Other Parts Discussed in Thread: OMAP-L137
Hi E2E,
Our customer needs your expertise with TMS320C6747 DSP. Here are the details of the query.
In TMS3230C6747 boot mode pins are set regarding nor flash parallel interface to EMIFA. Some of the address pins are connected to GPIO's which are pulled high. If we set pin multiplexing for boot mode pins and load the code through emulator then code stores in flash or else there is another procedure for loading the code in flash.
Is the file loaded in flash is in .out format or in another format? Is the flash code is loaded through xds100v2 emulator or another? I want the complete setup detail of flash code load.
Thank you for your guidance.
Carlo
