Are there any problem with my debug infomation about DM368 H264 V2.1 ?
In my DM368,I had a problem.
The program started and runned ok at first.But it stopped after some time.
I found the program stopped  at "VIDENC1_process()".
I turned on the debug infomation of the dvsdk.
/dvsdk_2_10_01_18_2.1/dm365_codecs_01_00_06/packages/ti/sdo/codecs/h264enc
/package.xe h264venc_ti_arm926.a h264venc_ti_arm926_debug.a
But the debug infomation seemed no problem.
The resolution is 2176X1760.
The debug infomation:
AVSERVER UI: Initializing.
 AVSERVER API: Creating TSKs.
DRV_SyncRst: module = 47, domain = 0, state = 0
DRV_SyncRst: module = 47, domain = 0, state = 3
 CLK Hz,
 ARM   Hz =  432000000
 DDR   Hz =  340000000
 VPSS  Hz =  340000000
 IMCOP Hz =  340000000
 [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
 AVSERVER API: Creating TSKs...DONE
CONFIGURING AVSERVER FOR DM368 .....
 AVSERVER API: Sending START.
 AVSERVER MAIN: Recevied CMD = 0x0400, state = 0x0000
 AVSERVER MAIN: AVSERVER_tskConnectInit() ...
 AVSERVER MAIN: Create captureTsk ...
 CAPTURE: Recevied CMD = 0x0300
 CAPTURE: Create...
 CAPTURE: Opening capture on imager FPGA_KYLIN.
SENSOR FPS VALUE = 25
gDRV_isifObj.imgsModeInfo.validWidth is 2176,gDRV_isifObj.imgsModeInfo.validHeight is 1760,gDRV_isifObj.info.ddrOutDataOffsetH is 4352
 CAPTURE: Create...DONE
 AVSERVER MAIN: Create encodeTsk ...
 ENCODE: Recevied CMD = 0x0300
 ENCODE: Create...
CODEC_DEBUG_ENABLE: Inside Funtion to get memtab Requirement -> H264VENC_TI_numAlloc
CODEC_DEBUG_ENABLE: Number of memtabs required: 15
CODEC_DEBUG_ENABLE: Inside Funtion to Get Memory Requirements of the current algoirthm  instance -> H264VENC_TI_alloc
CODEC_DEBUG_ENABLE: H264VENC_TI_Obj-memTab[0].size =   0x0710
CODEC_DEBUG_ENABLE: tH264EncState-memTab[1].size =   0x1670
CODEC_DEBUG_ENABLE: tH264EncState-memTab[2].size =   0x1670
CODEC_DEBUG_ENABLE: EXT_MEM_SCRATCH-memTab[3].size =   0x5000
CODEC_DEBUG_ENABLE: EXT_MEM_PERSIST-memTab[4].size =   0x0800
CODEC_DEBUG_ENABLE: MAX_REF_BUFFERS-memTab[5].size =   0xb9cd00
CODEC_DEBUG_ENABLE: LIST_SLICE_SIZES-memTab[6].size =   0x0320
CODEC_DEBUG_ENABLE: uiMaxCodeSize-memTab[7].size =   0xcd78
CODEC_DEBUG_ENABLE: uiMaxCodeSize-memTab[8].size =   0xcd78
CODEC_DEBUG_ENABLE: KALEIDO_COMMANDS-memTab[9].size =   0x10180
CODEC_DEBUG_ENABLE: AIR_BIT_STORAGE-memTab[10].size =   0x20000
CODEC_DEBUG_ENABLE: AIR_BIT_STORAGE-memTab[11].size =   0x40000
CODEC_DEBUG_ENABLE: tStPhysicalAddrHandle-memTab[12].size =  0x0280
CODEC_DEBUG_ENABLE: IMCOP_TO_DDR-memTab[13].size =   0xc000
CODEC_DEBUG_ENABLE: MEGAPIX_IMCOP_TO_DDR-memTab[14].size =   0xa180
CODEC_DEBUG_ENABLE: Exiting Funtion H264VENC_TI_alloc
CODEC_DEBUG_ENABLE: Inside Init Obj Function
CODEC_DEBUG_ENABLE: Intialises the memory allocated for a given handle object instance
CODEC_DEBUG_ENABLE: Checking MemTab Parameters-> Base_Null, Base_Not_Aligned and Overlap
CODEC_DEBUG_ENABLE: Checking MemTab Parameters-> Base_Null, Base_Not_Aligned and Overlap Completed
CODEC_DEBUG_ENABLE: Checking Input parameter Values
CODEC_DEBUG_ENABLE: Checking of Input parameter Completed
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_Copy_codearm968 Function to Copy Code & Data Sections
CODEC_DEBUG_ENABLE: Succesfully Copied Code & Data Sections
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_Copy_codearm968_3 Function to Copy Code & Data Sections
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_Copy_codearm968_2 Function to Copy Code & Data Sections
CODEC_DEBUG_ENABLE: Initializing SPS parameters
CODEC_DEBUG_ENABLE: SPS parameters initialization Completed
CODEC_DEBUG_ENABLE: Initializing PPS parameters
CODEC_DEBUG_ENABLE: Inside Slice Initilization Call
CODEC_DEBUG_ENABLE: Slice Initilization Completed
CODEC_DEBUG_ENABLE: Inside IRES Call to get Number of Resources -> H264VENC_TI_numResourceDescriptors
CODEC_DEBUG_ENABLE: Number of Resources Required - 50
CODEC_DEBUG_ENABLE: Inside IRES Call to Get Resource -> H264VENC_TI_getResouceDescriptors
CODEC_DEBUG_ENABLE: Exiting IRES Call to Get Resource function
CODEC_DEBUG_ENABLE: Inside DDR allocation
CODEC_DEBUG_ENABLE: Inside IRES Call to Init Resource -> H264VENC_TI_initResources
CODEC_DEBUG_ENABLE: Resource Number - 0
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 12
CODEC_DEBUG_ENABLE: Assigned Number of TCs: 1
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564180
CODEC_DEBUG_ENABLE: Resource Number - 1
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 13
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405641a0
CODEC_DEBUG_ENABLE: Resource Number - 2
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 14
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405641c0
CODEC_DEBUG_ENABLE: Resource Number - 3
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 15
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405641e0
CODEC_DEBUG_ENABLE: Resource Number - 4
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 16
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564200
CODEC_DEBUG_ENABLE: Resource Number - 5
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 17
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564220
CODEC_DEBUG_ENABLE: Resource Number - 6
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 18
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564240
CODEC_DEBUG_ENABLE: Resource Number - 7
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 19
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564260
CODEC_DEBUG_ENABLE: Resource Number - 8
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 20
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564280
CODEC_DEBUG_ENABLE: Resource Number - 9
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 21
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405642a0
CODEC_DEBUG_ENABLE: Resource Number - 10
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 22
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405642c0
CODEC_DEBUG_ENABLE: Resource Number - 11
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 23
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405642e0
CODEC_DEBUG_ENABLE: Resource Number - 12
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 24
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564300
CODEC_DEBUG_ENABLE: Resource Number - 13
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 25
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564320
CODEC_DEBUG_ENABLE: Resource Number - 14
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 28
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564380
CODEC_DEBUG_ENABLE: Resource Number - 15
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 29
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405643a0
CODEC_DEBUG_ENABLE: Resource Number - 16
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 30
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405643c0
CODEC_DEBUG_ENABLE: Resource Number - 17
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 31
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405643e0
CODEC_DEBUG_ENABLE: Resource Number - 18
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 32
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564400
CODEC_DEBUG_ENABLE: Resource Number - 19
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 33
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564420
CODEC_DEBUG_ENABLE: Resource Number - 20
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 34
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564440
CODEC_DEBUG_ENABLE: Resource Number - 21
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 35
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564460
CODEC_DEBUG_ENABLE: Resource Number - 22
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 36
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564480
CODEC_DEBUG_ENABLE: Resource Number - 23
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 37
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405644a0
CODEC_DEBUG_ENABLE: Resource Number - 24
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 38
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405644c0
CODEC_DEBUG_ENABLE: Resource Number - 25
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 39
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405644e0
CODEC_DEBUG_ENABLE: Resource Number - 26
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 40
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564500
CODEC_DEBUG_ENABLE: Resource Number - 27
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 41
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564520
CODEC_DEBUG_ENABLE: Resource Number - 28
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 42
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564540
CODEC_DEBUG_ENABLE: Resource Number - 29
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 43
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564560
CODEC_DEBUG_ENABLE: Resource Number - 30
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 44
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564580
CODEC_DEBUG_ENABLE: Resource Number - 31
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 45
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405645a0
CODEC_DEBUG_ENABLE: Resource Number - 32
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 46
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405645c0
CODEC_DEBUG_ENABLE: Resource Number - 33
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 47
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405645e0
CODEC_DEBUG_ENABLE: Resource Number - 34
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 48
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564600
CODEC_DEBUG_ENABLE: Resource Number - 35
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 49
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564620
CODEC_DEBUG_ENABLE: Resource Number - 36
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 50
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564640
CODEC_DEBUG_ENABLE: Resource Number - 37
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 51
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564660
CODEC_DEBUG_ENABLE: Resource Number - 38
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 52
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564680
CODEC_DEBUG_ENABLE: Resource Number - 39
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 53
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405646a0
CODEC_DEBUG_ENABLE: Resource Number - 40
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 54
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405646c0
CODEC_DEBUG_ENABLE: Resource Number - 41
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 55
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x405646e0
CODEC_DEBUG_ENABLE: Resource Number - 42
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 56
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564700
CODEC_DEBUG_ENABLE: Resource Number - 43
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 57
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564720
CODEC_DEBUG_ENABLE: Resource Number - 44
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 58
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564740
CODEC_DEBUG_ENABLE: Resource Number - 45
CODEC_DEBUG_ENABLE: Assigned Edma Channel Index: 59
CODEC_DEBUG_ENABLE: Assigned Param Space Address: 0x40564760
CODEC_DEBUG_ENABLE: IRES Call to Open EDMA Channel Successfully Completed
CODEC_DEBUG_ENABLE: Inside IMCOP Resource allocation
CODEC_DEBUG_ENABLE: Resource Number - 47
CODEC_DEBUG_ENABLE: HDVICP resoruce alloted
CODEC_DEBUG_ENABLE: Inside Encoder Handle Structure Activate Call -> H264VENC_TI_activate
CODEC_DEBUG_ENABLE: Inside IRES Call to Activate All Resources -> H264VENC_TI_activateAllResources
CODEC_DEBUG_ENABLE: Control Call With SETPARAM Command
CODEC_DEBUG_ENABLE: Control Call With SETPARAM Command Completed Successfully
CODEC_DEBUG_ENABLE: Inside IRES Call to Deactivate All Resources -> H264VENC_TI_deactivateAllResources
CODEC_DEBUG_ENABLE: Inside Encoder Handle Structure Deactivate Call -> H264VENC_TI_deactivate
CODEC_DEBUG_ENABLE: Control Call With GETBUFINFO Command
CODEC_DEBUG_ENABLE: Control Call With GETBUFINFO Command Completed Successfully
fd_emif0 is 23
 AVSERVER MAIN: Create streamTsk ...
 STREAM: Recevied CMD = 0x0300
 STREAM: Create...
 STREAM: Ext 0: 0x0
 STREAM: Ext 1: 0x0
 STREAM: Create...DONE
 AVSERVER MAIN: Allocing Buffers ...
 AVSERVER MAIN: Allocating buffers ...
 AVSERVER MAIN: Stream 0: Allocating Encode IN buffers: 3 of size 5744768 bytes
 AVSERVER MAIN: Allocating FD buffers: 3 of size 128 bytes
 AVSERVER MAIN: Stream 0: Allocating Encrypt buffers: 3 of size 1915904 bytes
 AVSERVER MAIN: Stream 0: Allocating Stream buffers: 3 of size 1915904 bytes
 AVSERVER MAIN: Allocating buffers ...DONE
 AVSERVER MAIN: Start captureTsk ...
 CAPTURE: Start...
 CAPTURE: Start...DONE
 AVSERVER MAIN: Start DONE
 AVSERVER API: Sending START...DONE
 CAPTURE: Isif Buf 0
 ENCODE: Stream 0 InBuf 0 OutBuf 0 (0, 0)
bitrate is 5000000
CODEC_DEBUG_ENABLE: H264VENC_TI_encode function executing..
CODEC_DEBUG_ENABLE: DEVICE ID CHECK completed
CODEC_DEBUG_ENABLE: ROI Enabled
CODEC_DEBUG_ENABLE: SEI USERDATA INSERTION initialization done..
CODEC_DEBUG_ENABLE: H264VENC_TI_Init executed..
CODEC_DEBUG_ENABLE: bitstream initialization done..
CODEC_DEBUG_ENABLE: pAddrHndl computed and stored..
CODEC_DEBUG_ENABLE: reset_vIMCOP_every_frame done..
CODEC_DEBUG_ENABLE: Inside ARM926 H264VENC_TI_Encode_Frame_HeaderGen Function Call
CODEC_DEBUG_ENABLE: Sequence Scaling Flag is 3
CODEC_DEBUG_ENABLE: Seq scaling matrix Copied in to CALC command set
CODEC_DEBUG_ENABLE: Generating the NAL unit containing Sequence Parameter Set SPS
CODEC_DEBUG_ENABLE: Generation of the NAL unit containing Sequence Parameter Set (SPS) Completed
CODEC_DEBUG_ENABLE: Generating the NAL unit containing Picture Parameter Set PPS
CODEC_DEBUG_ENABLE: Generation of NAL unit containing Picture Parameter Set PPS Completed
CODEC_DEBUG_ENABLE: H264V_TI_DMA_Map_TC executed..
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_KALEIDO_PSC_Reset Function
CODEC_DEBUG_ENABLE: Exiting H264VENC_TI_KALEIDO_PSC_Reset Function
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_KALEIDO_PSC_Enable_InitRam_Low Function
CODEC_DEBUG_ENABLE: Exiting H264VENC_TI_KALEIDO_PSC_Enable_InitRam_Low Function
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_Loader_arm968 Function to Load Code & Data Sections
CODEC_DEBUG_ENABLE: DMA of Section 0 and Parameters are:
 Source Address: 0x85168000  Destination Address: 0x12040000  Number of Bytes: 32
CODEC_DEBUG_ENABLE: DMA of Section 1 and Parameters are:
 Source Address: 0x85168020  Destination Address: 0x12040100  Number of Bytes: 43616
CODEC_DEBUG_ENABLE: DMA of Section 2 and Parameters are:
 Source Address: 0x85172a80  Destination Address: 0x12066834  Number of Bytes: 3992
CODEC_DEBUG_ENABLE: DMA of Section 3 and Parameters are:
 Source Address: 0x85173a18  Destination Address: 0x12067acc  Number of Bytes: 104
CODEC_DEBUG_ENABLE: Succesfully Loaded Code & Data Sections
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_KALEIDO_PSC_SyncReset Function
CODEC_DEBUG_ENABLE: Exiting H264VENC_TI_KALEIDO_PSC_SyncReset Function
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_KALEIDO_PSC_Enable Function
CODEC_DEBUG_ENABLE: Exiting H264VENC_TI_KALEIDO_PSC_Enable Function
CODEC_DEBUG_ENABLE: Inside ARM926 H264VENC_TI_Encode_Frame Function Call
CODEC_DEBUG_ENABLE: Physical addresses computed and stored in the structure
CODEC_DEBUG_ENABLE: H264VENC_TI_Encode_Frame Function Executed..
CODEC_DEBUG_ENABLE: Generate interrupt to arm968 using KLD intc
 CAPTURE: Isif Buf 1
 CAPTURE: Isif Buf 2
CODEC_DEBUG_ENABLE: H264VENC_TI_Encode_End calling..
CODEC_DEBUG_ENABLE: Inside ARM926 H264VENC_TI_Encode_End Function Call
CODEC_DEBUG_ENABLE: ARM926 H264VENC_TI_Encode_End Function Executed
CODEC_DEBUG_ENABLE: H264VENC_TI_Encode_End executed..
CODEC_DEBUG_ENABLE: Updating EncOutParams..
CODEC_DEBUG_ENABLE: H264VENC_TII_encode executed successfully..
 ALGVIDENC  |         100.00 |      10.00 |        100 |            1 |
 ENCODE FRAME 0: Stream 0 Size 68077 bytes Keyframe 1
 ENCODE: Stream 0 InBuf 1 OutBuf 1 (0, 0)
CODEC_DEBUG_ENABLE: Inside H264VENC_TI_Loader_arm968_2 Function to Load Code & Data Sections
