How to which SFR register i should assign the ISR address!!!!!111
hi freinds!!
can you me tell in which register do you store the ISR address.
Please let me know ......
i have the following code for Irq.c
#include "am35xx.h"
#include "types.h"
#include "irq.h"
UL32 install_irq( UL32 IntNumber, void *HandlerAddr, UL32 Priority )
        UL32 *vect_addr;
        UL32 *vect_prio;
    if(IntNumber <= 0  && IntNumber >= 31)
     INTCPS_MIRC0 = 1 << IntNumber ;                                     /* Disable Interrupt */
    else if(IntNumber <= 32  && IntNumber >= 63)
            INTCPS_MIRC1 = 1 << (31 - IntNumber);                    /* Disable Interrupt */
        else if(IntNumber <= 64  && IntNumber >= 95)                /* Disable Interrupt */
           INTCPS_MIRC2 = 1 << (63 - IntNumber);                        /* Disacble Interrupt */
        if ( IntNumber >= MAX_NUM_INT )
        return (FALSE);
        else
       vect_addr = (UL32* )(which register + (what index addr * 4));  <----             i need help at this statement.
        vect_prio = (UL32 *)(ILRM_BASE_ADDR + (IntNumber * 4));
        *vect_prio = Priority;
        *vect_addr = (void)Timer0Handler;
        // code to enable interrupt
        return(TRUE);
   return (0);
http://e2e.ti.com/support/dsp/sitara_arm174_microprocessors/f/416/p/106085/373798.aspx#373798
Link for .h file
