Hi, when I run the app "vision_apps_init.sh", there is an error keeps appearing: EnetPhy_enableState: PHY 0: no supported caps found; EnetPhy_enableState: PHY 3: no supported caps found.
There are the app and log:
export VX_TEST_DATA_PATH=/opt/vision_apps/test_data # Location of DLR library export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib:/usr/lib/python3.8/site-packages/dlr # Location of the input data for PTK demos export TIAP_DATABASE_PATH=/opt/vision_apps/test_data_ptk # Location of the input data for Stereo demo export APP_STEREO_DATA_PATH=$VX_TEST_DATA_PATH/psdkra/stereo_test_data # APP config path for PTK demos export APP_CONFIG_BASE_PATH=/opt/vision_apps/ptk_app_cfg /opt/vision_apps/vx_app_arm_remote_log.out &
root@TDA4-Board:/opt/vision_apps# source ./vision_apps_init.sh root@TDA4-Board:/opt/vision_apps# [MCU2_0] 3.583914 s: CIO: Init ... Done !!! [MCU2_0] 3.583995 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [MCU2_0] 3.584042 s: APP: Init ... !!! [MCU2_0] 3.584063 s: SCICLIENT: Init ... !!! [MCU2_0] 3.585223 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [MCU2_0] 3.585276 s: SCICLIENT: DMSC FW revision 0x14 [MCU2_0] 3.585304 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 3.585329 s: SCICLIENT: Init ... Done !!! [MCU2_0] 3.585350 s: UDMA: Init ... !!! [MCU2_0] 3.595314 s: UDMA: Init ... Done !!! [MCU2_0] 3.595371 s: MEM: Init ... !!! [MCU2_0] 3.595412 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e1000000 of size 16777216 bytes !!! [MCU2_0] 3.595472 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 131072 bytes !!! [MCU2_0] 3.595522 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d8000000 of size 16777216 bytes !!! [MCU2_0] 3.595570 s: MEM: Init ... Done !!! [MCU2_0] 3.595590 s: IPC: Init ... !!! [MCU2_0] 3.595625 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 3.595661 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 8.002360 s: IPC: HLOS is ready !!! [MCU2_0] 8.017698 s: IPC: Init ... Done !!! [MCU2_0] 8.017778 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 8.019960 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 8.020152 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 8.022251 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 8.022383 s: ETHFW: Init ... !!! [MCU2_0] 8.063807 s: CPSW_9G Test on MAIN NAVSS [MCU2_0] 8.087773 s: EnetPhy_bindDriver: PHY 0: OUI:000732 Model:33 Ver:00 <-> 'generic' : OK [MCU2_0] 8.088116 s: EnetPhy_bindDriver: PHY 3: OUI:000732 Model:33 Ver:00 <-> 'generic' : OK [MCU2_0] 8.088354 s: PHY 0 is alive [MCU2_0] 8.088416 s: PHY 1 is alive [MCU2_0] 8.088442 s: PHY 2 is alive [MCU2_0] 8.088464 s: PHY 3 is alive [MCU2_0] 8.090371 s: ETHFW: Version : 0.01.01 [MCU2_0] 8.090451 s: ETHFW: Build Date: Nov 22, 2021 [MCU2_0] 8.090480 s: ETHFW: Build Time: 15:51:17 [MCU2_0] 8.090500 s: ETHFW: Commit SHA: [MCU2_0] 8.090526 s: ETHFW: Init ... DONE !!! [MCU2_0] 8.090551 s: ETHFW: Remove server Init ... !!! [MCU2_0] 8.092090 s: Remote demo device (core : mcu2_0) ..... [MCU2_0] 8.092161 s: ETHFW: Remove server Init ... DONE !!! [MCU2_0] 8.116992 s: Host MAC address: 70:ff:76:1d:92:c2 [MCU2_0] 8.141285 s: FVID2: Init ... !!! [MCU2_0] 8.141420 s: FVID2: Init ... Done !!! [MCU2_0] 8.141474 s: DSS: Init ... !!! [MCU2_0] 8.141520 s: DSS: Display type is eDP !!! [MCU2_0] 8.141551 s: DSS: SoC init ... !!! [MCU2_0] 8.141572 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2 [MCU2_0] 8.143049 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.143101 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2 [MCU2_0] 8.145224 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.145273 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2 [MCU2_0] 8.146639 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.146678 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11 [MCU2_0] 8.147298 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 8.147337 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18 [MCU2_0] 8.147826 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 8.147860 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2 [MCU2_0] 8.148390 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 8.148432 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000 [MCU2_0] 8.168265 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success [MCU2_0] 8.168304 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0 [MCU2_0] 8.168789 s: SCICLIENT: Sciclient_pmModuleClkRequest success [MCU2_0] 8.168822 s: DSS: SoC init ... Done !!! [MCU2_0] 8.168847 s: DSS: Board init ... !!! [MCU2_0] 8.168869 s: DSS: Board init ... Done !!! [MCU2_0] 8.195541 s: DSS: Init ... Done !!! [MCU2_0] 8.195619 s: VHWA: VPAC Init ... !!! [MCU2_0] 8.195649 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 8.196464 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.196511 s: VHWA: LDC Init ... !!! [MCU2_0] 8.210750 s: VHWA: LDC Init ... Done !!! [MCU2_0] 8.210816 s: VHWA: MSC Init ... !!! [MCU2_0] 8.255039 s: VHWA: MSC Init ... Done !!! [MCU2_0] 8.255115 s: VHWA: NF Init ... !!! [MCU2_0] 8.263457 s: VHWA: NF Init ... Done !!! [MCU2_0] 8.263529 s: VHWA: VISS Init ... !!! [MCU2_0] 8.297380 s: VHWA: VISS Init ... Done !!! [MCU2_0] 8.297447 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 8.297489 s: VX_ZONE_INIT:Enabled [MCU2_0] 8.297514 s: VX_ZONE_ERROR:Enabled [MCU2_0] 8.297535 s: VX_ZONE_WARNING:Enabled [MCU2_0] 8.298803 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target IPU1-0 [MCU2_0] 8.299174 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_NF [MCU2_0] 8.299585 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_LDC1 [MCU2_0] 8.299964 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC1 [MCU2_0] 8.300392 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC2 [MCU2_0] 8.300815 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_VISS1 [MCU2_0] 8.301187 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE1 [MCU2_0] 8.301632 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE2 [MCU2_0] 8.302035 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY1 [MCU2_0] 8.302469 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY2 [MCU2_0] 8.302835 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CSITX [MCU2_0] 8.303214 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE3 [MCU2_0] 8.303671 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE4 [MCU2_0] 8.304082 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE5 [MCU2_0] 8.304550 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE6 [MCU2_0] 8.304964 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE7 [MCU2_0] 8.305388 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE8 [MCU2_0] 8.305455 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [MCU2_0] 8.305489 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 8.319369 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 8.319438 s: CSI2RX: Init ... !!! [MCU2_0] 8.319467 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 8.319997 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.320039 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2 [MCU2_0] 8.320856 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.320896 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2 [MCU2_0] 8.321863 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.321903 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2 [MCU2_0] 8.322445 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.322484 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2 [MCU2_0] 8.323021 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.326325 s: CSI2RX: Init ... Done !!! [MCU2_0] 8.326385 s: CSI2TX: Init ... !!! [MCU2_0] 8.326411 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 8.326849 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.326886 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2 [MCU2_0] 8.327849 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.327896 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2 [MCU2_0] 8.328707 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 8.332056 s: CSI2TX: Init ... Done !!! [MCU2_0] 8.332120 s: ISS: Init ... !!! [MCU2_0] 8.332160 s: IssSensor_Init ... Done !!! [MCU2_0] 8.332287 s: vissRemoteServer_Init ... Done !!! [MCU2_0] 8.332379 s: IttRemoteServer_Init ... Done !!! [MCU2_0] 8.332414 s: UDMA Copy: Init ... !!! [MCU2_0] 8.340464 s: UDMA Copy: Init ... Done !!! [MCU2_0] 8.340545 s: APP: Init ... Done !!! [MCU2_0] 8.340575 s: APP: Run ... !!! [MCU2_0] 8.340595 s: IPC: Starting echo test ... [MCU2_0] 8.343313 s: APP: Run ... Done !!! [MCU2_0] 8.346171 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[.] C66X_2[P] C7X_1[.] [MCU2_0] 8.346548 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 8.346723 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 8.346872 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_0] 8.388511 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 8.388751 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 8.488510 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 8.488759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 8.588509 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 8.588754 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 8.688519 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 8.688758 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 8.788513 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 8.788760 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 8.888512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 8.888771 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 8.988515 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 8.988760 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.088526 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.088767 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.188517 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.188765 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.237322 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6 [MCU2_0] 9.288525 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.288772 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.388523 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.388767 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.488523 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.488769 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.588523 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.588766 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.688501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.688763 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.788528 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.788766 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.888532 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.888785 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 9.988499 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 9.988742 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.088504 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.088758 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.188501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.188760 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.288499 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.288751 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.388538 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.388781 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.488504 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.488760 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.588509 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.588752 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.688500 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.688750 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.788511 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.788757 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.888515 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.888760 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 10.988504 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 10.988750 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.019924 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a37518d4,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 11.023240 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:11, Policer Entry:0 [MCU2_0] 11.023698 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a37518d4,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 11.026995 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:12, Policer Entry:1 [MCU2_0] 11.027402 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a37518d4,CoreKey:38acb7e6, MacAddress:1:1b:19:0:0:0, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 11.030762 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:13, Policer Entry:2 [MCU2_0] 11.031191 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a37518d4,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:6b, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 11.034522 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:14, Policer Entry:3 [MCU2_0] 11.034916 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a37518d4,CoreKey:38acb7e6, MacAddress:1:0:5e:0:1:81, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 11.038212 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:15, Policer Entry:4 [MCU2_0] 11.039901 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a37518d4,CoreKey:38acb7e6, MacAddress:1:0:5e:7f:0:1, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 11.043207 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:16, Policer Entry:5 [MCU2_0] 11.063528 s: Function:CpswProxyServer_registerIpv4MacHandlerCb,HostId:0,Handle:a37518d4,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1 IPv4Addr:192.168.5.120 [MCU2_0] 11.063715 s: Failed to add Static ARP Entry [MCU2_0] 11.063786 s: [MCU2_0] ================LLI Table entries=========== [MCU2_0] 11.063825 s: [MCU2_0] Number of Static ARP Entries: 0 [MCU2_0] 11.063852 s: [MCU2_0] SNo. IP Address MAC Address [MCU2_0] 11.063877 s: ------ ------------- --------------- [MCU2_0] 11.088507 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.088752 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.188510 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.188757 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.288512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.288755 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.388513 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.388755 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.488512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.488757 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.588512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.588758 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.688514 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.688759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.788517 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.788791 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.888519 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.888762 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 11.988516 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 11.988762 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 12.088518 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 12.088766 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 12.188486 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 12.188736 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 12.288492 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 12.288734 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 12.388525 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 12.388799 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 12.488490 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 12.488740 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 12.588492 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 176.361440 s: DHCP client timed out. Retrying..... [MCU2_1] 3.614179 s: CIO: Init ... Done !!! [MCU2_1] 3.614259 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [MCU2_1] 3.614302 s: APP: Init ... !!! [MCU2_1] 3.614323 s: SCICLIENT: Init ... !!! [MCU2_1] 3.615428 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [MCU2_1] 3.615477 s: SCICLIENT: DMSC FW revision 0x14 [MCU2_1] 3.615503 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 3.615527 s: SCICLIENT: Init ... Done !!! [MCU2_1] 3.615547 s: UDMA: Init ... !!! [MCU2_1] 3.627130 s: UDMA: Init ... Done !!! [MCU2_1] 3.627186 s: MEM: Init ... !!! [MCU2_1] 3.627225 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e2000000 of size 16777216 bytes !!! [MCU2_1] 3.627308 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3620000 of size 131072 bytes !!! [MCU2_1] 3.627372 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ d9000000 of size 117440512 bytes !!! [MCU2_1] 3.627420 s: MEM: Init ... Done !!! [MCU2_1] 3.627440 s: IPC: Init ... !!! [MCU2_1] 3.627472 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 3.627510 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 7.954583 s: IPC: HLOS is ready !!! [MCU2_1] 7.966840 s: IPC: Init ... Done !!! [MCU2_1] 7.966910 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 8.019961 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 8.020149 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 8.021996 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 8.022076 s: FVID2: Init ... !!! [MCU2_1] 8.022149 s: FVID2: Init ... Done !!! [MCU2_1] 8.022183 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 8.022204 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 8.023136 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 8.023185 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 8.026406 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 8.026446 s: VHWA: DOF Init ... !!! [MCU2_1] 8.075655 s: VHWA: DOF Init ... Done !!! [MCU2_1] 8.075722 s: VHWA: SDE Init ... !!! [MCU2_1] 8.092616 s: VHWA: SDE Init ... Done !!! [MCU2_1] 8.092689 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 8.092725 s: VHWA: Codec: Init ... !!! [MCU2_1] 8.092744 s: VHWA: VDEC Init ... !!! [MCU2_1] 8.108872 s: VHWA: VDEC Init ... Done !!! [MCU2_1] 8.108942 s: VHWA: VENC Init ... !!! [MCU2_1] 8.110123 s: MM_ENC_Init: No OCM RAM pool available, fallback to DDR mode for above mp params [MCU2_1] 8.170048 s: VHWA: VENC Init ... Done !!! [MCU2_1] 8.170106 s: VHWA: Init ... Done !!! [MCU2_1] 8.170145 s: VX_ZONE_INIT:Enabled [MCU2_1] 8.170171 s: VX_ZONE_ERROR:Enabled [MCU2_1] 8.170192 s: VX_ZONE_WARNING:Enabled [MCU2_1] 8.171420 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DMPAC_SDE [MCU2_1] 8.171697 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DMPAC_DOF [MCU2_1] 8.171948 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VDEC1 [MCU2_1] 8.172186 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VDEC2 [MCU2_1] 8.172477 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VENC1 [MCU2_1] 8.172734 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VENC2 [MCU2_1] 8.172787 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [MCU2_1] 8.172816 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 8.173251 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 8.173348 s: UDMA Copy: Init ... !!! [MCU2_1] 8.180495 s: UDMA Copy: Init ... Done !!! [MCU2_1] 8.180555 s: APP: Init ... Done !!! [MCU2_1] 8.180581 s: APP: Run ... !!! [MCU2_1] 8.180599 s: IPC: Starting echo test ... [MCU2_1] 8.182852 s: APP: Run ... Done !!! [MCU2_1] 8.184408 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 8.184524 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 8.184608 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 8.345937 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 3.667400 s: CIO: Init ... Done !!! [C6x_1 ] 3.667436 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz> [C6x_1 ] 3.667450 s: APP: Init ... !!! [C6x_1 ] 3.667458 s: SCICLIENT: Init ... !!! [C6x_1 ] 3.668697 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C6x_1 ] 3.668714 s: SCICLIENT: DMSC FW revision 0x14 [C6x_1 ] 3.668723 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 3.668733 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 3.668742 s: UDMA: Init ... !!! [C6x_1 ] 3.683039 s: UDMA: Init ... Done !!! [C6x_1 ] 3.683063 s: MEM: Init ... !!! [C6x_1 ] 3.683077 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e4000000 of size 16777216 bytes !!! [C6x_1 ] 3.683096 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 3.683113 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e5000000 of size 50331648 bytes !!! [C6x_1 ] 3.683130 s: MEM: Init ... Done !!! [C6x_1 ] 3.683138 s: IPC: Init ... !!! [C6x_1 ] 3.683153 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 3.683167 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 7.788927 s: IPC: HLOS is ready !!! [C6x_1 ] 7.821833 s: IPC: Init ... Done !!! [C6x_1 ] 7.821864 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 8.019958 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 8.019970 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 8.020856 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 8.020921 s: VX_ZONE_INIT:Enabled [C6x_1 ] 8.020934 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 8.020943 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 8.022056 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [C6x_1 ] 8.022077 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 8.022495 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 8.022515 s: UDMA Copy: Init ... !!! [C6x_1 ] 8.044604 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 8.044634 s: APP: Init ... Done !!! [C6x_1 ] 8.050450 s: APP: Run ... !!! [C6x_1 ] 8.050463 s: IPC: Starting echo test ... [C6x_1 ] 8.051680 s: APP: Run ... Done !!! [C6x_1 ] 8.052072 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 8.053119 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 8.184117 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 8.345749 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 3.710411 s: CIO: Init ... Done !!! [C6x_2 ] 3.710447 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz> [C6x_2 ] 3.710462 s: APP: Init ... !!! [C6x_2 ] 3.710470 s: SCICLIENT: Init ... !!! [C6x_2 ] 3.711583 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C6x_2 ] 3.711599 s: SCICLIENT: DMSC FW revision 0x14 [C6x_2 ] 3.711609 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 3.711620 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 3.711629 s: UDMA: Init ... !!! [C6x_2 ] 3.725670 s: UDMA: Init ... Done !!! [C6x_2 ] 3.725695 s: MEM: Init ... !!! [C6x_2 ] 3.725709 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ e8000000 of size 16777216 bytes !!! [C6x_2 ] 3.725729 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 3.725746 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e9000000 of size 50331648 bytes !!! [C6x_2 ] 3.725763 s: MEM: Init ... Done !!! [C6x_2 ] 3.725772 s: IPC: Init ... !!! [C6x_2 ] 3.725787 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 3.725801 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 7.790581 s: IPC: HLOS is ready !!! [C6x_2 ] 7.825304 s: IPC: Init ... Done !!! [C6x_2 ] 7.825338 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 8.019958 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 8.019971 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 8.020892 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 8.020949 s: VX_ZONE_INIT:Enabled [C6x_2 ] 8.020962 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 8.020974 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 8.022065 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [C6x_2 ] 8.022087 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 8.022502 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 8.022522 s: UDMA Copy: Init ... !!! [C6x_2 ] 8.045705 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 8.045729 s: APP: Init ... Done !!! [C6x_2 ] 8.051281 s: APP: Run ... !!! [C6x_2 ] 8.051292 s: IPC: Starting echo test ... [C6x_2 ] 8.052676 s: APP: Run ... Done !!! [C6x_2 ] 8.053116 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 8.053155 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 8.184153 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 8.345787 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 3.796385 s: CIO: Init ... Done !!! [C7x_1 ] 3.796410 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [C7x_1 ] 3.796426 s: APP: Init ... !!! [C7x_1 ] 3.796434 s: SCICLIENT: Init ... !!! [C7x_1 ] 3.797512 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C7x_1 ] 3.797528 s: SCICLIENT: DMSC FW revision 0x14 [C7x_1 ] 3.797539 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 3.797550 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 3.797559 s: UDMA: Init ... !!! [C7x_1 ] 3.808715 s: UDMA: Init ... Done !!! [C7x_1 ] 3.808729 s: MEM: Init ... !!! [C7x_1 ] 3.808742 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ 100000000 of size 1073741824 bytes !!! [C7x_1 ] 3.808764 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 3.808783 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 491520 bytes !!! [C7x_1 ] 3.808800 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 3.808818 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ ec000000 of size 268435456 bytes !!! [C7x_1 ] 3.808836 s: MEM: Init ... Done !!! [C7x_1 ] 3.808844 s: IPC: Init ... !!! [C7x_1 ] 3.808855 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 3.808869 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 8.006250 s: IPC: HLOS is ready !!! [C7x_1 ] 8.019923 s: IPC: Init ... Done !!! [C7x_1 ] 8.019941 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 8.019957 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 8.019971 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 8.020329 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 8.020356 s: VX_ZONE_INIT:Enabled [C7x_1 ] 8.020433 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 8.020447 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 8.020731 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! [C7x_1 ] 8.020747 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 8.020874 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 8.020897 s: APP: Init ... Done !!! [C7x_1 ] 8.020911 s: APP: Run ... !!! [C7x_1 ] 8.020923 s: IPC: Starting echo test ... [C7x_1 ] 8.021486 s: APP: Run ... Done !!! [C7x_1 ] 8.052055 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s] [C7x_1 ] 8.053109 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 8.184181 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 8.345842 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [MCU2_0] 795.388497 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 795.388743 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 795.488500 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 795.488744 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 795.588500 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 795.588747 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 795.688500 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 795.688749 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 795.788500 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 795.788747 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 795.888503 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 795.888748 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 795.988503 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 795.988748 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.088505 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.088752 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.188506 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.188750 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.288506 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.288754 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.388507 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.388756 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.488509 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.488755 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.588510 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.588759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.688511 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.688759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.788512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.788757 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.888514 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.888756 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 796.988515 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 796.988758 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.088513 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.088764 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.188515 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.188763 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.288516 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.288765 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.388519 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.388765 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.488489 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.488739 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.588489 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.588742 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.688489 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.688736 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.788495 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.788737 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.888494 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.888742 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 797.988494 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 797.988741 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.088493 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.088741 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.188498 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.188746 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.288498 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.288745 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.388503 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.388744 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.488501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.488746 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.588499 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.588748 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.688499 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.688750 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.788501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.788753 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.888504 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.888748 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 798.988504 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 798.988753 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.088507 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.088752 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.188505 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.188756 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.288507 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.288759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.388511 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.388759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.488509 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.488759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.588510 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.588759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.688512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.688761 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.788512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.788758 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.888516 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.888760 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 799.988516 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 799.988761 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.088518 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.088762 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.188516 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.188764 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.288520 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.288763 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.388522 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.388770 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.488491 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.488740 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.588492 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.588738 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.688492 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.688739 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.788495 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.788739 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.888493 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.888743 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 800.988494 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 800.988743 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.088497 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.088744 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.188500 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.188748 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.288501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.288746 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.388500 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.388747 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.488501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.488746 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.588502 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.588747 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.688501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.688747 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.788505 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.788749 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.888506 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.888754 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 801.988509 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 801.988751 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.088508 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.088755 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.188507 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.188757 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.288511 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.288758 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.388513 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.388762 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.488512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.488758 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.588514 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.588761 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.688514 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.688761 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.788514 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.788762 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.888519 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.888763 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 802.988520 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 802.988764 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.088489 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.088737 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.188489 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.188736 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.288521 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.288766 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.388522 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.388739 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.488494 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.488736 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.588495 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.588736 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.688494 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.688738 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.788496 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.788741 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.888496 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.888745 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 803.988499 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 803.988743 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.088499 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.088745 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.188501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.188747 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.288504 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.288751 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.388505 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.388749 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.488501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.488751 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.588505 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.588749 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.688502 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.688756 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.788508 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.788755 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.888509 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.888756 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 804.988508 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 804.988754 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.088512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.088755 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.188510 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.188760 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.288512 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.288759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.388513 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.388762 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.488514 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.488759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.588516 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.588759 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.688519 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.688760 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.788516 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.788764 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.888519 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.888765 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 805.988520 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 805.988765 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.088489 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.088739 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.188489 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.188738 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.288493 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.288740 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.388526 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.388770 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.488497 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.488741 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.588496 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.588744 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.688491 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.688712 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.788497 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.788746 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.888499 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.888747 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 806.988500 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 806.988749 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 807.088502 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 807.088749 s: EnetPhy_enableState: PHY 3: no supported caps found [MCU2_0] 807.188501 s: EnetPhy_enableState: PHY 0: no supported caps found [MCU2_0] 807.188746 s: EnetPhy_enableState: PHY 3: no supported caps found
Can you help to see what causes this error?
