TDA4VM: reboot fail on custom board
Part Number: TDA4VM
Other Parts Discussed in Thread: PCM3168A,
Hi TI,
Our custom board always reboot failed, block at "[   46.350342] reboot: Restarting system", what will result in this? could  you please help?
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:47 +0800)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -19
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
U-Boot 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   Could not get PHY for ethernet@46000000: addr 0
am65_cpsw_nuss_slave ethernet@46000000: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
54 bytes read in 8 ms (5.9 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
527528 bytes read in 32 ms (15.7 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 527528 bytes: Success!
78708 bytes read in 14 ms (5.4 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 78708 bytes: Success!
Load Remote Processor 4 with data@addr=0x82000000 78708 bytes: Success!
Load Remote Processor 5 with data@addr=0x82000000 78708 bytes: Success!
187480 bytes read in 18 ms (9.9 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 187480 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 187480 bytes: Success!
10489872 bytes read in 444 ms (22.5 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 10489872 bytes: Success!
19137024 bytes read in 798 ms (22.9 MiB/s)
97623 bytes read in 13 ms (7.2 MiB/s)
10737 bytes read in 9 ms (1.1 MiB/s)
   Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.41-g4c2eade9f7 (qywu@op01) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT Tue Oct 26 17:24:36 CST 2021
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000fbffffff]
[    0.000000]   node   0: [mem 0x00000000fc000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x000000088fffffff]
[    0.000000]   node   0: [mem 0x0000000890000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Failed to reserve 512 MiB
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0b959c33-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
[    0.000000] Memory: 2319360K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 1874944K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a00b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008371] Console: colour dummy device 80x25
[    0.012932] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023602] pid_max: default: 32768 minimum: 301
[    0.028347] LSM: Security Framework initializing
[    0.033091] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040656] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049595] rcu: Hierarchical SRCU implementation.
[    0.054647] Platform MSI: msi-controller@1820000 domain created
[    0.060890] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070189] EFI services will not be available.
[    0.074938] smp: Bringing up secondary CPUs ...
[    0.080120] Detected PIPT I-cache on CPU1
[    0.080142] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.080153] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000
[    0.080187] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.080240] smp: Brought up 1 node, 2 CPUs
[    0.109585] SMP: Total of 2 processors activated.
[    0.114390] CPU features: detected: 32-bit EL0 Support
[    0.119645] CPU features: detected: CRC32 instructions
[    0.133314] CPU: All CPU(s) started at EL2
[    0.137510] alternatives: patching kernel code
[    0.142492] devtmpfs: initialized
[    0.150874] KASLR disabled due to lack of seed
[    0.155528] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.165489] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.172625] pinctrl core: initialized pinctrl subsystem
[    0.178179] DMI not present or invalid.
[    0.182375] NET: Registered protocol family 16
[    0.187137] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.194459] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.202418] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.210693] thermal_sys: Registered thermal governor 'step_wise'
[    0.210695] thermal_sys: Registered thermal governor 'power_allocator'
[    0.217086] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.230713] ASID allocator initialised with 65536 entries
[    0.251338] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.258194] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.264951] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.272615] cryptd: max_cpu_qlen set to 1000
[    0.278475] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.287350] vsys_3v3: supplied by evm_12v0
[    0.291660] vsys_5v0: supplied by evm_12v0
[    0.296272] iommu: Default domain type: Translated
[    0.301407] SCSI subsystem initialized
[    0.305529] mc: Linux media interface: v0.10
[    0.309905] videodev: Linux video capture interface: v2.00
[    0.315536] pps_core: LinuxPPS API ver. 1 registered
[    0.320607] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.329943] PTP clock support registered
[    0.333961] EDAC MC: Ver: 3.0.0
[    0.337703] FPGA manager framework
[    0.341210] Advanced Linux Sound Architecture Driver Initialized.
[    0.347804] clocksource: Switched to clocksource arch_sys_counter
[    0.354210] VFS: Disk quotas dquot_6.6.0
[    0.358251] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.367946] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.374252] NET: Registered protocol family 2
[    0.378829] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.387374] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.396139] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.404335] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.412268] TCP: Hash tables configured (established 32768 bind 32768)
[    0.419011] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.425901] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.433293] NET: Registered protocol family 1
[    0.437981] RPC: Registered named UNIX socket transport module.
[    0.444035] RPC: Registered udp transport module.
[    0.448849] RPC: Registered tcp transport module.
[    0.453652] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.460235] PCI: CLS 0 bytes, default 64
[    0.464584] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.474755] Initialise system trusted keyrings
[    0.479365] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.487606] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.493807] NFS: Registering the id_resolver key type
[    0.498995] Key type id_resolver registered
[    0.503268] Key type id_legacy registered
[    0.507388] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.514236] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.521871] 9p: Installing v9fs 9p2000 file system support
[    0.546903] Key type asymmetric registered
[    0.551090] Asymmetric key parser 'x509' registered
[    0.556088] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.563647] io scheduler mq-deadline registered
[    0.568271] io scheduler kyber registered
[    0.573444] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.579626] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.587961] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.594222] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.601942] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.610022] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.618997] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.627860] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.635528] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.648183] brd: module loaded
[    0.654053] loop: module loaded
[    0.657591] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[    0.665517] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.41-g4c2eade9f7 #2
[    0.672716] Hardware name: Texas Instruments K3 J721E SoC (DT)
[    0.678672] Call trace:
[    0.681175]  dump_backtrace+0x0/0x1a0
[    0.684911]  show_stack+0x18/0x68
[    0.688294]  dump_stack+0xd0/0x12c
[    0.691764]  sysfs_warn_dup+0x60/0x80
[    0.695498]  sysfs_create_dir_ns+0xe0/0xf8
[    0.699679]  kobject_add_internal+0x98/0x288
[    0.704035]  kobject_add+0x94/0x100
[    0.707597]  device_add+0xe0/0x748
[    0.711066]  platform_device_add+0x100/0x238
[    0.715423]  platform_device_register_full+0xcc/0x150
[    0.720581]  dma_buf_phys_init+0x6c/0x9c
[    0.724583]  do_one_initcall+0x54/0x1b8
[    0.728497]  kernel_init_freeable+0x1d4/0x23c
[    0.732944]  kernel_init+0x14/0x114
[    0.736500]  ret_from_fork+0x10/0x34
[    0.740155] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
[    0.753319] megasas: 07.714.04.00-rc1
[    0.758195] libphy: Fixed MDIO Bus: probed
[    0.762832] tun: Universal TUN/TAP device driver, 1.6
[    0.768233] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.774639] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.780707] sky2: driver version 1.30
[    0.784935] VFIO - User Level meta-driver version: 0.3
[    0.790580] i2c /dev entries driver
[    0.794729] sdhci: Secure Digital Host Controller Interface driver
[    0.801050] sdhci: Copyright(c) Pierre Ossman
[    0.805666] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.811965] ledtrig-cpu: registered to indicate activity on CPUs
[    0.818261] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.825348] optee: probing for conduit method.
[    0.829903] optee: revision 3.12 (3d47a131)
[    0.830137] optee: initialized driver
[    0.839356] NET: Registered protocol family 17
[    0.843962] 9pnet: Installing 9P2000 support
[    0.848350] Key type dns_resolver registered
[    0.852826] Loading compiled-in X.509 certificates
[    0.861590] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.867918] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.875966] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[    0.902099] random: fast init done
[    0.924527] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.932082] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.938137] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.944159] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.953258] omap_i2c 2020000.i2c: bus 3 rev0.12 at 400 kHz
[    0.959473] pca953x 4-0020: supply vcc not found, using dummy regulator
[    0.966290] pca953x 4-0020: using no AI
[    0.991848] pca953x 4-0020: failed writing register
[    0.996886] pca953x: probe of 4-0020 failed with error -121
[    1.002927] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
[    1.008949] omap_i2c 2040000.i2c: bus 5 rev0.12 at 100 kHz
[    1.014883] omap_i2c 2050000.i2c: bus 6 rev0.12 at 100 kHz
[    1.021246] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.031206] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.040001] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    1.049822] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.067397] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.075089] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.083367] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.091643] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.100471] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.108143] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.116426] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.124702] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.133491] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.141159] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.149435] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    1.157711] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.166834] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    1.176714] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.183473] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.192411] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.202554] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.209312] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.217241] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    1.226596] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    1.235341] printk: console [ttyS2] enabled
[    1.243781] printk: bootconsole [ns16550a0] disabled
[    1.254224] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    1.263157] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    1.272712] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    1.283225] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    1.293379] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    1.303620] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    1.314311] scsi host0: ufshcd
[    1.359810] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.367455] libphy: 46000f00.mdio: probed
[    1.371875] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    1.378601] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.392301] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.401044] mmc0: CQHCI version 5.10
[    1.405091] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.411006] mmc1: CQHCI version 5.10
[    1.420693] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.427518] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.434400] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.441201] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.447721] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.455502] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.465065] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.472608] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.480702] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.488852] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.497599] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.505155] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.513295] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.521440] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.530129] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.537701] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.545789] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    1.553868] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.562840] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.572873] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    1.585544] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    1.590781] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[    1.597829] mtd: 47040000.spi.0: skipping zero sized partition
[    1.603660] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    1.610258] Creating 7 MTD partitions on "47040000.spi.0":
[    1.615729] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.621759] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.627427] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.633210] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.638766] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    1.644506] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    1.650662] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    1.658528] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    1.665403] spi-nor: probe of spi1.0 failed with error -2
[    1.691463] mmc0: Command Queue Engine enabled
[    1.695905] mmc0: new DDR MMC card at address 0001
[    1.700927] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    1.705522] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    1.711439] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.719150] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    1.725088] libphy: 46000f00.mdio: probed
[    1.729113] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
[    1.736622] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    1.743493] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.744426] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    1.756282]  mmcblk0: p1 p2
[    1.761721] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    1.765326] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    1.769545] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    1.769547] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    1.769550] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    1.769553] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    1.776867] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.782237] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    1.788680] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.795524] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    1.807851] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    1.809325] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    1.816774] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.821571] cdns-ufshcd 4e84000.ufs: last intr at 1651508 us, last intr status=0x404
[    1.833600] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.835026] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    1.843192] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.848909] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    1.856633] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.864092] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    1.871558] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.879624] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    1.888961] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.896714] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    1.896717] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    1.896721] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    1.896742] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    1.902729] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.910959] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    1.917212] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.924681] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    1.930751] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.936825] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    1.949247] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.955306] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    1.955309] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    1.963394] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.969716] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    1.977790] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    1.984119] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    1.992364] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.998697] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    2.012924] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.018834] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    2.018837] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    2.018841] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    2.026933] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.033245] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    2.033247] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    2.033250] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    2.041335] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.047652] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    2.055911] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.062232] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.069978] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.076030] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1652627 us
[    2.076032] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.076034] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.076036] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.076038] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.076041] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    2.081358] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.189751] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.197834] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.206410] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.213912] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.222003] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.230087] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.239615] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    2.247050] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    2.254419] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    2.261748] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    2.269844] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.277208] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.284708] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.292797] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.300897] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.309544] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.317042] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.325127] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.333211] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.341788] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.349282] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.357371] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.365456] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.380947] ALSA device list:
[    2.383913]   No soundcards found.
[    2.474518] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.482647] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.490218] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.498306] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.506395] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.514792] Waiting for root device PARTUUID=0b959c33-02...
[    2.514995] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.527849] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.535942] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.544082] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.552751] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.560291] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.568380] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.576497] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.626208] mmc1: new ultra high speed DDR50 SDHC card at address 5048
[    2.633042] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[    2.640335]  mmcblk1: p1 p2
[    2.644078] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.651565] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.659644] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.667725] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.676281] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.683779] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.691862] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.699940] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.708472] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.715967] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.724045] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.732124] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.061160] EXT4-fs (mmcblk1p2): recovery complete
[    3.066813] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.074921] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    3.085259] devtmpfs: mounted
[    3.088525] Freeing unused kernel memory: 1856K
[    3.093077] Run /sbin/init as init process
[    3.262524] systemd[1]: System time before build time, advancing clock.
[    3.316035] NET: Registered protocol family 10
[    3.320932] Segment Routing with IPv6
[    3.333912] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.349342] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.369006] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    3.390725] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[    3.432629] systemd[1]: Set hostname to <j7-evm>.
[    3.535488] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.553749] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.569706] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.585858] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.605196] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.622623] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.640706] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.658548] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.676224] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.693307] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.710929] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.728743] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.746458] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.764369] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.782882] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.800818] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.817318] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.833665] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.850966] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.868018] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.886174] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.903936] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.922360] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.940401] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.959152] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.976791] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    3.995214] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.013750] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.031627] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.049187] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.066226] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.082484] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.100506] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.117017] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.134409] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.150961] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.168458] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.187046] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.204785] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.221433] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.238052] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.255987] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.275644] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.293598] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.310722] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.328475] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.346297] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.362425] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.378300] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.394412] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.412607] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.430884] systemd[1]: Configuration file /lib/systemd/system/strongswan-starter.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.448433] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.464616] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.480999] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.497193] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.513570] systemd[1]: Configuration file /lib/systemd/system/rngd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.529638] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.547318] systemd[1]: Configuration file /lib/systemd/system/ofono.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.563635] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.580242] systemd[1]: Configuration file /lib/systemd/system/kdump.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.596357] systemd[1]: Configuration file /lib/systemd/system/irqbalanced.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.613008] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.629449] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.646023] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.662899] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.679509] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.697243] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.713918] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.730773] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.747627] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.764565] systemd[1]: Configuration file /lib/systemd/system/docker.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.780934] systemd[1]: Configuration file /lib/systemd/system/docker.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.796983] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[    4.816697] systemd[1]: Configuration file /lib/systemd/system/demo.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.832847] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.848998] systemd[1]: Configuration file /lib/systemd/system/crond.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.865219] systemd[1]: Configuration file /lib/systemd/system/bt-enable.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.881924] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.899183] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.916119] systemd[1]: Configuration file /lib/systemd/system/atd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.932930] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.951675] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.968031] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.985369] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.002762] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.018915] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.035848] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.053570] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.071817] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.088375] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.104963] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.121515] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.138561] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.157023] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.174708] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.190738] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.208179] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.225485] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.243446] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.260261] systemd[1]: Configuration file /lib/systemd/system/psplash-systemd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.277384] systemd[1]: Configuration file /lib/systemd/system/psplash-start.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.294376] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.310876] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.328285] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.344971] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.361862] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.378510] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.394977] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.412791] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.431119] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.448861] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.466026] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.483124] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.500270] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.517510] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.534390] systemd[1]: Configuration file /lib/systemd/system/var-volatile-srv.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.551780] systemd[1]: Configuration file /lib/systemd/system/var-volatile-spool.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.569327] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.586743] systemd[1]: Configuration file /lib/systemd/system/var-volatile-cache.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.604275] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.620266] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.637916] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.655331] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.671840] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.688698] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.706985] random: systemd: uninitialized urandom read (16 bytes read)
[    5.713698] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    5.726023] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    5.735915] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    5.755876] random: systemd: uninitialized urandom read (16 bytes read)
[    5.763093] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    5.783866] random: systemd: uninitialized urandom read (16 bytes read)
[    5.790991] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    5.811975] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    5.835910] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    5.859910] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    5.879858] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    5.899849] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    5.919851] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    5.944857] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    5.967878] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    5.987970] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.006411] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    6.028012] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    6.060699] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    6.069006] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    6.092057] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    6.112098] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    6.136021] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    6.155962] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    6.178473] systemd[1]: Mounting Huge Pages File System...
[    6.202437] systemd[1]: Mounting POSIX Message Queue File System...
[    6.230446] systemd[1]: Mounting Kernel Debug File System...
[    6.255222] systemd[1]: Mounting Temporary Directory (/tmp)...
[    6.278706] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    6.305952] systemd[1]: Starting Start psplash boot splash screen...
[    6.335626] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    6.361987] systemd[1]: Starting RPC Bind...
[    6.376045] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    6.396257] systemd[1]: Starting Journal Service...
[    6.404569] systemd-journald[163]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.431479] systemd[1]: Starting Load Kernel Modules...
[    6.436798] systemd-journald[163]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.462000] cryptodev: loading out-of-tree module taints kernel.
[    6.470208] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.479711] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    6.491946] cryptodev: driver 1.10 loaded.
[    6.502615] systemd[1]: Starting udev Coldplug all Devices...
[    6.530941] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    6.552218] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    6.576174] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    6.604177] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    6.628167] systemd[1]: Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Temporary Directory (/tmp).
[    6.648177] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    6.795017] systemd-journald[163]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
[  OK  ] Started udev Coldplug all Devices.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started D-Bus System Message Bus.
[    7.498675] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
         Starting Print notice about GPLv3 packages[    7.514370] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.529038] ina2xx 3-0040: error configuring the device: -121
[    7.534943] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
         Starting IPv6 Packet Filtering Framework..[    7.546577] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.560594] ina2xx 3-0041: error configuring the device: -121
[    7.564339] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
         Starting IPv4 Packet Filtering Framework..[    7.581553] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.595626] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[  OK  ] Started irqbalance daemon.
[    7.612820] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
         Starting Telephony service...
[    7.632436] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
         Starting rc.pvr.service...
[    7.647195] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
         Starting Login Service...
[    7.665196] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[  OK  ] Started Reboot and dump vmcore via [    7.680924] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
kexec.
[    7.702130] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[  OK  ] Started IPv6 Packet Filtering Frame[    7.716041] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
work.
[    7.725012] ina2xx 3-0042: error configuring the device: -121
[    7.727830] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Reached target Network ([    7.747632] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
Pre).
         Starting Network Service...
[    7.872280] PVR_K:  242: Read BVNC 22.104.208.318 from HW device registers
[  OK  ] Started Telephony service.[    7.883824] PVR_K:  242: RGX Device registered with BVNC 22.104.208.318
[    7.903250] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[    7.903655] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    7.903674] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.903684] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    7.903694] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.904207] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    7.904225] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    7.904236] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    7.904245] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.905118] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    7.905136] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.905145] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    7.905155] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.992474] Bluetooth: Core ver 2.22
[    7.992525] NET: Registered protocol family 31
[    7.992527] Bluetooth: HCI device and connection manager initialized
[    7.992535] Bluetooth: HCI socket layer initialized
[    7.992540] Bluetooth: L2CAP socket layer initialized
[    7.992547] Bluetooth: SCO socket layer initialized
[    8.086679] ina2xx 3-0043: error configuring the device: -121
[    8.087513] ina2xx 3-0044: error configuring the device: -121
[    8.103462] ina2xx 3-0045: error configuring the device: -121
[    8.104265] ina2xx 3-0046: error configuring the device: -121
[    8.108243] ina2xx 3-0047: error configuring the device: -121
[    8.116930] ina2xx 3-0048: error configuring the device: -121
[    8.119391] ina2xx 3-0049: error configuring the device: -121
[    8.119587] ina2xx 3-004a: error configuring the device: -121
[    8.119709] ina2xx 3-004b: error configuring the device: -121
[    8.121059] ina2xx 3-004c: error configuring the device: -121
[    8.121246] ina2xx 3-004d: error configuring the device: -121
[    8.135928] ina2xx 3-004e: error configuring the device: -121
[    8.136130] ina2xx 3-004f: error configuring the device: -121
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[  OK  ] Started Login Service.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[    8.849034] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[    8.871337] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.880596] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    8.893843] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.905519] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.918934] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    8.930711] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    8.943032] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    8.951177] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.977323] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.979845] random: crng init done
[    8.987827] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.988203] random: 7 urandom warning(s) missed due to ratelimiting
[    8.996308] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.015855] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.024814] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.035830] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.043933] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.052039] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Load/Save Random Seed.
[    9.131284] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.140303] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.151547] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[    9.154808] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.171375] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.185390] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.196034] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.208319] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.220674] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.220811] CAN device driver interface
[    9.270864] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.279335] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.292775] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.303872] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.316572] remoteproc remoteproc0: 4d80800000.dsp is available
[    9.320012] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.331862] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.344129] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.356815] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.371661] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.383841] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.392730] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.404047] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.416635] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.424228] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.439459] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.440822] remoteproc remoteproc0: attaching to 4d80800000.dsp
[    9.451825] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[    9.628932] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[    9.699212] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    9.793515] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.802463] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.816634] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.831387] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.847411] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.860259] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.875541] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.891851] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.908025] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.915565] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.930494] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.942514] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.024495] remoteproc remoteproc0: unsupported resource 65538
[   10.093852] platform 41000000.r5f: configured R5F for IPC-only mode
[   10.125892] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[   10.244334] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[   10.285394]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav-dev
        gstreamer1.0-libav
        gzip
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextl[   10.428384] remoteproc remoteproc1: 41000000.r5f is available
ib
        libgettextsrc
        libgmp-dev
        libgmp10
        libgmpxx4
        libidn2-0
        libidn2-dev
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline8
        libunistring-dev
        libunistring2
        m4-dev
        m4
        make
        nettle-dev
        nettle
        parted
        python3-rfc3987
        python3-strict-rfc3339
        tar
        which
        zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to [   10.467626] virtio_rpmsg_bus virtio0: rpmsg host is online
distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name p[   10.484482] am65-cpsw-nuss 46000000.ethernet: phy /bus@100000/bus@28380000/ethernet@46000000/mdio@f00/ethernet-phy@0 not found on slave 1
rinted in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[   10.597435] remoteproc remoteproc1: attaching to 41000000.r5f
[   10.616889]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[   10.623147] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.631909] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.647865] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.655996] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.672837] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.683861] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.695852] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.705216] platform 41000000.r5f: R5F core initialized in IPC-only mode
[   10.712015] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.722969] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.732692]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[   10.735904] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.755883] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.767858] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.792590] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[   10.899138] virtio_rpmsg_bus virtio1: rpmsg host is online
[   10.912335] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.915004] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[   10.919860] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.931899] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[   10.943180] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[   10.953014] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.961130] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.976859] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.987838] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.000420] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.012854]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[   11.015894] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.034876] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[   11.041800] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.051878] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.061434] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.074345] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.086831] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.099844] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.107976] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.113729] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
[   11.119835] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.135923] remoteproc remoteproc2: 4d81800000.dsp is available
[   11.141968] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.151438] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.163877] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.175836] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.234679] remoteproc remoteproc2: attaching to 4d81800000.dsp
[   11.384687] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.392253] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.407859] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.416094] platform 5c00000.r5f: configured R5F for IPC-only mode
[   11.422403] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.436637] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.447870] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.467240] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.483872] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.494703] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.502896] Unable to handle kernel paging request at virtual address ffff80001bffffff
[   11.510907] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.519038] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.531940] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.540706] Mem abort info:
[   11.543492]   ESR = 0x96000007
[   11.559627] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.569068] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.576021] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[   11.579825] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.599860] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.616330] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[   11.629343] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[   11.644634] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.652171] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.667839] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.674162]   EC = 0x25: DABT (current EL), IL = 32 bits
[   11.677980] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.696180] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.707840] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.718705] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.731836] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.741039] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.751262] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.763860] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.772057] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.852053] remoteproc remoteproc3: 5c00000.r5f is available
[   11.868666]   SET = 0, FnV = 0
[   11.908574]   EA = 0, S1PTW = 0
[   11.911708] Data abort info:
[   11.949382] remoteproc remoteproc3: attaching to 5c00000.r5f
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   11.987966] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[   12.025432]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[   12.041817]   ISV = 0, ISS = 0x00000007
[   12.096643] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   12.139417]   CM = 0, WnR = 0
[   12.156690] swapper pgtable: 64k pages, 48-bit VAs, pgdp=0000000082f10000
[   12.192183] virtio_rpmsg_bus virtio2: rpmsg host is online
[   12.224795] [ffff80001bffffff] pgd=00000008ffff0003, p4d=00000008ffff0003, pud=00000008ffff0003, pmd=00000008fffe0003, pte=0000000000000000
[   12.284063]  remoteproc3#vdev0buffer: registered virtio2 (type 7)
[   12.290299] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   12.299976] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   12.311872] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   12.323860] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.338838] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   12.346388] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   12.359864] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   12.367994] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.384836] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   12.392426] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   12.395842] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
[   12.403839] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   12.419868] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.428743] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   12.459830] Internal error: Oops: 96000007 [#1] PREEMPT SMP
[   12.465392] Modules linked in: crct10dif_ce snd_soc_j721e_evm ti_j721e_cpsw_virt_mac phy_can_transceiver ti_k3_r5_remoteproc(+) m_can_platform m_can vxd_dec ti_am335x_tscadc can_dev videobuf2_dma_sg v4l2_mem2mem videobuf2_dma_contig videobuf2_memops pruss videobuf2_v4l2 videobuf2_common sa2ul sha512_generic authenc ti_k3_dsp_remoteproc(+) cdns_dphy snd_soc_pcm3168a_i2c virtio_rpmsg_bus snd_soc_pcm3168a bluetooth ecdh_generic ecc rfkill pvrsrvkm(O) ina2xx cdns3_ti rti_wdt sch_fq_codel rpmsg_kdrv_switch cryptodev(O) ipv6
[   12.511321] CPU: 1 PID: 187 Comm: systemd-udevd Tainted: G           O      5.10.41-g4c2eade9f7 #2
[   12.520258] Hardware name: Texas Instruments K3 J721E SoC (DT)
[   12.526079] pstate: 00000005 (nzcv daif -PAN -UAO -TCO BTYPE=--)
[   12.532078] pc : rproc_handle_resources.constprop.0+0x94/0x168
[   12.537894] lr : rproc_boot+0x334/0x670
[   12.541717] sp : ffff80001302f7d0
[   12.545021] x29: ffff80001302f7d0 x28: ffff8000112e69b0
[   12.550319] x27: ffff00087ff2ba20 x26: ffffffffffffffff
[   12.555617] x25: ffff80001c000000 x24: ffff800010e09a08
[   12.556215] platform 5d00000.r5f: configured R5F for IPC-only mode
[   12.560914] x23: ffff000829fa9038 x22: 0000000000000000
[   12.560917] x21: ffff80001121c458 x20: ffff000829fa9000
[   12.560921] x19: 0000000000000000 x18: 0000000000000000
[   12.560924] x17: 0000000000000000 x16: 0000000000000000
[   12.588264] x15: 000000ddc85b4cc5 x14: ffffffffffffffff
[   12.593564] x13: ffffffffffffffff x12: ffffffffffffffff
[   12.598860] x11: ffffffffffffffff x10: ffffffffffffffff
[   12.604157] x9 : ffffffffffffffff x8 : ffffffffffffffff
[   12.609456] x7 : ffffffffffffffff x6 : ffff000829f63c00
[   12.614752] x5 : 0000000000000000 x4 : 0000000000000000
[   12.620047] x3 : 00000000000000fd x2 : 00000000ffffffff
[   12.625345] x1 : ffff80001c000003 x0 : ffff80001c000000
[   12.630645] Call trace:
[   12.633090]  rproc_handle_resources.constprop.0+0x94/0x168
[   12.638559]  rproc_boot+0x334/0x670
[   12.642035]  rproc_add+0x88/0x158
[   12.645346]  k3_dsp_rproc_probe+0x710/0x850 [ti_k3_dsp_remoteproc]
[   12.651524]  platform_drv_probe+0x54/0xa8
[   12.651527]  really_probe+0xe4/0x3b0
[   12.651529]  driver_probe_device+0x58/0xb8
[   12.651536]  device_driver_attach+0x74/0x80
[   12.667337]  __driver_attach+0x58/0xe0
[   12.671075]  bus_for_each_dev+0x70/0xc0
[   12.674896]  driver_attach+0x24/0x30
[   12.678458]  bus_add_driver+0x14c/0x1f0
[  OK  ] Found device /dev/mmcblk0p1.
[   12.682279]  driver_register+0x64/0x120
[   12.691566]  __platform_driver_register+0x48/0x58
[   12.696261]  k3_dsp_rproc_driver_init+0x20/0x10000 [ti_k3_dsp_remoteproc]
[   12.703042]  do_one_initcall+0x54/0x1b8
[   12.703053]  do_init_module+0x54/0x208
[   12.710602]  load_module+0x1f28/0x24c8
[   12.714341]  __do_sys_finit_module+0xb8/0xf8
[   12.718598]  __arm64_sys_finit_module+0x20/0x30
[   12.723117]  el0_svc_common.constprop.0+0x78/0x1a0
[   12.727892]  do_el0_svc+0x24/0x90
         Starting File System Check on /dev/mmcblk0p1   12.731197]  el0_svc+0x14/0x20
0m...
[   12.737744] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[   12.739781]  el0_sync_handler+0xb0/0xb8
[   12.739784]  el0_sync+0x180/0x1c0
[   12.739792] Code: 128002b3 91274021 97ffebcc 1400002e (b87a6b20)
[   12.739797] ---[ end trace 68f3f71a50a7ba61 ]---
[  OK  ] Started File System Check on /dev/mmcblk0p1.
         Mounting /run/media/mmcblk0p1...
[  OK  ] Mounted /run/media/mmcblk0p1.
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1   13.099950] remoteproc remoteproc4: 5d00000.r5f is available
0m...
[  OK  ] Found device /dev/mmcblk0p2.
         Starting File System Check on /dev/mmcblk0p2...
[  OK  ] Started File System Check on /dev/mmcblk1p1.
         Mounting /run/media/mmcblk1p1...
[  OK  ] Started File System Check on /dev/mmcblk0p2.
         Mounting /run/media/mmcblk0p2...
[   13.314814] remoteproc remoteproc4: attaching to 5d00000.r5f
[  OK  ] Mounted /run/media/mmcblk1p1.
[   13.344529] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Mounted /run/media/mmcblk0p2.
[   13.421268] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[   13.561875]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[   13.672100] virtio_rpmsg_bus virtio3: rpmsg host is online
[   13.693135] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   13.703230] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   13.716044] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   13.725383]  remoteproc4#vdev0buffer: registered virtio3 (type 7)
[   13.731715] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   13.744956] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   13.758328] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   13.771015] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   13.783863] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   13.801450] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   13.808973] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   13.823886] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   13.835851] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   13.836942] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached
[   13.848385] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   13.994246] usbcore: registered new interface driver usbfs
[   14.048210] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   14.058061] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   14.071848] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   14.083520] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.102036] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.112458] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.127005] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.151873] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.166432] remoteproc remoteproc6: b034000.pru is available
[   14.184241] usbcore: registered new interface driver hub
[   14.189719] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.199836] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.203920] platform 5e00000.r5f: configured R5F for IPC-only mode
[   14.215853] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.236408] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.245335] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   14.256279] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   14.264547] remoteproc remoteproc7: b004000.rtu is available
[   14.267837] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   14.278312] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   14.291829] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.304822] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.315187] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.327820] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.335953] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.352473] usbcore: registered new device driver usb
[   14.357713] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.365330] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.373479] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.387855] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.392420] remoteproc remoteproc8: b00a000.txpru is available
[   14.400342] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   14.412195] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   14.419689] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   14.431963] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[   14.441024] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   14.449129] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.459512] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.471850] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.482106] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.493429] remoteproc remoteproc5: 5e00000.r5f is available
[   14.499255] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.510873] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.520644] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.531164] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.539273] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.577822] remoteproc remoteproc5: attaching to 5e00000.r5f
[   14.590442] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   14.599262] remoteproc remoteproc9: b038000.pru is available
[   14.599862] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   14.605058] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   14.623997] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   14.635847] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   14.647855] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.659946] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.667507] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.675632] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.691851] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.701086] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.711865] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.718278] PVR_K:  1040: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   14.719979] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.739840] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.748756] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   14.765397] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| [   14.779856] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
.'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  [   14.793188] platform 5e00000.r5f: R5F core initialized in IPC-only mode
|___|  |__|  |_| |___|_| |___|___|_|
              |___|     [   14.805077] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
               |___|
Arago Project http://arago-p[   14.823826] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
roject.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm [   14.833227] remoteproc remoteproc10: b006000.rtu is available
login: [   14.844732] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.855886] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.870044] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.883871] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.899707] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.911965] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.927863] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.939917] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.956400] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   14.971918] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   14.983826] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   14.995839] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   15.011850] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.016285] remoteproc remoteproc11: b00c000.txpru is available
[   15.026206] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.031843]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[   15.033758] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.059853] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.067957] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.080621] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.088129] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.093625] remoteproc remoteproc12: b134000.pru is available
[   15.099816] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.110300] virtio_rpmsg_bus virtio4: rpmsg host is online
[   15.115833] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.116365] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[   15.124622] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   15.139900] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[   15.147080] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   15.152989]  remoteproc5#vdev0buffer: registered virtio4 (type 7)
[   15.159828] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   15.168762] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   15.176861] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.188793] remoteproc remoteproc13: b104000.rtu is available
[   15.194645] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.202162] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.215821] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.227891] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.228072] remoteproc remoteproc14: b10a000.txpru is available
[   15.244631] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.255841] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.263811] remoteproc remoteproc5: remote processor 5e00000.r5f is now attached
[   15.267838] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.283839] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.288377] platform 5f00000.r5f: configured R5F for IPC-only mode
[   15.296373] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   15.308266] remoteproc remoteproc16: b138000.pru is available
[   15.308286] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   15.323006] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[   15.327829] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   15.340158] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   15.346319] remoteproc remoteproc17: b106000.rtu is available
[   15.351824] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.364864] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.372373] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.383834] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.384265] remoteproc remoteproc15: 5f00000.r5f is available
[   15.391939] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.397785] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.419841] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.421249] remoteproc remoteproc18: b10c000.txpru is available
[   15.427951] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.447832] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.456721] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   15.464052] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   15.471546] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   15.483827] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   15.491950] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.505746] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.513314] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.527840] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.535971] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.548688] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.559858] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.567955] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.579840] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.588745] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   15.600248] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   15.611846] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   15.619943] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   15.631845] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.692052] remoteproc remoteproc15: attaching to 5f00000.r5f
[   15.725917] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[   15.748132]  remoteproc15#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[   15.774338] virtio_rpmsg_bus virtio5: rpmsg host is online
[   15.810514]  remoteproc15#vdev0buffer: registered virtio5 (type 7)
[   15.816926] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.824482] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.832729] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.847863] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.864908] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.877450] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.891837] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.899969] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.916516] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   15.928030] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   15.939835] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   15.947956] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   15.959843] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.022862] remoteproc remoteproc15: remote processor 5f00000.r5f is now attached
[   16.039270] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   16.047843] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   16.053441] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   16.065629] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   16.079889] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   16.091929] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.111981] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   16.123858] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   16.133974] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   16.147834] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.156755] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   16.168260] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   16.179876] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   16.188009] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   16.196141] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.477700] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   16.485236] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   16.499845] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   16.511857] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.528878] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   16.536402] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   16.551841] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   16.559980] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.572476] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   16.583949] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   16.591477] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   16.603824] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   16.611940] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.624841] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   16.635833] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   16.643924] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   16.655818] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.128318] xhci-hcd xhci-hcd.2.auto: can't setup: -110
[   26.133546] xhci-hcd xhci-hcd.2.auto: USB bus 1 deregistered
[   26.139242] xhci-hcd: probe of xhci-hcd.2.auto failed with error -110
[   26.145795] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.151286] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[   26.159311] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[   26.168731] xhci-hcd xhci-hcd.3.auto: irq 606, io mem 0x06410000
[   26.174899] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   26.183158] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   26.190369] usb usb1: Product: xHCI Host Controller
[   26.195237] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   26.201752] usb usb1: SerialNumber: xhci-hcd.3.auto
[   26.206895] hub 1-0:1.0: USB hub found
[   26.210679] hub 1-0:1.0: 1 port detected
[   26.215160] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.220779] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   26.221322] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[   26.228271] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   26.228281] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   26.235945] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   26.244965] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.252104] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   26.259446] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   26.266918] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   26.275735] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   26.281822] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   26.290469] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   26.297521] usb usb2: Product: xHCI Host Controller
[   26.297524] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   26.297526] usb usb2: SerialNumber: xhci-hcd.3.auto
[   26.298021] hub 2-0:1.0: USB hub found
[   26.306015] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   26.312864] hub 2-0:1.0: 1 port detected
[   26.318267] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.355870] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   26.363425] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   26.371646] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   26.379785] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.389008] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   26.396567] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   26.404693] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   26.412833] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.422301] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   26.436228] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   26.447252] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   26.455565] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   26.463688] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   33.847821] tlv71033: disabling
[   50.352132] mmc1: card 5048 removed
[   50.373702] JBD2: Error while async write back metadata bh 970.
[   50.373711] Aborting journal on device mmcblk1p2-8.
[   50.384563] JBD2: Error -5 detected when updating journal superblock for mmcblk1p2-8.
[   50.392440] JBD2: Error while async write back metadata bh 1019.
[   50.392447] JBD2: Error while async write back metadata bh 1027.
[   50.402452] JBD2: Error while async write back metadata bh 1029.
[   50.408480] JBD2: Error while async write back metadata bh 1041.
[   50.414485] JBD2: Error while async write back metadata bh 1045.
[   50.420515] JBD2: Error while async write back metadata bh 1750.
[   50.426514] JBD2: Error while async write back metadata bh 1752.
[   50.432514] JBD2: Error while async write back metadata bh 1763.
[   50.438507] JBD2: Error while async write back metadata bh 1766.
[   50.444501] JBD2: Error while async write back metadata bh 1767.
[   50.450497] JBD2: Error while async write back metadata bh 1768.
[   50.456496] JBD2: Error while async write back metadata bh 1785.
[   50.462490] JBD2: Error while async write back metadata bh 1786.
[   50.468483] JBD2: Error while async write back metadata bh 1787.
[   50.474479] JBD2: Error while async write back metadata bh 1789.
[   50.480478] JBD2: Error while async write back metadata bh 1803.
[   50.486477] JBD2: Error while async write back metadata bh 1815.
[   50.492471] JBD2: Error while async write back metadata bh 1816.
[   50.498463] JBD2: Error while async write back metadata bh 1817.
[   50.504539] JBD2: Error while async write back metadata bh 524351.
[   50.510569] JBD2: Error while async write back metadata bh 524730.
[   50.516736] JBD2: Error while async write back metadata bh 524731.
[   50.522904] JBD2: Error while async write back metadata bh 524732.
[   50.529088] JBD2: Error while async write back metadata bh 524750.
[   50.535287] JBD2: Error while async write back metadata bh 524777.
[   50.541577] JBD2: Error while async write back metadata bh 1048614.
[   50.547747] JBD2: Error while async write back metadata bh 1048615.
[   50.554003] JBD2: Error while async write back metadata bh 1048616.
[   50.560256] JBD2: Error while async write back metadata bh 1048617.
[   50.566510] JBD2: Error while async write back metadata bh 1048619.
[   50.572764] JBD2: Error while async write back metadata bh 1048623.
[   50.579031] JBD2: Error while async write back metadata bh 1048664.
[   50.585286] JBD2: Error while async write back metadata bh 1048666.
[   50.591541] JBD2: Error while async write back metadata bh 1048667.
[   50.597798] JBD2: Error while async write back metadata bh 1048668.
[   50.604141] JBD2: Error while async write back metadata bh 1573423.
[   50.610707] JBD2: Error while async write back metadata bh 3145790.
[   50.616974] JBD2: Error while async write back metadata bh 3145814.
[   50.623229] JBD2: Error while async write back metadata bh 3145820.
[   50.629488] JBD2: Error while async write back metadata bh 3145837.
[   50.635743] JBD2: Error while async write back metadata bh 3145838.
[   50.641996] JBD2: Error while async write back metadata bh 3145839.
[   50.648263] JBD2: Error while async write back metadata bh 3145840.
[   50.654531] JBD2: Error while async write back metadata bh 3145864.
[   50.660788] JBD2: Error while async write back metadata bh 3145865.
[   50.667042] JBD2: Error while async write back metadata bh 3145866.
[   50.673397] JBD2: Error while async write back metadata bh 3146286.
[   50.680789] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[   50.698921] Buffer I/O error on dev mmcblk1p2, logical block 0, lost sync page write
[   50.707205] EXT4-fs (mmcblk1p2): I/O error while writing superblock
[   50.714127] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #15: comm systemd-udevd: reading directory lblock 0
[   50.725940] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[   50.738393] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #785007: comm systemd-udevd: reading directory lblock 0
[   50.750216] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[   50.762139] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[   50.773970] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[   50.786403] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #784636: comm systemd-udevd: reading directory lblock 0
[   50.798222] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[   50.819533] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[   50.831457] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[   50.843328] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #783510: comm systemd-udevd: reading directory lblock 0
[   50.856431] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:83: Detected aborted journal
[   50.865545] EXT4-fs (mmcblk1p2): Remounting filesystem read-only
[   50.871547] ------------[ cut here ]------------
[   50.876160] bdi-(unknown) not registered
[   50.880109] WARNING: CPU: 0 PID: 181 at fs/fs-writeback.c:2326 __mark_inode_dirty+0x1d8/0x200
[   50.888611] Modules linked in: rpmsg_char xhci_plat_hcd xhci_hcd ti_am335x_adc kfifo_buf omap_rng cdns3 udc_core rng_core roles irq_pruss_intc pru_rproc icss_iep usbcore usb_common crct10dif_ce snd_soc_j721e_evm ti_j721e_cpsw_virt_mac phy_can_transceiver ti_k3_r5_remoteproc m_can_platform m_can vxd_dec ti_am335x_tscadc can_dev videobuf2_dma_sg v4l2_mem2mem videobuf2_dma_contig videobuf2_memops pruss videobuf2_v4l2 videobuf2_common sa2ul sha512_generic authenc ti_k3_dsp_remoteproc(+) cdns_dphy snd_soc_pcm3168a_i2c virtio_rpmsg_bus snd_soc_pcm3168a bluetooth ecdh_generic ecc rfkill pvrsrvkm(O) ina2xx cdns3_ti rti_wdt sch_fq_codel rpmsg_kdrv_switch cryptodev(O) ipv6
[   50.947295] CPU: 0 PID: 181 Comm: systemd-udevd Tainted: G      D    O      5.10.41-g4c2eade9f7 #2
[   50.956230] Hardware name: Texas Instruments K3 J721E SoC (DT)
[   50.962045] pstate: 40000005 (nZcv daif -PAN -UAO -TCO BTYPE=--)
[   50.968033] pc : __mark_inode_dirty+0x1d8/0x200
[   50.972548] lr : __mark_inode_dirty+0x1d8/0x200
[   50.977061] sp : ffff800012defb90
[   50.980362] x29: ffff800012defb90 x28: 0000000000000000
[   50.985659] x27: ffff00082466eea0 x26: ffff000824b10398
[   50.990955] x25: 0000000000000002 x24: 0000000000000000
[   50.996252] x23: ffff00084059fcb8 x22: 0000000000000000
[   51.001548] x21: 0000000000000001 x20: ffff00084059fc30
[   51.006845] x19: ffff000824382060 x18: 0000000000000010
[   51.012141] x17: 0000000000000000 x16: 0000000000000000
[   51.017438] x15: ffff00082031bb30 x14: 000000000000050c
[   51.022734] x13: ffff00082031bb30 x12: 00000000ffffffea
[   51.028030] x11: ffff8000111ba360 x10: ffff8000111a2320
[   51.033326] x9 : ffff8000111a2378 x8 : 0000000000017fe8
[   51.038621] x7 : c0000000ffffefff x6 : 0000000000000001
[   51.043916] x5 : 0000000000000000 x4 : ffff00087fa61aa8
[   51.049212] x3 : ffff00087fa689b0 x2 : ffff00087fa61aa8
[   51.054507] x1 : 9ba2533295577800 x0 : 0000000000000000
[   51.059804] Call trace:
[   51.062239]  __mark_inode_dirty+0x1d8/0x200
[   51.066409]  generic_update_time+0x64/0xe0
[   51.070490]  update_time+0x2c/0x38
[   51.073878]  touch_atime+0x1b0/0x250
[   51.077441]  ext4_file_mmap+0x64/0x88
[   51.081092]  mmap_region+0x3c8/0x690
[   51.084653]  do_mmap+0x35c/0x598
[   51.087870]  vm_mmap_pgoff+0xdc/0x108
[   51.091517]  ksys_mmap_pgoff+0x1b8/0x1e8
[   51.095428]  __arm64_sys_mmap+0x30/0x48
[   51.099250]  el0_svc_common.constprop.0+0x78/0x1a0
[   51.104024]  do_el0_svc+0x24/0x90
[   51.107329]  el0_svc+0x14/0x20
[   51.110369]  el0_sync_handler+0xb0/0xb8
[   51.114191]  el0_sync+0x180/0x1c0
[   51.117492] ---[ end trace 68f3f71a50a7ba62 ]---
[   51.123129] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[   51.135650] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[   51.148137] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[   51.160629] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[   67.473923] EXT4-fs error: 14 callbacks suppressed
[   67.473928] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   67.490852] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   67.502503] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   67.514582] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   67.526222] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   67.538289] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   67.549936] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   67.562004] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   67.573639] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   67.585706] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   78.470563] EXT4-fs error: 10 callbacks suppressed
[   78.470568] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm crond: reading directory lblock 0
[   78.486535] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #791785: comm crond: reading directory lblock 0
[   78.497704] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm crond: reading directory lblock 0
[   78.508859] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm crond: reading directory lblock 0
[   78.519983] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm crond: reading directory lblock 0
[   78.531121] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #791785: comm crond: reading directory lblock 0
[   97.723898] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   97.735997] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   97.747655] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   97.759741] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   97.771381] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   97.783487] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   97.795124] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   97.807193] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   97.818827] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[   97.830901] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[   98.191725] mmc1: new ultra high speed DDR50 SDHC card at address 5048
[   98.198554] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[   98.211184] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[   98.211907] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[   98.226278]  mmcblk1: p1 p2
[   98.231047] debugfs: Directory 'mmcblk1' with parent 'block' already present!
[   98.239124] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   98.246638] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   98.254738] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   98.262832] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   98.271829] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   98.279318] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   98.287402] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   98.295488] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   98.304279] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   98.311435] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   98.318936] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   98.327027] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   98.335111] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
j7-evm login:
j7-evm login:
j7-evm login:
j7-evm login:
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:47 +0800)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -19
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
U-Boot 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   Could not get PHY for ethernet@46000000: addr 0
am65_cpsw_nuss_slave ethernet@46000000: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 1 ms (0 Bytes/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19137024 bytes read in 798 ms (22.9 MiB/s)
97623 bytes read in 13 ms (7.2 MiB/s)
   Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.41-g4c2eade9f7 (qywu@op01) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT Tue Oct 26 17:24:36 CST 2021
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0b959c33-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3372032K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 297984K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008800b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008372] Console: colour dummy device 80x25
[    0.012933] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023603] pid_max: default: 32768 minimum: 301
[    0.028349] LSM: Security Framework initializing
[    0.033092] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040658] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049595] rcu: Hierarchical SRCU implementation.
[    0.054645] Platform MSI: msi-controller@1820000 domain created
[    0.060880] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070178] EFI services will not be available.
[    0.074925] smp: Bringing up secondary CPUs ...
[    0.080106] Detected PIPT I-cache on CPU1
[    0.080129] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.080140] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[    0.080172] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.080224] smp: Brought up 1 node, 2 CPUs
[    0.109569] SMP: Total of 2 processors activated.
[    0.114374] CPU features: detected: 32-bit EL0 Support
[    0.119628] CPU features: detected: CRC32 instructions
[    0.133263] CPU: All CPU(s) started at EL2
[    0.137459] alternatives: patching kernel code
[    0.142450] devtmpfs: initialized
[    0.150668] KASLR disabled due to lack of seed
[    0.155320] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.165282] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.172954] pinctrl core: initialized pinctrl subsystem
[    0.178531] DMI not present or invalid.
[    0.182758] NET: Registered protocol family 16
[    0.190243] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.197543] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.205546] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.213851] thermal_sys: Registered thermal governor 'step_wise'
[    0.213854] thermal_sys: Registered thermal governor 'power_allocator'
[    0.220263] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.233904] ASID allocator initialised with 65536 entries
[    0.256497] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.263351] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.270112] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.278034] cryptd: max_cpu_qlen set to 1000
[    0.284045] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.292871] vsys_3v3: supplied by evm_12v0
[    0.297181] vsys_5v0: supplied by evm_12v0
[    0.301805] iommu: Default domain type: Translated
[    0.306967] SCSI subsystem initialized
[    0.311082] mc: Linux media interface: v0.10
[    0.315451] videodev: Linux video capture interface: v2.00
[    0.321079] pps_core: LinuxPPS API ver. 1 registered
[    0.326149] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.335486] PTP clock support registered
[    0.339504] EDAC MC: Ver: 3.0.0
[    0.343246] FPGA manager framework
[    0.346757] Advanced Linux Sound Architecture Driver Initialized.
[    0.353358] clocksource: Switched to clocksource arch_sys_counter
[    0.359775] VFS: Disk quotas dquot_6.6.0
[    0.363821] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.373475] NET: Registered protocol family 2
[    0.378058] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.386672] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.395440] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.403635] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.411435] TCP: Hash tables configured (established 32768 bind 32768)
[    0.418180] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.425072] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.432468] NET: Registered protocol family 1
[    0.437150] RPC: Registered named UNIX socket transport module.
[    0.443211] RPC: Registered udp transport module.
[    0.448015] RPC: Registered tcp transport module.
[    0.452819] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.459402] PCI: CLS 0 bytes, default 64
[    0.463761] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.473961] Initialise system trusted keyrings
[    0.478575] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.486832] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.493045] NFS: Registering the id_resolver key type
[    0.498266] Key type id_resolver registered
[    0.502538] Key type id_legacy registered
[    0.506657] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.513505] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.521142] 9p: Installing v9fs 9p2000 file system support
[    0.546129] Key type asymmetric registered
[    0.550314] Asymmetric key parser 'x509' registered
[    0.555312] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.562870] io scheduler mq-deadline registered
[    0.567496] io scheduler kyber registered
[    0.572740] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.578901] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.587288] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.593554] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.601321] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.609444] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.618410] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.627233] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.634946] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.647781] brd: module loaded
[    0.653607] loop: module loaded
[    0.657436] megasas: 07.714.04.00-rc1
[    0.662373] libphy: Fixed MDIO Bus: probed
[    0.667024] tun: Universal TUN/TAP device driver, 1.6
[    0.672444] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.678849] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.684917] sky2: driver version 1.30
[    0.689166] VFIO - User Level meta-driver version: 0.3
[    0.694840] i2c /dev entries driver
[    0.699000] sdhci: Secure Digital Host Controller Interface driver
[    0.705320] sdhci: Copyright(c) Pierre Ossman
[    0.709937] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.716250] ledtrig-cpu: registered to indicate activity on CPUs
[    0.722549] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.729674] optee: probing for conduit method.
[    0.734226] optee: revision 3.12 (3d47a131)
[    0.734460] optee: initialized driver
[    0.743719] NET: Registered protocol family 17
[    0.748331] 9pnet: Installing 9P2000 support
[    0.752716] Key type dns_resolver registered
[    0.757174] Loading compiled-in X.509 certificates
[    0.766269] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.772598] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.780683] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[    0.806992] random: fast init done
[    0.832841] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.840321] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.846376] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.852401] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.858822] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[    0.868315] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[    0.874567] pca953x 5-0020: supply vcc not found, using dummy regulator
[    0.881430] pca953x 5-0020: using no AI
[    0.909404] pca953x 5-0020: failed writing register
[    0.914441] pca953x: probe of 5-0020 failed with error -121
[    0.920513] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    0.926550] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[    0.932482] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[    0.938684] pca953x 8-0020: supply vcc not found, using dummy regulator
[    0.945495] pca953x 8-0020: using no AI
[    1.957359] omap_i2c 2060000.i2c: timeout waiting for bus ready
[    1.963412] pca953x 8-0020: failed writing register
[    1.968444] pca953x: probe of 8-0020 failed with error -16
[    1.974372] omap_i2c 2060000.i2c: bus 8 rev0.12 at 400 kHz
[    1.980759] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.990721] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.999523] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    2.009342] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    2.029175] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    2.036864] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.044531] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.052808] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.061083] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.069916] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.077588] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.085863] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.094138] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.102894] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.110562] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.118838] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.127113] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.136225] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    2.146104] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    2.152863] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.161817] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    2.171958] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    2.178717] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.186627] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    2.195978] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    2.204723] printk: console [ttyS2] enabled
[    2.213161] printk: bootconsole [ns16550a0] disabled
[    2.223608] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    2.232537] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    2.242885] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    2.253397] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    2.263552] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    2.273794] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    2.284549] scsi host0: ufshcd
[    2.329365] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.337012] libphy: 46000f00.mdio: probed
[    2.341434] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    2.348161] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    2.361915] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    2.370685] mmc0: CQHCI version 5.10
[    2.374318] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    2.374533] mmc1: CQHCI version 5.10
[    2.389631] pca953x 3-0020: supply vcc not found, using dummy regulator
[    2.396307] pca953x 3-0020: using no AI
[    2.426434] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    2.567035] mmc0: Command Queue Engine enabled
[    2.571474] mmc0: new DDR MMC card at address 0001
[    2.576504] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    2.581110] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    2.587088] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    2.593070] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
[    2.601626]  mmcblk0: p1 p2
[    2.695587] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    2.701065] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    2.706104] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    2.712355] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    2.718780] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    2.725637] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    2.732235] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    2.738572] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    2.743089] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    2.751247] cdns-ufshcd 4e84000.ufs: last intr at 2589112 us, last intr status=0x404
[    2.758973] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    2.766439] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    2.775463] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    2.781453] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    2.787704] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    2.793780] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    2.799859] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    2.812020] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    2.818359] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    2.824696] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    2.831033] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    2.837371] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    2.843707] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    2.850044] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    2.856380] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    2.862722] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    2.869061] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    2.875399] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    2.880698] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    2.885996] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    2.891293] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    2.896590] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    2.901974] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    2.908137] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.913696] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 2590230 us
[    2.920813] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.926543] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.932360] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.937920] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.943564] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    3.405360] omap_i2c 2010000.i2c: timeout waiting for bus ready
[    3.411279] pca953x 3-0020: failed writing register
[    3.416234] pca953x: probe of 3-0020 failed with error -16
[    3.422114] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    3.428936] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    3.435742] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    3.441871] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.449754] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    3.456550] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    3.466070] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.473557] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.481642] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.489721] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.498389] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.498800] mmc1: new ultra high speed DDR50 SDHC card at address 5048
[    3.505878] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.512687] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[    3.520450] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.527800]  mmcblk1: p1 p2
[    3.532961] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.544436] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.551923] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.560003] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.568081] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.577061] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    3.587085] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    3.600268] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    3.605503] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[    3.612535] mtd: 47040000.spi.0: skipping zero sized partition
[    3.618354] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    3.624950] Creating 7 MTD partitions on "47040000.spi.0":
[    3.630421] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    3.636411] 0x000000080000-0x000000280000 : "ospi.tispl"
[    3.642074] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    3.647798] 0x000000680000-0x0000006c0000 : "ospi.env"
[    3.653323] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    3.658992] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    3.665135] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    3.672973] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.679852] spi-nor: probe of spi1.0 failed with error -2
[    3.725362] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.733008] libphy: 46000f00.mdio: probed
[    3.737428] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    3.744154] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    3.757683] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.764653] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    3.771861] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.778138] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    3.788138] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    3.799738] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.807232] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.815312] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.823391] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.831943] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.839433] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.847515] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.855594] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.864119] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.871607] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.879685] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.887778] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.897142] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.904629] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.912707] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.920787] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.929325] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.936820] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.944903] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.952984] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.961518] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.969013] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.977098] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.985181] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.995087] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    4.002492] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    4.009854] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    4.017164] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    4.025242] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.032633] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    4.040134] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    4.048221] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    4.056307] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.064992] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    4.072496] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    4.080584] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    4.088670] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.097285] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    4.104782] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    4.112867] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    4.120952] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.137330] ALSA device list:
[    4.140294]   No soundcards found.
[    4.150970] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.159085] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    4.169372] devtmpfs: mounted
[    4.172617] Freeing unused kernel memory: 1856K
[    4.177167] Run /sbin/init as init process
[    4.359725] systemd[1]: System time before build time, advancing clock.
[    4.411519] NET: Registered protocol family 10
[    4.416384] Segment Routing with IPv6
[    4.436238] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.451711] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.471325] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    4.493043] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[    4.530184] systemd[1]: Set hostname to <j7-evm>.
[    4.633276] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.651690] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.667656] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.683817] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.703187] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.720605] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.738600] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.756434] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.774067] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.791141] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.808754] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.826547] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.844250] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.862163] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.880670] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.898577] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.915084] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.931431] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.948748] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.965825] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.983984] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.001745] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.020165] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.038174] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.056908] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.074537] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.092949] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.111485] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.129396] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.146941] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.163989] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.180252] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.198339] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.214954] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.232460] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.251047] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.268796] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.285468] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.301740] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.318215] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.336212] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.353772] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.373512] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.391454] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.408576] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.426281] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.444051] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.460176] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.476049] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.492161] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.510345] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.528613] systemd[1]: Configuration file /lib/systemd/system/strongswan-starter.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.546139] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.562321] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.578703] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.594900] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.611285] systemd[1]: Configuration file /lib/systemd/system/rngd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.627362] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.645035] systemd[1]: Configuration file /lib/systemd/system/ofono.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.661350] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.677944] systemd[1]: Configuration file /lib/systemd/system/kdump.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.694052] systemd[1]: Configuration file /lib/systemd/system/irqbalanced.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.710704] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.727147] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.743724] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.760597] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.777213] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.794942] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.811623] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.828474] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.845318] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.862235] systemd[1]: Configuration file /lib/systemd/system/docker.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.878617] systemd[1]: Configuration file /lib/systemd/system/docker.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.894673] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[    5.914390] systemd[1]: Configuration file /lib/systemd/system/demo.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.930560] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.946718] systemd[1]: Configuration file /lib/systemd/system/crond.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.962944] systemd[1]: Configuration file /lib/systemd/system/bt-enable.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.979650] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.996917] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.013858] systemd[1]: Configuration file /lib/systemd/system/atd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.030623] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.049371] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.065697] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.083040] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.100438] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.116593] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.133609] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.151338] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.169606] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.186153] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.202731] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.219282] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.236327] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.254773] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.272449] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.288483] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.305925] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.323235] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.341204] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.358034] systemd[1]: Configuration file /lib/systemd/system/psplash-systemd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.375162] systemd[1]: Configuration file /lib/systemd/system/psplash-start.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.392149] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.408636] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.426038] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.442726] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.459615] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.476264] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.492734] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.510527] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.528840] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.546317] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.563473] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.580580] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.597707] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.614936] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.631803] systemd[1]: Configuration file /lib/systemd/system/var-volatile-srv.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.649191] systemd[1]: Configuration file /lib/systemd/system/var-volatile-spool.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.666746] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.684172] systemd[1]: Configuration file /lib/systemd/system/var-volatile-cache.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.701731] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.717730] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.735341] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.752753] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.769248] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.786090] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.804312] random: systemd: uninitialized urandom read (16 bytes read)
[    6.811028] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    6.823354] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    6.833257] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    6.853430] random: systemd: uninitialized urandom read (16 bytes read)
[    6.860663] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    6.881423] random: systemd: uninitialized urandom read (16 bytes read)
[    6.888535] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    6.909526] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    6.933465] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    6.957465] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    6.973411] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    6.993404] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    7.009404] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    7.033427] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.057432] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.077529] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.095983] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    7.117535] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    7.150252] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.158597] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.181623] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.197669] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.221577] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.241514] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.263834] systemd[1]: Mounting Huge Pages File System...
[    7.283450] systemd[1]: Mounting POSIX Message Queue File System...
[    7.308096] systemd[1]: Mounting Kernel Debug File System...
[    7.328762] systemd[1]: Mounting Temporary Directory (/tmp)...
[    7.348309] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    7.375459] systemd[1]: Starting Start psplash boot splash screen...
[    7.401075] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    7.427490] systemd[1]: Starting RPC Bind...
[    7.445746] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.468536] systemd[1]: Starting Journal Service...
         Starting Journal Service...[    7.477783] systemd-journald[165]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.510280] systemd-journald[165]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.516708] systemd[1]: Starting Load Kernel Modules...
[    7.547337] cryptodev: loading out-of-tree module taints kernel.
[    7.560154] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
[0m...
[    7.581202] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    7.591686] systemd[1]: Starting udev Coldplug all Devices...
[    7.615926] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    7.638422] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    7.849028] systemd-journald[165]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
[  OK  ] Started udev Coldplug all Devices.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the [    8.458553] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
API.
[    8.469412] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[  OK  ] Reached target Sockets.[    8.482484] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.497267] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Reached target Basic System.[    8.510021] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.524174] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[  OK  ] Started Job spooling tools.[    8.537507] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.553397] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Periodic Command Scheduler j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[0m.
[    8.585408] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[  OK  ] Started D-Bus System Message Bus    8.596701] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
m.
[    8.613395] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
         Starting Print notice about GPLv3 packages...
[    8.634427] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
         Starting IPv6 Packet Filtering Framework..[    8.649443] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.658364] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.666678] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Telephony service...
         Starting rc.pvr.service...
         Starting Login Service...
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Started IPv6 Packet Filtering Framework.
[    8.802494] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.803317] ina2xx 4-0040: error configuring the device: -121
[    8.813423] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[  OK  ] Started IPv4 Packet Filtering Frame[    8.827302] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
work.
[    8.845420] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.855539] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    8.869412] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    8.877561] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    8.889486] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Reached target Network (Pre).[    8.902512] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
         Starting Network Service...
[    8.913409] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[  OK  ] Started Telephony service.
[    8.925416] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.941389] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.950178] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.961410] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    8.969608] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.977943] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.005904] PVR_K:  247: Read BVNC 22.104.208.318 from HW device registers
[    9.016971] Bluetooth: Core ver 2.22
[    9.021848] PVR_K:  247: RGX Device registered with BVNC 22.104.208.318
[    9.025507] NET: Registered protocol family 31
[    9.029029] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[    9.035804] Bluetooth: HCI device and connection manager initialized
[    9.052212] Bluetooth: HCI socket layer initialized
[    9.060906] Bluetooth: L2CAP socket layer initialized
[    9.067415] Bluetooth: SCO socket layer initialized
[    9.074357] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.074373] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.074383] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.074393] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.075781] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.075798] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.075808] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.075817] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.076142] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.076164] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.076173] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.076183] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.351451] ina2xx 4-0041: error configuring the device: -121
[    9.352242] ina2xx 4-0042: error configuring the device: -121
[    9.355292] ina2xx 4-0043: error configuring the device: -121
[    9.356431] ina2xx 4-0044: error configuring the device: -121
[    9.356760] ina2xx 4-0045: error configuring the device: -121
[    9.356989] ina2xx 4-0046: error configuring the device: -121
[    9.361854] ina2xx 4-0047: error configuring the device: -121
[    9.362812] ina2xx 4-0048: error configuring the device: -121
[    9.367016] ina2xx 4-0049: error configuring the device: -121
[    9.367444] ina2xx 4-004a: error configuring the device: -121
[    9.367833] ina2xx 4-004b: error configuring the device: -121
[    9.368319] ina2xx 4-004c: error configuring the device: -121
[    9.369109] ina2xx 4-004d: error configuring the device: -121
[    9.380703] ina2xx 4-004e: error configuring the device: -121
[    9.382584] ina2xx 4-004f: error configuring the device: -121
[    9.442287] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.442310] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.442321] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.442332] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.444597] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.444621] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.444632] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.444643] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.448203] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.448225] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.448235] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.448246] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.475524] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.475543] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.475554] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.475564] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.476750] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.476768] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.476777] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.476787] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.477124] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.477140] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.477149] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.477159] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.512665] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.512685] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.512694] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.512704] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.513934] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[  OK  ] Started Login Service.
[    9.851854] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.861329] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.869448] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.879077] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.887876] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.895991] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.904970] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.915423] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.924175] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.933302] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.942402] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.953595] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.962029] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.971741] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.979883] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.021280] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[   10.165391] random: crng init done
[   10.171569] random: 7 urandom warning(s) missed due to ratelimiting
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[   10.246735] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Load/Save Random Seed.
[   10.397627] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.406641] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.419275] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.431112] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.448225] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.456582] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.459221] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[   10.469380] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.484999] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.506382] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   10.514675] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   10.525009] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   10.533274] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   10.544411] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   10.551236] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[   10.552673] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   10.594474] CAN device driver interface
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[   10.792613] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[   10.821456] remoteproc remoteproc0: 4d80800000.dsp is available
[   10.980416] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[   11.049535] remoteproc remoteproc0: powering up 4d80800000.dsp
[   11.055513] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 187480
[   11.069671] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200000
[   11.081405] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[   11.090254]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[   11.100926] virtio_rpmsg_bus virtio0: rpmsg host is online
[   11.107427] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[   11.110462]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[   11.114987] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[   11.129384] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[   11.301992] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[   11.327276] platform 41000000.r5f: configured R5F for IPC-only mode
[   11.432221] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[   11.432794] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   11.544896] remoteproc remoteproc2: 4d81800000.dsp is available
[   11.574928] remoteproc remoteproc1: 41000000.r5f is available
[   11.627068] am65-cpsw-nuss 46000000.ethernet: phy /bus@100000/bus@28380000/ethernet@46000000/mdio@f00/ethernet-phy@0 not found on slave 1
[   11.649636] remoteproc remoteproc1: attaching to 41000000.r5f
[   11.747237] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   11.755825] remoteproc remoteproc2: powering up 4d81800000.dsp
[   11.761661] remoteproc remoteproc2: Booting fw image j7-c66_1-fw, size 187480
[   11.769306] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200000
[   11.780384]  remoteproc2#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[   11.781530] platform 41000000.r5f: R5F core initialized in IPC-only mode
[   11.791666] virtio_rpmsg_bus virtio1: rpmsg host is online
[   11.797529] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[   11.804446]  remoteproc2#vdev0buffer: registered virtio1 (type 7)
[   11.812350] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[   11.817401] remoteproc remoteproc2: remote processor 4d81800000.dsp is now up
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav-dev
        gstreamer1.0-libav
        gzip
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp-dev
        libgmp10
        libgmpxx4
        libidn2-0
        libidn2-dev
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline8
        libunistring-dev
        libunistring2
        m4-dev
        m4
        make
        nettle-dev
        nettle
        parted
        python3-rfc3987
        python3-strict-rfc3339
        tar
        which
        zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependenc[   12.082432] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
y of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[   12.181451]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[   12.274359] remoteproc remoteproc3: 64800000.dsp is available
[   12.329762] virtio_rpmsg_bus virtio2: rpmsg host is online
[   12.345211] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[   12.431281]  remoteproc1#vdev0buffer: registered virtio2 (type 7)
[   12.519513] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
[   12.656888] remoteproc remoteproc3: powering up 64800000.dsp
[   12.662585] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489872
[   12.677440] remoteproc remoteproc3: unsupported resource 65538
[   12.683948] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
[   12.711938]  remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[   12.720609] virtio_rpmsg_bus virtio3: rpmsg host is online
[   12.726654] platform 5c00000.r5f: configured R5F for remoteproc mode
[   12.733134]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[   12.739315] remoteproc remoteproc3: remote processor 64800000.dsp is now up
[   12.746378] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[   12.761527] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[   12.770729] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[   12.799073] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   12.882046] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   12.923822] remoteproc remoteproc4: 5c00000.r5f is available
[   12.950056] platform 5d00000.r5f: configured R5F for remoteproc mode
[   12.969213] remoteproc remoteproc4: powering up 5c00000.r5f
[   12.974902] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 527528
[   12.985627] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   12.995512]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[   13.009719] virtio_rpmsg_bus virtio4: rpmsg host is online
[   13.015268]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[   13.021359] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[   13.022349] remoteproc remoteproc5: 5d00000.r5f is available
[   13.207471] remoteproc remoteproc5: powering up 5d00000.r5f
[   13.213091] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 78708
[   13.249570]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[   13.260694] virtio_rpmsg_bus virtio5: rpmsg host is online
[   13.266269]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[   13.277401] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[   13.286823] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[   13.294436] platform 5e00000.r5f: configured R5F for remoteproc mode
[   13.301012] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
[   13.399364] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   13.554045] remoteproc remoteproc6: 5e00000.r5f is available
[   13.666111] remoteproc remoteproc6: powering up 5e00000.r5f
[   13.671721] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 78708
[   13.694036] platform 5f00000.r5f: configured R5F for remoteproc mode
[   13.701620]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[   13.713760] virtio_rpmsg_bus virtio6: rpmsg host is online
[   13.725441]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[   13.731571] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[   13.741722] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[   13.753499] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
[   13.854413] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   13.938725] remoteproc remoteproc7: 5f00000.r5f is available
[   13.961824] remoteproc remoteproc7: powering up 5f00000.r5f
[   13.967432] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 78708
[   13.981677]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[   13.993632] virtio_rpmsg_bus virtio7: rpmsg host is online
[   14.002271]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[   14.010073] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[   14.011444] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[   14.020597] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[  OK  ] Created slice system-weston.slice.
[  OK  ] Started Weston Wayland Compositor.
[   14.343172] usbcore: registered new interface driver usbfs
[   14.353923] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[   14.372290] usbcore: registered new interface driver hub
[  OK  ] Created slice User Slice of UID 0.
[   14.401019] usbcore: registered new device driver usb
         Starting User Runtime Directory /run/user/0   14.415100] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
m...
[  OK  ] Started User Runtime Directory /run/user/0.
         Starting User Manager for UID 0...
[   14.508892] remoteproc remoteproc8: b034000.pru is available
[   14.538743] remoteproc remoteproc9: b004000.rtu is available
[   14.750082] remoteproc remoteproc10: b00a000.txpru is available
[  OK  ] Started User Manager for UID 0.
[  OK  ] Started Session c1 of user root.
[  OK  ] Found device /dev/mmcblk0p2.
         Starting File System Check on /dev/mmcblk0p2...
[   14.929449] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   14.935665] remoteproc remoteproc11: b038000.pru is available
[  OK  ] Found device /dev/mmcblk0p1.
         Starting File System Check on /dev/mmcblk0p1...
[   15.016678] remoteproc remoteproc12: b006000.rtu is available
[  OK  ] Started File System Check on /dev/mmcblk0p2.
         Mounting /run/media/mmcblk0p2...
[   15.063378] remoteproc remoteproc13: b00c000.txpru is available
[  OK  ] Started File System Check on /dev/mmcblk0p1.
[   15.085273] PVR_K:  1068: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
         Mounting /run/media/mmcblk0p1...[   15.101765] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Mounted /run/media/mmcblk0p2.
[  OK  ] Mounted /run/media/mmcblk0p1.
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[   15.252326] remoteproc remoteproc14: b134000.pru is available
[   15.401979] remoteproc remoteproc15: b104000.rtu is available
[   15.457642] remoteproc remoteproc16: b10a000.txpru is available
[   15.507187] remoteproc remoteproc17: b138000.pru is available
[   15.517713] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   15.538864] remoteproc remoteproc18: b106000.rtu is available
[   15.542432] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   15.594631] remoteproc remoteproc19: b10c000.txpru is available
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm login: [   16.975387] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   16.978369] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.989362] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   16.990388] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.006378] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.014601] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.024835] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.033057] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.043295] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.051519] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.062374] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.070597] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.080836] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.089067] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.099310] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.107551] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.118378] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.126610] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.136862] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.145096] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.155338] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.163565] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.174378] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.182608] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.192859] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.201097] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.211337] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.219563] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.229212] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.237371] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.248389] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.256618] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.267384] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.275608] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.286384] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.294625] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.304865] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.313092] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.323337] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.331568] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.342382] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.350622] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.360861] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.369088] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.379332] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.387562] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.398382] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.406621] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.416853] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.425077] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.435315] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.443539] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.454373] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.462595] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.472826] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.481054] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.491293] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.499515] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.510375] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.518598] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.525201] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[   17.534375] Console: switching to colour frame buffer device 128x48
[   17.545037] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
[   17.566652] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   17.577456] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   17.589487] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   17.600639] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.613490] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   17.623394] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   17.634383] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   17.644494] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.657019] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   17.666391] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   17.676518] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   17.687385] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.699777] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[   17.711741] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[   17.724152] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.734517] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   17.745065] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   17.756195] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   17.766350] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.778580] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   17.788144] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   17.799406] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   17.809397] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.820825] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   17.834201] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   17.845344] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   17.856524] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
j7-evm login:
j7-evm login:
j7-evm login: root
Last login: Wed Aug  4 22:20:56 UTC 2021
root@j7-evm:~#
root@j7-evm:~# [   23.992380] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   23.999248] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   25.564598] xhci-hcd xhci-hcd.2.auto: can't setup: -110
[   25.569826] xhci-hcd xhci-hcd.2.auto: USB bus 1 deregistered
[   25.575535] xhci-hcd: probe of xhci-hcd.2.auto failed with error -110
[   25.582103] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   25.587595] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[   25.595624] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[   25.605045] xhci-hcd xhci-hcd.3.auto: irq 613, io mem 0x06410000
[   25.611245] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   25.619504] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   25.626713] usb usb1: Product: xHCI Host Controller
[   25.631581] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   25.638096] usb usb1: SerialNumber: xhci-hcd.3.auto
[   25.643240] hub 1-0:1.0: USB hub found
[   25.647024] hub 1-0:1.0: 1 port detected
[   25.651467] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   25.652796] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   25.659565] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   25.663839] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[   25.663849] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   25.672057] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   25.679016] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   25.685818] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   25.693641] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   25.701980] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   25.709714] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   25.709716] usb usb2: Product: xHCI Host Controller
[   25.709718] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   25.709720] usb usb2: SerialNumber: xhci-hcd.3.auto
[   25.710175] hub 2-0:1.0: USB hub found
[   25.720086] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   25.726269] hub 2-0:1.0: 1 port detected
[   25.734205] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   25.773501] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   25.782102] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   25.792572] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   25.800561] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   25.808700] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   25.816914] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   25.826066] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   25.836377] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   25.845926] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   25.854064] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   25.862174] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   25.871027] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   25.878585] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   25.886675] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   25.894760] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   30.424473] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   30.431344] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   30.467400] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.477061] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.489415] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.499433] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.509954] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.518238] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.528942] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.537260] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.548396] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.556716] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.568389] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.576629] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.587386] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.595626] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.606375] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.614602] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.624848] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.633075] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.643312] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.651542] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.662373] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.670605] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.680851] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.689078] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.699312] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.707542] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.718373] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.726601] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.736853] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.745075] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.755317] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.763542] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.773181] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.781370] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.792381] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.800607] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.811376] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.819602] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.830371] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.838608] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.848840] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.857062] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.867297] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.875520] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.886372] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.894598] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.904850] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.913070] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.923312] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.931536] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.942373] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.950603] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.960849] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.969070] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.979305] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.987528] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.998372] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.006598] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.016845] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.025066] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.035307] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.043531] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.054373] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.062599] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.069217] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# [   35.913378] tlv71033: disabling
cd /[   37.494747] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   37.501617] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
opt/
root@j7-evm:/opt# ;ls
-sh: syntax error near unexpected token `;'
root@j7-evm:/opt# ;s
root@j7-evm:/opt# ls
containerd  img-powervr-sdk  ltp  vx_app_arm_remote_log.out
root@j7-evm:/opt# ./vx_app_arm_remote_log.out
APP_LOG: ERROR: Unable to map memory @ 0xb2000000 of size 262144 bytes !!!
^C
root@j7-evm:/opt# [   43.922429] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   43.929297] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# dmesg |grep rpmsg
root@j7-evm:/opt# [  130.630402] Initializing XFRM netlink socket
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# [  133.476940] process 'docker/tmp/qemu-check614505420/check' started with executable stack
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt#
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:47 +0800)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -19
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
U-Boot 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   Could not get PHY for ethernet@46000000: addr 0
am65_cpsw_nuss_slave ethernet@46000000: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
=> env default -a -f
## Resetting to default environment
=> saveenv
Saving Environment to FAT... OK
=> boot
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 1 ms (0 Bytes/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19137024 bytes read in 798 ms (22.9 MiB/s)
97623 bytes read in 13 ms (7.2 MiB/s)
   Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.41-g4c2eade9f7 (qywu@op01) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT Tue Oct 26 17:24:36 CST 2021
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0b959c33-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3372032K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 297984K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008800b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008351] Console: colour dummy device 80x25
[    0.012913] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023584] pid_max: default: 32768 minimum: 301
[    0.028329] LSM: Security Framework initializing
[    0.033075] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040641] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049579] rcu: Hierarchical SRCU implementation.
[    0.054631] Platform MSI: msi-controller@1820000 domain created
[    0.060866] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070162] EFI services will not be available.
[    0.074909] smp: Bringing up secondary CPUs ...
[    0.080091] Detected PIPT I-cache on CPU1
[    0.080116] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.080126] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[    0.080159] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.080210] smp: Brought up 1 node, 2 CPUs
[    0.109555] SMP: Total of 2 processors activated.
[    0.114360] CPU features: detected: 32-bit EL0 Support
[    0.119614] CPU features: detected: CRC32 instructions
[    0.133247] CPU: All CPU(s) started at EL2
[    0.137443] alternatives: patching kernel code
[    0.142433] devtmpfs: initialized
[    0.150548] KASLR disabled due to lack of seed
[    0.155203] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.165164] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.172834] pinctrl core: initialized pinctrl subsystem
[    0.178407] DMI not present or invalid.
[    0.182629] NET: Registered protocol family 16
[    0.190163] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.197463] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.205467] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.213770] thermal_sys: Registered thermal governor 'step_wise'
[    0.213772] thermal_sys: Registered thermal governor 'power_allocator'
[    0.220182] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.233819] ASID allocator initialised with 65536 entries
[    0.255903] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.262757] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.269518] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.277418] cryptd: max_cpu_qlen set to 1000
[    0.283434] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.292267] vsys_3v3: supplied by evm_12v0
[    0.296571] vsys_5v0: supplied by evm_12v0
[    0.301191] iommu: Default domain type: Translated
[    0.306351] SCSI subsystem initialized
[    0.310463] mc: Linux media interface: v0.10
[    0.314833] videodev: Linux video capture interface: v2.00
[    0.320461] pps_core: LinuxPPS API ver. 1 registered
[    0.325531] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.334868] PTP clock support registered
[    0.338886] EDAC MC: Ver: 3.0.0
[    0.342627] FPGA manager framework
[    0.346139] Advanced Linux Sound Architecture Driver Initialized.
[    0.352730] clocksource: Switched to clocksource arch_sys_counter
[    0.359144] VFS: Disk quotas dquot_6.6.0
[    0.363190] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.372872] NET: Registered protocol family 2
[    0.377458] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.386056] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.394836] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.403031] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.410819] TCP: Hash tables configured (established 32768 bind 32768)
[    0.417567] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.424459] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.431857] NET: Registered protocol family 1
[    0.436537] RPC: Registered named UNIX socket transport module.
[    0.442599] RPC: Registered udp transport module.
[    0.447402] RPC: Registered tcp transport module.
[    0.452205] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.458789] PCI: CLS 0 bytes, default 64
[    0.463137] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.473354] Initialise system trusted keyrings
[    0.477970] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.486200] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.492391] NFS: Registering the id_resolver key type
[    0.497586] Key type id_resolver registered
[    0.501858] Key type id_legacy registered
[    0.505977] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.512825] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.520513] 9p: Installing v9fs 9p2000 file system support
[    0.545673] Key type asymmetric registered
[    0.549859] Asymmetric key parser 'x509' registered
[    0.554856] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.562415] io scheduler mq-deadline registered
[    0.567040] io scheduler kyber registered
[    0.572256] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.578412] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.586802] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.593079] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.600883] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.608990] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.617952] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.626767] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.634475] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.647178] brd: module loaded
[    0.653058] loop: module loaded
[    0.656853] megasas: 07.714.04.00-rc1
[    0.661774] libphy: Fixed MDIO Bus: probed
[    0.666439] tun: Universal TUN/TAP device driver, 1.6
[    0.671861] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.678269] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.684339] sky2: driver version 1.30
[    0.688583] VFIO - User Level meta-driver version: 0.3
[    0.694242] i2c /dev entries driver
[    0.698406] sdhci: Secure Digital Host Controller Interface driver
[    0.704730] sdhci: Copyright(c) Pierre Ossman
[    0.709348] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.715660] ledtrig-cpu: registered to indicate activity on CPUs
[    0.721955] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.729062] optee: probing for conduit method.
[    0.733613] optee: revision 3.12 (3d47a131)
[    0.733844] optee: initialized driver
[    0.743114] NET: Registered protocol family 17
[    0.747726] 9pnet: Installing 9P2000 support
[    0.752111] Key type dns_resolver registered
[    0.756569] Loading compiled-in X.509 certificates
[    0.765658] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.771987] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.780092] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[    0.806527] random: fast init done
[    0.832355] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.839843] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.845909] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.851925] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.858347] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[    0.867844] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[    0.874084] pca953x 5-0020: supply vcc not found, using dummy regulator
[    0.880905] pca953x 5-0020: using no AI
[    0.908775] pca953x 5-0020: failed writing register
[    0.913812] pca953x: probe of 5-0020 failed with error -121
[    0.919884] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    0.925913] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[    0.931848] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[    0.938063] pca953x 8-0020: supply vcc not found, using dummy regulator
[    0.944877] pca953x 8-0020: using no AI
[    1.956732] omap_i2c 2060000.i2c: timeout waiting for bus ready
[    1.962785] pca953x 8-0020: failed writing register
[    1.967819] pca953x: probe of 8-0020 failed with error -16
[    1.973751] omap_i2c 2060000.i2c: bus 8 rev0.12 at 400 kHz
[    1.980156] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.990121] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.998922] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    2.008747] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    2.028504] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    2.036192] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.043858] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.052134] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.060410] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.069240] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.076914] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.085189] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.093465] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.102226] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.109897] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.118172] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.126448] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.135567] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    2.145445] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    2.152204] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.161169] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    2.171309] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    2.178068] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.185995] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    2.195372] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    2.204117] printk: console [ttyS2] enabled
[    2.212556] printk: bootconsole [ns16550a0] disabled
[    2.223011] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    2.231939] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    2.242337] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    2.252851] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    2.263006] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    2.273247] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    2.284009] scsi host0: ufshcd
[    2.328736] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.336383] libphy: 46000f00.mdio: probed
[    2.340803] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    2.347543] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    2.361314] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    2.370097] mmc0: CQHCI version 5.10
[    2.373728] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    2.373937] mmc1: CQHCI version 5.10
[    2.389009] pca953x 3-0020: supply vcc not found, using dummy regulator
[    2.395688] pca953x 3-0020: using no AI
[    2.426220] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    2.501790] mmc0: Command Queue Engine enabled
[    2.506231] mmc0: new DDR MMC card at address 0001
[    2.511260] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    2.515857] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    2.521845] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    2.527822] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
[    2.536389]  mmcblk0: p1 p2
[    2.695099] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    2.700583] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    2.705621] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    2.711873] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    2.718297] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    2.725155] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    2.731754] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    2.738090] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    2.742609] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    2.750766] cdns-ufshcd 4e84000.ufs: last intr at 2589257 us, last intr status=0x404
[    2.758490] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    2.765954] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    2.774978] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    2.780969] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    2.787220] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    2.793297] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    2.799379] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    2.811539] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    2.817878] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    2.824216] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    2.830553] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    2.836891] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    2.843228] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    2.849565] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    2.855903] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    2.862240] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    2.868577] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    2.874915] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    2.880212] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    2.885509] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    2.890807] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    2.896103] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    2.901489] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    2.907653] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.913211] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 2590369 us
[    2.920327] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.926058] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.931874] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.937431] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.943074] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    3.408732] omap_i2c 2010000.i2c: timeout waiting for bus ready
[    3.414662] pca953x 3-0020: failed writing register
[    3.419621] pca953x: probe of 3-0020 failed with error -16
[    3.425509] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    3.432331] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    3.439197] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    3.446008] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    3.452529] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.460274] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    3.469822] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.477355] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.485449] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.493539] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.502233] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.509732] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.517821] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.525908] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.534502] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.541995] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.550079] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.558190] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.567192] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    3.577235] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    3.590457] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    3.595694] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[    3.602785] mtd: 47040000.spi.0: skipping zero sized partition
[    3.608622] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    3.615238] Creating 7 MTD partitions on "47040000.spi.0":
[    3.620720] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    3.626710] 0x000000080000-0x000000280000 : "ospi.tispl"
[    3.632400] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    3.638212] 0x000000680000-0x0000006c0000 : "ospi.env"
[    3.643710] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    3.649444] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    3.655611] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    3.663015] mmc1: new ultra high speed DDR50 SDHC card at address 5048
[    3.669919] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[    3.674981] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.681882] spi-nor: probe of spi1.0 failed with error -2
[    3.689785]  mmcblk1: p1 p2
[    3.724735] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.732380] libphy: 46000f00.mdio: probed
[    3.736803] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    3.743542] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    3.757081] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.764029] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    3.771240] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.777482] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    3.787494] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    3.799117] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.806609] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.814689] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.822769] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.831325] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.838817] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.846899] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.854979] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.863517] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.871004] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.879083] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.887175] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.896537] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.904022] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.912101] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.920181] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.928749] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.936238] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.944323] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.952406] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.960958] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.968450] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.976532] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.984613] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.994594] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    4.002018] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    4.009324] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    4.016628] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    4.024678] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.032057] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    4.039572] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    4.047662] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    4.055748] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.064417] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    4.071916] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    4.080002] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    4.088085] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.096704] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    4.104201] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    4.112286] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    4.120369] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.136792] ALSA device list:
[    4.139749]   No soundcards found.
[    4.484309] EXT4-fs (mmcblk1p2): recovery complete
[    4.489941] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.498051] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    4.508333] devtmpfs: mounted
[    4.511577] Freeing unused kernel memory: 1856K
[    4.516129] Run /sbin/init as init process
[    4.683461] systemd[1]: System time before build time, advancing clock.
[    4.735299] NET: Registered protocol family 10
[    4.740187] Segment Routing with IPv6
[    4.753281] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.768807] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.788424] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    4.810135] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[    4.849569] systemd[1]: Set hostname to <j7-evm>.
[    4.955707] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.974117] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.990088] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.006184] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.025664] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.043077] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.061122] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.078933] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.096591] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.113677] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.131294] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.149127] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.166840] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.184785] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.203294] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.221230] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.237729] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.254078] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.271381] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.288442] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.306642] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.324410] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.342834] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.360880] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.379622] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.397262] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.415682] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.434225] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.452124] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.469678] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.486712] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.502968] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.521009] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.537542] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.554959] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.571537] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.589054] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.607646] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.625409] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.642068] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.658695] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.676645] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.698494] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.716429] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.733581] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.751308] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.769102] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.785259] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.801160] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.817286] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.835479] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.853772] systemd[1]: Configuration file /lib/systemd/system/strongswan-starter.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.871300] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.887473] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.903854] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.920057] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.936475] systemd[1]: Configuration file /lib/systemd/system/rngd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.952542] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.970240] systemd[1]: Configuration file /lib/systemd/system/ofono.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.986591] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.003183] systemd[1]: Configuration file /lib/systemd/system/kdump.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.019293] systemd[1]: Configuration file /lib/systemd/system/irqbalanced.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.035940] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.052385] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.069034] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.085957] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.102619] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.120366] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.137074] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.153949] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.170800] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.187705] systemd[1]: Configuration file /lib/systemd/system/docker.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.204079] systemd[1]: Configuration file /lib/systemd/system/docker.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.220136] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[    6.239857] systemd[1]: Configuration file /lib/systemd/system/demo.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.256007] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.272161] systemd[1]: Configuration file /lib/systemd/system/crond.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.288395] systemd[1]: Configuration file /lib/systemd/system/bt-enable.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.305121] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.322408] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.339346] systemd[1]: Configuration file /lib/systemd/system/atd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.356133] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.374896] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.391240] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.408578] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.425983] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.442160] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.459121] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.476870] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.495144] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.511689] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.528276] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.544845] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.561909] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.580374] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.598064] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.614109] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.631538] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.648856] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.666831] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.683640] systemd[1]: Configuration file /lib/systemd/system/psplash-systemd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.700779] systemd[1]: Configuration file /lib/systemd/system/psplash-start.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.717780] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.734285] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.751696] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.768381] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.785288] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.801964] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.818454] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.836252] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.854587] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.872088] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.889275] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.906393] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.923532] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.940778] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.957687] systemd[1]: Configuration file /lib/systemd/system/var-volatile-srv.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.975095] systemd[1]: Configuration file /lib/systemd/system/var-volatile-spool.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.992629] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.010058] systemd[1]: Configuration file /lib/systemd/system/var-volatile-cache.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.027572] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.043555] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.061247] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.078679] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.095192] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.112030] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.130361] random: systemd: uninitialized urandom read (16 bytes read)
[    7.137072] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    7.149399] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.159404] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    7.180803] random: systemd: uninitialized urandom read (16 bytes read)
[    7.188067] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    7.208799] random: systemd: uninitialized urandom read (16 bytes read)
[    7.215926] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    7.236910] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    7.260842] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    7.284840] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    7.300784] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    7.320778] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    7.336780] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    7.354221] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.376806] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.396906] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.415366] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    7.436915] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    7.469621] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.477931] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.501000] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.517043] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.540960] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.560888] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.583036] systemd[1]: Mounting Huge Pages File System...
[    7.599523] systemd[1]: Mounting POSIX Message Queue File System...
[    7.623411] systemd[1]: Mounting Kernel Debug File System...
[    7.643676] systemd[1]: Mounting Temporary Directory (/tmp)...
[    7.663528] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    7.691402] systemd[1]: Starting Start psplash boot splash screen...
[    7.720891] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    7.746965] systemd[1]: Starting RPC Bind...
[    7.761120] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.785197] systemd[1]: Starting Journal Service...
[    7.793824] systemd-journald[166]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.816460] systemd[1]: Starting Load Kernel Modules...
[    7.821714] systemd-journald[166]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.847140] cryptodev: loading out-of-tree module taints kernel.
[    7.856131] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
[0m...
[    7.870984] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    7.883616] systemd[1]: Starting udev Coldplug all Devices...
[    7.908242] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    7.933856] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    7.957830] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    7.985095] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    8.005111] systemd[1]: Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Temporary Directory (/tmp).
[    8.029973] systemd[1]: Started Create list of static device nodes for the current kernel.
[  OK  ] Started Create list of sta… nodes for the current kernel.
[    8.061124] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage    8.190813] systemd-journald[166]: Received client request to flush runtime journal.
0m...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[    8.875150] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[  OK  ] Started Job spooling tools.[    8.888787] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.902055] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[  OK  ] Started Periodic Command Scheduler j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[0m.
[    8.936872] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[  OK  ] Started D-Bus System Message Bus    8.944577] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
m.
[    8.964791] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
         Starting Print notice about GPLv3 packages[    8.982950] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
         Starting IPv6 Packet Filtering Framework..[    9.004492] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.024789] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
         Starting IPv4 Packet Filtering Framework..[    9.040781] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.052753] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started irqbalance daemon.[    9.065853] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.080783] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
         Starting Telephony service...[    9.092610] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.108795] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
         Starting rc.pvr.service...
         Starting Login Service...
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Reached target Network (Pre).
         Starting Network Service...
[  OK  ] Started Telephony service.
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[    9.313251] PVR_K:  253: Read BVNC 22.104.208.318 from HW device registers
[    9.324789] PVR_K:  253: RGX Device registered with BVNC 22.104.208.318
[    9.337081] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[    9.349191] Bluetooth: Core ver 2.22
[    9.350542] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.352831] NET: Registered protocol family 31
[    9.364755] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.372905] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.381055] Bluetooth: HCI device and connection manager initialized
[    9.381060] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.391353] Bluetooth: HCI socket layer initialized
[    9.401292] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.405010] Bluetooth: L2CAP socket layer initialized
[    9.412754] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.421944] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.421977] Bluetooth: SCO socket layer initialized
[    9.430056] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.444888] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.452404] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.467414] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.482671] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Login Service.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[    9.688168] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.695678] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.711808] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.724447] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.740469] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.751458] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.764724] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.772934] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.791766] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.799281] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.814154] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.825943] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.838192] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.845714] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.857799] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.865950] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.879187] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.888045] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.898697] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.908801] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.942109] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[   10.001058] ina2xx 4-0040: error configuring the device: -121
[   10.079464] ina2xx 4-0041: error configuring the device: -121
[   10.100687] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[   10.135548] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[   10.158449] ina2xx 4-0042: error configuring the device: -121
[   10.187114] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[   10.210052] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.219588] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.234757] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.245482] ina2xx 4-0043: error configuring the device: -121
[   10.249481] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.268398] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.276975] ina2xx 4-0044: error configuring the device: -121
[   10.281456] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.291224] remoteproc remoteproc0: 4d80800000.dsp is available
[   10.297138] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.297152] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.298202] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.323020] ina2xx 4-0045: error configuring the device: -121
[   10.334304] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.347233] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.359900] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.372666] ina2xx 4-0046: error configuring the device: -121
[   10.397616] ina2xx 4-0047: error configuring the device: -121
[   10.414394] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.421991] remoteproc remoteproc0: powering up 4d80800000.dsp
[   10.427969] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 187480
[   10.436250] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.448767] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.457169] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200000
[   10.458364] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[   10.465112] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.482168]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[   10.493351] virtio_rpmsg_bus virtio0: rpmsg host is online
[   10.498990] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.499360] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[   10.506503]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[   10.520090] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.521269] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[   10.528178] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.545427] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[   10.552412] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[   10.554922] random: crng init done
[   10.559579] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.562915] random: 7 urandom warning(s) missed due to ratelimiting
[   10.590464] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.602518] ina2xx 4-0048: error configuring the device: -121
[   10.608474] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.616697] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.628772] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.645683] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.660780] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.664744] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[   10.668895] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.685107] ina2xx 4-0049: error configuring the device: -121
[   10.688750] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.701043] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.707275] ina2xx 4-004a: error configuring the device: -121
[   10.712750] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.722718] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.736777] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.740926] remoteproc remoteproc1: 4d81800000.dsp is available
[  OK  ] Started Load/Save Random Seed.
[   10.768276] ina2xx 4-004b: error configuring the device: -121
[   10.803922] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.813149] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.822533] ina2xx 4-004c: error configuring the device: -121
[   10.828454] remoteproc remoteproc1: powering up 4d81800000.dsp
[   10.834342] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 187480
[   10.841582] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.851019] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200000
[   10.862513] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.873408]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[   10.883566] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   10.893939] virtio_rpmsg_bus virtio1: rpmsg host is online
[   10.899579] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.907127]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[   10.914141] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.925137] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[   10.932530] ina2xx 4-004d: error configuring the device: -121
[   10.935432] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.952575] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.961148] ina2xx 4-004e: error configuring the device: -121
[   10.965575] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.978343] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.988845] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.000135] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.012179] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[   11.020156] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.027696] ina2xx 4-004f: error configuring the device: -121
[   11.032554] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[   11.040577] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.049656] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[   11.052772] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.065992] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.078355] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.088784] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.096992] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.108779] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.152843] remoteproc remoteproc2: 64800000.dsp is available
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[   11.272526] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.282454] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.296555] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.312852] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.325596] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.333104] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.352795] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.363564] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.378829] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.388201] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.400774] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.409253] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.445639] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.456868] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.468806] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.484793] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.549215] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.558734] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.569846] remoteproc remoteproc2: powering up 64800000.dsp
[   11.572791] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.575561] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10489872
[   11.592790] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.596775] remoteproc remoteproc2: unsupported resource 65538
[   11.607620] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
[   11.611851] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.623103]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[   11.632921] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.642568] virtio_rpmsg_bus virtio2: rpmsg host is online
[   11.648455] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.661235] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.674469] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[   11.682674]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[   11.684895] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[   11.692794] remoteproc remoteproc2: remote processor 64800000.dsp is now up
[   11.696006] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.716213] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[   11.719078] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.745870] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.753989] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.771951] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.780456] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.782053] CAN device driver interface
[   11.792757] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.800963] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.816333] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[   11.823495] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   11.831774] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   12.061279] platform 41000000.r5f: configured R5F for IPC-only mode
[   12.285932] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   12.485136] remoteproc remoteproc3: 41000000.r5f is available
[   12.637277] remoteproc remoteproc3: attaching to 41000000.r5f
[   12.703603] am65-cpsw-nuss 46000000.ethernet: phy /bus@100000/bus@28380000/ethernet@46000000/mdio@f00/ethernet-phy@0 not found on slave 1
[   12.758792] platform 41000000.r5f: R5F core initialized in IPC-only mode
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav-dev
        gstreamer1.0-libav
        gzip
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp-dev
        libgmp10
        libgmpxx4
        libidn2-0
        libidn2-dev
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline8
        libunistring-dev
        libunistring2
        m4-dev
        m4
        make
        nettle-dev
        nettle
        parted
        python3-rfc3987
        python3-strict-rfc3339
        tar
        which
        zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to[   12.871841]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
 distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[   13.020283] virtio_rpmsg_bus virtio3: rpmsg host is online
[   13.030629] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[   13.092136]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[   13.156634] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
[   13.240466] platform 5c00000.r5f: configured R5F for remoteproc mode
[   13.359142] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   13.422972] remoteproc remoteproc4: 5c00000.r5f is available
[   13.511805] platform 5d00000.r5f: configured R5F for remoteproc mode
[   13.522116] remoteproc remoteproc4: powering up 5c00000.r5f
[   13.527735] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 527528
[   13.542727]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[   13.554138] virtio_rpmsg_bus virtio4: rpmsg host is online
[   13.562860]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[   13.570985] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[   13.726865] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   13.811551] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   13.887476] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[   13.925540] remoteproc remoteproc5: 5d00000.r5f is available
[   14.075318] remoteproc remoteproc5: powering up 5d00000.r5f
[   14.080919] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 78708
[   14.081869] platform 5e00000.r5f: configured R5F for remoteproc mode
[   14.096212]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[   14.109343] virtio_rpmsg_bus virtio5: rpmsg host is online
[   14.114923]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[   14.123966] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[   14.124061] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[   14.136706] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   14.168822] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
[   14.326353] remoteproc remoteproc6: 5e00000.r5f is available
[   14.435157] remoteproc remoteproc6: powering up 5e00000.r5f
[   14.440771] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 78708
[   14.454481] platform 5f00000.r5f: configured R5F for remoteproc mode
[   14.462094]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[   14.472871] virtio_rpmsg_bus virtio6: rpmsg host is online
[   14.480772]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[   14.489929] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[   14.500829] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[   14.511905] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   14.607292] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[   14.762986] remoteproc remoteproc7: 5f00000.r5f is available
[   14.873027] remoteproc remoteproc7: powering up 5f00000.r5f
[   14.878645] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 78708
[   14.892179]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[   14.904030] virtio_rpmsg_bus virtio7: rpmsg host is online
[   14.912648]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[   14.921794] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[   14.930795] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[   14.940840] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
[   15.313806] usbcore: registered new interface driver usbfs
[   15.369930] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[   15.465062] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   15.549721] usbcore: registered new interface driver hub
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm login: [   15.663480] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   15.690879] remoteproc remoteproc8: b034000.pru is available
[   15.813949] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
[   15.845227] remoteproc remoteproc9: b004000.rtu is available
[   15.875304] usbcore: registered new device driver usb
[   15.952373] remoteproc remoteproc10: b00a000.txpru is available
[   16.022120] remoteproc remoteproc11: b038000.pru is available
[   16.055458] remoteproc remoteproc12: b006000.rtu is available
[   16.074755] remoteproc remoteproc13: b00c000.txpru is available
[   16.092854] PVR_K:  1079: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   16.093042] remoteproc remoteproc14: b134000.pru is available
[   16.336044] remoteproc remoteproc15: b104000.rtu is available
[   16.418283] remoteproc remoteproc16: b10a000.txpru is available
[   16.462842] remoteproc remoteproc17: b138000.pru is available
[   16.477309] remoteproc remoteproc18: b106000.rtu is available
[   16.493806] remoteproc remoteproc19: b10c000.txpru is available
[   16.503520] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   16.673632] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
j7-evm login:
j7-evm login:
j7-evm login: [   18.251784] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   18.258670] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.266895] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.273506] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   18.282543] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.290779] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.301754] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.309986] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.320247] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.328485] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.338729] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.346957] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.357752] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.365977] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.376227] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
j7-evm login: [   18.384463] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.394708] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.402932] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.413752] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.421979] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.432213] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.440437] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.450676] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.458900] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.469747] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.477975] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.488208] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.496430] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.506672] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.514894] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.525748] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.533972] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.543603] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.551825] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.562750] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.570974] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.581747] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.589970] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.600205] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.608429] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.618667] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.626890] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.637748] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.645970] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.656202] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
r[   18.664437] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.674691] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.682924] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.693750] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.701979] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.712215] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.720448] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.730680] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.738901] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.749746] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.757967] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.768198] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.776419] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.786658] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.794878] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.805745] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
o[   18.813979] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.824207] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.832427] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.839032] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[   18.848045] Console: switching to colour frame buffer device 128x48
[   18.855507] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
[   18.885646] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   18.885666] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   18.885677] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
o[   18.885686] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   18.893642] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   18.893667] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   18.893676] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   18.893687] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   18.894250] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   18.894270] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   18.894279] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
t[   18.894290] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   18.896195] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[   18.897600] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[   18.898334] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.898954] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   18.898974] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   18.898984] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   18.898993] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   18.899407] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   18.899423] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   18.899432] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   18.899442] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   18.899811] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
Last login: Wed Aug  4 22:20:56 UTC 2021
[   18.899826] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   18.899835] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   18.899845] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# ls
root@j7-evm:~# cd /opt/
root@j7-evm:/opt# ls
containerd  img-powervr-sdk  ltp  vx_app_arm_remote_log.out
root@j7-evm:/opt# ./v[   25.293313] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   25.300184] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
APP_LOG: ERROR: Unable to map memory @ 0xb2000000 of size 262144 bytes !!!
[   26.722640] xhci-hcd xhci-hcd.2.auto: can't setup: -110
[   26.727866] xhci-hcd xhci-hcd.2.auto: USB bus 1 deregistered
[   26.733562] xhci-hcd: probe of xhci-hcd.2.auto failed with error -110
[   26.740125] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.745617] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[   26.753629] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[   26.763052] xhci-hcd xhci-hcd.3.auto: irq 613, io mem 0x06410000
[   26.769244] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   26.777501] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   26.784711] usb usb1: Product: xHCI Host Controller
[   26.789580] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   26.796096] usb usb1: SerialNumber: xhci-hcd.3.auto
[   26.801218] hub 1-0:1.0: USB hub found
[   26.804995] hub 1-0:1.0: 1 port detected
[   26.809439] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   26.810177] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.821867] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[   26.821924] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   26.829523] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   26.837763] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   26.843536] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   26.851949] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   26.859712] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   26.868119] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.875995] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   26.875998] usb usb2: Product: xHCI Host Controller
[   26.876000] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   26.876002] usb usb2: SerialNumber: xhci-hcd.3.auto
[   26.876468] hub 2-0:1.0: USB hub found
[   26.891569] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   26.896364] hub 2-0:1.0: 1 port detected
[   26.902886] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   26.931114] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   26.939261] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.953895] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   26.961471] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   26.969607] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   26.977748] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.989276] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   26.996910] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   27.005192] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   27.013357] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   27.021489] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   27.030496] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   27.038033] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   27.046140] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   27.054238] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   31.741451] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   31.748322] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   31.874547] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.882817] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.897096] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.904756] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.915766] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.924025] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.934778] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.943038] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.959774] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.973727] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.984069] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   31.992322] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.003525] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.011782] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.025776] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.035674] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.046764] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.055027] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.067161] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.082498] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.093778] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.102270] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.112570] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.121622] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.132453] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.141305] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.151578] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.159821] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.170754] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.178992] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.189748] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.197974] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.207622] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.215851] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.226753] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.234983] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.245747] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.253979] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.264219] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.272440] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.282675] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.290905] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.301747] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.309979] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.320226] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.328452] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.338684] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.346913] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.357747] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.365973] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.376225] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.384446] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.394688] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.402911] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.413637] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.421866] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.432098] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.440318] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.450557] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.458780] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.469746] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.477972] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.488217] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.496443] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.503047] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
^C
root@j7-evm:/opt# [   35.912747] tlv71033: disabling
[   38.928477] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   38.935349] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   45.356492] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   45.363362] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[  130.009244] Initializing XFRM netlink socket
[  132.873695] process 'docker/tmp/qemu-check533801743/check' started with executable stack
[ 1791.429102] mmc1: card 5048 removed
[ 1791.456096] JBD2: Error while async write back metadata bh 3146286.
[ 1791.456106] Aborting journal on device mmcblk1p2-8.
[ 1791.468797] JBD2: Error -5 detected when updating journal superblock for mmcblk1p2-8.
[ 1791.478889] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[ 1791.490738] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #15: comm systemd-udevd: reading directory lblock 0
[ 1791.502232] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[ 1791.514708] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #785007: comm systemd-udevd: reading directory lblock 0
[ 1791.526558] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[ 1791.538373] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[ 1791.550187] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[ 1791.562624] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #784636: comm systemd-udevd: reading directory lblock 0
[ 1791.574442] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[ 1791.587774] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[ 1791.599650] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-udevd: reading directory lblock 0
[ 1791.611512] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #783510: comm systemd-udevd: reading directory lblock 0
[ 1791.624341] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:83: Detected aborted journal
[ 1791.633401] EXT4-fs (mmcblk1p2): Remounting filesystem read-only
[ 1791.639397] ------------[ cut here ]------------
[ 1791.644005] bdi-(unknown) not registered
[ 1791.647956] WARNING: CPU: 1 PID: 183 at fs/fs-writeback.c:2326 __mark_inode_dirty+0x1d8/0x200
[ 1791.656456] Modules linked in: xt_conntrack xt_MASQUERADE xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ip_tables x_tables bridge stp llc overlay xfrm_user xfrm_algo md5 ecb aes_neon_bs aes_neon_blk des_generic libdes cbc xhci_plat_hcd xhci_hcd ti_am335x_adc kfifo_buf cdns3 udc_core roles rpmsg_char irq_pruss_intc pru_rproc icss_iep omap_rng rng_core cdns_csi2rx usbcore usb_common crct10dif_ce snd_soc_j721e_evm ti_j721e_cpsw_virt_mac phy_can_transceiver m_can_platform m_can can_dev ti_am335x_tscadc cdns_mhdp8546 pruss ti_k3_r5_remoteproc sa2ul sha512_generic authenc ov5640 v4l2_fwnode snd_soc_pcm3168a_i2c snd_soc_pcm3168a ti_k3_dsp_remoteproc virtio_rpmsg_bus ina2xx vxd_dec j721e_csi2rx cdns_dphy bluetooth videobuf2_dma_sg v4l2_mem2mem ecdh_generic ecc rfkill videobuf2_dma_contig videobuf2_memops pvrsrvkm(O) videobuf2_v4l2 videobuf2_common cdns3_ti rti_wdt sch_fq_codel rpmsg_kdrv_switch cryptodev(O) ipv6
[ 1791.741100] CPU: 1 PID: 183 Comm: systemd-udevd Tainted: G           O      5.10.41-g4c2eade9f7 #2
[ 1791.750035] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 1791.755850] pstate: 40000005 (nZcv daif -PAN -UAO -TCO BTYPE=--)
[ 1791.761840] pc : __mark_inode_dirty+0x1d8/0x200
[ 1791.766354] lr : __mark_inode_dirty+0x1d8/0x200
[ 1791.770867] sp : ffff800012ecfb90
[ 1791.774167] x29: ffff800012ecfb90 x28: 0000000000000000
[ 1791.779464] x27: ffff000804444e58 x26: ffff000803244898
[ 1791.784760] x25: 0000000000000002 x24: 0000000000000000
[ 1791.790056] x23: ffff0008206b01c8 x22: 0000000000000000
[ 1791.795353] x21: 0000000000000001 x20: ffff0008206b0140
[ 1791.800649] x19: ffff000802af0860 x18: 0000000000000010
[ 1791.805946] x17: 0000000000000000 x16: 0000000000000000
[ 1791.811242] x15: ffff000803656730 x14: 0000000000000476
[ 1791.816538] x13: ffff000803656730 x12: 00000000ffffffea
[ 1791.821835] x11: ffff8000111ba360 x10: ffff8000111a2320
[ 1791.827131] x9 : ffff8000111a2378 x8 : 0000000000017fe8
[ 1791.832428] x7 : c0000000ffffefff x6 : 0000000000000001
[ 1791.837723] x5 : 0000000000000000 x4 : ffff00087fa81aa8
[ 1791.843018] x3 : ffff00087fa889b0 x2 : ffff00087fa81aa8
[ 1791.848314] x1 : 9debe79c1ac7eb00 x0 : 0000000000000000
[ 1791.853611] Call trace:
[ 1791.856047]  __mark_inode_dirty+0x1d8/0x200
[ 1791.860216]  generic_update_time+0x64/0xe0
[ 1791.864296]  update_time+0x2c/0x38
[ 1791.867684]  touch_atime+0x1b0/0x250
[ 1791.871246]  ext4_file_mmap+0x64/0x88
[ 1791.874898]  mmap_region+0x3c8/0x690
[ 1791.878460]  do_mmap+0x35c/0x598
[ 1791.881676]  vm_mmap_pgoff+0xdc/0x108
[ 1791.885323]  ksys_mmap_pgoff+0x1b8/0x1e8
[ 1791.889233]  __arm64_sys_mmap+0x30/0x48
[ 1791.893055]  el0_svc_common.constprop.0+0x78/0x1a0
[ 1791.897829]  do_el0_svc+0x24/0x90
[ 1791.901133]  el0_svc+0x14/0x20
[ 1791.904174]  el0_sync_handler+0xb0/0xb8
[ 1791.907994]  el0_sync+0x180/0x1c0
[ 1791.911296] ---[ end trace 3aacffa76a9a5307 ]---
[ 1791.916195] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[ 1791.928786] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[ 1791.941259] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[ 1791.953765] EXT4-fs warning (device mmcblk1p2): dx_probe:767: inode #12102: lblock 0: comm systemd-udevd: error -5 reading directory block
[ 1819.926737] EXT4-fs error: 34 callbacks suppressed
[ 1819.926743] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm crond: reading directory lblock 0
[ 1819.942717] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #791785: comm crond: reading directory lblock 0
[ 1819.953910] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm crond: reading directory lblock 0
[ 1819.965063] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm crond: reading directory lblock 0
[ 1819.976229] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm crond: reading directory lblock 0
[ 1819.987413] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #791785: comm crond: reading directory lblock 0
[ 1823.404562] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[ 1823.416683] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[ 1823.428336] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm systemd-timesyn: reading directory lblock 0
[ 1823.440422] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm sd-resolve: reading directory lblock 0
[ 1831.971192] EXT4-fs error: 16 callbacks suppressed
[ 1831.971198] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm weston-desktop-: reading directory lblock 0
[ 1831.988123] EXT4-fs error (device mmcblk1p2): __ext4_find_entry:1534: inode #261121: comm weston-desktop-: reading directory lblock 0
[ 1?
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:47 +0800)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -19
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
U-Boot 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   Could not get PHY for ethernet@46000000: addr 0
am65_cpsw_nuss_slave ethernet@46000000: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  1
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 0 ms
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19137024 bytes read in 798 ms (22.9 MiB/s)
97623 bytes read in 13 ms (7.2 MiB/s)
   Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.41-g4c2eade9f7 (qywu@op01) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT Tue Oct 26 17:24:36 CST 2021
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0b959c33-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3372032K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 297984K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008800b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008373] Console: colour dummy device 80x25
[    0.012934] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023604] pid_max: default: 32768 minimum: 301
[    0.028350] LSM: Security Framework initializing
[    0.033094] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040660] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049599] rcu: Hierarchical SRCU implementation.
[    0.054647] Platform MSI: msi-controller@1820000 domain created
[    0.060879] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070176] EFI services will not be available.
[    0.074920] smp: Bringing up secondary CPUs ...
[    0.080101] Detected PIPT I-cache on CPU1
[    0.080125] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.080135] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[    0.080168] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.080216] smp: Brought up 1 node, 2 CPUs
[    0.109561] SMP: Total of 2 processors activated.
[    0.114366] CPU features: detected: 32-bit EL0 Support
[    0.119620] CPU features: detected: CRC32 instructions
[    0.133521] CPU: All CPU(s) started at EL2
[    0.137714] alternatives: patching kernel code
[    0.142707] devtmpfs: initialized
[    0.150902] KASLR disabled due to lack of seed
[    0.155551] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.165514] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.173176] pinctrl core: initialized pinctrl subsystem
[    0.178750] DMI not present or invalid.
[    0.182970] NET: Registered protocol family 16
[    0.190450] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.197750] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.205754] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.214073] thermal_sys: Registered thermal governor 'step_wise'
[    0.214075] thermal_sys: Registered thermal governor 'power_allocator'
[    0.220486] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.234124] ASID allocator initialised with 65536 entries
[    0.256058] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.262912] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.269673] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.277589] cryptd: max_cpu_qlen set to 1000
[    0.283510] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.292336] vsys_3v3: supplied by evm_12v0
[    0.296644] vsys_5v0: supplied by evm_12v0
[    0.301264] iommu: Default domain type: Translated
[    0.306404] SCSI subsystem initialized
[    0.310522] mc: Linux media interface: v0.10
[    0.314899] videodev: Linux video capture interface: v2.00
[    0.320528] pps_core: LinuxPPS API ver. 1 registered
[    0.325598] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.334935] PTP clock support registered
[    0.338953] EDAC MC: Ver: 3.0.0
[    0.342694] FPGA manager framework
[    0.346204] Advanced Linux Sound Architecture Driver Initialized.
[    0.352805] clocksource: Switched to clocksource arch_sys_counter
[    0.359222] VFS: Disk quotas dquot_6.6.0
[    0.363267] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.372925] NET: Registered protocol family 2
[    0.377506] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.386118] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.394885] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.403080] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.410879] TCP: Hash tables configured (established 32768 bind 32768)
[    0.417627] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.424521] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.431916] NET: Registered protocol family 1
[    0.436601] RPC: Registered named UNIX socket transport module.
[    0.442660] RPC: Registered udp transport module.
[    0.447464] RPC: Registered tcp transport module.
[    0.452267] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.458851] PCI: CLS 0 bytes, default 64
[    0.463196] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.473430] Initialise system trusted keyrings
[    0.478042] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.486284] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.492495] NFS: Registering the id_resolver key type
[    0.497717] Key type id_resolver registered
[    0.501990] Key type id_legacy registered
[    0.506109] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.512957] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.520592] 9p: Installing v9fs 9p2000 file system support
[    0.545583] Key type asymmetric registered
[    0.549769] Asymmetric key parser 'x509' registered
[    0.554765] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.562323] io scheduler mq-deadline registered
[    0.566949] io scheduler kyber registered
[    0.572192] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.578357] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.586800] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.593077] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.600854] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.608995] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.617957] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.626779] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.634487] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.647274] brd: module loaded
[    0.653172] loop: module loaded
[    0.656973] megasas: 07.714.04.00-rc1
[    0.661878] libphy: Fixed MDIO Bus: probed
[    0.666531] tun: Universal TUN/TAP device driver, 1.6
[    0.671939] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.678348] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.684420] sky2: driver version 1.30
[    0.688657] VFIO - User Level meta-driver version: 0.3
[    0.694311] i2c /dev entries driver
[    0.698482] sdhci: Secure Digital Host Controller Interface driver
[    0.704805] sdhci: Copyright(c) Pierre Ossman
[    0.709494] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.715826] ledtrig-cpu: registered to indicate activity on CPUs
[    0.722125] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.729237] optee: probing for conduit method.
[    0.733789] optee: revision 3.12 (3d47a131)
[    0.734021] optee: initialized driver
[    0.743334] NET: Registered protocol family 17
[    0.747944] 9pnet: Installing 9P2000 support
[    0.752330] Key type dns_resolver registered
[    0.756775] Loading compiled-in X.509 certificates
[    0.765925] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.772255] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.780372] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[    0.806581] random: fast init done
[    0.832419] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.839959] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.846021] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.852048] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.858459] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[    0.867818] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[    0.874068] pca953x 5-0020: supply vcc not found, using dummy regulator
[    0.880885] pca953x 5-0020: using no AI
[    0.908851] pca953x 5-0020: failed writing register
[    0.913886] pca953x: probe of 5-0020 failed with error -121
[    0.919942] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    0.925974] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[    0.931922] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[    0.938117] pca953x 8-0020: supply vcc not found, using dummy regulator
[    0.944929] pca953x 8-0020: using no AI
[    1.956808] omap_i2c 2060000.i2c: timeout waiting for bus ready
[    1.962861] pca953x 8-0020: failed writing register
[    1.967893] pca953x: probe of 8-0020 failed with error -16
[    1.973809] omap_i2c 2060000.i2c: bus 8 rev0.12 at 400 kHz
[    1.980217] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.990182] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.998983] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    2.008821] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    2.028628] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    2.036318] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.043986] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.052263] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.060541] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.069380] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.077054] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.085330] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.093609] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.102400] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.110065] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.118341] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.126618] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.135743] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    2.145621] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    2.152380] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.161347] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    2.171491] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    2.178250] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.186184] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    2.195546] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    2.204291] printk: console [ttyS2] enabled
[    2.212730] printk: bootconsole [ns16550a0] disabled
[    2.223193] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    2.232134] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    2.242486] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    2.252999] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    2.263154] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    2.273396] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    2.284138] scsi host0: ufshcd
[    2.328812] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.336459] libphy: 46000f00.mdio: probed
[    2.340880] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    2.347620] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    2.361383] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    2.370207] mmc0: CQHCI version 5.10
[    2.370277] mmc1: CQHCI version 5.10
[    2.377563] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    2.389450] pca953x 3-0020: supply vcc not found, using dummy regulator
[    2.396133] pca953x 3-0020: using no AI
[    2.414647] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    2.570084] mmc0: Command Queue Engine enabled
[    2.574526] mmc0: new DDR MMC card at address 0001
[    2.579515] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    2.584106] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    2.590084] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    2.596053] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
[    2.604530]  mmcblk0: p1 p2
[    2.701052] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    2.706534] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    2.711578] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    2.717830] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    2.724260] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    2.731118] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    2.737720] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    2.744059] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    2.748576] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    2.756738] cdns-ufshcd 4e84000.ufs: last intr at 2595130 us, last intr status=0x404
[    2.764465] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    2.771935] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    2.780965] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    2.786955] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    2.793210] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    2.799289] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    2.805373] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    2.817539] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    2.823880] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    2.830223] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    2.836560] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    2.842902] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    2.849240] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    2.855582] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    2.861925] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    2.868266] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    2.874605] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    2.880949] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    2.886247] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    2.891545] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    2.896848] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    2.902145] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    2.907528] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    2.913697] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.919256] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 2596247 us
[    2.926379] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.932109] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.937931] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.943491] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.949140] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    3.404808] omap_i2c 2010000.i2c: timeout waiting for bus ready
[    3.410722] pca953x 3-0020: failed writing register
[    3.415677] pca953x: probe of 3-0020 failed with error -16
[    3.421562] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    3.428385] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    3.435199] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    3.437448] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.442008] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    3.456037] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    3.465618] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.473122] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.481266] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.489398] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.498117] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.505619] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.513705] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.521789] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.530345] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.537842] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.545920] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.554005] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.563003] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    3.573072] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    3.586246] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    3.591494] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[    3.598536] mtd: 47040000.spi.0: skipping zero sized partition
[    3.604369] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    3.610978] Creating 7 MTD partitions on "47040000.spi.0":
[    3.616462] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    3.622559] 0x000000080000-0x000000280000 : "ospi.tispl"
[    3.628375] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    3.634522] mmc1: new ultra high speed DDR50 SDHC card at address 5048
[    3.641217] 0x000000680000-0x0000006c0000 : "ospi.env"
[    3.641389] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[    3.646819] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    3.656537] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    3.662413]  mmcblk1: p1 p2
[    3.662756] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    3.673061] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.679935] spi-nor: probe of spi1.0 failed with error -2
[    3.724812] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.732458] libphy: 46000f00.mdio: probed
[    3.736879] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    3.743606] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    3.757142] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.764117] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    3.771326] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.777590] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    3.787594] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    3.799191] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.806685] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.814765] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.822845] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.831411] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.838908] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.846991] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.855071] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.863608] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.871101] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.879181] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.887261] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.896583] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.904068] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.912147] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.920226] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.928760] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.936248] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.944333] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.952413] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.960942] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.968429] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.976511] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.984592] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.994504] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    4.001955] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    4.009263] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    4.016567] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    4.024621] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.031988] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    4.039492] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    4.041621] ALSA device list:
[    4.047574] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    4.050526]   No soundcards found.
[    4.058595] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.070662] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    4.078150] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    4.086229] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    4.094307] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.102869] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    4.110356] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    4.118435] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    4.126515] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.180505] EXT4-fs (mmcblk1p2): recovery complete
[    4.186319] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.194420] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    4.201257] devtmpfs: mounted
[    4.204503] Freeing unused kernel memory: 1856K
[    4.209057] Run /sbin/init as init process
[    4.391680] systemd[1]: System time before build time, advancing clock.
[    4.443625] NET: Registered protocol family 10
[    4.448523] Segment Routing with IPv6
[    4.468044] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.483438] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.503012] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    4.524727] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[    4.561633] systemd[1]: Set hostname to <j7-evm>.
[    4.667408] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.685847] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.701868] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.717983] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.737336] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.754757] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.772764] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.790590] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.808237] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.825324] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.842945] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.860744] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.878455] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.896377] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.914889] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.932821] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.949343] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.965701] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.983023] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.000073] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.018231] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.035979] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.054404] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.072415] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.091161] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.108792] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.127220] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.145765] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.163646] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.181208] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.198256] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.214534] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.232540] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.249073] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.266454] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.283027] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.300510] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.319093] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.336834] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.353493] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.370135] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.388120] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.407758] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.425713] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.442844] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.460545] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.478363] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.494488] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.510362] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.526469] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.544643] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.562910] systemd[1]: Configuration file /lib/systemd/system/strongswan-starter.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.580432] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.596593] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.613011] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.629219] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.645611] systemd[1]: Configuration file /lib/systemd/system/rngd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.661689] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.679366] systemd[1]: Configuration file /lib/systemd/system/ofono.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.695684] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.712277] systemd[1]: Configuration file /lib/systemd/system/kdump.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.728385] systemd[1]: Configuration file /lib/systemd/system/irqbalanced.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.745041] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.761486] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.778062] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.794937] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.811549] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.829285] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.845961] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.862814] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.879666] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.896556] systemd[1]: Configuration file /lib/systemd/system/docker.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.912927] systemd[1]: Configuration file /lib/systemd/system/docker.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.928981] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[    5.948703] systemd[1]: Configuration file /lib/systemd/system/demo.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.964865] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.981033] systemd[1]: Configuration file /lib/systemd/system/crond.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.997265] systemd[1]: Configuration file /lib/systemd/system/bt-enable.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.013975] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.031225] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.048139] systemd[1]: Configuration file /lib/systemd/system/atd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.064932] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.083661] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.099983] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.117328] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.134715] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.150863] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.167781] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.185518] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.203753] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.220308] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.236895] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.253463] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.270509] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.288965] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.306642] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.322675] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.340093] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.357397] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.375358] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.392144] systemd[1]: Configuration file /lib/systemd/system/psplash-systemd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.409279] systemd[1]: Configuration file /lib/systemd/system/psplash-start.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.426257] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.442763] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.460159] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.476858] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.493750] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.510394] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.526860] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.544642] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.562952] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.580415] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.597573] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.614656] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.631783] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.649013] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.665891] systemd[1]: Configuration file /lib/systemd/system/var-volatile-srv.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.683259] systemd[1]: Configuration file /lib/systemd/system/var-volatile-spool.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.700795] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.718197] systemd[1]: Configuration file /lib/systemd/system/var-volatile-cache.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.735692] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.751658] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.769306] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.786719] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.803218] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.820050] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.838278] random: systemd: uninitialized urandom read (16 bytes read)
[    6.844985] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    6.857310] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    6.867157] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    6.888877] random: systemd: uninitialized urandom read (16 bytes read)
[    6.896093] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    6.916872] random: systemd: uninitialized urandom read (16 bytes read)
[    6.923979] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    6.944976] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    6.968911] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    6.992906] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    7.012859] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    7.032851] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    7.052856] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    7.080778] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.104886] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.124975] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.143436] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    7.164988] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    7.197700] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.206009] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.229058] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.249104] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.273024] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.292960] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.315096] systemd[1]: Mounting Huge Pages File System...
[    7.339701] systemd[1]: Mounting POSIX Message Queue File System...
[    7.366935] systemd[1]: Mounting Kernel Debug File System...
[    7.387817] systemd[1]: Mounting Temporary Directory (/tmp)...
[    7.411327] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    7.443237] systemd[1]: Starting Start psplash boot splash screen...
[    7.472676] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    7.498944] systemd[1]: Starting RPC Bind...
[    7.520980] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.539925] systemd[1]: Starting Journal Service...
         Starting Journal Service...[    7.549148] systemd-journald[166]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.581803] systemd-journald[166]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.584162] systemd[1]: Starting Load Kernel Modules...
[    7.623068] cryptodev: loading out-of-tree module taints kernel.
[    7.631328] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.646774] cryptodev: driver 1.10 loaded.
[    7.659829] systemd[1]: Starting udev Coldplug all Devices...
[    7.673195] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    7.681314] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    7.702035] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    7.725224] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    7.749207] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    7.916574] systemd-journald[166]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started D-Bus System Message Bus.
         Starting Print notice about GPLv3 packages...
[    8.636013] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.644887] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework    8.660869] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
m...
[  OK  ] Started irqbalance daemon.
         Starting Telephony service...
[    8.681205] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
         Starting rc.pvr.service...
         Starting Login Service...
[    8.696333] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[  OK  ] Started Reboot and dump vmcore via [    8.712245] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
kexec.
[  OK  ] Started IPv6 Packet Fil[    8.724724] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
tering Framework.
[  OK  ] Started IPv4[    8.738892] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Reached ta[    8.749285] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
rget Network (Pre).
         Starting Net[    8.762736] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
work Service...
[    8.776867] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    8.786162] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.797782] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.808843] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.816997] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.825192] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.836528] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.846174] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    8.860868] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.875753] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.889446] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    8.904862] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    8.920359] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    8.932320] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.948608] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.960875] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.975221] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.987138] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.003997] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.016601] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.026783] PVR_K:  251: Read BVNC 22.104.208.318 from HW device registers
[    9.033797] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.036876] PVR_K:  251: RGX Device registered with BVNC 22.104.208.318
[    9.048831] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[  OK  ] Started Telephony service.
[    9.111944] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[    9.146593] Bluetooth: Core ver 2.22
[    9.152237] NET: Registered protocol family 31
[    9.160894] Bluetooth: HCI device and connection manager initialized
[    9.173112] Bluetooth: HCI socket layer initialized
[    9.184867] Bluetooth: L2CAP socket layer initialized
[    9.192118] Bluetooth: SCO socket layer initialized
[    9.201488] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.211181] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.222415] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.234399] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.247981] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.256248] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.264385] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.276894] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.285727] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.294918] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.304169] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.312324] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Login Service.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[    9.650740] ina2xx 4-0040: error configuring the device: -121
[    9.694634] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.703417] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.720840] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.732304] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.749716] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.764882] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.777383] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.792949] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.807463] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.820851] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.836848] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.852842] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.865289] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.880883] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.893238] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.907678] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.942789] ina2xx 4-0041: error configuring the device: -121
[   10.031726] ina2xx 4-0042: error configuring the device: -121
[   10.053482] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[   10.134738] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.139477] random: crng init done
[   10.144869] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.145595] random: 7 urandom warning(s) missed due to ratelimiting
[   10.160001] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.170710] ina2xx 4-0043: error configuring the device: -121
[   10.176513] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.190033] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.204871] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.216928] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.232868] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.247568] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.260846] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.274977] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.287954] ina2xx 4-0044: error configuring the device: -121
[   10.296631] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.308945] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.310816] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[   10.320829] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.340858] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.351893] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[   10.358944] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.373418] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.383430] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.396856] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.403533] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[   10.408832] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.434745] ina2xx 4-0045: error configuring the device: -121
[   10.457882] ina2xx 4-0046: error configuring the device: -121
[   10.465375] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.470581] remoteproc remoteproc0: 4d80800000.dsp is available
[   10.476152] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.490510] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.495551] ina2xx 4-0047: error configuring the device: -121
[   10.504589] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.522420] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.534390] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.545853] ina2xx 4-0048: error configuring the device: -121
[   10.551643] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.564840] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.581352] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.593158] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.608544] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.622408] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.635759] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[   10.644541] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.652598] ina2xx 4-0049: error configuring the device: -121
[   10.658472] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[  OK  ] Started Simple Network Man…ement [   10.667391] remoteproc remoteproc0: powering up 4d80800000.dsp
[   10.678403] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 187480
[   10.687990] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.705105] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200000
[   10.713050] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.732838] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[   10.739826]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[   10.748304] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.755942] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.764322] virtio_rpmsg_bus virtio0: rpmsg host is online
[   10.769846]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[   10.770033] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[   10.780829] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.785752] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[   10.791495] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[   10.812875] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.826049] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.836891] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.846379] ina2xx 4-004a: error configuring the device: -121
[   10.852190] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.864884] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.880997] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.888500] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.908870] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.920864] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.937845] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.945908] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[   10.953121] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.961275] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.972591] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.990696] ina2xx 4-004b: error configuring the device: -121
[   11.012545] remoteproc remoteproc1: 4d81800000.dsp is available
[   11.022725] ina2xx 4-004c: error configuring the device: -121
[   11.035373] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.043010] remoteproc remoteproc1: powering up 4d81800000.dsp
[   11.048888] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 187480
[   11.056090] ina2xx 4-004d: error configuring the device: -121
[   11.060836] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.070311] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200000
[   11.080869] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.090166] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   11.092879] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.107009]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[   11.121114] virtio_rpmsg_bus virtio1: rpmsg host is online
[   11.127059]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[   11.133330] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.134701] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[   11.140824] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[   11.140871] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.152870] ina2xx 4-004e: error configuring the device: -121
[   11.160825] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.163619] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[   11.169256] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.192942] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.204877] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.213001] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.221115] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.233525] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.244870] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.255871] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[   11.257209] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.276863] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.285717] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.296867] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.297309] ina2xx 4-004f: error configuring the device: -121
[   11.304975] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.304985] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.348152] remoteproc remoteproc2: 64800000.dsp is available
[   11.389657] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.399277] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.412857] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.424228] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.439517] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.452775] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.461371] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.469640] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.485020] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.493004] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.501129] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.516913] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav-dev
        gstreamer1.0-libav
        gzip
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp-dev
        libgmp10
        libgmpxx4
        libidn2-0
        libidn2-dev
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline8
        libunistring-dev
        libunistring2
        m4-dev
        m4
        make
        nettle-dev
        nettle
        parted
        python3-rfc3987
        python3-strict-rfc3339
        tar
        which
        zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[   11.657369] remoteproc remoteproc2: powering up 64800000.dsp
[   11.663043] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10489872
[  OK  ] Started Print notice about GPLv3 pa[   11.676863] remoteproc remoteproc2: unsupported resource 65538
ckages.
[   11.684620] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
[   11.695147]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[   11.709123] virtio_rpmsg_bus virtio2: rpmsg host is online
[   11.714637]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[   11.721211] remoteproc remoteproc2: remote processor 64800000.dsp is now up
[   11.729008] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[   11.738001] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[   11.747910] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.758761] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.766924] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.780848] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.792956] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.800549] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.810755] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.824828] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.833794] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.841423] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.856848] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.865005] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.955032] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[   11.981402] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.992849] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   12.004024] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   12.016905] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.079065] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   12.086593] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   12.100852] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   12.108997] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.125475] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   12.133931] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   12.148867] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   12.157084] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.170155] CAN device driver interface
[   12.174171] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[   12.181337] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   12.189646] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   12.214848] platform 41000000.r5f: configured R5F for IPC-only mode
[   12.348979] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   12.479859] remoteproc remoteproc3: 41000000.r5f is available
[   12.596550] remoteproc remoteproc3: attaching to 41000000.r5f
[   12.730057] platform 41000000.r5f: R5F core initialized in IPC-only mode
[   12.797001]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[   12.872554] am65-cpsw-nuss 46000000.ethernet: phy /bus@100000/bus@28380000/ethernet@46000000/mdio@f00/ethernet-phy@0 not found on slave 1
[   12.935121] virtio_rpmsg_bus virtio3: rpmsg host is online
[   12.944632] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[   13.064944]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[   13.148303] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
[   13.281725] platform 5c00000.r5f: configured R5F for remoteproc mode
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   13.364974] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   13.602540] remoteproc remoteproc4: 5c00000.r5f is available
[   13.686805] remoteproc remoteproc4: powering up 5c00000.r5f
[   13.691045] platform 5d00000.r5f: configured R5F for remoteproc mode
[   13.692387] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 527528
[   13.716031]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[   13.724754] virtio_rpmsg_bus virtio4: rpmsg host is online
[   13.736939]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[   13.743101] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[   13.797930] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[   13.917565] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   13.945770] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   14.047840] remoteproc remoteproc5: 5d00000.r5f is available
[   14.146881] remoteproc remoteproc5: powering up 5d00000.r5f
[   14.152516] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 78708
[   14.175574]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[   14.187410] virtio_rpmsg_bus virtio5: rpmsg host is online
[   14.195016]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[   14.204214] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[   14.212930] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[   14.222978] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
[   14.240181] platform 5e00000.r5f: configured R5F for remoteproc mode
[   14.319103] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   14.435815] remoteproc remoteproc6: 5e00000.r5f is available
[   14.576220] remoteproc remoteproc6: powering up 5e00000.r5f
[   14.579216] platform 5f00000.r5f: configured R5F for remoteproc mode
[   14.581832] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 78708
[   14.606016]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[   14.617263] virtio_rpmsg_bus virtio6: rpmsg host is online
[   14.622805]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[   14.634138] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[   14.636965] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[   14.653167] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
[   14.771504] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[   14.879881] remoteproc remoteproc7: 5f00000.r5f is available
[   14.929685] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   14.946226] remoteproc remoteproc7: powering up 5f00000.r5f
[   14.953313] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 78708
[   14.973703]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[   14.987184] virtio_rpmsg_bus virtio7: rpmsg host is online
[   14.996893]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[   15.007874] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[   15.021850] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[   15.034994] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
[   15.405288] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[   15.427182] usbcore: registered new interface driver usbfs
[   15.468857] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   15.533905] remoteproc remoteproc8: b034000.pru is available
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago[   15.575023] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
-project.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm login: [   15.593943] usbcore: registered new interface driver hub
[   15.639184] remoteproc remoteproc9: b004000.rtu is available
[   15.797152] usbcore: registered new device driver usb
[   15.853105] remoteproc remoteproc10: b00a000.txpru is available
[   15.975236] PVR_K:  1091: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   15.987134] remoteproc remoteproc11: b038000.pru is available
[   16.083181] remoteproc remoteproc12: b006000.rtu is available
[   16.211352] remoteproc remoteproc13: b00c000.txpru is available
[   16.275014] remoteproc remoteproc14: b134000.pru is available
[   16.329762] remoteproc remoteproc15: b104000.rtu is available
[   16.342116] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   16.388864] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   16.405168] remoteproc remoteproc16: b10a000.txpru is available
[   16.433106] remoteproc remoteproc17: b138000.pru is available
[   16.457039] remoteproc remoteproc18: b106000.rtu is available
[   16.473030] remoteproc remoteproc19: b10c000.txpru is available
j7-evm login:
j7-evm login:
j7-evm login: [   18.616841] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   18.623724] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.630943] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   18.636951] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
j7-evm login: [   18.647849] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.656090] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.666830] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.675066] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.685833] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.694066] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.704307] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.712534] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.722782] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.731016] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.741825] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.750052] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.760300] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.768532] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.778769] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
j7-evm login: [   18.786993] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.798830] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.807051] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.817831] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.826067] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.836300] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.844529] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.854771] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.862998] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.873834] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.882069] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.892299] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.900519] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.910826] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.919047] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.929821] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.938041] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.948267] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.956491] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.966727] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.974947] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.985820] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.994041] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.004268] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.012488] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.022721] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.030947] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.041821] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
r[   19.050053] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.060281] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.068500] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.078734] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.086954] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.097821] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.106042] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.116320] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.124556] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.134797] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.143020] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.153835] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.162056] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.172284] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.180504] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
o[   19.190742] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.198963] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   19.205571] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[   19.214555] Console: switching to colour frame buffer device 128x48
[   19.224839] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
[   19.249713] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   19.257235] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   19.272850] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   19.280947] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.293367] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   19.300864] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   19.312819] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   19.320907] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
o[   19.333305] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   19.340799] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   19.352821] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   19.360908] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.378261] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[   19.390255] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[   19.405707] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   19.416964] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   19.424476] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
t[   19.436850] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   19.444953] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.461505] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   19.472865] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   19.480995] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   19.492852] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.504970] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   19.512484] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   19.524843] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   19.536831] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
Last login: Wed Aug  4 22:20:56 UTC 2021
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# ks
-sh: ks: command not found
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# ls
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# cd /
root@j7-evm:/# ls
bin  boot  dev  etc  home  include  init  lib  linuxrc  lost+found  media  mnt  opt  proc  run  sbin  sys  tmp  usr  var
root@j7-evm:/# [   25.661958] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   25.668827] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   26.420846] xhci-hcd xhci-hcd.2.auto: can't setup: -110
[   26.426069] xhci-hcd xhci-hcd.2.auto: USB bus 1 deregistered
[   26.431777] xhci-hcd: probe of xhci-hcd.2.auto failed with error -110
root@j7-evm:/# [   26.438359] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.445120] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[   26.453129] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[   26.462541] xhci-hcd xhci-hcd.3.auto: irq 613, io mem 0x06410000
[   26.468745] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   26.477008] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   26.484221] usb usb1: Product: xHCI Host Controller
[   26.489090] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   26.495604] usb usb1: SerialNumber: xhci-hcd.3.auto
[   26.500720] hub 1-0:1.0: USB hub found
[   26.504502] hub 1-0:1.0: 1 port detected
[   26.508955] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   26.510211] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.516423] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   26.521307] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[   26.528824] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   26.536734] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   26.544528] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   26.551544] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   26.559133] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.567587] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   26.576049] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   26.583736] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   26.591592] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   26.598386] usb usb2: Product: xHCI Host Controller
[   26.598388] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   26.598391] usb usb2: SerialNumber: xhci-hcd.3.auto
[   26.606955] hub 2-0:1.0: USB hub found
[   26.612695] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   26.634602] hub 2-0:1.0: 1 port detected
[   26.635143] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.648089] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   26.656069] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
root@j7-evm:/# [   26.664743] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   26.674016] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.685295] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   26.694119] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   26.701708] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   26.710500] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   26.718643] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.727518] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   26.735069] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   26.743219] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   26.751351] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
root@j7-evm:/#
root@j7-evm:/# \
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/#
root@j7-evm:/# cd opt/
root@j7-evm:/opt# ls
containerd  img-powervr-sdk  ltp  vision_apps_init.sh  vx_app_arm_remote_log.out
root@j7-evm:/opt# [   32.089597] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   32.096493] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   32.220714] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.228860] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.244846] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.252824] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.264010] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.272278] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.287848] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.301830] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.312850] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.320991] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.331903] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.340205] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.350763] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.365317] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.375611] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.383903] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.394835] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.403517] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.413847] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.434589] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.445379] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.453658] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.464361] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.472677] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.483920] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.492282] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.503838] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.512079] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.522829] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.531051] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.541822] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.550049] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.559700] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.567927] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.578830] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.587081] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.597822] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.606054] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.616300] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.624521] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.634757] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.642981] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.653821] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.662048] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.672299] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.680521] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.690763] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.698986] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.709821] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.718046] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.728292] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.736513] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.746747] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.754971] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.765822] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.774050] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.784297] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.792529] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.802762] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.810989] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.821822] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.830048] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.840292] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.848513] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.855122] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# chmod vision_apps_init.sh
chmod: missing operand after 'vision_apps_init.sh'
Try 'chmod --help' for more information.
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# [   35.912827] tlv71033: disabling
root@j7-evm:/opt#
root@j7-evm:/opt# chmod [   39.281840] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   39.288710] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
777
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# chmod 777 vision_apps_init.sh
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# ./vision_apps_init.sh
root@j7-evm:/opt# ./vision_apps_init.sh: line 14: /opt/vision_apps/vx_app_arm_remote_log.out: No such file or directory
[   45.708225] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   45.715095] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# mkdir vision_apps
containerd  img-powervr-sdk  ltp  vision_apps  vision_apps_init.sh  vx_app_arm_remote_log.out
root@j7-evm:/opt# mv vx_app_arm_remote_log.out vision_apps
root@j7-evm:/opt# APP_LOG: ERROR: Unable to map memory @ 0xb2000000 of size 262144 bytes !!!
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# [  129.864439] Initializing XFRM netlink socket
[  132.700545] process 'docker/tmp/qemu-check778966446/check' started with executable stack
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt#
root@j7-evm:/opt# cd /lib/
root@j7-evm:/lib# cd firmware/
root@j7-evm:/lib/firmware# ls
LICENCE.iwlwifi_firmware  iwlwifi-8000C-31.ucode  j7-c66_0-fw        j7-pru0_0-fw    j7-txpru0_1-fw         rgx.sh.22.104.208.318
cadence                   iwlwifi-8000C-34.ucode  j7-c66_1-fw        j7-pru0_1-fw    j7-txpru1_0-fw         ti-connectivity
ethfw                     iwlwifi-8000C-36.ucode  j7-c71_0-fw        j7-pru1_0-fw    j7-txpru1_1-fw         vx_app_rtos_linux_mcu2_0.out
iwlwifi-3160-17.ucode     iwlwifi-8265-21.ucode   j7-main-r5f0_0-fw  j7-pru1_1-fw    pdk-ipc                vx_app_rtos_linux_mcu2_1.out
iwlwifi-8000C-13.ucode    iwlwifi-8265-22.ucode   j7-main-r5f0_1-fw  j7-rtu0_0-fw    pru
iwlwifi-8000C-16.ucode    iwlwifi-8265-27.ucode   j7-main-r5f1_0-fw  j7-rtu0_1-fw    pvdec_full_bin.fw
iwlwifi-8000C-21.ucode    iwlwifi-8265-31.ucode   j7-main-r5f1_1-fw  j7-rtu1_0-fw    regulatory.db
iwlwifi-8000C-22.ucode    iwlwifi-8265-34.ucode   j7-mcu-r5f0_0-fw   j7-rtu1_1-fw    regulatory.db.p7s
iwlwifi-8000C-27.ucode    iwlwifi-8265-36.ucode   j7-mcu-r5f0_1-fw   j7-txpru0_0-fw  rgx.fw.22.104.208.318
root@j7-evm:/lib/firmware# clear
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:47 +0800)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -19
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
U-Boot SPL 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
U-Boot 2021.01-dirty (Oct 30 2021 - 16:02:44 +0800)
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   Could not get PHY for ethernet@46000000: addr 0
am65_cpsw_nuss_slave ethernet@46000000: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 0 ms
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19137024 bytes read in 798 ms (22.9 MiB/s)
97623 bytes read in 13 ms (7.2 MiB/s)
   Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.41-g4c2eade9f7 (qywu@op01) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT Tue Oct 26 17:24:36 CST 2021
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=0b959c33-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3372032K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 297984K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008800b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008358] Console: colour dummy device 80x25
[    0.012919] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023589] pid_max: default: 32768 minimum: 301
[    0.028335] LSM: Security Framework initializing
[    0.033078] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040645] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049590] rcu: Hierarchical SRCU implementation.
[    0.054642] Platform MSI: msi-controller@1820000 domain created
[    0.060873] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070168] EFI services will not be available.
[    0.074914] smp: Bringing up secondary CPUs ...
[    0.080093] Detected PIPT I-cache on CPU1
[    0.080117] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.080127] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[    0.080160] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.080212] smp: Brought up 1 node, 2 CPUs
[    0.109557] SMP: Total of 2 processors activated.
[    0.114362] CPU features: detected: 32-bit EL0 Support
[    0.119616] CPU features: detected: CRC32 instructions
[    0.133256] CPU: All CPU(s) started at EL2
[    0.137451] alternatives: patching kernel code
[    0.142436] devtmpfs: initialized
[    0.150636] KASLR disabled due to lack of seed
[    0.155286] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.165248] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.172960] pinctrl core: initialized pinctrl subsystem
[    0.178526] DMI not present or invalid.
[    0.182748] NET: Registered protocol family 16
[    0.190231] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.197531] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.205535] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.213840] thermal_sys: Registered thermal governor 'step_wise'
[    0.213842] thermal_sys: Registered thermal governor 'power_allocator'
[    0.220250] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.233890] ASID allocator initialised with 65536 entries
[    0.255921] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.262776] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.269538] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.277437] cryptd: max_cpu_qlen set to 1000
[    0.283388] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.292234] vsys_3v3: supplied by evm_12v0
[    0.296544] vsys_5v0: supplied by evm_12v0
[    0.301171] iommu: Default domain type: Translated
[    0.306294] SCSI subsystem initialized
[    0.310405] mc: Linux media interface: v0.10
[    0.314819] videodev: Linux video capture interface: v2.00
[    0.320447] pps_core: LinuxPPS API ver. 1 registered
[    0.325517] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.334853] PTP clock support registered
[    0.338871] EDAC MC: Ver: 3.0.0
[    0.342602] FPGA manager framework
[    0.346110] Advanced Linux Sound Architecture Driver Initialized.
[    0.352710] clocksource: Switched to clocksource arch_sys_counter
[    0.359119] VFS: Disk quotas dquot_6.6.0
[    0.363161] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.372888] NET: Registered protocol family 2
[    0.377478] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.386066] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.394845] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.403040] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.410839] TCP: Hash tables configured (established 32768 bind 32768)
[    0.417589] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.424481] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.431871] NET: Registered protocol family 1
[    0.436554] RPC: Registered named UNIX socket transport module.
[    0.442615] RPC: Registered udp transport module.
[    0.447419] RPC: Registered tcp transport module.
[    0.452222] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.458805] PCI: CLS 0 bytes, default 64
[    0.463153] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.473396] Initialise system trusted keyrings
[    0.478003] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.486271] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.492467] NFS: Registering the id_resolver key type
[    0.497645] Key type id_resolver registered
[    0.501916] Key type id_legacy registered
[    0.506033] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.512881] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.520514] 9p: Installing v9fs 9p2000 file system support
[    0.545904] Key type asymmetric registered
[    0.550089] Asymmetric key parser 'x509' registered
[    0.555086] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.562644] io scheduler mq-deadline registered
[    0.567269] io scheduler kyber registered
[    0.572495] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.578663] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.587070] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.593339] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.601099] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.609214] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.618189] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.627012] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.634725] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.647459] brd: module loaded
[    0.653385] loop: module loaded
[    0.657218] megasas: 07.714.04.00-rc1
[    0.662117] libphy: Fixed MDIO Bus: probed
[    0.666764] tun: Universal TUN/TAP device driver, 1.6
[    0.672170] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.678575] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.684645] sky2: driver version 1.30
[    0.688893] VFIO - User Level meta-driver version: 0.3
[    0.694550] i2c /dev entries driver
[    0.698707] sdhci: Secure Digital Host Controller Interface driver
[    0.705027] sdhci: Copyright(c) Pierre Ossman
[    0.709644] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.715962] ledtrig-cpu: registered to indicate activity on CPUs
[    0.722263] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.729363] optee: probing for conduit method.
[    0.733920] optee: revision 3.12 (3d47a131)
[    0.734158] optee: initialized driver
[    0.743416] NET: Registered protocol family 17
[    0.748026] 9pnet: Installing 9P2000 support
[    0.752411] Key type dns_resolver registered
[    0.756891] Loading compiled-in X.509 certificates
[    0.766032] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.772364] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.780461] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[    0.807002] random: fast init done
[    0.832843] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.840383] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.846446] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.852470] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.858890] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[    0.868514] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[    0.874765] pca953x 5-0020: supply vcc not found, using dummy regulator
[    0.881579] pca953x 5-0020: using no AI
[    0.908756] pca953x 5-0020: failed writing register
[    0.913792] pca953x: probe of 5-0020 failed with error -121
[    0.919872] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    0.925904] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[    0.931841] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[    0.938040] pca953x 8-0020: supply vcc not found, using dummy regulator
[    0.944852] pca953x 8-0020: using no AI
[    1.956713] omap_i2c 2060000.i2c: timeout waiting for bus ready
[    1.962765] pca953x 8-0020: failed writing register
[    1.967797] pca953x: probe of 8-0020 failed with error -16
[    1.973730] omap_i2c 2060000.i2c: bus 8 rev0.12 at 400 kHz
[    1.980123] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.990082] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.998883] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    2.008710] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    2.028520] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    2.036195] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.043864] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.052140] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.060417] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.069248] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.076921] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.085197] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.093475] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.102239] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.109903] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.118178] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.126454] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.135573] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    2.145450] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    2.152209] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.161165] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    2.171308] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    2.178067] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.186002] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    2.195361] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    2.204105] printk: console [ttyS2] enabled
[    2.212544] printk: bootconsole [ns16550a0] disabled
[    2.223004] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    2.231935] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    2.242365] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    2.252880] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    2.263035] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    2.273277] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    2.284051] scsi host0: ufshcd
[    2.328717] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.336376] libphy: 46000f00.mdio: probed
[    2.340797] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    2.347525] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    2.361217] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    2.369938] mmc0: CQHCI version 5.10
[    2.373957] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    2.379877] mmc1: CQHCI version 5.10
[    2.389443] pca953x 3-0020: supply vcc not found, using dummy regulator
[    2.396123] pca953x 3-0020: using no AI
[    2.418650] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    2.561001] mmc0: Command Queue Engine enabled
[    2.565441] mmc0: new DDR MMC card at address 0001
[    2.570431] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    2.575023] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
[    2.581001] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
[    2.586971] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0)
[    2.595513]  mmcblk0: p1 p2
[    2.701121] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    2.706602] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    2.711646] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    2.717898] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    2.724327] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    2.731185] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    2.737787] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    2.744124] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    2.748641] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    2.756807] cdns-ufshcd 4e84000.ufs: last intr at 2603298 us, last intr status=0x404
[    2.764531] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    2.772002] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    2.781032] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    2.787022] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    2.793277] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    2.799356] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    2.805438] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    2.817605] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    2.823945] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    2.830288] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    2.836627] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    2.842968] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    2.849310] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    2.855653] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    2.861992] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    2.868334] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    2.874672] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    2.881017] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    2.886315] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    2.891613] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    2.896915] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    2.902213] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    2.907596] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    2.913765] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.919324] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 2604412 us
[    2.926446] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.932176] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.937998] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.943577] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.949227] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    3.404713] omap_i2c 2010000.i2c: timeout waiting for bus ready
[    3.410627] pca953x 3-0020: failed writing register
[    3.415580] pca953x: probe of 3-0020 failed with error -16
[    3.421459] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    3.428286] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    3.435098] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    3.441208] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.441915] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    3.455933] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    3.465467] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.472967] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.481111] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.489244] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.497964] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.505464] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.513552] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.521635] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.530181] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.537676] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.545755] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.553839] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.562828] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    3.572888] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    3.586074] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    3.591321] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[    3.598362] mtd: 47040000.spi.0: skipping zero sized partition
[    3.604195] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    3.610803] Creating 7 MTD partitions on "47040000.spi.0":
[    3.616287] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    3.622428] 0x000000080000-0x000000280000 : "ospi.tispl"
[    3.628206] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    3.634344] mmc1: new ultra high speed DDR50 SDHC card at address 5048
[    3.634521] 0x000000680000-0x0000006c0000 : "ospi.env"
[    3.641203] mmcblk1: mmc1:5048 SD16G 14.4 GiB
[    3.646385] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    3.656197] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[    3.661989]  mmcblk1: p1 p2
[    3.662380] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    3.672612] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.679486] spi-nor: probe of spi1.0 failed with error -2
[    3.724716] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.732360] libphy: 46000f00.mdio: probed
[    3.736779] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    3.743504] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    3.757066] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.764044] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    3.771252] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.777515] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    3.787517] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    3.799104] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.806597] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.814678] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.822757] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.831315] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.838810] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.846892] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.854971] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.863501] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.870993] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.879072] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.887150] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.896533] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.904021] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.912101] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.920179] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.928725] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.936212] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.944294] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.952376] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.960918] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.968407] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.976491] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.984571] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.994489] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    4.001901] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    4.009213] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    4.016520] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    4.024643] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.032038] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    4.039529] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    4.041513] ALSA device list:
[    4.047608] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    4.050565]   No soundcards found.
[    4.058632] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.070694] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    4.078193] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    4.086273] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    4.094351] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.102923] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    4.110409] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    4.118488] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    4.126567] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.530338] EXT4-fs (mmcblk1p2): recovery complete
[    4.535974] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.544079] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    4.550926] devtmpfs: mounted
[    4.554180] Freeing unused kernel memory: 1856K
[    4.558729] Run /sbin/init as init process
[    4.725036] systemd[1]: System time before build time, advancing clock.
[    4.776641] NET: Registered protocol family 10
[    4.781571] Segment Routing with IPv6
[    4.794654] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.810119] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    4.829795] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    4.851515] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[    4.889542] systemd[1]: Set hostname to <j7-evm>.
[    4.996178] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.014536] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.030511] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.046616] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.066035] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.083469] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.101654] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.119503] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.137173] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.154260] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.171883] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.189694] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.207412] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.225332] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.243848] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.261776] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.278280] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.294634] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.311953] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.329027] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.347293] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.365060] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.383485] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.401496] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.420260] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.437916] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.456344] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.474891] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.492781] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.510325] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.527372] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.543639] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.561677] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.578187] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.595573] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.612144] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.629635] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.648217] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.665962] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.682618] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.699238] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.717189] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.738994] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.756959] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.774096] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.791829] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.809656] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.825813] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.841700] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.857819] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.876012] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.894295] systemd[1]: Configuration file /lib/systemd/system/strongswan-starter.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.911819] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.928007] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.944403] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.960610] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.977023] systemd[1]: Configuration file /lib/systemd/system/rngd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    5.993100] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.010783] systemd[1]: Configuration file /lib/systemd/system/ofono.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.027120] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.043711] systemd[1]: Configuration file /lib/systemd/system/kdump.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.059830] systemd[1]: Configuration file /lib/systemd/system/irqbalanced.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.076486] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.092949] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.109535] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.126416] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.143047] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.160768] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.177458] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.194329] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.211173] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.228071] systemd[1]: Configuration file /lib/systemd/system/docker.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.244444] systemd[1]: Configuration file /lib/systemd/system/docker.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.260491] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[    6.280199] systemd[1]: Configuration file /lib/systemd/system/demo.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.296350] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.312511] systemd[1]: Configuration file /lib/systemd/system/crond.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.328757] systemd[1]: Configuration file /lib/systemd/system/bt-enable.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.345474] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.362726] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.379638] systemd[1]: Configuration file /lib/systemd/system/atd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.396430] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.415169] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.431500] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.448865] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.466252] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.482419] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.499365] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.517099] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.535353] systemd[1]: Configuration file /lib/systemd/system/logrotate.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.551907] systemd[1]: Configuration file /lib/systemd/system/logrotate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.568503] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.585063] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.602108] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.620556] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.638237] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.654275] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.671693] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.689016] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.706978] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.723785] systemd[1]: Configuration file /lib/systemd/system/psplash-systemd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.740930] systemd[1]: Configuration file /lib/systemd/system/psplash-start.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.757930] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.774427] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.791836] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.808528] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.825428] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.842083] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.858562] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.876364] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.894679] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.912176] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.929360] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.946497] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.963635] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.980875] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.997762] systemd[1]: Configuration file /lib/systemd/system/var-volatile-srv.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.015166] systemd[1]: Configuration file /lib/systemd/system/var-volatile-spool.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.032702] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.050130] systemd[1]: Configuration file /lib/systemd/system/var-volatile-cache.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.067639] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.083616] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.101323] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.118772] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.135285] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.152132] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.170423] random: systemd: uninitialized urandom read (16 bytes read)
[    7.177134] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    7.189459] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.199292] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    7.220783] random: systemd: uninitialized urandom read (16 bytes read)
[    7.227998] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    7.248773] random: systemd: uninitialized urandom read (16 bytes read)
[    7.255907] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    7.276881] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    7.300815] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    7.324814] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    7.340766] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    7.360756] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    7.376760] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    7.394193] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.416784] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.436880] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.455321] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    7.476887] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    7.509596] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.517904] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.540970] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.557022] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.580932] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.600869] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.623355] systemd[1]: Mounting Huge Pages File System...
[    7.642860] systemd[1]: Mounting POSIX Message Queue File System...
[    7.667473] systemd[1]: Mounting Kernel Debug File System...
[    7.687419] systemd[1]: Mounting Temporary Directory (/tmp)...
[    7.707764] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    7.735458] systemd[1]: Starting Start psplash boot splash screen...
[    7.761041] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    7.786904] systemd[1]: Starting RPC Bind...
[    7.808884] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.827694] systemd[1]: Starting Journal Service...
         Starting Journal Service...[    7.836965] systemd-journald[165]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.869634] systemd-journald[165]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.872582] systemd[1]: Starting Load Kernel Modules...
[    7.907307] cryptodev: loading out-of-tree module taints kernel.
[    7.916234] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
[0m...
[    7.946919] systemd[1]: Starting udev Coldplug all Devices...
[    7.961900] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    7.971333] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    7.993931] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    8.203998] systemd-journald[165]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[    8.899632] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.907141] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[  OK  ] Started D-Bus System Message Bus    8.920776] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
m.
[    8.936589] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.949474] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.957088] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
         Starting Print notice about GPLv3 packages[    8.970106] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.984480] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
         Starting IPv6 Packet Filtering Framework..[    8.997114] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.011805] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
         Starting IPv4 Packet Filtering Framework..[    9.023337] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.040674] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started irqbalance daemon.
[    9.055751] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
         Starting Telephony service...
[    9.067216] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
         Starting rc.pvr.service...
[    9.084357] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
         Starting Login Service...
[    9.099207] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Reboot and dump vmcore via [    9.117359] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
kexec.
[    9.130937] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.143507] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.156772] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Reached target Network (Pre).
         Starting Network Service...
[  OK  ] Started Telephony service.
[  OK  ] Started Login Service.
[    9.325219] PVR_K:  253: Read BVNC 22.104.208.318 from HW device registers
[    9.337834] PVR_K:  253: RGX Device registered with BVNC 22.104.208.318
[    9.349145] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[    9.357461] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.365041] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.376751] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.377510] Bluetooth: Core ver 2.22
[    9.384846] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.396794] NET: Registered protocol family 31
[    9.402207] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.404197] Bluetooth: HCI device and connection manager initialized
[    9.412739] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[  OK  ] Started Network Service.[    9.427562] Bluetooth: HCI socket layer initialized
         Starting Wait for Network to be Configured    9.429481] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
0m...
[    9.438629] Bluetooth: L2CAP socket layer initialized
[    9.456447] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.460746] Bluetooth: SCO socket layer initialized
[    9.469718] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.479851] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.492764] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.504745] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
         Starting Network Name Resolution...
[    9.673955] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.683106] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.696827] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.710435] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.726804] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.739243] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.752903] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.761469] ina2xx 4-0040: error configuring the device: -121
[    9.767272] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.781041] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.793433] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.806931] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.820090] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.835965] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.847538] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.860674] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.874131] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[   10.022187] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.032742] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.045577] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.059786] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.077296] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.089881] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.103428] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.116776] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.133139] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.144807] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.156750] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.164867] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.198823] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.208757] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.216867] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.228742] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.274742] ina2xx 4-0041: error configuring the device: -121
[   10.284923] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[   10.321281] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[   10.345674] ina2xx 4-0042: error configuring the device: -121
[   10.353264] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.364491] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.376758] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.388763] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.399696] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.416756] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.427713] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.440749] random: crng init done
[   10.444144] random: 7 urandom warning(s) missed due to ratelimiting
[   10.450483] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.464500] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.472546] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[   10.479624] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.492736] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.501130] ina2xx 4-0043: error configuring the device: -121
[   10.506908] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.538665] ina2xx 4-0044: error configuring the device: -121
[   10.548809] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[  OK  ] Started Load/Save Random Seed.
[   10.580937] ina2xx 4-0045: error configuring the device: -121
[   10.592649] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.602108] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.616755] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.631180] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.647783] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.656799] remoteproc remoteproc0: 4d80800000.dsp is available
[   10.662861] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.674842] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.683032] ina2xx 4-0046: error configuring the device: -121
[   10.685906] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[   10.697450] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.707442] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.715704] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.724269] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[   10.728729] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.739473] remoteproc remoteproc0: powering up 4d80800000.dsp
[   10.745387] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 187480
[   10.748758] ina2xx 4-0047: error configuring the device: -121
[   10.752554] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.764862] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[   10.766775] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200000
[   10.785386] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.793100]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[   10.804765] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.813227] virtio_rpmsg_bus virtio0: rpmsg host is online
[   10.818819]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[   10.824957] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.835534] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[   10.843330] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.857014] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[   10.864754] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[   10.887174] remoteproc remoteproc1: 4d81800000.dsp is available
[   10.893294] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.902912] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.916762] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.924893] ina2xx 4-0048: error configuring the device: -121
[   10.930697] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.940445] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.952760] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.961340] ina2xx 4-0049: error configuring the device: -121
[   10.967201] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.975314] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.989423] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.998248] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   11.006770] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.014929] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.027916] remoteproc remoteproc1: powering up 4d81800000.dsp
[   11.033823] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 187480
[   11.034043] ina2xx 4-004a: error configuring the device: -121
[   11.040990] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.055296] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200000
[   11.067843] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.076510]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[   11.085183] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[   11.092061] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.100540] virtio_rpmsg_bus virtio1: rpmsg host is online
[   11.106085]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[   11.112789] ina2xx 4-004b: error configuring the device: -121
[   11.116738] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.126678] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[   11.133897] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.134009] remoteproc remoteproc2: 64800000.dsp is available
[   11.142752] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[   11.158300] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.168968] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[   11.176906] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.190863] ina2xx 4-004c: error configuring the device: -121
[   11.196748] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.204858] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.219204] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.223801] ina2xx 4-004d: error configuring the device: -121
[   11.230483] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[  OK  ] Started Simple Network Man…ement [   11.242550] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.256746] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.268907] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.276433] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.288768] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.296917] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.310098] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.312845] ina2xx 4-004e: error configuring the device: -121
[   11.320727] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.331780] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.344065] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.365020] ina2xx 4-004f: error configuring the device: -121
[   11.523145] remoteproc remoteproc2: powering up 64800000.dsp
[   11.528862] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10489872
[   11.539153] remoteproc remoteproc2: unsupported resource 65538
[   11.547485] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
[   11.558733]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[   11.569072] virtio_rpmsg_bus virtio2: rpmsg host is online
[   11.574637]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[   11.584725] remoteproc remoteproc2: remote processor 64800000.dsp is now up
[   11.592035] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[   11.599699] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.608813] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[   11.620760] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.628983] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.637112] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.649597] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.657873] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.666022] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.680784] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.691065] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.698587] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.712766] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.722371] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.774777] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[   11.838629] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.847750] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.861416] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.875189] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.891000] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.903947] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.917899] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.931284] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.963605] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   11.971978] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   11.978929] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[   11.989768] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   12.162517] CAN device driver interface
[   12.224529] platform 41000000.r5f: configured R5F for IPC-only mode
[   12.388397] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[   12.484096] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   12.540844] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[   12.704028] remoteproc remoteproc3: 41000000.r5f is available
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav-dev
[   12.849785] remoteproc remoteproc3: attaching to 41000000.r5f
        gstreamer1.0-libav
        gzip
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp-dev
        libgmp10
        libgmpxx4
        libidn2-0
        libidn2-dev
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline8
        libunistring-dev
        libunistring2
        m4-dev
        m4
        make
        nettle-dev
        nettle
        parted
        python3-rfc3987
        python3-strict-rfc3339
        tar
        which
        zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[   13.023965] platform 41000000.r5f: R5F core initialized in IPC-only mode
[   13.092635]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[   13.123989] am65-cpsw-nuss 46000000.ethernet: phy /bus@100000/bus@28380000/ethernet@46000000/mdio@f00/ethernet-phy@0 not found on slave 1
[   13.231101] virtio_rpmsg_bus virtio3: rpmsg host is online
[   13.245313] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[   13.288526]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[   13.321568] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
[   13.398811] platform 5c00000.r5f: configured R5F for remoteproc mode
[   13.468930] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   13.588034] remoteproc remoteproc4: 5c00000.r5f is available
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   13.664966] platform 5d00000.r5f: configured R5F for remoteproc mode
[   13.676132] remoteproc remoteproc4: powering up 5c00000.r5f
[   13.681781] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 527528
[   13.697124]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[   13.709886] virtio_rpmsg_bus virtio4: rpmsg host is online
[   13.718865]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[   13.728013] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[   13.802264] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   13.826420] remoteproc remoteproc5: 5d00000.r5f is available
[   13.850871] remoteproc remoteproc5: powering up 5d00000.r5f
[   13.856495] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 78708
[   13.871799] platform 5e00000.r5f: configured R5F for remoteproc mode
[   13.878207]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[   13.878560] virtio_rpmsg_bus virtio5: rpmsg host is online
[   13.889789] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[   13.896792]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[   13.905585] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[   13.956143] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
[   14.006873] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   14.028242] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[   14.112084] remoteproc remoteproc6: 5e00000.r5f is available
[  OK  ] Found device /dev/mmcblk0p2.
         Starting File System Check on /dev/mmcblk0p2...
[   14.198512] platform 5f00000.r5f: configured R5F for remoteproc mode
[   14.204999] remoteproc remoteproc6: powering up 5e00000.r5f
[   14.210711] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 78708
[   14.224752]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[   14.237040] virtio_rpmsg_bus virtio6: rpmsg host is online
[   14.242708]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[   14.252741] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[   14.253020] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[   14.272859] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
[  OK  ] Started File System Check on /dev/mmcblk0p2.
         Mounting /run/media/mmcblk0p2...
[   14.388454] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Mounted /run/media/mmcblk0p2.
[  OK  ] Found device /dev/mmcblk1p1.
[   14.492871] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Started File System Check on /dev/m[   14.651556] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
mcblk1p1.
         Mounting /run/media/mmcblk1p1...
[   14.684234] remoteproc remoteproc7: 5f00000.r5f is available
[  OK  ] Mounted /run/media/mmcblk1p1.
[   14.820878] remoteproc remoteproc7: powering up 5f00000.r5f
[   14.826487] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 78708
[  OK  ] Found device /dev/mmcblk0p1.
[   14.842346]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[   14.857087] virtio_rpmsg_bus virtio7: rpmsg host is online
         Starting File System Check on /dev/mmcblk0p1   14.864885]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
0m...
[   14.870343] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[   14.880493] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[   14.893878] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
[   15.714081] usbcore: registered new interface driver usbfs
[   15.776849] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[   15.796117] usbcore: registered new interface driver hub
[   15.880846] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     [   15.949784] usbcore: registered new device driver usb
|  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm login: [   16.028883] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
[   16.059735] remoteproc remoteproc8: b034000.pru is available
[   16.217117] remoteproc remoteproc9: b004000.rtu is available
[   16.300479] remoteproc remoteproc10: b00a000.txpru is available
[   16.404129] PVR_K:  1091: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   16.469988] remoteproc remoteproc11: b038000.pru is available
[   16.574426] remoteproc remoteproc12: b006000.rtu is available
[   16.671830] remoteproc remoteproc13: b00c000.txpru is available
[   16.775511] remoteproc remoteproc14: b134000.pru is available
[   16.809052] remoteproc remoteproc15: b104000.rtu is available
[   16.824452] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   16.842813] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   16.855768] remoteproc remoteproc16: b10a000.txpru is available
[   16.872968] remoteproc remoteproc17: b138000.pru is available
[   16.893965] remoteproc remoteproc18: b106000.rtu is available
[   16.926632] remoteproc remoteproc19: b10c000.txpru is available
j7-evm login:
j7-evm login: [   18.411762] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   18.418637] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.426861] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.433473] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   18.442509] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.450747] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.461728] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.469965] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.480210] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.488433] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.498680] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
j7-evm login: [   18.506915] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.517730] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.525958] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.536209] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.544444] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.554685] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.562910] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.573735] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.581963] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.592215] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.600448] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.610690] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.618915] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.629730] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.637961] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.648214] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.656447] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.666685] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.674907] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
j7-evm login: [   18.685729] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.692725] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.703742] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.711961] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.722726] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.730944] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.741723] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.749942] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.760172] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.768392] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.778625] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.786843] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.797723] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.805942] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.816168] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.824387] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.834620] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.842837] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.853723] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.861942] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.872169] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.880392] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.890625] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.898842] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.909722] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.917941] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.928169] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.936389] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.946629] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.954847] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.965723] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.973942] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.984169] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   18.990768] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[   18.999905] Console: switching to colour frame buffer device 128x48
[   19.010242] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
[   19.037719] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   19.046246] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   19.057735] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   19.069736] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.082282] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   19.091804] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   19.102736] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   19.114797] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.127367] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   19.136733] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   19.146843] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   19.157729] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.168661] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
j7-evm login:
j7-evm login:
j7-evm login: root
Last login: Wed Aug  4 22:20:57 UTC 2021
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# reboot
root@j7-evm:~#              Stopping Session c2 of user root.
[  OK  ] Stopped target RPC Port Mapper.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped Daily rotation of log files.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
[  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Stopping Reboot and dump vmcore via kexec...
         Stopping NFS status monitor for NFSv2/3 lockin[   25.445812] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
g....
[   25.458781] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
         Stopping Load/Save Random Seed...
[  OK  ] Stopped target Login Prompts.
         Stopping Job spooling tools...
         Stopping Avahi mDNS/DNS-SD Stack...
         Stopping Periodic Command Scheduler...
[  OK  ] Stopped DEMO.
         Stopping Getty on tty1...
         Stopping irqbalance daemon...
         Stopping Telephony service...
         Stopping Serial Getty on ttyS2...
         Stopping Serial Getty on ttyS3...
         Stopping Simple Network Ma…ent Protocol (SNMP) Daemon....
[  OK  ] Stopped target System Time Synchronized.
[  OK  ] Stopped target System Time Set.
         Stopping telnetd.service...
         Stopping Weston Wayland Compositor...
[  OK  ] Stopped Job spooling tools.
[  OK  ] Stopped Periodic Command Scheduler.
[  OK  ] Stopped irqbalance daemon.
[  OK  ] Stopped Telephony service.
[  OK  ] Stopped Wait for Network to be Configured.
[  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
[  OK  ] Stopped NFS status monitor for NFSv2/3 locking..
[  OK  ] Stopped Simple Network Man…ement Protocol (SNMP) Daemon..
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped Serial Getty on ttyS2.
[  OK  ] Stopped Serial Getty on ttyS3.
[  OK  ] Stopped Reboot and dump vmcore via kexec.
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped telnetd.service.
[  OK  ] Stopped Session c2 of user root.
[  OK  ] Removed slice system-getty.slice.
[  OK  ] Removed slice system-serial\x2dgetty.slice.
[  OK  ] Stopped target Host and Network Name Lookups.
         Stopping weston.service...
[  OK  ] Stopped weston.service.
         Stopping rc.pvr.service...
[  OK  ] Stopped rc.pvr.service.
[   26.865781] xhci-hcd xhci-hcd.2.auto: can't setup: -110
[   26.871007] xhci-hcd xhci-hcd.2.auto: USB bus 1 deregistered
[   26.876719] xhci-hcd: probe of xhci-hcd.2.auto failed with error -110
[   26.883276] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.888770] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[   26.896809] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[   26.906221] xhci-hcd xhci-hcd.3.auto: irq 613, io mem 0x06410000
[   26.912447] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   26.920713] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   26.927923] usb usb1: Product: xHCI Host Controller
[   26.932795] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   26.939310] usb usb1: SerialNumber: xhci-hcd.3.auto
[   26.944433] hub 1-0:1.0: USB hub found
[   26.948213] hub 1-0:1.0: 1 port detected
[   26.952943] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   26.953915] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.960439] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   26.965907] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[   26.975087] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   26.981666] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   26.990208] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   26.996257] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   27.012613] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   27.012649] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   27.020872] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   27.028890] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   27.035537] usb usb2: Product: xHCI Host Controller
[   27.035539] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   27.035541] usb usb2: SerialNumber: xhci-hcd.3.auto
[   27.036006] hub 2-0:1.0: USB hub found
[   27.044989] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   27.048534] hub 2-0:1.0: 1 port detected
[   27.055069] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   27.086442] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   27.094024] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   27.102858] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   27.111399] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   27.121550] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   27.136885] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   27.144407] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   27.153269] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   27.161796] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   27.170744] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   27.178245] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   27.186332] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   27.194417] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[***   ] (1 of 2) A stop job is running for …on c1 of user root (6s / 1min 30s)
[   31.882997] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   31.889866] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   32.014134] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.025844] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.036182] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.044513] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.055659] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.064018] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.075966] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.084245] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Session c1 of user ro[   32.102864] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
ot.
[   32.117732] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.126176] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Weston Wayland Compositor   32.136428] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
0m.
[   32.146674] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.157730] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Removed slice system-weston.slice   32.166445] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
0m.
[   32.182737] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.190971] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping Login Service...
[   32.202761] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping User Manager for UID 0...[   32.211411] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.225781] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped User Manager for UID 0.[   32.235047] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.250826] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.259637] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping User Runtime Directory /run/user/0   32.270750] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
m...
[   32.280259] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.290521] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Unmounted /run/user/0.
[   32.298827] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.312437] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.320759] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Login Service.
[   32.331747] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped User Runtime Directory /run[   32.341235] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
/user/0.
[   32.356558] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.364825] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Removed slice User Slice of UID 0   32.375737] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
0m.
[   32.385005] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.395739] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping D-Bus System Message Bus...
[   32.404744] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping Permit User Sessions...[   32.419884] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.431703] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped D-Bus System Message Bus   32.442849] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
m.
[   32.456669] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Permit User Sessions.
[   32.467758] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped target Network.
[   32.480209] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped target Remote File Systems cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[0m.
[   32.504598] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping Network Name Resolution...
[   32.515766] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Network Name Resolution[   32.526616] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.542763] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.551071] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping Network Service...
[   32.562745] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Network Service.[   32.571883] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.587760] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.596025] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped target Network (Pre).[   32.606921] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.616722] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped IPv6 Packet Filtering Frame[   32.627870] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
work.
[   32.638826] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped IPv4 Packet Filtering Frame[   32.649735] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
work.
[   32.662836] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped target Basic System.
[   32.673736] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped target Paths.
[   32.686646] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Dispatch Password …ts to [   32.700199] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.710759] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.718356] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
[  OK  ] Stopped target Slices.
[   32.763695] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.764727] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.768398] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.770034] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.773671] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.775296] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.779786] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.780728] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.784362] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.785987] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.789623] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.791247] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.795737] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.796722] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.800359] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.801991] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.805626] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.807250] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.811758] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.812735] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.816367] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.817992] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.821627] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.823251] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.827740] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.828734] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.832366] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.833993] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.837626] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.839249] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.843735] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.844721] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.847750] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.848721] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.852357] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.853984] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.857618] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.859241] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.863736] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.864757] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.868389] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.870013] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.873647] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.875270] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.879736] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.880720] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.884356] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.885983] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.889618] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.891241] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.895736] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.896761] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.900393] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.902016] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.905650] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.907273] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.911738] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.912720] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.916355] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.917982] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.921616] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.923239] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.927737] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.928767] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   32.928771] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Sockets.
[   33.381734] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.390167] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Closed Avahi mDNS/DNS-SD Stack Acti[   33.400424] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
vation Socket.
[   33.411032] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Closed D-Bus System Message Bus Soc[   33.422039] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
ket.
[   33.434941] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.445746] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Closed Docker Socket for the API   33.453997] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
m.
[   33.468266] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.476664] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Closed dropbear.socket.
[   33.487763] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped target System Initializatio[   33.496959] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
n.
[   33.512725] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.520722] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping Hardware RNG Entropy Gatherer Daemon cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[0m...
[   33.540723] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.544388] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Apply Kernel Variables.[   33.555603] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.570734] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Load Kernel Modules.[   33.578971] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.593730] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping Network Time Synchronization...[   33.602177] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.616688] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.625691] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Stopping Update UTMP about System Boot/Shutdow[   33.636000] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
n...
[   33.646246] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Hardware RNG Entropy Gather[   33.656508] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
er Daemon.
[   33.668552] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Network Time Synchronizatio[   33.678770] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
n.
[   33.691937] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.702765] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Update UTMP about System Bo[   33.711050] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
ot/Shutdown.
[   33.724732] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped Create Volatile Files and D[   33.733263] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
irectories.
[   33.749730] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped target Local File Systems   33.757990] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
0m.
[   33.773732] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.781991] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Unmounting /media/ram...
[   33.794792] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.803082] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Unmounting /run/media/mmcblk0p1...[   33.815889] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.824353] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Unmounting /run/media/mmcblk0p2...
[   33.835309] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Unmounting /run/media/mmcblk1p1...[   33.850835] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.863871] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.872111] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Unmounting Temporary Directory (/tmp)...
[   33.883853] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
         Unmounting /var/volatile...
[   33.894313] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.909145] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Unmounted /media/ram.
[   33.917108] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Unmounted /run/media/mmcblk0p1.[   33.931073] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.944042] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Unmounted /run/media/mmcblk0p2.[   33.954774] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.968249] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Unmounted /run/media/mmcblk1p1.[   33.978519] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   33.992215] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[FAILED] Failed unmounting Temporary Direc[   34.002760] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
tory (/tmp).
[   34.015281] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[FAILED] Failed unmounting /var/volatile   34.025539] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
0m.
[   34.039099] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Stopped target Swap.
[   34.049741] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[  OK  ] Reached target Unmount All Filesyst[   34.062364] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
ems.
[   34.076727] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   34.084736] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   34.091341] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[  OK  ] Stopped File System Check on /dev/mmcblk0p1.
[  OK  ] Stopped File System Check on /dev/mmcblk0p2.
[  OK  ] Stopped File System Check on /dev/mmcblk1p1.
[  OK  ] Removed slice system-systemd\x2dfsck.slice.
[  OK  ] Stopped target Local File Systems (Pre).
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Reached target Shutdown.
[  OK  ] Reached target Final Step.
[  OK  ] Started Reboot.
[  OK  ] Reached target Reboot.
[   34.333155] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[   34.340059] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[   34.346924] watchdog: watchdog0: watchdog did not stop!
[   34.369737] systemd-shutdown[1]: Syncing filesystems and block devices.
[   34.418143] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[   34.429631] systemd-journald[165]: Received SIGTERM from PID 1 (systemd-shutdow).
[   35.900727] tlv71033: disabling
[   40.512732] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   40.519596] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   40.532696] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.540921] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.551156] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.559385] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.569617] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.577843] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.588076] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.596298] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.606530] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.614752] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.624983] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.633206] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.643437] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.651661] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.661892] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.670114] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.680345] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.688567] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.698798] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.707019] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.717252] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.725474] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.735706] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.743927] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.754159] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.762381] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.772611] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.780835] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.791067] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.799288] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.809519] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.817741] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.827369] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.835591] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.845823] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.854046] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.864277] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.872499] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.882729] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.890951] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.901183] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.909406] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.919637] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.927859] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.938089] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.946312] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.956542] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.964764] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.974996] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.983218] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   40.993450] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.001672] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.011903] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.020125] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.030355] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.038578] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.048809] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.057032] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.067263] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.075485] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.085719] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.093941] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.104174] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.112395] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   41.118995] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[   41.127200] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[   41.137312] systemd-shutdown[1]: Hardware watchdog 'K3 RTI Watchdog', version 0
[   41.145822] systemd-shutdown[1]: Unmounting file systems.
[   41.152631] [1234]: Unmounting '/var/volatile'.
[   41.158334] [1235]: Unmounting '/tmp'.
[   41.163011] [1236]: Remounting '/' read-only in with options '(null)'.
[   41.180850] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[   41.190459] systemd-shutdown[1]: All filesystems unmounted.
[   41.196047] systemd-shutdown[1]: Deactivating swaps.
[   41.201051] systemd-shutdown[1]: All swaps deactivated.
[   41.206268] systemd-shutdown[1]: Detaching loop devices.
[   41.213173] systemd-shutdown[1]: All loop devices detached.
[   41.218756] systemd-shutdown[1]: Detaching DM devices.
[   41.223996] systemd-shutdown[1]: All DM devices detached.
[   41.229387] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
[   41.243720] systemd-shutdown[1]: Syncing filesystems and block devices.
[   41.250505] systemd-shutdown[1]: Rebooting.
[   46.310000] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   46.316863] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   46.335135] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   46.343360] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   46.350342] reboot: Restarting system
thanks
  • Hi Veitch,
    I verified that reboot works fine on TI TDA4VM.
    [  OK  ] Removed slice system-weston.slice.
    [  OK  ] Stopped target Sound Card.
             Stopping Save/Restore Sound Card State...
             Stopping NFS status monitor for NFSv2/3 locking....
             Starting Update UTMP about System Runlevel Changes...
    [  OK  ] Stopped Save/Restore Sound Card State.
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [  OK  ] Started Update UTMP about System Runlevel Changes.
    [  OK  ] Removed slice User Slice of UID 0.
    [  OK  ] Stopped D-Bus System Message Bus.
    [  OK  ] Stopped target Remote File Systems.
    [  OK  ] Stopped Network Name Resolution.
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
    [  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed D-Bus System Message Bus Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Stopped target System Initialization.
             Stopping Hardware RNG Entropy Gatherer Daemon...
    [  OK  ] Stopped Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Stopped Network Time Synchronization.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
    [  OK  ] Unmounted Temporary Directory (/tmp).
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Reached target Unmount All Filesystems.
    [   30.941716] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   30.948616] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   30.955569] watchdog: watchdog0: watchdog did not stop!
    [   30.983757] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   31.129759] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   31.141281] systemd-journald[166]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   31.159246] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   31.169030] systemd-shutdown[1]: Hardware watchdog 'K3 RTI Watchdog', version 0
    [   31.177409] systemd-shutdown[1]: Unmounting file systems.
    [   31.184364] [1190]: Remounting '/' read-only in with options '(null)'.
    [   31.232062] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [   31.239558] systemd-shutdown[1]: All filesystems unmounted.
    [   31.245134] systemd-shutdown[1]: Deactivating swaps.
    [   31.250188] systemd-shutdown[1]: All swaps deactivated.
    [   31.255406] systemd-shutdown[1]: Detaching loop devices.
    [   31.262335] systemd-shutdown[1]: All loop devices detached.
    [   31.267916] systemd-shutdown[1]: Detaching DM devices.
    [   31.273156] systemd-shutdown[1]: All DM devices detached.
    [   31.278547] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
    [   31.294058] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   31.300772] systemd-shutdown[1]: Rebooting.
    [   31.324342] pci_generic_config_write32: 71 callbacks suppressed
    [   31.324349] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0xdc may corrupt adjacent RW1C bits
    [   31.339999] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [   31.349715] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x9c may corrupt adjacent RW1C bits
    [   31.359486] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [   31.369210] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [   31.378889] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [   31.388553] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0xdc may corrupt adjacent RW1C bits
    [   31.398284] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [   31.407999] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x9c may corrupt adjacent RW1C bits
    [   31.417748] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [   31.427897] reboot: Restarting system
    U-Boot SPL 2021.01-g53e79d0e89 (Aug 04 2021 - 23:32:00 +0000)
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E6
    SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
    NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
    U-Boot SPL 2021.01-g53e79d0e89 (Aug 04 2021 - 22:33:28 +0000)
    Detected: J7X-BASE-CPB rev E2
    Detected: J7X-INFOTAN-EXP rev E3
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2021.01-g53e79d0e89 (Aug 04 2021 - 22:33:28 +0000)
    SoC:   J721E SR1.0
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    eth0: ethernet@46000000
    Hit any key to stop autoboot:  0
    It seems like there are multiple failure messages on cdns-mhdp side. Also can you make sure that HW design is done right to trigger reboot?
    Also does reset command work from U-Boot?
    - Keerthy
