AM5749/Linux: Unstable work after freq increasing to 1.5GHz
Other Parts Discussed in Thread: AM5749
Hello support!!!
I'm using AM5749 (custom bord) with PROCESSOR-SDK-LINUX-RT-AM57X  05.03.
The problem is: After freq increasing it is work unstable. Problem with loading. From time to time it is working.
I think the problem was  in temperature but I check it (I use good heat sink) everything ok.
Here two logs dmesg:
link up on port 0, speed 1000, full duplex
BOOTP broadcast 1
DHCP client bound to address 10.10.10.235 (12 ms)
Using ethernet@48484000 device
File transfer via NFS from server 10.10.10.2; our IP address is 10.10.10.95
Filename '/nfs/tisdk502/boot/zImage'.
Load address: 0x82000000
Loading: #################################################################
done
Bytes transferred = 3985920 (3cd200 hex)
Filename '/nfs/tisdk502/boot/am574x-idk.dtb'.
Load address: 0x88000000
done
Bytes transferred = 98576 (18110 hex)
   Loading Device Tree to 8ffe4000, end 8ffff10f ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.79-rt47-g28d73230da (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1            SMP PREEMPT RT Sun Dec 16 04:27:40 UTC 2018
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: TI AM5748 IDK
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[    0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000fd800000
[    0.000000] OMAP4: Map 0x000000027fd00000 to fe600000 for dram barrier
[    0.000000] DRA762 ES1.0
[    0.000000] percpu: Embedded 15 pages/cpu @dff35000 s32032 r8192 d21216 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 944256
[    0.000000] Kernel command line: console=ttyS2,115200 root=/dev/nfs nfsroot=10.10.10.2:/nfs/tisdk502/,v3,nolock rw ip=10.10.10           .95:10.10.10.2:10.10.10.1:255.255.255.0::eth0
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 3543384K/3781632K available (8192K kernel code, 358K rwdata, 2596K rodata, 2048K init, 289K bss, 49832K re           served, 188416K cma-reserved, 3232768K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0a00000   (10208 kB)
[    0.000000]       .init : 0xc0e00000 - 0xc1000000   (2048 kB)
[    0.000000]       .data : 0xc1000000 - 0xc1059860   ( 359 kB)
[    0.000000]        .bss : 0xc105b000 - 0xc10a3690   ( 290 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  RCU priority boosting: priority 1 delay 500 ms.
[    0.000000]  No expedited grace period (rcu_normal_after_boot).
[    0.000000]  Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000003] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000007] Switching to timer-based delay loop, resolution 162ns
[    0.000220] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000222] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000527] Console: colour dummy device 80x30
[    0.000613] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000618] pid_max: default: 32768 minimum: 301
[    0.000699] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000703] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001141] CPU: Testing write buffer coherency: ok
[    0.001164] CPU0: Spectre v2: using ICIALLU workaround
[    0.001328] /cpus/cpu@0 missing clock-frequency property
[    0.001350] /cpus/cpu@1 missing clock-frequency property
[    0.001358] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.039955] Setting up static identity map for 0x80200000 - 0x80200060
[    0.079954] Hierarchical SRCU implementation.
[    0.140302] EFI services will not be available.
[    0.160055] smp: Bringing up secondary CPUs ...
[    0.260369] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.260371] CPU1: Spectre v2: using ICIALLU workaround
[    0.260447] smp: Brought up 1 node, 2 CPUs
[    0.260459] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.260464] CPU: All CPU(s) started in HYP mode.
[    0.260469] CPU: Virtualization extensions available.
[    0.260905] devtmpfs: initialized
[    0.281243] random: get_random_u32 called from bucket_table_alloc+0x14c/0x288 with crng_init=0
[    0.281440] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.281618] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.281631] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.284414] pinctrl core: initialized pinctrl subsystem
[    0.284950] DMI not present or invalid.
[    0.285259] NET: Registered protocol family 16
[    0.286954] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.287616] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.454485] OMAP GPIO hardware version 0.1
[    0.478675] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.478683] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.478959] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.478967] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.479889] OMAP DMA hardware revision 0.0
[    0.490919] edma 43300000.edma: memcpy is disabled
[    0.494813] edma 43300000.edma: TI EDMA DMA engine driver
[    0.503113] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.506937] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.507254] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.507634] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.507999] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.508463] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.508780] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.509092] iommu: Adding device 58820000.ipu to group 1
[    0.509221] iommu: Adding device 55020000.ipu to group 2
[    0.509452] iommu: Adding device 40800000.dsp to group 0
[    0.509845] iommu: Adding device 41000000.dsp to group 3
[    0.511830] palmas 0-0058: Irq flag is 0x00000004
[    0.541881] palmas 0-0058: Muxing GPIO 29, PWM 0, LED 0
[    0.543303] SMPS12: supplied by regulator-dummy
[    0.544862] SMPS3: supplied by VMAIN
[    0.546402] SMPS45: supplied by regulator-dummy
[    0.548086] SMPS6: supplied by VMAIN
[    0.549641] SMPS7: supplied by VMAIN
[    0.551358] SMPS8: supplied by VMAIN
[    0.552622] SMPS9: supplied by VMAIN
[    0.553508] LDO1: supplied by VMAIN
[    0.561369] LDO2: supplied by VMAIN
[    0.571218] LDO3: supplied by VMAIN
[    0.581250] LDO4: supplied by VMAIN
[    0.591246] LDO5: supplied by regulator-dummy
[    0.592000] LDO6: supplied by regulator-dummy
[    0.592740] LDO7: supplied by regulator-dummy
[    0.593505] LDO8: supplied by regulator-dummy
[    0.594250] LDO9: supplied by VMAIN
[    0.601566] LDOLN: supplied by VMAIN
[    0.611271] LDOUSB: supplied by VMAIN
[    0.624132] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.624335] media: Linux media interface: v0.10
[    0.624373] Linux video capture interface: v2.00
[    0.624454] pps_core: LinuxPPS API ver. 1 registered
[    0.624460] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.624475] PTP clock support registered
[    0.624504] EDAC MC: Ver: 3.0.0
[    0.630735] dmi: Firmware registration failed.
[    0.631115] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.631397] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.631781] Advanced Linux Sound Architecture Driver Initialized.
[    0.632539] clocksource: Switched to clocksource arch_sys_counter
[    0.641053] NET: Registered protocol family 2
[    0.641632] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.641668] TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
[    0.641757] TCP: Hash tables configured (established 4096 bind 4096)
[    0.641846] UDP hash table entries: 256 (order: 2, 16384 bytes)
[    0.641868] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[    0.642042] NET: Registered protocol family 1
[    0.642370] RPC: Registered named UNIX socket transport module.
[    0.642378] RPC: Registered udp transport module.
[    0.642384] RPC: Registered tcp transport module.
[    0.642390] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.643382] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    0.643609] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.644859] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[    0.650168] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.650757] NFS: Registering the id_resolver key type
[    0.650779] Key type id_resolver registered
[    0.650786] Key type id_legacy registered
[    0.650835] ntfs: driver 2.1.32 [Flags: R/O].
[    0.652182] bounce: pool size: 64 pages
[    0.652224] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.652233] io scheduler noop registered
[    0.652240] io scheduler deadline registered
[    0.652341] io scheduler cfq registered (default)
[    0.652349] io scheduler mq-deadline registered
[    0.652356] io scheduler kyber registered
[    0.656738] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.659775] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
[    0.660176] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
[    0.660200] OF: PCI:    IO 0x20003000..0x20012fff -> 0x00000000
[    0.660217] OF: PCI:   MEM 0x20013000..0x2fffffff -> 0x20013000
[    1.652713] dra7-pcie 51000000.pcie: phy link never came up
[    1.652847] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    1.652859] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.652867] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    1.652874] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    1.653149] PCI: bus0: Fast back to back transfers disabled
[    1.653242] PCI: bus1: Fast back to back transfers enabled
[    1.653273] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[    1.653286] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    1.653720] pcieport 0000:00:00.0: Signaling PME with IRQ 174
[    1.653940] pcieport 0000:00:00.0: AER enabled with IRQ 174
[    1.658051] V3_3D: supplied by smps9
[    1.658306] vtt_fixed: supplied by V3_3D
[    1.708939] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    1.712113] console [ttyS2] disabled
[    1.712163] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
[    2.759910] console [ttyS2] enabled
[    2.765335] omap_rng 48090000.rng: Random Number Generator ver. 20
[    2.772434] DSS: OMAP DSS rev 6.1
[    2.777533] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    2.785997] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[    2.807840] brd: module loaded
[    2.818919] loop: module loaded
[    2.826826] m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
[    2.831851] 7 ofpart partitions found on MTD device spi0.0
[    2.837359] Creating 7 MTD partitions on "spi0.0":
[    2.842172] 0x000000000000-0x000000040000 : "QSPI.SPL"
[    2.848134] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[    2.854304] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[    2.861099] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[    2.867638] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[    2.874862] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[    2.881040] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[    2.888315] libphy: Fixed MDIO Bus: probed
[    2.952585] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    2.960274] davinci_mdio 48485000.mdio: detected phy mask fffffffc
[    2.970598] libphy: 48485000.mdio: probed
[    2.974627] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[    2.984323] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[    2.994891] cpsw 48484000.ethernet: Detected MACID = 90:9a:77:63:53:16
[    3.001508] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[    3.007887] cpsw 48484000.ethernet: ALE Table size 1024
[    3.013142] cpsw 48484000.ethernet: device node lookup for pps timer failed
[    3.020160] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[    3.028105] cpsw 48484000.ethernet: cpsw: Detected MACID = 90:9a:77:63:53:17
[    3.036594] i2c /dev entries driver
[    3.041058] IR NEC protocol handler initialized
[    3.045607] IR RC5(x/sz) protocol handler initialized
[    3.050679] IR RC6 protocol handler initialized
[    3.055226] IR JVC protocol handler initialized
[    3.059774] IR Sony protocol handler initialized
[    3.064407] IR SANYO protocol handler initialized
[    3.069131] IR Sharp protocol handler initialized
[    3.073938] IR MCE Keyboard/mouse protocol handler initialized
[    3.079795] IR XMP protocol handler initialized
[    3.088419] sdhci: Secure Digital Host Controller Interface driver
[    3.094624] sdhci: Copyright(c) Pierre Ossman
[    3.099595] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.106404] sdhci-omap 4809c000.mmc: Got CD GPIO
[    3.112080] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[    3.118726] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[    3.182826] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[    3.252606] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[    3.269431] NET: Registered protocol family 10
[    3.274847] Segment Routing with IPv6
[    3.278581] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.285040] NET: Registered protocol family 17
[    3.289820] Key type dns_resolver registered
[    3.292040] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.295849] mmc0: new high speed SDHC card at address aaaa
[    3.296222] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[    3.297412]  mmcblk0: p1
[    3.317606] omap_voltage_late_init: Voltage driver support not added
[    3.325032] Power Management for TI OMAP4+ devices.
[    3.330200] Registering SWP/SWPB emulation handler
[    3.360855] dmm 4e000000.dmm: workaround for errata i878 in use
[    3.368697] dmm 4e000000.dmm: initialized all PAT entries
[    3.375869] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.382511] [drm] No driver support for vblank timestamp query.
[    3.676566] [drm] Enabling DMM ywrap scrolling
[    3.708196] Console: switching to colour frame buffer device 240x67
[    3.724019] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    3.730887] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[    3.738579] hctosys: unable to open rtc device (rtc0)
[    3.744548] net eth0: initializing cpsw version 1.15 (0)
[    3.873100] Micrel KSZ9031 Gigabit PHY 48485000.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48           485000.mdio:00, irq=POLL)
[    3.893331] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.441233] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   13.462585] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.492568] IP-Config: Complete:
[   13.495810]      device=eth0, hwaddr=90:9a:77:63:53:16, ipaddr=10.10.10.95, mask=255.255.255.0, gw=10.10.10.1
[   13.505766]      host=10.10.10.95, domain=, nis-domain=(none)
[   13.511535]      bootserver=10.10.10.2, rootserver=10.10.10.2, rootpath=
[   13.519381] ALSA device list:
[   13.522358]   No soundcards found.
[   13.543872] VFS: Mounted root (nfs filesystem) on device 0:15.
[   13.550149] devtmpfs: mounted
[   13.555120] Freeing unused kernel memory: 2048K
[   13.732693] systemd[1]: System time before build time, advancing clock.
[   13.768991] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCR           YPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid)
[   13.790244] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.10!
[   13.824174] systemd[1]: Set hostname to <am57xx-evm>.
[   14.389108] random: systemd: uninitialized urandom read (16 bytes read)
[   14.415963] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[   14.452701] random: systemd: uninitialized urandom read (16 bytes read)
[   14.459434] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[   14.492668] random: systemd: uninitialized urandom read (16 bytes read)
[   14.499913] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[   14.535456] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[   14.567449] systemd[1]: Mounting POSIX Message Queue File System...
[   14.604904] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[   14.633022] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Swap.
         Mounting Temporary Directory (/tmp)...
[  OK  ] Reached target Slices.
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
         Mounting Kernel Debug File System...
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Listening on Journal Socket.
         Starting Create list of required st…ce nodes for the current kernel...
         Starting Load Kernel Modules...
[   15.062843] cmemk: loading out-of-tree module taints kernel.
[   15.069233] CMEMK module: reference Linux version 4.14.79
[  OK  ] Listening on udev Control Socket.
[   15.075330] allocated heap buffer 0x40500000 of size 0x100000
[   15.085623] cmemk initialized
[   15.094888] cryptodev: driver 1.9 loaded.
[  OK  ] Created slice system-getty.slice.
[   15.125807] usbcore: registered new interface driver usbfs
[   15.131373] usbcore: registered new interface driver hub
[   15.136829] usbcore: registered new device driver usb
[  OK  ] Reached target Paths.
[   15.148047] usbcore: registered new interface driver usbserial
[   15.162439] usbcore: registered new interface driver ftdi_sio
[   15.168270] usbserial: USB Serial support registered for FTDI USB Serial Device
         Starting Remount Root and Kernel File Systems...
[  OK  ] Reached target Remote File Systems.
[  OK  ] Listening on Syslog Socket.
         Starting Journal Service...
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Journal Service.
         Starting udev Coldplug all Devices...
         Starting Flush Journal to Persistent Storage...
         Mounting Kernel Configuration File System...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[   16.036723] systemd-journald[125]: Received request to flush runtime journal from PID 1
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started udev Kernel Device Manager.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[   17.237729] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[   17.251628] remoteproc remoteproc0: 58820000.ipu is available
[   17.265695] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[   17.385683] remoteproc remoteproc1: 55020000.ipu is available
[   17.415891] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[   17.548632] remoteproc remoteproc2: 40800000.dsp is available
[   17.623846] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[   17.648465] remoteproc remoteproc3: 41000000.dsp is available
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target System Initialization.
[   17.700246] remoteproc remoteproc0: powering up 58820000.ipu
[   17.707637] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 6680920
[   17.716742] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[  OK  ] Started Daily Cleanup of Temporary Directories.
[   17.740442] virtio_rpmsg_bus virtio0: rpmsg host is online
[   17.746948] remoteproc remoteproc0: registered virtio0 (type 7)
[   17.754456] remoteproc remoteproc0: remote processor 58820000.ipu is now up
         Starting Docker Socket for the API.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         [   17.885199] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
Starting Network Service...
[   17.914604] remoteproc remoteproc1: powering up 55020000.ipu
[   17.920302] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3747220
[   17.928456] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[   17.932743] virtio_rpmsg_bus virtio0: msg received with no recipient
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[   18.059354] virtio_rpmsg_bus virtio1: rpmsg host is online
[   18.062681] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[   18.071811] remoteproc remoteproc1: registered virtio1 (type 7)
[   18.077849] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[  OK  ] Started Daily rotation of log files.
[   18.105284] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
[  OK  ] Reached target Timers.
[  OK  ] Listening on dropbear.socket.
[   18.436937] Unable to handle kernel paging request at virtual address ffeff000
[   18.444191] pgd = c0003000
[   18.446906] [ffeff000] *pgd=80000080007003, *pmd=9ffae003, *pte=00000000
[   18.453646] Internal error: Oops: a07 [#1] PREEMPT SMP ARM
[   18.453648] Modules linked in: omap_remoteproc virtio_rpmsg_bus rpmsg_core remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_           sio usbserial usbcore usb_common gdbserverproxy(O) cryptodev(O) cmemk(O)
[   18.453673] CPU: 0 PID: 195 Comm: kworker/0:2H Tainted: G           O    4.14.79-rt47-g28d73230da #1
[   18.453675] Hardware name: Generic DRA74X (Flattened Device Tree)
[   18.453683] Workqueue: xprtiod xs_udp_data_receive_workfn
[   18.453686] task: d3925280 task.stack: d2ec2000
[   18.453692] PC is at csum_partial_copy_nocheck+0x2c/0x418
[   18.453697] LR is at skb_copy_and_csum_bits+0x64/0x340
[   18.453699] pc : [<c09209d8>]    lr : [<c07e71bc>]    psr: 000e0013
[   18.453701] sp : d2ec3d3c  ip : 200fba40  fp : d2ec3dac
[   18.453703] r10: 00000ac0  r9 : 000005c8  r8 : 000005c0
[   18.453705] r7 : 6c617624  r6 : 00200e17  r5 : 0056415f  r4 : 316c6176
[   18.453707] r3 : 6016f992  r2 : 000005c8  r1 : ffeff000  r0 : d33dacf8
[   18.453711] Flags: nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   18.453714] Control: 30c5387d  Table: 92df3a40  DAC: fffffffd
[   18.453716] Process kworker/0:2H (pid: 195, stack limit = 0xd2ec2210)
[   18.453719] Stack: (0xd2ec3d3c to 0xd2ec4000)
[   18.453721] 3d20:        ffefe540
[   18.453725] 3d40: 00000000 000005c8 000005c8 ffefe540 000005c0 c07e71bc c0e594ac dff42700
[   18.453729] 3d60: d2ec3d7c d2de0300 dff42700 000005c8 00000001 00000000 ffefe540 c028a44c
[   18.453732] 3d80: d2ec3db4 b90289be 000005c8 00000b88 d2de0300 000005c0 00000540 00000ac0
[   18.453735] 3da0: d2ec3e04 d2ec3db0 c07e73d4 c07e7164 00000000 1f0dc000 d2ec3de4 d2de0f00
[   18.453739] 3dc0: 000005c0 00000ac0 0000071f 000005c0 ffefe540 c0c2f49c d2ec3e04 d2ec3e70
[   18.453742] 3de0: 00001000 00000080 00000000 d2ec3e70 ffefe000 00000080 d2ec3e2c d2ec3e08
[   18.453745] 3e00: c08f7b88 c07e7164 00000000 00001000 d2c5d120 00001000 00001000 d2c5d120
[   18.453749] 3e20: d2ec3e6c d2ec3e30 c08f792c c08f7b58 d2ec3e54 01080020 d321f098 c08f7b4c
[   18.453752] 3e40: d3925280 d2de0f00 d321f098 d3c34e00 d2ec3ec4 d2ec3ecc 00000000 d327a39c
[   18.453755] 3e60: d2ec3e94 d2ec3e70 c08f7aa8 c08f77f0 d2de0f00 00000080 00001000 f777a48f
[   18.453758] 3e80: d2de0f00 00001080 d2ec3efc d2ec3e98 c08f9dc8 c08f79ec d2ec3ecc d2ec3ec4
[   18.453762] 3ea0: c022cac8 0000110c d2c5cf70 d321f000 d327a000 d327a2e4 d327a3e0 d327a3d0
[   18.453765] 3ec0: c024fc18 c093b4c4 00000000 00000000 d327a3d0 d327a3d0 d2cfdd80 dff3bfc0
[   18.453768] 3ee0: dff42800 00000000 00000000 c1004100 d2ec3f34 d2ec3f00 c0242408 c08f9ca4
[   18.453771] 3f00: 200e0013 00000000 ffffe000 d2cfdd80 dff3bfc0 d2cfdd98 ffffe000 dff3bfec
[   18.453774] 3f20: 00000008 c1004100 d2ec3f74 d2ec3f38 c0243690 c0242238 d3925280 c0baa040
[   18.453778] 3f40: c105952b dff3bfc0 c0243634 d2ede780 d2c98700 00000000 d2ec2000 d2cfdd80
[   18.453781] 3f60: c0243634 df881e80 d2ec3fac d2ec3f78 c0248924 c0243640 d2ede79c d2ede79c
[   18.453784] 3f80: 00000000 d2c98700 c02487c0 00000000 00000000 00000000 00000000 00000000
[   18.453787] 3fa0: 00000000 d2ec3fb0 c0207a00 c02487cc 00000000 00000000 00000000 00000000
[   18.453790] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   18.453793] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[   18.453794] Backtrace:
[   18.453801] [<c07e7158>] (skb_copy_and_csum_bits) from [<c07e73d4>] (skb_copy_and_csum_bits+0x27c/0x340)
[   18.453806]  r10:00000ac0 r9:00000540 r8:000005c0 r7:d2de0300 r6:00000b88 r5:000005c8
[   18.453807]  r4:b90289be
[   18.453814] [<c07e7158>] (skb_copy_and_csum_bits) from [<c08f7b88>] (xdr_skb_read_and_csum_bits+0x3c/0x80)
[   18.453818]  r10:00000080 r9:ffefe000 r8:d2ec3e70 r7:00000000 r6:00000080 r5:00001000
[   18.453820]  r4:d2ec3e70
[   18.453826] [<c08f7b4c>] (xdr_skb_read_and_csum_bits) from [<c08f792c>] (xdr_partial_copy_from_skb+0x148/0x1fc)
[   18.453829]  r6:d2c5d120 r5:00001000 r4:00001000
[   18.453835] [<c08f77e4>] (xdr_partial_copy_from_skb) from [<c08f7aa8>] (csum_partial_copy_to_xdr+0xc8/0x16c)
[   18.453839]  r10:d327a39c r9:00000000 r8:d2ec3ecc r7:d2ec3ec4 r6:d3c34e00 r5:d321f098
[   18.453840]  r4:d2de0f00
[   18.453845] [<c08f79e0>] (csum_partial_copy_to_xdr) from [<c08f9dc8>] (xs_udp_data_receive_workfn+0x130/0x224)
[   18.453847]  r5:00001080 r4:d2de0f00
[   18.453853] [<c08f9c98>] (xs_udp_data_receive_workfn) from [<c0242408>] (process_one_work+0x1dc/0x3f8)
[   18.453857]  r10:c1004100 r9:00000000 r8:00000000 r7:dff42800 r6:dff3bfc0 r5:d2cfdd80
[   18.453858]  r4:d327a3d0
[   18.453863] [<c024222c>] (process_one_work) from [<c0243690>] (worker_thread+0x5c/0x600)
[   18.453867]  r10:c1004100 r9:00000008 r8:dff3bfec r7:ffffe000 r6:d2cfdd98 r5:dff3bfc0
[   18.453868]  r4:d2cfdd80
[   18.453873] [<c0243634>] (worker_thread) from [<c0248924>] (kthread+0x164/0x16c)
[   18.453877]  r10:df881e80 r9:c0243634 r8:d2cfdd80 r7:d2ec2000 r6:00000000 r5:d2c98700
[   18.453878]  r4:d2ede780
[   18.453884] [<c02487c0>] (kthread) from [<c0207a00>] (ret_from_fork+0x14/0x34)
[   18.453887]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c02487c0
[   18.453889]  r4:d2c98700
[   18.453893] Code: 1a00002c e3d2c00f 0a000008 e8b000f0 (e8a100f0)
[   18.926205] ---[ end trace 0000000000000002 ]---
[   18.927358] virtio_rpmsg_bus virtio0: msg received with no recipient
[   28.657980] omap_hwmod: timer14: _wait_target_disable failed
[   95.920256] cpsw 48484000.ethernet eth0: Link is Down
[  101.121356] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
U-Boot 2019.01-gbf4d281ebe-dirty (Nov 10 2021 - 10:30:07 +0300)
CPU  : DRA762-GP ES1.0 ABZ package
Model: TI AM5748 IDK
Board: AM574x IDK REV 1.1A
DRAM:  4 GiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from SPI Flash... SF: Detected s25fl256s1 with page size 256 Bytes, erase size 64 KiB, total 32 MiB
OK
Card did not respond to voltage select!
invalid mmc device
Net:   eth0: ethernet@48484000
Hit any key to stop autoboot:  0
ethernet@48484000 Waiting for PHY auto negotiation to complete....... done
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 10.10.10.235 (264 ms)
done
done
Starting kernel ...
[    0.000000] Kernel command line: console=ttyS2,115200 root=/dev/nfs nfsroot=10.10.10.2:/nfs/tisdk502/,v3,nolock rw ip=10.10.10.95:10.10.10.2:10.10.10.1:255.255.255.0::eth0
[    0.000000] Memory: 3543384K/3781632K available (8192K kernel code, 358K rwdata, 2596K rodata, 2048K init, 289K bss, 49832K reserved, 188416K cma-reserved, 3232768K highmem)
[    0.000244] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000247] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000558] Console: colour dummy device 80x30
[    0.000644] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000649] pid_max: default: 32768 minimum: 301
[    0.000728] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000732] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001174] CPU: Testing write buffer coherency: ok
[    0.001195] CPU0: Spectre v2: using ICIALLU workaround
[    0.001360] /cpus/cpu@0 missing clock-frequency property
[    0.001382] /cpus/cpu@1 missing clock-frequency property
[    0.001390] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.039952] Setting up static identity map for 0x80200000 - 0x80200060
[    0.079953] Hierarchical SRCU implementation.
[    0.140306] EFI services will not be available.
[    0.160056] smp: Bringing up secondary CPUs ...
[    0.260370] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.260372] CPU1: Spectre v2: using ICIALLU workaround
[    0.260458] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.260468] CPU: Virtualization extensions available.
[    0.260899] devtmpfs: initialized
[    0.281173] random: get_random_u32 called from bucket_table_alloc+0x14c/0x288 with crng_init=0
[    0.281377] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.281553] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.281567] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.284347] pinctrl core: initialized pinctrl subsystem
[    0.284880] DMI not present or invalid.
[    0.285188] NET: Registered protocol family 16
[    0.286900] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.287555] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.454348] OMAP GPIO hardware version 0.1
[    0.478550] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.478558] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.478831] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.478838] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.479760] OMAP DMA hardware revision 0.0
[    0.490719] edma 43300000.edma: memcpy is disabled
[    0.494630] edma 43300000.edma: TI EDMA DMA engine driver
[    0.502978] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.506802] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.507121] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.507497] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.507860] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.508326] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.508640] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.508955] iommu: Adding device 58820000.ipu to group 1
[    0.509083] iommu: Adding device 55020000.ipu to group 2
[    0.509314] iommu: Adding device 40800000.dsp to group 0
[    0.509705] iommu: Adding device 41000000.dsp to group 3
[    0.511686] palmas 0-0058: Irq flag is 0x00000004
[    0.541768] palmas 0-0058: Muxing GPIO 29, PWM 0, LED 0
[    0.543190] SMPS12: supplied by regulator-dummy
[    0.544750] SMPS3: supplied by VMAIN
[    0.546284] SMPS45: supplied by regulator-dummy
[    0.547978] SMPS6: supplied by VMAIN
[    0.549520] SMPS7: supplied by VMAIN
[    0.551239] SMPS8: supplied by VMAIN
[    0.552507] SMPS9: supplied by VMAIN
[    0.553394] LDO1: supplied by VMAIN
[    0.561356] LDO2: supplied by VMAIN
[    0.571206] LDO3: supplied by VMAIN
[    0.581241] LDO4: supplied by VMAIN
[    0.591231] LDO5: supplied by regulator-dummy
[    0.591989] LDO6: supplied by regulator-dummy
[    0.592738] LDO7: supplied by regulator-dummy
[    0.593500] LDO8: supplied by regulator-dummy
[    0.594247] LDO9: supplied by VMAIN
[    0.601537] LDOLN: supplied by VMAIN
[    0.611262] LDOUSB: supplied by VMAIN
[    0.624097] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.624296] media: Linux media interface: v0.10
[    0.624335] Linux video capture interface: v2.00
[    0.624415] pps_core: LinuxPPS API ver. 1 registered
[    0.624421] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.624437] PTP clock support registered
[    0.624465] EDAC MC: Ver: 3.0.0
[    0.630719] dmi: Firmware registration failed.
[    0.631094] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.631376] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.631758] Advanced Linux Sound Architecture Driver Initialized.
[    0.632508] clocksource: Switched to clocksource arch_sys_counter
[    0.640955] NET: Registered protocol family 2
[    0.641534] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.641569] TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
[    0.641653] TCP: Hash tables configured (established 4096 bind 4096)
[    0.641740] UDP hash table entries: 256 (order: 2, 16384 bytes)
[    0.641763] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[    0.641936] NET: Registered protocol family 1
[    0.642260] RPC: Registered named UNIX socket transport module.
[    0.642268] RPC: Registered udp transport module.
[    0.642274] RPC: Registered tcp transport module.
[    0.642280] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.643265] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    0.643493] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.644749] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[    0.649997] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.650599] NFS: Registering the id_resolver key type
[    0.650631] Key type id_resolver registered
[    0.650638] Key type id_legacy registered
[    0.650686] ntfs: driver 2.1.32 [Flags: R/O].
[    0.652034] bounce: pool size: 64 pages
[    0.652075] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.652084] io scheduler noop registered
[    0.652091] io scheduler deadline registered
[    0.652193] io scheduler cfq registered (default)
[    0.652201] io scheduler mq-deadline registered
[    0.652208] io scheduler kyber registered
[    0.656594] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.659634] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
[    0.660036] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
[    0.660060] OF: PCI:    IO 0x20003000..0x20012fff -> 0x00000000
[    0.660078] OF: PCI:   MEM 0x20013000..0x2fffffff -> 0x20013000
[    1.652676] dra7-pcie 51000000.pcie: phy link never came up
[    1.652810] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    1.652821] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.652829] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    1.652836] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    1.653113] PCI: bus0: Fast back to back transfers disabled
[    1.653204] PCI: bus1: Fast back to back transfers enabled
[    1.653236] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[    1.653248] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    1.653686] pcieport 0000:00:00.0: Signaling PME with IRQ 174
[    1.653903] pcieport 0000:00:00.0: AER enabled with IRQ 174
[    1.658022] V3_3D: supplied by smps9
[    1.658279] vtt_fixed: supplied by V3_3D
[    1.709014] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    1.712182] console [ttyS2] disabled
[    1.712233] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
[    2.759965] console [ttyS2] enabled
[    2.765377] omap_rng 48090000.rng: Random Number Generator ver. 20
[    2.772481] DSS: OMAP DSS rev 6.1
[    2.777584] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    2.786053] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[    2.807904] brd: module loaded
[    2.818981] loop: module loaded
[    2.826868] m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
[    2.831894] 7 ofpart partitions found on MTD device spi0.0
[    2.837403] Creating 7 MTD partitions on "spi0.0":
[    2.842215] 0x000000000000-0x000000040000 : "QSPI.SPL"
[    2.848177] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[    2.854346] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[    2.861141] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[    2.867676] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[    2.874899] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[    2.881073] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[    2.888353] libphy: Fixed MDIO Bus: probed
[    2.952553] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    2.960243] davinci_mdio 48485000.mdio: detected phy mask fffffffc
[    2.971393] libphy: 48485000.mdio: probed
[    2.975423] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[    2.985120] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[    2.995676] cpsw 48484000.ethernet: Detected MACID = 90:9a:77:63:53:16
[    3.002294] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[    3.008675] cpsw 48484000.ethernet: ALE Table size 1024
[    3.013932] cpsw 48484000.ethernet: device node lookup for pps timer failed
[    3.020949] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[    3.028892] cpsw 48484000.ethernet: cpsw: Detected MACID = 90:9a:77:63:53:17
[    3.037376] i2c /dev entries driver
[    3.041835] IR NEC protocol handler initialized
[    3.046385] IR RC5(x/sz) protocol handler initialized
[    3.051458] IR RC6 protocol handler initialized
[    3.056005] IR JVC protocol handler initialized
[    3.060553] IR Sony protocol handler initialized
[    3.065186] IR SANYO protocol handler initialized
[    3.069911] IR Sharp protocol handler initialized
[    3.074957] IR MCE Keyboard/mouse protocol handler initialized
[    3.080813] IR XMP protocol handler initialized
[    3.089412] sdhci: Secure Digital Host Controller Interface driver
[    3.095618] sdhci: Copyright(c) Pierre Ossman
[    3.100588] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.107389] sdhci-omap 4809c000.mmc: Got CD GPIO
[    3.113123] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[    3.119770] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[    3.182793] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[    3.252574] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[    3.269418] NET: Registered protocol family 10
[    3.274831] Segment Routing with IPv6
[    3.278566] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.285026] NET: Registered protocol family 17
[    3.289805] Key type dns_resolver registered
[    3.292008] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.295834] mmc0: new high speed SDHC card at address aaaa
[    3.296203] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[    3.297391]  mmcblk0: p1
[    3.317583] omap_voltage_late_init: Voltage driver support not added
[    3.325006] Power Management for TI OMAP4+ devices.
[    3.330173] Registering SWP/SWPB emulation handler
[    3.360812] dmm 4e000000.dmm: workaround for errata i878 in use
[    3.368627] dmm 4e000000.dmm: initialized all PAT entries
[    3.375804] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.382448] [drm] No driver support for vblank timestamp query.
[    3.671921] [drm] Enabling DMM ywrap scrolling
[    3.703467] Console: switching to colour frame buffer device 240x67
[    3.719213] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    3.726073] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[    3.733767] hctosys: unable to open rtc device (rtc0)
[    3.739747] net eth0: initializing cpsw version 1.15 (0)
[    3.863076] Micrel KSZ9031 Gigabit PHY 48485000.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:00, irq=POLL)
[    3.883432] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.081319] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[    8.082555] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    8.112536] IP-Config: Complete:
[    8.115779]      device=eth0, hwaddr=90:9a:77:63:53:16, ipaddr=10.10.10.95, mask=255.255.255.0, gw=10.10.10.1
[    8.125734]      host=10.10.10.95, domain=, nis-domain=(none)
[    8.131505]      bootserver=10.10.10.2, rootserver=10.10.10.2, rootpath=
[    8.139348] ALSA device list:
[    8.142326]   No soundcards found.
[    8.151155] VFS: Mounted root (nfs filesystem) on device 0:15.
[    8.157351] devtmpfs: mounted
[    8.162320] Freeing unused kernel memory: 2048K
[    8.334443] systemd[1]: System time before build time, advancing clock.
[    8.370148] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid)
[    8.391402] systemd[1]: Detected architecture arm.
[    8.423544] systemd[1]: Set hostname to <am57xx-evm>.
[    8.835105] random: systemd: uninitialized urandom read (16 bytes read)
[    8.841878] systemd[1]: Listening on udev Kernel Socket.
[    8.872652] random: systemd: uninitialized urandom read (16 bytes read)
[    8.879778] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.912633] random: systemd: uninitialized urandom read (16 bytes read)
[    8.919453] systemd[1]: Listening on Journal Socket.
[    8.994746] systemd[1]: Listening on Process Core Dump Socket.
[    9.022711] systemd[1]: Reached target Remote File Systems.
[    9.052664] systemd[1]: Reached target Swap.
[    9.083098] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    9.297177] cmemk: loading out-of-tree module taints kernel.
[    9.303658] CMEMK module: reference Linux version 4.14.79
[    9.309731] allocated heap buffer 0x40500000 of size 0x100000
[    9.315540] cmemk initialized
[    9.323888] cryptodev: driver 1.9 loaded.
[    9.353089] usbcore: registered new interface driver usbfs
[    9.361813] usbcore: registered new interface driver hub
[    9.367488] usbcore: registered new device driver usb
[  OK  ] Started Forward Password Requests to Wall Dir[    9.377904] usbcore: registered new interface driver usbserial
ectory Watch.
[    9.392701] usbcore: registered new interface driver ftdi_sio
[    9.398528] usbserial: USB Serial support registered for FTDI USB Serial Device
[   10.517173] systemd-journald[118]: Received request to flush runtime journal from PID 1
[   11.646591] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[   11.708436] remoteproc remoteproc0: 58820000.ipu is available
[   11.759082] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[   11.824203] remoteproc remoteproc1: 55020000.ipu is available
[   11.855244] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[   11.882214] remoteproc remoteproc2: 40800000.dsp is available
[   12.027423] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[   12.086110] remoteproc remoteproc3: 41000000.dsp is available
[   12.188512] remoteproc remoteproc1: powering up 55020000.ipu
[   12.194815] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3747220
[   12.205461] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[   12.325738] virtio_rpmsg_bus virtio0: rpmsg host is online
[   12.332032] remoteproc remoteproc1: registered virtio0 (type 7)
[   12.338368] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[   12.366705] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[  OK  ] Listening on RPCbind Server Activation Socket[   12.386327] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x66
[FAILED] Failed to listen on Docker Socket for the API.
See 'systemctl status docker.socket' for details.
BR,
Oleg
  • Hi Oleg,
    Can you please take a look at this thread: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/964029/am5718-can-t-upgrade-cpu-speed-to-1-5ghz/3564317#3564317
    There are more things that need to be configured for 1.5GHz apart from the frequency change. That might be leading to crashes.
    Voltage changes will be needed to sustain 1.5GHz frequency.
    Keerthy
  • Actually I still didn't understand this mechanism. On a website when I made a choiсe I see 1500 max.freq. You are company made 6 DSK but still didn't have some user friendly ability how to right set up freq on a maximum. Nobody know how to do it right step by step. In stock it is work on 1000 and across with some POH register, it is mean the life time of your product on this freq will be short.
    Any way I don't know how but I add this rows in bord.c
    //.mpu.value[OPP_NOM] = VDD_MPU_DRA7_NOM,
    //.mpu.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_MPU_NOM,
    .mpu.value[OPP_HIGH] = 1200,
    .mpu.efuse.reg[OPP_HIGH] = STD_FUSE_OPP_VMIN_MPU_HIGH,
    Rebuild and after that it is looks like stable loading I've try to reboot it many times and it is still stable.
    Omapconf show me a 1500 freq and OPP now is HIGH. I didn't understand why this man set 1250. I didn't see this value of voltage in this table.
