GingerBread-2.3-DevKit-1.0 on DM3730 responses slowly
Other Parts Discussed in Thread: DM3730
i'm using prbuilt kernel and filesystem of AM37X fom TI-Android-GingerBread-2.3-DevKit-1.0.tar.gz on DM3730 EVM board.
When I put filesystem in an SD card, Android comes up successfully, and evrything else is OK.
But when I tried to mount NFS filesystem, Android brings up after very-very long time, and the GUI response after a very-very long time after a tap on the touch screen.
I'm wondering if  there's some problem with the Ethernet driver of DM3730?
thanks.
  • Do you see the same issue with the Android Froyo images also?
  • I have the same issue.
    2.3 for AM is quite slow if you run it on DM.
    But with froyo(2.2), the  prebuild image for AM works well also on DM(I know it without dsp)
  • Yeah, only the froyo version has the problem.
  • I found something from ddms of android sdk when booting from NFS:
    01-01 00:54:34.054: ERROR/ActivityManager(1339): ANR in com.android.email
    01-01 00:54:34.054: ERROR/ActivityManager(1339): Reason: Executing service com.android.email/.service.EmailBroadcastProcessorService
    01-01 00:54:34.054: ERROR/ActivityManager(1339): Load: 2.78 / 2.66 / 1.81
    01-01 00:54:34.054: ERROR/ActivityManager(1339): CPU usage from 59178ms to -792ms ago:
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0.8% 298/rpciod/0: 0% user + 0.8% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0.7% 1492/com.android.email: 0.3% user + 0.3% kernel / faults: 1487 minor 82 major
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0.6% 1339/system_server: 0.3% user + 0.2% kernel / faults: 1093 minor 63 major
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0.3% 1501/android.process.media: 0.2% user + 0.1% kernel / faults: 337 minor 10 major
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0.1% 894/adbd: 0% user + 0.1% kernel / faults: 1 minor
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 311/nfsiod: 0% user + 0% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 1456/android.process.acore: 0% user + 0% kernel / faults: 70 minor
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 5/events/0: 0% user + 0% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 978/logcat: 0% user + 0% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 6/khelper: 0% user + 0% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 883/servicemanager: 0% user + 0% kernel / faults: 4 minor
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 1326/zygote: 0% user + 0% kernel / faults: 17 minor
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 1422/com.android.phone: 0% user + 0% kernel / faults: 33 minor 16 major
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   0% 1425/com.android.launcher: 0% user + 0% kernel / faults: 58 minor
    01-01 00:54:34.054: ERROR/ActivityManager(1339):  +0% 1515/com.android.bluetooth: 0% user + 0% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339): 99% TOTAL: 1.3% user + 1.6% kernel + 96% iowait + 0% irq + 0.8% softirq
    01-01 00:54:34.054: ERROR/ActivityManager(1339): CPU usage from 2231ms to 2758ms later:
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   9.4% 1339/system_server: 5.6% user + 3.7% kernel / faults: 88 minor
    01-01 00:54:34.054: ERROR/ActivityManager(1339):     7.5% 1441/Binder Thread #: 5.6% user + 1.8% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339):     5.6% 1353/ActivityManager: 1.8% user + 3.7% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339):     1.8% 1344/Compiler: 1.8% user + 0% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339):   1.8% 298/rpciod/0: 0% user + 1.8% kernel
    01-01 00:54:34.054: ERROR/ActivityManager(1339): 100% TOTAL: 7.6% user + 1.9% kernel + 90% iowait
    01-01 00:54:34.539: INFO/Process(1339): Sending signal. PID: 1492 SIG: 9
    01-01 00:54:34.734: INFO/ActivityManager(1339): Process com.android.email (pid 1492) has died.
    01-01 00:54:34.742: WARN/ActivityManager(1339): Scheduling restart of crashed service com.android.email/com.android.exchange.SyncManager in 5000ms
    01-01 00:54:34.750: WARN/ActivityManager(1339): Scheduling restart of crashed service com.android.email/.service.EmailBroadcastProcessorService in 116012ms
    from the cpu's iowait percentage, I guess the problem is probably caused by the ethernet drivers.
