I have been trying to do the SI simulation in one of the board, where the processor chip used is AM5K2E04, i have used the IBIS of this processor model but it is generating error while validating.
This the output report:-
C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs(65492) : Warning : Messages for model PDIFF_D3FF3L_ODT120:
;; Warning: Current (-0.00500232) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground.
C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs(65717) : Warning : Messages for model PDIFF_D3FF3L_ODT40:
;; Warning: Current (0.0129819) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground.
;; Warning: Current (0.0122152) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground.
;; Warning: Current (0.0149212) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground.
C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs(65942) : Warning : Messages for model PDIFF_D3FF3L_ODT60:
;; Warning: Current (0.00881084) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground.
;; Warning: Current (0.00814358) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground.
;; Warning: Current (0.0097348) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground.
C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs(211043) : Error : Pin model s_iclkrx0p9gh used by the series pin mapping from pin AM2 to pin AN3 of component 66ak2e05 does not exist in this file.
C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs(211043) : Error : Pin model s_iclkrx0p9gh used by the series pin mapping from pin AF1 to pin AG1 of component 66ak2e05 does not exist in this file.
C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs(211043) : Error : Pin model s_iclkrx0p9gh used by the series pin mapping from pin U4 to pin T4 of component 66ak2e05 does not exist in this file.
C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs(211043) : Error : Pin model s_iclkrx0p9gv used by the series pin mapping from pin AJ24 to pin AJ25 of component 66ak2e05 does not exist in this file.
C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs(211043) : Error : Pin model s_iclkrx0p9gh used by the series pin mapping from pin G4 to pin G3 of component 66ak2e05 does not exist in this file.
Error : Parse failed on file C:/Users/admin/AppData/Local/Temp/ibsA543.tmp/am5k2e04_02_r1p2.ibs.
C:\Users\admin\AppData\Local\Temp\ibsA543.tmp\am5k2e04_02_r1p2.ibs - 6 error(s), 18 warnings(s)
Kindly have a look and help me this
Thanks and regards
Karthik Pillai
