Part Number: TDA2P-ACD
Dear expert,
TDA2P whether support IPU1 and IPU2 boot at same time when A15 run Linux? How to configure cfg.mk? I have find related question on E2E https://e2e.ti.com/support/processors-group/processors/f/processors-forum/981078/tda2p-acd-visionsdk-3-07-using-ipu2-and-ipu1-at-the-same-time?tisearch=e2e-sitesearch&keymatch=TDA2P#
my configure at list:
PROC_IPU1_0_INCLUDE=yes
PROC_IPU1_1_INCLUDE=no
PROC_IPU2_INCLUDE=yes
PROC_A15_0_INCLUDE=yes
PROC_DSP1_INCLUDE=yes
PROC_DSP2_INCLUDE=yes
PROC_EVE1_INCLUDE=yes
PROC_EVE2_INCLUDE=yes
IPU_PRIMARY_CORE=ipu1_0
IPU_SECONDARY_CORE=ipu2
and boot log has some error as below:
[19:18:34:506]switch to partitions #0, OK [19:18:34:506]mmc0 is current device [19:18:34:681]SD/MMC found on device 0 [19:18:34:905]3560384 bytes read in 224 ms (15.2 MiB/s) [19:18:34:959]108033 bytes read in 28 ms (3.7 MiB/s) [19:18:34:959]Booting from mmc0 ... [19:18:34:959]Kernel image @ 0x82000000 [ 0x000000 - 0x3653c0 ] [19:18:34:959]## Flattened Device Tree blob at 88000000 [19:18:34:960] Booting using the fdt blob at 0x88000000 [19:18:34:964] Loading Device Tree to 8ffe2000, end 8ffff600 ... OK [19:18:34:964] [19:18:34:964]Starting kernel ... [19:18:34:964] [19:18:37:817][ 0.000000] Booting Linux on physical CPU 0x0 [19:18:37:817][ 0.000000] Initializing cgroup subsys cpuset [19:18:37:817][ 0.000000] Initializing cgroup subsys cpu [19:18:37:817][ 0.000000] Initializing cgroup subsys cpuacct [19:18:37:817][ 0.000000] Linux version 4.4.84-00034-gaa42c96 (root@ubuntu1604) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #20 SMP PREEMPT Wed Nov 3 18:45:40 CST 2021 [19:18:37:817][ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [19:18:37:817][ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [19:18:37:817][ 0.000000] Machine model: TI DRA762 EVM [19:18:37:817][ 0.000000] Reserved memory: OVERLAP DETECTED! [19:18:37:818][ 0.000000] vsdk_sr1_mem@84000000 (0x0000000084000000--0x0000000097000000) overlaps with cmem@95400000 (0x0000000095400000--0x0000000095800000) [19:18:37:818][ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB [19:18:37:818][ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool [19:18:37:818][ 0.000000] Reserved memory: regions without no-map are not yet supported [19:18:37:818][ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB [19:18:37:818][ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool [19:18:37:818][ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB [19:18:37:818][ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool [19:18:37:818][ 0.000000] Reserved memory: regions without no-map are not yet supported [19:18:37:818][ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB [19:18:37:819][ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool [19:18:37:819][ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB [19:18:37:819][ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool [19:18:37:819][ 0.000000] Reserved memory: regions without no-map are not yet supported [19:18:37:819][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 32 MiB [19:18:37:819][ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool [19:18:37:819][ 0.000000] cma: Reserved 64 MiB at 0x00000000bb800000 [19:18:37:819][ 0.000000] Forcing write-allocate cache policy for SMP [19:18:37:819][ 0.000000] Memory policy: Data cache writealloc [19:18:37:820][ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier [19:18:37:820][ 0.000000] DRA762 ES1.0 [19:18:37:820][ 0.000000] PERCPU: Embedded 11 pages/cpu @ef629000 s14912 r8192 d21952 u45056 [19:18:37:820][ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 250176 [19:18:37:820][ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=50ea9e20-02 rw rootwait ip=none mem=1024M cma=64M [19:18:37:820][ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [19:18:37:820][ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [19:18:37:820][ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [19:18:37:820][ 0.000000] Memory: 352196K/1007616K available (6635K kernel code, 320K rwdata, 2392K rodata, 336K init, 290K bss, 409660K reserved, 245760K cma-reserved, 192512K highmem) [19:18:37:821][ 0.000000] Virtual kernel memory layout: [19:18:37:821][ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [19:18:37:821][ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [19:18:37:821][ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [19:18:37:821][ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [19:18:37:821][ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [19:18:37:821][ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [19:18:37:821][ 0.000000] .text : 0xc0008000 - 0xc08d902c (9029 kB) [19:18:37:821][ 0.000000] .init : 0xc08da000 - 0xc092e000 ( 336 kB) [19:18:37:821][ 0.000000] .data : 0xc092e000 - 0xc097e120 ( 321 kB) [19:18:37:821][ 0.000000] .bss : 0xc0980000 - 0xc09c8800 ( 290 kB) [19:18:37:822][ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [19:18:38:164][ 0.000000] Preemptible hierarchical RCU implementation. [19:18:38:164][ 0.000000] Build-time adjustment of leaf fanout to 32. [19:18:38:164][ 0.000000] NR_IRQS:16 nr_irqs:16 16 [19:18:38:165][ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div [19:18:38:165][ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [19:18:38:165][ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys). [19:18:38:167][ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [19:18:38:167][ 0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [19:18:38:167][ 0.000015] Switching to timer-based delay loop, resolution 162ns [19:18:38:167][ 0.000331] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [19:18:38:167][ 0.000339] OMAP clocksource: 32k_counter at 32768 Hz [19:18:38:167][ 0.000798] Console: colour dummy device 80x30 [19:18:38:167][ 0.000814] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [19:18:38:167][ 0.000820] This ensures that you still see kernel messages. Please [19:18:38:167][ 0.000825] update your kernel commandline. [19:18:38:167][ 0.000838] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [19:18:38:167][ 0.000851] pid_max: default: 32768 minimum: 301 [19:18:38:167][ 0.000948] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [19:18:38:167][ 0.000958] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [19:18:38:167][ 0.001491] Initializing cgroup subsys io [19:18:38:168][ 0.001508] Initializing cgroup subsys memory [19:18:38:168][ 0.001532] Initializing cgroup subsys devices [19:18:38:168][ 0.001545] Initializing cgroup subsys freezer [19:18:38:168][ 0.001556] Initializing cgroup subsys perf_event [19:18:38:168][ 0.001567] Initializing cgroup subsys pids [19:18:38:168][ 0.001593] CPU: Testing write buffer coherency: ok [19:18:38:168][ 0.001789] /cpus/cpu@0 missing clock-frequency property [19:18:38:168][ 0.001804] /cpus/cpu@1 missing clock-frequency property [19:18:38:168][ 0.001814] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [19:18:38:169][ 0.001850] Setting up static identity map for 0x80008380 - 0x800083e0 [19:18:38:169][ 0.080044] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [19:18:38:169][ 0.080113] Brought up 2 CPUs [19:18:38:169][ 0.080126] SMP: Total of 2 processors activated (24.59 BogoMIPS). [19:18:38:169][ 0.080132] CPU: All CPU(s) started in HYP mode. [19:18:38:169][ 0.080137] CPU: Virtualization extensions available. [19:18:38:169][ 0.080515] devtmpfs: initialized [19:18:38:169][ 0.109877] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [19:18:38:169][ 0.110841] omap_hwmod: l3_main_2 using broken dt data from ocp [19:18:38:169][ 0.226070] omap_hwmod: dcan1: _wait_target_disable failed [19:18:38:170][ 0.323602] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [19:18:38:170][ 0.323625] futex hash table entries: 512 (order: 3, 32768 bytes) [19:18:38:170][ 0.328542] pinctrl core: initialized pinctrl subsystem [19:18:38:170][ 0.329413] NET: Registered protocol family 16 [19:18:38:170][ 0.330373] DMA: preallocated 256 KiB pool for atomic coherent allocations [19:18:38:170][ 0.360229] cpuidle: using governor ladder [19:18:38:170][ 0.390250] cpuidle: using governor menu [19:18:38:170][ 0.398826] OMAP GPIO hardware version 0.1 [19:18:38:170][ 0.402955] GPIO line 161 (radio_rst) hogged as output/low [19:18:38:170][ 0.405339] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 ! [19:18:38:170][ 0.429691] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [19:18:38:171][ 0.429701] hw-breakpoint: maximum watchpoint size is 8 bytes. [19:18:38:171][ 0.430179] omap4_sram_init:Unable to allocate sram needed to handle errata I688 [19:18:38:171][ 0.430189] omap4_sram_init:Unable to get sram pool needed to handle errata I688 [19:18:38:171][ 0.430788] OMAP DMA hardware revision 0.0 [19:18:38:171][ 0.471497] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [19:18:38:171][ 0.472663] edma 43300000.edma: memcpy is disabled [19:18:38:171][ 0.477396] edma 43300000.edma: TI EDMA DMA engine driver [19:18:38:171][ 0.482285] omap-iommu 40d01000.mmu: 40d01000.mmu registered [19:18:38:171][ 0.482462] omap-iommu 40d02000.mmu: 40d02000.mmu registered [19:18:38:174][ 0.482632] omap-iommu 58882000.mmu: 58882000.mmu registered [19:18:38:511][ 0.482796] omap-iommu 55082000.mmu: 55082000.mmu registered [19:18:38:512][ 0.483079] omap-iommu 41501000.mmu: 41501000.mmu registered [19:18:38:512][ 0.483263] omap-iommu 41502000.mmu: 41502000.mmu registered [19:18:38:512][ 0.486295] palmas 0-0058: IRQ missing: skipping irq request [19:18:38:512][ 0.500716] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2 [19:18:38:512][ 0.551252] irq: no irq domain found for /ocp/i2c@48070000/tps65917@58 ! [19:18:38:512][ 0.552167] pcf857x 0-0020: probed [19:18:38:512][ 0.552735] pcf857x 0-0021: probed [19:18:38:513][ 0.553120] GPIO line 465 (vin6_sel_s0) hogged as output/low [19:18:38:513][ 0.553247] GPIO line 466 (vin2_s0) hogged as output/low [19:18:38:513][ 0.553373] GPIO line 471 (vin2_s2) hogged as output/high [19:18:38:513][ 0.553499] GPIO line 473 (exvin2_s0) hogged as output/low [19:18:38:513][ 0.553625] GPIO line 474 (exvin2_s2) hogged as output/high [19:18:38:513][ 0.553720] pcf857x 0-0026: probed [19:18:38:513][ 0.553866] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [19:18:38:513][ 0.554261] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz [19:18:38:513][ 0.570572] pcf857x: probe of 3-0021 failed with error -121 [19:18:38:514][ 0.570609] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz [19:18:38:514][ 0.570810] media: Linux media interface: v0.10 [19:18:38:514][ 0.570860] Linux video capture interface: v2.00 [19:18:38:514][ 0.570899] pps_core: LinuxPPS API ver. 1 registered [19:18:38:514][ 0.570905] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [19:18:38:514][ 0.570928] PTP clock support registered [19:18:38:514][ 0.570972] EDAC MC: Ver: 3.0.0 [19:18:38:514][ 0.571729] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [19:18:38:514][ 0.572024] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [19:18:38:515][ 0.572379] Advanced Linux Sound Architecture Driver Initialized. [19:18:38:515][ 0.573246] clocksource: Switched to clocksource arch_sys_counter [19:18:38:515][ 0.583598] NET: Registered protocol family 2 [19:18:38:515][ 0.584094] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [19:18:38:515][ 0.584157] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [19:18:38:515][ 0.584282] TCP: Hash tables configured (established 8192 bind 8192) [19:18:38:515][ 0.584326] UDP hash table entries: 512 (order: 2, 16384 bytes) [19:18:38:515][ 0.584357] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [19:18:38:515][ 0.584560] NET: Registered protocol family 1 [19:18:38:515][ 0.584820] RPC: Registered named UNIX socket transport module. [19:18:38:515][ 0.584829] RPC: Registered udp transport module. [19:18:38:515][ 0.584835] RPC: Registered tcp transport module. [19:18:38:516][ 0.584842] RPC: Registered tcp NFSv4.1 backchannel transport module. [19:18:38:516][ 0.585828] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [19:18:38:516][ 0.595877] squashfs: version 4.0 (2009/01/31) Phillip Lougher [19:18:38:516][ 0.596538] NFS: Registering the id_resolver key type [19:18:38:516][ 0.596566] Key type id_resolver registered [19:18:38:516][ 0.596573] Key type id_legacy registered [19:18:38:516][ 0.596643] ntfs: driver 2.1.32 [Flags: R/O]. [19:18:38:516][ 0.597959] bounce: pool size: 64 pages [19:18:38:516][ 0.598113] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [19:18:38:516][ 0.598131] io scheduler noop registered [19:18:38:516][ 0.598145] io scheduler deadline registered [19:18:38:517][ 0.598181] io scheduler cfq registered (default) [19:18:38:517][ 0.600558] vsys_5v0: supplied by vsys_12v0 [19:18:38:517][ 0.600607] ldo3: supplied by vsys_5v0 [19:18:38:517][ 0.604354] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128 [19:18:38:517][ 0.607628] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges: [19:18:38:517][ 0.607640] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff] [19:18:38:519][ 0.607672] IO 0x20003000..0x20012fff -> 0x00000000 [19:18:38:519][ 0.607693] MEM 0x20013000..0x2fffffff -> 0x20013000 [19:18:38:519][ 0.637790] dra7-pcie 51000000.pcie_rc: link is not up [19:18:38:520][ 0.637951] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00 [19:18:38:520][ 0.637964] pci_bus 0000:00: root bus resource [bus 00-ff] [19:18:38:520][ 0.637974] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [19:18:38:520][ 0.637983] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff] [19:18:38:520][ 0.638384] PCI: bus0: Fast back to back transfers disabled [19:18:38:716][ 0.638499] PCI: bus1: Fast back to back transfers enabled [19:18:38:717][ 0.638581] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff] [19:18:38:717][ 0.638596] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff] [19:18:38:717][ 0.638608] pci 0000:00:00.0: PCI bridge to [bus 01] [19:18:38:717][ 0.638834] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [19:18:38:717][ 0.699301] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [19:18:38:717][ 0.702702] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250 [19:18:38:717][ 1.786589] console [ttyS0] enabled [19:18:38:717][ 1.790978] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250 [19:18:38:717][ 1.800673] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250 [19:18:38:718][ 1.810729] [drm] Initialized drm 1.1.0 20060810 [19:18:38:718][ 1.816263] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [19:18:38:718][ 1.822906] [drm] No driver support for vblank timestamp query. [19:18:38:718][ 1.829070] [drm] Initialized vdrm 1.0.0 20110917 on minor 0 [19:18:38:718][ 1.842051] loop: module loaded [19:18:38:718][ 1.848066] vmemexp device MAJOR num = 245 [19:18:38:718][ 1.852194] vmemexp class registered [19:18:38:718][ 1.855932] /dev/vmemexp device registered [19:18:38:718][ 1.860047] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120 [19:18:38:718][ 1.868450] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes) [19:18:38:718][ 1.873867] 7 ofpart partitions found on MTD device spi32766.0 [19:18:38:718][ 1.879726] Creating 7 MTD partitions on "spi32766.0": [19:18:38:718][ 1.884905] 0x000000000000-0x000000040000 : "QSPI.SPL" [19:18:38:719][ 1.891022] 0x000000040000-0x000000140000 : "QSPI.u-boot" [19:18:38:719][ 1.897374] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os" [19:18:38:719][ 1.904338] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env" [19:18:38:719][ 1.911025] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1" [19:18:38:719][ 1.918434] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel" [19:18:38:719][ 1.924789] 0x0000009e0000-0x000002000000 : "QSPI.file-system" [19:18:38:721][ 1.932547] libphy: Fixed MDIO Bus: probed [19:18:38:822][ 1.983279] davinci_mdio 48485000.mdio: davinci mdio revision 1.6 [19:18:38:822][ 1.989401] libphy: 48485000.mdio: probed [19:18:38:822][ 1.997500] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver TI DP83867 [19:18:38:822][ 2.005846] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver TI DP83867 [19:18:38:822][ 2.014808] cpsw 48484000.ethernet: Detected MACID = 0c:b2:b7:90:b4:fa [19:18:38:828][ 2.021450] cpsw 48484000.ethernet: cpts: overflow check period 800 [19:18:38:843][ 2.028458] cpsw 48484000.ethernet: cpsw: Detected MACID = 0c:b2:b7:90:b4:fb [19:18:38:844][ 2.037229] mousedev: PS/2 mouse device common for all mice [19:18:38:904][ 2.053485] i2c /dev entries driver [19:18:38:905][ 2.062286] omap_hsmmc 4809c000.mmc: Got CD GPIO [19:18:38:905][ 2.067175] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode [19:18:38:905][ 2.073686] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode [19:18:38:905][ 2.080071] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode [19:18:38:905][ 2.086472] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode [19:18:38:905][ 2.092854] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode [19:18:38:907][ 2.099956] vsys_3v3: supplied by vsys_12v0 [19:18:38:921][ 2.104217] vio_3v3: supplied by vsys_3v3 [19:18:38:922][ 2.108286] vio_3v3_sd: supplied by vio_3v3 [19:18:38:923][ 2.112619] ldo4: supplied by vsys_5v0 [19:18:38:958][ 2.163688] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode [19:18:38:969][ 2.170074] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode [19:18:38:993][ 2.193415] smps5: supplied by vsys_3v3 [19:18:38:995][ 2.197470] vio_1v8: supplied by smps5 [19:18:39:081][ 2.254993] ledtrig-cpu: registered to indicate activity on CPUs [19:18:39:081][ 2.266605] hwspinlock_user gatemp: requested 20 hwspinlocks [19:18:39:081][ 2.273559] aic_dvdd: supplied by vio_3v3 [19:18:39:082][ 2.278822] davinci-mcasp 48464000.mcasp: DAI is shared [19:18:39:098][ 2.284931] davinci-mcasp 48474000.mcasp: DAI is shared [19:18:39:099][ 2.291434] NET: Registered protocol family 10 [19:18:39:223][ 2.306774] sit: IPv6 over IPv4 tunneling driver [19:18:39:223][ 2.311943] NET: Registered protocol family 17 [19:18:39:223][ 2.316651] Key type dns_resolver registered [19:18:39:223][ 2.321063] omap_voltage_late_init: Voltage driver support not added [19:18:39:224][ 2.327950] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [19:18:39:224][ 2.334174] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [19:18:39:224][ 2.340457] buck10: supplied by vsys_3v3 [19:18:39:224][ 2.345068] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [19:18:39:224][ 2.351278] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [19:18:39:224][ 2.359486] Power Management for TI OMAP4+ devices. [19:18:39:224][ 2.364536] Registering SWP/SWPB emulation handler [19:18:39:224][ 2.370111] dmm 4e000000.dmm: workaround for errata i878 in use [19:18:39:224][ 2.377185] dmm 4e000000.dmm: initialized all PAT entries [19:18:39:224][ 2.383183] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1 [19:18:39:225][ 2.390201] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok [19:18:39:225][ 2.399752] input: gpio_keys as /devices/platform/gpio_keys/input/input0 [19:18:39:225][ 2.406633] hctosys: unable to open rtc device (rtc0) [19:18:39:225][ 2.418738] aic_dvdd: disabling [19:18:39:225][ 2.422023] ALSA device list: [19:18:39:241][ 2.425011] #0: DRA7xx-EVM [19:18:39:242][ 2.428453] Waiting for root device PARTUUID=50ea9e20-02... [19:18:39:348][ 2.510187] mmc0: host does not support reading read-only switch, assuming write-enable [19:18:39:349][ 2.519989] mmc0: Problem switching card into high-speed mode! [19:18:39:349][ 2.525900] mmc0: new SDHC card at address 0001 [19:18:39:349][ 2.530723] mmcblk0: mmc0:0001 SD16G 14.6 GiB [19:18:39:349][ 2.536405] mmcblk0: p1 p2 [19:18:39:350][ 2.543914] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities [19:18:39:359][ 2.552675] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities [19:18:39:428][ 2.576996] mmc1: MAN_BKOPS_EN bit is not set [19:18:39:428][ 2.582466] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [19:18:39:429][ 2.588393] mmc1: new HS200 MMC card at address 0001 [19:18:39:429][ 2.593368] mmcblk1: mmc1:0001 MMC08G 7.25 GiB [19:18:39:429][ 2.600165] VFS: Mounted root (ext4 filesystem) on device 179:2. [19:18:39:429][ 2.603541] mmcblk1boot0: mmc1:0001 MMC08G partition 1 8.00 MiB [19:18:39:429][ 2.603700] mmcblk1boot1: mmc1:0001 MMC08G partition 2 8.00 MiB [19:18:39:429][ 2.620459] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 [19:18:39:429][ 2.628313] devtmpfs: mounted [19:18:39:430][ 2.631463] Freeing unused kernel memory: 336K [19:18:39:440][ 2.635955] This architecture does not have kernel memory protection. [19:18:39:882][ 3.087200] systemd[1]: System time before build time, advancing clock. [19:18:39:991][ 3.144627] random: systemd: uninitialized urandom read (16 bytes read, 14 bits of entropy available) [19:18:39:991][ 3.158139] random: systemd: uninitialized urandom read (16 bytes read, 14 bits of entropy available) [19:18:39:991][ 3.169877] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN) [19:18:39:991][ 3.188416] systemd[1]: Detected architecture arm. [19:18:39:991] [19:18:39:998]Welcome to Arago 2016.12! [19:18:40:008] [19:18:40:020][ 3.214753] systemd[1]: Set hostname to <dra7xx-evm>. [19:18:40:034][ 3.222650] random: systemd: uninitialized urandom read (16 bytes read, 15 bits of entropy available) [19:18:40:036][ 3.231984] systemd[1]: Initializing machine ID from random generator. [19:18:40:094][ 3.299517] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 15 bits of entropy available) [19:18:40:122][ 3.321997] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 15 bits of entropy available) [19:18:40:130][ 3.332195] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 15 bits of entropy available) [19:18:40:183][ 3.379496] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available) [19:18:40:192][ 3.392769] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available) [19:18:40:343][ 3.543270] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available) [19:18:40:353][ 3.552744] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available) [19:18:41:059][ 4.215810] systemd[1]: basic.target: Found ordering cycle on basic.target/start [19:18:41:059][ 4.223266] systemd[1]: basic.target: Found dependency on sysinit.target/start [19:18:41:059][ 4.230526] systemd[1]: basic.target: Found dependency on alignment.service/start [19:18:41:059][ 4.238081] systemd[1]: basic.target: Found dependency on basic.target/start [19:18:41:060][ 4.245181] systemd[1]: basic.target: Breaking ordering cycle by deleting job alignment.service/start [19:18:41:061][ 4.254480] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with basic.target/start [19:18:41:072][ SKIP ] Ordering cycle found, skipping alignment.service [19:18:41:102][ 4.285454] systemd[1]: Listening on Journal Socket. [19:18:41:103][ OK ] Listening on Journal Socket. [19:18:41:116][ 4.303554] systemd[1]: Listening on Syslog Socket. [19:18:41:120][ OK ] Listening on Syslog Socket. [19:18:41:134][ 4.323505] systemd[1]: Listening on udev Kernel Socket. [19:18:41:136][ OK ] Listening on udev Kernel Socket. [19:18:41:161][ 4.354762] systemd[1]: Created slice User and Session Slice. [19:18:41:162][ OK ] Created slice User and Session Slice. [19:18:41:178][ 4.383624] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [19:18:41:189][ OK ] Started Forward Password Requests to Wall Directory Watch. [19:18:41:215][ 4.413977] systemd[1]: Created slice System Slice. [19:18:41:216][ OK ] Created slice System Slice. [19:18:41:257][ 4.473480] systemd[1]: Mounting Temporary Directory... [19:18:41:272] Mounting Temporary Directory... [19:18:41:306][ 4.505459] systemd[1]: Starting Setup Virtual Console... [19:18:41:307] Starting Setup Virtual Console... [19:18:41:336][ 4.534334] systemd[1]: Created slice system-getty.slice. [19:18:41:337][ OK ] Created slice system-getty.slice. [19:18:41:358][ 4.563605] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [19:18:41:367][ OK ] Listening on /dev/initctl Compatibility Named Pipe. [19:18:41:393][ 4.593539] systemd[1]: Listening on udev Control Socket. [19:18:41:394][ OK ] Listening on udev Control Socket. [19:18:41:455][ 4.653640] systemd[1]: Starting Create list of required static device nodes for the current kernel... [19:18:41:462] Starting Create list of required st... nodes for the current kernel... [19:18:41:488][ 4.683680] systemd[1]: Listening on Network Service Netlink Socket. [19:18:41:489][ OK ] Listening on Network Service Netlink Socket. [19:18:41:509][ 4.714106] systemd[1]: Created slice system-serial\x2dgetty.slice. [19:18:41:519][ OK ] Created slice system-serial\x2dgetty.slice. [19:18:41:544][ 4.743452] systemd[1]: Reached target Swap. [19:18:41:545][ OK ] Reached target Swap. [19:18:41:592][ 4.793436] systemd[1]: Mounting Debug File System... [19:18:41:593] Mounting Debug File System... [19:18:41:630][ 4.828665] systemd[1]: Reached target Remote File Systems. [19:18:41:631][ OK ] Reached target Remote File Systems. [19:18:41:692][ 4.893598] systemd[1]: Starting Load Kernel Modules... [19:18:41:693] Starting Load Kernel Modules... [19:18:41:720][ 4.915521] systemd[1]: Mounting POSIX Message Queue File System... [19:18:41:721] Mounting POSIX Message Queue File System... [19:18:41:750][ 4.943611] systemd[1]: Listening on Journal Socket (/dev/log). [19:18:41:752][ OK ] Listening on Journal Socket (/dev/log). [19:18:41:792][ 5.013655] systemd[1]: Starting Journal Service... [19:18:41:808] Starting Journal Service... [19:18:41:844][ 5.043483] systemd[1]: Reached target Slices. [19:18:41:846][ OK ] Reached target Slices. [19:18:41:911][ 5.065483] systemd[1]: Starting Remount Root and Kernel File Systems... [19:18:41:911] Starting Remount Root and Kernel File Systems... [19:18:41:913][ 5.094445] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [19:18:41:928][ 5.103718] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [19:18:41:930][ OK ] Started Dispatch Password Requests to Console Directory Watch. [19:18:41:945][ 5.143482] systemd[1]: Reached target Paths. [19:18:41:947][ OK ] Reached target Paths. [19:18:42:003][ 5.201697] systemd[1]: Mounted Debug File System. [19:18:42:004][ OK ] Mounted Debug File System. [19:18:42:019][ 5.223526] systemd[1]: Mounted POSIX Message Queue File System. [19:18:42:029][ OK ] Mounted POSIX Message Queue File System. [19:18:42:056][ 5.253487] systemd[1]: Mounted Temporary Directory. [19:18:42:057][ OK ] Mounted Temporary Directory. [19:18:42:074][ 5.273653] systemd[1]: Started Journal Service. [19:18:42:075][ OK ] Started Journal Service. [19:18:42:086][ OK ] Started Setup Virtual Console. [19:18:42:110][ OK ] Started Create list of required sta...ce nodes for the current kernel. [19:18:42:126][FAILED] Failed to start Load Kernel Modules. [19:18:42:157]See 'systemctl status systemd-modules-load.service' for details. [19:18:42:181][ OK ] Started Remount Root and Kernel File Systems. [19:18:42:436] Starting udev Coldplug all Devices... [19:18:42:469] Starting Apply Kernel Variables... [19:18:42:500] Starting Create Static Device Nodes in /dev... [19:18:42:503] Starting Flush Journal to Persistent Storage... [19:18:42:591][ OK ] Started Apply Kernel Variables. [19:18:42:685][ OK ] Started Create Static Device Nodes in /dev. [19:18:42:710][ 5.914755] systemd-journald[145]: Received request to flush runtime journal from PID 1 [19:18:42:741] Starting udev Kernel Device Manager... [19:18:42:769][ OK ] Reached target Local File Systems (Pre). [19:18:42:834] Mounting /media/ram... [19:18:42:865] Mounting /var/volatile... [19:18:42:897][ OK ] Mounted /var/volatile. [19:18:42:932][ OK ] Mounted /media/ram. [19:18:42:945][ OK ] Started udev Kernel Device Manager. [19:18:42:978][ OK ] Started Flush Journal to Persistent Storage. [19:18:42:994][ OK ] Started udev Coldplug all Devices. [19:18:43:025][ 6.245407] CAN device driver interface [19:18:43:111][ 6.299464] m_can 42c01a00.mcan: hclk could not be found [19:18:43:126][ 6.309179] m_can 42c01a00.mcan: m_can device registered (irq=361, version=32) [19:18:43:127] Starting Load/Save Random Seed... [19:18:43:136][ OK ] Reached target Local File Systems. [19:18:43:164] Starting Create Volatile Files and Directories... [19:18:43:196][ OK ] Found device /dev/ttyS0. [19:18:43:239][ 6.434332] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000 [19:18:43:240][ 6.442145] remoteproc0: 58820000.ipu is available [19:18:43:276][ OK ] Started Load/Save Random Seed. [19:18:43:278][ 6.465899] remoteproc0: Note: remoteproc is still under development and considered experimental. [19:18:43:287][ 6.478980] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [19:18:43:297][ 6.502045] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000 [19:18:43:321][ 6.522726] remoteproc1: 55020000.ipu is available [19:18:43:329][ 6.530236] remoteproc1: Note: remoteproc is still under development and considered experimental. [19:18:43:347][ 6.552252] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [19:18:43:410][ 6.575630] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000 [19:18:43:410][ 6.586980] remoteproc2: 40800000.dsp is available [19:18:43:410][ OK ] Started Create Volatile Files and Directories. [19:18:43:412][ 6.595787] remoteproc2: Note: remoteproc is still under development and considered experimental. [19:18:43:421][ 6.611019] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [19:18:43:495][ 6.633469] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20 [19:18:43:495][ 6.641599] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000 [19:18:43:495][ 6.650051] remoteproc3: 41000000.dsp is available [19:18:43:495][ 6.659827] remoteproc3: Note: remoteproc is still under development and considered experimental. [19:18:43:495][ 6.669475] remoteproc1: registered virtio0 (type 7) [19:18:43:495] Starting Network Time Synchronization... [19:18:43:496][ 6.677069] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [19:18:43:512] Starting Update UTMP about System Boot/Shutdown...[ 6.698429] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2 [19:18:43:513] [19:18:44:774][ 7.983492] remoteproc3: registered virtio1 (type 7) [19:18:45:189][ 8.404605] remoteproc2: registered virtio2 (type 7) [19:18:45:301] Starting Opkg first boot configure... [19:18:45:330][ 8.527495] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3 [19:18:45:345][ OK ] Started Network Time Synchronization.[ 8.535525] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3 [19:18:45:346] [19:18:45:441][ OK ] Started Update UTMP about System Boot/Shutdown. [19:18:45:456][ OK ] Reached target Sound Card. [19:18:45:520] Starting Synchronize System and HW clocks... [19:18:45:559][ 8.753808] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3 [19:18:45:561][ OK ] Reached target System Time Synchronized. [19:18:45:639][FAILED] Failed to start Synchronize System and HW clocks. [19:18:45:655]See 'systemctl status sync-clocks.service' for details. [19:18:46:119][ 9.338118] remoteproc0: registered virtio3 (type 7) [19:18:46:446][ 9.651671] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2 [19:18:46:622][ 9.840539] SCSI subsystem initialized [19:18:47:006][ 10.195440] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled [19:18:47:007][ 10.207485] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode [19:18:47:063][ 10.267905] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst [19:18:47:155][ 10.342706] EXT4-fs (mmcblk1p12): recovery complete [19:18:47:155][ 10.348424] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: (null) [19:18:47:156][ 10.355620] EXT4-fs (mmcblk1p10): recovery complete [19:18:47:163][ 10.355629] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: (null) [19:18:47:210][ 10.404034] scsi host0: ahci [19:18:47:211][ 10.407164] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 341 [19:18:47:492][ OK ] Started Opkg first boot configure. [19:18:47:577][ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [19:18:47:612][ 10.803289] ata1: SATA link down (SStatus 0 SControl 300) [19:18:47:613][ OK ] Reached target System Initialization. [19:18:47:625][ OK ] Listening on dropbear.socket. [19:18:47:643][ OK ] Started Daily Cleanup of Temporary Directories. [19:18:47:658][ OK ] Reached target Timers. [19:18:47:706][ OK ] Listening on D-Bus System Message Bus Socket. [19:18:47:707][ OK ] Reached target Sockets. [19:18:47:717][ OK ] Reached target Basic System. [19:18:47:764][ OK ] Started System Logging Service. [19:18:47:780][ OK ] Started Kernel Logging Service. [19:18:47:796] Starting rc.pvr.service... [19:18:47:812] Starting Save/Restore Sound Card State... [19:18:47:828] Starting Permit User Sessions... [19:18:47:876] Starting Login Service... [19:18:47:924][ OK ] Started D-Bus System Message Bus. [19:18:48:035][ 11.233624] remoteproc1: powering up 55020000.ipu [19:18:48:048][ 11.238932] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 470392 [19:18:48:050][ 11.245883] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1 [19:18:48:106][ 11.264291] remoteproc1: remote processor 55020000.ipu is now up [19:18:48:106][ 11.270866] virtio_rpmsg_bus virtio0: rpmsg host is online [19:18:48:106][ 11.277492] remoteproc3: powering up 41000000.dsp [19:18:48:107][ 11.287390] remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5600464 [19:18:48:107][ 11.300953] omap_hwmod: mmu0_dsp2: _wait_target_disable failed [19:18:48:108][ 11.306830] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0 [19:18:48:116][ 11.312739] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0 [19:18:48:168][ 11.331756] remoteproc3: remote processor 41000000.dsp is now up [19:18:48:169][ 11.338633] virtio_rpmsg_bus virtio1: rpmsg host is online [19:18:48:169][ 11.345280] remoteproc2: powering up 40800000.dsp [19:18:48:169][ 11.350127] random: nonblocking pool is initialized [19:18:48:169][ 11.354833] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5600464 [19:18:48:170][ 11.361386] omap_hwmod: mmu0_dsp1: _wait_target_disable failed [19:18:48:186][ 11.361408] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0 [19:18:48:187][ 11.361434] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0 [19:18:48:225][ 11.397692] remoteproc2: remote processor 40800000.dsp is now up [19:18:48:225][ 11.404797] virtio_rpmsg_bus virtio2: rpmsg host is online [19:18:48:227][ 11.411078] remoteproc0: powering up 58820000.ipu [19:18:48:241][ 11.425456] remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 10829984 [19:18:48:242][ 11.432706] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1 [19:18:48:313][ 11.459537] omap_rproc_request_timer: request for timer node ef676e4c failed [19:18:48:313][ 11.466663] omap-rproc 58820000.ipu: request for timer ef676e4c failed: -16 [19:18:48:313][ 11.473890] omap-rproc 58820000.ipu: omap_rproc_enable_timers failed: -16 [19:18:48:313][ 11.480763] remoteproc0: can't start rproc 58820000.ipu: -16 [19:18:48:313][ 11.488215] remoteproc0: failed to unmap 16777216/0 [19:18:48:313][ 11.493397] remoteproc0: failed to unmap 16777216/0 [19:18:48:313][ 11.498419] remoteproc0: failed to unmap 16777216/0 [19:18:48:313][ 11.504375] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] [19:18:48:315][ 11.518293] remoteproc0: rproc_boot() failed -16 [19:18:48:325][ 11.523040] virtio_rpmsg_bus: probe of virtio3 failed with error -16 [19:18:48:521] Starting Network Service... [19:18:48:554][ OK ] Started rc.pvr.service. [19:18:48:586][ OK ] Started Save/Restore Sound Card State. [19:18:48:622][ 11.813231] net eth1: initializing cpsw version 1.15 (0) [19:18:48:624][ 11.819277] net eth0: initialized cpsw ale version 1.4 [19:18:48:640][ 11.826013] net eth0: ALE Table size 1024 [19:18:48:641][ OK ] Started Permit User Sessions. [19:18:48:654][ OK ] Started Network Service. [19:18:48:669][ 11.881859] net eth1: phy found : id is : 0x2000a231 [19:18:48:692][ 11.897810] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [19:18:48:708][ 11.915271] net eth0: initializing cpsw version 1.15 (0) [19:18:48:789][ 11.982218] net eth0: phy found : id is : 0x2000a231 [19:18:48:790][ 11.991896] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [19:18:49:054][ OK ] Reached target Network. [19:18:49:099][ 12.297923] usbcore: registered new interface driver usbfs [19:18:49:100][ 12.304034] usbcore: registered new interface driver hub [19:18:49:109][ 12.309682] usbcore: registered new device driver usb [19:18:49:119] Starting Network Name Resolution... [19:18:49:131][ OK ] Started Getty on tty1. [19:18:49:147][ OK ] Started Serial Getty on ttyS0. [19:18:49:179] Starting weston.service... [19:18:49:194][ OK ] Started Login Service. [19:18:49:401][ 12.493480] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [19:18:49:401][ 12.499755] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [19:18:49:401][ OK ] Started Network Name Resolution. [19:18:49:401][ 12.508573] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010 [19:18:49:401][ 12.523305] xhci-hcd xhci-hcd.2.auto: irq 495, io mem 0x488d0000 [19:18:49:401][ 12.530198] hub 1-0:.0: USB hub found [19:18:49:402][ 12.534332] hub 1-0:1.0: 1 port detected [19:18:49:402][ 12.539745] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [19:18:49:402][ 12.545417] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [19:18:49:402][ 12.545517] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [19:18:49:402][ 12.546183] hub 2-0:1.0: USB hub found [19:18:49:402][ 12.546212] hub 2-0:1.0: 1 port detected [19:18:49:402][ 12.547836] dwc3 48890000.usb: otg: primary host xhci-hcd.3.auto registered [19:18:49:404][ 12.547842] dwc3 48890000.usb: otg: shared host xhci-hcd.3.auto registered [19:18:49:417][ 12.547846] dwc3 48890000.usb: otg: can't start till gadget registers [19:18:49:420][ OK ] Started weston.service. [19:18:49:433] Starting telnetd.service... [19:18:49:466] Starting tiipclad-daemon.service... [19:18:49:481][ OK ] Started telnetd.service. [19:18:49:529][ OK ] Started tiipclad-daemon.service. [19:18:49:647][ 12.853287] usb 1-1: new high-speed USB device number 2 using xhci-hcd [19:18:49:825][ 13.025664] hub 1-1:1.0: USB hub found [19:18:49:827][ 13.029473] hub 1-1:1.0: 2 ports detected [19:18:55:175] [19:18:55:235] _____ _____ _ _ [19:18:55:235]| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ [19:18:55:235]| | _| .'| . | . | | __| _| . | | | -_| _| _| [19:18:55:235]|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| [19:18:55:235] |___| |___| [19:18:55:237] [19:18:55:249]Arago Project http://arago-project.org dra7xx-evm ttyS0 [19:18:55:250] [19:18:55:250]Arago 2016.12 dra7xx-evm ttyS0 [19:18:55:252] [19:19:33:091]dra7xx-evm login: root [19:19:35:713]Password: [19:19:37:893] [19:19:37:894]Login incorrect [19:19:41:404]dra7xx-evm login: root [19:19:44:824]root@dra7xx-evm:~# dmesg [19:19:45:184][ 0.000000] Booting Linux on physical CPU 0x0 [19:19:45:184][ 0.000000] Initializing cgroup subsys cpuset [19:19:45:185][ 0.000000] Initializing cgroup subsys cpu [19:19:45:185][ 0.000000] Initializing cgroup subsys cpuacct [19:19:45:185][ 0.000000] Linux version 4.4.84-00034-gaa42c96 (root@ubuntu1604) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #20 SMP PREEMPT Wed Nov 3 18:45:40 CST 2021 [19:19:45:185][ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [19:19:45:185][ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [19:19:45:185][ 0.000000] Machine model: TI DRA762 EVM [19:19:45:185][ 0.000000] Reserved memory: OVERLAP DETECTED! [19:19:45:185][ 0.000000] vsdk_sr1_mem@84000000 (0x0000000084000000--0x0000000097000000) overlaps with cmem@95400000 (0x0000000095400000--0x0000000095800000) [19:19:45:185][ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB [19:19:45:186][ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool [19:19:45:186][ 0.000000] Reserved memory: regions without no-map are not yet supported [19:19:45:186][ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB [19:19:45:186][ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool [19:19:45:186][ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB [19:19:45:186][ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool [19:19:45:186][ 0.000000] Reserved memory: regions without no-map are not yet supported [19:19:45:186][ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB [19:19:45:186][ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool [19:19:45:187][ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB [19:19:45:187][ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool [19:19:45:187][ 0.000000] Reserved memory: regions without no-map are not yet supported [19:19:45:187][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 32 MiB [19:19:45:187][ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool [19:19:45:187][ 0.000000] cma: Reserved 64 MiB at 0x00000000bb800000 [19:19:45:187][ 0.000000] Forcing write-allocate cache policy for SMP [19:19:45:187][ 0.000000] Memory policy: Data cache writealloc [19:19:45:187][ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier [19:19:45:187][ 0.000000] On node 0 totalpages: 251904 [19:19:45:187][ 0.000000] free_area_init_node: node 0, pgdat c097b640, node_mem_map ef69a000 [19:19:45:187][ 0.000000] DMA zone: 1728 pages used for memmap [19:19:45:188][ 0.000000] DMA zone: 0 pages reserved [19:19:45:188][ 0.000000] DMA zone: 187392 pages, LIFO batch:31 [19:19:45:188][ 0.000000] HighMem zone: 64512 pages, LIFO batch:15 [19:19:45:188][ 0.000000] DRA762 ES1.0 [19:19:45:188][ 0.000000] PERCPU: Embedded 11 pages/cpu @ef629000 s14912 r8192 d21952 u45056 [19:19:45:188][ 0.000000] pcpu-alloc: s14912 r8192 d21952 u45056 alloc=11*4096 [19:19:45:188][ 0.000000] pcpu-alloc: [0] 0 [0] 1 [19:19:45:188][ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 250176 [19:19:45:188][ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=50ea9e20-02 rw rootwait ip=none mem=1024M cma=64M [19:19:45:188][ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [19:19:45:189][ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [19:19:45:189][ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [19:19:45:189][ 0.000000] Memory: 352196K/1007616K available (6635K kernel code, 320K rwdata, 2392K rodata, 336K init, 290K bss, 409660K reserved, 245760K cma-reserved, 192512K highmem) [19:19:45:189][ 0.000000] Virtual kernel memory layout: [19:19:45:189][ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [19:19:45:189][ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [19:19:45:189][ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [19:19:45:189][ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [19:19:45:190][ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [19:19:45:530][ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [19:19:45:530][ 0.000000] .text : 0xc0008000 - 0xc08d902c (9029 kB) [19:19:45:530][ 0.000000] .init : 0xc08da000 - 0xc092e000 ( 336 kB) [19:19:45:530][ 0.000000] .data : 0xc092e000 - 0xc097e120 ( 321 kB) [19:19:45:530][ 0.000000] .bss : 0xc0980000 - 0xc09c8800 ( 290 kB) [19:19:45:531][ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [19:19:45:531][ 0.000000] Preemptible hierarchical RCU implementation. [19:19:45:531][ 0.000000] Build-time adjustment of leaf fanout to 32. [19:19:45:531][ 0.000000] NR_IRQS:16 nr_irqs:16 16 [19:19:45:531][ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div [19:19:45:531][ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [19:19:45:531][ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys). [19:19:45:531][ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [19:19:45:531][ 0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [19:19:45:531][ 0.000015] Switching to timer-based delay loop, resolution 162ns [19:19:45:531][ 0.000331] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [19:19:45:532][ 0.000339] OMAP clocksource: 32k_counter at 32768 Hz [19:19:45:532][ 0.000798] Console: colour dummy device 80x30 [19:19:45:532][ 0.000814] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [19:19:45:532][ 0.000820] This ensures that you still see kernel messages. Please [19:19:45:532][ 0.000825] update your kernel commandline. [19:19:45:532][ 0.000838] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [19:19:45:532][ 0.000851] pid_max: default: 32768 minimum: 301 [19:19:45:532][ 0.000948] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [19:19:45:533][ 0.000958] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [19:19:45:533][ 0.001491] Initializing cgroup subsys io [19:19:45:533][ 0.001508] Initializing cgroup subsys memory [19:19:45:533][ 0.001532] Initializing cgroup subsys devices [19:19:45:533][ 0.001545] Initializing cgroup subsys freezer [19:19:45:533][ 0.001556] Initializing cgroup subsys perf_event [19:19:45:533][ 0.001567] Initializing cgroup subsys pids [19:19:45:533][ 0.001593] CPU: Testing write buffer coherency: ok [19:19:45:533][ 0.001789] /cpus/cpu@0 missing clock-frequency property [19:19:45:533][ 0.001804] /cpus/cpu@1 missing clock-frequency property [19:19:45:534][ 0.001814] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [19:19:45:534][ 0.001850] Setting up static identity map for 0x80008380 - 0x800083e0 [19:19:45:534][ 0.080044] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [19:19:45:534][ 0.080113] Brought up 2 CPUs [19:19:45:534][ 0.080126] SMP: Total of 2 processors activated (24.59 BogoMIPS). [19:19:45:534][ 0.080132] CPU: All CPU(s) started in HYP mode. [19:19:45:534][ 0.080137] CPU: Virtualization extensions available. [19:19:45:534][ 0.080515] devtmpfs: initialized [19:19:45:534][ 0.109877] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [19:19:45:535][ 0.110841] omap_hwmod: l3_main_2 using broken dt data from ocp [19:19:45:535][ 0.226070] omap_hwmod: dcan1: _wait_target_disable failed [19:19:45:535][ 0.323602] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [19:19:45:535][ 0.323625] futex hash table entries: 512 (order: 3, 32768 bytes) [19:19:45:535][ 0.328542] pinctrl core: initialized pinctrl subsystem [19:19:45:535][ 0.329413] NET: Registered protocol family 16 [19:19:45:536][ 0.330373] DMA: preallocated 256 KiB pool for atomic coherent allocations [19:19:45:536][ 0.360229] cpuidle: using governor ladder [19:19:45:536][ 0.390250] cpuidle: using governor menu [19:19:45:536][ 0.398826] OMAP GPIO hardware version 0.1 [19:19:45:536][ 0.402955] GPIO line 161 (radio_rst) hogged as output/low [19:19:45:536][ 0.405339] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 ! [19:19:45:536][ 0.429691] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [19:19:45:536][ 0.429701] hw-breakpoint: maximum watchpoint size is 8 bytes. [19:19:45:536][ 0.430179] omap4_sram_init:Unable to allocate sram needed to handle errata I688 [19:19:45:537][ 0.430189] omap4_sram_init:Unable to get sram pool needed to handle errata I688 [19:19:45:876][ 0.430788] OMAP DMA hardware revision 0.0 [19:19:45:876][ 0.471497] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [19:19:45:877][ 0.472663] edma 43300000.edma: memcpy is disabled [19:19:45:877][ 0.477396] edma 43300000.edma: TI EDMA DMA engine driver [19:19:45:877][ 0.482285] omap-iommu 40d01000.mmu: 40d01000.mmu registered [19:19:45:877][ 0.482462] omap-iommu 40d02000.mmu: 40d02000.mmu registered [19:19:45:877][ 0.482632] omap-iommu 58882000.mmu: 58882000.mmu registered [19:19:45:877][ 0.482796] omap-iommu 55082000.mmu: 55082000.mmu registered [19:19:45:877][ 0.483079] omap-iommu 41501000.mmu: 41501000.mmu registered [19:19:45:877][ 0.483263] omap-iommu 41502000.mmu: 41502000.mmu registered [19:19:45:878][ 0.486295] palmas 0-0058: IRQ missing: skipping irq request [19:19:45:878][ 0.500716] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2 [19:19:45:878][ 0.551252] irq: no irq domain found for /ocp/i2c@48070000/tps65917@58 ! [19:19:45:878][ 0.552167] pcf857x 0-0020: probed [19:19:45:878][ 0.552735] pcf857x 0-0021: probed [19:19:45:878][ 0.553120] GPIO line 465 (vin6_sel_s0) hogged as output/low [19:19:45:878][ 0.553247] GPIO line 466 (vin2_s0) hogged as output/low [19:19:45:878][ 0.553373] GPIO line 471 (vin2_s2) hogged as output/high [19:19:45:878][ 0.553499] GPIO line 473 (exvin2_s0) hogged as output/low [19:19:45:878][ 0.553625] GPIO line 474 (exvin2_s2) hogged as output/high [19:19:45:879][ 0.553720] pcf857x 0-0026: probed [19:19:45:879][ 0.553866] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [19:19:45:879][ 0.554261] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz [19:19:45:879][ 0.570572] pcf857x: probe of 3-0021 failed with error -121 [19:19:45:879][ 0.570609] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz [19:19:45:879][ 0.570810] media: Linux media interface: v0.10 [19:19:45:879][ 0.570860] Linux video capture interface: v2.00 [19:19:45:879][ 0.570899] pps_core: LinuxPPS API ver. 1 registered [19:19:45:879][ 0.570905] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [19:19:45:880][ 0.570928] PTP clock support registered [19:19:45:880][ 0.570972] EDAC MC: Ver: 3.0.0 [19:19:45:880][ 0.571729] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [19:19:45:880][ 0.572024] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [19:19:45:880][ 0.572379] Advanced Linux Sound Architecture Driver Initialized. [19:19:45:880][ 0.573246] clocksource: Switched to clocksource arch_sys_counter [19:19:45:880][ 0.583598] NET: Registered protocol family 2 [19:19:45:880][ 0.584094] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [19:19:45:880][ 0.584157] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [19:19:45:880][ 0.584282] TCP: Hash tables configured (established 8192 bind 8192) [19:19:45:880][ 0.584326] UDP hash table entries: 512 (order: 2, 16384 bytes) [19:19:45:880][ 0.584357] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [19:19:45:880][ 0.584560] NET: Registered protocol family 1 [19:19:45:880][ 0.584820] RPC: Registered named UNIX socket transport module. [19:19:45:880][ 0.584829] RPC: Registered udp transport module. [19:19:45:880][ 0.584835] RPC: Registered tcp transport module. [19:19:45:880][ 0.584842] RPC: Registered tcp NFSv4.1 backchannel transport module. [19:19:45:880][ 0.584857] PCI: CLS 0 bytes, default 64 [19:19:45:880][ 0.585828] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [19:19:45:881][ 0.595877] squashfs: version 4.0 (2009/01/31) Phillip Lougher [19:19:45:881][ 0.596538] NFS: Registering the id_resolver key type [19:19:45:881][ 0.596566] Key type id_resolver registered [19:19:45:881][ 0.596573] Key type id_legacy registered [19:19:45:881][ 0.596643] ntfs: driver 2.1.32 [Flags: R/O]. [19:19:45:881][ 0.597959] bounce: pool size: 64 pages [19:19:45:881][ 0.598113] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [19:19:45:881][ 0.598131] io scheduler noop registered [19:19:45:881][ 0.598145] io scheduler deadline registered [19:19:45:881][ 0.598181] io scheduler cfq registered (default) [19:19:45:881][ 0.600558] vsys_5v0: supplied by vsys_12v0 [19:19:45:882][ 0.600607] ldo3: supplied by vsys_5v0 [19:19:45:882][ 0.604354] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128 [19:19:45:882][ 0.607628] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges: [19:19:45:882][ 0.607640] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff] [19:19:45:886][ 0.607672] IO 0x20003000..0x20012fff -> 0x00000000 [19:19:46:221][ 0.607693] MEM 0x20013000..0x2fffffff -> 0x20013000 [19:19:46:221][ 0.637790] dra7-pcie 51000000.pcie_rc: link is not up [19:19:46:221][ 0.637951] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00 [19:19:46:221][ 0.637964] pci_bus 0000:00: root bus resource [bus 00-ff] [19:19:46:221][ 0.637974] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [19:19:46:222][ 0.637983] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff] [19:19:46:222][ 0.638015] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400 [19:19:46:222][ 0.638058] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff] [19:19:46:222][ 0.638080] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff] [19:19:46:222][ 0.638148] pci 0000:00:00.0: supports D1 [19:19:46:222][ 0.638157] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [19:19:46:222][ 0.638384] PCI: bus0: Fast back to back transfers disabled [19:19:46:223][ 0.638499] PCI: bus1: Fast back to back transfers enabled [19:19:46:223][ 0.638581] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff] [19:19:46:223][ 0.638596] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff] [19:19:46:223][ 0.638608] pci 0000:00:00.0: PCI bridge to [bus 01] [19:19:46:223][ 0.638834] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [19:19:46:223][ 0.638847] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded [19:19:46:223][ 0.638969] aer 0000:00:00.0:pcie02: service driver aer loaded [19:19:46:223][ 0.699301] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [19:19:46:223][ 0.702702] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250 [19:19:46:223][ 1.786589] console [ttyS0] enabled [19:19:46:224][ 1.790978] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250 [19:19:46:224][ 1.800673] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250 [19:19:46:224][ 1.810729] [drm] Initialized drm 1.1.0 20060810 [19:19:46:224][ 1.816263] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [19:19:46:224][ 1.822906] [drm] No driver support for vblank timestamp query. [19:19:46:224][ 1.829070] [drm] Initialized vdrm 1.0.0 20110917 on minor 0 [19:19:46:224][ 1.842051] loop: module loaded [19:19:46:225][ 1.848066] vmemexp device MAJOR num = 245 [19:19:46:225][ 1.852194] vmemexp class registered [19:19:46:225][ 1.855932] /dev/vmemexp device registered [19:19:46:225][ 1.860047] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120 [19:19:46:225][ 1.868450] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes) [19:19:46:225][ 1.873867] 7 ofpart partitions found on MTD device spi32766.0 [19:19:46:225][ 1.879726] Creating 7 MTD partitions on "spi32766.0": [19:19:46:225][ 1.884905] 0x000000000000-0x000000040000 : "QSPI.SPL" [19:19:46:225][ 1.891022] 0x000000040000-0x000000140000 : "QSPI.u-boot" [19:19:46:225][ 1.897374] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os" [19:19:46:225][ 1.904338] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env" [19:19:46:225][ 1.911025] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1" [19:19:46:226][ 1.918434] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel" [19:19:46:226][ 1.924789] 0x0000009e0000-0x000002000000 : "QSPI.file-system" [19:19:46:226][ 1.932547] libphy: Fixed MDIO Bus: probed [19:19:46:226][ 1.983279] davinci_mdio 48485000.mdio: davinci mdio revision 1.6 [19:19:46:226][ 1.989401] libphy: 48485000.mdio: probed [19:19:46:226][ 1.997500] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver TI DP83867 [19:19:46:226][ 2.005846] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver TI DP83867 [19:19:46:226][ 2.014808] cpsw 48484000.ethernet: Detected MACID = 0c:b2:b7:90:b4:fa [19:19:46:226][ 2.021450] cpsw 48484000.ethernet: cpts: overflow check period 800 [19:19:46:227][ 2.028458] cpsw 48484000.ethernet: cpsw: Detected MACID = 0c:b2:b7:90:b4:fb [19:19:46:227][ 2.037229] mousedev: PS/2 mouse device common for all mice [19:19:46:227][ 2.053485] i2c /dev entries driver [19:19:46:227][ 2.062286] omap_hsmmc 4809c000.mmc: Got CD GPIO [19:19:46:227][ 2.067175] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode [19:19:46:227][ 2.073686] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode [19:19:46:227][ 2.080071] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode [19:19:46:227][ 2.086472] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode [19:19:46:229][ 2.092854] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode [19:19:46:568][ 2.099956] vsys_3v3: supplied by vsys_12v0 [19:19:46:569][ 2.104217] vio_3v3: supplied by vsys_3v3 [19:19:46:569][ 2.108286] vio_3v3_sd: supplied by vio_3v3 [19:19:46:569][ 2.112619] ldo4: supplied by vsys_5v0 [19:19:46:569][ 2.163688] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode [19:19:46:569][ 2.170074] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode [19:19:46:569][ 2.193415] smps5: supplied by vsys_3v3 [19:19:46:569][ 2.197470] vio_1v8: supplied by smps5 [19:19:46:569][ 2.254993] ledtrig-cpu: registered to indicate activity on CPUs [19:19:46:569][ 2.266605] hwspinlock_user gatemp: requested 20 hwspinlocks [19:19:46:569][ 2.273559] aic_dvdd: supplied by vio_3v3 [19:19:46:569][ 2.278822] davinci-mcasp 48464000.mcasp: DAI is shared [19:19:46:569][ 2.284931] davinci-mcasp 48474000.mcasp: DAI is shared [19:19:46:570][ 2.291434] NET: Registered protocol family 10 [19:19:46:570][ 2.306774] sit: IPv6 over IPv4 tunneling driver [19:19:46:570][ 2.311943] NET: Registered protocol family 17 [19:19:46:570][ 2.316651] Key type dns_resolver registered [19:19:46:570][ 2.321063] omap_voltage_late_init: Voltage driver support not added [19:19:46:570][ 2.327950] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [19:19:46:570][ 2.334174] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [19:19:46:570][ 2.340457] buck10: supplied by vsys_3v3 [19:19:46:570][ 2.345068] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [19:19:46:570][ 2.351278] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [19:19:46:570][ 2.359486] Power Management for TI OMAP4+ devices. [19:19:46:570][ 2.364536] Registering SWP/SWPB emulation handler [19:19:46:570][ 2.370111] dmm 4e000000.dmm: workaround for errata i878 in use [19:19:46:571][ 2.377185] dmm 4e000000.dmm: initialized all PAT entries [19:19:46:571][ 2.383183] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1 [19:19:46:571][ 2.390201] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok [19:19:46:571][ 2.399752] input: gpio_keys as /devices/platform/gpio_keys/input/input0 [19:19:46:571][ 2.406633] hctosys: unable to open rtc device (rtc0) [19:19:46:571][ 2.418738] aic_dvdd: disabling [19:19:46:571][ 2.422023] ALSA device list: [19:19:46:571][ 2.425011] #0: DRA7xx-EVM [19:19:46:571][ 2.428453] Waiting for root device PARTUUID=50ea9e20-02... [19:19:46:571][ 2.510187] mmc0: host does not support reading read-only switch, assuming write-enable [19:19:46:571][ 2.519989] mmc0: Problem switching card into high-speed mode! [19:19:46:572][ 2.525900] mmc0: new SDHC card at address 0001 [19:19:46:572][ 2.530723] mmcblk0: mmc0:0001 SD16G 14.6 GiB [19:19:46:572][ 2.536405] mmcblk0: p1 p2 [19:19:46:572][ 2.543914] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities [19:19:46:572][ 2.552675] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities [19:19:46:572][ 2.576996] mmc1: MAN_BKOPS_EN bit is not set [19:19:46:572][ 2.582466] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [19:19:46:572][ 2.588393] mmc1: new HS200 MMC card at address 0001 [19:19:46:572][ 2.593368] mmcblk1: mmc1:0001 MMC08G 7.25 GiB [19:19:46:572][ 2.600165] VFS: Mounted root (ext4 filesystem) on device 179:2. [19:19:46:572][ 2.603541] mmcblk1boot0: mmc1:0001 MMC08G partition 1 8.00 MiB [19:19:46:572][ 2.603700] mmcblk1boot1: mmc1:0001 MMC08G partition 2 8.00 MiB [19:19:46:572][ 2.620459] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 [19:19:46:572][ 2.628313] devtmpfs: mounted [19:19:46:572][ 2.631463] Freeing unused kernel memory: 336K [19:19:46:572][ 2.635955] This architecture does not have kernel memory protection. [19:19:46:572][ 3.087200] systemd[1]: System time before build time, advancing clock. [19:19:46:572][ 3.144627] random: systemd: uninitialized urandom read (16 bytes read, 14 bits of entropy available) [19:19:46:572][ 3.158139] random: systemd: uninitialized urandom read (16 bytes read, 14 bits of entropy available) [19:19:46:573][ 3.169877] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN) [19:19:46:573][ 3.188416] systemd[1]: Detected architecture arm. [19:19:46:573][ 3.214753] systemd[1]: Set hostname to <dra7xx-evm>. [19:19:46:573][ 3.222650] random: systemd: uninitialized urandom read (16 bytes read, 15 bits of entropy available) [19:19:46:577][ 3.231984] systemd[1]: Initializing machine ID from random generator. [19:19:46:914][ 3.299517] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 15 bits of entropy available) [19:19:46:914][ 3.321997] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 15 bits of entropy available) [19:19:46:914][ 3.332195] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 15 bits of entropy available) [19:19:46:915][ 3.379496] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available) [19:19:46:915][ 3.392769] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available) [19:19:46:915][ 3.543270] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available) [19:19:46:915][ 3.552744] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available) [19:19:46:915][ 4.215810] systemd[1]: basic.target: Found ordering cycle on basic.target/start [19:19:46:915][ 4.223266] systemd[1]: basic.target: Found dependency on sysinit.target/start [19:19:46:915][ 4.230526] systemd[1]: basic.target: Found dependency on alignment.service/start [19:19:46:916][ 4.238081] systemd[1]: basic.target: Found dependency on basic.target/start [19:19:46:916][ 4.245181] systemd[1]: basic.target: Breaking ordering cycle by deleting job alignment.service/start [19:19:46:916][ 4.254480] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with basic.target/start [19:19:46:916][ 4.285454] systemd[1]: Listening on Journal Socket. [19:19:46:916][ 4.303554] systemd[1]: Listening on Syslog Socket. [19:19:46:916][ 4.323505] systemd[1]: Listening on udev Kernel Socket. [19:19:46:916][ 4.354762] systemd[1]: Created slice User and Session Slice. [19:19:46:916][ 4.383624] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [19:19:46:916][ 4.413977] systemd[1]: Created slice System Slice. [19:19:46:916][ 4.473480] systemd[1]: Mounting Temporary Directory... [19:19:46:917][ 4.505459] systemd[1]: Starting Setup Virtual Console... [19:19:46:917][ 4.534334] systemd[1]: Created slice system-getty.slice. [19:19:46:917][ 4.563605] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [19:19:46:917][ 4.593539] systemd[1]: Listening on udev Control Socket. [19:19:46:917][ 4.653640] systemd[1]: Starting Create list of required static device nodes for the current kernel... [19:19:46:917][ 4.683680] systemd[1]: Listening on Network Service Netlink Socket. [19:19:46:917][ 4.714106] systemd[1]: Created slice system-serial\x2dgetty.slice. [19:19:46:917][ 4.743452] systemd[1]: Reached target Swap. [19:19:46:917][ 4.793436] systemd[1]: Mounting Debug File System... [19:19:46:917][ 4.828665] systemd[1]: Reached target Remote File Systems. [19:19:46:917][ 4.893598] systemd[1]: Starting Load Kernel Modules... [19:19:46:918][ 4.915521] systemd[1]: Mounting POSIX Message Queue File System... [19:19:46:918][ 4.943611] systemd[1]: Listening on Journal Socket (/dev/log). [19:19:46:918][ 5.013655] systemd[1]: Starting Journal Service... [19:19:46:918][ 5.043483] systemd[1]: Reached target Slices. [19:19:46:918][ 5.065483] systemd[1]: Starting Remount Root and Kernel File Systems... [19:19:46:918][ 5.094445] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [19:19:46:918][ 5.103718] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [19:19:46:918][ 5.143482] systemd[1]: Reached target Paths. [19:19:46:918][ 5.201697] systemd[1]: Mounted Debug File System. [19:19:46:918][ 5.223526] systemd[1]: Mounted POSIX Message Queue File System. [19:19:46:918][ 5.253487] systemd[1]: Mounted Temporary Directory. [19:19:46:919][ 5.273653] systemd[1]: Started Journal Service. [19:19:46:919][ 5.914755] systemd-journald[145]: Received request to flush runtime journal from PID 1 [19:19:46:919][ 6.245407] CAN device driver interface [19:19:46:919][ 6.299464] m_can 42c01a00.mcan: hclk could not be found [19:19:46:919][ 6.309179] m_can 42c01a00.mcan: m_can device registered (irq=361, version=32) [19:19:46:919][ 6.434332] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000 [19:19:46:919][ 6.442145] remoteproc0: 58820000.ipu is available [19:19:46:919][ 6.465899] remoteproc0: Note: remoteproc is still under development and considered experimental. [19:19:46:920][ 6.478980] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [19:19:47:261][ 6.502045] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000 [19:19:47:261][ 6.522726] remoteproc1: 55020000.ipu is available [19:19:47:261][ 6.530236] remoteproc1: Note: remoteproc is still under development and considered experimental. [19:19:47:261][ 6.552252] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [19:19:47:261][ 6.575630] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000 [19:19:47:261][ 6.586980] remoteproc2: 40800000.dsp is available [19:19:47:262][ 6.595787] remoteproc2: Note: remoteproc is still under development and considered experimental. [19:19:47:262][ 6.611019] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [19:19:47:262][ 6.633469] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20 [19:19:47:262][ 6.641599] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000 [19:19:47:262][ 6.650051] remoteproc3: 41000000.dsp is available [19:19:47:262][ 6.659827] remoteproc3: Note: remoteproc is still under development and considered experimental. [19:19:47:262][ 6.669475] remoteproc1: registered virtio0 (type 7) [19:19:47:262][ 6.677069] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [19:19:47:262][ 6.698429] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2 [19:19:47:262][ 7.983492] remoteproc3: registered virtio1 (type 7) [19:19:47:262][ 8.404605] remoteproc2: registered virtio2 (type 7) [19:19:47:262][ 8.527495] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3 [19:19:47:263][ 8.535525] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3 [19:19:47:263][ 8.753808] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3 [19:19:47:263][ 9.338118] remoteproc0: registered virtio3 (type 7) [19:19:47:263][ 9.651671] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2 [19:19:47:263][ 9.840539] SCSI subsystem initialized [19:19:47:263][ 10.055662] libata version 3.00 loaded. [19:19:47:263][ 10.195440] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled [19:19:47:263][ 10.207485] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode [19:19:47:263][ 10.267905] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst [19:19:47:263][ 10.342706] EXT4-fs (mmcblk1p12): recovery complete [19:19:47:263][ 10.348424] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: (null) [19:19:47:263][ 10.355620] EXT4-fs (mmcblk1p10): recovery complete [19:19:47:263][ 10.355629] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: (null) [19:19:47:263][ 10.404034] scsi host0: ahci [19:19:47:263][ 10.407164] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 341 [19:19:47:263][ 10.803289] ata1: SATA link down (SStatus 0 SControl 300) [19:19:47:263][ 11.233624] remoteproc1: powering up 55020000.ipu [19:19:47:263][ 11.238932] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 470392 [19:19:47:263][ 11.245883] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1 [19:19:47:263][ 11.264291] remoteproc1: remote processor 55020000.ipu is now up [19:19:47:263][ 11.270866] virtio_rpmsg_bus virtio0: rpmsg host is online [19:19:47:264][ 11.277492] remoteproc3: powering up 41000000.dsp [19:19:47:264][ 11.287390] remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5600464 [19:19:47:264][ 11.300953] omap_hwmod: mmu0_dsp2: _wait_target_disable failed [19:19:47:264][ 11.306830] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0 [19:19:47:264][ 11.312739] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0 [19:19:47:264][ 11.331756] remoteproc3: remote processor 41000000.dsp is now up [19:19:47:264][ 11.338633] virtio_rpmsg_bus virtio1: rpmsg host is online [19:19:47:264][ 11.345280] remoteproc2: powering up 40800000.dsp [19:19:47:265][ 11.350127] random: nonblocking pool is initialized [19:19:47:265][ 11.354833] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5600464 [19:19:47:265][ 11.361386] omap_hwmod: mmu0_dsp1: _wait_target_disable failed [19:19:47:265][ 11.361408] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0 [19:19:47:265][ 11.361434] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0 [19:19:47:265][ 11.397692] remoteproc2: remote processor 40800000.dsp is now up [19:19:47:265][ 11.404797] virtio_rpmsg_bus virtio2: rpmsg host is online [19:19:47:267][ 11.411078] remoteproc0: powering up 58820000.ipu [19:19:47:503][ 11.425456] remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 10829984 [19:19:47:503][ 11.432706] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1 [19:19:47:503][ 11.459537] omap_rproc_request_timer: request for timer node ef676e4c failed [19:19:47:503][ 11.466663] omap-rproc 58820000.ipu: request for timer ef676e4c failed: -16 [19:19:47:503][ 11.473890] omap-rproc 58820000.ipu: omap_rproc_enable_timers failed: -16 [19:19:47:503][ 11.480763] remoteproc0: can't start rproc 58820000.ipu: -16 [19:19:47:504][ 11.488215] remoteproc0: failed to unmap 16777216/0 [19:19:47:504][ 11.493397] remoteproc0: failed to unmap 16777216/0 [19:19:47:504][ 11.498419] remoteproc0: failed to unmap 16777216/0 [19:19:47:504][ 11.504375] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] [19:19:47:504][ 11.518293] remoteproc0: rproc_boot() failed -16 [19:19:47:504][ 11.523040] virtio_rpmsg_bus: probe of virtio3 failed with error -16 [19:19:47:504][ 11.813231] net eth1: initializing cpsw version 1.15 (0) [19:19:47:504][ 11.819277] net eth0: initialized cpsw ale version 1.4 [19:19:47:504][ 11.826013] net eth0: ALE Table size 1024 [19:19:47:504][ 11.881859] net eth1: phy found : id is : 0x2000a231 [19:19:47:505][ 11.897810] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [19:19:47:505][ 11.915271] net eth0: initializing cpsw version 1.15 (0) [19:19:47:505][ 11.982218] net eth0: phy found : id is : 0x2000a231 [19:19:47:505][ 11.991896] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [19:19:47:505][ 12.297923] usbcore: registered new interface driver usbfs [19:19:47:505][ 12.304034] usbcore: registered new interface driver hub [19:19:47:505][ 12.309682] usbcore: registered new device driver usb [19:19:47:505][ 12.493480] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [19:19:47:505][ 12.499755] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [19:19:47:505][ 12.508573] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010 [19:19:47:506][ 12.523305] xhci-hcd xhci-hcd.2.auto: irq 495, io mem 0x488d0000 [19:19:47:506][ 12.530198] hub 1-0:1.0: USB hub found [19:19:47:506][ 12.534332] hub 1-0:1.0: 1 port detected [19:19:47:506][ 12.539745] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [19:19:47:506][ 12.545417] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [19:19:47:506][ 12.545517] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [19:19:47:506][ 12.546183] hub 2-0:1.0: USB hub found [19:19:47:506][ 12.546212] hub 2-0:1.0: 1 port detected [19:19:47:506][ 12.547836] dwc3 48890000.usb: otg: primary host xhci-hcd.3.auto registered [19:19:47:506][ 12.547842] dwc3 48890000.usb: otg: shared host xhci-hcd.3.auto registered [19:19:47:506][ 12.547846] dwc3 48890000.usb: otg: can't start till gadget registers [19:19:47:508][ 12.853287] usb 1-1: new high-speed USB device number 2 using xhci-hcd [19:19:47:524][ 13.025664] hub 1-1:1.0: USB hub found [19:19:47:525][ 13.029473] hub 1-1:1.0: 2 ports detected [19:20:12:942]root@dra7xx-evm:~# cd /opt/vision_sdk/ [19:20:13:134]root@dra7xx-evm:/opt/vision_sdk# [19:20:13:310]root@dra7xx-evm:/opt/vision_sdk# [19:20:13:518]root@dra7xx-evm:/opt/vision_sdk# [19:20:13:710]root@dra7xx-evm:/opt/vision_sdk# [19:20:22:326]root@dra7xx-evm:/opt/vision_sdk# source ./vision_sdk_load.sh [19:20:22:404][ 105.592398] DMA: Module install successful, device major num = 242 [19:20:22:405][ 105.598926] DRV: Module install successful [19:20:22:413]insmod: ERROR: could not load module ./bin/cmemk.ko: No such file or directory [19:20:22:517]Error: I2C Read failed [19:20:22:540]Error: I2C Read failed [19:20:22:542]Error: I2C Read failed [19:20:22:731]./disableDssInterruptsOnA15.sh: line 11: COMMANDS: command not found [19:20:22:732]./disableDssInterruptsOnA15.sh: line 12: COMMANDS: command not found [19:20:22:732]./disableDssInterruptsOnA15.sh: line 13: COMMANDS: command not found [19:20:22:732]./disableDssInterruptsOnA15.sh: line 14: COMMANDS: command not found [19:20:22:732]./disableDssInterruptsOnA15.sh: line 15: COMMANDS: command not found [19:20:22:732]./disableDssInterruptsOnA15.sh: line 16: COMMANDS: command not found [19:20:22:732]./disableDssInterruptsOnA15.sh: line 17: COMMANDS: command not found [19:20:22:732]./disableDssInterruptsOnA15.sh: line 18: COMMANDS: command not found [19:20:22:732]./disableDssInterruptsOnA15.sh: line 19: COMMANDS: command not found [19:20:22:732]updated value is [19:20:22:732] [19:20:22:732] [19:20:22:733]COMMANDS [19:20:22:733] [19:20:22:733] ### WARNING ###: use the following [read | write | set bit | clear bit | dump] commands at your own risk! [19:20:22:733] No address check done, may generate: [19:20:22:733] - bus error (invalid or not accessible <physical address>, [19:20:22:733] - platform crash/hang (bad <value>). [19:20:22:733] [19:20:22:733] Read any OMAP memory address (register), given its <physical address> or <name> as listed in TRM. [19:20:22:733] [19:20:22:733] Write <value> at any OMAP memory address (register), given its <physical address> or <name> as listed in TRM. [19:20:22:733] [19:20:22:733] Set bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM. [19:20:22:733] [19:20:22:733] Clear bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM. [19:20:22:733] [19:20:22:734] Dump a range of OMAP memory addresses, from <start address> to <end address>. [19:20:22:734] Note all addresses within given range must be valid and accessible. [19:20:22:734] [19:20:22:734] ### WARNING ###: use the following I2C [read | write] commands at your own risk! [19:20:22:734] No address check done, may generate: [19:20:22:734] - I2C bus error (invalid or not accessible <physical address>, [19:20:22:734] - platform crash/hang (bad <value>). [19:20:22:734] [19:20:22:734] Read I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>. [19:20:22:736] [19:20:22:744] Write <value> in I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>. [19:20:26:701]root@dra7xx-evm:/opt/vision_sdk# ./apps.out [19:20:27:210] [HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb69bf000 of size 0x00100000 [19:20:27:210] [HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa3dbf000 of size 0x12c00000 [19:20:27:210] [HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa3cff000 of size 0x00040000 [19:20:27:211] [HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa3d3f000 of size 0x00080000 [19:20:27:211] [HOST] OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000 [19:20:27:211] [HOST] OSA: IPU1-0 Remote Log Shared Memory @ 0xa0200000 [19:20:27:211] [HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140 [19:20:27:211] [HOST] OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0 [19:20:27:211] [HOST] OSA: DSP2 Remote Log Shared Memory @ 0xa029e280 [19:20:27:211] [HOST] OSA: EVE1 Remote Log Shared Memory @ 0xa02c5b20 [19:20:27:211] [HOST] OSA: EVE2 Remote Log Shared Memory @ 0xa02ed3c0 [19:20:27:211] [HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0 [19:20:27:212] [HOST] [HOST ] 116.781065 s: SYSTEM: System A15 Init in progress !!! [19:20:27:212] [HOST] [DSP1 ] 18.083297 s: ***** DSP1 Firmware build time 18:59:39 Nov 3 2021 [19:20:27:212] [HOST] [DSP1 ] 18.083358 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 850000000 Hz> [19:20:27:212] [HOST] [DSP1 ] 18.083572 s: SYSTEM: System Common Init in progress !!! [19:20:27:212] [HOST] [DSP1 ] 18.083785 s: UTILS: CIO: Init Done !!! [19:20:27:212] [HOST] [DSP1 ] 18.083816 s: SYSTEM: IPC init in progress !!! [19:20:27:212] [HOST] [DSP1 ] 18.083816 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:212] [HOST] [DSP1 ] 19.083602 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:212] [HOST] [DSP1 ] 20.083633 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:212] [HOST] [DSP1 ] 21.083663 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 22.083663 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 23.083694 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 24.083724 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 25.083755 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 26.083785 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 27.083816 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 28.083846 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 29.083877 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 30.083907 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 31.083907 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 32.083938 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:213] [HOST] [DSP1 ] 33.083968 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 34.083999 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 35.084029 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 36.084060 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 37.084090 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 38.084121 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 39.084151 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 40.084151 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 41.084182 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:214] [HOST] [DSP1 ] 42.084212 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 43.084243 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 44.084273 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 45.084304 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 46.084334 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 47.084365 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 48.084365 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 49.084395 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 50.084426 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 51.084456 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 52.084487 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:215] [HOST] [DSP1 ] 53.084517 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:219] [HOST] [DSP1 ] 54.084548 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:557] [HOST] [DSP1 ] 55.084578 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:557] [HOST] [DSP1 ] 56.084609 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:557] [HOST] [DSP1 ] 57.084609 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:557] [HOST] [DSP1 ] 58.084639 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:557] [HOST] [DSP1 ] 59.084670 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:557] [HOST] [DSP1 ] 60.084700 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 61.084731 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 62.084761 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 63.084792 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 64.084822 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 65.084853 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 66.084853 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 67.084883 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 68.084914 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 69.084944 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 70.084975 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:558] [HOST] [DSP1 ] 71.085005 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:559] [HOST] [DSP1 ] 72.085036 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:559] [HOST] [DSP1 ] 73.085066 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:559] [HOST] [DSP1 ] 74.085097 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:559] [HOST] [DSP1 ] 75.085097 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:559] [HOST] [DSP1 ] 76.085127 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:559] [HOST] [DSP1 ] 77.085158 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:559] [HOST] [DSP1 ] 78.085188 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:559] [HOST] [DSP1 ] 79.085219 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 80.085249 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 81.085280 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 82.085310 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 83.085310 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 84.085341 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 85.085371 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 86.085402 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 87.085432 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 88.085463 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:560] [HOST] [DSP1 ] 89.085493 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 90.085524 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 91.085554 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 92.085554 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 93.085585 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 94.085615 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 95.085646 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 96.085676 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 97.085707 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 98.085737 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 99.085768 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:561] [HOST] [DSP1 ] 100.085798 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:562] [HOST] [DSP1 ] 101.085798 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:562] [HOST] [DSP1 ] 102.085829 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:562] [HOST] [DSP1 ] 103.085859 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:562] [HOST] [DSP1 ] 104.085890 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:562] [HOST] [DSP1 ] 105.085920 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:562] [HOST] [DSP1 ] 106.085951 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:562] [HOST] [DSP1 ] 107.085981 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:562] [HOST] [DSP1 ] 108.086012 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:564] [HOST] [DSP1 ] 109.086012 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:901] [HOST] [DSP1 ] 110.086042 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:902] [HOST] [DSP1 ] 111.086073 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:902] [HOST] [DSP1 ] 112.086103 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:902] [HOST] [DSP1 ] 113.086134 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:902] [HOST] [DSP1 ] 114.086164 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:902] [HOST] [DSP1 ] 115.086195 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:902] [HOST] [DSP1 ] 116.086225 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:902] [HOST] [DSP1 ] 117.086256 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:903] [HOST] [DSP2 ] 18.017293 s: ***** DSP2 Firmware build time 18:59:39 Nov 3 2021 [19:20:27:903] [HOST] [DSP2 ] 18.017385 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 850000000 Hz> [19:20:27:903] [HOST] [DSP2 ] 18.017598 s: SYSTEM: System Common Init in progress !!! [19:20:27:903] [HOST] [DSP2 ] 18.017812 s: UTILS: CIO: Init Done !!! [19:20:27:903] [HOST] [DSP2 ] 18.017842 s: SYSTEM: IPC init in progress !!! [19:20:27:903] [HOST] [DSP2 ] 18.017842 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:903] [HOST] [DSP2 ] 19.019581 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:903] [HOST] [DSP2 ] 20.019612 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:903] [HOST] [DSP2 ] 21.019642 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 22.019673 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 23.019703 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 24.019734 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 25.019764 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 26.019795 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 27.019825 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 28.019825 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 29.019856 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:904] [HOST] [DSP2 ] 30.019886 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 31.019917 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 32.019947 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 33.019978 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 34.020008 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 35.020039 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 36.020069 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 37.020069 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 38.020100 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 39.020130 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 40.020161 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:905] [HOST] [DSP2 ] 41.020191 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 42.020222 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 43.020252 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 44.020283 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 45.020283 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 46.020313 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 47.020344 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 48.020374 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 49.020405 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 50.020435 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 51.020466 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:906] [HOST] [DSP2 ] 52.020496 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:907] [HOST] [DSP2 ] 53.020527 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:907] [HOST] [DSP2 ] 54.020527 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:907] [HOST] [DSP2 ] 55.020557 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:907] [HOST] [DSP2 ] 56.020588 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:907] [HOST] [DSP2 ] 57.020618 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:907] [HOST] [DSP2 ] 58.020649 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:27:909] [HOST] [DSP2 ] 59.020679 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:249] [HOST] [DSP2 ] 60.020710 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:249] [HOST] [DSP2 ] 61.020740 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:249] [HOST] [DSP2 ] 62.020771 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:249] [HOST] [DSP2 ] 63.020771 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 64.020801 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 65.020832 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 66.020862 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 67.020893 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 68.020923 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 69.020954 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 70.020984 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 71.020984 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 72.021015 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 73.021045 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:250] [HOST] [DSP2 ] 74.021076 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:251] [HOST] [DSP2 ] 75.021106 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:251] [HOST] [DSP2 ] 76.021137 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:251] [HOST] [DSP2 ] 77.021167 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:251] [HOST] [DSP2 ] 78.021198 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:251] [HOST] [DSP2 ] 79.021228 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:251] [HOST] [DSP2 ] 80.021228 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:251] [HOST] [DSP2 ] 81.021259 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:251] [HOST] [DSP2 ] 82.021289 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 83.021320 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 84.021350 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 85.021381 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 86.021411 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 87.021442 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 88.021472 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 89.021472 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 90.021503 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 91.021533 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 92.021564 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:252] [HOST] [DSP2 ] 93.021594 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 94.021625 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 95.021655 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 96.021686 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 97.021716 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 98.021716 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 99.021747 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 100.021777 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 101.021808 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 102.021838 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:253] [HOST] [DSP2 ] 103.021869 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:254] [HOST] [DSP2 ] 104.021899 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:254] [HOST] [DSP2 ] 105.021930 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:254] [HOST] [DSP2 ] 106.021930 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:254] [HOST] [DSP2 ] 107.021960 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:254] [HOST] [DSP2 ] 108.021991 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:254] [HOST] [DSP2 ] 109.022021 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:254] [HOST] [DSP2 ] 110.022052 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:254] [HOST] [DSP2 ] 111.022082 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:255] [HOST] [DSP2 ] 112.022113 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:255] [HOST] [DSP2 ] 113.022143 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:256] [HOST] [DSP2 ] 114.022174 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:595] [HOST] [DSP2 ] 115.022174 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:595] [HOST] [DSP2 ] 116.022204 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:595] [HOST] [DSP2 ] 117.022235 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:595] [HOST] [IPU2 ] 17.954828 s: ***** IPU2 Firmware build time 19:01:24 Nov 3 2021 [19:20:28:595] [HOST] [IPU2 ] 17.955011 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [19:20:28:595] [HOST] [IPU2 ] 17.957573 s: SYSTEM: System Common Init in progress !!! [19:20:28:596] [HOST] [IPU2 ] 17.958579 s: UTILS: CIO: Init Done !!! [19:20:28:596] [HOST] [IPU2 ] 17.958671 s: SYSTEM: IPC init in progress !!! [19:20:28:596] [HOST] [IPU2 ] 17.958732 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:596] [HOST] [IPU2 ] 18.957969 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:596] [HOST] [IPU2 ] 19.958000 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:596] [HOST] [IPU2 ] 20.958000 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:596] [HOST] [IPU2 ] 21.958030 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:596] [HOST] [IPU2 ] 22.958061 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:596] [HOST] [IPU2 ] 23.958091 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:596] [HOST] [IPU2 ] 24.958122 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 25.958152 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 26.958183 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 27.958213 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 28.958244 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 29.958244 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 30.958274 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 31.958305 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 32.958335 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 33.958366 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 34.958396 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 35.958427 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 36.958457 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 37.958488 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:597] [HOST] [IPU2 ] 38.958488 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 39.958518 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 40.958549 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 41.958579 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 42.958610 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 43.958640 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 44.958671 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 45.958701 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 46.958701 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 47.958732 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 48.958762 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 49.958793 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 50.958823 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 51.958854 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:598] [HOST] [IPU2 ] 52.958884 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 53.958915 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 54.958945 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 55.958945 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 56.958976 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 57.959006 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 58.959037 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 59.959067 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 60.959098 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:599] [HOST] [IPU2 ] 61.959128 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:603] [HOST] [IPU2 ] 62.959159 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:941] [HOST] [IPU2 ] 63.959159 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:941] [HOST] [IPU2 ] 64.959189 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 65.959220 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 66.959250 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 67.959281 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 68.959311 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 69.959342 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 70.959372 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 71.959403 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 72.959403 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 73.959433 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:942] [HOST] [IPU2 ] 74.959464 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 75.959494 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 76.959525 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 77.959555 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 78.959586 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 79.959616 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 80.959647 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 81.959647 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 82.959677 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 83.959708 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 84.959738 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:943] [HOST] [IPU2 ] 85.959769 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 86.959799 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 87.959830 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 88.959860 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 89.959891 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 90.959891 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 91.959921 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 92.959952 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 93.959982 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:944] [HOST] [IPU2 ] 94.960013 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 95.960043 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 96.960074 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 97.960104 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 98.960104 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 99.960135 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 100.960165 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 101.960196 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 102.960226 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 103.960257 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 104.960287 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:945] [HOST] [IPU2 ] 105.960318 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 106.960348 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 107.960348 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 108.960379 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 109.960409 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 110.960440 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 111.960470 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 112.960501 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 113.960531 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:946] [HOST] [IPU2 ] 114.960562 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:947] [HOST] [IPU2 ] 115.960592 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:947] [HOST] [IPU2 ] 116.960592 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:948] [HOST] [IPU2 ] 117.960623 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:965] [HOST] [DSP1 ] 118.086256 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:28:974] [HOST] [DSP2 ] 118.022265 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:29:078] [HOST] [IPU2 ] 118.960653 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:29:139] [HOST] [DSP2 ] 119.022296 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:29:198] [HOST] [DSP1 ] 119.086286 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:30:071] [HOST] [IPU2 ] 119.960684 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:30:140] [HOST] [DSP2 ] 120.022326 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:30:201] [HOST] [DSP1 ] 120.086317 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:31:072] [HOST] [IPU2 ] 120.960714 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:31:133] [HOST] [DSP2 ] 121.022357 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:31:203] [HOST] [DSP1 ] 121.086347 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:32:076] [HOST] [IPU2 ] 121.960745 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:32:135] [HOST] [DSP2 ] 122.022387 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:32:196] [HOST] [DSP1 ] 122.086378 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:33:075] [HOST] [IPU2 ] 122.960775 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:33:137] [HOST] [DSP2 ] 123.022418 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:33:199] [HOST] [DSP1 ] 123.086408 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:34:070] [HOST] [IPU2 ] 123.960806 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:34:141] [HOST] [DSP2 ] 124.022418 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:34:200] [HOST] [DSP1 ] 124.086439 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:35:073] [HOST] [IPU2 ] 124.960836 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:35:132] [HOST] [DSP2 ] 125.022448 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:35:203] [HOST] [DSP1 ] 125.086469 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:36:075] [HOST] [IPU2 ] 125.960836 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:36:135] [HOST] [DSP2 ] 126.022479 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:36:196] [HOST] [DSP1 ] 126.086500 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:37:075] [HOST] [IPU2 ] 126.960867 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:37:138] [HOST] [DSP2 ] 127.022509 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:37:198] [HOST] [DSP1 ] 127.086500 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:38:070] [HOST] [IPU2 ] 127.960897 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:38:140] [HOST] [DSP2 ] 128.022540 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:38:200] [HOST] [DSP1 ] 128.086530 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:39:073] [HOST] [IPU2 ] 128.960928 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:39:133] [HOST] [DSP2 ] 129.022570 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:39:202] [HOST] [DSP1 ] 129.086561 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:40:075] [HOST] [IPU2 ] 129.960958 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:40:134] [HOST] [DSP2 ] 130.022601 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:40:206] [HOST] [DSP1 ] 130.086591 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:41:077] [HOST] [IPU2 ] 130.960989 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:41:139] [HOST] [DSP2 ] 131.022631 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:41:198] [HOST] [DSP1 ] 131.086622 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:42:070] [HOST] [IPU2 ] 131.961019 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:42:140] [HOST] [DSP2 ] 132.022631 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:42:201] [HOST] [DSP1 ] 132.086652 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:43:072] [HOST] [IPU2 ] 132.961050 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:43:133] [HOST] [DSP2 ] 133.022662 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:43:202] [HOST] [DSP1 ] 133.086683 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:44:075] [HOST] [IPU2 ] 133.961050 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:44:134] [HOST] [DSP2 ] 134.022692 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:44:205] [HOST] [DSP1 ] 134.086713 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:45:078] [HOST] [IPU2 ] 134.961080 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:45:138] [HOST] [DSP2 ] 135.022723 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:45:198] [HOST] [DSP1 ] 135.086744 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:46:078] [HOST] [IPU2 ] 135.961111 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:46:141] [HOST] [DSP2 ] 136.022753 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:46:199] [HOST] [DSP1 ] 136.086744 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:47:073] [HOST] [IPU2 ] 136.961141 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:47:133] [HOST] [DSP2 ] 137.022784 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:47:203] [HOST] [DSP1 ] 137.086774 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:48:075] [HOST] [IPU2 ] 137.961172 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:48:135] [HOST] [DSP2 ] 138.022814 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:48:205] [HOST] [DSP1 ] 138.086805 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:49:078] [HOST] [IPU2 ] 138.961202 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:49:137] [HOST] [DSP2 ] 139.022845 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:49:198] [HOST] [DSP1 ] 139.086835 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:50:077] [HOST] [IPU2 ] 139.961233 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:50:140] [HOST] [DSP2 ] 140.022875 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:50:201] [HOST] [DSP1 ] 140.086866 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:51:072] [HOST] [IPU2 ] 140.961263 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:51:132] [HOST] [DSP2 ] 141.022875 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:51:203] [HOST] [DSP1 ] 141.086896 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:52:075] [HOST] [IPU2 ] 141.961294 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:52:134] [HOST] [DSP2 ] 142.022906 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:52:205] [HOST] [DSP1 ] 142.086927 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:53:077] [HOST] [IPU2 ] 142.961294 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:53:137] [HOST] [DSP2 ] 143.022936 s: SYSTEM: Attaching to [IPU1-0] ... [19:20:54:079] [HOST] [DSP1 ] 143.086957 s: SYSTEM: Attaching to [IPU1-0] ...
According to log, I think ipu1 boot failed or IPC can not connect with others. could you give me some comments to let IPU1 and IPU2 boot at the same time when A15 run Linux. Thanks a lot!
