TDA3MV: DDR3 Memory address remapping issue
Part Number: TDA3MV
Hi team,
The TDA3MV hardware design replaces the DDR3 memory chip, such as 128M memory on the development board, customers change to 1G memory in the design, so the customer would like to know what changes should do for memory remapping on sdk?
The VisionSDK_UserGuide_MemoryMap.pdf document only explain some issues of TDA2x, but the TDA3x is very different from it. Is it possible to give some specific instructions on the TDA3x, such as which sections of the file need to be changed, and so on.
Could you help check this case? Thanks.
Cherry
