TDA4VM: Can we use the OSPI as simple SPI with CLK MISO MOSI CSn in the usual duplex mode?
Part Number: TDA4VM
The TRM describes this case:
However, we are not sure if this works in the usual SPI duplex mode where the TDA4VM SPI master outputs the write data to MOSI (DQ0) and simultaneously reads the data to MISO (DQ1).
(We running out of standard SPI ports on the right power/voltage domain. We do not need Flash on the OSPI ports.)
Many thanks in advance!
