basic_streambuf__tm__7_Z1ZZ2Z)
                  c4020d40    00000020                    : wiostrea.obj (.text:_setbuf__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFPZ1Zi_PQ2_3std29basic_streambuf__tm__7_Z1ZZ2Z)
                  c4020d60    00000020                    : iostream.obj (.text:_showmanyc__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_i)
                  c4020d80    00000020                    : wiostrea.obj (.text:_showmanyc__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_i)
                  c4020da0    00000020                    : iostream.obj (.text:_sync__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_i)
                  c4020dc0    00000020                    : wiostrea.obj (.text:_sync__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_i)
                  c4020de0    00000020                    : tolower.obj (.text:_tolower)
                  c4020e00    00000020                    : toupper.obj (.text:_toupper)
                  c4020e20    00000020                    : iostream.obj (.text:_underflow__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_cFv_Q2_Z2Z8int_type)
                  c4020e40    00000020                    : wiostrea.obj (.text:_underflow__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_wFv_Q2_Z2Z8int_type)
                  c4020e60    00000020                    : multibyte.obj (.text:_wctomb)
                  c4020e80    00000020                    : eh_util.obj (.text:_what__Q2_3std9exceptionCFv)
                  c4020ea0    00000020                    : ios.obj (.text:_what__Q2_3std9exceptionCFv)
                  c4020ec0    00000020                    : newhandler.obj (.text:_what__Q2_3std9exceptionCFv)
                  c4020ee0    00000020                    : string.obj (.text:_what__Q2_3std9exceptionCFv)
                  c4020f00    00000020                    : wiostrea.obj (.text:_widen__Q2_3std17ctype__tm__2_w__SCFc)
                  c4020f20    00000020     bios.a674 : malloc.o674 ($Tramp$S$$_free)
                  c4020f40    00000020               : malloc.o674 ($Tramp$S$$_calloc)
                  c4020f60    00000020               : malloc.o674 ($Tramp$S$$_malloc)
                  c4020f80    00000020               : lck.o674 ($Tramp$S$$_LCK_post)
                  c4020fa0    00000020               : lck.o674 ($Tramp$S$$_LCK_pend)
                  c4020fc0    00000020               : sys_abor.o674 ($Tramp$S$$_SYS_abort)
.cinit     0    c4020fe0    000054fc
                  c4020fe0    00001259     rts6740_eh.lib : wlocale.obj (.cinit)
                  c4022239    00000007     --HOLE-- [fill = 0]
                  c4022240    00000bd9                    : xlocale.obj (.cinit)
                  c4022e19    00000007     --HOLE-- [fill = 0]
                  c4022e20    00000b59                    : locale.obj (.cinit)
                  c4023979    00000007     --HOLE-- [fill = 0]
                  c4023980    0000079c                    : iostream.obj (.cinit)
                  c402411c    00000004     --HOLE-- [fill = 0]
                  c4024120    00000744                    : wiostrea.obj (.cinit)
                  c4024864    00000004     --HOLE-- [fill = 0]
                  c4024868    0000062c     IPT_Firmwarecfg.obj (.cinit)
                  c4024e94    00000004     --HOLE-- [fill = 0]
                  c4024e98    000003dc     rts6740_eh.lib : locale0.obj (.cinit)
                  c4025274    00000004     --HOLE-- [fill = 0]
                  c4025278    00000315                    : ios.obj (.cinit)
                  c402558d    00000003     --HOLE-- [fill = 0]
                  c4025590    0000026c     bios.a674 : biosdata.o674 (.cinit)
                  c40257fc    00000004     --HOLE-- [fill = 0]
                  c4025800    00000201     rts6740_eh.lib : string.obj (.cinit)
                  c4025a01    00000007     --HOLE-- [fill = 0]
                  c4025a08    000001a4     bios.a674 : knl.o674 (.cinit)
                  c4025bac    00000004     --HOLE-- [fill = 0]
                  c4025bb0    00000129     rts6740_eh.lib : typeinfo_.obj (.cinit)
                  c4025cd9    00000007     --HOLE-- [fill = 0]
                  c4025ce0    000000b0     bios.a674 : swi.o674 (.cinit)
                  c4025d90    00000089     rts6740_eh.lib : eh_util.obj (.cinit)
                  c4025e19    00000007     --HOLE-- [fill = 0]
                  c4025e20    00000080     bios.a674 : tsk.o674 (.cinit)
                  c4025ea0    00000068     rtdx64xplus.lib : rtdx_mon.o64P (.cinit)
                  c4025f08    00000061     rts6740_eh.lib : newhandler.obj (.cinit)
                  c4025f69    00000007     --HOLE-- [fill = 0]
                  c4025f70    00000060     bios.a674 : tsk_stup.o674 (.cinit)
                  c4025fd0    0000005c     lnkrtdx.a674 : rtdx.o674 (.cinit)
                  c402602c    00000004     --HOLE-- [fill = 0]
                  c4026030    0000005c     rts6740_eh.lib : defs.obj (.cinit)
                  c402608c    00000004     --HOLE-- [fill = 0]
                  c4026090    0000005c                    : lowlev.obj (.cinit)
                  c40260ec    00000004     --HOLE-- [fill = 0]
                  c40260f0    0000004c     bios.a674 : rta.o674 (.cinit)
                  c402613c    00000004     --HOLE-- [fill = 0]
                  c4026140    0000004c     rtdx64xplus.lib : buffer1.o64P (.cinit)
                  c402618c    00000004     --HOLE-- [fill = 0]
                  c4026190    0000004c     rts6740_eh.lib : vars.obj (.cinit)
                  c40261dc    00000004     --HOLE-- [fill = 0]
                  c40261e0    0000003c     bios.a674 : exc.o674 (.cinit)
                  c402621c    00000004     --HOLE-- [fill = 0]
                  c4026220    0000003c     main.obj (.cinit)
                  c402625c    00000004     --HOLE-- [fill = 0]
                  c4026260    00000039     rts6740_eh.lib : setlocale.obj (.cinit)
                  c4026299    00000007     --HOLE-- [fill = 0]
                  c40262a0    00000034     bios.a674 : hwi.o674 (.cinit)
                  c40262d4    00000004     --HOLE-- [fill = 0]
                  c40262d8    0000002c               : utl_putc.o674 (.cinit)
                  c4026304    00000004     --HOLE-- [fill = 0]
                  c4026308    0000002c     rts6740_eh.lib : exit.obj (.cinit)
                  c4026334    00000004     --HOLE-- [fill = 0]
                  c4026338    0000002c                    : throw_edg.obj (.cinit)
                  c4026364    00000004     --HOLE-- [fill = 0]
                  c4026368    00000024     bios.a674 : obj_init.o674 (.cinit)
                  c402638c    00000004     --HOLE-- [fill = 0]
                  c4026390    00000020     rts6740_eh.lib : tmzone.obj (.cinit)
                  c40263b0    0000001c     bios.a674 : exc_asm.o674 (.cinit)
                  c40263cc    00000004     --HOLE-- [fill = 0]
                  c40263d0    0000001c               : sys.o674 (.cinit)
                  c40263ec    00000004     --HOLE-- [fill = 0]
                  c40263f0    0000001c     rts6740_eh.lib : _lock.obj (.cinit)
                  c402640c    00000004     --HOLE-- [fill = 0]
                  c4026410    0000001c                    : atexit.obj (.cinit)
                  c402642c    00000004     --HOLE-- [fill = 0]
                  c4026430    00000018     bios.a674 : knl_tick.o674 (.cinit)
                  c4026448    00000014     rts6740_eh.lib : array_new.obj (.cinit)
                  c402645c    00000004     --HOLE-- [fill = 0]
                  c4026460    00000014                    : new_.obj (.cinit)
                  c4026474    00000004     --HOLE-- [fill = 0]
                  c4026478    0000000c     bios.a674 : idl_busy.o674 (.cinit)
                  c4026484    00000004     --HOLE-- [fill = 0]
                  c4026488    0000000c               : knl_swit.o674 (.cinit)
                  c4026494    00000004     --HOLE-- [fill = 0]
                  c4026498    0000000c     rts6740_eh.lib : errno.obj (.cinit)
                  c40264a4    00000004     --HOLE-- [fill = 0]
                  c40264a8    0000000c                    : fopen.obj (.cinit)
                  c40264b4    00000004     --HOLE-- [fill = 0]
                  c40264b8    0000000c                    : sinit.obj (.cinit)
                  c40264c4    00000004     --HOLE-- [fill = 0]
                  c40264c8    0000000c                    : vec_newdel.obj (.cinit)
                  c40264d4    00000004     --HOLE-- [fill = 0]
                  c40264d8    00000004     (.pad.cinit) [fill = 0]
.args      0    c40264dc    00000004
                  c40264dc    00000004     --HOLE-- [fill = 0]
.bios      0    c40264e0    000042e0
                  c40264e0    000005c0     lnkrtdx.a674 : rtdx.o674 (.bios)
                  c4026aa0    00000580     bios.a674 : exc.o674 (.bios)
                  c4027020    000004e0               : hwi_disp_asm.o674 (.bios)
                  c4027500    000004c0               : swi.o674 (.bios)
                  c40279c0    00000380               : prd.o674 (.bios)
                  c4027d40    00000280               : malloc.o674 (.bios)
                  c4027fc0    00000280               : rta.o674 (.bios)
                  c4028240    00000240               : knl_run.o674 (.bios)
                  c4028480    00000200               : mem_allo.o674 (.bios:.near)
                  c4028680    00000200               : knl_tick.o674 (.bios)
                  c4028880    000001e0               : mem_free.o674 (.bios:.near)
                  c4028a60    000001e0               : exc_asm.o674 (.bios)
                  c4028c40    000001e0               : pip.o674 (.bios)
                  c4028e20    000001e0               : sem_pend.o674 (.bios)
                  c4029000    000001a0               : sem_dopo.o674 (.bios)
                  c40291a0    000001a0               : tsk_setu.o674 (.bios)
                  c4029340    000001a0     bios6748.a674 : clk.o674 (.bios)
                  c40294e0    00000180     bios.a674 : knl_swit.o674 (.bios)
                  c4029660    00000140               : autoinit.o674 (.bios)
                  c40297a0    00000140               : tsk_exit.o674 (.bios)
                  c40298e0    00000140     bios6748.a674 : bcache_init.o674 (.bios)
                  c4029a20    00000120     bios.a674 : gbl_cacheinit64P.o674 (.bios)
                  c4029b40    00000120               : knl_chec.o674 (.bios)
                  c4029c60    00000120               : tsk_stup.o674 (.bios)
                  c4029d80    000000e0               : sem_post_asm.o674 (.bios)
                  c4029e60    000000c0               : knl_exit.o674 (.bios)
                  c4029f20    000000a0               : sem_post.o674 (.bios)
                  c4029fc0    000000a0               : sys_exit.o674 (.bios)
                  c402a060    00000080               : knl_ipos.o674 (.bios)
                  c402a0e0    00000080               : knl_post.o674 (.bios)
                  c402a160    00000080               : lck.o674 (.bios)
                  c402a1e0    00000080               : log.o674 (.bios)
                  c402a260    00000080     bios6748.a674 : idl_cal.o674 (.bios)
                  c402a2e0    00000060     bios.a674 : sys_erro.o674 (.bios:.near)
                  c402a340    00000060               : fxn.o674 (.bios)
                  c402a3a0    00000060               : hwi_c.o674 (.bios)
                  c402a400    00000060               : idl_busy.o674 (.bios)
                  c402a460    00000060               : sem_pend_counting.o674 (.bios)
                  c402a4c0    00000060               : sts.o674 (.bios)
                  c402a520    00000060               : sys_abor.o674 (.bios)
                  c402a580    00000060     bios6748.a674 : clk_meas.o674 (.bios)
                  c402a5e0    00000040     bios.a674 : idl_stub.o674 (.bios)
                  c402a620    00000040               : rta_andn.o674 (.bios)
                  c402a660    00000040               : utl_doab.o674 (.bios)
                  c402a6a0    00000040               : utl_putc.o674 (.bios)
                  c402a6e0    00000020               : fxn_c.o674 (.bios)
                  c402a700    00000020               : gbl_vers.o674 (.bios)
                  c402a720    00000020               : idl.o674 (.bios)
                  c402a740    00000020               : sts_set.o674 (.bios)
                  c402a760    00000020               : utl_doer.o674 (.bios)
                  c402a780    00000020               : utl_halt.o674 (.bios)
                  c402a7a0    00000020     bios6748.a674 : clk_gethtime.o674 (.bios)
.far       0    c402a7c0    00003ed4     UNINITIALIZED
                  c402a7c0    00000e0c     rts6740_eh.lib : wlocale.obj (.far)
                  c402b5cc    00000004     bios6748.a674 : clk_data.o674 (.far)
                  c402b5d0    00000924     rts6740_eh.lib : xlocale.obj (.far)
                  c402bef4    00000004                    : errno.obj (.far)
                  c402bef8    000008b4                    : locale.obj (.far)
                  c402c7ac    00000004                    : fopen.obj (.far)
                  c402c7b0    00000788                    : iostream.obj (.far)
                  c402cf38    00000730                    : wiostrea.obj (.far)
                  c402d668    000002d8                    : locale0.obj (.far)
                  c402d940    00000268                    : ios.obj (.far)
                  c402dba8    00000194                    : defs.obj (.far)
                  c402dd3c    00000004                    : sinit.obj (.far)
                  c402dd40    00000188                    : atexit.obj (.far)
                  c402dec8    00000184                    : string.obj (.far)
                  c402e04c    00000004     --HOLE--
                  c402e050    000000ec                    : typeinfo_.obj (.far)
                  c402e13c    00000004     --HOLE--
                  c402e140    000000d8     bios.a674 : knl.o674 (.far)
                  c402e218    000000d0     rts6740_eh.lib : trgdrv.obj (.far)
                  c402e2e8    000000cc                    : lowlev.obj (.far)
                  c402e3b4    00000004     --HOLE--
                  c402e3b8    00000064                    : eh_util.obj (.far)
                  c402e41c    0000005c     bios.a674 : tsk.o674 (.far)
                  c402e478    00000054               : obj_init.o674 (.far)
                  c402e4cc    00000050               : tsk_stup.o674 (.far)
                  c402e51c    00000004     --HOLE--
                  c402e520    0000004c     rts6740_eh.lib : newhandler.obj (.far)
                  c402e56c    00000034                    : setlocale.obj (.far)
                  c402e5a0    00000020     bios.a674 : sys.o674 (.far)
                  c402e5c0    00000020     main.obj (.far)
                  c402e5e0    00000018     rtdx64xplus.lib : rtdx_mon.o64P (.far)
                  c402e5f8    00000018     rts6740_eh.lib : tmzone.obj (.far)
                  c402e610    00000010     bios.a674 : exc.o674 (.far)
                  c402e620    00000010               : knl_tick.o674 (.far)
                  c402e630    00000010     rts6740_eh.lib : throw_edg.obj (.far)
                  c402e640    0000000c     bios.a674 : utl_putc.o674 (.far)
                  c402e64c    00000004     --HOLE--
                  c402e650    0000000c     rts6740_eh.lib : array_new.obj (.far)
                  c402e65c    0000000c                    : exit.obj (.far)
                  c402e668    0000000c                    : new_.obj (.far)
                  c402e674    0000000c                    : vars.obj (.far)
                  c402e680    0000000a                    : _tvaltostr.obj (.far)
                  c402e68a    00000002     --HOLE--
                  c402e68c    00000008                    : _lock.obj (.far)
.mem       0    c402e694    00000004     UNINITIALIZED
                  c402e694    00000004     IPT_Firmwarecfg.obj (.mem)
.TSK_idle$stk
*          0    c402e698    00002710     UNINITIALIZED
                  c402e698    00002710     IPT_Firmwarecfg.obj (.TSK_idle$stk)
.const     0    c4030da8    00002534
                  c4030da8    000003e1     rts6740_eh.lib : wlocale.obj (.const:.string)
                  c4031189    000002cb                    : xlocale.obj (.const:.string)
                  c4031454    00000004     bios.a674 : mem_allo.o674 (.const:.string)
                  c4031458    00000202     rts6740_eh.lib : xlocinfo.obj (.const:__Ctyptab__3std)
                  c403165a    00000002                    : fputs.obj (.const:.string)
                  c403165c    000001ea                    : wlocale.obj (.const)
                  c4031846    00000193     bios.a674 : exc.o674 (.const:.string)
                  c40319d9    00000188     rts6740_eh.lib : wiostrea.obj (.const:.string)
                  c4031b61    00000178                    : iostream.obj (.const:.string)
                  c4031cd9    00000003     --HOLE-- [fill = 0]
                  c4031cdc    0000015a                    : xlocale.obj (.const)
                  c4031e36    00000148                    : locale.obj (.const:.string)
                  c4031f7e    00000002     --HOLE-- [fill = 0]
                  c4031f80    0000012d                    : locale.obj (.const)
                  c40320ad    00000003     --HOLE-- [fill = 0]
                  c40320b0    00000101                    : ctype.obj (.const:__ctypes_)
                  c40321b1    00000003     --HOLE-- [fill = 0]
                  c40321b4    000000e9                    : wiostrea.obj (.const)
                  c403229d    00000003     --HOLE-- [fill = 0]
                  c40322a0    000000e8                    : iostream.obj (.const)
                  c4032388    0000009f                    : ios.obj (.const:.string)
                  c4032427    00000099                    : strftime.obj (.const:.string)
                  c40324c0    00000088                    : ios.obj (.const)
                  c4032548    00000080                    : iostream.obj (.const:___vtbl__Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_c)
                  c40325c8    00000080                    : wiostrea.obj (.const:___vtbl__Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_w)
                  c4032648    00000080                    : iostream.obj (.const:___vtbl__Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_c)
                  c40326c8    00000080                    : wiostrea.obj (.const:___vtbl__Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_w)
                  c4032748    00000074                    : string.obj (.const:.string)
                  c40327bc    00000004     bios.a674 : mem_free.o674 (.const:.string)
                  c40327c0    00000070     rts6740_eh.lib : wiostrea.obj (.const:___vtbl__Q2_3std14ctype__tm__2_w)
                  c4032830    00000058                    : xlocale.obj (.const:___vtbl__Q2_3std16_Mpunct__tm__2_c)
                  c4032888    00000058                    : wlocale.obj (.const:___vtbl__Q2_3std16_Mpunct__tm__2_w)
                  c40328e0    00000054                    : string.obj (.const)
                  c4032934    00000001     bios.a674 : tsk.o674 (.const:.string)
                  c4032935    00000003     --HOLE-- [fill = 0]
                  c4032938    00000050     main.obj (.const:___vtbl__Q2_3std14ctype__tm__2_c)
                  c4032988    00000050     rts6740_eh.lib : iostream.obj (.const:___vtbl__Q2_3std14ctype__tm__2_c)
                  c40329d8    00000050                    : typeinfo_.obj (.const)
                  c4032a28    0000004e     bios.a674 : tsk_stup.o674 (.const:.string)
                  c4032a76    00000002     --HOLE-- [fill = 0]
                  c4032a78    00000048     rts6740_eh.lib : iostream.obj (.const:___vtbl__Q2_3std18codecvt__tm__4_cci)
                  c4032ac0    00000048                    : wiostrea.obj (.const:___vtbl__Q2_3std18codecvt__tm__4_wci)
                  c4032b08    00000045                    : typeinfo_.obj (.const:.string)
                  c4032b4d    0000003d                    : throw_edg.obj (.const:.string)
                  c4032b8a    00000002     --HOLE-- [fill = 0]
                  c4032b8c    00000038                    : locale0.obj (.const)
                  c4032bc4    00000030                    : eh_util.obj (.const:.string)
                  c4032bf4    0000002d                    : newhandler.obj (.const:.string)
                  c4032c21    0000002c                    : locale0.obj (.const:.string)
                  c4032c4d    00000003     --HOLE-- [fill = 0]
                  c4032c50    00000028                    : iostream.obj (.const:___vtbl__Q2_3std12codecvt_base)
                  c4032c78    00000028                    : wiostrea.obj (.const:___vtbl__Q2_3std12codecvt_base)
                  c4032ca0    00000028                    : array_new.obj (.const)
                  c4032cc8    00000028                    : eh_util.obj (.const)
                  c4032cf0    00000028                    : new_.obj (.const)
                  c4032d18    00000028                    : newhandler.obj (.const)
                  c4032d40    00000024     main.obj (.const:.string)
                  c4032d64    00000023     bios.a674 : utl_doab.o674 (.const:.string)
                  c4032d87    00000023     rts6740_eh.lib : _printfi.obj (.const:.string)
                  c4032daa    00000022     bios.a674 : utl_doer.o674 (.const:.string)
                  c4032dcc    0000001e     rts6740_eh.lib : array_new.obj (.const:.string)
                  c4032dea    0000001e                    : new_.obj (.const:.string)
                  c4032e08    00000018                    : string.obj (.const:___vtbl__Q2_3std11logic_error)
                  c4032e20    00000018                    : string.obj (.const:___vtbl__Q2_3std12length_error)
                  c4032e38    00000018                    : string.obj (.const:___vtbl__Q2_3std12out_of_range)
                  c4032e50    00000018                    : eh_util.obj (.const:___vtbl__Q2_3std13bad_exception)
                  c4032e68    00000018                    : ios.obj (.const:___vtbl__Q2_3std13runtime_error)
                  c4032e80    00000018                    : newhandler.obj (.const:___vtbl__Q2_3std9bad_alloc)
                  c4032e98    00000018                    : eh_util.obj (.const:___vtbl__Q2_3std9exception)
                  c4032eb0    00000018                    : ios.obj (.const:___vtbl__Q2_3std9exception)
                  c4032ec8    00000018                    : newhandler.obj (.const:___vtbl__Q2_3std9exception)
                  c4032ee0    00000018                    : string.obj (.const:___vtbl__Q2_3std9exception)
                  c4032ef8    00000018                    : ios.obj (.const:___vtbl__Q3_3std8ios_base7failure)
                  c4032f10    00000010                    : iostream.obj (.const:___CPR130____vtbl__57Q2_3std48basic_ios__tm__31_cQ2_3std20char_traits__tm__2_c__Q2_3std52basic_istream__tm__J34J)
                  c4032f20    00000010                    : iostream.obj (.const:___CPR130____vtbl__57Q2_3std48basic_ios__tm__31_cQ2_3std20char_traits__tm__2_c__Q2_3std52basic_ostream__tm__J34J)
                  c4032f30    00000010                    : wiostrea.obj (.const:___CPR130____vtbl__57Q2_3std48basic_ios__tm__31_wQ2_3std20char_traits__tm__2_w__Q2_3std52basic_istream__tm__J34J)
                  c4032f40    00000010                    : wiostrea.obj (.const:___CPR130____vtbl__57Q2_3std48basic_ios__tm__31_wQ2_3std20char_traits__tm__2_w__Q2_3std52basic_ostream__tm__J34J)
                  c4032f50    00000010     main.obj (.const:___vtbl__Q2_3std10ctype_base)
                  c4032f60    00000010     rts6740_eh.lib : iostream.obj (.const:___vtbl__Q2_3std10ctype_base)
                  c4032f70    00000010                    : wiostrea.obj (.const:___vtbl__Q2_3std10ctype_base)
                  c4032f80    00000010                    : iostream.obj (.const:___vtbl__Q2_3std48basic_ios__tm__31_cQ2_3std20char_traits__tm__2_c)
                  c4032f90    00000010                    : wiostrea.obj (.const:___vtbl__Q2_3std48basic_ios__tm__31_wQ2_3std20char_traits__tm__2_w)
                  c4032fa0    00000010                    : iostream.obj (.const:___vtbl__Q2_3std52basic_istream__tm__31_cQ2_3std20char_traits__tm__2_c)
                  c4032fb0    00000010                    : wiostrea.obj (.const:___vtbl__Q2_3std52basic_istream__tm__31_wQ2_3std20char_traits__tm__2_w)
                  c4032fc0    00000010                    : iostream.obj (.const:___vtbl__Q2_3std52basic_ostream__tm__31_cQ2_3std20char_traits__tm__2_c)
                  c4032fd0    00000010                    : wiostrea.obj (.const:___vtbl__Q2_3std52basic_ostream__tm__31_wQ2_3std20char_traits__tm__2_w)
                  c4032fe0    00000010                    : ios.obj (.const:___vtbl__Q2_3std8ios_base)
                  c4032ff0    00000010                    : typeinfo_.obj (.const:___vtbl__Q2_3std9type_info)
                  c4033000    00000010     main.obj (.const:___vtbl__Q3_3std6locale5facet)
                  c4033010    00000010     rts6740_eh.lib : iostream.obj (.const:___vtbl__Q3_3std6locale5facet)
                  c4033020    00000010                    : locale0.obj (.const:___vtbl__Q3_3std6locale5facet)
                  c4033030    00000010                    : wiostrea.obj (.const:___vtbl__Q3_3std6locale5facet)
                  c4033040    00000010                    : locale0.obj (.const:___vtbl__Q3_3std6locale7_Locimp)
                  c4033050    00000008                    : array_new.obj (.const:_$P$T0)
                  c4033058    00000008                    : eh_util.obj (.const:_$P$T0)
                  c4033060    00000008                    : ios.obj (.const:_$P$T0)
                  c4033068    00000008                    : iostream.obj (.const:_$P$T0)
                  c4033070    00000008                    : locale.obj (.const:_$P$T0)
                  c4033078    00000008                    : locale0.obj (.const:_$P$T0)
                  c4033080    00000008                    : new_.obj (.const:_$P$T0)
                  c4033088    00000008                    : newhandler.obj (.const:_$P$T0)
                  c4033090    00000008                    : string.obj (.const:_$P$T0)
                  c4033098    00000008                    : typeinfo_.obj (.const:_$P$T0)
                  c40330a0    00000008                    : wiostrea.obj (.const:_$P$T0)
                  c40330a8    00000008                    : wlocale.obj (.const:_$P$T0)
                  c40330b0    00000008                    : xlocale.obj (.const:_$P$T0)
                  c40330b8    00000008                    : wlocale.obj (.const:_$P$T10)
                  c40330c0    00000008                    : xlocale.obj (.const:_$P$T10)
                  c40330c8    00000008                    : wlocale.obj (.const:_$P$T11)
                  c40330d0    00000008                    : xlocale.obj (.const:_$P$T11)
                  c40330d8    00000008                    : wlocale.obj (.const:_$P$T12)
                  c40330e0    00000008                    : xlocale.obj (.const:_$P$T12)
                  c40330e8    00000008                    : wlocale.obj (.const:_$P$T13)
                  c40330f0    00000008                    : xlocale.obj (.const:_$P$T13)
                  c40330f8    00000008                    : wlocale.obj (.const:_$P$T14)
                  c4033100    00000008                    : wlocale.obj (.const:_$P$T15)
                  c4033108    00000008                    : wlocale.obj (.const:_$P$T16)
                  c4033110    00000008                    : wlocale.obj (.const:_$P$T17)
                  c4033118    00000008                    : wlocale.obj (.const:_$P$T18)
                  c4033120    00000008                    : ios.obj (.const:_$P$T1)
                  c4033128    00000008                    : iostream.obj (.const:_$P$T1)
                  c4033130    00000008                    : locale.obj (.const:_$P$T1)
                  c4033138    00000008                    : string.obj (.const:_$P$T1)
                  c4033140    00000008                    : typeinfo_.obj (.const:_$P$T1)
                  c4033148    00000008                    : wiostrea.obj (.const:_$P$T1)
                  c4033150    00000008                    : wlocale.obj (.const:_$P$T1)
                  c4033158    00000008                    : xlocale.obj (.const:_$P$T1)
                  c4033160    00000008                    : ios.obj (.const:_$P$T2)
                  c4033168    00000008                    : iostream.obj (.const:_$P$T2)
                  c4033170    00000008                    : locale.obj (.const:_$P$T2)
                  c4033178    00000008                    : string.obj (.const:_$P$T2)
                  c4033180    00000008                    : wiostrea.obj (.const:_$P$T2)
                  c4033188    00000008                    : wlocale.obj (.const:_$P$T2)
                  c4033190    00000008                    : xlocale.obj (.const:_$P$T2)
                  c4033198    00000008                    : iostream.obj (.const:_$P$T3)
                  c40331a0    00000008                    : locale.obj (.const:_$P$T3)
                  c40331a8    00000008                    : wiostrea.obj (.const:_$P$T3)
                  c40331b0    00000008                    : wlocale.obj (.const:_$P$T3)
                  c40331b8    00000008                    : xlocale.obj (.const:_$P$T3)
                  c40331c0    00000008                    : iostream.obj (.const:_$P$T4)
                  c40331c8    00000008                    : locale.obj (.const:_$P$T4)
                  c40331d0    00000008                    : wiostrea.obj (.const:_$P$T4)
                  c40331d8    00000008                    : wlocale.obj (.const:_$P$T4)
                  c40331e0    00000008                    : xlocale.obj (.const:_$P$T4)
                  c40331e8    00000008                    : iostream.obj (.const:_$P$T5)
                  c40331f0    00000008                    : locale.obj (.const:_$P$T5)
                  c40331f8    00000008                    : wiostrea.obj (.const:_$P$T5)
                  c4033200    00000008                    : wlocale.obj (.const:_$P$T5)
                  c4033208    00000008                    : xlocale.obj (.const:_$P$T5)
                  c4033210    00000008                    : iostream.obj (.const:_$P$T6)
                  c4033218    00000008                    : locale.obj (.const:_$P$T6)
                  c4033220    00000008                    : wiostrea.obj (.const:_$P$T6)
                  c4033228    00000008                    : wlocale.obj (.const:_$P$T6)
                  c4033230    00000008                    : xlocale.obj (.const:_$P$T6)
                  c4033238    00000008                    : iostream.obj (.const:_$P$T7)
                  c4033240    00000008                    : locale.obj (.const:_$P$T7)
                  c4033248    00000008                    : wiostrea.obj (.const:_$P$T7)
                  c4033250    00000008                    : wlocale.obj (.const:_$P$T7)
                  c4033258    00000008                    : xlocale.obj (.const:_$P$T7)
                  c4033260    00000008                    : locale.obj (.const:_$P$T8)
                  c4033268    00000008                    : wlocale.obj (.const:_$P$T8)
                  c4033270    00000008                    : xlocale.obj (.const:_$P$T8)
                  c4033278    00000008                    : wlocale.obj (.const:_$P$T9)
                  c4033280    00000008                    : xlocale.obj (.const:_$P$T9)
                  c4033288    00000008                    : divd.obj (.const:_initial_approx$1)
                  c4033290    00000008     main.obj (.const)
                  c4033298    00000005     rts6740_eh.lib : setlocale.obj (.const:.string)
                  c403329d    00000003     --HOLE-- [fill = 0]
                  c40332a0    00000004                    : wiostrea.obj (.const:_$P$T286$43)
                  c40332a4    00000004     --HOLE-- [fill = 0]
                  c40332a8    00000004                    : iostream.obj (.const:_$P$T294$43)
                  c40332ac    00000004     --HOLE-- [fill = 0]
                  c40332b0    00000004                    : wiostrea.obj (.const:_$P$T295$45)
                  c40332b4    00000004     --HOLE-- [fill = 0]
                  c40332b8    00000004                    : iostream.obj (.const:_$P$T303$45)
                  c40332bc    00000004     --HOLE-- [fill = 0]
                  c40332c0    00000004                    : wiostrea.obj (.const:_$P$T309$49)
                  c40332c4    00000004     --HOLE-- [fill = 0]
                  c40332c8    00000004                    : iostream.obj (.const:_$P$T317$49)
                  c40332cc    00000004     --HOLE-- [fill = 0]
                  c40332d0    00000004                    : wiostrea.obj (.const:_$P$T318$51)
                  c40332d4    00000004     --HOLE-- [fill = 0]
                  c40332d8    00000004                    : iostream.obj (.const:_$P$T326$51)
.printf    0    c40332dc    0000003f     COPY SECTION
                  c40332dc    0000003f     IPT_Firmwarecfg.obj (.printf)
.rtdx_text
*          0    c40332e0    00000fc0
                  c40332e0    000002a0     rtdx64xplus.lib : rtdx_mon.o64P (.rtdx_text:_HSRTDX_rec)
                  c4033580    00000260                     : buffer1.o64P (.rtdx_text:_RTDX_Buffer_WriteCB)
                  c40337e0    00000260                     : buffer1.o64P (.rtdx_text:_RTDX_write_next)
                  c4033a40    000001a0                     : rtdx_mon.o64P (.rtdx_text:_HSRTDX_xmt)
                  c4033be0    00000160                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Send_To_Host)
                  c4033d40    000000e0                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Mon_Queue)
                  c4033e20    000000e0                     : buffer1.o64P (.rtdx_text:_claim)
                  c4033f00    000000a0                     : rtdx_mon.o64P (.rtdx_text:_RTDX_GetH2THeader)
                  c4033fa0    000000a0                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Poll)
                  c4034040    00000080                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Final_RT_Monitor)
                  c40340c0    00000060                     : buffer1.o64P (.rtdx_text:_RTDX_Buffer_Initialize)
                  c4034120    00000060                     : rtdx_mon.o64P (.rtdx_text:_RTDX_Init_RT_Monitor)
                  c4034180    00000040                     : buffer2.o64P (.rtdx_text:_RTDX_Buffer_ReadCB)
                  c40341c0    00000040                     : buffer1.o64P (.rtdx_text:_RTDX_Buffer_Size)
                  c4034200    00000040                     : memfill.o64P (.rtdx_text:_RTDX_memfill)
                  c4034240    00000020                     : buffer2.o64P (.rtdx_text:_RTDX_Buffer_Read)
                  c4034260    00000020                     : buffer1.o64P (.rtdx_text:_RTDX_Buffer_Write)
                  c4034280    00000020                     : intr_tgt.o64P (.rtdx_text)
.sysinit   0    c40342a0    00000560
                  c40342a0    00000380     IPT_Firmwarecfg.obj (.sysinit)
                  c4034620    000000c0     bios.a674 : boot.o674 (.sysinit)
                  c40346e0    000000c0               : mem_init.o674 (.sysinit)
                  c40347a0    00000060               : tsk_init.o674 (.sysinit)
.rtdx_data
*          0    c4034800    000004f4     UNINITIALIZED
                  c4034800    00000080     --HOLE--
                  c4034880    00000410     IPT_Firmwarecfg.obj (.rtdx_data)
                  c4034c90    00000044     rtdx64xplus.lib : rtdx_mon.o64P (.rtdx_data)
                  c4034cd4    00000020                     : buffer1.o64P (.rtdx_data)
.trace     0    c4034cf4    00000200
                  c4034cf4    00000200     --HOLE-- [fill = 00000000]
.hst0      0    c4034ef4    00000100     UNINITIALIZED
                  c4034ef4    00000100     IPT_Firmwarecfg.obj (.hst0)
.trcdata   0    c4034ff4    0000000c
                  c4034ff4    0000000c     bios.a674 : trc.o674 (.trcdata)
.LOG_system$buf
*          0    c4035000    00000400     UNINITIALIZED
                  c4035000    00000400     IPT_Firmwarecfg.obj (.LOG_system$buf)
.stack     0    c4035400    00000400     UNINITIALIZED
                  c4035400    00000400     --HOLE--
.trace$buf
*          0    c4035800    00000400     UNINITIALIZED
                  c4035800    00000400     IPT_Firmwarecfg.obj (.trace$buf)
.bss       0    c4035c00    00000394     UNINITIALIZED
                  c4035c00    00000100     bios.a674 : hwi_disp_asm.o674 (.bss)
                  c4035d00    000000cc               : biosdata.o674 (.bss)
                  c4035dcc    0000009c               : swi.o674 (.bss)
                  c4035e68    00000048               : knl.o674 (.bss)
                  c4035eb0    00000028     IPT_Firmwarecfg.obj (.bss)
                  c4035ed8    00000020     bios.a674 : exc_asm.o674 (.bss)
                  c4035ef8    00000018               : hwi.o674 (.bss)
                  c4035f10    00000018     lnkrtdx.a674 : rtdx.o674 (.bss)
                  c4035f28    00000010     bios.a674 : exc.o674 (.bss)
                  c4035f38    00000010     rtdx64xplus.lib : buffer1.o64P (.bss)
                  c4035f48    00000010                     : rtdx_mon.o64P (.bss)
                  c4035f58    00000010     rts6740_eh.lib : vars.obj (.bss)
                  c4035f68    0000000c     bios.a674 : tsk.o674 (.bss)
                  c4035f74    00000008               : clk_data.o674 (.bss)
                  c4035f7c    00000008               : sys.o674 (.bss)
                  c4035f84    00000004               : clk_data2.o674 (.bss)
                  c4035f88    00000004               : idl_busy.o674 (.bss)
                  c4035f8c    00000004               : mem_asm.o674 (.bss)
                  c4035f90    00000004     rts6740_eh.lib : vec_newdel.obj (.bss)
.tsk       0    c4035f94    00000060     UNINITIALIZED
                  c4035f94    00000060     IPT_Firmwarecfg.obj (.tsk)
.hwi_vec   0    c4036000    00000200
                  c4036000    00000200     IPT_Firmwarecfg.obj (.hwi_vec)
.cio       0    c4036200    00000120     UNINITIALIZED
                  c4036200    00000120     rts6740_eh.lib : trgmsg.obj (.cio)
.pip       0    c4036320    000000c8     UNINITIALIZED
                  c4036320    000000c8     IPT_Firmwarecfg.obj (.pip)
.gblinit   0    c40363e8    0000004c
                  c40363e8    0000004c     IPT_Firmwarecfg.obj (.gblinit)
.hst       0    c4036434    0000003c     UNINITIALIZED
                  c4036434    0000003c     IPT_Firmwarecfg.obj (.hst)
.pinit     0    c4036470    00000028
                  c4036470    00000004     main.obj (.pinit)
                  c4036474    00000004     rtdx64xplus.lib : buffer1.o64P (.pinit)
                  c4036478    00000004                     : rtdx_mon.o64P (.pinit)
                  c403647c    00000004     rts6740_eh.lib : iostream.obj (.pinit)
                  c4036480    00000004                    : locale.obj (.pinit)
                  c4036484    00000004                    : locale0.obj (.pinit)
                  c4036488    00000004                    : wiostrea.obj (.pinit)
                  c403648c    00000004                    : wlocale.obj (.pinit)
                  c4036490    00000004                    : xlocale.obj (.pinit)
                  c4036494    00000004     --HOLE-- [fill = 0]
.hst1      0    c4036498    00000010     UNINITIALIZED
                  c4036498    00000010     IPT_Firmwarecfg.obj (.hst1)
.sys       0    c40364a8    00000010     UNINITIALIZED
                  c40364a8    00000010     IPT_Firmwarecfg.obj (.sys)
FAR CALL TRAMPOLINES
callee name               trampoline name
   callee addr  tramp addr   call addr  call info
$.bios:bios.a674<malloc.o674>$0x0  $Tramp$S$$_free
   c4027d40     c4020f20     c4000518   main.obj (.text)
                             c400e8cc   rts6740_eh.lib : locale0.obj (.text:___dt__Q3_3std6locale7_LocimpFv)
                             c400eec4                  : iostream.obj (.text:___ct__Q2_3std17ctype__tm__2_c__SFPCsbUi)
                             c400fd6c                  : setvbuf.obj (.text:_setvbuf)
                             c4012138                  : iostream.obj (.text:___dt__Q2_3std17ctype__tm__2_c__SFv)
                             c40142c4                  : wiostrea.obj (.text:___dt__Q2_3std17ctype__tm__2_w__SFv)
                             c4014728                  : fclose.obj (.text:_fclose)
                             c401e868                  : delete.obj (.text:___dl__FPv)
                             c401ec04                  : throw_edg.obj (.text:_eh_free_on_stack__FPv)
$.bios:bios.a674<malloc.o674>$0x22c  $Tramp$S$$_calloc
   c4027f6c     c4020f40     c400f688   rts6740_eh.lib : xlocinfo.obj (.text:__Getctyptab)
$.bios:bios.a674<malloc.o674>$0x24  $Tramp$S$$_malloc
   c4027d64     c4020f60     c400fdf0   rts6740_eh.lib : setvbuf.obj (.text:_setvbuf)
                             c4010dc8                  : throw_edg.obj (.text:_eh_alloc_on_stack__FUi)
                             c4010e00                  : throw_edg.obj (.text:_eh_alloc_on_stack__FUi)
                             c4010e08                  : throw_edg.obj (.text:_eh_alloc_on_stack__FUi)
                             c4019a28                  : throw_edg.obj (.text:_alloc_new_mem_block__FUi)
                             c401bd64                  : new_.obj (.text:___nw__FUi)
                             c401bda4                  : new_.obj (.text:___nw__FUi)
$.bios:bios.a674<lck.o674>$0x0  $Tramp$S$$_LCK_post
   c402a160     c4020f80     c401cda0   bios.a674 : tsk_stup.o674 (.text)
$.bios:bios.a674<lck.o674>$0x20  $Tramp$S$$_LCK_pend
   c402a180     c4020fa0     c401ce04   bios.a674 : tsk_stup.o674 (.text)
$.bios:bios.a674<sys_abor.o674>$0x0  $Tramp$S$$_SYS_abort
   c402a520     c4020fc0     c401ce08   bios.a674 : tsk_stup.o674 (.text)
                             c401ce24             : tsk_stup.o674 (.text)
[6 trampolines]
[21 trampoline calls]
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
address    name
c4035c00   $bss
c4035c00   .bss
c0000000   .data
c4000000   .text
c4034464   BIOS$$CLKOFF
c4034424   BIOS$$CLKON
c40342a0   BIOS_init
c40344d0   BIOS_start
00000000   BUF$
00000001   BUF_ENABLED
c4020760   C$$EXIT
c401f8f8   C$$IO$$
ffffffff   CACHE_L1D
ffffffff   CACHE_L1P
ffffffff   CACHE_L2
00000001   CLK$
118000b4   CLK_A_TABBEG
00000001   CLK_CALDIV
00000001   CLK_CALMULT
000493e0   CLK_COUNTSPMS
00000004   CLK_COUNTSPMSHIGH
c4035d28   CLK_D_idletime
c4035d24   CLK_D_isrhook
c4035d20   CLK_D_tabbeg
c4035d1c   CLK_D_timefxn
00000001   CLK_ENABLEHTIME
c402a7a0   CLK_F_gethtime
c4029340   CLK_F_getltime
c4029350   CLK_F_isr
c4029490   CLK_F_itime
c4027020   CLK_HOOKFXN
00000001   CLK_HTIMEDIV
00000001   CLK_HTIMEMULT
000493e0   CLK_HTIMEPERLTIME
00005dc0   CLK_INPUTCLK
00008000   CLK_INTBIT
00000001   CLK_LTIMEDIV
000493e0   CLK_LTIMEMULT
000003e8   CLK_MICROSECS
00005dc0   CLK_PRD
00000000   CLK_PRDHIGH
01c21000   CLK_REGS
00000001   CLK_RESETTIMER
c4035d18   CLK_R_time
00000020   CLK_TCR
00000000   CLK_TDDR
00000000   CLK_TDDRHIGH
c402a7a0   CLK_TIMEFXN
00000001   CLK_TIMERNUM
00000005   CLK_TIMMODE
00000001   CLK_USETIMER
118000b8   CLK_null
c4035ebc   DDR
c0000000   DDR$B
04000000   DDR$L
00000000   DEV$
00000000   DGN$
00000000   DHL$
00000000   DHL_gChannelsAvailable
00000000   DIO$
00000000   DIO_NUMSWIBASE
00000000   DIO_NUMTSKBASE
00000000   DIO_STATIC
00000000   DPI$
00000000   ECM$
00000000   ECM_ENABLE
ffffffff   ECM_EVTMASK0
ffffffff   ECM_EVTMASK1
ffffffff   ECM_EVTMASK2
ffffffff   ECM_EVTMASK3
0000000a   EVENT10
00000064   EVENT100
00000065   EVENT101
00000066   EVENT102
00000067   EVENT103
00000068   EVENT104
00000069   EVENT105
0000006a   EVENT106
0000006b   EVENT107
0000006c   EVENT108
0000006d   EVENT109
0000000b   EVENT11
0000006e   EVENT110
0000006f   EVENT111
00000070   EVENT112
00000071   EVENT113
00000072   EVENT114
00000073   EVENT115
00000074   EVENT116
00000075   EVENT117
00000076   EVENT118
00000077   EVENT119
0000000c   EVENT12
00000078   EVENT120
00000079   EVENT121
0000007a   EVENT122
0000007b   EVENT123
0000007c   EVENT124
0000007d   EVENT125
0000007e   EVENT126
0000007f   EVENT127
0000000d   EVENT13
0000000e   EVENT14
0000000f   EVENT15
00000010   EVENT16
00000011   EVENT17
00000012   EVENT18
00000013   EVENT19
00000014   EVENT20
00000015   EVENT21
00000016   EVENT22
00000017   EVENT23
00000018   EVENT24
00000019   EVENT25
0000001a   EVENT26
0000001b   EVENT27
0000001c   EVENT28
0000001d   EVENT29
0000001e   EVENT30
0000001f   EVENT31
00000020   EVENT32
00000021   EVENT33
00000022   EVENT34
00000023   EVENT35
00000024   EVENT36
00000025   EVENT37
00000026   EVENT38
00000027   EVENT39
00000004   EVENT4
00000028   EVENT40
00000029   EVENT41
0000002a   EVENT42
0000002b   EVENT43
0000002c   EVENT44
0000002d   EVENT45
0000002e   EVENT46
0000002f   EVENT47
00000030   EVENT48
00000031   EVENT49
00000005   EVENT5
00000032   EVENT50
00000033   EVENT51
00000034   EVENT52
00000035   EVENT53
00000036   EVENT54
00000037   EVENT55
00000038   EVENT56
00000039   EVENT57
0000003a   EVENT58
0000003b   EVENT59
00000006   EVENT6
0000003c   EVENT60
0000003d   EVENT61
0000003e   EVENT62
0000003f   EVENT63
00000040   EVENT64
00000041   EVENT65
00000042   EVENT66
00000043   EVENT67
00000044   EVENT68
00000045   EVENT69
00000007   EVENT7
00000046   EVENT70
00000047   EVENT71
00000048   EVENT72
00000049   EVENT73
0000004a   EVENT74
0000004b   EVENT75
0000004c   EVENT76
0000004d   EVENT77
0000004e   EVENT78
0000004f   EVENT79
00000008   EVENT8
00000050   EVENT80
00000051   EVENT81
00000052   EVENT82
00000053   EVENT83
00000054   EVENT84
00000055   EVENT85
00000056   EVENT86
00000057   EVENT87
00000058   EVENT88
00000059   EVENT89
00000009   EVENT9
0000005a   EVENT90
0000005b   EVENT91
0000005c   EVENT92
0000005d   EVENT93
0000005e   EVENT94
0000005f   EVENT95
00000060   EVENT96
00000061   EVENT97
00000062   EVENT98
00000063   EVENT99
c402a340   FXN_F_nop
c402a344   FXN_F_run
c402a380   FXN_F_zero
00000001   GBL$
00005205   GBL_A_VERSION
00000000   GBL_BCACHEREADADDR0
00000000   GBL_BCACHEREADADDR1
00000000   GBL_BCACHEREADADDR2
00000000   GBL_BIGENDIAN
00000000   GBL_CACHE
00000000   GBL_CALLCSLCFGINIT
00004e20   GBL_CLKIN
00001a5b   GBL_CLKTYPE
00001a5c   GBL_DSPSUBTYPE
0000003e   GBL_DSPTYPE
00000001   GBL_ENABLEINST
00000000   GBL_ENABLE_SK
00000042   GBL_FOOTPRINT
000493e0   GBL_FREQ
00000000   GBL_GEMTRUECOMPEN
00000007   GBL_L1DMODE
00000007   GBL_L1PMODE
00000001   GBL_L2CONFIGURE
00000000   GBL_L2MAR0_31
00000000   GBL_L2MAR128_159
00000000   GBL_L2MAR160_191
000000ff   GBL_L2MAR192_223
00000000   GBL_L2MAR224_255
00000000   GBL_L2MAR32_63
00000000   GBL_L2MAR64_95
00000000   GBL_L2MAR96_127
00000003   GBL_L2MODE
00000000   GBL_NULL
00000000   GBL_PROCID
00000000   GBL_ROM
00000000   GBL_SUPPORTCSL
00004000   GBL_TRCMASKVALUE
00000000   GBL_USERINIT
c402a6e0   GBL_USERINITFXN
00000001   GBL_boot
c4034ffc   GBL_initdone
c4035400   GBL_stackbeg
c40357ff   GBL_stackend
00000000   GIO$
c402a6e0   GIO_CREATEFXN
c402a6e0   GIO_DELETEFXN
c402a6e0   GIO_PENDFXN
c402a6e0   GIO_POSTFXN
00000000   HOOK$
00000000   HOOK_KNLID
00000001   HST$
c4036434   HST_A_TABBEG
c4036470   HST_A_TABEND
00000000   HST_DSM
c4035ebc   HST_DSMBUFSEG
00000400   HST_DSMMEMSIZE
c4035d94   HST_D_chanmask
c4035d98   HST_D_tabbeg
c4035d9c   HST_D_tabend
000000ff   HST_MAXFRAMEALLOWED
00000040   HST_MAXFRAMESET
00000000   HST_NONE
00000001   HST_RTDX
00000001   HWI$
c4036000   HWI_A_VECS
00009828   HWI_CFGDISPATCHED
c4035f08   HWI_D_bss
c4035f0c   HWI_D_ccmask
c4035ef8   HWI_D_spsave
00000001   HWI_ENABLE_EXC
c4027020   HWI_F_dispatch
00000000   HWI_GENERATE_RESET_VEC
0000000a   HWI_INT10
00000000   HWI_INT10$hwi
0000000b   HWI_INT11
00000000   HWI_INT11$hwi
0000000c   HWI_INT12
00000000   HWI_INT12$hwi
0000000d   HWI_INT13
00000000   HWI_INT13$hwi
0000000e   HWI_INT14
00000000   HWI_INT14$hwi
0000000f   HWI_INT15
00000000   HWI_INT15$hwi
00000004   HWI_INT4
00000000   HWI_INT4$hwi
00000005   HWI_INT5
00000000   HWI_INT5$hwi
00000006   HWI_INT6
00000000   HWI_INT6$hwi
00000007   HWI_INT7
00000000   HWI_INT7$hwi
00000008   HWI_INT8
00000000   HWI_INT8$hwi
00000009   HWI_INT9
00000000   HWI_INT9$hwi
07061304   HWI_INTRMUX1
0b0a0908   HWI_INTRMUX2
28040d0c   HWI_INTRMUX3
00000001   HWI_NMI
00000000   HWI_NMI$hwi
00000000   HWI_POLARITYMASK
00000002   HWI_RESERVED0
00000000   HWI_RESERVED0$hwi
00000003   HWI_RESERVED1
00000000   HWI_RESERVED1$hwi
00000000   HWI_RESET
00000000   HWI_RESET$hwi
00000000   HWI_ZEROTAB
00000001   IDL$
118000a0   IDL_A_CALBEG
1180008c   IDL_A_TABBEG
00000006   IDL_CALIBRERROR
c402a5e0   IDL_CALIBRFXN
c4035f88   IDL_D_busyObj
c4035d08   IDL_D_calbeg
c4035d04   IDL_D_calibrate
c4035d00   IDL_D_tabbeg
1180009c   IDL_END
118000b0   IDL_END$
c402a400   IDL_F_busy
c402a260   IDL_F_calibrate
c402a720   IDL_F_loop
c402a5e0   IDL_F_stub
00000001   IDL_USECLKIDLTIME
11800054   IDL_busyObj
c4033316   IDL_busyObj$avgfmt
00000001   IDL_busyObj$filter
00000001   IDL_busyObj$iA
00000000   IDL_busyObj$iB
00000001   IDL_busyObj$iC
c4033310   IDL_busyObj$maxfmt
00000000   IDL_busyObj$operation
11800050   IDL_busyObj$stsobj
c4033313   IDL_busyObj$sumfmt
00000002   IDL_busyObj$unittype
1180008c   IDL_cpuLoad
118000a0   IDL_cpuLoad$
11800098   IPT_Firmware
118000ac   IPT_Firmware$
ffffffff   IRAM
00000001   ISRC$
c4029638   KNL_glue
11800060   KNL_swi
00000001   KNL_swi$dorta
00000000   KNL_swi$ord
00000000   KNL_swi$pri
11800034   KNL_swi$sts
c40332ec   KNL_swi$sts$avgfmt
00000002   KNL_swi$sts$filter
00000001   KNL_swi$sts$filtmaxmult
00000001   KNL_swi$sts$filtsummult
c40332dc   KNL_swi$sts$maxfmt
11800030   KNL_swi$sts$stsobj
c40332e4   KNL_swi$sts$sumfmt
00000000   KNL_swi$sts$unittype
00000000   KNL_swi$swi
ffffffff   L3_CBA_RAM
00000001   LCK$
c40264e0   LNK_F_checkBufferCall
c4026560   LNK_F_dataPump
c4026500   LNK_F_getChanPtr
c4026558   LNK_F_init
c4026a68   LNK_F_readCallBack
11800090   LNK_dataPump
118000a4   LNK_dataPump$
c4035f14   LNK_dspFrameReadyMask
c4035f10   LNK_dspFrameRequestMask
c40267e0   LNK_newin
c4026914   LNK_newout
c4026570   LNK_rcloop
c4026634   LNK_rdrtry
c4035f1c   LNK_readDone
c4035f20   LNK_readFail
c4035f18   LNK_readPend
c4026644   LNK_rrloop
c4035f24   LNK_writeFail
c4026710   LNK_wrloop
c4026704   LNK_wrrtry
00000001   LOG$
11800000   LOG_A_TABBEG
11800030   LOG_A_TABEND
00000002   LOG_A_TABLEN
c4035d0c   LOG_D_system
00000001   LOG_ENABLED
c402a1e0   LOG_F_event
11800000   LOG_system
c4035000   LOG_system$buf
00000000   LOG_system$datatype
00000000   LOG_system$log
00000100   LOG_system$size
00000000   MBX$
00000001   MEM$
c4035ebc   MEM_MALLOCSEG
00000000   MEM_NULL
c4035ebc   MEM_SEGZERO
00000000   MEM_USEMPC
00000001   MEM_gNumHeap
00000000   MSGQ$
00000000   MSGQ_USEMSGQ
00000000   OBJ$
00000000   PIP$
c4036320   PIP_A_TABBEG
c40363e8   PIP_A_TABEND
00000002   PIP_A_TABLEN
c4035d10   PIP_D_tabbeg
c4035d14   PIP_D_tablen
c4028cb8   PIP_F_give
c4028cb8   PIP_F_probe
c4028d88   PIP_F_start
c4028c40   PIP_F_take
00000064   PIP_OBJSIZE
00000000   PIP_gNextId
00000002   PIP_gNumEmbed
00000000   POOL$
00000000   POOL_USEPOOL
00000001   PRD$
c0000000   PRD_A_TABBEG
c0000000   PRD_A_TABEND
00000000   PRD_A_TABLEN
c4035d50   PRD_D_cur
c4035d54   PRD_D_elapsed
c4035d58   PRD_D_prevtim
c4035d5c   PRD_D_scalar
c4035d60   PRD_D_swihandle
c4035d64   PRD_D_tabbeg
c4035d68   PRD_D_tablen
c4035d6c   PRD_D_thook
c4035d4c   PRD_D_tick
c40279c0   PRD_F_swi
c4027c44   PRD_F_tick
00000001   PRD_SCALAR
00000000   PRD_SWIHANDLE
c4028854   PRD_THOOKFXN
118000b4   PRD_clock
00000001   PWRM$
00000030   PWRM_PWRM_CAPSMASK
0000000a   PWRM_PWRM_CLKTICKSPERSLOT
00000000   PWRM_PWRM_ENABLE
00000002   PWRM_PWRM_INITSPCPU
00000000   PWRM_PWRM_INITSPPER
00000000   PWRM_PWRM_LOADENABLE
00000001   PWRM_PWRM_NUMSLOTS
00000000   PWRM_PWRM_RESOURCETRACKING
00000000   PWRM_PWRM_SCALING
c402a6e0   PWRM_PWRM_SHAREDRESOURCEFXN
c402a6e0   PWRM_PWRM_SLOTHOOKFXN
00000000   PWRM_PWRM_TIMERIDNUM
00000000   PWRM_PWRM_TIMERINTRMASK
00000000   PWRM_PWRM_TIMERWUGENMASK
00000000   PWRM_PWRM_USERRESOURCES
00000000   PWRM_PWRM_USETIMER
00000001   QUE$
c4035d70   RTA_D_fromHost
c4035d78   RTA_D_logval
c4035d88   RTA_D_stsval
c4035d74   RTA_D_toHost
c402a620   RTA_F_andn
c40280a0   RTA_F_dispatch
c4027fc0   RTA_F_getlog
c4027ff8   RTA_F_getsts
c402a638   RTA_F_or
c4028038   RTA_F_readblk
c4028060   RTA_F_resetmem
c4028054   RTA_F_writeword
11800094   RTA_dispatcher
118000a8   RTA_dispatcher$
c40280ec   RTA_execute
c4036438   RTA_fromHost
c4036498   RTA_fromHost$buf
00000004   RTA_fromHost$framesize
00000000   RTA_fromHost$hst
00000001   RTA_fromHost$id
00000000   RTA_fromHost$mode
c4036320   RTA_fromHost$pipe
c4036350   RTA_fromHost$pipe$aaa
c4036380   RTA_fromHost$pipe$bbb
c4035ec0   RTA_fromHost$pipe$dtab
c4036324   RTA_fromHost$pipe$rd
c4036354   RTA_fromHost$pipe$wr
c4036440   RTA_fromHost$rtdx
c4036454   RTA_toHost
c4034ef4   RTA_toHost$buf
00000040   RTA_toHost$framesize
00000000   RTA_toHost$hst
00000000   RTA_toHost$id
00000001   RTA_toHost$mode
c4036384   RTA_toHost$pipe
c40363b4   RTA_toHost$pipe$aaa
c40363e4   RTA_toHost$pipe$bbb
c4035ecc   RTA_toHost$pipe$dtab
c4036388   RTA_toHost$pipe$rd
c40363b8   RTA_toHost$pipe$wr
c403645c   RTA_toHost$rtdx
00000001   RTDX$
00000408   RTDX_BUFMEMSIZE
c4035ebc   RTDX_DATAMEMSEG
00000000   RTDX_MODE
00000001   RTDX_NORMALIZED_HDR
00000001   RTDX_USERTDX
00000000   RTDX_USERTEXECUTION
00000000   SEM$
00000000   SIO$
00000001   STS$
11800030   STS_A_TABBEG
11800060   STS_A_TABEND
c402a4ec   STS_F_add
c402a4c0   STS_F_delta
c402a508   STS_F_reset
00000001   SWI$
11800060   SWI_A_TABBEG
1180008c   SWI_A_TABEND
00000001   SWI_A_TABLEN
c4035de4   SWI_D_curfxn
c4035dd4   SWI_D_curmask
c4035de0   SWI_D_curmbox
c4035dd8   SWI_D_curset
c4035dd0   SWI_D_execaddr
c4035dec   SWI_D_inswi
c4035ddc   SWI_D_lock
c4035de8   SWI_D_rdybeg
c4035df0   SWI_D_rdytab
c4035dcc   SWI_D_runaddr
00000000   SWI_EHOOKFXN
c40276e4   SWI_EXECFXN
c4027500   SWI_F_enable
c40276e4   SWI_F_exec
c402770c   SWI_F_iexec
c4027570   SWI_F_post
c402778c   SWI_F_run
00000000   SWI_IHOOKFXN
c402778c   SWI_RUNFXN
00000001   SYS$
c40364a8   SYS$config
c402a660   SYS_ABORTFXN
c402a760   SYS_ERRORFXN
c402a780   SYS_EXITFXN
c402a6a0   SYS_PUTCFXN
c4034ff8   TRC_R_mask
c4034ff4   TRC_cinit
00000001   TSK$
00000000   TSK_NUM_HOOKS
00000001   TSK_PRIORITY
00000000   TSK_READYFXN
00000000   TSK_STACKSEG
00000400   TSK_STACKSIZE
00000000   TSK_SWITCHFXN
c402a6e0   TSK_VCREATEFXN
c402a6e0   TSK_VDELETEFXN
c402a6e0   TSK_VEXITFXN
c4035fa0   TSK_idle
00000000   TSK_idle$ord
00000000   TSK_idle$pri
c402e698   TSK_idle$stack
c4030d40   TSK_idle$stkptr
11800044   TSK_idle$sts
c4033306   TSK_idle$sts$avgfmt
00000002   TSK_idle$sts$filter
00000001   TSK_idle$sts$filtmaxmult
00000001   TSK_idle$sts$filtsummult
c40332f6   TSK_idle$sts$maxfmt
11800040   TSK_idle$sts$stsobj
c40332fe   TSK_idle$sts$sumfmt
00000000   TSK_idle$sts$unittype
00000000   TSK_idle$tsk
00000000   UDEV$
c4029974   _BCACHE_bootInit
c40299f4   _BCACHE_getMar
c40299a4   _BCACHE_getSize
c4029974   _BCACHE_setCacheToSram
c4029924   _BCACHE_setMar
c40298e0   _BCACHE_setSize
c40342a0   _BIOS_init
c40344d0   _BIOS_start
ffffffff   _CACHE_L1D
ffffffff   _CACHE_L1P
ffffffff   _CACHE_L2
000493e0   _CLK_COUNTSPMS
c4035f74   _CLK_DFLTMICROSECS
c4035d48   _CLK_D_countspms
c4035d3c   _CLK_D_dirty
c4035f78   _CLK_D_microseconds
c4035d40   _CLK_D_prd
c4035d44   _CLK_D_tddr
c4029490   _CLK_F_itime
00005dc0   _CLK_PRD
01c21000   _CLK_REGS
00000000   _CLK_TDDR
00000001   _CLK_TIMERNUM
00000001   _CLK_USETIMER
c402a7a0   _CLK_gethtime
c4035d2c   _CLK_htimeDiv
c4035d30   _CLK_htimeMult
c4035f84   _CLK_htimePerLtime
c402b5cc   _CLK_inputClock
c4029490   _CLK_itime
c4035d34   _CLK_ltimeDiv
c4035d38   _CLK_ltimeMult
c402a580   _CLK_measure
c402e56c   _C_locale
c4035ebc   _DDR
c0000000   _DDR_base
04000000   _DDR_length
0000000a   _EVENT10
00000064   _EVENT100
00000065   _EVENT101
00000066   _EVENT102
00000067   _EVENT103
00000068   _EVENT104
00000069   _EVENT105
0000006a   _EVENT106
0000006b   _EVENT107
0000006c   _EVENT108
0000006d   _EVENT109
0000000b   _EVENT11
0000006e   _EVENT110
0000006f   _EVENT111
00000070   _EVENT112
00000071   _EVENT113
00000072   _EVENT114
00000073   _EVENT115
00000074   _EVENT116
00000075   _EVENT117
00000076   _EVENT118
00000077   _EVENT119
0000000c   _EVENT12
00000078   _EVENT120
00000079   _EVENT121
0000007a   _EVENT122
0000007b   _EVENT123
0000007c   _EVENT124
0000007d   _EVENT125
0000007e   _EVENT126
0000007f   _EVENT127
0000000d   _EVENT13
0000000e   _EVENT14
0000000f   _EVENT15
00000010   _EVENT16
00000011   _EVENT17
00000012   _EVENT18
00000013   _EVENT19
00000014   _EVENT20
00000015   _EVENT21
00000016   _EVENT22
00000017   _EVENT23
00000018   _EVENT24
00000019   _EVENT25
0000001a   _EVENT26
0000001b   _EVENT27
0000001c   _EVENT28
0000001d   _EVENT29
0000001e   _EVENT30
0000001f   _EVENT31
00000020   _EVENT32
00000021   _EVENT33
00000022   _EVENT34
00000023   _EVENT35
00000024   _EVENT36
00000025   _EVENT37
00000026   _EVENT38
00000027   _EVENT39
00000004   _EVENT4
00000028   _EVENT40
00000029   _EVENT41
0000002a   _EVENT42
0000002b   _EVENT43
0000002c   _EVENT44
0000002d   _EVENT45
0000002e   _EVENT46
0000002f   _EVENT47
00000030   _EVENT48
00000031   _EVENT49
00000005   _EVENT5
00000032   _EVENT50
00000033   _EVENT51
00000034   _EVENT52
00000035   _EVENT53
00000036   _EVENT54
00000037   _EVENT55
00000038   _EVENT56
00000039   _EVENT57
0000003a   _EVENT58
0000003b   _EVENT59
00000006   _EVENT6
0000003c   _EVENT60
0000003d   _EVENT61
0000003e   _EVENT62
0000003f   _EVENT63
00000040   _EVENT64
00000041   _EVENT65
00000042   _EVENT66
00000043   _EVENT67
00000044   _EVENT68
00000045   _EVENT69
00000007   _EVENT7
00000046   _EVENT70
00000047   _EVENT71
00000048   _EVENT72
00000049   _EVENT73
0000004a   _EVENT74
0000004b   _EVENT75
0000004c   _EVENT76
0000004d   _EVENT77
0000004e   _EVENT78
0000004f   _EVENT79
00000008   _EVENT8
00000050   _EVENT80
00000051   _EVENT81
00000052   _EVENT82
00000053   _EVENT83
00000054   _EVENT84
00000055   _EVENT85
00000056   _EVENT86
00000057   _EVENT87
00000058   _EVENT88
00000059   _EVENT89
00000009   _EVENT9
0000005a   _EVENT90
0000005b   _EVENT91
0000005c   _EVENT92
0000005d   _EVENT93
0000005e   _EVENT94
0000005f   _EVENT95
00000060   _EVENT96
00000061   _EVENT97
00000062   _EVENT98
00000063   _EVENT99
c4026ff0   _EXC_clearLastStatus
c4028a60   _EXC_dispatch
c4026e14   _EXC_exceptionHandler
c4035f28   _EXC_exceptionHook
c4026de0   _EXC_external
c4035f30   _EXC_externalHook
c4026dc0   _EXC_getLastStatus
c4026d80   _EXC_init
c4026ad4   _EXC_internal
c4035f2c   _EXC_internalHook
c4026aa0   _EXC_nmi
c4035f34   _EXC_nmiHook
c4035ee0   _EXC_returnPtr
c4028c24   _EXC_setReturnPtr
c402e610   _EXC_status
c4035ed8   _EXC_sysTrapTable
c402a6e0   _FXN_F_nop
c402a344   _FXN_F_run
c402a380   _FXN_F_zero
00000000   _GBL_CACHE
c4029a88   _GBL_cacheInit64P
c4035da4   _GBL_clkIn
c4035da8   _GBL_freq
c402a700   _GBL_getVersion
c4035da0   _GBL_procId
c401ce60   _HOSTclose
c40150e0   _HOSTlseek
c4017de0   _HOSTopen
c4019f20   _HOSTread
c400fea0   _HOSTrename
c4019fe0   _HOSTunlink
c401a0a0   _HOSTwrite
c40332e0   _HSRTDX_rec
c4033a40   _HSRTDX_xmt
c4036434   _HST_A_TABBEG
c4036470   _HST_A_TABEND
00009828   _HWI_CFGDISPATCHED
c4035f04   _HWI_D_inhwi
c4035ef8   _HWI_D_spsave
c4027020   _HWI_F_dispatch
0000000a   _HWI_INT10
0000000b   _HWI_INT11
0000000c   _HWI_INT12
0000000d   _HWI_INT13
0000000e   _HWI_INT14
0000000f   _HWI_INT15
00000004   _HWI_INT4
00000005   _HWI_INT5
00000006   _HWI_INT6
00000007   _HWI_INT7
00000008   _HWI_INT8
00000009   _HWI_INT9
00000001   _HWI_NMI
00000002   _HWI_RESERVED0
00000003   _HWI_RESERVED1
00000000   _HWI_RESET
c40357f8   _HWI_STKBOTTOM
c4035400   _HWI_STKTOP
c4035ef8   _HWI_data
c402a3a0   _HWI_disable
c4035c00   _HWI_dispatchTab
c402a3b8   _HWI_enable
c402a3cc   _HWI_restore
11800054   _IDL_busyObj
1180008c   _IDL_cpuLoad
c402a720   _IDL_loop
11800098   _IPT_Firmware
ffffffff   _IRAM
c4035e70   _KNL_alarm
c4029b40   _KNL_check
c4035e94   _KNL_curqueue
c4035e84   _KNL_curtask
c4035e8c   _KNL_curtime
c402e1e0   _KNL_dummy
c4029ea0   _KNL_enter
c4029e60   _KNL_exit
c4029c08   _KNL_idle
c4035eac   _KNL_idlefxn
c4035e78   _KNL_inactive
c402a060   _KNL_ipost
c4029c30   _KNL_max
c4035e98   _KNL_maxqueue
c402a0e0   _KNL_post
c4035e88   _KNL_prevtask
c4035e7c   _KNL_priority
c402e140   _KNL_queues
c4028240   _KNL_run
c40294e0   _KNL_saveIsrFrame
c4035e80   _KNL_set
c4035e74   _KNL_setpri
11800060   _KNL_swi
c4035e90   _KNL_swiptr
c402958c   _KNL_switch
c4035ea0   _KNL_tcreatefxn
c4035ea4   _KNL_tdeletefxn
c4028854   _KNL_tick
c4035ea8   _KNL_treadyfxn
c4035e9c   _KNL_tswitchfxn
c4035e68   _KNL_wFlag
c4035e6c   _KNL_wList
ffffffff   _L3_CBA_RAM
c402a180   _LCK_pend
c402a160   _LCK_post
11800090   _LNK_dataPump
c4035f14   _LNK_dspFrameReadyMask
c4035f10   _LNK_dspFrameRequestMask
c4035f1c   _LNK_readDone
c4035f20   _LNK_readFail
c4035f18   _LNK_readPend
c4035f24   _LNK_writeFail
11800000   _LOG_A_TABBEG
11800030   _LOG_A_TABEND
00000002   _LOG_A_TABLEN
c4035d0c   _LOG_D_system
c402a1e0   _LOG_event
11800000   _LOG_system
c4035f8c   _MEM
c4035dac   _MEM_D_NUMSEGMENTS
c4035db4   _MEM_D_freelist
c4035db8   _MEM_D_lockaddr
c4035db0   _MEM_D_memtab
c4035dbc   _MEM_D_unlockaddr
c4028480   _MEM_alloc
c4028880   _MEM_free
c40346e0   _MEM_init
c4035eb0   _MEM_memtab
c402e4b0   _OBJ_segtab
c402e478   _OBJ_table
c4036320   _PIP_A_TABBEG
c40363e8   _PIP_A_TABEND
c4035d4c   _PRD_D_tick
118000b4   _PRD_clock
11800094   _RTA_dispatcher
c4036438   _RTA_fromHost
c4036454   _RTA_toHost
c4034880   _RTDX_Buffer
c4034c8c   _RTDX_Buffer_End
c40340c0   _RTDX_Buffer_Initialize
c4034240   _RTDX_Buffer_Read
c4034180   _RTDX_Buffer_ReadCB
c40341c0   _RTDX_Buffer_Size
c4034c88   _RTDX_Buffer_Start
c4034260   _RTDX_Buffer_Write
c4033580   _RTDX_Buffer_WriteCB
c4034040   _RTDX_Final_RT_Monitor
c4034120   _RTDX_Init_RT_Monitor
00000002   _RTDX_JTAGONLY
c4034280   _RTDX_Mask_IER
c4033d40   _RTDX_Mon_Queue
c4033fa0   _RTDX_Poll
00000000   _RTDX_interrupt_mask
c4034200   _RTDX_memfill
c4034ce0   _RTDX_writing
c402a460   _SEM_pend
c4028e20   _SEM_pendEnterKnl
c4029d80   _SEM_post
c4029d80   _SEM_postBinary
c4029f20   _SEM_postEnterKnl
11800030   _STS_A_TABBEG
11800060   _STS_A_TABEND
c402a4ec   _STS_add
c402a4c0   _STS_delta
c402a508   _STS_reset
c402a740   _STS_set
c4035de4   _SWI_D_curfxn
c4035dd4   _SWI_D_curmask
c4035dd8   _SWI_D_curset
c4035dd0   _SWI_D_execaddr
c4035dec   _SWI_D_inswi
c4035ddc   _SWI_D_lock
c4035de8   _SWI_D_rdybeg
c4035dcc   _SWI_D_runaddr
c4035dcc   _SWI_data
c4027570   _SWI_post
c4035dc0   _SYS
c4034cf4   _SYS_PUTCBEG
c4034ef3   _SYS_PUTCEND
c402a520   _SYS_abort
c402a2e0   _SYS_error
c4029fc0   _SYS_exit
c402e5a0   _SYS_exitStack
c4035f7c   _SYS_exitStackPtr
c4035f80   _SYS_exitStackTop
c4034ff8   _TRC_R_mask
c4035f70   _TSK
c402e41c   _TSK_ATTRS
c402e438   _TSK_config
c40297a0   _TSK_exit
c4035fa0   _TSK_idle
c40347a0   _TSK_init
c4035f68   _TSK_nTasks
c4035f6c   _TSK_pid
c40291a0   _TSK_setup
c4029d04   _TSK_startup
c402e458   _TSK_timerSem
c402a660   _UTL_doAbort
c402a760   _UTL_doError
c402a6a0   _UTL_doPutc
c402a780   _UTL_halt
c4012aa0   __Addstd__Q2_3std8ios_baseFv
c4020540   __Atexit
c4032540   __BADOFF__3std
c4036200   __CIOBUF_
c40294b0   __CLK_lat1beg
c40294d0   __CLK_lat1end
c401e6c0   __Callfns__Q2_3std8ios_baseFQ3_3std8ios_base5event
c402d66c   __Clocptr__Q3_3std6locale7_Locimp
c401f0c0   __Deletegloballocale
c4011920   __Fac_tidy
c402d948   __Fpz__3std
c400f680   __Getctyptab
c401e740   __Getfacet__Q2_3std6localeCFUi
c4020560   __Getgloballocale
c4035dc8   __HOOK_NUMHOOKS
c4035dc4   __HOOK_knlId
c4027020   __HWI_lat1beg
c40271a8   __HWI_lat1end
c40271a8   __HWI_lat2beg
c4027384   __HWI_lat2end1
c4027310   __HWI_lat2end2
c40273a0   __HWI_lat3beg
c4027340   __HWI_lat3end2
c402a400   __IDL_lat1beg
c402a440   __IDL_lat1end
c402d668   __Id_cnt__Q3_3std6locale2id
c402d940   __Index__Q2_3std8ios_base
c4009be0   __Init__Q2_3std6localeSFv
c401f120   __Init__Q2_3std8ios_baseFv
c402cf3c   __Init_cnt__Q2_3std6_Winit
c402c810   __Init_cnt__Q3_3std8ios_base4Init
c4029b8c   __KNL_lat1beg
c4029c08   __KNL_lat1end
c402a1e0   __LOG_lat1beg
c402e4f4   __MEM_mutex
c402c7b0   __PJP_CPP_Copyright
c402e5c0   __Psave__Q2_3std41_Facetptr__tm__24_Q2_3std14ctype__tm__2_c
c4028060   __RTA_lat1beg
c4028094   __RTA_lat1end
c401e7c0   __Register__Q3_3std6locale5facetFv
c4029000   __SEM_dopost
c4035800   __STACK_END
00000400   __STACK_SIZE
c4027678   __SWI_lat1beg
c4027724   __SWI_lat1end
c4027728   __SWI_lat2beg
c4027788   __SWI_lat2end
c4027500   __SWI_lat3beg
c402756c   __SWI_lat3end
c401cf00   __Setgloballocale
c402d944   __Sync__Q2_3std8ios_base
c402e4cc   __TSK_mutex
c401cfa0   __Tidy__Q2_3std8ios_baseFv
c4012bc0   __Xlen__Q2_3std12_String_baseCFv
c4012ce0   __Xran__Q2_3std12_String_baseCFv
0000011b   ___TID_Q2_3std10bad_typeid
00000107   ___TID_Q2_3std10ctype_base
00000124   ___TID_Q2_3std10money_base
00000103   ___TID_Q2_3std11logic_error
0000010d   ___TID_Q2_3std12codecvt_base
00000104   ___TID_Q2_3std12length_error
00000105   ___TID_Q2_3std12out_of_range
0000011a   ___TID_Q2_3std13bad_exception
00000122   ___TID_Q2_3std13messages_base
00000110   ___TID_Q2_3std13runtime_error
00000112   ___TID_Q2_3std14_Iosb__tm__2_i
00000115   ___TID_Q2_3std14ctype__tm__2_c
00000108   ___TID_Q2_3std14ctype__tm__2_w
00000137   ___TID_Q2_3std16_Mpunct__tm__2_c
0000012c   ___TID_Q2_3std16_Mpunct__tm__2_w
00000139   ___TID_Q2_3std16collate__tm__2_c
0000012d   ___TID_Q2_3std16collate__tm__2_w
00000136   ___TID_Q2_3std17messages__tm__2_c
00000128   ___TID_Q2_3std17messages__tm__2_w
0000012f   ___TID_Q2_3std17numpunct__tm__2_c
00000125   ___TID_Q2_3std17numpunct__tm__2_w
00000113   ___TID_Q2_3std18codecvt__tm__4_cci
0000010a   ___TID_Q2_3std18codecvt__tm__4_wci
00000133   ___TID_Q2_3std28moneypunct__tm__10_cXCbL_1_0
00000134   ___TID_Q2_3std28moneypunct__tm__10_cXCbL_1_1
00000126   ___TID_Q2_3std28moneypunct__tm__10_wXCbL_1_0
00000127   ___TID_Q2_3std28moneypunct__tm__10_wXCbL_1_1
00000118   ___TID_Q2_3std48basic_ios__tm__31_cQ2_3std20char_traits__tm__2_c
00000106   ___TID_Q2_3std48basic_ios__tm__31_wQ2_3std20char_traits__tm__2_w
00000114   ___TID_Q2_3std52basic_filebuf__tm__31_cQ2_3std20char_traits__tm__2_c
0000010e   ___TID_Q2_3std52basic_filebuf__tm__31_wQ2_3std20char_traits__tm__2_w
00000117   ___TID_Q2_3std52basic_istream__tm__31_cQ2_3std20char_traits__tm__2_c
0000010b   ___TID_Q2_3std52basic_istream__tm__31_wQ2_3std20char_traits__tm__2_w
00000116   ___TID_Q2_3std52basic_ostream__tm__31_cQ2_3std20char_traits__tm__2_c
00000109   ___TID_Q2_3std52basic_ostream__tm__31_wQ2_3std20char_traits__tm__2_w
00000119   ___TID_Q2_3std54basic_streambuf__tm__31_cQ2_3std20char_traits__tm__2_c
0000010c   ___TID_Q2_3std54basic_streambuf__tm__31_wQ2_3std20char_traits__tm__2_w
00000130   ___TID_Q2_3std84num_get__tm__69_cQ2_3std58istreambuf_iterator__tm__31_cQ2_3std20char_traits__tm__2_c
00000123   ___TID_Q2_3std84num_get__tm__69_wQ2_3std58istreambuf_iterator__tm__31_wQ2_3std20char_traits__tm__2_w
0000012e   ___TID_Q2_3std84num_put__tm__69_cQ2_3std58ostreambuf_iterator__tm__31_cQ2_3std20char_traits__tm__2_c
00000129   ___TID_Q2_3std84num_put__tm__69_wQ2_3std58ostreambuf_iterator__tm__31_wQ2_3std20char_traits__tm__2_w
00000131   ___TID_Q2_3std85time_get__tm__69_cQ2_3std58istreambuf_iterator__tm__31_cQ2_3std20char_traits__tm__2_c
0000012a   ___TID_Q2_3std85time_get__tm__69_wQ2_3std58istreambuf_iterator__tm__31_wQ2_3std20char_traits__tm__2_w
00000138   ___TID_Q2_3std85time_put__tm__69_cQ2_3std58ostreambuf_iterator__tm__31_cQ2_3std20char_traits__tm__2_c
0000012b   ___TID_Q2_3std85time_put__tm__69_wQ2_3std58ostreambuf_iterator__tm__31_wQ2_3std20char_traits__tm__2_w
00000135   ___TID_Q2_3std86money_get__tm__69_cQ2_3std58istreambuf_iterator__tm__31_cQ2_3std20char_traits__tm__2_c
0000011f   ___TID_Q2_3std86money_get__tm__69_wQ2_3std58istreambuf_iterator__tm__31_wQ2_3std20char_traits__tm__2_w
00000132   ___TID_Q2_3std86money_put__tm__69_cQ2_3std58ostreambuf_iterator__tm__31_cQ2_3std20char_traits__tm__2_c
00000120   ___TID_Q2_3std86money_put__tm__69_wQ2_3std58ostreambuf_iterator__tm__31_wQ2_3std20char_traits__tm__2_w
0000011c   ___TID_Q2_3std8bad_cast
0000010f   ___TID_Q2_3std8ios_base
0000011e   ___TID_Q2_3std9bad_alloc
00000102   ___TID_Q2_3std9exception
00000121   ___TID_Q2_3std9time_base
0000011d   ___TID_Q2_3std9type_info
00000100   ___TID_Q3_3std6locale5facet
00000101   ___TID_Q3_3std6locale7_Locimp
00000111   ___TID_Q3_3std8ios_base7failure
c402e630   ___TID_v
c402e664   ___TI_enable_exit_profile_output
ffffffff   ___TI_pprof_out_hndl
ffffffff   ___TI_prof_data_size
ffffffff   ___TI_prof_data_start
c4032a00   ___T_Q2_3std10bad_typeid
c40329ec   ___T_Q2_3std8bad_cast
c40324fc   ___T_Q2_3std8ios_base
c4032a14   ___T_Q2_3std9type_info
c4032ba0   ___T_Q3_3std6locale7_Locimp
c4020600   ___abort_execution
c401f900   ___add_dtor
c401f940   ___adelete
c4035f90   ___array_new_prefix_size
c402dd40   ___atexit_func_id__
ffffffff   ___binit__
c4035c00   ___bss__
ffffffff   ___c_args__
c401f240   ___call_terminate
c400eba0   ___call_unexpected
c4012e00   ___can_throw_type
c4035f60   ___catch_clause_number
c4035f64   ___caught_object_address
c4020fe0   ___cinit__
c40151e0   ___cleanup_vec_new_or_delete
c4002e00   ___ct__Q2_3std6_WinitFv
c4013b80   ___ct__Q2_3std6localeFv
c4006a40   ___ct__Q2_3std8_LocinfoFPCc
c4011ce0   ___ct__Q3_3std6locale7_LocimpFb
c40034e0   ___ct__Q3_3std8ios_base4InitFv
c4035f5c   ___curr_eh_stack_entry
c0000000   ___data__
c401f980   ___default_new_handler__Fv
c4020620   ___default_terminate
c402e678   ___default_terminate_routine
c402e67c   ___default_unexpected_routine
c400cbc0   ___derived_to_base_conversion
c401e840   ___dl__FPv
c4020640   ___dl__FPvT1
c401f2a0   ___dla__FPv
c400ab00   ___dt__Q2_3std6_WinitFv
c400e5a0   ___dt__Q2_3std8_LocinfoFv
c401bc60   ___dt__Q2_3std8ios_baseFv
c401fd00   ___dt__Q2_3std9type_infoFv
c400e7a0   ___dt__Q3_3std6locale7_LocimpFv
c400ade0   ___dt__Q3_3std8ios_base4InitFv
c0000000   ___edata__
c4035f58   ___eh_curr_region
c4035f94   ___end__
c4020fe0   ___etext__
c401f3c0   ___exception_caught
c4010920   ___free_thrown_object
c4020660   ___internal_rethrow
c401fec0   ___isinf
c401bd20   ___nw__FUi
c4020680   ___nw__FUiPv
c4036470   ___pinit__
c40172e0   ___rethrow
c401f420   ___sti___10_locale_cpp_8e0a6042
c401f480   ___sti___11_locale0_cpp_36e19383
c4019820   ___sti___11_wlocale_cpp_961df3c4
c401dfe0   ___sti___11_xlocale_cpp_e9f82b60
c4014360   ___sti___12_iostream_cpp_3a72482d
c40121e0   ___sti___12_wiostrea_cpp_74e2bd13
c4001000   ___sti___8_main_cpp_main
c401ff80   ___suppress_optim_on_vars_in_try
c4000000   ___text__
c4004240   ___throw
c401f4e0   ___throw_setup_dtor
c401bde0   ___type_of_thrown_object
c4032fe0   ___vtbl__Q2_3std8ios_base
c4032ff0   ___vtbl__Q2_3std9type_info
c4033040   ___vtbl__Q3_3std6locale7_Locimp
c4029660   __auto_init
c4012320   __buff_read
c401c020   __c6xabi_divu
c401bea0   __cleanup
c402e65c   __cleanup_ptr
c40320b0   __ctypes_
c4003bc0   __divd
c401e080   __divli
c401c020   __divu
c400f9c0   __divul
c400ce40   __divull
c401c0e0   __doflush
c402e660   __dtors_ptr
c401e260   __fixdli
c401e8c0   __fltlid
c4010aa0   __frcmpyd_div
c402dd38   __ft_end
c402dba8   __ftable
c401e940   __llshl
c401ffc0   __llshru
c402e68c   __lock
c40206a0   __negll
c402e674   __new_handler
c40206c0   __nop
c4007c80   __printfi
c401e3a0   __rd_ok
c4020720   __register_lock
c4020740   __register_unlock
c4020000   __remli
c4020340   __setjmp
c4035400   __stack
c401f540   __subcull
c402dc98   __tmpnams
c402e5f8   __tz
c402e690   __unlock
c40174e0   __wrt_ok
c4020760   _abort
c401c1a0   _atexit
c4019ac0   _atoi
c4034620   _c_int00
c40175e0   _call_dtors
c4027f6c   _calloc
c402c990   _cerr__3std
c402c8c4   _cin__3std
c400b3a0   _clear__Q2_3std8ios_baseFQ3_3std14_Iosb__tm__2_i8_Iostateb
c402c9cc   _clog__3std
c4019ba0   _close
c402c904   _cout__3std
c402dd3c   _dtors
c402bef4   _errno
c40146c0   _fclose
c40177e0   _fflush
c40147e0   _fgetc
c4020240   _fgetpos
c4020ba0   _fgetwc
c401ec40   _fprintf
c40125a0   _fputc
c400a240   _fputs
c4020bc0   _fputwc
c4027d40   _free
c401c620   _fseek
c4020be0   _fsetpos
c401c6e0   _ftell
c4007820   _fwrite
c40147e0   _getc
c402d674   _id__Q2_3std17ctype__tm__2_c__S
c402a7c0   _id__Q2_3std17ctype__tm__2_w__S
c402d670   _id__Q2_3std21codecvt__tm__4_wci__S
c402a7c4   _id__S__Q2_3std96time_put__ps__5_wZ1Z__tm__68_Q2_3std58ostreambuf_iterator__tm__31_wQ2_3std20char_traits__tm__2_w
c401f660   _longjmp
c401c7a0   _lseek
c401c860   _ltoa
c4000f74   _main
c4027d64   _malloc
c40202c0   _mbrtowc
c4020300   _mbtowc
c4027ea8   _memalign
c401f6c0   _memccpy
c401e620   _memcpy
c401f720   _memmove
c4019d60   _memset
c40125a0   _putc
c401c920   _read
c401ecc0   _readmsg
c4027dc4   _realloc
c4020d00   _remove
c4035f40   _rtdxNullChanCnt
c4035f44   _rtdxNullFuncCnt
c4035f4c   _rtdxRecNotDoneCnt
c4035f54   _rtdxXmtErrorCnt
c4035f48   _rtdxXmtNotDoneCnt
c4035f50   _rtdxXmtRestartCnt
c4034cd4   _rtdx_buffer_state
c4034c90   _rtdx_mon_state
c4000fd0   _serviceUSB0Interrupt
c4020340   _setjmp
c401f840   _setlocale
c400fd00   _setvbuf
c4020380   _strcmp
c40203c0   _strlen
c4032bc0   _table_size__Q2_3std17ctype__tm__2_c__S
c4000fa4   _taskIdleFunction
c4020400   _terminate__3stdFv
c4020de0   _tolower
c4020e00   _toupper
11800018   _trace
c40178e0   _ungetc
c401ef40   _ungetwc
c401efc0   _unlink
c402d0bc   _wcerr__3std
c402d040   _wcin__3std
c402d0f8   _wclog__3std
c402d080   _wcout__3std
c4020440   _wcrtomb
c4020480   _wcslen
c4020e60   _wctomb
c401f040   _wmemcpy
c401cc20   _wmemmove
c401cce0   _write
c401f8a0   _writemsg
ffffffff   binit
c4020fe0   cinit
c0000000   edata
c4035f94   end
c4020fe0   etext
c4036000   hwi0
c4036020   hwi1
c4036140   hwi10
c4036160   hwi11
c4036180   hwi12
c40361a0   hwi13
c40361c0   hwi14
c40361e0   hwi15
c4036040   hwi2
c4036060   hwi3
c4036080   hwi4
c40360a0   hwi5
c40360c0   hwi6
c40360e0   hwi7
c4036100   hwi8
c4036120   hwi9
c4036470   pinit
11800018   trace
c4035800   trace$buf
00000001   trace$datatype
00000000   trace$log
00000100   trace$size
GLOBAL SYMBOLS: SORTED BY Symbol Address
address    name
00000000   BUF$
00000000   CLK_TDDR
00000000   DEV$
00000000   DGN$
00000000   DHL$
00000000   DIO$
00000000   DIO_STATIC
00000000   DPI$
00000000   ECM$
00000000   ECM_ENABLE
00000000   GBL_CACHE
00000000   GBL_NULL
00000000   GBL_PROCID
00000000   GBL_ROM
00000000   GIO$
00000000   HOOK$
00000000   HOOK_KNLID
00000000   HST_DSM
00000000   HST_NONE
00000000   HWI_RESET
00000000   MBX$
00000000   MEM_NULL
00000000   MEM_USEMPC
00000000   MSGQ$
00000000   OBJ$
00000000   PIP$
00000000   POOL$
00000000   RTDX_MODE
00000000   SEM$
00000000   SIO$
00000000   UDEV$
00000000   _CLK_TDDR
00000000   _GBL_CACHE
00000000   _HWI_RESET
00000000   trace$log
00000001   CLK$
00000001   CLK_CALDIV
00000001   GBL$
00000001   GBL_boot
00000001   HST$
00000001   HST_RTDX
00000001   HWI$
00000001   HWI_NMI
00000001   IDL$
00000001   ISRC$
00000001   LCK$
00000001   LOG$
00000001   MEM$
00000001   PRD$
00000001   PRD_SCALAR
00000001   PWRM$
00000001   QUE$
00000001   RTDX$
00000001   STS$
00000001   SWI$
00000001   SYS$
00000001   TSK$
00000001   _HWI_NMI
00000003   GBL_L2MODE
00000004   EVENT4
00000004   HWI_INT4
00000004   _EVENT4
00000004   _HWI_INT4
00000005   EVENT5
00000005   HWI_INT5
00000005   _EVENT5
00000005   _HWI_INT5
00000006   EVENT6
00000006   HWI_INT6
00000006   _EVENT6
00000006   _HWI_INT6
00000007   EVENT7
00000007   HWI_INT7
00000007   _EVENT7
00000007   _HWI_INT7
00000008   EVENT8
00000008   HWI_INT8
00000008   _EVENT8
00000008   _HWI_INT8
00000009   EVENT9
00000009   HWI_INT9
00000009   _EVENT9
00000009   _HWI_INT9
0000000a   EVENT10
0000000a   HWI_INT10
0000000a   _EVENT10
0000000a   _HWI_INT10
0000000b   EVENT11
0000000b   HWI_INT11
0000000b   _EVENT11
0000000b   _HWI_INT11
0000000c   EVENT12
0000000c   HWI_INT12
0000000c   _EVENT12
0000000c   _HWI_INT12
0000000d   EVENT13
0000000d   HWI_INT13
0000000d   _EVENT13
0000000d   _HWI_INT13
0000000e   EVENT14
0000000e   HWI_INT14
0000000e   _EVENT14
0000000e   _HWI_INT14
0000000f   EVENT15
0000000f   HWI_INT15
0000000f   _EVENT15
0000000f   _HWI_INT15
00000010   EVENT16
00000010   _EVENT16
00000011   EVENT17
00000011   _EVENT17
00000012   EVENT18
00000012   _EVENT18
00000013   EVENT19
00000013   _EVENT19
00000014   EVENT20
00000014   _EVENT20
00000015   EVENT21
00000015   _EVENT21
00000016   EVENT22
00000016   _EVENT22
00000017   EVENT23
00000017   _EVENT23
00000018   EVENT24
00000018   _EVENT24
00000019   EVENT25
00000019   _EVENT25
0000001a   EVENT26
0000001a   _EVENT26
0000001b   EVENT27
0000001b   _EVENT27
0000001c   EVENT28
0000001c   _EVENT28
0000001d   EVENT29
0000001d   _EVENT29
0000001e   EVENT30
0000001e   _EVENT30
0000001f   EVENT31
0000001f   _EVENT31
00000020   CLK_TCR
00000020   EVENT32
00000020   _EVENT32
00000021   EVENT33
00000021   _EVENT33
00000022   EVENT34
00000022   _EVENT34
00000023   EVENT35
00000023   _EVENT35
00000024   EVENT36
00000024   _EVENT36
00000025   EVENT37
00000025   _EVENT37
00000026   EVENT38
00000026   _EVENT38
00000027   EVENT39
00000027   _EVENT39
00000028   EVENT40
00000028   _EVENT40
00000029   EVENT41
00000029   _EVENT41
0000002a   EVENT42
0000002a   _EVENT42
0000002b   EVENT43
0000002b   _EVENT43
0000002c   EVENT44
0000002c   _EVENT44
0000002d   EVENT45
0000002d   _EVENT45
0000002e   EVENT46
0000002e   _EVENT46
0000002f   EVENT47
0000002f   _EVENT47
00000030   EVENT48
00000030   _EVENT48
00000031   EVENT49
00000031   _EVENT49
00000032   EVENT50
00000032   _EVENT50
00000033   EVENT51
00000033   _EVENT51
00000034   EVENT52
00000034   _EVENT52
00000035   EVENT53
00000035   _EVENT53
00000036   EVENT54
00000036   _EVENT54
00000037   EVENT55
00000037   _EVENT55
00000038   EVENT56
00000038   _EVENT56
00000039   EVENT57
00000039   _EVENT57
0000003a   EVENT58
0000003a   _EVENT58
0000003b   EVENT59
0000003b   _EVENT59
0000003c   EVENT60
0000003c   _EVENT60
0000003d   EVENT61
0000003d   _EVENT61
0000003e   EVENT62
0000003e   _EVENT62
0000003f   EVENT63
0000003f   _EVENT63
00000040   EVENT64
00000040   _EVENT64
00000041   EVENT65
00000041   _EVENT65
00000042   EVENT66
00000042   _EVENT66
00000043   EVENT67
00000043   _EVENT67
00000044   EVENT68
00000044   _EVENT68
00000045   EVENT69
00000045   _EVENT69
00000046   EVENT70
00000046   _EVENT70
00000047   EVENT71
00000047   _EVENT71
00000048   EVENT72
00000048   _EVENT72
00000049   EVENT73
00000049   _EVENT73
0000004a   EVENT74
0000004a   _EVENT74
0000004b   EVENT75
0000004b   _EVENT75
0000004c   EVENT76
0000004c   _EVENT76
0000004d   EVENT77
0000004d   _EVENT77
0000004e   EVENT78
0000004e   _EVENT78
0000004f   EVENT79
0000004f   _EVENT79
00000050   EVENT80
00000050   _EVENT80
00000051   EVENT81
00000051   _EVENT81
00000052   EVENT82
00000052   _EVENT82
00000053   EVENT83
00000053   _EVENT83
00000054   EVENT84
00000054   _EVENT84
00000055   EVENT85
00000055   _EVENT85
00000056   EVENT86
00000056   _EVENT86
00000057   EVENT87
00000057   _EVENT87
00000058   EVENT88
00000058   _EVENT88
00000059   EVENT89
00000059   _EVENT89
0000005a   EVENT90
0000005a   _EVENT90
0000005b   EVENT91
0000005b   _EVENT91
0000005c   EVENT92
0000005c   _EVENT92
0000005d   EVENT93
0000005d   _EVENT93
0000005e   EVENT94
0000005e   _EVENT94
0000005f   EVENT95
0000005f   _EVENT95
00000060   EVENT96
00000060   _EVENT96
00000061   EVENT97
00000061   _EVENT97
00000062   EVENT98
00000062   _EVENT98
00000063   EVENT99
00000063   _EVENT99
00000064   EVENT100
00000064   _EVENT100
00000065   EVENT101
00000065   _EVENT101
00000066   EVENT102
00000066   _EVENT102
00000067   EVENT103
00000067   _EVENT103
00000068   EVENT104
00000068   _EVENT104
00000069   EVENT105
00000069   _EVENT105
0000006a   EVENT106
0000006a   _EVENT106
0000006b   EVENT107
0000006b   _EVENT107
0000006c   EVENT108
0000006c   _EVENT108
0000006d   EVENT109
0000006d   _EVENT109
0000006e   EVENT110
0000006e   _EVENT110
0000006f   EVENT111
0000006f   _EVENT111
00000070   EVENT112
00000070   _EVENT112
00000071   EVENT113
00000071   _EVENT113
00000072   EVENT114
00000072   _EVENT114
00000073   EVENT115
00000073   _EVENT115
00000074   EVENT116
00000074   _EVENT116
00000075   EVENT117
00000075   _EVENT117
00000076   EVENT118
00000076   _EVENT118
00000077   EVENT119
00000077   _EVENT119
00000078   EVENT120
00000078   _EVENT120
00000079   EVENT121
00000079   _EVENT121
0000007a   EVENT122
0000007a   _EVENT122
0000007b   EVENT123
0000007b   _EVENT123
0000007c   EVENT124
0000007c   _EVENT124
0000007d   EVENT125
0000007d   _EVENT125
0000007e   EVENT126
0000007e   _EVENT126
0000007f   EVENT127
0000007f   _EVENT127
00000100   trace$size
00004e20   GBL_CLKIN
00005dc0   CLK_PRD
00005dc0   _CLK_PRD
00008000   CLK_INTBIT
000493e0   GBL_FREQ
01c21000   CLK_REGS
01c21000   _CLK_REGS
04000000   DDR$L
11800000   LOG_system
11800018   _trace
11800018   trace
11800060   KNL_swi
11800060   _KNL_swi
1180009c   IDL_END
118000b0   IDL_END$
118000b4   PRD_clock
118000b4   _PRD_clock
118000b8   CLK_null
c0000000   .data
c0000000   DDR$B
c0000000   _DDR_base
c0000000   ___data__
c0000000   ___edata__
c0000000   edata
c4000000   .text
c4000000   ___text__
c4000f74   _main
c4003bc0   __divd
c4004240   ___throw
c4007820   _fwrite
c4007c80   __printfi
c400a240   _fputs
c400ce40   __divull
c400f9c0   __divul
c400fd00   _setvbuf
c4011920   __Fac_tidy
c40125a0   _fputc
c40125a0   _putc
c40146c0   _fclose
c40147e0   _fgetc
c40147e0   _getc
c40150e0   _HOSTlseek
c40172e0   ___rethrow
c40174e0   __wrt_ok
c40177e0   _fflush
c40178e0   _ungetc
c4017de0   _HOSTopen
c4019ac0   _atoi
c4019ba0   _close
c4019d60   _memset
c4019f20   _HOSTread
c401a0a0   _HOSTwrite
c401bd20   ___nw__FUi
c401bea0   __cleanup
c401c020   __divu
c401c0e0   __doflush
c401c1a0   _atexit
c401c620   _fseek
c401c6e0   _ftell
c401c7a0   _lseek
c401c860   _ltoa
c401c920   _read
c401cc20   _wmemmove
c401cce0   _write
c401ce60   _HOSTclose
c401e080   __divli
c401e260   __fixdli
c401e3a0   __rd_ok
c401e620   _memcpy
c401e840   ___dl__FPv
c401e8c0   __fltlid
c401e940   __llshl
c401ec40   _fprintf
c401ecc0   _readmsg
c401ef40   _ungetwc
c401efc0   _unlink
c401f040   _wmemcpy
c401f540   __subcull
c401f660   _longjmp
c401f6c0   _memccpy
c401f720   _memmove
c401f840   _setlocale
c401f8a0   _writemsg
c401f8f8   C$$IO$$
c401f940   ___adelete
c401fec0   ___isinf
c401ffc0   __llshru
c4020000   __remli
c4020240   _fgetpos
c40202c0   _mbrtowc
c4020300   _mbtowc
c4020340   __setjmp
c4020340   _setjmp
c4020380   _strcmp
c40203c0   _strlen
c4020440   _wcrtomb
c4020480   _wcslen
c4020540   __Atexit
c40206a0   __negll
c40206c0   __nop
c4020760   C$$EXIT
c4020760   _abort
c4020ba0   _fgetwc
c4020bc0   _fputwc
c4020be0   _fsetpos
c4020d00   _remove
c4020de0   _tolower
c4020e00   _toupper
c4020e60   _wctomb
c4020fe0   ___cinit__
c4020fe0   ___etext__
c4020fe0   cinit
c4020fe0   etext
c4026558   LNK_F_init
c4026570   LNK_rcloop
c4026634   LNK_rdrtry
c4026644   LNK_rrloop
c4026704   LNK_wrrtry
c4026710   LNK_wrloop
c40267e0   LNK_newin
c4026914   LNK_newout
c4026aa0   _EXC_nmi
c4026d80   _EXC_init
c4027570   SWI_F_post
c4027570   _SWI_post
c40276e4   SWI_F_exec
c402778c   SWI_F_run
c402778c   SWI_RUNFXN
c40279c0   PRD_F_swi
c4027c44   PRD_F_tick
c4027d40   _free
c4027d64   _malloc
c4027dc4   _realloc
c4027ea8   _memalign
c4027f6c   _calloc
c4028240   _KNL_run
c4028480   _MEM_alloc
c4028854   _KNL_tick
c4028880   _MEM_free
c4028c40   PIP_F_take
c4028cb8   PIP_F_give
c40291a0   _TSK_setup
c4029350   CLK_F_isr
c4029490   _CLK_itime
c4029638   KNL_glue
c40297a0   _TSK_exit
c4029b40   _KNL_check
c4029c08   _KNL_idle
c4029c30   _KNL_max
c4029d80   _SEM_post
c4029e60   _KNL_exit
c4029ea0   _KNL_enter
c4029fc0   _SYS_exit
c402a060   _KNL_ipost
c402a0e0   _KNL_post
c402a160   _LCK_post
c402a180   _LCK_pend
c402a1e0   _LOG_event
c402a2e0   _SYS_error
c402a340   FXN_F_nop
c402a344   FXN_F_run
c402a344   _FXN_F_run
c402a380   FXN_F_zero
c402a400   IDL_F_busy
c402a460   _SEM_pend
c402a4c0   _STS_delta
c402a4ec   STS_F_add
c402a4ec   _STS_add
c402a508   _STS_reset
c402a520   _SYS_abort
c402a5e0   IDL_F_stub
c402a620   RTA_F_andn
c402a638   RTA_F_or
c402a6e0   _FXN_F_nop
c402a720   IDL_F_loop
c402a720   _IDL_loop
c402a740   _STS_set
c402a780   _UTL_halt
c402bef4   _errno
c402c8c4   _cin__3std
c402dba8   __ftable
c402dc98   __tmpnams
c402dd38   __ft_end
c402dd3c   _dtors
c402e1e0   _KNL_dummy
c402e41c   _TSK_ATTRS
c402e478   _OBJ_table
c402e56c   _C_locale
c402e5f8   __tz
c402e630   ___TID_v
c402e68c   __lock
c402e690   __unlock
c40320b0   __ctypes_
c4033fa0   _RTDX_Poll
c40342a0   BIOS_init
c40342a0   _BIOS_init
c40344d0   BIOS_start
c4034620   _c_int00
c40346e0   _MEM_init
c40347a0   _TSK_init
c4034ff4   TRC_cinit
c4034ff8   TRC_R_mask
c4035400   __stack
c4035800   trace$buf
c4035c00   $bss
c4035c00   .bss
c4035c00   ___bss__
c4035d18   CLK_R_time
c4035d40   _CLK_D_prd
c4035d4c   PRD_D_tick
c4035d50   PRD_D_cur
c4035da4   _GBL_clkIn
c4035da8   _GBL_freq
c4035dc0   _SYS
c4035dcc   _SWI_data
c4035ddc   SWI_D_lock
c4035e68   _KNL_wFlag
c4035e6c   _KNL_wList
c4035e70   _KNL_alarm
c4035e80   _KNL_set
c4035ebc   DDR
c4035ebc   _DDR
c4035ef8   _HWI_data
c4035f08   HWI_D_bss
c4035f6c   _TSK_pid
c4035f70   _TSK
c4035f8c   _MEM
c4035f94   ___end__
c4035f94   end
c4035fa0   TSK_idle
c4035fa0   _TSK_idle
c4036000   HWI_A_VECS
c4036000   hwi0
c4036020   hwi1
c4036040   hwi2
c4036060   hwi3
c4036080   hwi4
c40360a0   hwi5
c40360c0   hwi6
c40360e0   hwi7
c4036100   hwi8
c4036120   hwi9
c4036140   hwi10
c4036160   hwi11
c4036180   hwi12
c40361a0   hwi13
c40361c0   hwi14
c40361e0   hwi15
c4036200   __CIOBUF_
c4036454   RTA_toHost
c4036470   ___pinit__
c4036470   pinit
c40364a8   SYS$config
ffffffff   CACHE_L1D
ffffffff   CACHE_L1P
ffffffff   CACHE_L2
ffffffff   IRAM
ffffffff   L3_CBA_RAM
ffffffff   _CACHE_L1D
ffffffff   _CACHE_L1P
ffffffff   _CACHE_L2
ffffffff   _IRAM
ffffffff   ___binit__
ffffffff   binit
[1253 symbols]
  • Mark,
       Have you reviewed the DSP/BIOS5 Startup Sequence as part of the DSP/BIOS5 User's Guide? It gives a pretty detailed overview of the start up sequence for DSP/BIOS5
    I wouldn't expect your main function to be reached until the BIOS_Init function returns. This is outlined in the Section 2.8 of the User's Guide.
