Dear all,
I am currently using DM37X EVM and I want to use IVA2.2 to config the McSPI2. But I could not access the McSPI registers.
I write to MCSPI_SYSCONFIG reg and read back, then I found the value does not match.
I had tried *(volatile *Uint32)(MCSPI_SYSCONFIG) , view->register->McSPI2 and view->memory but none of them is effictive.
I have already enable the EN_MCSPI2 bit in CM_FCLKEN1_CORE and CM_ICLKEN1_CORE reg. Then I check the configuration of DPLL4 which provide the 48M_FCLK to McSPI module and found CM_CLKEN2_PLL (0x0x48004D04) == 0x02400000 which means DPLL4 has not been configed properly.
I use CCS V4.2 and the gel file in DM3730-25_GELs_CCSv4.zip (You can find this in ti wiki).
Your helps will be very beneficial.
Thank you.
